NVMe drives connect over PCIe using a protocol designed for flash storage, not the ATA commands SATA drives use. When an NVMe controller burns out, firmware corrupts, or a power surge kills the voltage regulator, SATA recovery tools cannot help. We use the PC-3000 Portable III with PC-3000 SSD active utilities for Phison and Silicon Motion technological mode entry, with limited Samsung diagnostic access, and hardware-level stabilization for Western Digital and Maxio controllers. M.2 2230, M.2 2280, U.2, and PCIe add-in card form factors. All work in-house at our Austin, TX lab.
NVMe data recovery retrieves files from drives that connect over PCIe, not SATA. NVMe uses Gen3/Gen4/Gen5 x4 lanes across M.2 2280, M.2 2230, U.2, and PCIe add-in card form factors. Recovery requires hardware such as the PC-3000 Portable III, paired with board-level microsoldering for proprietary controllers.
What Is NVMe SSD Data Recovery?
NVMe SSD data recovery retrieves files from Non-Volatile Memory Express solid-state drives that have stopped working. NVMe drives use PCIe lanes instead of SATA cables, which creates different failure points: controller burnout from heat, firmware corruption after power loss, and PCIe lane electrical faults.
Recovery requires specialized hardware that speaks the NVMe protocol. Consumer data recovery software cannot communicate with a failed NVMe controller.
What We Do & What It Costs
A dead modern NVMe drive is a board-repair job before it is a data job. Chip-off usually returns scrambled or encrypted output, so the path to your files is reviving the original controller through microsoldering, then rebuilding the drive's Flash Translation Layer to image the NAND.
How Does NVMe Recovery Work at Our Lab?
We handle the parts of NVMe recovery most labs outsource or skip: board-level controller revival, the encryption-key barrier that kills chip-off, & proprietary FTL reconstruction. All of it runs in-house at our Austin, TX lab. Mail your drive in from anywhere in the country & ship to the same address the technician works at.
Free evaluation
No diagnostic fee. We identify the controller, run a FLIR thermal scan for shorts, & quote a firm bracket before any paid work starts.
Nationwide mail-in
Ship the bare drive to 2410 San Antonio Street, Austin, TX 78705. Single location, no franchises, no outsourcing.
From $200
Published brackets across $200–$2,500. The tier follows the failure mode, not the drive brand or capacity. Jump to pricing.
No data, no recovery fee
If we can't recover usable data, you owe nothing for the recovery work. See the no-fix-no-fee guarantee.
The Process in Three Steps
Free evaluation.Ship the drive in. We identify the controller, scan the board for shorts with a FLIR thermal camera, & send you a firm quote inside the published bracket. No charge for this step.
Board repair & PC-3000 imaging.If the board is dead, we replace the failed PMIC or voltage regulator with a Hakko FM-2032 so the original controller boots. Then the PC-3000 Portable III enters the controller's diagnostic mode, rebuilds the FTL, & images the NAND sector-by-sector.
Data return.We extract your files, verify them against the directory structure, & return them on the media of your choice. No recovery, no recovery fee.
Need the cost first? See the 5 published NVMe pricing brackets. The deeper architecture (why chip-off fails, which controllers have a firmware path, how the PCIe link & FTL break) is documented in the sections below.
NVMe Recovery Turnaround
Turnaround on NVMe recovery follows the failure type, not the drive's capacity. A working drive that only needs its data moved off runs 3-5 business days. Board, firmware, & NAND-transplant cases run several weeks because microsoldering & Flash Translation Layer reconstruction are required before the data is readable.
How Long Does NVMe Data Recovery Take?
Each tier carries a published turnaround window tied to the work it needs. A simple transfer off a healthy drive takes 3-5 business days. A dead board or a corrupted controller takes weeks, because the original controller has to be revived or its NAND moved to a donor board, & the mapping tables rebuilt before a single file is readable.
Capacity does not move these windows: a 256 GB drive & a 4 TB drive with the same failure mode follow the same path. The free evaluation returns a firm quote & bracket before any paid work starts. A rush option is available when a deadline is tight: +$100 rush fee to move to the front of the queue.
Failure type
What you're seeing
Published turnaround
Price bracket
These windows start when paid recovery begins, not at the loading dock. See the full 5 brackets on the pricing table.
Recover or Replace?
Replacing a failed NVMe drive gives you a working drive, not your lost files. Recovery makes sense when the data is irreplaceable & there is no recent backup. The cost tier follows the failure mode, & the no-fix-no-fee guarantee means a failed attempt costs you nothing beyond shipping.
Should You Recover or Replace a Failed NVMe Drive?
A new drive solves one problem: you need working storage again. It does nothing for the files that were on the dead one. If those files exist somewhere else, replacement is the cheaper call & you do not need a lab. If they do not, the question becomes what the data is worth against the cost of getting it back.
That cost is set by the failure mode, not the brand on the label. A functional drive that only needs its data copied off sits at $200. A drive that won't power on lands in the circuit-board-repair bracket at $900–$1,200, & a controller reporting the wrong size or no data sits in the firmware-recovery bracket at $900–$1,200.
There is no diagnostic fee to find out which one you are looking at. The published brackets list every tier.
The no-fix-no-fee guarantee removes the gamble from trying: if we cannot recover usable data, you owe nothing for the recovery work. So the practical order is recover first, then replace. Pull the files off the failed drive, then buy whatever new drive you like. Start with a free evaluation through our contact page & we will tell you the failure mode & the bracket before you commit.
Why NVMe Fails Differently
NVMe drives fail differently than SATA SSDs because NVMe uses a protocol designed for flash: up to 64,000 I/O queues and direct PCIe lane access at speeds exceeding 7,000 MB/s. This creates three failure categories: thermal burnout, power-loss FTL corruption, and encryption-barrier failures that block chip-off extraction.
Why Do NVMe Drives Fail Differently Than SATA SSDs?
NVMe drives fail differently than SATA SSDs because NVMe uses a protocol designed for flash: up to 64,000 I/O queues, memory-mapped doorbell registers, and direct PCIe lane access at speeds exceeding 7,000 MB/s compared to SATA's 600 MB/s. This architectural difference creates three failure categories.
Thermal Failures
NVMe controllers run hotter than SATA controllers. In laptops with restricted M.2 slot airflow, sustained workloads push the controller past its thermal junction limit.
The controller throttles, then shuts down. Repeated thermal cycling weakens solder joints between the BGA controller package and the PCB.
Power Loss Vulnerability
NVMe's higher ingest speed fills the volatile write cache faster than data programs to NAND. More uncommitted data sits in DRAM or Host Memory Buffer at any moment.
A power drop during a Flash Translation Layer update leaves the mapping table in an inconsistent state. Consumer NVMe drives lack power loss protection capacitors.
Encryption Barriers
Many NVMe controllers implement AES-256 hardware encryption, even on drives not marketed as "encrypted." The encryption key is stored in the controller. If the controller dies and cannot be revived, chip-off NAND extraction produces only ciphertext. Board-level repair to restore power delivery to the original controller is the only path to decrypted data.
NVMe vs SATA Recovery Complexity
NVMe recovery is more complex than SATA SSD recovery because NVMe controllers use the PCIe bus with up to 64,000 I/O queues, hardware-bound AES-256 encryption, and vendor-specific firmware. SATA tools that send ATA commands over AHCI cannot communicate with an NVMe controller. Recovery requires hardware such as the PC-3000 Portable III.
How Does NVMe Recovery Differ from SATA SSD Recovery?
NVMe recovery is more complex than SATA SSD recovery because NVMe controllers use the PCIe bus with up to 64,000 I/O queues, hardware-bound AES-256 encryption, and vendor-specific firmware architectures. SATA recovery tools that send ATA commands over AHCI cannot communicate with an NVMe controller at all.
Attribute
SATA SSD Recovery
NVMe SSD Recovery
Protocol & Bus
AHCI over SATA (max 600 MB/s)
NVMe over PCIe (Gen3/Gen4/Gen5, up to 14,000 MB/s)
Command Queues
1 queue, 32 commands
Up to 64,000 queues, 64,000 commands each
Hardware Encryption
Rare on consumer SATA SSDs; often software-based
Common (AES-256 key bound to controller die, even on non-marketed "encrypted" drives)
Chip-Off Viability
Viable on older unencrypted SATA controllers
Not viable on most post-2020 NVMe controllers due to hardware encryption
Diagnostic Tooling
PC-3000 Express / UDMA (ATA command interface)
Recovery Cost Range
$200 and up (SATA SSD)
$200–$2,500 (NVMe SSD)
Board Repair Frequency
Less common; SATA controllers run cooler
More common; NVMe controllers overheat in M.2 slots and fail voltage regulators
The core difference: when a SATA SSD controller fails, chip-off NAND extraction sometimes works as a fallback because many SATA controllers don't encrypt data. Board-level microsoldering to revive the original controller is the only path to decrypted data on most NVMe drives.
Deep Dive: Board Repair & Encryption
Why NVMe Recovery Requires Board Repair First
NVMe data recovery on a dead modern controller is a board-repair job first, a data-extraction job second. The AES-256 Media Encryption Key (MEK) is generated on and bound to the original controller on Phison E18 and E26, Silicon Motion SM2262EN and SM2263XT, and Samsung's in-house controllers, so it never leaves that silicon. If the controller has electrical damage, the only path to the plaintext is microsoldering the original board back to a working state. Swapping the controller, swapping the NAND, or sending the drive to a software-only lab loses the key permanently.
Many premium NVMe controllers apply always-on AES-256 XTS encryption to every page written to NAND, including some drives the manufacturer does not market as self-encrypting. On those encrypted controllers the Media Encryption Key is generated per-drive at first power-on and stored inside a secure hardware boundary on the controller die. There is no external interface that exports it.
Consumer DRAM-less drives often omit hardware encryption entirely; on those the chip-off barrier is proprietary data scrambling and multi-gear LDPC error correction rather than ciphertext.
That single architectural choice collapses three recovery paths that worked on older unencrypted SATA SSDs:
Chip-off NAND extraction produces ciphertext. A standalone NAND programmer reads the raw pages without the key, so the file system never reassembles.
Controller transplant to a donor PCB loses the key. The donor controller has its own MEK and cannot decrypt the original drive's NAND.
Firmware reflash from the manufacturer's update tool can rewrite the FTL metadata that PC-3000 needs for reconstruction. On a panicked controller it usually fails outright and sometimes overwrites the system area.
The remaining path is to repair the original board so the original controller wakes up and decrypts its own NAND. That is microsoldering work: replacing the failed voltage regulator, PMIC, or shorted MLCC capacitor on the existing PCB so the controller die receives clean power and completes its boot sequence. After that, the controller is healthy enough to enter PC-3000 Technological Mode and image the NAND through its own hardware ECC and decryption engines.
Phison E18 (PS5018-E18): why chip-off is dead on this controller
The Phison E18 is the 12 nm, 8-channel NVMe 1.4 controller behind Sabrent Rocket 4 Plus, Seagate FireCuda 530, Corsair MP600 Pro, and dozens of OEM PCIe 4.0 drives. Even on E18 drives that ship without hardware encryption, the controller's LDPC error correction and multi-plane XOR scrambling render raw NAND chip-off dumps effectively unintelligible without the original controller's decoding algorithms.
ACELab lists the PS5018-E18 in the PC-3000 SSD supported-drives list under "Only Repairing," which covers firmware repair (e.g. clearing a SAFE-MODE lock) but does not include FTL rebuild or controller-side decryption of NAND on this generation. The practical recovery path is to repair the original PCB so the original E18 powers up and the drive can boot normally over PCIe and decrypt its own NAND.
If the E18 is dead from an over-voltage event on a primary power rail, or the package substrate cracked from thermal cycling, chip-off the NAND and you get scrambled, LDPC-encoded raw pages that no commercial NAND reader can decode without the original controller. The recovery path is to reflow or replace the failed passive on the original PCB so the original E18 die powers up.
Samsung Elpis (S4LV003): why this controller is even harder
Elpis is the 8-channel in-house controller in the 980 PRO, PM9A1, and PM9A3. It is absent from the ACELab PC-3000 SSD supported-drives list, which means no vendor service-area access, no diagnostic mode entry, and no controller-side decrypt path from the recovery tool we run in this lab.
The MEK is cryptographically bound to the unique hardware silicon of the specific Elpis die that shipped with the drive. Even a working Elpis transplanted from an identical donor drive lacks the unique hardware identifier required to unwrap the original drive's encryption key. We perform diagnostic intake on Elpis-based drives and identify the failure mode. A drive that still enumerates may need only a logical recovery; a dead one is board-level work on the original PCB. We do not chip-off Elpis NAND because the ciphertext output is unrecoverable without the original die.
The same constraint applies on Apple T2 and M-series MacBooks: the encryption key lives in the Secure Enclave on the logic board, the NAND is soldered, and recovery depends on repairing the original logic board so the Secure Enclave functions normally. This is legal board repair, not security circumvention.
Power Failure
M.2 NVMe drives pull 3.3V straight from the motherboard into a tiny onboard PMIC with little board space for surge protection on a 2280 PCB. A power-supply or VRM fault sends a spike down that rail, the PMIC dies as a dead short, & the drive vanishes from BIOS.
Why Do Power Surges Kill NVMe Drives More Often Than SATA?
An M.2 NVMe drive taps the motherboard's own 3.3V rail through the slot & feeds it into a single onboard PMIC. The 2280 form factor leaves almost no PCB area for surge-suppression parts, so a failing PSU or a faulty motherboard VRM pushes the spike straight into that one chip.
The PMIC usually fails as a dead short. Once it shorts, it drags the motherboard 3.3V rail down, so the drive disappears from BIOS or the whole system stops at POST. This is the exact pattern we see after a power surge that killed an NVMe SSD.
A 2.5-inch SATA SSD takes power through a separate dedicated SATA power connector & runs primarily on the 5V rail. Its larger PCB carries far more voltage-regulation area, which can absorb or isolate some of the electrical stress that destroys a cramped 2280 board.
We localize the shorted component with a FLIR thermal camera before applying full power, then confirm the abnormal draw on a current-limited bench supply. Board-level PMIC or voltage-regulator replacement via microsoldering revives the original controller, which holds the AES-256 keys that a donor controller can never reproduce. That work sits in the circuit-board-repair bracket at $900–$1,200.
Common NVMe Failure Modes
NVMe drives fail from controller burnout, FTL mapping corruption after power loss, PCIe lane electrical faults, NAND cell degradation, and firmware bugs. Recovery requires PC-3000 with the correct vendor-specific utility. Consumer recovery software cannot address any of these because it depends on the controller functioning normally to read data.
What Are the Common NVMe Failure Modes?
NVMe drives fail from controller burnout, FTL mapping corruption after power loss, PCIe lane electrical faults, NAND cell degradation, and firmware bugs. Recovery requires PC-3000 with the correct vendor-specific utility for the controller family. Consumer recovery software cannot address any of these because it depends on the controller functioning normally.
Failure mode
What the user sees
Lab diagnostic path
Recovery boundary
Controller burnout
Drive disappears from BIOS entirely
FLIR thermal imaging before power is applied
Original controller must respond after board repair
Drive shows 0 bytes or is not detected
PC-3000 reconstructs FTL metadata from NAND pages
Works when surviving metadata can rebuild the map
PCIe lane failure
Intermittent detection or Unknown Device errors
Inspect connector pins, solder joints, and link training
Drive must establish a stable PCIe link for imaging
NAND wear and read disturb
Read-only mode or protection mode
PC-3000 shifts read voltage thresholds
LDPC correction must still recover enough valid pages
Firmware bugs
BSY state, health drops, or firmware panic
PC-3000 Technological Mode where controller support exists
The NVMe controller overheats and fails permanently. Common in laptops where the M.2 slot sits under the keyboard with no heatsink or airflow.
The drive disappears from BIOS entirely. FLIR thermal imaging identifies the failed component before we apply power, preventing further damage.
FTL Mapping Table Corruption
The Flash Translation Layer maps logical block addresses to physical NAND locations. Power loss during an FTL update leaves the table in a partially written state.
The controller cannot boot, so the drive shows 0 bytes or is not detected. PC-3000 reconstructs the FTL from surviving metadata scattered across NAND pages.
PCIe Lane Failure
NVMe drives connect through 2 or 4 PCIe lanes. Bent M.2 connector pins, cracked solder joints on the drive, or a damaged M.2 slot on the motherboard can break the PCIe link. The drive may intermittently appear and vanish from the system, or show as "Unknown Device" in Device Manager with errors in link training.
NAND Wear and Read Disturb
QLC and TLC NAND in consumer NVMe drives has limited program/erase endurance. As cells degrade, the bit error rate exceeds the controller's LDPC error correction capacity.
The controller enters a read-only or protection mode. PC-3000 can shift read voltage thresholds to recover data from degraded NAND cells that fail at default settings.
Firmware Bugs
Samsung 980 Pro and 990 Pro drives had a documented firmware bug that caused rapid health percentage drops and eventual drive failure. Samsung released firmware patches, but drives that degraded before the patch may have irreversible NAND damage. Some Phison-based drives can enter a BSY (busy) state after firmware panic that locks out all I/O. Recovery depends on whether the specific controller and firmware revision have a supported diagnostic path.
On the 990 Pro the health decline traces to the launch firmware 0B2QJXD7. Samsung's 1B2QJXD7 update halts the erroneous decline but does not reverse the S.M.A.R.T. health already recorded on affected drives. The Samsung 990 Pro firmware degradation breakdown covers the affected firmware revisions and what the later revisions do and do not reset.
NVMe Drive Not Detected in BIOS: Diagnosis Steps
Before assuming hardware failure, rule out motherboard configuration. Enter your UEFI/BIOS settings and check the Compatibility Support Module (CSM). If CSM is enabled, the BIOS may be running in legacy mode, which lacks NVMe protocol support and may not enumerate M.2 NVMe devices.
Disable CSM to force pure UEFI mode, then check the onboard device or storage configuration menu (not the boot priority list) for NVMe detection. Also verify the M.2 slot's PCIe bandwidth is allocated to NVMe mode, not SATA mode (some boards share lanes between SATA ports and M.2 slots).
If BIOS settings are correct but the drive still does not appear, try the drive in a different M.2 slot or a USB-to-NVMe enclosure. If the drive shows up with a generic capacity (1 GB, 2 MB, or 0 bytes) or displays the raw controller name ("SM2263XT," "PS5007," "MAP1602") instead of the product name, the controller has entered ROM mode after a firmware panic.
At that point, no consumer software or BIOS update will restore access. On the controllers ACE Lab supports, the drive needs PC-3000 Technological Mode intervention to rebuild the Flash Translation Layer from surviving NAND metadata. The Maxio MAP1602 is absent from that list. Rossmann does not currently offer in-lab recovery for Maxio MAP1602.
Do not initialize the disk in Windows Disk Management or run CHKDSK if the drive reappears intermittently. Both operations write to the drive and can overwrite the FTL metadata that PC-3000 needs for reconstruction.
Intel VMD Hides NVMe Drives from BIOS on 11th-Gen and Newer Systems
Intel Volume Management Device (VMD) is a controller built into 11th-Gen (Tiger Lake) and newer Intel processors. VMD intercepts the PCIe lanes connected to M.2 slots and re-presents them through Intel Rapid Storage Technology (RST). If RST drivers are not installed, or if the OS does not support VMD, the NVMe drive disappears from BIOS entirely.
This is not a drive failure; the drive is physically functional but hidden behind the VMD abstraction layer.
To rule out VMD masking: enter UEFI settings, navigate to Advanced > System Agent Configuration or Devices & I/O Ports (exact path varies by board manufacturer), and set Intel VMD to Disabled. Reboot and check whether the NVMe drive reappears. On Linux, adding modprobe.blacklist=vmd to the kernel boot parameters bypasses VMD without a BIOS change.
If the drive remains invisible with VMD disabled, the problem is not VMD masking. The controller has likely suffered a hardware or firmware failure. Send the drive to our Austin lab for professional SSD recovery using PC-3000.
NVMe Not Detected: Hardware Differential
When an NVMe drive is missing from BIOS, rule out host configuration first: CSM, Intel VMD, & M.2 lane sharing. Once config is clear, three hardware faults remain. Controller power-rail collapse makes the drive vanish & draw no current. PCIe link-training failure leaves the drive drawing current but advertising no valid link, often with freezes or kernel panics. Firmware decoder corruption lets the link train but returns a wrong name, a tiny capacity, or no namespace at the NVMe handshake.
NVMe Not Detected in BIOS: Hardware Differential After Config Is Ruled Out
Start at the host, not the drive. The two config blocks above, NVMe Drive Not Detected in BIOS: Diagnosis Steps & Intel VMD Hides NVMe Drives from BIOS, cover the config layer: CSM forcing legacy mode, a shared M.2/SATA lane stealing the slot, & Intel VMD hiding the endpoint behind Rapid Storage. Work through those first. Everything below assumes the host config is already ruled out & the drive is still missing.
After config, an undetected NVMe drive falls into one of three hardware fault classes. Each presents differently to you, & each takes a different lab path. This is the differential most recovery sites skip, treating "dead drive" as one black box. For the full board-repair context, see our SSD data recovery flagship & the PC-3000 tool overview.
Not Showing Up in BIOS vs. Not Showing Up in Windows or macOS
Two different failures share one sentence. In the first, the drive is missing from BIOS/UEFI enumeration, which is a power-rail, PCIe link, or controller-firmware problem. In the second, BIOS lists the drive & the operating system's volume manager doesn't, which is a namespace, FTL, partition-metadata, or driver-binding problem.
One check separates them without opening the machine. On Windows, open Device Manager & look under Storage Controllers. An NVMe controller listed there with no error code on it means the power rails are up, the PCIe link trained, & the controller answered the hardware handshake, so the fault sits above the hardware layer in the namespace, the FTL, or the driver binding. If BIOS doesn't list the drive & Device Manager shows no NVMe controller, you're in the first state.
Where the drive is visible
Layer that failed
Lab path
Nowhere. Absent from BIOS/UEFI & absent from Device Manager
Controller power tree, PCIe link training, or controller firmware never reaching the NVMe handshake
Board-level electrical work to bring the original controller back up, in the circuit-board-repair bracket at $900–$1,200
Listed in BIOS/UEFI & in Device Manager, absent from Windows Disk Management or macOS Disk Utility
Namespace metadata, FTL mapping, partition table, or the Windows driver bound to the controller
Host driver ruled out first, then service-area work on the live controller in the firmware-recovery bracket at $900–$1,200
Check what BIOS reports before you settle on this branch. A drive in the first state shows no entry at all. A wrong entry, a generic factory name or a capacity that isn't the drive's real one, means the link trained & the controller answered, which puts you in the second state instead.
Listed in BIOS, Missing from Disk Management or Disk Utility
The controller is alive here & the block device never arrives. Windows Disk Management, macOS Disk Utility, & Windows File Explorer all read from a layer the controller has to build first: a namespace with a valid logical block range, mapped by an FTL the controller can still parse. The NAND keeps its contents while that map is broken.
Rule out the host driver before you call it a drive failure. On an AMD platform with RAID mode enabled in BIOS, the NVMe controller binds to the AMD RAID driver instead of the standard NVMe controller driver, & the drive sits in BIOS while Disk Management never lists it. That's a binding problem on the host, not damage inside the drive, & Device Manager shows you which driver claimed the controller.
Disk Management shows the disk as Unallocated or RAW while File Explorer shows no drive letter. The namespace reached the OS & the partition or GPT metadata above it is damaged. Initializing the disk when Windows offers to is a write, & it lays a fresh partition table over the structure you want read back.
The drive answers, but reports a tiny or zero capacity, or accepts no writes. The controller has locked into a protective read-only or safe state: the host sees the controller & still gets no usable volume.
Device Manager lists the controller, & Disk Management or Disk Utility shows nothing at all. No namespace was presented, so the OS has no block device to instantiate & no partition table to parse.
Recovery software reads what the controller presents. With no namespace, Disk Drill or R-Studio have nothing to scan, & on supported controller families the rebuild happens inside the original controller with PC-3000 SSD rather than above it. Namespace reconstruction is covered further down this page, & the mapping layer itself in our FTL technical reference.
The Three Hardware Fault Classes
Fault class
What breaks
How it presents to you
Dead short: shorted decoupling capacitor, failed PMIC, or a damaged core-voltage trace
Drive vanishes entirely, draws no or abnormal current, zero PCIe link activity. The system otherwise boots fine.
LTSSM stalls in Detect, Polling, or Configuration: lost 100 MHz reference clock, degraded PCIe PHY, or physical lane damage after a thermal event
Drive draws current but advertises no valid lane width. Intermittent link drops, plus freezes, blue screens, or kernel panics at boot. The OS can read controller status (CSTS) as all ones.
Firmware / decoder corruption
Controller boots to safe mode or panic, often from power loss during a service-area write
Link trains, but the NVMe handshake fails: stalls at Controller Enable, returns garbage to Identify Controller, advertises inactive namespaces, or shows a generic factory alias with a 1 GB or 2 MB capacity instead of the real model.
Triage: Match the Symptom to the Fault
If the drive vanishes from BIOS, the system still boots, & a current-limited bench supply reads no or abnormal draw, suspect controller power-rail collapse. A shorted MLCC, a dead PMIC, or a damaged core-voltage trace is pulling the rail down.
If the drive draws current but trains no valid link, drops in & out, or freezes or kernel-panics the host at boot, suspect PCIe link-training failure: a lost reference clock, a degraded PHY, or physical lane damage after a thermal event.
If the link trains cleanly but the drive reports a generic name, a 1 GB or 2 MB capacity, returns garbage to Identify Controller, or shows inactive namespaces, suspect firmware or host-interface decoder corruption, usually from power loss during a service-area write.
Why No Recovery Software Can See a Drive the BIOS Never Enumerates
Tools like Disk Drill, R-Studio, & PhotoRec work at the OS block-device layer. That layer only exists after a four-step low-level chain finishes. Break any step & the drive never becomes a block device for software to scan:
PCIe link training. The lanes negotiate width & speed. Broken by power-rail collapse or a lost reference clock.
NVMe class-code presentation. The controller presents its NVMe class code in PCI configuration space so the host knows what it is.
Driver bind. The OS NVMe driver binds to the PCIe endpoint.
Admin handshake. The host sets Controller Enable (CC.EN), waits for Controller Ready, reads Identify Controller, & maps the I/O queues. Broken by firmware or decoder corruption that returns invalid Identify data.
SATA-based recovery tools can't interrogate an NVMe controller at all, because they have no PCIe logic to bring up the link in the first place.
The Lab Path Per Fault Class
The PC-3000 Portable III manages memory mapping & doorbell signaling on its own, independent of a motherboard BIOS, so it can talk to a controller that's stuck in a fault state no motherboard will enumerate.
Power-rail & link faults are electrical first. We localize the dead short with a FLIR thermal camera, then microsolder the failed PMIC or decoupling capacitor with a Hakko FM-2032 to restore core voltage. Once the controller has clean power, it boots & answers NVMe admin commands. That work sits in the circuit-board-repair bracket at $900–$1,200.
Firmware & safe-mode faults are a service-area job. For supported controller families, Phison & Silicon Motion, PC-3000 SSD Active Utilities enter vendor-specific Technological Mode to reach the service area & rebuild the L2P/FTL map or namespace metadata inside the original controller. That work sits in the firmware-recovery bracket at $900–$1,200.
Chip-off is not the path. The data is bound to the original controller. On encrypted drives that's hardware AES; even without AES it's proprietary XOR scrambling, LDPC error correction, & dynamic FTL geometry. A generic NAND reader yields ciphertext or garbage. Reading desoldered NAND is a separate discipline from PC-3000 SSD, which talks only to a live controller, never to desoldered chips.
Yes: USB-to-NVMe enclosures use a bridge IC to translate NVMe commands into USB protocol. When the bridge IC overheats or fails, the NVMe drive inside is often intact but the enclosure stops responding. Users frequently mistake a dead bridge IC for a dead NVMe drive. Removing the drive and installing it directly into an M.2 slot confirms which component failed.
Can a USB NVMe Enclosure Cause Data Loss?
Yes: USB-to-NVMe enclosures use a bridge IC (Realtek RTL9210B, JMicron JMS583, or ASMedia ASM2362) to translate NVMe commands into USB protocol. When the bridge IC overheats or fails, the NVMe drive inside is often intact but the enclosure stops responding. Users frequently mistake a dead bridge IC for a dead NVMe drive.
Thunderbolt 3/4 & USB4 enclosures run hotter than USB 3.2 models because they push higher bandwidth through a compact aluminum shell. Sustained file transfers heat the bridge IC past its thermal limit, and repeated thermal cycling weakens the solder joints on the bridge chip.
Before Assuming the Drive Is Dead
Remove the M.2 NVMe drive from the enclosure.Most enclosures use a tool-free slide mechanism or a single Phillips screw. Handle the drive by its edges; don't touch the gold connector pins.
Install the drive directly into a desktop motherboard M.2 slot.This bypasses the USB bridge entirely. If the drive appears in BIOS and shows its correct model name & capacity, the enclosure bridge IC was the problem, not the NVMe drive.
Do not leave a failing drive powered in the enclosure.A bridge IC that drops the connection under load causes repeated connect/disconnect cycles that stress the NVMe controller. If the drive has a logical issue (deleted files, RAW partition), the controller uses idle time to execute TRIM & background garbage collection, permanently erasing recoverable data.
If the drive doesn't appear in BIOS after direct M.2 installation, the NVMe controller has a hardware or firmware failure. At that point, send the bare drive to our Austin lab for PC-3000 diagnostic imaging. USB bridge failures don't damage NAND data, so recovery prognosis is strong if you stop using the enclosure before the controller takes additional stress.
NVMe Form Factors
NVMe SSD recovery covers M.2 2280, M.2 2230, M.2 2242, U.2, and PCIe add-in card form factors. Each uses different connector types and thermal characteristics that affect the recovery process. Soldered NVMe on Apple MacBooks requires board-level logic board repair rather than drive extraction, because the Secure Enclave holds the decryption key.
What NVMe Form Factors Can Be Recovered?
NVMe SSD recovery covers M.2 2280, M.2 2230, M.2 2242, U.2, and PCIe add-in card form factors. Each uses different connector types and thermal characteristics that affect the recovery process. Soldered NVMe on Apple MacBooks requires board-level logic board repair rather than drive extraction.
M.2 2280
22mm wide, 80mm long. The standard NVMe form factor in desktops and laptops. Samsung 970/980/990 series, WD Black SN770/SN850X, Crucial P5 Plus, and most consumer NVMe drives use this size. The 4TB WD SN850X is double-sided, which causes fitment issues in single-sided M.2 slots.
M.2 2230
22mm wide, 30mm long. Found in Steam Deck, Microsoft Surface Pro, Dell XPS, and Framework laptops. Smaller PCB means denser component placement and tighter thermal margins. WD SN740, Micron 2400, and Samsung PM991a are common 2230 drives.
U.2 (2.5" NVMe)
Enterprise data center form factor using the SFF-8639 connector. Higher capacities (up to 30TB+), power loss protection capacitors, and dual-port PCIe for redundancy. Intel DC P4510, Samsung PM9A3, and Micron 9400 are common enterprise models.
PCIe Add-In Card (AIC)
Full-size PCIe cards used in workstations and servers. Intel Optane 905P and Samsung PM1733 are examples. These drives use x4 or x8 PCIe lanes and often have their own heatsinks, which reduces thermal failure risk compared to M.2 form factors.
Soldered NVMe (Apple MacBook)
Apple MacBooks with T2 or M-series chips have NAND soldered to the logic board, encrypted by the SoC's Secure Enclave. The NAND cannot be desoldered and read independently. Recovery requires board-level repair to restore the original logic board.
M.2 2242
22mm wide, 42mm long. Found in some industrial devices, thin clients, and embedded systems. Less common in consumer hardware but we handle them with the same NVMe diagnostic workflow.
A 2.5-inch drive with a separate SATA data connector and SATA power connector is a SATA device, not a U.2 NVMe drive on the SFF-8639 connector. If that 2.5-inch unit is a spinning hard drive, it goes through hard drive data recovery instead.
M.2 Form Factor Deep Dive
M.2 NVMe form factor determines which devices use the drive, how it fails, and what adapter connects it to PC-3000 for diagnostic imaging. M.2 2280, 2230, and 2242 share the NVMe protocol but differ in physical size, connector keying, and thermal behavior. We recover all M.2 sizes and keying configurations at our Austin lab.
How Does M.2 Form Factor Affect NVMe Data Recovery?
See the PC-3000 tool overview for how the diagnostic hardware interfaces with NVMe controllers across all M.2 form factors.
M-Key vs B+M-Key Connector Keying
The M.2 connector uses mechanical notches ("keys") to prevent inserting an incompatible module. Keying also determines how many PCIe lanes the drive can use, which affects recovery adapter selection.
M-Key (right-side notch)
Supports PCIe x4 (four lanes). This is the standard for all high-performance NVMe drives: Samsung 980/990 Pro, WD Black SN850X, Crucial T700. Recovery adapters must provide a full x4 PCIe connection. Using an x2 adapter on an M-key drive cuts available bandwidth and can cause PC-3000 read timeouts on drives with marginal controller health.
B+M-Key (dual notch, both sides)
Physically fits both B-key and M-key M.2 slots but is electrically limited to PCIe x2 (two lanes) or SATA. Common on budget Gen3 NVMe drives and older SATA M.2 SSDs. Not all USB-to-NVMe enclosures support the NVMe protocol over B+M-key; some legacy enclosures wire B+M slots for SATA only. Forcing an M-key NVMe drive into a legacy B-key or SATA-only enclosure bends the connector pins and damages the PCIe contact pads.
Physical Damage Patterns by M.2 Size
Smaller M.2 form factors concentrate more components into less PCB area, creating different mechanical and thermal failure patterns than full-size 2280 drives.
M.2 2280 PCB Flex Damage
The 80mm length makes 2280 drives susceptible to bending. Installing without a standoff or overtorquing the retention screw flexes the PCB and can crack the copper traces that route PCIe lanes from the connector to the controller.
A cracked trace causes intermittent detection or complete link failure. Double-sided 2280 drives (WD SN850X 4TB, Crucial T700 4TB) are thicker and cannot seat properly in single-sided M.2 slots, adding mechanical stress at the connector end.
M.2 2230 Thermal and HMB Failures
The 30mm PCB packs the controller and NAND within millimeters of each other, so heat from the controller conducts directly into the NAND. In devices with restricted airflow (Steam Deck, Microsoft Surface Pro, ROG Ally), sustained writes push the controller past its thermal junction limit.
Repeated thermal cycling cracks the BGA solder balls between the controller and the PCB. Most 2230 drives are DRAM-less and use Host Memory Buffer (HMB) borrowed from system RAM. A power loss during an FTL update wipes the HMB copy, corrupting the Flash Translation Layer and locking the drive in a firmware panic state.
M.2 2242 and 2260: Connector Pin Damage
These mid-length form factors appear in industrial embedded systems, thin clients, and some legacy ThinkPads. The 2260 is largely obsolete in consumer hardware but remains active in ruggedized industrial PCs and point-of-sale systems.
Connector pin damage from forced insertion into a mismatched M.2 slot is the most common physical failure. Many 2242 drives use B+M-key and SATA protocol; the drive physically fits a modern M-key-only NVMe socket but will not be detected if the slot lacks SATA protocol support.
Steam Deck and Surface Pro SSD Extraction
Handheld and ultraportable devices use M.2 2230 NVMe drives in tight enclosures with device-specific access methods. Improper extraction risks physical damage to the drive and the device.
Steam Deck
The Steam Deck uses a 2230 NVMe drive beneath an RF shield held by Phillips screws. Accessing the drive requires removing the back panel (8 Phillips screws) and peeling the RF shield tape. Common 2230 drives in the Steam Deck: WD SN740 (SanDisk Polaris controller), Micron 2400 (SM2269XT controller), Samsung PM991a (Pablo controller).
These DRAM-less drives fail from aggressive suspend/resume power cycling that corrupts the HMB-based FTL mapping table. If your Steam Deck no longer boots or shows a storage error, do not attempt a firmware update through SteamOS recovery; ship the drive to our lab for SSD recovery. Depending on the specific controller, we use hardware-level diagnostic tools to image the NAND directly.
Surface Pro 7+, 8, 9, X, and 11 use a 2230 NVMe drive behind a small door beneath the kickstand. WiFi models have a magnetic door; 5G/LTE models require a SIM ejector pin.
The drive is secured with a 3IP (Torx-Plus) screw. Most consumer precision kits stop at T4 or T5 and lack Torx-Plus bits entirely.
Using a standard Torx driver strips the soft metal screw head, trapping the drive in the chassis. Microsoft specifies sliding the drive out at a 15-degree angle to avoid snapping the M.2 connector pins. If the drive has failed, send the entire Surface for recovery rather than risking physical damage during extraction.
2230 NVMe Controller Failure Modes
The 2230 drives in handheld devices share three failure patterns driven by their DRAM-less architecture and constrained thermal environment.
HMB FTL corruption from suspend/resume cycles.Handhelds aggressively sleep and wake the SSD. If power drops before the controller finishes flushing its HMB cache to NAND, the Flash Translation Layer mapping table corrupts. The drive enters a BSY (busy) firmware state and stops responding to standard NVMe commands. For supported controllers (Silicon Motion SM22xx family, Phison PS50xx), PC-3000 enters Technological Mode to reconstruct the FTL from surviving NAND metadata. Proprietary controllers (WD, Samsung) require alternative diagnostic approaches.
BGA solder micro-fractures from thermal cycling.The controller runs hot in a space with minimal airflow. Repeated expansion and contraction of the solder connections between the BGA controller and the PCB causes microscopic cracks. The drive works intermittently at first, then fails permanently. Repair requires reflowing or reballing the BGA connections using a precision rework station.
Controller burnout from sustained writes.Large game downloads or OS updates push sustained write loads that exceed the thermal budget of a 30mm PCB. Without a heatsink, the controller hits its thermal junction limit and shuts down. Repeated overheating degrades the controller silicon permanently. FLIR thermal imaging identifies the failed component before we apply power, preventing cascading damage.
Transparent NVMe Pricing
NVMe SSD recovery at our Austin lab is priced in 5 published brackets: $200 for a working-drive copy, From $250 for file system corruption, $900–$1,200 for circuit board repair, $900–$1,200 for firmware and FTL reconstruction, and $1,200–$2,500 for NAND chip transplant onto a donor PCB. No data, no recovery fee. Free evaluation. No diagnostic charge. Single location at 2410 San Antonio Street, Austin, TX. Rated 4.9 across 1,837 verified Google reviews.
What Trust Signals Apply to NVMe Recovery?
Every NVMe recovery quoted on this page is bound by the same five operational commitments. They apply identically whether the drive arrives by mail-in or in person.
If we cannot recover usable data, you owe nothing for the recovery work. See the no-fix-no-fee guarantee for the exact scope and the donor-drive cost exception.
Free evaluation, no diagnostic fee
Inbound NVMe drives are evaluated and quoted before any paid work begins. The evaluation covers controller identification, FLIR thermal scan for shorts, and a board-level inspection of the voltage rails. You receive a firm quote within the published bracket before authorizing the recovery.
Published bracket pricing
Recovery is priced in 5 brackets across $200–$2,500. The bracket is determined by the failure mode identified during evaluation, not by the drive brand or capacity. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers.
All work performed in Austin
One physical location at 2410 San Antonio Street, Austin, TX 78705. No franchises, no satellite offices, no outsourcing. The technician who evaluates the drive is the technician who repairs it. Mail-in customers ship to that same Austin address.
4.9 stars across 1,837 verified Google reviews
Aggregate Google Business Profile rating for Rossmann Repair Group. Louis Rossmann documents recoveries on YouTube; the channel has 2.64M subscribers and publishes lab footage of the equipment used on this page.
NVMe SSD data recovery costs $200–$2,500 across 5 tiers. The tier depends on the failure mode, not the form factor or drive brand. Board-level repair for failed voltage regulators falls in the $900–$1,200 range. Firmware corruption requiring FTL reconstruction is $900–$1,200. Free evaluation. No data, no recovery fee.
How Much Does NVMe SSD Data Recovery Cost?
NVMe SSD data recovery costs $200–$2,500 across 5 tiers; the tier depends on the failure mode, not the form factor or drive brand. Board-level repair for failed voltage regulators falls in the $900–$1,200 range; firmware corruption requiring FTL reconstruction is $900–$1,200.
PC-3000 SSD Recovery Workflow
Each controller family requires a vendor-specific diagnostic module. The five-step workflow covers pre-power inspection, controller identification, Technological Mode entry, FTL reconstruction, and sector-by-sector imaging.
How Does PC-3000 Recover Failed NVMe Drives?
Each controller family requires a vendor-specific diagnostic module. The five-step workflow below covers every case from pre-power inspection through final file extraction.
FLIR thermal camera scans the drive for shorts before applying power. Voltage rails are tested individually with a bench power supply to isolate failed components. This prevents cascading damage from powering a shorted board.
02
Controller Identification
Identify the NVMe controller die markings and NAND configuration. This determines which PC-3000 Active Utility to load: Samsung, Phison, Silicon Motion, or Universal for controllers without dedicated support (WD proprietary, Maxio).
03
Technological Mode Entry
PC-3000 forces the controller into its vendor diagnostic mode (Technological Mode). In this mode, the controller bypasses its normal boot sequence and firmware validation, allowing direct access to NAND through the controller's hardware ECC and descrambling engines.
04
FTL Reconstruction
If the Flash Translation Layer is corrupted, PC-3000 scans surviving FTL metadata spread across NAND pages to reconstruct the logical-to-physical block mapping. This process restores the drive's ability to present its file system to the OS.
05
Sector-by-Sector Imaging
Once the controller responds, the entire drive is imaged sector-by-sector to a known-good destination drive. Bad sector maps are generated to track unreadable regions. Files are extracted, verified against directory structure, and returned on your choice of media.
NVMe Controller Families
NVMe recovery success depends on which controller family is in the drive. Phison and Silicon Motion have dedicated PC-3000 active utilities that enable Technological Mode access and FTL reconstruction. Samsung has limited diagnostic support through PC-3000. Western Digital, Maxio, InnoGrit, and Realtek controllers require board-level repair or the Universal Utility.
Which NVMe Controller Families Have a Recovery Path?
NVMe recovery success depends on which controller family is in the drive. Phison and Silicon Motion have dedicated PC-3000 active utilities that enable Technological Mode access and FTL reconstruction. Samsung has limited diagnostic support through PC-3000, while Western Digital, Maxio, InnoGrit, and Realtek controllers require board-level repair or the Universal Utility.
Each controller family has different firmware architectures, failure signatures, and PC-3000 recovery modules. The cards below cover supported and unsupported families.
Controller family
Common drives
Failure signature
PC-3000 path
Phison E12, E16, E21T
Corsair MP510/MP600, Sabrent Rocket
BSY state or firmware panic after power loss
Phison Utility through Technological Mode
Samsung in-house (Elpis, Pablo, 970 and 990 series)
Samsung 970, 980, 990, 990 EVO, PM991a
Proprietary NAND encoding and AES-256 encryption
Limited diagnostic support; chip-off is not viable
ADATA SX8200 Pro, HP EX900/EX950, Lexar NM600, Kingston NV2
HMB-based FTL corruption on DRAM-less controllers
Silicon Motion (SM) Utility for SM22xx/SM22x9 controllers
Western Digital / SanDisk
WD SN770, WD SN850X, SanDisk Extreme Portable
Proprietary controller access and USB bridge complications
Firmware-level BSY state without a dedicated Active Utility
Hardware-level stabilization and board repair
KIOXIA, SK Hynix, Intel custom firmware
BC501, PC401, and less common OEM NVMe drives
Permanent BSY state within milliseconds of power-on
Universal Utility, power sequencing, and thermal stabilization
Phison E12, E16, and E21T Controllers
Powers Corsair MP510/MP600, Sabrent Rocket, and many other drives. The PC-3000 Phison Utility handles supported PS50xx family controllers through Technological Mode. Controller support is model-specific, so we verify the exact controller and firmware revision before quoting a firmware-level recovery.
Samsung designs its own controllers. Elpis powers the 980 Pro, and the 990 Pro runs another in-house design. The 990 EVO and 990 EVO Plus use the DRAM-less Piccolo controller with Host Memory Buffer.
The 970 EVO/PRO run an earlier in-house controller. Pablo is Samsung's DRAM-less HMB controller in the 980 (non-Pro). Samsung NVMe drives use proprietary NAND encoding and AES-256 encryption, making chip-off not viable.
Silicon Motion SM2262EN, SM2263XT, SM2267XT, and SM2269XT
Found in ADATA SX8200 Pro, HP EX900/EX950, Lexar NM600, Kingston NV2. The SM2263XT is DRAM-less and depends on Host Memory Buffer, making it more vulnerable to power-loss FTL corruption. PC-3000 SSD Silicon Motion Utility covers the major supported controllers in the SM22xx/SM22x9 family.
WD designs proprietary controllers for the SN770 and SN850X. No dedicated PC-3000 Active Utility exists for WD proprietary controllers.
Recovery uses the PC-3000 SSD Universal Utility for basic access. The SanDisk Extreme Portable uses a USB bridge that requires bypass for direct NVMe access.
Maxio MAP1602 and MAP1602A
The MAP1602 is a common budget Gen4 NVMe controller found in Kingston NV2 and many sub-$50 NVMe drives. PC-3000 does not currently have dedicated Active Utilities for Maxio NVMe controllers, making firmware-level BSY state recovery dependent on hardware-level stabilization and board repair.
InnoGrit IG5236
The IG5236 has a specific failure pattern: under thermal stress or after a diagnostic scan from ADATA SSD Toolbox, the controller panics and reverts to a factory ROM descriptor.
The drive re-enumerates as "MN-5236" with a capacity of 2 MB or 2.1 GB instead of its actual size. Consumer firmware update utilities cannot communicate with the controller in this state.
PC-3000 does not currently have a dedicated Active Utility for InnoGrit controllers. Recovery requires component-level board repair or specialized research to stabilize the controller hardware before imaging can proceed.
Realtek
Realtek publishes no public documentation for its NVMe controllers, so what a given drive is doing has to be established on the bench.
PC-3000 does not currently have a dedicated Active Utility for Realtek NVMe controllers, so firmware-level FTL reconstruction is not available. Recovery relies on board-level repair to stabilize the original controller hardware so it can complete its own boot sequence and allow imaging.
Other Controllers
KIOXIA (formerly Toshiba Memory), SK Hynix proprietary controllers (found in BC501, PC401 series), and Intel custom firmware on SM2263. Less common controllers may require the PC-3000 SSD Universal Utility, which provides basic diagnostic access without vendor-specific features. SK Hynix controllers can enter a permanent BSY state within milliseconds of power-on, requiring current-limited power sequencing and thermal NAND stabilization to keep the controller alive long enough for imaging.
Controller Architecture Hubs
Because modern NVMe SSDs use hardware-level AES-256 encryption tied to the controller, chip-off recovery yields only ciphertext. Therefore, NVMe data recovery is strictly a board-level microsoldering discipline required to revive the original controller.
Which Controller Architecture Hub Covers Your NVMe Drive?
This page is the form-factor entry point for M.2 and PCIe NVMe recovery. The four architecture hubs below are the per-vendor controller deep dives. If you know which controller is on your drive, route directly to the matching hub for silicon-level failure signatures, firmware panic descriptors, & ACELab PC-3000 SSD support truth. The hierarchy exists so that broad NVMe queries land here, while vendor-specific queries route to the silicon-level page that can answer them.
Every hub below carries the same AES-256 key-boundary constraint. The Media Encryption Key is generated on and bound to the original controller, so it never leaves that die. Chip-off the NAND & you get ciphertext. Move the NAND to a donor PCB & the donor controller's key cannot decrypt your data. Board-level repair to revive the original silicon is the only viable path.
Phison (linked architecture hub)
Phison's flagship PS5026-E26 is the dominant client PCIe Gen5 x4 controller: TSMC 12nm FinFET, 8-channel NAND with up to 32 chip-enable lines, ARM Cortex-R5 paired with three CoXProcessors, DDR4/LPDDR4 DRAM, & 2400 MT/s flash transfer rates. Inline hardware AES-256, SHA-512, & RSA-4096 cryptography is fused inside the E26 package, so the key boundary never leaves the silicon.
Common drives include the Seagate FireCuda 540, Corsair MP700 / MP700 Pro, Crucial T700 / T705, ADATA Legend 970, & Gigabyte Aorus Gen5 10000 / 12000. Legacy Phison controllers (E12, E16, E18, E21T) are supported on ACELab PC-3000 SSD; the Gen5 E26 is not currently in the PC-3000 SSD support matrix, so recovery on E26 drives hinges on repairing power delivery & PMIC rails so the native controller can boot & decrypt the NAND stream.
The SM2264 is Silicon Motion's flagship PCIe Gen4 x4 controller: 12nm process, quad-core ARM Cortex-R8, 8-channel NAND at 1600 MT/s per channel, with onboard DRAM. It powers the ADATA XPG Legend 960 & Legend 960 Max. The DRAM-less SM2268XT & SM2268XT2 variants use a 4-channel interface at up to 3200 MT/s & 3600 MT/s respectively, & rely on Host Memory Buffer for FTL metadata, which makes them susceptible to power-loss FTL corruption.
Legacy Silicon Motion families (SM22xx / SM22x9) are supported on ACELab PC-3000 SSD through the Silicon Motion (SM) Utility, which enables Technological Mode access & FTL reconstruction on drives where the native controller can be revived through board repair. The SM2264 is not currently in the PC-3000 SSD support matrix; recovery on SM2264 drives depends on board-level repair of the native controller.
The InnoGrit IG5236 is an 8-channel PCIe Gen4 x4 NVMe 1.4 controller with independent DRAM caching.
Under thermal stress or after a diagnostic scan, the IG5236 panics & re-enumerates as "MN-5236" (the silicon factory ROM descriptor) at 2 MB or 2.1 GB instead of its actual terabyte-class capacity. The controller uses inline AES-256 hardware encryption with the key generated on and bound to the original silicon.
The Maxio MAP1602 & minor revision MAP1602A "Falcon Lite" is a 4-channel, DRAM-less PCIe Gen4 x4 controller on a 12nm process with an ARM Cortex-R5 core. It depends entirely on Host Memory Buffer technology & dynamic SLC caching to maintain performance at 2400 MT/s NAND interface speeds. Common drives include the Lexar NM790, Acer FA200, some Kingston NV2 SKUs, & the KLEVV CRAS C925G.
When HMB metadata desynchronizes after power loss, the controller panics & the drive vanishes from BIOS or enumerates as "MAP1602" at 0 bytes or 2 MB. The MAP1602 family relies on proprietary data scrambling, Host Memory Buffer dependencies, and multi-gear LDPC error correction, so raw NAND reads are unintelligible without the original controller's descrambling engine.
This hierarchy exists so that nobody pays for a chip-off attempt that physics cannot satisfy. The shop that sells you NAND removal & donor-controller transplant on an encrypted NVMe drive is selling a procedure that ends with ciphertext & a bill.
Vendor-specific hub pages exist because each controller family has its own panic descriptor, its own ACELab support status, & its own electrical failure profile. Treating them as interchangeable is how unsupported drives get billed at supported rates by labs that prefer not to admit the difference.
Controller Workflow Specifics
Phison and Silicon Motion are the two NVMe controller families with mature PC-3000 Active Utility support. Each family has a different diagnostic-mode entry method, a different way to bypass the corrupted firmware running in the controller's internal RAM, and a different metadata structure the technician must reconstruct to image the NAND.
What Are the Controller-Specific PC-3000 Workflows for NVMe Recovery?
Phison and Silicon Motion are the two NVMe controller families with mature PC-3000 Active Utility support. Each family has a different diagnostic-mode entry method, a different way to bypass the corrupted firmware running in the controller's internal RAM, and a different metadata structure that the technician must reconstruct to image the NAND. The procedures below are specific enough that the diagnostic path for one family cannot be reused on the other.
Phison PS5012-E12 and PS5016-E16: Safe Mode Entry and Virtual Translator
A Phison E-series NVMe controller in firmware panic state will not enumerate on the PCIe bus, or will enumerate with a generic ROM-mode descriptor and zero capacity. To recover, the technician must force the controller into a Safe Mode that bypasses the normal boot sequence, then use PC-3000 to load an alternative loader and rebuild the translator from surviving NAND metadata.
Safe Mode entry by test-pad short.Phison E-series controllers expose a Safe Mode test pad on the drive PCB. Briefly shorting the pad to ground at the moment of power-on prevents the controller from executing its on-die boot ROM normally; instead it enters a minimal diagnostic state that accepts vendor commands over PCIe. The exact pad position and short technique varies by drive model, which is why the family-level Phison PS5000-series controller reference lists confirmed pad maps per drive.
PC-3000 SSD Phison Utility.With the controller in Safe Mode, PC-3000 loads the Phison Utility and pushes a known-good loader into the controller's internal RAM over the vendor command channel. The loader bypasses the corrupted FTL service code and exposes the raw NAND command interface to the host.
Virtual translator reconstruction in RAM on the drive itself.The Phison utility scans surviving FTL journal pages and translation map fragments scattered across NAND, then uploads the rebuilt virtual translator into RAM on the drive itself, where it stays volatile and is never written back to the NAND. That reconstruction is non-destructive: if the rebuild produces a wrong map, the technician restarts without ever touching the original NAND. The drive's logical block addresses are then served to the imager through this virtual translator.
Sector imaging through controller ECC.The imager reads through the original controller's hardware LDPC and AES-256 decryption engines, so the bytes that land in the destination image are already plaintext and error-corrected. Bad pages are tracked in a defect map for later forensic reconstruction.
Silicon Motion SM2262EN, SM2263XT, and SM2269XT: LDR Loader Microcode Injection
Silicon Motion NVMe controllers behave differently in fault state. Instead of a test-pad-triggered Safe Mode, they expose a vendor command interface that accepts an alternative loader microcode (known in PC-3000 documentation as the LDR loader). The LDR runs in place of the corrupted on-NAND firmware service area, giving the technician direct access to NAND through the controller's own ECC and descrambling hardware.
Power-on with current limit.The drive is brought up on a bench supply with a current limit set below the level the host motherboard would tolerate. If a voltage regulator or PMIC is shorted, FLIR thermal imaging localizes the heat under the brief pulse, and board-level repair happens before any LDR work begins. A controller that boots stably is a prerequisite for the loader handshake.
LDR loader microcode injection through PC-3000 SSD Silicon Motion Utility.PC-3000 sends vendor-specific NVMe admin commands that hand the controller a small loader image. The controller copies the loader into its internal RAM and jumps to it, bypassing the standard firmware that would normally boot from the NAND service area. From the loader, the controller responds to a separate diagnostic command set rather than the standard NVMe protocol.
FTL bypass and raw page access.Under the LDR, the controller exposes raw NAND pages and the system area metadata that the standard firmware would have used to build the FTL. PC-3000 parses the surviving translation map fragments, reconstructs a virtual translator in RAM on the drive itself, and feeds reads through the controller's hardware ECC and AES-256 decryption engines. This is the same plaintext-by-the-original-controller mechanism that makes the procedure viable on encrypted drives.
DRAM-less HMB handling on SM2263XT and SM2269XT.These controllers normally store the FTL in Host Memory Buffer borrowed from system RAM. Once HMB is wiped by a power loss, only NAND-resident metadata survives. The LDR-driven scan reconstructs the translator from those NAND fragments alone; HMB is not used during recovery imaging.
Both workflows fall in the firmware-recovery bracket ($900–$1,200) when the controller is electrically healthy and only the firmware service area or FTL is corrupted. If the controller has board-level damage, the circuit-board-repair bracket ($900–$1,200) is done first to bring the controller online, then the firmware workflow runs on top of the repaired board. The full toolkit is documented at the SSD data recovery flagship.
TRIM / Deleted File Reality Check
Deleted file recovery on a functioning NVMe drive is not viable once garbage collection runs. NVMe implements the Deallocate command, the NVMe equivalent of SATA TRIM. On most NVMe implementations, garbage collection begins within seconds of file deletion.
Can Deleted Files Be Recovered from an NVMe Drive?
When you delete a file, the operating system sends a Deallocate command to the controller, which marks those NAND blocks for garbage collection.
NVMe's Deallocate is more aggressive than SATA TRIM on most controller implementations. The combination of higher throughput and deeper I/O queues means the controller processes Deallocate commands faster, shrinking the forensic window for deleted data to near-zero on a functioning drive.
If your NVMe drive is functional but you deleted files, the odds of recovery are low. If the drive has failed (not detected, wrong capacity, firmware corruption), TRIM/Deallocate cannot run and your data may still be intact on the NAND.
Emergency TRIM Disable Procedure
If you accidentally deleted files and the NVMe drive still functions, the single most important action is stopping the OS from sending further Deallocate commands. On Windows, run fsutil behavior set DisableDeleteNotify 1 as Administrator. On macOS, run sudo trimforce disable in Terminal. Then stop using the drive immediately.
How Do You Disable NVMe TRIM Before Recovery?
If you accidentally deleted files and the NVMe drive still functions, the single most important action is stopping the OS from sending further Deallocate commands. Every second TRIM runs, the controller erases more NAND blocks. Disabling TRIM does not recover deleted data on its own.
Disabling TRIM freezes the drive's current state so a professional imaging process has the best chance of reading surviving blocks.
This procedure only applies to logical deletion (files removed from the Recycle Bin or Trash while the drive is still operational). If the NVMe drive is physically dead, showing 0 bytes, or locked by firmware corruption, TRIM status is irrelevant.
Open Command Prompt as Administrator. Press Win + R, type cmd, then press Ctrl + Shift + Enter.
Check the current TRIM setting:fsutil behavior query DisableDeleteNotifyIf DisableDeleteNotify = 0, TRIM is currently enabled.
Disable TRIM:fsutil behavior set DisableDeleteNotify 1This stops Windows from sending Deallocate commands to all NVMe and SATA SSDs on the system. The setting takes effect immediately; no reboot required.
Do not use the drive.Stop writing files, installing software, or running Windows Update. Any write operation can overwrite the NAND pages where deleted data still resides.
In PowerShell, the equivalent command is fsutil behavior set DisableDeleteNotify 1 (same syntax). Windows applies a single DisableDeleteNotify flag that covers both NVMe Deallocate and SATA TRIM.
macOS APFS and HFS+
Open Terminal(Applications > Utilities > Terminal).
Disable TRIM:sudo trimforce disablemacOS will prompt for your admin password and warn that disabling TRIM may affect SSD performance. Type y to confirm. The system reboots automatically.
Do not use the drive.After the reboot, shut down the Mac and remove the NVMe drive (if removable) or ship the entire machine for recovery. Continued use risks overwriting deleted data.
After disabling TRIM
Disabling TRIM preserves the current NAND state but does not guarantee recovery.
The faster you act after deletion, the more blocks survive. For a full explanation of how the Deallocate command interacts with the Flash Translation Layer, see our technical reference on TRIM and recovery odds after TRIM.
Re-enable TRIM after recovery is complete. Windows: fsutil behavior set DisableDeleteNotify 0. macOS: sudo trimforce enable.
Leaving TRIM disabled long-term degrades SSD write performance and accelerates wear leveling imbalance.
Board-Level Repair for NVMe
NVMe board-level repair restores the original controller when its voltage regulator, PMIC, or passive components fail. Because many premium NVMe controllers implement hardware AES-256 encryption, the original controller must be repaired; on those drives, swapping a replacement controller loses the encryption keys permanently. We use Hakko FM-2032 irons, Atten 862 hot air stations, and Zhuo Mao BGA rework stations for this work.
How Does Board-Level NVMe Repair Recover Failed Controllers?
NVMe board-level repair restores the original controller when its voltage regulator, PMIC, or passive components fail. Because most NVMe controllers implement hardware AES-256 encryption, the original controller must be repaired; swapping a replacement controller loses the encryption keys and makes the data permanently unrecoverable. Board-level microsoldering repairs the surrounding power delivery circuit and brings the original controller back online.
We use Hakko FM-2032 microsoldering irons for passives and fine-pitch work, Atten 862 hot air stations for VRM and small-BGA reflow, and Zhuo Mao BGA rework stations for controller reballing.
Failed voltage regulators, capacitors, and resistors on NVMe drive PCBs are replaced at the iron or hot air station as appropriate.
For BGA controller packages with cracked solder joints (common after thermal cycling), we reball the BGA connections to restore electrical contact between the controller die and the PCB traces.
This is the same board-level repair capability that sets our Mac data recovery and logic board repair apart. Other recovery labs outsource board repair or skip it entirely, declaring the drive unrecoverable. We do the repair in-house.
Board repair is one technique in our SSD recovery toolkit. Firmware reconstruction and FTL rebuilds apply when the controller powers on but the data is logically inaccessible. Chip-off NAND extraction is the fallback when the controller cannot be revived at all.
NVMe SSD Repair: Diagnosing 3.3V Power Rail Failures
NVMe SSD repair starts with power rail analysis. M.2 NVMe drives receive 3.3V through the M.2 connector. When a voltage regulator or PMIC fails, the 3.3V rail shorts to ground and the drive draws excessive current at power-on; the motherboard cuts power within milliseconds as a safety measure, and the drive never enumerates.
Diagnostic point
Failure evidence
Tool used
Repair action
3.3V rail
Short to ground or excessive current at power-on
Bench power supply with current limiting
Stop before the motherboard cuts power again
PMIC or voltage regulator
Failed component heats under a brief current-limited pulse
FLIR thermal camera and Atten 862 hot air station
Replace or reflow the failed VRM or small-BGA package
MLCC capacitor near controller
Shorted passive visible on thermal imaging
Replace passives and fine-pitch components
Controller package
Cracked BGA solder joints after thermal cycling
Reball BGA connections to restore electrical contact
We use FLIR thermal imaging to locate the shorted component without applying full power. A brief, current-limited pulse through the 3.3V rail heats the failed component (typically a blown VRM or a shorted MLCC capacitor near the controller), making it visible on the thermal camera.
Once identified, the component is replaced with a Hakko FM-2032 microsoldering iron for passives and an Atten 862 hot air station for VRM reflow.
NVMe SSD repair through board-level work only succeeds when the original controller remains functional after component replacement. If the controller itself has permanently failed and the drive enforces hardware AES-256 encryption, neither a replacement controller nor a NAND chip transplant will restore data access.
The encryption keys are generated on and bound to the original controller die; without that specific silicon, the NAND contents are unreadable ciphertext. Board-level microsoldering to repair the surrounding power delivery circuit and bring the original controller back online is the only path to decrypted data. For drives without hardware encryption, NAND chip transplant to a donor PCB ($1,200–$2,500) remains a viable last resort.
Why Chip-Off NAND Extraction Fails on Encrypted NVMe SSDs
Some recovery labs advertise "chip-off" extraction for NVMe drives: desoldering the NAND flash chips, reading them with a standalone programmer, and reassembling the file system from raw pages. This technique worked on older SATA SSDs with unencrypted NAND. On modern NVMe controllers, it produces only ciphertext.
Boundary
What fails
Why it matters
Recovery path
NAND chip-off
Raw NAND pages read outside the controller
Modern NVMe controllers return ciphertext without the key
Not viable on encrypted Samsung, Phison, and Silicon Motion NVMe drives
AES-256 key boundary
Media key stays inside the controller die
No external programmer can extract the hardware key
Repair the original controller power delivery circuit
LDPC correction
Raw NAND reads include uncorrected bit errors
Errors compound across every 16KB page
Use the controller's own ECC engine through PC-3000 when supported
Unencrypted NVMe exception
Controller cannot be revived but NAND is not encrypted
Rare in post-2020 hardware
NAND transplant to a matching donor PCB as a last resort
Samsung Elpis (980 Pro) and the 990 Pro controller, Phison E18 (Corsair MP600 Pro, Kingston KC3000), and most Silicon Motion Gen4 controllers apply AES-256 XTS encryption to all data written to NAND, even on drives not marketed as "self-encrypting." The media encryption key is generated per-drive and stored in a secure hardware boundary inside the controller die.
No external programmer can extract it. Reading raw NAND pages without the key yields scrambled data that cannot be decrypted, reconstructed, or mounted.
The LDPC error correction codes stored alongside user data add another layer: without the controller's hardware LDPC engine, raw NAND reads include uncorrected bit errors that compound across every 16KB page.
For supported controllers (Phison, Silicon Motion), PC-3000 can enter Technological Mode and use the controller's own decryption and ECC engines to image the NAND. For proprietary controllers like Samsung's in-house NVMe silicon, PC-3000 firmware-level support does not exist; board-level microsoldering to repair the power delivery feeding the original controller is the only path to decrypted data.
For unencrypted NVMe controllers, NAND transplant to a matching donor PCB ($1,200–$2,500) remains a last resort. Contact us for a free evaluation with no diagnostic fees.
SLC Cache Folding Failures
Consumer NVMe drives use a pseudo-SLC write cache before moving data to slower TLC or QLC NAND. A power loss during the cache folding process corrupts the Flash Translation Layer and locks the controller in a firmware panic state. The drive reports 0 bytes or fails to enumerate. PC-3000 reconstructs the FTL for supported Phison and Silicon Motion controllers.
How Does SLC Cache Folding Cause NVMe Drive Failure?
Consumer NVMe drives use a pseudo-SLC write cache to absorb data at high speed before moving it to slower TLC or QLC NAND. A power loss during the cache folding process corrupts the Flash Translation Layer and locks the controller in a firmware panic state. The drive reports 0 bytes or fails to enumerate.
SLC Cache Architecture
TLC NAND stores 3 bits per cell; QLC stores 4 bits. Writing 3 or 4 bits per cell is slow because each cell needs precise voltage placement across multiple threshold levels. To mask this latency, the controller designates a portion of the NAND as pseudo-SLC, writing just 1 bit per cell at speeds matching the PCIe bus.
Samsung calls this Intelligent TurboWrite; Phison controllers (E12, E18) use a dynamic SLC pool that grows & shrinks based on available capacity.
During idle periods, the controller "folds" SLC-cached data into the TLC or QLC main array. Folding reads data from the SLC partition at 1 bit per cell, reprograms it into the TLC/QLC partition at 3 or 4 bits per cell, then erases the SLC blocks for reuse. This involves simultaneous reads, writes, & erases across multiple NAND die.
Power Loss During Folding
If power drops while the controller is mid-fold, the FTL journal enters an inconsistent state. Some logical blocks point to the SLC partition (old copy), others point to the TLC/QLC partition (new copy), and some point to blocks that were partially programmed.
The controller cannot determine which copy is valid on the next boot. It enters a firmware panic state and drops off the PCIe bus.
Consumer NVMe drives lack power loss protection capacitors. Enterprise U.2 & EDSFF drives include tantalum capacitors that hold enough charge for the controller to flush its write cache & update the FTL journal cleanly. Budget M.2 drives have no such protection.
NVMe APST Failures
NVMe controllers use Autonomous Power State Transition (APST) to cycle into low-power sleep states during idle periods. If the controller's firmware reports inaccurate wake-up latencies to the OS, the drive enters a deep sleep state it can't exit. The drive vanishes from BIOS.
How Do NVMe Power State Failures Cause Data Loss?
NVMe Power States: PS0 Through PS4
The NVMe specification allows drive manufacturers to define up to 32 power states (PS0 through PS31). Most consumer NVMe controllers implement five: PS0 through PS4. Each state trades performance for lower power draw, with an associated entry latency & exit latency the controller reports to the host OS.
PS0 (Active)
Maximum performance. The controller runs all PCIe lanes at full link speed. Typical power draw: 3-9W for Gen4 controllers like the Phison E18 or Samsung Elpis. No transition latency.
PS1-PS2 (Idle Low Power)
Reduced clock speeds and partial lane shutdown. Power drops to 1-2W. Exit latency is under 100 microseconds. The controller remains responsive to NVMe commands without re-training the PCIe link.
PS3 (Low Power with Link Down)
The PCIe PHY powers down. The link goes inactive. Exit latency climbs to 1-5 milliseconds because the controller must re-train the PCIe link from scratch. This is where APST bugs typically trigger: if the controller reports a 5ms exit latency but needs 50ms, the host times out & marks the device as absent.
PS4 (Deepest Sleep)
Sub-milliwatt power draw. The controller shuts down all internal clocks except the wake-up logic. Exit latency can exceed 100ms on some implementations. A controller stuck in PS4 won't respond to PCIe link training requests at all; the host sees an empty M.2 slot.
APST Failure Mechanism
During initialization, the host OS reads the controller's Identify Controller data structure and builds an APST transition table from the reported entry/exit latencies for each power state. The OS schedules transitions based on idle time thresholds. The failure sequence is specific: the controller enters PS3 or PS4, the PCIe PHY link powers down, and on wake-up the controller fails to complete link training within the window the host expects.
The PCIe bus drops the device. From the user's perspective, the drive disappears after a sleep cycle or cold boot.
The NAND flash is untouched during an APST failure. No data is written or erased. The controller cannot get back online to present the data to the host.
This makes APST failures one of the better-prognosis categories for recovery; the data is physically intact and only needs the controller to wake up through a non-standard path.
NVMe Drives with Known APST Bugs
Several controller families have documented APST wake-up failures. The Linux kernel maintains a NVME_QUIRK_NO_DEEPEST_PS quirk flag that disables the deepest power state for affected devices.
Kingston A2000 (firmware S5Z42105, SM2263EN controller): fails PCIe link training after PS3 entry on Linux & some Windows configurations
Samsung PM951 & 970 EVO: Linux kernel hardcodes NVME_QUIRK_NO_DEEPEST_PS for these models due to persistent wake-up failures. The PM951 uses Samsung's older Polaris/UBX controller; the 970 EVO uses Samsung's in-house controller
ADATA SX8200 Pro (SM2262EN controller): intermittent PS4 lock-up reported across multiple firmware revisions
SK Hynix BC501 (proprietary controller): found in Dell & Lenovo OEM laptops, disappears after suspend/resume cycles when APST is active
Maxio MAP1602-based drives (some Kingston NV2 variants): a Maxio MAP1602 APST bug causes disappearance after idle periods on Linux systems with aggressive APST scheduling
OS-Level APST Workarounds for Functioning Drives
If the drive still works but vanishes intermittently after sleep or idle, disabling APST at the OS level prevents the controller from entering the problematic deep sleep state. These workarounds only apply to drives that currently function.
Windows Registry Fix
Navigate to HKLM\SYSTEM\CurrentControlSet\Services\stornvme\Parameters\Device. Create a new DWORD value named EnableAPST and set it to 0. Reboot. The stornvme driver will skip APST configuration during initialization.
Linux Kernel Parameter
Add nvme_core.default_ps_max_latency_us=0 to the kernel boot parameters in your bootloader config (GRUB: /etc/default/grub, append to GRUB_CMDLINE_LINUX_DEFAULT). This sets the maximum tolerable latency to zero, preventing all APST transitions. Run update-grub and reboot.
PC-3000 Recovery Path for APST-Locked Drives
When the drive is permanently stuck and OS workarounds can't apply (the drive doesn't enumerate at all), PC-3000 bypasses the APST state machine by forcing the controller into Technological Mode. This mode skips the normal boot sequence, PCIe link negotiation, and power state configuration entirely. The controller wakes into a raw diagnostic state where NAND can be imaged directly through the controller's own hardware ECC & decryption engines.
Connect the drive to PC-3000 Portable III via NVMe diagnostic adapter
Send vendor-specific Technological Mode entry command (controller family dependent)
Bypass APST state machine & force controller into active diagnostic state
Read NAND through the controller's own ECC and decryption hardware
Image all user data sectors to a target drive, skipping bad pages
APST failures don't damage NAND cells, so recovery prognosis is high when the controller responds to Technological Mode commands. Board-level repair ($900–$1,200) applies if the controller's PMIC or voltage regulator also failed during the power state transition. For a complete overview of our capabilities across all SSD form factors & controllers, see our SSD data recovery service page.
NVMe Namespace Corruption
NVMe namespaces map host-visible block addresses to physical NAND locations. If the namespace metadata table corrupts, the drive appears on the PCIe bus but reports zero capacity. The NAND data survives because the controller has no instruction to erase it. PC-3000 reconstructs the namespace mapping from surviving NAND metadata.
What Happens When NVMe Namespace Metadata Corrupts?
NVMe namespaces are logical storage volumes that map host-visible block addresses to physical NAND locations. If the namespace metadata table corrupts, the drive appears on the PCIe bus but reports zero capacity. The NAND data survives because the controller has no instruction to erase it.
NVMe Namespaces: What They Are
A namespace is an abstraction layer between the host operating system & the physical NAND. The NVMe specification uses a 32-bit Namespace ID (NSID) field, allowing a controller to address over four billion namespaces in theory. Each namespace has its own Logical Block Address range and shares the controller's I/O submission and completion queues.
Enterprise deployments use multiple namespaces to isolate multi-tenant cloud workloads, separate SLC caching tiers from bulk QLC storage, and configure overprovisioning ratios per namespace. Consumer NVMe drives ship with a single namespace spanning the full capacity, but the namespace management layer still exists in the controller firmware and can still corrupt.
Namespace Deletion vs. File Deletion
File deletion sends a Deallocate (TRIM) command. The controller marks specific NAND blocks for erasure during garbage collection. The logical volume structure survives; only the file's data blocks are erased.
Namespace corruption is different from file deletion. When the namespace metadata table corrupts (from a power loss, firmware panic, or bad FTL write), the logical-to-physical mapping breaks but the NAND cells retain their data.
The controller cannot address the blocks, but it also has no reason to erase them. This makes namespace corruption recoverable when the mapping can be reconstructed from surviving metadata.
Intentional namespace deletion (the NVMe Delete Namespace admin command) is worse. The controller unmaps all logical blocks for that NSID and returns the physical capacity to the unallocated pool.
Background garbage collection can then erase those NAND blocks to prepare them for future writes. If the drive remains powered on after a Delete Namespace command, the data may be physically erased within minutes.
nvme-cli Risks
The open-source nvme-cli tool exposes raw NVMe admin commands including Create Namespace, Delete Namespace, Attach, Detach, and Format NVM. Bugs in older nvme-cli versions have caused unintended namespace deletion or secure erase across multiple attached NVMe devices when the wrong namespace ID was targeted. Running nvme delete-ns /dev/nvme0 -n 1 on the wrong device wipes the namespace mapping instantly with no confirmation prompt in non-interactive mode.
PC-3000 Namespace Recovery Procedure
Recovering a corrupted or deleted namespace requires bypassing the normal NVMe command interface and accessing the controller's internal metadata directly. The drive enumerates on PCIe but the OS sees no addressable storage, so standard imaging tools have nothing to read.
Isolate the drive on a dedicated PCIe bus via PC-3000 SSD diagnostic adapter to prevent OS interference
Force the controller into engineering/Technological Mode, bypassing namespace validation
Detach the corrupted namespace entry from the controller's active namespace table
Parse controller memory dumps & NAND system area pages for surviving namespace metadata (NSID, LBA ranges, FTL fragments)
Reconstruct a virtual translator that maps logical block addresses to physical NAND pages
Image all user data blocks through the reconstructed mapping to a target drive
Verify file system integrity & extract recovered files
Namespace recovery is a firmware-level procedure priced at $900–$1,200. If the controller itself has failed in addition to namespace corruption, board-level repair ($900–$1,200) is required first to bring the controller online before namespace reconstruction can proceed.
+$100 rush fee to move to the front of the queue is available to move to the front of the queue. For details on how the Flash Translation Layer maps logical blocks to physical NAND, see our FTL technical reference.
Video embed
Watch SSD Recovery in Our Lab
See our recovery process on camera. Louis Rossmann documents real recoveries on YouTube; the channel has 2.64M subscribers.
How does NVMe recovery differ from SATA SSD recovery?
NVMe drives use the PCIe bus and NVMe command set instead of SATA/AHCI. Recovery tools built for SATA cannot communicate with NVMe controllers. The PC-3000 Portable III with NVMe-specific modules acts as a PCIe Root Complex to send vendor-specific diagnostic commands. Many NVMe drives implement hardware encryption, which makes chip-off recovery not viable when encryption is present.
Can you recover data from a dead NVMe SSD?
In most cases, yes, if the NAND flash is intact. We use the PC-3000 SSD Extended modules to bypass corrupted firmware and access NAND directly. If the controller has electrical damage, board-level microsoldering can restore it. The primary limitation is hardware encryption: if the controller cannot be revived and the drive uses always-on AES-256 encryption, the data cannot be decrypted.
NVMe recovery ranges from $200–$2,500 across 5 published tiers. Simple data copies start at $200. File system recovery starts at $250. Board-level repair is $900–$1,200. Firmware corruption recovery is $900–$1,200. Advanced controller reconstruction and NAND chip transplants are $1,200–$2,500. Free evaluation, firm quote before any paid work, no data means no charge.
Why are NVMe drives more vulnerable to power loss than SATA SSDs?
NVMe's higher throughput fills the volatile write cache (DRAM or Host Memory Buffer) faster than data can be programmed to NAND. At any given instant, more data sits uncommitted in the buffer compared to a SATA SSD. A sudden power loss loses all buffered data and can corrupt the Flash Translation Layer if the controller was mid-update. Consumer NVMe drives lack the power loss protection capacitors found in enterprise U.2 and EDSFF models.
Do you recover M.2 2230 drives from Steam Deck and Surface?
Yes. M.2 2230 NVMe drives are used in the Steam Deck, Microsoft Surface Pro, Dell XPS, and Framework laptops. The smaller PCB has tighter component spacing, but the recovery workflow is the same: identify the controller, enter diagnostic mode via PC-3000, and image the NAND. We handle both WD SN740 and Micron 2400 variants commonly found in these devices.
Can deleted files be recovered from an NVMe SSD?
Rarely. NVMe implements the Deallocate command (equivalent to SATA TRIM), which instructs the controller to erase deleted blocks during background garbage collection. On most NVMe drives, this process completes within seconds of file deletion. Recovery of deleted files from a functioning NVMe drive is not viable in the vast majority of cases.
Should I disable TRIM before sending my NVMe SSD for recovery?
Only if the drive still functions and you accidentally deleted files. On Windows, open an Administrator Command Prompt and run fsutil behavior set DisableDeleteNotify 1. On macOS, open Terminal and run sudo trimforce disable. This stops the OS from sending Deallocate commands that trigger garbage collection. If the drive is physically dead or not detected, TRIM status does not matter because the controller cannot execute Deallocate commands on a drive that will not boot.
Can a failed NVMe SSD be repaired?
It depends on the failure. If the NVMe controller's voltage regulator or PMIC has failed, board-level microsoldering can replace the dead component and restore the controller ($900–$1,200). If firmware is corrupted but the controller still powers on, PC-3000 can enter the controller's Technological Mode to rebuild the Flash Translation Layer without replacing any hardware ($900–$1,200). If the controller is permanently dead and the drive uses hardware AES-256 encryption, the original controller must be revived through board repair; a replacement controller will not have the encryption keys. NAND chip transplant to a donor PCB is the last resort when the original board is beyond repair ($1,200–$2,500).
Why is my NVMe SSD not detected in BIOS?
An NVMe drive that disappears from the BIOS has usually entered a firmware panic state or suffered an electrical failure. When the NVMe controller's firmware corrupts (often after a power loss during an FTL update), the controller cannot complete its boot sequence and fails PCIe link training. The motherboard BIOS sees no device on that M.2 slot. In some cases, a panicked controller locks the PCIe bus entirely, causing the whole system to freeze during POST. Do not run CHKDSK, initialize the disk in Windows Disk Management, or format the drive if it reappears intermittently; these actions overwrite the NAND metadata that PC-3000 needs to reconstruct the FTL. Remove the drive and send it for professional recovery.
Why does a firmware panic on a Phison E12 or SM2263XT controller require lab recovery instead of a firmware update?
When a Phison E12 or Silicon Motion SM2263XT controller experiences critical firmware corruption, it locks into a protective ROM state that prevents further NAND damage. In ROM mode, the controller typically enumerates with a generic capacity (1 GB or 2 MB) or does not appear as a valid storage volume at all. Consumer firmware update tools (manufacturer dashboards, NVMe CLI utilities) cannot recognize or communicate with the drive in this state. Even if a tool detects the device, attempting a firmware flash risks overwriting the FTL metadata that maps logical addresses to physical NAND locations. Lab recovery uses PC-3000 to enter the controller's Technological Mode, which bypasses the normal boot sequence and injects vendor-specific loader microcode directly into the controller's RAM. This allows the technician to read the NAND and reconstruct the translator table without writing over the corrupted firmware.
Why did my NVMe drive's speed drop before it failed completely?
Many consumer NVMe drives use an SLC write cache that absorbs data at high speed before programming it to slower TLC or QLC NAND. Samsung calls this Intelligent TurboWrite; other manufacturers use similar pseudo-SLC caching. During sustained writes, the SLC buffer fills and the controller falls back to native TLC or QLC NAND speed. If the system loses power or the user force-reboots during this heavy write phase while the controller is running background garbage collection, the Flash Translation Layer can corrupt mid-update. The result is a drive that no longer boots or reports the wrong capacity.
What is the difference between M-key and B+M-key M.2 connectors for data recovery?
M-key M.2 connectors have a single notch on the right side and support PCIe x4 (four lanes). B+M-key connectors have notches on both sides and are electrically limited to PCIe x2 (two lanes) or SATA. B+M-key drives physically fit both B-key and M-key sockets. For data recovery, this keying distinction determines which diagnostic adapter connects the drive to PC-3000. Using an x2 adapter on an M-key drive can cause read timeouts on drives with marginal controller health. Forcing an M-key NVMe drive into a legacy B-key or SATA-only enclosure bends the connector pins.
How do you extract a failed M.2 2230 SSD from a Steam Deck or Surface Pro?
Steam Deck extraction requires removing the back panel (8 Phillips screws) and peeling the RF shield. Surface Pro models (7+, 8, 9, X, 11) have a small door beneath the kickstand secured with a Torx T3 (3IP Torx-Plus) screw. Using the wrong driver strips the screw head. Microsoft specifies a 15-degree extraction angle to avoid snapping the connector pins. If the drive has already failed, we recommend shipping the entire device to our lab rather than risking physical damage during removal. The 2230 drives in these devices (WD SN740, Micron 2400, Samsung PM991a) are DRAM-less and prone to FTL corruption from suspend/resume power cycling.
Why does my DRAM-less NVMe SSD show as a 1GB or 2MB disk in Windows?
DRAM-less NVMe controllers like the Silicon Motion SM2263XT and Maxio MAP1602 store the Flash Translation Layer in Host Memory Buffer (HMB) borrowed from system RAM instead of onboard DRAM. A power loss during an FTL update wipes the HMB copy, and the controller cannot rebuild it from NAND on its own. The controller enters a protective ROM state and enumerates with its raw hardware capacity (1 GB or 2 MB) instead of the drive's actual size. Do not initialize or format the disk in Windows Disk Management; that overwrites the NAND metadata needed for FTL reconstruction. For supported controllers like the SM2263XT, recovery uses PC-3000 to enter Technological Mode and rebuild the translator table from surviving NAND metadata. For controllers without PC-3000 firmware support, component-level board repair stabilizes the controller so it can complete its own FTL rebuild. This is a firmware-level recovery priced at $900–$1,200.
Can Intel VMD cause my NVMe SSD to disappear from BIOS?
Yes. Intel Volume Management Device (VMD) on 11th-Gen (Tiger Lake) and newer Intel processors intercepts the PCIe lanes connected to M.2 slots and re-presents them through Intel Rapid Storage Technology. If RST drivers are not loaded, or if the OS does not support VMD, the NVMe drive becomes invisible in both BIOS and the operating system. This is not a drive failure. To test, enter UEFI settings and disable Intel VMD under Advanced or Devices and I/O Ports, then reboot. If the drive reappears, the issue was VMD masking. If the drive remains invisible with VMD disabled, the controller has likely suffered a hardware or firmware failure requiring professional recovery.
How does NVMe SSD recovery differ from SATA SSD recovery?
NVMe drives use the PCIe bus with up to 64,000 I/O queues, while SATA drives use AHCI with a single queue of 32 commands. Recovery tools that send ATA commands cannot communicate with an NVMe controller. NVMe recovery requires PC-3000 Portable III acting as a PCIe Root Complex to send vendor-specific diagnostic commands. The bigger difference is encryption: most post-2020 NVMe controllers apply AES-256 hardware encryption bound to the controller die, making chip-off NAND extraction useless if the controller is dead. SATA controllers rarely encrypt data at the hardware level, so chip-off remains a fallback. NVMe recovery more frequently requires board-level microsoldering to revive the original controller.
Can my NVMe drive be dead if it works in a different slot but not in my USB enclosure?
Probably not. USB-to-NVMe enclosures use a bridge IC (Realtek RTL9210B, JMicron JMS583, or ASMedia ASM2362) to translate NVMe protocol to USB. These bridge chips overheat and fail, especially in Thunderbolt 3/4 and USB4 enclosures running sustained transfers. If you remove the M.2 drive from the enclosure and install it directly into a desktop motherboard M.2 slot, and it appears in BIOS with its correct model name and capacity, the enclosure bridge IC was the problem. Do not leave a failing drive powered in the enclosure; the bridge IC's repeated connect/disconnect cycles stress the NVMe controller, and idle time lets the controller run TRIM and garbage collection on your data.
What causes SLC cache folding failure on an NVMe SSD?
Consumer NVMe drives use a pseudo-SLC write cache that absorbs data at high speed (1 bit per cell) before 'folding' it into slower TLC or QLC NAND (3 or 4 bits per cell). Folding involves simultaneous reads, writes, and erases across multiple NAND die. A power loss during folding leaves the Flash Translation Layer in an inconsistent state: some logical blocks point to the SLC partition, others to the TLC partition, and some to partially programmed blocks. The controller cannot resolve the conflict on the next boot and enters a firmware panic. Consumer M.2 drives lack the power loss protection capacitors found in enterprise U.2 models. Recovery requires PC-3000 to access the SLC and TLC partitions independently and compare block sequence counters to reconstruct a valid translator. This is priced at $900–$1,200.
What does a WHEA_UNCORRECTABLE_ERROR mean for my NVMe SSD?
A WHEA_UNCORRECTABLE_ERROR is a Windows Hardware Error Architecture blue screen triggered when the NVMe controller physically stops responding to PCIe interrupts from the CPU. This is a hardware fault, not a software bug. Common causes include controller burnout, failing NAND modules producing uncorrectable ECC errors, or severe thermal throttling that forces the controller offline mid-operation. Running CHKDSK or consumer recovery software against a drive throwing WHEA errors stresses the failing hardware and risks pushing it into a permanent dead state. Power off the machine, remove the NVMe drive, and send it for professional recovery.
Will putting my failing NVMe drive in a USB enclosure fix the detection issue?
No. USB-to-NVMe bridge chips (commonly Realtek RTL9210B or JMicron JMS583) mask low-level NVMe diagnostic registers that PC-3000 needs for recovery. If the drive has firmware corruption or bad blocks, the bridge chip drops the connection under load, causing repeated connect/disconnect cycles that stress the controller. If you are dealing with a logical issue like deleted files or a RAW partition, leaving the drive powered on in a USB enclosure gives the controller idle time to execute TRIM and background garbage collection, permanently erasing recoverable data. A USB adapter cannot bypass a PCIe link training failure; if the drive is not detected via direct M.2 or PCIe connection, a USB bridge will not fix it.
What is APST and how does it cause NVMe drive failure?
Autonomous Power State Transition (APST) is an NVMe protocol feature that moves the controller into low-power sleep states during idle periods. Some controllers report inaccurate wake-up latencies to the OS, causing the drive to enter a deep sleep state (PS3 or PS4) that it cannot exit. The drive vanishes from the system after a sleep cycle or cold boot. The NAND flash data is still intact; the controller cannot complete its PCIe link training sequence to come back online. Known affected models include the Kingston A2000 (firmware S5Z42105) and Samsung PM951. Recovery requires PC-3000 to force the controller into Technological Mode, skipping the APST state machine and accessing NAND directly.
What is NVMe namespace corruption and how does it differ from file deletion?
An NVMe namespace is a logical storage volume that maps host-visible block addresses to physical NAND locations. Namespace corruption destroys this logical map; the drive enumerates on the PCIe bus but reports zero capacity. When the metadata table corrupts naturally (power loss, firmware panic), the NAND cells retain their data because the controller has no reason to erase them. Recovery uses PC-3000 to parse surviving metadata and reconstruct a virtual translator. However, if a namespace is intentionally deleted via the NVMe Delete Namespace command, the controller unmaps the blocks and background garbage collection can erase the NAND cells within minutes. Power off the drive immediately after an accidental namespace deletion.
Why must NVMe board repair come before data extraction on encrypted drives?
On modern NVMe controllers (Phison E26, Silicon Motion SM2262EN, Samsung Elpis), the AES-256 Media Encryption Key is generated per-drive at first power-on and stored inside a secure hardware boundary on the controller die. If the controller has electrical damage, it cannot decrypt its own NAND, and a chip-off NAND read returns ciphertext that no external tool can recover. Replacing the controller with a donor controller does not help because the donor has its own MEK. The only path to plaintext is microsoldering the original board back to a working state so the original controller wakes up and decrypts its own NAND through PC-3000 Technological Mode.
What is Safe Mode entry on a Phison PS5016-E16 controller?
Phison PS5012-E12 and PS5016-E16 NVMe controllers expose a Safe Mode test pad on the drive PCB. Briefly shorting the pad to ground at the moment of power-on prevents the controller from running its normal boot sequence; it enters a minimal diagnostic state that accepts vendor commands over PCIe. PC-3000 then loads the Phison utility, pushes a known-good loader into the controller's internal RAM, scans surviving FTL journal pages, and builds a virtual translator and uploads it into RAM on the drive itself, where it stays volatile and is never written back to the NAND. Reads pass through the original controller's hardware LDPC and AES-256 decryption engines so the imaged bytes are already plaintext.
What is LDR loader microcode injection on a Silicon Motion SM2262EN controller?
Silicon Motion NVMe controllers (SM2262EN, SM2263XT, SM2269XT) accept an alternative loader microcode (the LDR loader) through vendor-specific NVMe admin commands. PC-3000 hands the controller this small loader image; the controller copies it into internal RAM and jumps to it, bypassing the corrupted firmware that would normally boot from the NAND service area. Under the LDR, the controller exposes raw NAND pages and system area metadata so PC-3000 can reconstruct a virtual translator in RAM on the drive itself and image the drive through the controller's own ECC and decryption hardware. This is the primary recovery path for DRAM-less SM2263XT and SM2269XT drives where Host Memory Buffer FTL has been wiped by power loss.
Where does the rebuilt virtual translator live during a PC-3000 recovery?
On Phison PS5012 and PS5016 NVMe controllers, the PC-3000 SSD Phison utility rebuilds the translator and uploads it into the drive's own RAM, where it stays volatile. This is non-destructive: if the rebuild produces a wrong logical-to-physical map, the technician restarts without ever touching the original NAND. The drive's logical block addresses are then served to the imager through that volatile translator. The same approach is used on Silicon Motion SM22xx controllers under the LDR loader. The rebuilt translator is never written back to the NAND, because that would overwrite the surviving FTL fragments PC-3000 might need to revise its reconstruction.
What does the BIOS error "no NVMe device found" mean for data recovery?
"No NVMe device found" means the motherboard could not establish a PCIe link with the SSD's controller; in most cases the NAND flash still holds your data. The common, recoverable cause is a controller firmware panic, where the controller enters a protective state and fails PCIe link training, often after a power loss interrupted an FTL update. The NAND is intact; the controller just cannot boot its own firmware to present the drive. The rarer, unrecoverable case is electrical death of the controller die, where the silicon itself is gone. We connect the drive to PC-3000 and force the controller into Technological Mode, which skips past the corrupt boot firmware to reconstruct the FTL and read the NAND directly. Do not run CHKDSK, do not initialize the disk in Windows Disk Management, and do not format it if it reappears intermittently; those overwrite the NAND metadata PC-3000 needs. Firmware-level recovery is the firmware tier at $900–$1,200; if the board needs electrical repair first, that work is $900–$1,200. Diagnosis is free, and if we can't recover your data, you don't pay.
Why does my NVMe drive disappear after a motherboard swap or PCIe slot change?
After a motherboard swap or moving the drive to a different M.2 or PCIe slot, the drive is usually healthy and hidden by a BIOS configuration difference, not a failure. The most common non-failure cause is Intel VMD being enabled on the new board, so the drive needs RST drivers loaded or VMD disabled in UEFI before it appears; CSM and legacy boot mode conflicts do the same thing. Some M.2 slots are SATA-only or share PCIe lanes with the SATA ports, so an NVMe drive in the wrong slot stays invisible, and a few boards disable a slot until you change a BIOS setting. The safe checks are to reseat the drive, confirm the slot actually supports NVMe, toggle Intel VMD in UEFI, and update the BIOS. It is a real fault only when the drive stays invisible across multiple known-good NVMe slots with VMD disabled and CSM correct; at that point the controller has likely suffered a firmware panic or electrical failure and needs lab recovery, the same path as a drive that throws a no-device error in BIOS.
Can data be recovered from an NVMe SSD after a PCIe link training failure?
Yes, in most cases, if the NAND flash is intact. PCIe link training is the handshake the motherboard and the SSD controller perform at power-on; when the controller's firmware is corrupt it can't complete that handshake, so the slot reports no device even though your data is still sitting on the NAND. PC-3000 Portable III acts as a PCIe Root Complex and forces the controller into Technological Mode, accessing the NAND directly past the corrupt boot firmware and reconstructing a virtual translator in RAM on the drive itself. If the controller has electrical damage, we restore it first with board-level microsoldering, then run the same firmware path. One caveat on encryption: if the controller is permanently dead and the drive uses always-on AES-256 hardware encryption bound to the controller die, the original controller has to be revived, because a donor controller doesn't hold the encryption keys. Firmware recovery is $900–$1,200 and board-level repair is $900–$1,200; this is data recovery work in our Austin lab, not a consumer DIY repair.
“I consulted Rossmann Repair Group for data recovery services. A new IT client was recently referred to me, because his main computer crashed and his business database went offline as a result. It turned out that the computer crashed because its main storage, a 500 GB Solid State Hybrid Drive, failed. That part was easy - replace it with a new 1 TB SSD and reinstall Windows along with the software he uses. However, the data on the SSHD was critical and would have meant serious problems for his business if he didn't get that back.
That's where Rossmann Repair Group came in.”
