SSD Controller Architecture Reference
SandForce SF-1200 & SF-2200 SSD Controller Architecture
SandForce SF-1200 & SF-2200 are the SATA SSD controller families that defined the 2010-2014 consumer SSD market. The SF-1200 / SF-1222 is the SATA II part; the SF-2200 family (SF-2241 budget 4-channel, SF-2281 / SF-2282 8-channel) is the SATA III evolution. Both run the DuraClass pipeline: DuraWrite data reduction, AES-128 transparent encryption, RAISE, & BCH ECC. This page is a technical reference for that architecture & for the ROM-mode fallback these drives enter on firmware failure. For lab-supported controller workflows see our SSD data recovery service.
Updated September 2026
Lab Support Status
Lab Support Status for SandForce SF-1200 / SF-2200
Rossmann does not currently offer in-lab recovery for SandForce SF-1200/2200 series controllers.
The ACELab PC-3000 SSD supported controller matrix does not list the SandForce family as an actively supported active-recovery target. This page exists as an architectural & identification reference, not a service page. For related Marvell SATA work and the broader legacy SATA context see the SandForce & Marvell legacy hub. For controllers our lab does support see the SSD controllers index.
Controller Family Identification
SandForce SF-1200 / SF-2200 Variant Table
The SandForce lineup splits cleanly between the first-generation SATA II SF-1200 / SF-1222 and the SATA III SF-2200 series. The SF-2281 is the controller most consumer drives shipped with; the SF-2282 is the high-capacity 16-byte-lane variant in a BGA-400 package. All SF-2200 variants share the same DuraClass data path & the same firmware failure signature.
ControllerInterfaceNAND ChannelsPackageCommon Drives / Notes
SF-1200 / SF-1222SATA II (3 Gbps)BGAFirst-generation DuraClass silicon. OCZ Vertex 2, Agility 2, Corsair Force F-series, ADATA S599.
SF-2200 / SF-2241SATA III (6 Gbps)4BGA-256Entry SATA III variant. Earlier client SSDs and reference designs.
SF-2281SATA III (6 Gbps)8BGA-256Dominant consumer part. OCZ Vertex 3, Kingston HyperX 3K, Corsair Force GT, Intel 520 / 330, ADATA S510.
SF-2282SATA III (6 Gbps)8 (16 byte lanes)BGA-400High-capacity variant. Corsair Force GT 180GB, OWC Mercury Extreme Pro 6G 240GB, OCZ RevoDrive 350.
Controller Family Failure-Mode Differences
SF-1222 vs SF-2241 vs SF-2281 Failure Differences
The three SandForce parts most people arrive here for separate cleanly on interface generation, NAND channel count, & market positioning. Those are the attributes worth identifying, because the deeper per-variant NAND & ECC tuning is not documented in any public source we can stand behind.
The variant table above carries the full lineup; the notes below describe how each of the three presents when it fails & why that presentation is the same regardless of which one is on the board. For the controllers our lab does support, see the SSD controllers index.
VariantInterface / ChannelsFirmware-Failure SignatureNotes
SF-1222SATA II (3 Gbps); the vendor never published a channel count for this partController aborts firmware boot & enumerates in ROM-mode with a generic silicon descriptor instead of the drive nameFirst-generation DuraClass silicon. The interface generation does not change that behavior, & it does not change the fact that the user data on the NAND sits behind the controller-bound AES key described in our SSD data recovery reference.
SF-2241Entry SATA III (6 Gbps); built around 4 NAND channels for lower-cost & lower-capacity drivesFalls into the identical ROM-mode stateThe data path is the same DuraClass pipeline: DuraWrite data reduction, AES-128, RAISE, & BCH ECC.
SF-22818-channel SATA IIIEnds in ROM-mode with the controller alive on the bus but unable to load the firmware that translates LBAs back to physical NANDThe 8-channel SATA III controller that shipped in most consumer SandForce drives. Carries the firmware history this page already documents: the early SATA Sleep / Wake BSOD lockup, & the separate broken-TRIM regression in firmware 5.0.1 / 5.0.2 that accelerated system-area wear.
The point of separating the three is identification, not recovery outcome. Budget 4-channel or mainstream 8-channel, SATA II or SATA III, every variant runs the same DuraClass data path & presents the same firmware-failure signature, so the recovery constraint is identical across the family. All of them sit outside the ACELab PC-3000 SSD active-recovery matrix, consistent with the lab-support disclaimer near the top of this page & the broader SandForce & Marvell legacy hub.
Why Seagate later used SandForce IP
SandForce was a fabless IP vendor; it designed controller silicon & licensed it to drive makers rather than building finished SSDs. That IP changed hands several times. LSI Corporation acquired SandForce in January 2012, Avago acquired LSI in May 2014, & later that same month Seagate announced its intent to buy LSI's Flash Components Division.
That lineage is the documented reason Seagate later used SandForce-derived controller IP in its own storage lines. The corporate history does not change any drive's recovery status: a SandForce-based drive remains outside the lab-supported controllers covered on our controllers index, whoever owned the design.
DuraClass Data Path
DuraClass Transformations on the Write Path
Every host write into a SandForce drive passes through the DuraClass transformations before the bytes land on NAND. That matters during any forensic attempt to reverse it, because the key material and the write-reduction state both live inside the controller silicon. SandForce never published the internal ordering of these stages.
  • DuraWrite data reduction. Incoming host LBAs are reduced in on-die SRAM (SandForce parts ship without external DRAM). Compressible payloads (text, uncompressed binaries, database logs, XML) shrink to a variable physical length; already-compressed input (JPEG, MP4, ZIP, encrypted volumes) passes through near 1:1.
  • AES-128 transparent encryption. The compressed payload is encrypted with a controller-resident AES key. The encryption is always on regardless of whether the user enabled an ATA security password; the password gates access to the key, it does not gate encryption.
  • RAISE. Redundant Array of Independent Silicon Elements adds redundancy across the flash, which the vendor describes as recovering completely lost sectors, pages, and blocks at runtime.
  • BCH ECC. Bose-Chaudhuri-Hocquenghem error correction codes are appended per-page to handle bit-level NAND read errors before the data leaves the controller.
  • NAND program. Final committed write of the reduced, encrypted, ECC-protected payload to an MLC / TLC page.
On read the controller undoes all of it. Any external attempt to reconstruct user data from raw NAND has to reproduce every one of those transformations with the same parameters & key material that lived inside the original controller.
AES-128 Transparent Encryption
The AES key is bound to the controller die. There is no publicly documented method to extract that key from a dead controller. If the controller cannot boot & serve as the decryption oracle, raw NAND pages read on an external programmer remain ciphertext indefinitely. This is the encryption barrier referenced on our broader SSD hardware encryption reference. Lab-supported controller families that share this transparent-encryption pipeline are listed under supported SSD data recovery workflows.
Why Chip-Off Yields Ciphertext
Why Chip-Off NAND Extraction Yields Ciphertext
Chip-off recovery is the practice of desoldering the NAND packages from a dead PCB & reading them directly on a NAND programmer. On older unencrypted controllers the resulting binary image can be processed offline to rebuild user data. On SandForce SF-2200 drives that workflow does not produce readable output, & the reason is architectural rather than procedural.
The raw NAND image off an SF-2281 contains reduced, AES-128 encrypted, ECC-protected pages. Reversing that to user data requires the controller's AES key, its proprietary write-reduction state, & the FTL mapping tables (held in SRAM & flushed periodically to NAND system-area blocks).
The AES key is the hard stop. Without on-die key extraction, which is not publicly documented for this silicon, the ciphertext on the NAND remains opaque.
This is the same encryption barrier described on the chip-off NAND reference for modern self-encrypting drives. It applies retroactively to the SandForce generation because DuraClass shipped with always-on transparent encryption.
ROM-Mode Firmware Panic
ROM-Mode Firmware Panic on SandForce Silicon
When a SandForce SF-2200 controller cannot complete its firmware boot sequence, it falls back to a vendor descriptor diagnostic mode & presents itself on the SATA bus under a generic silicon descriptor rather than the consumer-facing model name. This is a controller state, not a SMART failure event.
Triggers documented for this state include corruption of the firmware image inside the NAND system area (the early SF-2281 generation suffered the SATA Sleep / Wake BSOD lockup patched in base firmware 3.3.2, and a separate broken-TRIM regression in firmware 5.0.1 / 5.0.2 that accelerated system-area wear), failure to read system-area blocks due to NAND wear in reserved cells, & controller PMIC or supply-rail problems that prevent a clean cold boot.
A controller that still answers in ROM-mode is alive enough to respond on the SATA bus, & the NAND pages above the system area are typically untouched. The user data is on the chips. Restoring access requires an active recovery utility that can speak to the controller in ROM-mode & walk it back through firmware reload.
As noted in the lab-support disclaimer above, that active utility is not part of the ACELab PC-3000 SSD supported controller matrix for the SandForce family. See the firmware panic & ROM-mode reference for the analogous behavior on supported controller families.
Loader Microcode & Virtual Translator
Loader Microcode and the Virtual Translator
The ROM-mode state above raises a fair question: if the NAND pages are intact & the controller still answers on the bus, why can the drive not be read back? The answer is the two-step mechanism that active recovery platforms use on the controllers they do support, & the reason that mechanism stops short of the SandForce family.
On an FTL-based SSD controller, a normal cold boot loads the firmware & the translator modules out of NAND system-area blocks into the controller's volatile SRAM. When those modules are corrupt the controller aborts to ROM / safe mode, which is the state described in the section above.
An active recovery platform works around a corrupt firmware image on a supported drive by injecting a small controller-specific loader microcode straight into the controller's RAM, sidestepping the broken NAND-resident firmware. That loader runs read-only. It disables the controller's autonomous background work (garbage collection, wear-leveling, & the firmware mask that returns zeros over TRIMmed ranges) & exposes raw NAND read access without writing to the chips. A loader is tied to one silicon family; a loader compiled for one controller does not run on another.
Rebuilding the virtual translator
Raw NAND access alone is not enough. The logical-to-physical (L2P) map that tells the drive which physical page holds a given LBA is gone or inconsistent once the firmware fails. The platform rebuilds a virtual translator and uploads it into RAM on the drive itself, never writing it back to the NAND, by reading every physical NAND page through the controller & parsing the out-of-band (OOB) spare-area metadata stamped on each page: the LBA tag, a block sequence number, & wear counters.
Because flash never overwrites in place, one LBA can exist in several physical pages at once; the rebuild keeps the copy carrying the freshest sequence number. The compiled map then lets the platform image the drive sector by sector.
Why "supported controller" is an operational claim
For a platform to support a controller family, its developers had to reverse-engineer that exact controller's factory access mode, obtain a working loader for its RAM, & work out the math that rebuilds that family's virtual translator from its OOB layout. That investment is why Silicon Motion, Phison, Marvell, Maxio MAS0902, older Samsung, Indilinx, OCZ Barefoot 3, & Intel appear on the supported list, & why SandForce does not. Support is a per-silicon engineering outcome, not a blanket capability.
Why SandForce defeats this chain before the key problem
SandForce silicon breaks the virtual-translator approach one layer earlier than the AES-key barrier the rest of this page describes. SandForce is DRAM-less: the working FTL cache lives in on-die SRAM & the bulk FTL state lives in NAND system-area blocks. The DuraClass transformations sit between the host and the NAND, so a raw dump off the chips is not the byte stream a translator rebuild expects.
A raw chip-off dump therefore cannot even be parsed into a translator, and the AES key material stays inside the controller. Reversing the data requires the original controller, or a functional replica of it, to undo every stage the write path applied.
No loader for the SandForce family exists in the ACELab PC-3000 SSD supported matrix, which is the concrete reason the silicon sits outside lab-supported active recovery. Some specialized labs have built proprietary in-house engineering for this controller; that work is not part of any commercially supported platform & is not a service offered here.
For these reasons SandForce SF-1200 / SF-2200 remains outside the lab's supported controllers, consistent with the lab-support disclaimer near the top of this page. For the controller families that are supported, see the SSD controllers index & the firmware panic & ROM-mode reference for the analogous loader-driven workflow on those families.
Related Architecture References
Related SSD Architecture References
SandForce sits inside a wider SATA controller landscape. The pages below cover the adjacent architectures & the recovery topics that intersect with SandForce behavior.
SATA SSD Lab Pricing Context
SATA SSD Recovery Pricing (Supported Controllers)
The pricing tiers below apply to SATA SSDs built on controller families inside the ACELab PC-3000 SSD supported list (Silicon Motion, Phison, Marvell, Maxio MAS0902, older Samsung, Indilinx, OCZ Barefoot 3, Intel), handled by our SSD data recovery lab. They are reproduced here for architectural context. They do not represent a quoted service for SandForce SF-1200 / SF-2200 silicon; per the lab-support disclaimer near the top of this page, SandForce active recovery is not currently offered. Starting tier on supported SATA work is From $200. +$100 rush fee to move to the front of the queue.
SandForce SF-1200 / SF-2200 FAQ
Architecture, identification, and lab-support questions about SandForce SATA SSD controllers.
Why does a SandForce drive stop reporting its model name in BIOS?
When a SandForce SF-1200 or SF-2200 series controller cannot complete its firmware boot sequence, it falls back to a vendor descriptor diagnostic state and the host reads back a generic silicon descriptor instead of the consumer drive name. This is a controller-level ROM-mode state, not a SMART failure or a NAND wear event. The user data on the NAND chips is generally untouched at this point; the controller is unable to load the firmware image needed to translate logical block addresses back to physical NAND pages.
Why can't chip-off NAND extraction recover data from an SF-2281?
The SF-2281 runs the DuraClass transformations on every host write before the bytes touch NAND: DuraWrite data reduction, AES-128 transparent encryption, and RAISE. Removing the NAND chips and reading them on a programmer yields reduced, encrypted pages. Without the original controller, the raw NAND image cannot be reassembled into user files.
What is the difference between the SF-1200 and SF-2200 controller families?
The SF-1200 / SF-1222 is a SATA II (3 Gbps) part running the first-generation DuraClass pipeline. The SF-2200 family moved to SATA III (6 Gbps), with the SF-2241 as a budget 4-channel variant and the SF-2281 / SF-2282 as 8-channel parts, all running an updated DuraClass implementation with stronger BCH ECC. The SF-2282 doubles the byte-lane width to 16 lanes inside a BGA-400 package, allowing higher-capacity drives. All variants share the same architectural pipeline: DuraWrite data reduction, AES-128, RAISE, BCH ECC, and the same ROM-mode fallback on firmware failure.
Why does standard SSD recovery software not fix a BSY SandForce drive?
Standard logical file-recovery software reads logical blocks from a drive that enumerates correctly on the SATA bus. A SandForce SF-2281 stuck in ROM-mode never presents a usable LBA range. There is no accessible logical block range for the software to scan. Restoring access requires hardware-level controller diagnostics, not file-recovery software.
Why can't a virtual translator be rebuilt from a SandForce chip-off?
An active recovery platform images a supported drive in two steps: it injects a controller-specific loader microcode into the controller RAM for read-only raw NAND access, then rebuilds a virtual translator in RAM on the drive itself by parsing the out-of-band spare-area tags on each NAND page (LBA tag, block sequence number, wear counters). SandForce defeats that chain one layer before the AES-key barrier. The DuraClass transformations sit between the host and the NAND, so a raw dump off the chips is not the byte stream a translator rebuild expects. A raw chip-off dump cannot be parsed into a translator at all, and no loader for the SandForce family exists in the ACELab PC-3000 SSD supported matrix. That is the concrete reason SandForce SF-1200 / SF-2200 sits outside lab-supported active recovery.
Does Rossmann recover SandForce SSDs?
Rossmann does not currently offer in-lab recovery for SandForce SF-1200 / SF-2200 series controllers. The ACELab PC-3000 SSD supported list does not include the SandForce family as an actively supported controller. For related Marvell SATA work and the broader legacy SATA architecture, see the SandForce & Marvell legacy reference at /services/ssd-data-recovery/sandforce-marvell-legacy. For controllers covered by our lab, see /services/ssd-data-recovery/controllers.
What lab tools support SandForce active recovery?
PC-3000 SSD, the industry-standard active recovery platform from ACELab, does not list SandForce SF-1200 / SF-2200 silicon as a supported controller family in its current supported-drives matrix. Without an active utility for the silicon, chip-off does not get past the DuraWrite, AES-128, and RAISE stages.
Need SSD Data Recovery?
Free evaluation, no diagnostic fee, no data, no fee. Single-location lab in Austin, TX.
