Product-Specific Recovery
WD My Passport Data Recovery
My Passport not showing up? Dropped it? Set a password and forgot it? WD Passports have hardware encryption, and that makes recovery harder. We recover data from encrypted, clicking, and damaged Passports.
Updated April 2026
12 min read
WD Encryption Warning
Important: WD My Passport Hardware Encryption
WD My Passport drives encrypt your data in hardware, even if you never set a password. This has major implications for recovery:
  • The USB port is built into the drive's own board. There's no SATA connector.
  • The ROM on that board holds adaptive parameters tuned to that one drive
  • The wrapped key is also stored in the Service Area on the platters, so recovery is possible with a compatible SATA donor even if the original board is destroyed
  • Do NOT throw away the enclosure, even if it seems dead
Common Problems
Common WD My Passport Problems
Not Showing Up / Not Detected
The drive doesn't appear in File Explorer or Disk Management when connected.
Possible causes:
  • USB bridge board failure
  • Cable or USB port issue
  • Internal drive not spinning
  • Encryption chip malfunction
  • Corrupted bridge firmware. On Initio-bridge models, a failed bridge firmware update can make your computer list the drive as "Initio Default Controller" instead of its real name.
  • USB port broken off the PCB. The USB bridge is built into the drive's own board, so the drive can't go into a different enclosure. We solder the port back onto the original board or do a SATA conversion.
Recovery: $600–$900
Clicking Sound
It clicks or ticks when you plug it in. If it keeps clicking, that's a hardware fault. The sound won't tell you which part failed. We find that out on the bench.
Recovery: $1,200–$1,500
Dropped / Physical Damage
The drive was dropped while running or while connected. May or may not show symptoms immediately.
Potential damage:
  • Head crash
  • Platter damage
Recovery: $600–$900 to $1,200–$1,500 depending on damage
Password Forgotten
You set a WD Security password and can't remember it. Drive is locked.
Without that password, nobody can decrypt the data, and that includes us.
Models We Recover
WD Passport Models We Recover
Standard My Passport
  • USB 3.0 / USB-C models
  • Hardware encrypted
WD My Passport Recovery Pricing
Service TierPrice RangeDescription
File System RecoveryFrom $250Logical corruption, partition loss, accidental format on a healthy drive
Firmware / USB Bridge Repair$600–$900USB controller failure, encryption key extraction
Head Swap + Encryption$1,200–$1,500The drive needs donor heads before we can decrypt it. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
Surface / Platter Damage$2,000Head crash, platter scoring. Requires platter cleaning & head swap. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
Need it faster? +$100 rush fee to move to the front of the queue. SMR (Shingled Magnetic Recording) drives require more work at the firmware and head-swap tiers due to their overlapping track architecture.
No Data, No Charge. No diagnostic fees.
PCB Swap Warning
Do Not Swap the PCB
A plain board swap won't work. Each board's ROM carries adaptive parameters tied to its own drive.
To get your data back, we repair the original board, or we use PC-3000 to read the wrapped key from the Service Area through a compatible SATA donor.
Technical Methodology
How We Recover WD My Passport Drives
We solder SATA data pairs directly to test points on the Passport PCB, bypassing the USB bridge entirely. This gives PC-3000 direct Service Area access to the drive firmware. Standard SATA adapters do not work because these drives have no SATA connector; the USB bridge is integrated into the only circuit board.
SMR Firmware Repair via PC-3000
Spyglass (WD40NMZW) and Palmer drives use SMR, short for shingled magnetic recording.
Module 190 (T2 Translator) corruption
When Module 190 is damaged, every sector reads back as zeros. We write the original Module 190 back, lock user-area writing in PC-3000, and build the imaging map from the translator data.
Always-On AES-256 Encryption
If you set a password in WD Security, that password becomes a Key Encryption Key (KEK). The KEK encrypts the Data Encryption Key (DEK).
A donor board dropped in blind won't work by itself. It doesn't have the adaptive parameters from your original ROM. The wrapped DEK is also stored redundantly in the drive's Service Area, though. With a compatible SATA donor, PC-3000 can read it using vendor-specific commands and decrypt the image even when the original board is damaged or its ROM won't read.
ACE Lab says PC-3000 can unlock Techno Mode on WD SED drives in every SMR 2.5-inch and 3.5-inch family, and it doesn't need a custom unlocked PCB to do it.
Why Software Recovery Fails
Why Software Recovery Fails on Modern WD Passports
Consumer recovery software (Disk Drill, EaseUS, Recuva) depends on two things: an intact firmware translator that maps logical sectors to physical locations, and a working USB bridge that presents the drive as a standard block device. If either one is broken, no software you download will fix it.
Firmware Corruption Blocks All Software Access
If Module 190 (the T2 translator) is damaged, every sector reads back as zeros. Software scans the drive and finds nothing. Nothing running on your computer can reach the Service Area to repair it. We do that with PC-3000.
WD Drive Platform Families
WD Passport Internal Drive Platforms
WD has used different internal drive platforms across Passport generations.
Spyglass / Spyglass 2 / Spyglass 2 Ultra / Spyglass 3 (WD40NMZW, WD40NDZW, WD50NDZW)
A high-capacity SMR platform, used in 4TB & 5TB Passports over several generations. Spyglass 2 Ultra drives sit on 2060-810035 (USB 3.0) and 2060-810033 (USB-C) boards. Module 190 corruption is a known firmware failure on this family. Firmware repair: $600–$900.
Palmer
An SMR platform that uses a T2 translator.
Charger (WD20SDRW)
A 2TB SMR platform. Head swap: $1,200–$1,500. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
Oakmont 2 (WD60NDZW)
A 6TB platform WD uses in My Passport. Firmware repair: $600–$900. Head swap: $1,200–$1,500. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
Can data be recovered from an encrypted WD My Passport?
Yes. Your My Passport encrypts in hardware even if you never set a password. The wrapped Data Encryption Key is stored redundantly in the drive's firmware Service Area. That means we can extract the key and decrypt your data even when the USB board is dead. If you set a WD Security password and lost it, the data can't be decrypted.
Why is my WD My Passport not showing up?
Common causes include USB bridge board failure, internal drive failure (clicking, not spinning), encryption chip issues, or simple cable/port problems. Try a different cable and port first. If it still does not show up, professional diagnosis is needed.
Can I remove the drive from the enclosure myself?
You can take it out of the plastic shell, but the USB port is built into the drive's own circuit board, and there's no SATA connector. The wrapped encryption key is also stored in the drive's Service Area. PC-3000 can extract it from there through a compatible SATA donor, even if the original board is destroyed.
How much does WD My Passport recovery cost?
At Rossmann Repair Group, firmware and controller repair is $600–$900. A mechanical failure that needs a head swap is $1,200–$1,500. All with no data, no charge guarantee.
Can I run CHKDSK or recovery software on a failing WD Passport?
CHKDSK works on the file system. It can't reach the drive's firmware translator. On a drive that's failing physically, it forces endless read retries, and those wear out weak heads and score the platters.
What should I do if I dropped my WD Passport while it was running?
Don't plug it back in. Dropping a drive while it's running can damage the heads or the platter surface. Every time you power it on again, you risk turning a recoverable head crash into permanent platter scoring. We open it in a 0.02 micron ULPA-filtered clean bench and, if it needs one, swap in a head stack assembly from a matched donor drive. Recovery for head swap cases: $1,200–$1,500. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
Can data be recovered from a dead WD Passport?
A WD Passport that won't power on, makes no sound, and shows no LED activity can have a failed USB bridge controller or a blown TVS diode on the PCB. We either repair the original circuit board or do a SATA conversion to get around the dead bridge. Then we extract the encryption key and decrypt the image. If the heads are damaged too, the head swap comes first, in our 0.02 micron ULPA-filtered clean bench. Pricing: $600–$900 for bridge/firmware repair, $1,200–$1,500 if heads need replacement. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
How long does WD My Passport data recovery take?
Firmware and bridge controller repairs typically take 3-6 weeks. Head swap cases with donor matching take 4-8 weeks. How long imaging takes depends on how big the drive is and how healthy it is. +$100 rush fee to move to the front of the queue.
Can recovery software like Disk Drill or Recuva recover my WD Passport?
Only if the problem is purely logical: accidental file deletion on a mechanically healthy drive with intact firmware. Software won't work on a WD Passport with corrupted firmware. If Module 190 (the T2 translator) is damaged, every sector reads back as zeros, and the software has nothing to find. On a clicking drive, every read attempt the software makes damages the platters further. Firmware repair: $600–$900. Head swap: $1,200–$1,500.
Is my WD Passport ticking because of a power issue or a head failure?
Rule out power first. Plug the drive directly into a rear motherboard USB port, with no hub in between. If the ticking stops, it was a power issue. If it keeps clicking or ticking on a direct connection, that's a hardware fault. If it needs a head swap, that's $1,200–$1,500. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
WD My Passport Not Working?
We specialize in encrypted Passport recovery. Free evaluation, no data no charge.
