Lab Operational Since: 17 Years, 10 Months, 7 DaysFacility Status: Fully Operational & Accepting New Cases
ACELAB Spiderboard for PC-3000 microSD Card Data Recovery
A 34-minute walkthrough of direct NAND recovery on a microSD card using the ACELAB spiderboard and PC-3000 Flash.
Video01/05
Author02/05
Summary03/05
What the Video Demonstrates
When a microSD card's controller chip dies, there is no way to read data through the card's normal interface. The ACELAB spiderboard bypasses the controller entirely by placing 25 spring-loaded needle contacts directly onto the NAND flash memory traces inside the card.
The video walks through the full process: scraping the protective coating off the card to expose the NAND traces, using the PC-3000 Flash pinout database to identify which trace carries which signal (D6, D7, CE0, WE, RE, and so on), then positioning each needle onto the correct contact point under magnification. One misplaced needle shorts a signal and can destroy the chip.
The specialist spends roughly 30 minutes positioning 17 needles. When needles crowd together, they risk scratching adjacent traces or shorting, so some get repositioned to alternate locations on the spiderboard even if it breaks the sequential pin order from the database.
Summary04/05
How It Ends
After all that setup, the NAND chip reads as dead. No data was recoverable. The specialist mentions scratching a trace from needle pressure partway through, requiring repositioning; that is the kind of thing that can go wrong at this scale. But in this case the NAND itself had failed, not the connections.
The video is honest about this outcome. Spiderboard recovery works when the NAND is intact but the controller is dead. When the flash memory itself has degraded past the point of returning data, no amount of equipment fixes that. The ACELAB spiderboard costs around $8,000 and the PC-3000 Flash suite around $6,000. This is what professional microSD recovery looks like, and sometimes it still fails.
Get help05/05
Have a Dead MicroSD Card?
If your card is not recognized at all, it needs NAND-level recovery. We have the spiderboard, the PC-3000, and the patience to position 17 needles under a microscope. No promises on the NAND cooperating, but we will know within the evaluation.
