MacBook A1706 Soldered SSD Not Detected: Liquid Damage Repair
A MacBook A1706 boots to a question mark folder after a liquid spill. The SSD is soldered to the logic board and physically fine; the problem is a corroded resistor on the SSD power delivery circuit. This video walks through finding and replacing it. Our SSD data recovery service repairs soldered MacBook SSDs in our Austin, TX lab.
Video
Summary
Finding the Fault
The question mark folder means the Mac's firmware boots fine but cannot find storage. With soldered SSDs, the storage can't be swapped out; something on the logic board is preventing the Mac from talking to it. The customer reported a liquid spill, which narrows the search to corrosion on the SSD power delivery circuit.
Visual inspection of the SSD area revealed multiple corroded components: capacitors on the PP1V8 and PP3V3 rails, a corroded resistor on the NAND power line, and resistor R9350. Multimeter testing confirmed R9350 as the critical failure. It should read 1.3 megohms; it read open line (infinite resistance). The corroded resistor fell off the board when the multimeter probe touched it.
Summary
Why One Resistor Kills SSD Detection
R9350 is a pull-up resistor on the IUVD pin of the U9300 (Piccolo) power management chip. It holds the SSD presence-detection signal at a defined voltage. When the resistor corrodes and goes open circuit, the signal line floats. The Mac's firmware reads an undefined voltage, assumes no SSD is present, and skips straight to the question mark folder.
Replace the resistor, and the signal pulls high again. The Mac detects the SSD. Boot proceeds. In this case, the NAND storage itself was undamaged; only the macOS installation was corrupted by the liquid exposure, so a clean reinstall restored full functionality with data intact.
Get help
Question Mark Folder After a Spill?
The SSD itself is almost always intact. If your MacBook got wet and now shows a question mark folder, the circuit between the logic board and the NAND is disrupted by corrosion, not the storage itself. Send it in and we'll identify which component failed.
MacBook SSD Not Detected: Common Questions
What does the question mark folder mean on a MacBook?
It means the Mac's firmware powers up & runs, but it can't find a startup disk. On a model with a soldered SSD the storage isn't a removable part you can swap out, so a missing disk points at the logic board, not a loose drive. The repair is a circuit fix that lets the Mac see the storage that's already soldered to the board.
Can you recover data if the SSD is soldered to the MacBook logic board?
Yes. Soldered NAND can't be pulled out & read like a normal drive, so recovery here is board-level microsoldering to restore the circuit that lets the Mac talk to its own storage. On this A1706 the NAND was intact; a single corroded resistor on the SSD power line had gone open & broke detection. Replace the component, & the Mac reads the data again. It's the same board work behind our SSD data recovery service.
Is my data gone after a liquid spill on a MacBook?
Usually not. Liquid corrodes small components around the SSD power rails, & when a resistor or capacitor fails the Mac stops seeing the storage. The NAND that holds your files often survives untouched; it just can't be reached until the corroded part is replaced. In this repair the storage was fine & only the macOS install needed a clean reinstall once the circuit was fixed, so the data came back intact.
Do you replace the SSD or repair the logic board?
We repair the board. A soldered SSD can't be swapped for a new one, so we find the failed component & replace it instead of replacing storage. Here that meant one corroded resistor on the SSD power line; once it was back in place the Mac detected the storage & booted. That's MacBook logic board repair, not a drive swap.
What does soldered MacBook SSD recovery cost, & what if it fails?
Diagnosis is free & there's no diagnostic fee. If we can't recover your data, you don't pay; that's the no-fix-no-fee guarantee. Every repair runs in-house at our Austin, TX lab, a single location with no outsourcing. For the tier ranges on soldered-SSD work, see our SSD data recovery pricing.
