Lab Operational Since: 17 Years, 7 Months, 4 DaysFacility Status: Fully Operational & Accepting New Cases
WD Passport Data Recovery
Encrypted bridge | Dead board | Clicking heads | $100–$2,000 | Nationwide Mail-In
We recover WD My Passport drives in-house at our Austin, TX lab, & service is mail-in nationwide. The 2.5-inch mechanism inside a Passport is an air-filled hard drive, not an SSD, so a dead board, clicking heads, or a seized motor each need a different fix.
The Passport encrypts every sector through its USB board with hardware AES, even if you never set a password. That single fact is why you can't shuck the drive & read it on a SATA port, & why a parts-bin board swap fails. Recovery starts at From $100. No diagnostic fee. No data, no recovery fee.
Author01/12
Updated June 5, 2026
11 min read
WD My Passport Recovery Overview02/12
WD My Passport Data Recovery
A WD My Passport stores data on an air-filled 2.5-inch hard drive behind a USB board that encrypts every sector with hardware AES. That encryption is on even with no password set, so the platters can't be read on a plain SATA port without the original board & its key material. Recovery runs $100–$2,000 by failure type.
Passport failures split into two camps. The drive either stopped showing up because the board, firmware, or encryption path broke, or the mechanism inside is physically damaged & clicking. We cover both here, with a published price for each. This page is part of our external hard drive data recovery work, & the wider Western Digital data recovery lineup.
Why Is My WD Passport Not Showing Up?03/12
Why Is My WD My Passport Not Showing Up?
A WD My Passport stops showing up when the USB board dies, the drive firmware corrupts, or the internal heads & motor fail. A dead board still holds the unit-specific ROM & key material, so it routes to firmware-tier work at $600–$900, not a plain data copy. Clicking, beeping, or no spin points to physical damage that needs clean-bench work.
The first thing to check is whether the drive makes sound. A silent drive that isn't detected often has a board or firmware fault & a healthy mechanism. A drive that clicks or beeps has a mechanical fault, & every power-on makes it worse.
  • Dead USB board:No detection, no unusual sound. The native USB board failed; the mechanism is often fine, but the ROM & key material on the dead board have to move to a working board before the platters decrypt. Firmware-tier work at $600–$900.
  • Firmware corruption:Spins up, shows the wrong size or won't respond. Firmware repair with PC-3000 at $600–$900.
  • RAW / needs formatting:File system damage after a sudden unplug, platters usually healthy. Logical recovery from From $250.
  • Clicking or beeping:Read/write heads or spindle motor failed. Clean-bench head swap at $1,200–$1,500 plus a donor.
Bad sectors, clicking, & a seized motor are always physical failures. RAW & deleted files are logical. Running recovery software on a clicking drive scores the platters & can end the recovery before it starts.
What Customers Say
Sent my hdd for data recovery, process was simple and I was able to pre-authorize an amount. They worked on my drive within 2 days of receiving it and the total cost was literally 1/10th of the amount of another service I got a quote from. Professional, quick, affordable. Nothing to complain about.
Andrew Hansen
My satisfaction with Rossmann Repair Group goes beyond just 5 stars. I had a hard drive die some time ago, but I had no idea where I could send it knowing it would be safe, or there being a chance I'd be ripped off.
Kyle Hartley (crazybangles)
Had a raid 0 array (windows storage pool) (failed 2tb Seagate, and a working 1tb wd blue) recovered last year, it was much cheaper than the $1500 to $3500 Canadian dollars i was quoted by a Canadian data recovery service. the price while expensive was a comparatively reasonable $900USD (about $1100 CAD at the time).
Christopolis
Walked in with my wife's dead hard drive, walked out 20 minutes later with it fixed. They were friendly, professional, did the work in a snap, and saved me the hefty repair prices for other (mail in) hard drive recovery services!
Patrick Dughi
Why Can't You Read a WD Passport on a SATA Port?04/12
Why Can't You Read a WD My Passport on a Plain SATA Port?
Because the WD My Passport bridge controller encrypts every sector with hardware AES before it reaches the platters, even when no password was ever set. The key material lives with the bridge & its ROM, not the platters. Pull the 2.5-inch drive out & wire it to a SATA port, & the data reads as encrypted garbage.
Most WD My Passport models force this encryption on at the factory. It runs transparently, so you never see it during normal use. The board holds the key material; the platters hold only ciphertext. That design protects a lost drive, & it also means the board is part of the data path, not just a USB adapter.
Shuck the drive & connect it raw, & Windows or macOS sees high-entropy noise. It may offer to format the "blank" drive. Don't. The data is intact under the encryption; it just can't be decoded without the original key path. This is the single most common way a recoverable Passport gets made worse.
Do not shuck a WD Passport & plug the bare drive into a SATA port.
If you already did, stop. Do not format or write to it. Send the whole drive with its original board so the encryption path can be preserved.
Why Doesn't a Board Swap Fix a Dead WD Passport?05/12
A donor board doesn't fix a WD My Passport because the drive's ROM, adaptive parameters, & encryption key material are unique to that one physical unit. Bolt on a replacement board & the firmware can't read the platters, & the data stays encrypted. The original ROM & adaptive data have to move to the working board first.
Every Passport board carries data calibrated to its own mechanism: head & servo adaptive parameters, defect lists, & the encryption key material. A matching part number isn't enough. Two drives off the same production line still hold different unit-specific data, so a naive swap leaves the firmware unable to bring the heads online or decode the platters.
We transfer the original ROM contents & adaptive data to a working board by function, then bring the drive up. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. This work sits in the firmware tier at $600–$900 when the mechanism itself is healthy. If the heads or motor also failed, we quote the combined mechanical & firmware path after a free evaluation.
How Do You Recover an Encrypted WD Passport?06/12
How Do You Recover an Encrypted WD My Passport?
We use PC-3000 with the WD Marvell utility family to work with the drive's firmware, translator, & bridge encryption, then image & decrypt the user area in the correct order. The original board ships with the drive so its unit-specific key material is available. Firmware-tier work runs $600–$900.
The order matters. The decryption path has to be reconstructed before the user area is imaged, or the image is just ciphertext. We work through the drive's own firmware rather than trying to defeat the security.
  1. Triage the board & mechanism: confirm the drive spins, the heads respond, & whether the fault is electronic, firmware, or mechanical.
  2. Read & preserve the drive's ROM & adaptive data so the unit-specific parameters & key material are kept intact.
  3. Work with the firmware & translator through the PC-3000 WD utility to restore drive identification & the decryption path.
  4. Image the user area, then decrypt it using the preserved key material so the output is readable files, not ciphertext.
  5. Write the recovered data to a fresh target drive & verify the file tree.
If a user-set WD Security password is in play, you'll need to provide it. We don't crack or defeat user passwords; we reconstruct the correct decryption path once the credential is supplied.
What Happens When a WD Passport Clicks or Won't Spin?07/12
What Happens When a WD My Passport Clicks or Won't Spin?
Clicking, beeping, or no spin on a WD My Passport is a physical failure inside the sealed mechanism: crashed or stuck read/write heads, or a seized spindle motor. These need a 0.02 micron ULPA-filtered clean bench & a donor head stack, not software. A clean-bench head swap is $1,200–$1,500 plus the donor drive.
The Passport is a slim portable drive, so it travels & gets dropped. A fall while the platters spin slams the heads into the recording surface. The result is clicking or silence. The Passport is air-filled, so there's no helium refill involved; this is a standard 2.5-inch head swap.
We open the drive in our 0.02 micron ULPA-filtered clean bench, match a donor head stack by model, firmware revision, & head map, & install it. Then we image sector by sector with PC-3000 & a DeepSpar Disk Imager, skipping weak areas to pull the most data before the donor heads degrade. If the platters are scored, we clean the surface first; that escalates to $2,000.
Is a RAW WD Passport a Logical or Physical Failure?08/12
Is a RAW WD My Passport a Logical or Physical Failure?
A RAW or "needs formatting" WD My Passport after a sudden disconnect is usually a logical failure: the file system metadata is damaged but the platters are healthy. Clicking, beeping, & bad sectors are physical failures. The two routes need different work, & guessing wrong can finish off a failing drive.
Failure ClassSymptomsRecovery Path
LogicalDeleted files, RAW partition, "needs formatting", not initializedPC-3000 Data Extractor parses MFT/Catalog in RAM, no writes back; from From $250
PhysicalClicking, beeping, no spin, bad sectors, scored plattersClean-bench head swap, donor matching; $1,200–$1,500 plus donor
On a logical case with healthy platters, we parse the file system in RAM & write nothing back to the drive, so the original directory structure stays intact. The danger is treating a physical symptom like a logical one. Bad sectors are media surface degradation or failing heads; they are always physical, & no software repair fixes them without making the drive read harder.
How Much Does WD Passport Recovery Cost?09/12
How Much Does WD My Passport Recovery Cost?
WD My Passport recovery runs $100–$2,000 by failure type. A working drive that just needs its data copied off is $100. A logical/RAW file system is From $250. A dead board, bridge encryption, & firmware work is $600–$900. A clean-bench head swap is $1,200–$1,500 plus a donor. No diagnostic fee. No data, no charge.
The Passport uses an air-filled 2.5-inch mechanism, so it follows standard HDD pricing. Encrypted-bridge work that needs PC-3000 sits in the firmware tier at $600–$900. +$100 rush fee to move to the front of the queue.
    Your drive is clicking, beeping, or won't spin. The internal read/write heads have failed
Helium-sealed drives (8TB and larger NAS or server drives such as Toshiba MG08, Seagate Exos, and WD Ultrastar) are quoted on a separate tier. See helium drive pricing.
Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. We disclose the donor cost during the free evaluation before any paid work. Single location in Austin, TX. No franchises, no outsourcing. Founded in 2008.
WD Passport Recovery FAQ10/12
WD My Passport Recovery Questions
Why is my WD My Passport not showing up after I dropped it?
A WD My Passport that stops showing up right after a drop usually has head-platter contact inside the sealed mechanism. The fall slams the read/write heads onto the spinning platters, which produces clicking, beeping, or silence. This is a physical failure. Stop powering it on; each spin-up risks scoring the platters. Recovery is a clean-bench head swap with donor matching at $1,200–$1,500 plus the donor drive. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
Why can't I just remove the drive and plug it into another PC?
The bridge controller on a WD My Passport encrypts every sector with hardware AES before it lands on the platters, even when you never set a password. The key material is tied to the bridge and its ROM, not the platters. Pull the 2.5-inch mechanism out and connect it to a plain SATA port and the data reads as encrypted garbage. Ship the whole drive with its original board so the encryption path can be preserved.
Does the encryption mean my data is lost if the controller dies?
No. A dead USB controller does not erase the data on the platters; it removes the path that decrypts it. We work with the drive's firmware, ROM, and key material through PC-3000 with the WD Marvell utility family to rebuild the decryption path in the correct order, then image the user area. The original board must arrive with the drive so the unit-specific key material is available.
Is a PCB swap or bridge swap enough to fix a dead WD Passport board?
No. The board carries unit-specific ROM, adaptive parameters, and encryption key material that belong to that one physical drive. Bolt on a donor board and the firmware cannot read the platters and the data stays encrypted. The original ROM contents and adaptive data have to be transferred to a working board by function before the drive will read. We handle that ROM and adaptive transfer in-house rather than relying on a parts swap.
What does clicking, beeping, or a drive that won't spin mean on a WD Passport?
Clicking and beeping are physical failures. Clicking means the read/write heads cannot track the platters. Beeping or no spin means the spindle motor is seized or the heads are stuck to the surface (stiction). Both need a 0.02 micron ULPA-filtered clean bench, not recovery software. We swap heads from a matched donor or free stuck heads, then image with PC-3000. A clean-bench head swap is $1,200–$1,500 plus the donor drive.
My WD Passport says it needs formatting or shows as RAW. What should I do?
Do not click Format and do not run CHKDSK. A RAW, "needs formatting," or not-initialized prompt after a sudden disconnect is usually a logical failure with healthy platters. The file system metadata is damaged, not the media. We connect the drive through PC-3000 Data Extractor and parse the MFT or Catalog in RAM with no writes back to the drive. With no physical damage, this is a file system recovery from From $250. Bad sectors and clicking are always physical, not logical.
How much does WD My Passport data recovery cost and how long does it take?
WD My Passport recovery runs $100–$2,000 depending on the failure. A working drive that just needs its data copied off is $100. A logical or RAW file system is From $250. A dead board, bridge encryption, and firmware work that needs PC-3000 is $600–$900, because the unit-specific ROM and key material have to move to a working board before the platters decrypt. A clean-bench head swap is $1,200–$1,500 plus a donor; platter damage is $2,000. Firmware queues run 3-6 weeks; head swaps run 4-8 weeks. +$100 rush fee to move to the front of the queue. No diagnostic fee. No data, no recovery fee.
Do I have to send the WD Passport's original USB board?
Yes. The encryption key material and adaptive parameters live with the original board and its ROM, not on the platters. Without that board, even a successful mechanical recovery leaves the platter data encrypted and unreadable. Ship the whole drive intact, including the original board, even if the connector is cracked or the board is burnt.
Can you recover a WD Passport if I already set a password in WD Security?
A user-set password adds a second layer on top of the always-on hardware encryption. You will need to provide that password for recovery. We do not defeat or crack user-set passwords; we work with the drive's own firmware and key material to reconstruct the correct decryption path once the credential is supplied.
Send Us Your WD Passport
Free evaluation, a firm quote before any work, & no charge if we can't recover your data. Recovery runs $100–$2,000 by failure type.
