Gaming Console Data Recovery
PS5, Xbox Series X, Nintendo Switch, and Steam Deck
Modern gaming consoles store data on encrypted solid-state storage: NVMe SSDs, soldered NAND, and eMMC chips. When the motherboard dies, the storage cannot be removed and read on a PC because the decryption keys are tied to the original processor. We recover console data through board-level repair, firmware reconstruction with PC-3000, and eMMC chip-off extraction at our Austin, TX lab.
Updated March 17, 2026
Featured snippet target
Gaming console data recovery requires board-level hardware repair because PS5, Xbox Series X, and Nintendo Switch storage is bound to each console's processor through hardware encryption. Removing a console's internal drive and connecting it to a PC yields unreadable data. Recovery starts at $200 with a no data, no fee guarantee.
Why software fails
Why Data Recovery Software Cannot Read Console Drives
Search results for "PS5 data recovery" or "Xbox save recovery" are dominated by software tools that instruct you to connect the console drive to a Windows PC. For current-generation consoles, this approach fails for three reasons.
Hardware Encryption
PS5 and Xbox Series X encrypt all stored data using keys derived from the console's main processor (AMD SoC for PS5; custom Microsoft SoC for Xbox). The encryption is performed in hardware, not software. Without the original processor generating the decryption keys, the raw NAND contents are indistinguishable from random noise.
Proprietary File Systems
Xbox Series X uses XBFS (Xbox Boot File System), which no consumer operating system can mount or parse. Windows Disk Management will show the drive as "uninitialized" and prompt you to format it. Clicking "Initialize" destroys the partition table permanently.
TRIM Destroys Deleted Data
The Xbox, Steam Deck, and PS5 expansion slot all use NVMe SSDs that execute TRIM commands when files are deleted. TRIM instructs the controller to erase the underlying NAND cells during background garbage collection. Once a save file is deleted on a modern console, no software or hardware tool can retrieve it. Recovery is only possible when the storage fails while data is still present.
Per-console sections
Recovery by Console
PlayStation 5
The PS5 internal storage consists of raw NAND flash packages wired to a custom 12-channel Marvell flash controller that bridges the soldered NAND to the AMD Oberon SoC. This is not a removable M.2 SSD; the NAND chips and the flash controller are soldered to the mainboard, separate from the processor die. All data is encrypted in hardware by the SoC.
If the PS5 motherboard fails due to liquid damage, a dead PMIC, or a shorted voltage regulator, the repair path is component-level board work: identifying the failed rail with a thermal camera and multimeter, sourcing the correct replacement component, and resoldering it under a microscope. Once the board boots, the SoC decrypts the storage natively.
If the AMD SoC itself is physically destroyed (cracked die, burned BGA connections), the encryption keys are lost. In this scenario, the data is not recoverable by any method. The NAND chips cannot be desoldered and read independently because the data is bound to that specific processor.
Xbox Series X and Series S
The Xbox Series X uses an M.2 2230 NVMe SSD (1TB for Series X; 512GB for Series S). Unlike the PS5, this drive is a standard M.2 form factor and can be physically removed. However, removal alone does not make the data accessible.
Microsoft uses the XBFS (Xbox Boot File System) partition layout. The first 1GB raw partition contains console-specific encryption keys tied to the CPU. If this partition is intact and the NVMe controller is functional, we image the drive using PC-3000 SSD and reconstruct the file system from the raw XBFS image. If the NVMe controller has failed (firmware panic, dead PMIC), we perform firmware-level recovery to restore controller communication before imaging.
If the XBFS boot partition is corrupted beyond repair or the console's CPU is destroyed, the encryption keys cannot be regenerated. A replacement drive will not boot in the console because the keys are tied to the original CPU/drive pairing.
Nintendo Switch
The Switch stores all game save data on a soldered 32GB eMMC 5.1 chip (NAND flash with an integrated controller in a BGA package). The removable microSD card holds game installation files and screenshots only. Save data never touches the SD card.
Common Switch failures include dead power management ICs (the M92T36 USB-C controller and BQ24193 charge controller are the most frequent failure points), liquid damage corrosion, and bent-chassis induced board flex cracks. For these failures, we perform component-level microsoldering to restore board function. Once the Switch boots, save data is accessible through normal operation or cloud backup (Nintendo Switch Online subscribers).
If the mainboard is beyond repair, we desolder the eMMC BGA package using a hot-air rework station and read the BOOT0, BOOT1, and raw GPP partitions using a BGA-to-socket adapter. Decryption of the USER partition depends on the condition of the NVIDIA Tegra X1 processor, which holds the encryption keys. If the Tegra X1 is intact on the original board, key extraction may be possible; if the processor is destroyed, the encrypted data cannot be decrypted.
Steam Deck and Handheld PCs
The Steam Deck (and similar handhelds like the ASUS ROG Ally) use standard M.2 2230 NVMe SSDs with ext4 or NTFS file systems. Unlike PS5 and Xbox, these drives are not hardware-encrypted by the SoC. The drive can be removed and read on standard equipment, which means recovery focuses on the storage failure itself rather than bypassing encryption.
The most common failure pattern in Steam Deck SSDs is FTL (Flash Translation Layer) metadata corruption caused by aggressive suspend/resume power cycles. DRAMless M.2 2230 drives (often using Phison E21T or Silicon Motion SM2263XT controllers) are particularly vulnerable because they rely on the host for FTL metadata caching. When power is cut during a garbage collection cycle, the FTL metadata becomes inconsistent and the drive drops out of BIOS detection entirely.
We connect the drive to PC-3000 Portable III with an NVMe adapter to enter the controller's vendor-specific technological mode. From there, we rebuild the corrupted FTL mapping tables, stabilize the NAND, and extract a full sector-level image. SteamOS game saves, desktop-mode files, and any Windows partition data are recoverable from the image. The 64GB eMMC model of the Steam Deck follows the same eMMC recovery process used for Chromebooks and tablets.
Console Data Recovery Pricing
All console storage is solid-state (NVMe or eMMC). Pricing follows our standard SSD recovery tiers. No diagnostic fee.
Deleted game saves cannot be recovered from any modern console due to TRIM. Recovery applies only to drives that have failed while data was still present.
What SSD Recovery Customers Say
Shomari Hohn
Aravind Udayakumar
David Dachenhaus (DDock)
Ludwig Jonsson
LaCie
Gaming Console Recovery FAQ
Can you recover deleted game saves from a PS5 or Xbox Series X?
No. Both consoles use NVMe solid-state drives that execute TRIM commands when files are deleted. TRIM instructs the controller to erase the underlying NAND cells in the background. Once a save file is deleted on a modern console, the data is permanently destroyed at the hardware level. Software tools that claim otherwise cannot interface with the proprietary encryption or file systems these consoles use.
My PS5 stopped turning on. Is the data recoverable?
It depends on the failure. The PS5 internal storage uses raw NAND chips connected to a custom flash controller integrated into the AMD SoC. The data is encrypted by that specific processor. If the board can be repaired (dead PMIC, failed voltage regulator, liquid damage to a specific rail), the SoC decrypts the storage natively and the data is accessible. If the SoC itself is destroyed, the encryption keys are lost and the data cannot be decrypted.
Can I plug my Xbox Series X SSD into a PC to copy files off it?
No. The Xbox uses a proprietary file system called XBFS (Xbox Boot File System). Windows, Linux, and macOS cannot read this file system. The drive also contains hardware-specific encryption keys tied to your console's CPU. Plugging the drive into a PC and initializing it in Disk Management will permanently destroy the partition table and all data on it.
My Nintendo Switch will not turn on. Are my save files gone?
Not necessarily. Switch save data is stored on the internal soldered eMMC chip, not on the removable microSD card. If the Switch fails due to a power management IC failure (M92T36 or BQ24193) or liquid damage, we repair the board at the component level to restore access. If the mainboard is beyond repair, we can desolder the eMMC and extract partitions directly, though decryption depends on the condition of the Tegra X1 processor.
How much does gaming console data recovery cost?
Console storage recovery uses solid-state pricing tiers. Simple data transfer from a functional drive starts at $200. Board-level repair (dead power rail, failed PMIC) is $900–$1,200. Firmware reconstruction via PC-3000 is $900–$1,200. No diagnostic fee.
Console Storage Failed?
Ship your PS5, Xbox, Switch, or Steam Deck to our Austin lab. Free evaluation, no data no fee.
