Why Your RAID Rebuild Failed
Stop now and power the array off. Do not start another rebuild, do not click Repair, and do not run --assume-clean or mdadm --create. Forcing the array back together with a re-create or initialize command, or shoving a stale member back online, writes new parity across the surviving drives and permanently overwrites the data that is still intact.
Leave the chassis off and route the drives to our Mail-In RAID Recovery Service. All work is performed in-house at our Austin, TX lab, nationwide by mail-in. Free evaluation. No data recovered means no charge.
A RAID rebuild fails when the controller hits an unrecoverable read error on a surviving drive, when an SMR member stalls long enough for the controller to drop it, or when a drive without TLER stays in a deep-recovery loop longer than the controller is willing to wait. The risk scales with array size and drive age.
We recover failed rebuilds by imaging every member offline and assembling the array virtually on Data Extractor Express RAID Edition. The original chassis is never written to. Free evaluation. No data recovered means no charge. A failed rebuild is one of the array states our RAID data recovery service handles.
Your Rebuild Failed. What Is the Safe Next Step?
Every command that "fixes" a degraded array in place writes to the member drives. A live rebuild pins all surviving members at close to 100% sustained read until it finishes, which is the load that kills a marginal same-batch survivor and converts a single-fault degraded array into a double-fault failure.
Clone first, reconstruct from the clones, and the original platters keep their geometry intact no matter what the reconstruction attempt does. This is the image-first imperative, and it is the difference between a recoverable array and a destroyed one.
You do not need the original controller card to get the data back. Dell PERC and LSI MegaRAID write their DDF geometry to the trailing sectors of each member; HPE SmartArray writes a proprietary RAID Information Sector at the start of each drive; mdadm keeps its superblock on the member itself. The array geometry lives on the platters, so a dead or foreign controller does not destroy it.
RAID buys you availability, not a backup: a failed rebuild, a controller fault, or a correlated batch failure can take the whole array down at once, and that is exactly the array state our Mail-In RAID Recovery Service is built to handle. Free evaluation. No data recovered means no charge.
- Rebuild stalls at a fixed percentage, then drops a drive
- The sequential read pass hit a marginal-LBA band on a surviving member and the controller timed out inside its TLER or ERC window. Power the chassis down now. Do not retry the rebuild.
- Controller reports not enough devices to start the array, or array failed
- A second member dropped during the rebuild, which is a double fault on RAID 5. The drives still hold the data. Power down and do not initialize or clear the configuration.
- You already clicked Repair, ran
mdadm --createor--assume-clean, or re-added the original drive - Those commands overwrite metadata or resync stale blocks. Power down immediately to stop any running resync before it walks the full LBA range.
- SMR member stalled and the controller ejected a healthy drive
- The CMR cache overflowed and the multi-second flush exceeded the controller timeout. The drive is not dead. Power down and image it offline.
Every symptom above takes the same safe path: leave the chassis off and ship the labeled drives to the Austin, TX lab for per-member offline imaging on PC-3000 Express, followed by virtual array reconstruction in software with Data Extractor Express RAID Edition. The original chassis is never written to. This is the array state our RAID data recovery service is built for. Free evaluation. No data recovered means no charge.
What State Is the Array In When a Rebuild Aborts?
Target drive error versus source drive error
MegaRAID-family firmware, which covers the LSI and Broadcom cards and the Dell PERC line built on the same silicon, logs those two outcomes as different events: a rebuild that failed due to target drive error, and a rebuild that failed due to source drive error. Target is the replacement disk you inserted. Source is one of the members that was still carrying the array.
A target-drive error puts you back where you started: a single-fault degraded array plus a replacement disk that could not take the writes. A source-drive error is a different situation. A member that was holding data or parity dropped mid-pass, and on RAID 5 there is no second parity block to reconstruct from, so the array is now a double fault. The load that produces that outcome is the rebuild itself, which is why the URE and read-load math matters more on a second attempt than it did on the first.
On HPE SmartArray P-series and E-series controllers, a read error during a rebuild takes the logical drive offline. Under Linux mdadm the failed component is marked faulty in mdadm --detail output and /sys/block/mdX/md/sync_action returns to idle. Whichever of the three you are reading, the event comes off the card but the geometry a reconstruction needs does not: PERC and MegaRAID keep DDF in the trailing sectors of each member and SmartArray keeps its RAID Information Sector at the start of each drive, so losing the controller does not lose the layout.
What is on the members after the rebuild stops?
The replacement member holds mathematically valid reconstructed data up to the LBA where the rebuild stopped. Every stripe below that boundary was computed from the surviving members and written out before the abort.
Surviving members were read during the reconstruction pass, not rewritten. A parity rebuild pulls a full-surface read from every remaining member to recompute the missing blocks, and the writes it issues land on the replacement. The exceptions are administrative rather than bulk data: puncture records, bad-block-log entries, and metadata or checkpoint updates. So the surviving members are worth imaging exactly as they sit in the chassis.
Why does the abort percentage matter?
The completion figure corresponds to an LBA boundary on the members. Under Linux mdadm that boundary is recorded persistently as recovery_offset in the superblock, and the running value is exposed to user space through /sys/block/mdX/md/sync_completed. Below the offset the replacement member carries reconstructed data. That is the number a reconstruction engineer wants when deciding which image to trust for a given LBA range, and it is why the rebuild percentage belongs in the notes you take during array state assessment instead of scrolling out of a console buffer.
What happens when you power the chassis back on?
PERC firmware, MegaRAID firmware, and Linux mdadm all checkpoint rebuild progress persistently, so a power cycle is not a neutral look at the state. Dell documents that PERC firmware can resume a rebuild after an abrupt power loss or after the server is rebooted in the middle of a rebuild operation. The MegaRAID configuration utility documentation states that an interrupted rebuild continues from where it left off when Auto Resume is enabled, and starts over from the beginning when it is not, and Broadcom's StorCLI carries a command that resumes a paused rebuild. On Linux, mdadm picks recovery back up from recovery_offset when the array is assembled.
Booting the chassis to see how bad it is can therefore drop the array straight back into the sustained full-surface read pass that just failed, against the same marginal members that failed it. Leave the power off.
Do not discard the partially rebuilt replacement drive
After a partial rebuild there are two candidate reconstruction sources: the original surviving members, which still hold the data and parity the array was built on, and the partly written replacement member, which holds everything reconstructed below the abort boundary. Imaging every member, the replacement included, preserves both.
The mistake is throwing the replacement away as the bad new disk. If the rebuild aborted on a source-drive error, the surviving member that failed is no longer readable for the range it covered, and the replacement can hold the only surviving copy of the stripes it already reconstructed. Discard it and those stripes go with it.
Power the chassis down, label every drive with its physical slot, and image every member offline through a write blocker. Imaging runs on PC-3000 Express. The array geometry is then reconstructed in software from those clones with Data Extractor Express RAID Edition, never against the live members. All of it is performed in-house at the Austin, TX lab. There is no diagnostic fee, and no data recovered means no charge.
What Do RAID Controller Status Codes Mean?
Before troubleshooting a failed rebuild, identify the exact status the controller is reporting. The terminology is consistent across LSI MegaRAID, Dell PERC, HPE SmartArray, and the Linux mdadm stack that Synology and QNAP wrap in their UIs.
- Degraded
- The array is running with one or more members missing or marked failed. Reads still succeed because the surviving members plus parity can reconstruct the missing data on the fly. Writes succeed but generate no parity protection for the missing member.
- Rebuilding
- The controller is actively copying reconstructed stripes onto a replacement member. Every sector of every surviving member must be read during this phase. Multi-TB rebuilds take many hours and stress every drive in the chassis.
- Failed
- The array has lost more members than its parity level can tolerate. RAID 5 lost two members; RAID 6 lost three. The controller stops servicing reads and writes. The data is not erased, but normal access through the controller is impossible until the array is reassembled.
- Offline
- The controller has taken the virtual disk out of service, typically because a rebuild was attempted, halted, or encountered an unrecoverable error mid-stream. Offline is the state most failed rebuilds settle into.
- Foreign Configuration
- The controller detected DDF metadata it did not write itself, usually because the drives were moved from another controller or because the array configuration was cleared on this controller. Importing or clearing a Foreign Configuration rewrites metadata on the member drives. Do neither without an image first.
- Unconfigured-Good
- The drive is detected by the controller, passes its self-test, and is available to be assigned to an array. After a failed rebuild, drives that were dropped due to a TLER timeout sometimes return to Unconfigured-Good on the next power cycle even though their media has marginal sectors.
- Unconfigured-Bad
- The controller flagged the drive as having excessive media errors. The drive is not necessarily mechanically dead; the controller has simply decided not to use it again. These drives are recoverable on PC-3000 Express with adaptive read retry.
Why Does a RAID 5 Rebuild Stop at a Fixed Percentage?
Hard drives carry a worst-case unrecoverable read error (URE) specification, also called the bit error rate. Consumer SATA drives such as the WD Blue, Seagate Barracuda, and Toshiba P300 spec one URE per 10^14 bits read, which works out to about one unreadable sector per 12.5 TB of sequential reads. Enterprise drives such as the WD Ultrastar and Seagate Exos spec one URE per 10^15 bits, ten times better, or roughly one unreadable sector per 125 TB.
That number is a warranty floor, not a schedule: field studies (USENIX FAST latent-sector-error work; Backblaze fleet data) show the large majority of drives read far past 12.5 TB without a single URE, and read errors cluster on aging or marginal drives rather than striking on an independent per-byte basis.
During a RAID 5 rebuild the controller must read every sector of every surviving member in order to XOR them together and reconstruct the missing data. A four-member RAID 5 with 8 TB drives, after losing one member, has three surviving members of 8 TB each. The controller must read 24 TB sequentially under sustained load. Against the worst-case 10^14 consumer spec that read pass raises the probability of hitting a latent unreadable sector, but it does not guarantee one, and the dominant real-world failure driver is mechanical, not statistical.
Single-parity RAID 5 on large drives runs on razor-thin margins, which is why dual parity (RAID 6, RAIDZ2, SHR-2) is the sane minimum above roughly 12 TB of usable capacity.
What happens when a URE does land during a degraded rebuild depends on the controller, and the data inside that one stripe is lost in every case. Legacy block-level hardware RAID and low-end consumer controllers such as Intel RST hard-abort the rebuild and drop the volume offline. HP and HPE Smart Array P-series and E-series also abort: they drop the logical drive offline to protect integrity and flag POST Error 1784 or 1786.
Modern Dell PERC and LSI/Broadcom MegaRAID puncture instead, writing a bad-block placeholder over the stripe, completing the rebuild, and keeping the volume online with only the punctured stripe permanently lost. Linux mdadm records the unreadable LBA in its Bad Block Log and continues. ZFS RAIDZ finishes the resilver and names the exact corrupted file in zpool status -v. One URE does not take a modern array down, but the controllers that do abort produce the stuck rebuild that brings these arrays to the bench.
On the bench, degraded arrays rarely die from an independent per-byte bit error. They die because a full-surface parity rebuild pins every surviving member at close to 100% sustained read for the whole pass, pushing a marginal head, preamp, or scored platter into a secondary mechanical failure mid-rebuild.
Members also share a manufacturing batch, age, and thermal environment, so a second failure inside the rebuild window is positively correlated, not independent: a drive with one prior scan error is far more likely to fail within the next 60 days. The clean binomial coin-flip overstates random bit-rot while understating this correlated mechanical risk.
A rebuild that stops at a fixed percentage is the URE math playing out on a specific drive. A surviving member has a localized band of marginal sectors, the rebuild reads cleanly until it reaches that band, retries there, fails to recover the sectors inside the controller's timeout, and the drive gets dropped.
SMR Drives Trigger Controller Timeout Mid-Rebuild
Drive-managed Shingled Magnetic Recording (SMR) drives use a small persistent conventional-recording (CMR) cache zone for incoming writes, then reorganize that data onto overlapping shingled tracks during idle periods. A RAID rebuild is the opposite of idle. It forces continuous sequential writes to the replacement drive while the surviving members are read at sustained sequential rates.
Once the CMR cache fills, the SMR drive must pause to flush its accumulated writes into the shingled zones. That flush can stall the drive for several seconds while tracks are rewritten in band order.
NAS and enterprise drives cap their own internal retries at about 7 seconds through Time-Limited Error Recovery (TLER) or Error Recovery Control (ERC). The controller runs its own timeout on top of that, in the 8-to-20-second range. When the SMR pause exceeds the controller budget, the controller reads the silence as drive death and drops the physically healthy SMR member from the array.
No drive-managed SMR drive belongs inside a parity RAID array.
TLER and ERC Mismatch Drops Healthy Drives
Desktop drives without TLER or ERC firmware (WD Green, WD Blue, Seagate Barracuda non-RAID variants) handle a marginal sector by entering a deep internal recovery cycle. The drive will reread the sector with adjusted parameters for as long as its firmware wants before giving up. In a single-drive desktop the operating system tolerates this delay because nothing else depends on the drive responding within a fixed window.
Hardware RAID controllers do not tolerate that delay. The controller runs its own timeout, in the 8-to-20-second range. After that it declares the drive missing and drops it from the array. The drive itself may have eventually returned the sector successfully, but by the time it did, the controller had already moved on.
This is how arrays full of perfectly functional drives end up double-faulted during a rebuild.
Enterprise drives (WD Red Plus, WD Ultrastar, Seagate IronWolf and Exos) ship with a short TLER window (typically 7 seconds) so the drive returns a read failure inside the controller budget. The controller can then reconstruct the missing sector from parity in the normal way without dropping the drive. The difference between a desktop drive and a NAS or enterprise drive of similar physical specifications is almost entirely this firmware behavior.
SSD Cache and NVMe Members: Firmware Panics During Rebuild
SSD-based RAID arrays and NAS SSD caches introduce a failure mode that HDD-focused guides overlook. The sustained sequential read load of a rebuild can push consumer SSDs with aging NAND past their failure threshold.
SATA SSDs using the Phison S11 controller (PS3111) are prone to a firmware lockout when TLC NAND cells degrade beyond the ECC correction threshold. The controller enters a protective state, the drive drops offline, and re-identifies in the BIOS as "SATAFIRM S11" instead of the original model name. The rebuild's sustained read load does not cause the NAND degradation, but it surfaces latent cell failures that normal desktop workloads would not trigger.
NVMe SSDs with Phison E12 controllers experience similar FTL corruption but drop off the PCIe bus or report hardware initialization failures instead. Silicon Motion SM2259XT controllers exhibit a different symptom: firmware corruption (typically from power loss during garbage collection or cache flush) causes the drive to report 0 bytes capacity or appear as unallocated in disk management.
These failures corrupt the Flash Translation Layer (FTL), the firmware mapping table that tracks which logical block lives on which physical NAND page. Consumer SSD recovery tools can't access a panicked controller. Recovery requires placing the SSD into Technological Mode using PC-3000 SSD to access the raw NAND and reconstruct the block mapping directly from raw NAND.
For arrays mixing SSDs and HDDs, the panicked SSD is priced at the firmware-level SSD tier ($600–$1,200) while healthy HDDs image at the standard $100 rate. If a member SSD fails this way during a rebuild, the same imaging-first approach applies: image every drive before attempting any reconstruction.
Write-Hole Parity Corruption from Unclean Shutdown
A RAID 5 or RAID 6 write spans every member of a stripe. The controller writes new data blocks and a recalculated parity block. If power is lost between the data write and the parity write, the stripe ends up with new data and old parity, or new parity and old data. The controller has no way to know which blocks are current and which are stale.
On healthy hardware this is mitigated by a battery-backed write cache (BBWC) or flash-backed write cache (FBWC) on the controller. The cache survives the power loss and the controller replays the pending writes on the next boot. Consumer NAS units (Synology, QNAP, Buffalo) ship without battery-backed caches; their "write hole"protection depends on filesystem-layer journaling (ext4, XFS, Btrfs) which does not cover parity blocks.
When a write-hole stripe is later read during a rebuild, the parity does not match the data. The controller computes a missing block from inconsistent inputs and produces garbage. The garbage gets written to the replacement member as part of the rebuild. The rebuild completes successfully and reports no errors, but specific files stored across affected stripes are silently corrupt.
Reinstalling the Original Drive After a Spare Resynced
The most common destructive operator action is to reinstall the original failed drive after a hot spare has already started resyncing. The original drive contains data from before the failure and a lower RAID event count. Some controllers compare event counts and treat the higher count as authoritative. Others rely on the order in which drives respond at power-on and silently sync from whichever member they decide is current.
If the controller treats the stale drive as current, the resync overwrites the working spare and any other surviving members with the older data from the reintroduced drive. The array reports "resync complete" and the volume looks mounted normally, but every block that was modified between the original failure and the reintroduction is now lost.
If a drive was reinstalled and a resync started, power the chassis down immediately. Do not let the resync complete. The original data is still recoverable from the drives that have not yet been overwritten, but only if the resync is interrupted before it walks the full LBA range.
Commands That Destroy Your Array
If your rebuild failed: power down the chassis and stop. The commands below are the ones most often recommended on forums and in vendor knowledge bases for "recovering" a failed rebuild. Every one of them writes to the member drives and forecloses on a clean forensic recovery.
megacli -PDMakeGood -PhysDrv [E:S] -aALLWhat it does: changes the firmware state of an Unconfigured-Bad drive to Unconfigured-Good so the controller can address it again. Why it destroys data: if auto-rebuild is enabled, the controller may immediately begin rebuilding the degraded array onto this drive, overwriting the original pre-failure data with recomputed parity.MegaCli -CfgForeign -Clear -aALLWhat it does: tells the LSI controller to discard the Foreign Configuration metadata it found on the drives. Why it destroys data: the array geometry is in that metadata. Clearing it leaves the drives with valid user data but no record of how to assemble it.mdadm --create --assume-clean --level=5 --raid-devices=N ...What it does: creates a new mdadm superblock on every member and assumes parity is already consistent. Why it destroys data: the v1.2 superblock at offset 4 KiB is rewritten with new UUIDs and a new event count; the array geometry from the original create call (chunk size, layout, member order) is lost unless it happens to be identical, and silent corruption follows on the next write.mdadm --re-add /dev/sdX1 /dev/mdNon a heavily degraded driveWhat it does: tells mdadm the drive is current and only needs to replay the write-intent bitmap. Why it destroys data: if the drive was actually behind, mdadm marks it in-sync without resyncing, and every read from those stripes returns stale data.- Synology DSM Storage Manager "Repair" button on a crashed volumeWhat it does: runs a Synology-authored script that calls mdadm and lvm with parameters intended to bring the array back online. Why it destroys data: the script can overwrite md superblocks and LVM metadata on partition 3 of the surviving members. Read-only inspection on a separate Linux workstation is the safe alternative.
- "Force Online" or "Make Optimal" in LSI or PERC BIOS (F2) menusWhat it does: overrides the controller's decision that the array is offline. Why it destroys data: writes pending in the cache flush to the drives even though parity and data are inconsistent.
- QNAP Recovery Wizard "initialize" promptsWhat it does: formats the QNAP system partitions and rewrites the storage pool metadata. Why it destroys data: QTS stores its storage pool configuration database on partition 1 of the member drives. Initializing rewrites that database; the user data on the data partitions is still present but no longer addressable through QTS without manual LVM and Btrfs extraction.
- Online Capacity Expansion (OCE) or RAID level migration during a degraded stateWhat it does: rewrites stripe geometry across the array while parity reconstruction is in progress. Why it destroys data: if the process halts, the array exists in a hybrid state. Sectors before the failure point use the new geometry; sectors after use the old. No standard tool can assemble the split-geometry volume without manual analysis.
Assessing the Array State
Before deciding on a course of action, gather information about the array state without modifying anything on disk. The goal is to determine whether the failure was transient (cable, timeout) or physical (media degradation, mechanical fault).
- Record the controller error. The exact message narrows the diagnosis. "Media error on PD 2 at LBA X" points to a specific drive and sector. "PD 3 not responding" suggests a mechanical or connection failure. Note the rebuild percentage at failure.
- Check SMART data on all drives. Use
smartctl -a /dev/sdX(Linux) or the controller's management utility. Key attributes: Reallocated_Sector_Ct (sectors already moved to spare areas), Current_Pending_Sector (sectors queued for reallocation), and Offline_Uncorrectable (sectors that failed offline scan). Non-zero values on any of these indicate degraded media. - Document the RAID configuration. Record the controller model, firmware version, RAID level, stripe size, write policy (write-back vs write-through), and number of drives. This information is required for offline reconstruction if controller metadata is damaged.
- Label every drive. Mark each drive with its physical slot number using tape or a marker on the drive itself (not just the tray). If drives are removed for imaging, the slot mapping must be preserved.
For detailed guidance on reading controller logs across Dell PERC, HP SmartArray, LSI MegaRAID, and Linux mdadm, see the degraded RAID troubleshooting guide.
When You Can Fix This Yourself
Not every failed rebuild requires professional recovery. The following scenarios can often be resolved by the administrator.
- The rebuild failed due to a transient error. If the controller dropped a drive because of a timeout (not a URE or mechanical failure) and SMART data on all drives is clean, the issue may be a loose SATA/SAS cable, a failing backplane connector, or a controller port problem. Reseat cables, test on a different port, and attempt the rebuild again. Image the drives first as a precaution.
- You have recent, verified backups. If backup integrity has been confirmed (not just backup job completion), restore from the backup. This is the correct answer for any array containing replaceable data.
- Software RAID (mdadm) with a single-sector URE. If the rebuild is mdadm-based and the error is a single-sector URE, you can use
ddrescueto image the affected drive (skipping the bad sector), then reassemble the array from images. - RAID 6 or RAID 10 after a non-fatal rebuild failure. If a RAID 6 rebuild failed due to a non-fatal error (such as a URE on a single stripe) rather than a complete second drive failure, the array may still be accessible in degraded mode. The array is in a mixed parity state, not a clean single-failure degradation; rebuilt stripes carry updated parity while unrebuilt stripes retain the original layout. If a RAID 10 rebuild failed within one mirror pair, the other pairs remain intact. Check controller status. If the volume is still mounted, copy data off immediately.
Example: In a software mdadm RAID 5 array, if a rebuild fails because a member drive returns a read error on a single sector, it is often possible to use ddrescue to image all drives. By assembling the array offline using cloned images, the data can be extracted. The single unreadable sector typically only affects the specific file block mapped to that physical location, leaving the rest of the filesystem intact.
When Professional Imaging Is the Right Call
Some rebuild failure scenarios leave the array in a state that cannot be safely resolved with standard administrator tools.
- Multiple physical drive failures. If two or more drives have hardware problems (clicking, not spinning, SMART reporting thousands of reallocated sectors), the drives need to be imaged with hardware that can manage bad sectors, weak heads, and firmware faults at a level
ddrescuecannot. - Partial rebuild corrupted parity data. If the controller wrote partial parity updates before the rebuild failed, the array cannot be reassembled using either the pre-rebuild or post-rebuild state without analyzing which stripes were modified. This requires forensic RAID reconstruction that compares parity states across drives.
- Controller metadata is damaged or missing. If the controller BIOS no longer shows the virtual disk, or shows it as "Foreign" or "Missing," the metadata defining stripe size, drive order, and parity rotation may be corrupted. Reconstruction requires scanning the raw drives to detect RAID parameters from data patterns.
- Post-failure operations already modified the drives. If someone has run force-online, fsck, or reinitialized the virtual disk, the on-disk state has been modified. Recovery is still possible in many cases, but the window narrows with each modification.
For RAID data recovery involving physical drive faults, we image each drive with PC-3000 through write-blocked connections, then reconstruct the array offline in software. The original drives are never written to. For RAID 5 arrays with partial rebuild corruption, we analyze stripe-level parity to determine which sections use pre-rebuild vs post-rebuild data.
How Different RAID Controllers Fail During Rebuild
The on-disk metadata format and the firmware behavior during a failed rebuild differ by controller family. The recovery posture is the same in every case (image first, assemble offline), but understanding what the controller did to the metadata before it gave up is what determines how fast the virtual assembly converges.
LSI MegaRAID and Broadcom
LSI and Broadcom controllers write Disk Data Format (DDF) metadata to the trailing sectors of every member drive. When a drive drops during a rebuild due to a TLER timeout, the controller marks the drive as Unconfigured-Bad or Offline. A removed and reinserted drive shows up as Foreign Configuration on the next boot. The MegaCLI tool can report all of this without writing to the drives, but the -PDMakeGood and -CfgForeign -Clear commands both modify DDF and should never run before forensic imaging.
Dell PERC H700 through H965
Dell PERC is built on LSI silicon with Dell-specific firmware. The PERC family is DDF-conformant but adds copyback behavior: if a global hot spare resynced into a failed slot and the original slot is later populated, the firmware automatically copies the spare back. A drive failure during copyback degrades the array a second time. The H965 has a documented Online Capacity Expansion bug that halts the transformation queue with a "drive count exceeded" error; arrays caught in that state must be imaged member-by-member before any attempt to clear the transformation queue.
HPE SmartArray controllers (P-series, Gen8 through Gen10) use a proprietary metadata layout rather than DDF, written to RAID Information Sectors (RIS) at the beginning of each member drive rather than the trailing sectors used by LSI and PERC. Advanced Data Guarding (ADG), the HPE name for RAID 6, runs through a transformation queue that interleaves rebuild operations with expansion operations. A URE during a transformation halts the queue and writes a log event. Do not change Rebuild Priority or Expand Priority in Smart Storage Administrator once a transformation halts; the change can flush the proprietary metadata in the RAID Information Sectors and complicate offline parsing.
Adaptec and Areca
Adaptec controllers running the aacraid driver maintain a configuration database on the member drives and a battery-backed (BBWC) or zero-maintenance (ZMCP) cache on the card. If the rebuild halts due to a power anomaly, pending parity calculations may still be sitting in NVRAM. Issuing arcconf task start commits cached writes to the drives, including any inconsistent parity computed mid-rebuild. Disconnect the drives, capture metadata offline, and assemble virtually with the array's detected rotation, which is often distinct from Linux mdadm defaults.
Linux mdadm
The mdadm v1.2 superblock sits 4 KiB into the member device. mdadm tracks an event count and a write-intent bitmap; when a member drops, its event count stops advancing while the array keeps writing. The next time mdadm sees that drive, it compares event counts and either marks the drive stale (requires full resync via --add) or replays the bitmap (--re-add). Using --re-add on a drive that should have required a full resync silently introduces stale blocks. Read-only assembly with --assemble --readonly against cloned images is the safe inspection path.
Intel RST Rebuild Loops
Intel Rapid Storage Technology (RST) and the Intel Optane Memory and Storage Management app have a documented bug where a RAID 5 rebuild reaches 100% completion, crashes the application, and restarts the rebuild from 0%. This has been reported across multiple RST versions, from ICH10R-era controllers through modern chipsets. Each loop pass forces a full sequential read of all surviving members and rewrites the entire replacement drive from scratch, and if the loop also triggers a consistency check, parity on the surviving drives may be recalculated and overwritten. If the rebuild loops: power off the system, do not let it restart, and image all member drives through write-blocked connections before interacting with the RST software again.
Synology DSM and QNAP QTS
Synology DSM wraps Linux mdadm and LVM. Each member drive carries a small system partition (md raid1), a swap partition, and a data partition that joins the mdadm RAID, which is then exposed through LVM as a Btrfs or ext4 filesystem. A Volume Crashed alert in Storage Manager is mdadm halting on partition 3. QNAP QTS and QuTS hero use a similar layout but store a proprietary configuration database on partition 1; a hard reboot mid-rebuild can corrupt that database, after which the QNAP Recovery Wizard offers to "initialize" the drives. Decline. The user data on the data partitions is still readable through a Linux workstation with mdadm, LVM, and Btrfs or ZFS userspace tools.
Our Image-First, No Live Rebuild Process
- Free evaluation and documentation. Record the controller model, RAID level, member count, filesystem (ext4, XFS, Btrfs, ZFS, NTFS, VMFS), and every prior rebuild or repair attempt and the commands run. This step is free and informs which metadata layer is still intact.
- Label every drive bay. Each drive is marked with its physical slot number before removal and bagged individually. Slot order is required to validate stripe layout during virtual assembly.
- Capture RAID metadata from each member. For Linux software RAID, the mdadm v1.2 superblock sits at offset 4 KiB. Metadata capture runs against cloned images, not the originals.
- Write-blocked forensic imaging. Each member is connected through a hardware write-blocker to PC-3000 Express. Adaptive retry and head-map analysis pull marginal sectors that the failed-rebuild controller had given up on inside its TLER window. A member that turns out to have mechanical damage receives a donor head transplant on the ULPA-filtered laminar-flow clean bench before imaging.
- Offline virtual assembly. Data Extractor Express RAID Edition loads the cloned images and assembles the array virtually using the captured metadata. The stripe size, parity rotation, and member order are read from the on-disk metadata rather than guessed.
- Parity recalculation and filesystem extraction. Stripes with missing data are reconstructed from parity. The assembled volume is mounted read-only. R-Studio and UFS Explorer handle filesystem-level recovery if the filesystem itself sustained damage during the failed rebuild.
- Delivery and secure purge. Recovered data is copied to your target media. After you confirm receipt, working copies are securely purged on request.
How Much Does RAID Rebuild Failure Recovery Cost?
Per-Member Imaging
- Logical or firmware-level issues: $250 to $900 per drive. Covers filesystem corruption on the array, firmware module damage that prevents normal reads, and SMART threshold failures.
- Mechanical failures (head swap, motor seizure): $1,200 to $1,500 per drive with a 50% deposit. Donor parts are consumed during the transplant. Head swaps are performed on a validated laminar-flow clean bench before write-blocked cloning.
Array Reconstruction
- $400 to $800 depending on member count, filesystem type, and whether RAID parameters must be detected from raw data versus captured from surviving DDF or mdadm superblocks.
- Data Extractor Express RAID Edition performs parameter detection and virtual assembly from cloned member images. R-Studio and UFS Explorer handle filesystem-level extraction after reconstruction.
No Data = No Charge: if we recover nothing from your array, you owe $0. Free evaluation, no obligation.
Example: a four-member array with one mechanically failed member and three healthy members costs approximately $1,200 (head swap) + 3 × $250 (logical imaging) + $400 to $800 (reconstruction) = $2,350 to $2,750.
+$100 rush fee to move to the front of the queue. Full HDD pricing is published at our HDD recovery service page.
RAID Rebuild Failure Recovery Questions
My RAID rebuild failed, what do I do right now?
What state is the array in after a rebuild aborts?
Why does my RAID 5 rebuild stop at a fixed percentage?
What is the URE rate that causes RAID 5 rebuild failures?
Can I retry a failed RAID rebuild?
Does forcing a RAID drive online destroy data?
Why does the controller drop a drive during rebuild?
What is the difference between a failed rebuild and a failed drive?
Can SMR drives cause RAID rebuild failures?
How do I recover from a failed RAID 5 rebuild?
Does the RAID level affect recovery chances after a rebuild failure?
Why do ZFS resilvers succeed when hardware RAID 5 rebuilds fail?
What does "not enough devices to start the array" mean after a rebuild?
How long does a RAID 5 or RAID 6 rebuild take?
Your rebuild failed. Power down before doing anything else.
