Enterprise Server Data Recovery
HP Smart Array P408i-a Data RecoveryHPE ProLiant DL360 Gen10 / HPE ProLiant DL380 Gen10 / HPE ProLiant DL560 Gen10
HP Smart Array P408i-a data recovery at Rossmann Group in Austin, Texas. This HP hardware raid controller supports RAID levels 0, 1, 5, 6, 10, 50, 60 across up to 30 drives via SAS/SATA. Commonly found in HPE ProLiant DL360 Gen10, HPE ProLiant DL380 Gen10, HPE ProLiant DL560 Gen10. Per-drive imaging costs $600 to $1,500 depending on drive condition, plus an array reconstruction fee. The most common failure we handle is array accelerator / cache status: temporarily disabled. All work is backed by our no-data-no-fee guarantee; you pay nothing if we cannot recover your files.
Updated February 2026
5 min read
Specifications
HP Smart Array P408i-a Specifications
HPE Smart Array P408i-a is an embedded controller in ProLiant Gen10 servers. Unlike Dell PERC (which uses DDF), HP Smart Array stores RAID metadata in a proprietary format written to raw reserved physical sectors at the start of each member drive, independent of any OS partitioning scheme. Default stripe size is 256KB. Data Extractor Express RAID Edition includes an HP Smart Array module that parses this reserved-sector metadata to determine drive order, stripe size, and parity rotation.
Manufacturer
HP
Controller Type
Hardware RAID
Interface
SAS/SATA
RAID Levels
Max Drives
30
Cache
2GB DDR4
Battery-Backed Cache
Yes
Recovery Tool Support
Data Extractor Express RAID Edition: Supported
Manual Reconstruction: Supported
HP Smart Array uses a proprietary metadata format (not DDF) written to raw reserved physical sectors at the start of each member drive, independent of any OS partitioning scheme. Data Extractor Express RAID Edition includes an HP Smart Array module that parses this metadata to determine drive order, stripe size, and parity rotation. Default stripe size is 256KB.
Compatible Server Lines
The HP Smart Array P408i-a is found in the following server platforms. If your server uses this controller and the array has failed, we can reconstruct the RAID offline from individual drive images.
HPE ProLiant DL360 Gen10HPE ProLiant DL380 Gen10HPE ProLiant DL560 Gen10HPE ProLiant ML350 Gen10
Failure Modes
Failure Modes
RAID controller failures differ from individual drive failures. The controller metadata, stripe maps, and parity calculations must all be intact for the array to function. Below are the failure modes specific to the HP Smart Array P408i-a.
Array Accelerator / Cache Status: Temporarily Disabled
Flash-backed write cache (FBWC) battery or capacitor reports failed during its self-test. Controller disables write cache and forces write-through mode. The array still functions but at degraded write performance. If an administrator does not notice and a drive fails while running in write-through, rebuild times are longer because every write goes directly to disk.
Symptoms you may notice
  • HPE Smart Storage Administrator shows 'Cache Status: Temporarily Disabled'
  • iLO alerts for cache module failure
  • Write performance drops noticeably; sequential write throughput may halve
Related search terms
HP Smart Array P408i cache disabledHPE P408i FBWC failureSmart Array cache temporarily disabledHP ProLiant Gen10 RAID recovery
Logical Drive Failed (1785 POST Error)
Two or more drives in a RAID 5 array fail simultaneously, or both members of a RAID 1 mirror fail. HP metadata marks the logical drive as failed and the array goes offline. The controller reports error 1785 at POST and the OS cannot access the volume.
  • Server shows '1785 - Logical Drive Not Configured' at POST
  • OS cannot access the logical volume; filesystem shows as unmounted
  • iLO sends critical alert for logical drive failure
HP Smart Array logical drive failedHP 1785 error recoveryHPE P408i RAID 5 failedHP ProLiant DL380 data recovery
Recovery Process
How We Recover HP Smart Array P408i-a Arrays
Step 1: Individual Drive Imaging
Every drive from the array is imaged independently using the PC-3000 and DeepSpar Disk Imager. Drives with head failures or firmware corruption are repaired first. Each drive is imaged sector-by-sector to a clean target before any reconstruction begins.
For SAS/SATA drives, we use the appropriate interface hardware. SAS drives require dedicated SAS HBAs; SATA drives connect directly. This preserves every readable sector without relying on the original HP Smart Array P408i-a controller.
Step 2: Array Reconstruction
We use Data Extractor Express RAID Edition to reverse-engineer the HP Smart Array P408i-a's metadata structure: stripe size, drive order, parity rotation, and offset values. The array is reconstructed from the drive images without needing the original controller hardware.
Once the virtual array is assembled, we extract the file system (NTFS, ext4, XFS, VMFS, ZFS, or other) and verify file integrity before delivering the recovered data.
The HP Smart Array P408i-a includes a battery-backed or flash-backed write cache (2GB DDR4). If the server lost power during a write operation, pending writes are preserved in the cache. On restart with a healthy controller, the firmware automatically flushes this cached data to disk; no manual intervention is needed. If the controller itself has failed, recovering cached data requires an identical replacement controller (same model, firmware revision) to which the cache module can be transferred.
Recovery pricing for HP Smart Array P408i-a arrays has two components: per-drive imaging and array reconstruction. Drive imaging costs $600–$900 to $1,500 per drive depending on condition (firmware repair vs. head swap). Array reconstruction adds a separate fee depending on the number of drives and RAID level complexity.
See our full pricing breakdown for details. Our No Data, No Fee guarantee means you pay nothing if we cannot recover your files.
Why does HP Smart Array recovery differ from Dell PERC recovery?
Dell PERC controllers store RAID metadata in DDF (Disk Data Format) at the end of each drive. HP Smart Array uses a proprietary metadata format written to raw reserved physical sectors at the start of each member drive, independent of any OS partitioning scheme. Data Extractor Express RAID Edition has a dedicated HP Smart Array module that reads this reserved-sector metadata to determine drive order, stripe size (HP defaults to 256KB; Dell PERC defaults vary by generation, 64KB on PERC 9 and earlier and 256KB on PERC 10 and later), and parity rotation.
My ProLiant shows '1785 - Logical Drive Not Configured' at POST. What happened?
Error 1785 means HP's RAID metadata has marked the logical drive as failed, typically because two or more member drives are offline simultaneously (in a RAID 5 array) or both sides of a RAID 1 mirror failed. The array can be reconstructed offline by imaging the member drives and parsing the RIS metadata from the raw reserved sectors at the start of each drive.
The P408i FBWC module shows 'Cache Temporarily Disabled.' Does that affect recovery?
No. The FBWC (Flash-Backed Write Cache) failure means the controller stopped caching writes and switched to write-through mode. The data on the array drives is still intact. The performance impact matters for live servers but does not change the recovery process. We image the drives and reconstruct the array normally.
How much does HP Smart Array P408i recovery cost?
Per-drive imaging fee based on each drive's condition, plus $400-$800 array reconstruction with HP metadata parsing. No data recovered means no charge.
Overview
Need help with a different setup? We also recover NAS arrays, standalone RAID, and enterprise SSDs.
Server Recovery Overview →
Nationwide Coverage
View All Locations
HP Smart Array P408i-a array down?
Ship the drives to our Austin lab for a free evaluation. No data, no charge.
