If your SSD has visible damage, do not reconnect it to your computer. A cracked PCB with severed traces can short power rails to ground when powered, sending excess current through the controller or NAND chips and causing secondary damage that turns a repairable board into a NAND transplant case. Call (512) 212-9111 for a free evaluation before applying power.
Can Data Be Recovered from a Physically Damaged SSD?
Yes, in most cases. Physical damage to an SSD usually affects the circuit board, connectors, or BGA solder joints rather than the NAND flash chips where data is stored. If the NAND chips are intact, board-level microsoldering repairs the damaged PCB and restores the controller's connection to your data.
What Counts as Physical SSD Damage?
Physical SSD damage is any structural or environmental harm to the circuit board, connectors, or component packages that prevents the controller from communicating with the NAND flash chips. Unlike firmware corruption, where the controller powers on but its internal mapping is scrambled, physical damage means something on the board is broken, corroded, or disconnected at the hardware level.
- Cracked or Flexed PCB
- Laptops that flex in a backpack, M.2 drives inserted at an angle, or cases dropped onto concrete. The thin PCB substrate (0.8mm on most M.2 drives) cracks and severs copper traces carrying power & data signals.
- Water & Corrosion Damage
- Spills, floods, or humidity that reaches the M.2 slot or SATA connector. Moisture creates conductive paths between traces & corrodes copper pads under BGA packages over hours to days.
- Broken M.2 or SATA Connectors
- Bent or snapped connector pins from improper installation, forced removal, or physical impact. The drive can't make electrical contact with the motherboard slot.
- Impact Damage to BGA Solder Joints
- A hard drop fractures the hundreds of tiny solder balls connecting the controller IC or NAND chips to the PCB. The chips are fine, but they've lost electrical contact with the board.
- Fire & Heat Damage
- Extreme heat melts solder joints, chars the PCB laminate, and can warp BGA packages. While NAND silicon does not melt at typical fire temperatures, heat accelerates charge leakage from the floating gates; sustained exposure above 150°C causes bit-level data corruption well before the PCB structurally fails.
How Do You Know If Your SSD Has Physical Damage?
Physical SSD damage is identified by visible cracks, corrosion, or broken connectors on the PCB, or by a clear physical event: a drop, spill, or surge that preceded the failure. If the drive looks intact but shows SATAFIRM S11, 0 bytes, or the wrong model name in BIOS, that is firmware corruption, not physical damage.
Physical damage produces visible or circumstantial evidence that separates it from firmware corruption or electrical failure. If you can see the damage or you know the drive took a hit, that's your answer.
- Visible cracks, fractures, or bending in the PCB substrate
- Bent, broken, or missing connector pins on the M.2 edge connector or SATA port
- Green or white corrosion residue on the board surface, especially around the controller BGA pads or connector area
- Burn marks or charring from fire or extreme heat exposure
- Drive stopped working after a known physical event: drop, liquid spill, laptop sat on, or hardware pulled while seated
- M.2 drive wobbles in the slot or doesn't seat fully because the connector edge is damaged
If the drive looks physically intact but shows SATAFIRM S11, 0 bytes, or the wrong model name in BIOS, that's likely firmware corruption. Different problem, different repair.
How Much Does Physically Damaged SSD Recovery Cost?
Physically damaged SSD recovery costs between $450–$600 and $1,200–$2,500, depending on damage severity and whether the original controller can be saved. Board repair (fixing traces, replacing components, reflowing BGA joints) is the less expensive path. NAND transplant to a donor board is the last resort when the PCB is too damaged to repair.
Every case starts with a free evaluation & a firm quote before any paid work. No data recovered means no charge. +$100 rush fee to move to the front of the queue.
| Damage Type | SATA SSD Price | NVMe SSD Price | Timeline |
| Connector repair / trace bridging | $450–$600 | $900–$1,200 | 3-6 weeks |
| Water / corrosion cleanup & component replacement | $450–$600 | $900–$1,200 | 3-6 weeks |
| BGA reflow / reball (fractured solder joints) | $600–$1,200 | $900–$1,200 | 3-6 weeks |
| NAND transplant to donor PCB (board beyond repair) | $1,200–$1,500 | $1,200–$2,500 | 4-8 weeks |
NAND transplant requires a 50% deposit. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers. All prices exclude tax & target drive.
How Is Data Recovered from a Physically Damaged SSD?
The goal is to restore electrical continuity so the original controller boots & decrypts your data through its own AES-256 hardware encryption pipeline. We fix the board around the controller; we don't replace it.
- 01
Visual Inspection Under Magnification
We photograph the entire PCB under 20x-40x magnification, documenting every crack, corroded pad, & displaced component. This map guides the repair plan and gives you a clear picture of what's broken before we quote anything.
- 02
Multimeter & Thermal Fault Localization
Cold resistance measurements on each power rail identify shorts to ground. FLIR thermal imaging with a current-limited bench supply pinpoints the exact component drawing excess current. On a water-damaged board, corrosion often creates shorts that aren't visible to the eye.
- 03
Board-Level Microsoldering Repair
Using Hakko FM-2032 irons on an FM-203 base station for precision component work & Atten 862 hot air for BGA packages, we replace damaged components, bridge severed traces, & clean corroded pads. Zhuo Mao precision BGA rework handles controller reflow when solder joints have fractured from impact.
- 04
Controller Boot & PC-3000 SSD Imaging
With the board repaired, the original controller initializes & decrypts the NAND. We connect the drive to PC-3000 SSD and image the data sector-by-sector. If the physical event also caused a power interruption that corrupted the firmware, we reconstruct the Flash Translation Layer before imaging.
Can Recovery Software Fix a Physically Damaged SSD?
No. Recovery software like Disk Drill, EaseUS, R-Studio, & PhotoRec requires the operating system to detect the drive. If the PCB is cracked, the connector is broken, or a shorted component prevents the controller from powering on, the drive is invisible to the OS. Software has no path to the NAND.
These tools work when the SSD is physically healthy but has a logical problem: an accidentally deleted partition, a corrupted file system, or formatted volume. That's a different category of failure. Software vs. professional recovery covers when each approach applies.
Physical damage needs physical repair. A cracked trace won't heal itself, a corroded BGA pad won't clean itself, and a broken M.2 connector won't re-seat itself. The drive needs a lab with board-level microsoldering capability & PC-3000 SSD for post-repair data extraction.
What Are the Types of Physical SSD Damage and How Is Each Repaired?
Each type of physical damage requires a different repair approach. The common thread: restore electrical continuity between the controller IC, NAND BGA packages, DRAM (if present), and the power management circuitry without replacing the controller itself.
How Is a Cracked SSD PCB Repaired?
M.2 2280 drives (22mm wide, 80mm long) are the most common form factor for NVMe SSDs, and their thin 0.8mm PCBs crack when the laptop takes an impact or the drive gets flexed during handling. A crack severs copper traces on multiple layers of the PCB stackup.
Repair involves identifying every broken trace using continuity testing between the controller BGA pads and the NAND chip pads, then bridging each severed trace with fine gauge wire (typically 38-40 AWG) soldered under magnification with the Hakko FM-2032. On a 4-layer M.2 PCB, inner-layer traces are harder to reach; we may need to drill micro-vias to access broken inner connections.
How Are Fractured BGA Solder Joints Repaired?
Controller ICs from Phison, Silicon Motion, Samsung, & Marvell connect to the PCB through Ball Grid Array packages with hundreds of 0.3mm-0.5mm solder balls. Impact damage fractures these joints, breaking electrical contact on specific pins while leaving others intact. The symptom is intermittent detection or complete failure depending on which balls fractured.
The Zhuo Mao precision BGA rework station applies a controlled thermal profile to reflow the solder balls without exceeding the NAND flash rated temperature threshold. If simple reflow doesn't restore all connections, the controller is reballed: removed from the PCB, cleaned, fresh solder balls applied using a stencil, then repositioned & reflowed. This preserves the original controller silicon and its fused encryption keys.
How Is a Damaged M.2 or SATA Connector Repaired?
The M.2 standard defines a 75-position edge connector; M-key and B-key modules each use up to 67 contact pins after the keying notch. Bent or broken pins prevent the drive from seating in the motherboard slot. If the damage is limited to the connector pad area, we can rework the connector: straighten bent pins under magnification or solder jumper wires from damaged pads to the traces they connect to further back on the PCB.
2.5" SATA SSDs use a standard SATA data + power connector. Physical damage here is less common but occurs when drives are yanked from bays without disconnecting the cable first. A torn connector pad on the PCB requires trace repair to restore the SATA data lines (differential pair signals that carry data at 6 Gbps on SATA III).
Why Dropped NVMe Drives Fail at the M.2 Edge Connector First
When a laptop or desktop takes a drop with an M.2 NVMe drive installed, the failure point is almost never the NAND packages or the controller die. The energy concentrates at the gold-finger edge connector, because that is the only mechanical pivot between the drive and the motherboard. The module is anchored at one end by the M.2 mounting screw and held by friction at the other end inside the slot. A sudden shock rotates the PCB around the screw, levering the gold fingers against the spring contacts in the slot.
The first casualties are the small surface-mount components clustered behind the gold fingers: PCIe AC-coupling capacitors on the four TX/RX differential pairs, the REFCLK series capacitors, and the PERST# pull resistor. These are 0201 or 01005 passives within 2-3mm of the connector edge, exactly where the bending moment is highest. A single missing 100 nF coupling cap on PCIe lane 0 can drop the link to x2 or fail PCIe enumeration outright. Under microscope inspection, a tombstoned cap shows up as one solder pad bare while the other still has the component lifted at an angle.
NAND BGA joints, sitting near the center or far end of the M.2 module, are orders of magnitude further from the stress concentration and rarely fracture in a normal drop. This is why reseating an M.2 drive in a different slot does not fix a drop-damaged drive: the damage is on the drive's PCB, not in the slot.
Repair starts with high-resolution photography of every passive within 5mm of the gold-finger edge. Each missing or lifted component is replaced under 40x magnification with the Hakko FM-2032 fitted with a 0.1mm conical tip, fresh leaded solder paste from a 27 gauge needle, and tweezer placement. The PCI-SIG CEM specification requires PCIe AC coupling capacitors to fall between 75 nF and 265 nF, with 100 nF and 220 nF the common in-spec values; picking the right value matters because a too-small cap distorts the signal eye and triggers retraining loops. Once the passives are restored, the drive enumerates normally on a PC-3000 SSD test bench and imaging proceeds through the original controller with the AES-256 key still intact.
ONFI and Toggle NAND Bus Signal Integrity Diagnosis
When PCB damage severs traces between the controller and the NAND packages, the drive may power on, draw nominal current, and still fail to enumerate. The fault is on the NAND interface bus rather than the power rails, and a FLIR thermal scan will show a normal heat profile. Diagnosis moves from thermal imaging to per-line continuity testing on the ONFI (Open NAND Flash Interface) or Toggle Mode bus that connects each NAND package to its controller channel.
ONFI 4.x and Toggle Mode 2.0 buses use similar physical signal sets per channel with protocol-specific naming: CE# (chip enable, one per package on the channel), CLE (command latch enable), ALE (address latch enable), WE# (write enable), DQ[7:0] (eight data lines), and R/B# (ready/busy). ONFI 4.x runs the read enable and data strobe as differential pairs designated RE_t / RE_c and DQS_t / DQS_c; Toggle Mode 2.0 uses RE / RE# and DQS / DQS# for the same lines.
A typical Phison or Silicon Motion NVMe controller drives 4 to 8 channels, and each channel is shared across 1-4 NAND chip enables. Severing a single CE# line disables one quarter to one half of the drive capacity and produces a controller boot loop because the FTL inventory check fails. Severing a DQ line on a single channel corrupts every read on that channel with consistent bit-flip patterns aligned to the broken bit lane.
The diagnostic procedure pulls the drive off power, then runs cold continuity from each controller BGA pad on the affected channel to the corresponding NAND package ball using a fine-tip multimeter probe at 0.5mm pitch. A break shows infinite resistance where the netlist expects a short. With the bus mapped, the repair is the same trace bridging procedure used elsewhere on the board: 38-40 AWG enameled magnet wire run between the severed endpoints under 40x magnification, anchored with UV-cure solder mask, then re-tested for continuity before applying power. On boards where the break is on an inner layer, micro-via drilling reaches the fractured trace from the surface. NAND data strobe lines are the most timing- sensitive; a long jumper that adds capacitance can degrade the eye on Toggle Mode data captures and force the controller to negotiate a slower interface speed, which is acceptable for a one-time imaging session through PC-3000 SSD.
Controller IC Transplant: When the Die Fractures but NAND Survives
Controller IC transplant is a separate procedure from NAND transplant and applies to a narrow set of cases: the controller silicon has cracked or shattered (visible die fracture under microscope, or confirmed via thermal anomaly under low-voltage probing), the NAND packages and PCB are otherwise intact, and a donor controller with matching firmware revision can be sourced. On encrypted modern SSDs this procedure does not recover data. On a small subset of older or unencrypted parts it can.
The constraint is the Media Encryption Key. Transplanting the user's NAND onto a donor controller produces a working drive that decrypts the donor's test data correctly and yields high-entropy ciphertext when reading the customer's transplanted NAND. The math is the same as a chip-off attempt; without the original key, the cipher block chain never resolves to plaintext.
Controller transplant only applies on a narrow set of strictly unencrypted parts: certain JMicron JMS-series controllers on budget USB-to-SATA bridges, and certain monolithic flash drives where the data scrambling is reversible and not bound to a per-controller key. On those parts a die-cracked controller can be replaced with a same-revision donor. We confirm encryption status during the free evaluation by reading the controller part number, querying the Self-Encrypting Drive (SED) capability flag, and checking the TCG Opal 2.0 lock state. If the drive reports always-on AES, we do not quote a controller transplant; we quote board repair, and if the controller die is unrecoverable, we tell the customer the data cannot be decrypted rather than charging for an attempt that will only yield ciphertext.
Board Repair vs. NAND Transplant: Which Path?
Board repair is always the first approach. It costs less ($450–$600 for SATA, $900–$1,200 for NVMe), preserves the original controller & its encryption keys, and has a higher success ceiling because the data decrypts through the native hardware pipeline.
NAND transplant ($1,200–$1,500 SATA, $1,200–$2,500 NVMe, plus donor cost) is the fallback when the PCB is too damaged to repair or the controller silicon itself is cracked. The NAND chips are desoldered using hot air, transplanted onto a compatible donor board with a matching controller revision, and the data is extracted through the donor's controller using PC-3000 SSD.
| Factor | Board Repair | NAND Transplant |
| When to use | Controller chip intact; damage limited to PCB traces, passive components, or connectors | Controller silicon cracked or PCB damaged beyond trace repair |
| Encrypted drives | Original controller preserved; encryption keys intact; data decrypts normally | Donor controller has different encryption key; yields ciphertext on encrypted SSDs |
| SATA SSD cost | $450–$600 | $1,200–$1,500 |
| NVMe SSD cost | $900–$1,200 | $1,200–$2,500 |
| Deposit | None | 50% deposit required |
| Timeline | 3-6 weeks | 4-8 weeks |
We always attempt board repair first. If board repair isn't viable, we'll tell you during the evaluation and quote the NAND transplant path with full cost disclosure including donor drive pricing.
Can You Recover Data from a Water-Damaged SSD?
Yes. Water damage to an SSD primarily causes corrosion on PCB traces, BGA pads, and connector pins. The NAND flash chips are sealed BGA packages; water does not reach the silicon. Board repair cleans the corrosion, repairs eaten traces, and restores the controller's power and data paths. Ongoing electrolytic corrosion slowly eats through copper traces over hours.
Water-damaged SSDs are a board repair problem, not a data recovery tool problem. The NAND flash chips are sealed BGA packages; water doesn't reach the silicon inside. The damage is on the PCB: corroded traces, dissolved copper pads, and conductive deposits that create short circuits between signal lines.
Corrosion progresses in stages. Within hours of exposure, copper traces begin oxidizing. Over days, electrolytic corrosion eats through traces entirely, starting at the thinnest points. The BGA pads under the controller are a common failure point because trapped moisture between the chip and the PCB creates a micro-environment where corrosion accelerates.
We start with ultrasonic cleaning in isopropyl alcohol to remove contaminants, then inspect every BGA pad and trace under magnification. We clean and re-tin corroded pads, and we bridge eaten-through traces with 38-40 AWG jumper wire using the Hakko FM-2032. If corrosion has reached under the controller BGA, we remove the chip with hot air, clean the pads, and reflow the controller on the Zhuo Mao BGA rework station.
Time matters. If your SSD got wet, don't dry it with a hair dryer or put it in rice. Disconnect it from power, seal it in a bag, and ship it to the lab as quickly as possible. The sooner corrosion is arrested, the fewer traces need repair.
What Does a Power Surge Do to an SSD Controller?
A power surge damages an SSD by destroying the Power Management IC (PMIC) that converts incoming voltage to the 1.8V, 1.2V, & 0.9V rails feeding the controller core, DDR cache, & NAND chips. If the PMIC absorbs the surge before it reaches the controller die, replacing the PMIC restores the drive. If the surge reaches the controller silicon, the encryption key is gone on encrypted drives.
SATA SSD Power Delivery Failures
SATA SSDs draw 5V from the SATA power connector (the 3.3V pins on the 15-pin connector are unused by most consumer 2.5" SSDs). The most common overvoltage scenario isn't a lightning strike; it's plugging in the wrong modular PSU cable. Modular cable pinouts aren't standardized across manufacturers. A Corsair cable in an EVGA PSU can route 12V down the 5V line, delivering over twice the rated voltage to the PMIC. TVS (transient voltage suppressor) diodes on the input rail clamp first, but if sustained overvoltage burns them out and they fail open, the full 12V bypasses the protection and hits the PMIC & everything downstream.
Board repair for this failure costs $450–$600. We inject low voltage through a current-limited bench supply, then scan the PCB with a FLIR thermal camera. The shorted PMIC or blown MLCC capacitor shows up as a thermal hotspot within seconds. Replacing the failed component with the Hakko FM-2032 on an FM-203 base station restores the voltage rails, and the controller boots normally through PC-3000 SSD.
NVMe Power Delivery Failures
NVMe drives receive 3.3V from the motherboard's M.2 slot. A motherboard voltage regulator failure or surge event can spike this single rail, and there's no second input voltage to act as a buffer. The PMIC on an NVMe drive steps 3.3V down to the controller core voltage (often 0.9V on Phison PS5012/PS5016 or Samsung Elpis controllers), the 1.2V NAND interface rail, & the 1.8V DDR4 cache rail.
When the PMIC fails, the drive is dead: invisible to BIOS, no response to enumeration. NVMe board repair runs $900–$1,200, which covers PMIC replacement & any associated passive component failures. The diagnostic sequence is identical: current-limited power injection, FLIR thermal fault localization, component-level replacement. If the PMIC protected the controller die, the AES-256 key is intact & data extraction proceeds through PC-3000 SSD without encryption barriers.
The critical question after any surge event: did the PMIC absorb the hit, or did the overvoltage reach the controller die? FLIR imaging answers this within the first 10 minutes of evaluation. A hot PMIC with a cold controller is good news; the controller survived. A hot controller means the silicon took damage, and on encrypted drives that means the key material is compromised. We determine this during the free evaluation before quoting any repair work.
How Thermal Cycling Causes Internal PCB Damage in NVMe SSDs
NVMe SSDs running Gen4 or Gen5 controllers reach 70-85°C under sustained workloads. Repeated heating & cooling cycles create mechanical stress between the copper vias (16 ppm/°C expansion rate) and the FR-4 fiberglass substrate (roughly 70 ppm/°C in the Z-axis). Over thousands of cycles, this 4-5x expansion mismatch fractures internal via barrels or separates PCB layers entirely.
Why FR-4 Substrate Fails Under Thermal Stress
SSD circuit boards use FR-4 laminate: woven fiberglass bonded with epoxy resin, with copper layers sandwiched between the fiberglass plies. Copper vias punched through the board connect traces on different layers. Each heat-cool cycle stretches the via barrel against the surrounding FR-4. The cumulative strain either cracks the copper via barrel itself or separates the epoxy bond between FR-4 layers, a condition called delamination.
The damage is invisible from the surface. Unlike a cracked PCB or corroded pad, delamination happens inside the board stackup. The drive works fine for months, then stops cold. The board looks physically intact under magnification, and standard visual inspection won't find the failure. Diagnosis requires continuity testing between BGA pads layer by layer, checking each via connection against the PCB netlist.
Which Drives Are Most at Risk
NVMe drives installed without thermal pads, heatsinks, or airflow are the primary risk group. Fanless NUCs, laptops with poor thermal design, and external NVMe enclosures that trap heat keep the controller at sustained high temperatures during writes, then drop to ambient when idle. Each cycle adds cumulative fatigue to the via-to-FR4 interface. Older SATA SSDs with SM2246EN or SM2258XT controllers rarely generate enough heat for this failure mode; their thermal envelope stays under 50°C even at peak load.
Repair Options for Delamination Damage
If delamination has severed one or two internal vias, the repair is trace bridging: routing a jumper wire from the affected BGA pad to an alternative access point on the same net, bypassing the fractured via. This falls under the circuit board repair tier ($900–$1,200 for NVMe). Widespread delamination across multiple layers pushes the case to NAND transplant ($1,200–$2,500 plus donor cost), since the original PCB can't be trusted to maintain stable connections during a multi-hour imaging session.
Board repair preserves the original controller & its AES-256 encryption key. NAND transplant to a donor board means a different controller with a different key, which yields ciphertext on encrypted NVMe drives. That's why we exhaust every board-repair option before moving to transplant. +$100 rush fee to move to the front of the queue.
Does Physical Damage Affect SSD Encryption?
Yes, and this determines the recovery path. Hardware-encrypted SSDs bind their AES-256 key to the controller silicon. If the controller is intact but surrounding components are damaged, board repair preserves the original key and data decrypts normally. If the controller die is cracked or shattered, the key is gone.
Many modern SSDs encrypt all data using AES-256 hardware encryption, with the key generated on and bound to the original controller so it never leaves that silicon. Most NVMe drives manufactured after 2015 and SATA drives with TCG Opal or IEEE 1667 support have always-on encryption. Some budget SATA models use simpler XOR data scrambling instead of AES-256, but the data is still unreadable without the original controller.
This creates a hard constraint for physically damaged SSDs. If the controller chip is physically intact (the silicon isn't cracked), board repair restores the power and data paths around it. The controller boots, the encryption key is right there in the silicon, and the NAND decrypts normally. Recovery proceeds through PC-3000 SSD as if the drive were healthy.
If the controller is destroyed (cracked die, shattered package), the encryption key is gone. Chip-off NAND extraction can read the raw NAND pages, but the data is AES-256 ciphertext without the original controller's key material. On non-encrypted drives (some older SATA models, drives with encryption disabled at the factory), chip-off remains a viable last resort. We determine encryption status during the free evaluation and won't quote a chip-off on an encrypted drive that would yield only ciphertext.
This is why we always attempt board repair first. Saving the controller saves the encryption key. Most data recovery labs outsource board-level work or declare physical damage unrecoverable because they don't have microsoldering capability. Rossmann Repair Group was a board repair shop before it was a data recovery lab; founded in 2008, the microsoldering infrastructure was the starting point, not an add-on.
Damaged SSD: Is the Failure Physical or Logical?
A "damaged" SSD splits cleanly into two failure classes: physical or electrical damage to the PCB, and logical or firmware corruption inside the controller. The Austin lab handles both in-house. Physical damage routes to board-level microsoldering on the Hakko FM-2032 & Atten 862, then imaging through the original controller on PC-3000 SSD. Logical & firmware failures route directly to PC-3000 SSD service-area work without any soldering.
The Two Failure Classes
- Physical or Electrical Damage
- Board-level faults: blown PMIC, blown TVS diode, cracked PCB traces, fractured BGA solder joints under the controller or NAND, broken M.2 or SATA edge connector, liquid & corrosion damage, cracked NAND packages from impact. The drive does not enumerate in BIOS, draws abnormal current, or shows visible damage under 40x inspection. Resolved by board repair on the Hakko FM-2032 (FM-203 base), Atten 862 hot air, & Zhuo Mao precision BGA stations, with fault localization via current-limited bench injection & FLIR thermal imaging. Once the board is electrically healthy, imaging runs through the original controller on PC-3000 SSD.
- Logical or Firmware Failure
- The PCB is electrically sound & the drive powers up, but the controller's Flash Translation Layer or service area is corrupted. Symptoms include the drive enumerating as SATAFIRM S11, reporting the wrong model name, presenting 0 byte or 8 MB capacity, or dropping into protective read-only mode. No soldering is required. Resolved by firmware recovery on PC-3000 SSD: service-area reconstruction, FTL rebuild, & imaging through the original controller. See SSD firmware corruption recovery for the full firmware-failure workflow.
Symptom-to-Path Map
The table maps the observable symptom a customer can describe over the phone to the underlying failure class & the in-house recovery path. Classification happens in the first 10 minutes of the free evaluation using visual inspection under magnification & FLIR thermal scan on a current-limited bench.
| Observable Symptom | Failure Classification | Rossmann Lab Recovery Path |
| Drive invisible in BIOS after a drop | Physical (BGA / board damage) | Visual & FLIR triage, BGA reflow on Atten 862 hot air or Zhuo Mao BGA station, discrete component replacement on Hakko FM-2032, then image on PC-3000 SSD |
| Drive invisible in BIOS after liquid spill | Physical (corrosion) | Ultrasonic clean, microsoldering trace & pad repair on Hakko FM-2032, then image on PC-3000 SSD |
| Drive invisible in BIOS after a power surge | Physical / electrical (PMIC or TVS diode) | Current-limited bench injection, FLIR fault localization, component swap on Hakko FM-2032, then image on PC-3000 SSD |
| Drive enumerates as SATAFIRM S11 or wrong model name | Logical / firmware (FTL corruption) | PC-3000 SSD firmware recovery; on the Phison PS3111-S11 & related Phison SATA parts in the ACELab supported list, service-area reconstruction runs directly on the bench. See firmware corruption recovery. |
| Drive reports 0 byte or 8 MB capacity | Logical / firmware (service area corruption) | PC-3000 SSD service-area reconstruction, then image through the original controller |
| Drive locked into read-only mode | Logical / firmware (protective state, write-cycle exhaustion) | Image through the controller on PC-3000 SSD while the drive remains readable; no soldering required |
| M.2 module physically snapped | Physical (PCB fracture) | Board-side trace bridging with jumper wires on Hakko FM-2032 when the break misses the chips; when the break runs through the NAND side, NAND chips AND the original controller must be transplanted together to a matched donor board, because on AES-256 SED parts the NAND alone contains only ciphertext without the controller's on-die key |
| Snapped M.2 connector or bent gold-finger pads | Physical (connector damage) | Microsoldering rework of edge components & gold-finger traces on Hakko FM-2032, then image on PC-3000 SSD |
| Burn marks or visible charring on the PCB | Physical (heat / fire damage) | 40x visual triage; if the controller die survived, board repair on Hakko FM-2032 & Atten 862; if the controller die is destroyed on an AES-256 part, the encryption veto applies & we say so before quoting |
If you searched "damaged ssd data recovery," this is the workflow: ship the drive in, the lab classifies physical versus logical in the first 10 minutes of the free evaluation using visual inspection under 40x magnification & a FLIR thermal scan on a current-limited bench, & you get a firm written quote before any deposit is taken. Board-repair work on a SATA SSD prices at $450–$600; NVMe board repair prices at $900–$1,200. Logical firmware work prices separately under the firmware-recovery tier. +$100 rush fee to move to the front of the queue.
Reball, Replace, or Chip-Off: How Is a Damaged SSD Controller Triaged?
Every damaged SSD that hits the bench gets sorted into one of four controller paths and one of four NAND states. The two axes drive the quote: a healthy controller on cracked traces is a board-repair job, a fractured controller on intact NAND is a NAND transplant, and a shattered NAND package is an unrecoverable-pages call we make before charging anything. The matrices below are how the decision actually gets made under the microscope.
Controller Triage: When to Reflow, Reball, Transplant, or Chip-Off
Controller condition is graded under 40x microscope inspection combined with thermal and continuity testing on a current-limited bench. Encryption status sets a hard veto on transplant: an AES-256 SSD with a destroyed controller die is a key-loss case, and we say so before quoting.
| Controller Condition | Detection Method | Repair Path | Encrypted-Drive Veto |
| Intact silicon, suspected BGA joint fracture | Intermittent enumeration; continuity gaps on specific package balls | Hot-air reflow on Zhuo Mao BGA station | None; original key preserved |
| Intact silicon, reflow did not restore all pins | Post-reflow continuity still gapped on multiple balls | Reball: lift package, clean pads, fresh stencil, reflow | None; original key preserved |
| Cracked or shattered die | Visible die fracture under microscope; thermal anomaly under low-voltage probe | NAND transplant to donor board with matching controller revision | Hard veto on AES-256 drives: yields ciphertext. Quote not offered. |
| Vaporized or missing controller | Package physically absent or carbonized from surge or fire | Chip-off NAND read; donor-board imaging | Hard veto on AES-256 drives; only viable on unencrypted SATA parts |
Encryption status is read off the controller part number, SED capability flag, and TCG Opal 2.0 lock state during the free evaluation, before any quote.
NAND Damage Assessment: Four States, Four Outcomes
The NAND packages themselves are sealed BGA components, and they tolerate impact and spills well. When NAND damage does occur, it falls into one of four states with different detection methods and very different recovery prospects. Generic controller families that show up in failure-mode discussions include Phison E18 and E21T, Silicon Motion SM2264 and SM2320, Maxio MAP1602, Innogrit IG5236 and IG5666, and Marvell 88SS1093 and 88SS1100; we do not claim PC-3000 SSD recovery support for every one of these (see SSD data recovery overview for the supported-controller matrix), but the NAND failure modes below are independent of the controller in front of them.
| NAND State | Detection Method | Triage Path |
| Visible package crack | Hairline or open crack visible under 20x-40x on the epoxy package surface | Read attempt on the cracked package; if it responds, image immediately. If not, that package's data is unrecoverable; remaining packages still image normally. |
| Internal die fracture (package intact) | Read commands return all-bits-zero or all-bits-one; pre-read current draw abnormal on that channel | X-ray inspection or specialist decapsulation confirms; if the internal die is fractured the package is unrecoverable. Other packages on the drive still image. |
| Bond wire damage | Specific signal pins on the package read open; remaining pins continuous to the die | Limited package-level rework possible in narrow cases; more commonly this package is logged as partial-read and the rest of the drive proceeds to imaging. |
| Substrate delamination on the NAND BGA | Continuity present cold, fails under reflow temperature; warm rework restores then loses connection | Reball the NAND package onto fresh solder; if delamination is across multiple layers, transplant the die to a fresh substrate or chip-off read. |
NAND-side damage rarely takes the whole drive; modern M.2 SSDs distribute data across 2 to 4 NAND packages (each of which may contain multiple stacked dies), so a single failed package costs you a fraction of the LBA range rather than the entire dataset. We report exactly which logical block ranges were read successfully versus marked unrecoverable on the final recovery sheet.
Why Does SSD Recovery Require Board Repair Instead of a Cleanroom?
SSDs have no exposed media. The NAND die and controller are sealed inside epoxy-molded BGA packages impermeable to dust, moisture, and skin oils. SSD recovery requires a microsoldering bench: microscope, thermal camera, bench PSU, and surface-mount rework tools. Labs that charge cleanroom fees on SSD recoveries are billing for an environmental control the job does not use.
HDD recovery needs an ULPA clean bench because the read/write heads fly nanometers above exposed magnetic platters; a single airborne particle can score the surface. SSDs have no exposed media. The NAND die and controller are cast inside epoxy-molded BGA packages impermeable to dust, moisture, and skin oils. Opening an SSD case does not expose any data-bearing surface to ambient air. What SSD recovery does require is a microsoldering bench: microscope, thermal camera, bench PSU, and surface-mount rework tools. Rossmann Repair Group's SSD lab was a board repair shop first; the microsoldering infrastructure predates the data recovery service.
PMIC Failure Diagnosis with FLIR Thermal Imaging and Bench PSU
The Power Management IC on an NVMe SSD steps the 3.3V M.2 slot input down to the rails the controller and NAND actually need. When a PMIC shorts, the whole drive goes dark; BIOS sees nothing because the controller never receives power.
Diagnosis starts on a current-limited bench PSU set to the rated input with a 200 mA current ceiling. A healthy drive draws a brief inrush then settles under 50 mA at idle. A shorted PMIC or decoupling capacitor pins the supply at the current limit and pulls the rail below 3.0V. A FLIR thermal camera resolves the failed component within seconds: the shorted part runs 30-60°C above ambient while the rest of the board stays cold. Repair is a component swap with the Hakko FM-2032 on an FM-203 base station, or a hot air reflow on the Atten 862 when the failed part is the PMIC BGA itself.
VCC and VCCQ Rail Voltage Testing
NAND flash packages and controllers have narrow rail tolerances, set by JEDEC standards and component datasheets. The test procedure is multimeter on DC voltage, probe pads documented in controller service schematics, compare against nominal, and note any rail pulled below tolerance or shorted to ground.
- VCC (NAND core power): JEDEC-defined 2.7V to 3.6V, nominal 3.3V. A dead VCC rail means the NAND packages receive no power and the controller can never enumerate.
- VCCQ (controller-to-NAND I/O): 1.70V to 1.95V nominal on modern Gen3 and newer drives; some legacy parts run 3.3V. Exceeding 1.95V on a 1.8V VCCQ IC causes latch-up that is invisible externally but fatal.
- Vcore (controller logic): 0.9V to 1.0V for ARM cores inside Phison PS5026-E26, Samsung Elpis, and similar controllers. Instability here produces enumeration that drops out after a few seconds.
- VDD (DRAM cache): 1.2V for DDR4 cache, lower for LPDDR4 on Gen5 parts. A dead DRAM rail forces the controller into a degraded mode where the Flash Translation Layer cannot cache properly.
A rail out of tolerance points to a specific failed component (PMIC output stage, filter capacitor, inductor, or a shorted downstream load). Cold resistance to ground on each rail narrows the fault to a discrete location before any power is applied.
Trace Reconstruction and Tombstoned Component Replacement
M.2 NVMe boards are populated with 0201 (0.6mm x 0.3mm) and 01005 (0.4mm x 0.2mm) MLCC passives. An 01005 capacitor is smaller than a grain of sand. Drop events mechanically tombstone these parts: one end lifts off its pad while the other stays soldered, or the component flies off the board entirely. AC coupling capacitors on the PCIe TX/RX differential pairs near the gold-finger edge connector are the most common casualty because they sit right at the mechanical stress point where the module plugs into the motherboard.
PCIe Gen3 and Gen4 lanes require series DC-blocking capacitors of 100 nF to 220 nF on each differential line. A single missing 01005 coupling cap on one lane drops the link from x4 to x2, or fails enumeration entirely. Replacement is a microscope job with the Hakko FM-2032 at 0.1mm conical tip, preheat under the PCB to reduce thermal shock, fresh leaded solder paste dispensed from a 27 gauge needle, and tweezer placement under 40x magnification. Severed traces are bridged with 38-40 AWG enameled magnet wire run across the damaged section and anchored with UV-cure solder mask. Four- and six-layer M.2 boards sometimes need micro-via drilling to reach inner-layer traces that fractured in a flex event.
Why Epoxy-Encapsulated NAND Packages Do Not Need a Cleanroom
NAND flash dies are manufactured in semiconductor fab cleanrooms, then packaged at the back-end assembly house by injection-molding a cured epoxy compound around the die and substrate. The resulting plastic BGA is not hermetic in the strict MIL-STD-883J sense (that classification requires metal or ceramic enclosures with glass-to-metal seals), but the cured epoxy is impermeable to airborne particles, skin oils, and humidity at typical ambient levels. Opening the SSD chassis exposes only the outside of these sealed packages. Dust landing on a BGA does nothing. A fingerprint on a NAND package does nothing. None of the storage medium is exposed, and no part of SSD recovery requires laminar airflow or HEPA/ULPA filtration.
This is the difference between an HDD lab and an SSD lab. HDD recovery requires a ULPA bench because the platter surface is open to air every time the lid comes off. SSD recovery requires a microscope, a thermal camera, a temperature- controlled iron, and a PC-3000 SSD. Labs that charge cleanroom fees on SSD recoveries are billing for an environmental control the job does not use. Our SATA SSD board repair tier is $450–$600 and NVMe board repair is $900–$1,200; both cover PMIC diagnosis, rail testing, passive replacement, and imaging through the original controller via PC-3000 SSD. +$100 rush fee to move to the front of the queue.
What Is the Diagnostic Process for Damaged SSD Data Recovery?
Diagnosis runs in five fixed steps before any paid work begins. Visual inspection under 20x-40x stereo microscope logs burnt PMICs, fractured traces, and corrosion. FLIR thermal imaging under current-limited bench power identifies the shorted component within seconds. The result is a specific fault location and a firm quote before any deposit changes hands.
Damaged SSD data recovery starts with diagnosis, not repair. The five steps below run in order on every physically damaged drive that hits the bench. Each step narrows the fault from "something on this board is broken" to a specific component on a specific rail, so the repair plan and the quote are based on evidence rather than guesswork. No power is applied to a damaged drive until step 2, and no paid work begins until all five steps are complete.
- 01
Visual Inspection Under Stereo Microscope (20x-40x)
Every square millimeter of the PCB is photographed under 20x to 40x stereo magnification before any power is applied. The inspector logs burnt PMICs (visible charring or a missing top half of the package), scorched controller packages, blown decoupling capacitors (cracked dielectric or vaporized terminals), lifted or tombstoned BGA pads, fractured PCB traces, and corrosion on the M.2 gold fingers or SATA edge connector. The output is a damage map that drives the rest of the diagnostic flow.
- 02
FLIR Thermal Scan Under Low-Voltage Bench Injection
With the damage map in hand, a current-limited supply is injected from a bench PSU through the host interface: 3.3V for M.2 NVMe and M.2 SATA, 5V for the standard 2.5-inch SATA edge connector. The bench input feeds the PMIC, which regulates down to the controller core (often sub-1V), the 1.2V NAND interface rail, and the 1.8V cache rail; NVMe parts also expose a VCCQ rail for NAND I/O. A FLIR thermal camera resolves the failed component within seconds: a shorted regulator output, a leaking decoupling cap, or a cracked PMIC die runs 30-60°C above ambient while the rest of the board stays cold. The hotspot identifies the failed component without guesswork.
- 03
Bench Injector Current Draw Measurement Against Datasheet
Quiescent current is measured on each regulated rail and compared against the controller and PMIC datasheet expected idle draw. A healthy NVMe SSD settles into its datasheet-specified active-idle range, which depending on the controller and Active State Power Management state typically falls between roughly 10 mA and 200 mA; excess current beyond that envelope on a specific rail isolates the short to that rail's downstream components. If the host-input rail pulls the supply to the current ceiling, the fault is upstream of the PMIC. If the 1.2V NAND rail pulls excess current while the host input looks clean, the fault sits on a NAND-side filter cap or inside a NAND package. Read more on rail-by-rail diagnosis in our electrical failure recovery workflow.
- 04
NAND Package Continuity Verification
After the board fault is localized, each NAND package's power, ground, CE, RE, WE, R/B#, and data lines are verified for continuity using a fine-tip multimeter or low-voltage signal probe at the package pitch (1.0mm on both BGA-152 and BGA-132 NAND parts). Cracked solder joints under a NAND BGA can survive thermal imaging and still fail under load; cold continuity catches those before any imaging attempt. A break shows infinite resistance where the netlist expects a short, and the affected ball is logged for reflow or re-bridging during the repair step.
- 05
Decision Branch: Board-Repairable vs. Chip-Off-Required
The four diagnostic steps above sort the drive onto one of two paths. The decision is documented before any paid work begins.
- Board-repairable: controller silicon intact, surrounding components damaged
- The board is repaired with the Hakko FM-2032 (and the Atten 862 hot air station or Zhuo Mao precision BGA rework for BGA components), then imaged through the original controller on PC-3000 SSD. This preserves the controller-bound AES-256 encryption key and the data decrypts through the native hardware pipeline. Cost: $450–$600 for SATA, $900–$1,200 for NVMe.
- Chip-off-required: controller die fractured or package destroyed
- The encryption key is gone with the silicon, and the recovery path moves to chip-off NAND extraction. On AES-256 encrypted drives, chip-off reads only ciphertext and we will not quote it. On the narrow set of unencrypted parts where chip-off still yields plaintext, controller-scrambled data may still be unrecoverable depending on how the original part handled NAND scrambling. The free evaluation tells you which side of this line your drive falls on before any deposit changes hands.
Can data be recovered from a physically damaged SSD?
How much does physically damaged SSD recovery cost?
Can you recover data from a water-damaged SSD?
What happens if my SSD was dropped or crushed?
Does physical damage affect SSD encryption?
How long does physically damaged SSD recovery take?
Should I try to repair a physically damaged SSD myself?
Can data be recovered from an SSD with a cracked circuit board?
Can you recover data from a snapped or broken SSD?
Can data be recovered from a dead M.2 SSD?
Is it possible to recover data from a failed SSD?
How can I tell if my SSD is corrupted or failing?
Physically broken SSD: can I still recover data from it?
What is the diagnostic process for damaged SSD data recovery?
How do you diagnose a water-damaged SSD before attempting repair?
Can you recover data from a physically broken SSD that won't power on?
Related SSD Recovery Services
Electrical Failure Recovery
Burnt TVS diodes, blown voltage regulators, & shorted capacitors from power surges & ESD events.
Chip-Off NAND Extraction
Last resort when the controller is destroyed. Raw NAND read with honest limits on encrypted drives.
Firmware Corruption Recovery
SATAFIRM S11, 0GB capacity, wrong model name. Controller works but firmware mapping is corrupted.
Hardware Encryption Recovery
AES-256 encrypted SSDs where the controller must be repaired to preserve the encryption key.
SSD physically damaged? Cracked, dropped, or water-exposed?
Free evaluation. SATA PCB repair: $450–$600. NVMe PCB repair: $900–$1,200. No data, no fee.
