What Causes Samsung 870 EVO Failures?
The Samsung 870 EVO uses Samsung's MKX controller paired with Samsung V-NAND (3D TLC).
TLC NAND stores 3 bits per cell by distinguishing between 8 voltage levels. As cells degrade through program/erase cycles or manufacturing variability, the voltage margins between those 8 levels narrow. The controller uses Low-Density Parity-Check (LDPC) error correction to compensate, but LDPC has a correction ceiling. When a cell's voltage drift exceeds the LDPC correction capacity, the read fails as an uncorrectable error.
Why does a degraded 870 EVO go to the bench?
The MKX controller (documented as Metis / S4LR059 in firmware contexts) is what the 870 EVO ships with; MJX is the 860 EVO controller and is not interchangeable. As V-NAND cells lose retention faster than LDPC can correct, the controller cascades into FTL corruption and either drops off the SATA bus entirely, hangs in BSY during POST, or falls into a throttled PIO-style safe mode where the host sees zero or wrong capacity. The drive also enforces Deterministic Zeroes After TRIM, so even when an LBA happens to point to a physical page that still holds intact data, the controller intercepts the read and returns zeroes whenever the FTL has marked that LBA as trimmed or invalid. Consumer software (Recuva, EaseUS, R-Studio over a Windows or macOS driver) runs on top of the LBA abstraction the controller has already corrupted; there is no way for host-level software to bypass a panicked MKX controller.
The work has to keep the original controller alive long enough to image. On the bench, that means board-level diagnosis with a current-limited supply and FLIR thermal imaging to find the dead component. Microsoldering replacement of the failed part follows on a Hakko FM-2032 or Atten 862 hot-air rework station, with Zhuo Mao precision BGA equipment when reflow or reballing is required. Imaging then runs on PC-3000 SSD in normal mode with aggressive read-retry and per-command timeouts to pull what the stabilized controller can decrypt. No published firmware-level path covers the MKX generation the way PC-3000 SSD covers the older Samsung SATA MEX controller, so this is not a VSC reflash; it is hardware-stabilization plus normal-mode imaging.
If the controller silicon itself is dead, the AES key is gone with it and the case is generally not economically recoverable on this generation. Free evaluation in our Austin, TX lab determines which path applies before any paid work.
Symptoms of Samsung 870 EVO NAND Degradation
The failure progresses through stages. Early symptoms are subtle and easy to dismiss. By the time the drive shows 0 bytes, significant NAND degradation has accumulated.
- Stage 1
Intermittent read slowdowns
File copies stall or take longer than expected. Applications freeze briefly when loading files from the drive. The controller is spending extra cycles on ECC correction for marginal cells.
- Stage 2
Uncorrectable read errors in system logs
Windows Event Viewer shows "The IO operation at logical block address was retried" or "Reset to device was issued" errors. macOS Console logs show
IOAHCIBlockStoragetimeout errors. Specific files become unreadable or return corrupted data. The controller is hitting cells beyond LDPC correction capacity. - Stage 3
System freezes and boot failures
If the 870 EVO is the boot drive, Windows hangs during startup or enters a repair loop. The controller is failing reads on critical system files (NTFS metadata, registry hives, boot configuration). The system appears "frozen" because the OS is waiting on reads that the controller cannot complete.
- Stage 4
0 bytes capacity or drive not detected
The controller enters a protective state after exhausting its bad block remapping capacity. The drive may report 0 bytes in Disk Management, show an incorrect model string, or disappear from BIOS entirely. The firmware cannot maintain a coherent FTL mapping with the number of failed blocks.
What Happens to an 870 EVO During a Sudden Power Loss?
A sudden power loss during a write operation can corrupt the 870 EVO's internal mapping tables, making data inaccessible even though the NAND cells still hold it. The MKX controller maintains these tables in DRAM & flushes them to NAND periodically. Power loss mid-flush corrupts the mapping metadata, and the controller can no longer locate your files.
The 870 EVO's TLC NAND stores 3 bits per cell using 8 voltage levels. During a write, cells transition through intermediate states before settling at their target level. Lose power mid-write, and some cells land between valid voltage states. The controller flags these as uncorrectable errors on the next read attempt, even though the surrounding cells are healthy.
Power loss also damages the Flash Translation Layer (FTL). The FTL is the index that maps logical block addresses (what your OS sees) to physical NAND locations (where the data actually sits). The MKX controller keeps the working FTL copy in volatile DRAM for speed. If power drops while the controller is writing FTL updates back to NAND, the on-disk FTL copy becomes inconsistent. The controller boots, finds a corrupted FTL, and reports the drive as 0 bytes or wrong capacity.
Why 870 EVO FTL Corruption Is Harder Than Older Samsung SATA
On the older Samsung SATA drives ACELab lists for PC-3000 SSD (the 840 EVO and 850 PRO, both built on the S4LN045X01 MEX silicon), the Samsung utility rebuilds the logical-to-physical map at the firmware level. Nothing published does that on an 870 EVO (MKX / Metis, S4LR059), so the controller is effectively a closed box at the firmware layer.
What remains is normal-mode imaging. If the controller can be stabilized (board-level repair of the power rails or PMIC, replacing any shorted passive component, restoring clean supply to the controller so it boots into its own normal mode) and if enough of the drive's own internal FTL is still coherent in the NAND service area, the drive may re-enumerate long enough to be imaged over SATA at the logical layer. That image is then processed on a separate workstation. FTL damage that the controller itself cannot reconcile on boot is currently not recoverable on the 870 EVO generation through any published PC-3000 path. Free evaluation confirms whether a given drive falls into the recoverable or non-recoverable bucket ($600–$1,200 firmware-tier on successful stabilization).
How We Recover Data from Degraded Samsung V-NAND
No published PC-3000 technological-mode path covers the 870 EVO generation. The PC-3000 SSD recovery path for the MKX is therefore normal-mode imaging after hardware stabilization, not loader-based firmware rewrites. The goal is to get the original controller booting cleanly so its own LDPC engine can deliver as many blocks as possible over SATA.
- 01
Hardware stabilization on the test bench
The drive is powered on the PC-3000 SSD test bench with SATA link power management disabled and host timeouts extended. Power rails are checked against datasheet expectations; any shorted or sagging rail is repaired at the board level (PMIC, DC-DC inductors, decoupling caps) before any imaging attempt. The PC-3000 bench never asserts HIPM, DIPM, or DevSleep, which removes the host-side LPM failure surface described later.
- 02
Extended retry imaging for marginal LBAs
For LBAs that fail on standard reads, the bench issues repeated reads with extended per-command timeouts, giving the MKX's on-chip LDPC decoder more time to complete soft-decision decoding. Sectors that remain unreadable after the retry budget are logged as bad and the image is delivered with those gaps marked for filesystem-level handling.
- 03
Image assembly and file verification
The recovered sectors are assembled into a full drive image. File system analysis extracts the directory structure and verifies file integrity. Files are delivered on your choice of return media via our mail-in service.
Samsung 870 EVO Hardware Encryption and Chip-Off Limitations
The MKX controller applies AES-256 hardware encryption to all data written to NAND, even without BitLocker or Samsung's software encryption enabled. If the controller dies, the NAND holds only ciphertext.
Chip-off (desoldering the NAND packages and reading them with a raw NAND reader) is not a recovery option for the 870 EVO. The binary dumps yield only AES-256 ciphertext without the controller's key. Board-level repair to revive the original MKX controller is the only path to data. For broader Samsung SSD recovery procedures, including other controller families, see our Samsung hub page.
Samsung MKX Controller Firmware Failure Modes
The MKX controller has four distinct firmware-visible failure modes. No published technological-mode path covers this generation, so the repair path is different from the older Samsung SATA controllers PC-3000 SSD supports. Identifying the mode determines whether the case falls into the $600–$1,200 firmware tier on successful stabilization, the $450–$600 board repair tier, or is currently not recoverable.
- FTL Corruption
The Flash Translation Layer maps logical block addresses to physical NAND locations. When the FTL becomes inconsistent, the drive reports wrong capacity or 0 bytes. Unlike older Samsung SATA generations, the 870 EVO does not expose a supported firmware-level FTL rebuild path in PC-3000 SSD; recovery depends on whether the controller, once hardware-stabilized, can reconcile its own FTL from redundant copies in the NAND service area on boot. When it can, normal-mode imaging proceeds; when it cannot, the case is generally not recoverable today.
- ROM Corruption
The ROM region stores the controller's boot code and drive identity. When this region is corrupted, the MKX may report a generic model string (e.g., "Samsung SSD" instead of "Samsung SSD 870 EVO 2TB") or fail to present valid identity data. The drive can appear in BIOS but be inaccessible to the OS. With no published loader for this generation, the 870 EVO does not have a user-serviceable ROM reflash path through PC-3000; recovery depends on stabilizing the original controller at the board level. Cases where the ROM itself is damaged are generally not recoverable with tools publicly available today.
- Module Corruption
Individual firmware modules (S.M.A.R.T. tables, bad block management maps, wear leveling configuration) can corrupt independently of the main firmware. A corrupted bad block table causes the controller to read garbage from remapped sectors; a corrupted wear leveling map concentrates writes on a subset of NAND blocks. On the MKX, whether the drive survives this depends on the controller's own boot-time integrity checks and redundant module copies in the service area. When the controller recovers on boot, normal-mode imaging yields data; when it cannot, this class of failure is generally not recoverable without vendor-level tooling that is not commercially available.
- Controller Lockout
After accumulating too many uncorrectable errors or a firmware exception loop, the MKX may stop responding to ATA commands, time out during POST, or fail to appear in BIOS. On the test bench the drive is powered with SATA link power management disabled and extended timeouts so host-side aggression is removed from the equation. If the controller has a shorted power management IC (PMIC) or a failed passive, we locate the failure using a FLIR thermal camera and replace the component with a Hakko FM-2032 on an FM-203 base station. Once supply is clean and the controller boots on its own, imaging proceeds in normal mode.
Board Repair as Data Recovery
When the MKX controller itself is dead rather than firmware-corrupted, the case shifts from firmware recovery to board-level repair ($450–$600). The AES-256 encryption key lives on the controller silicon. A dead controller means the NAND is ciphertext. Replacing the controller with a new one doesn't work; the new chip has a different key.
The only path: revive the original controller. We use FLIR thermal imaging to pinpoint the failed component on the PCB, then replace it with Hakko FM-2032 microsoldering. Once the original controller boots, the encryption keys are intact & the data is accessible. Board repair isn't a separate service from data recovery for encrypted SSDs; it is data recovery.
For a full breakdown of SSD recovery pricing across all tiers, see our cost page.
What Is Inside the Samsung MKX Controller?
The MKX (internal designation Samsung S4LR059) is an ARM Cortex-R4 processor fabricated on Samsung's 14nm FinFET process. It manages 8 flash channels with 8 chip enables per channel, striping data across every NAND package on the PCB. That 8-channel interleave is why chip-off on an 870 EVO yields fragments from multiple packages rather than sequential files.
The MKX allocates LPDDR4 DRAM as a write cache & FTL mapping buffer. Capacity scales with the drive: 512MB of DRAM on the 250GB & 500GB models, 1GB on the 1TB, 2GB on the 2TB, and 4GB on the 4TB. The working FTL lives in this DRAM. Power loss before the controller flushes DRAM contents to NAND is what causes the FTL corruption described in the section above.
MKX vs. MJX: What Changed from the 860 EVO
The MJX controller (860 EVO) uses the same ARM Cortex-R4 architecture. Both run AES-256 Class 0 hardware encryption with TCG Opal 2.0 & IEEE 1667 support. The difference is the ECC engine. MJX was calibrated for Samsung's 64-layer (V4) & 96-layer (V5) V-NAND. MKX ships with a refined LDPC decoder tuned for the 128-layer (marketed) & 136-layer (actual) Gen-6 V-NAND stacking.
This matters for recovery triage. The older Samsung SATA drives on ACELab's PC-3000 SSD list, the 840 EVO and 850 PRO on MEX silicon, have a published firmware-level rebuild path. The MKX in the 870 EVO has none, so the practical triage question on an MKX is not "which image to reflash" but "can the original controller be hardware-stabilized long enough for a normal-mode image."
How Does Samsung V-NAND Physically Degrade?
Samsung's V-NAND uses Charge-Trap Flash (CTF) instead of the floating-gate design found in older planar NAND. CTF stores electrons in a non-conductive silicon nitride insulator rather than a conductive polysilicon floating gate. A single oxide defect in CTF doesn't drain the entire stored charge the way it does in floating-gate cells. That's the advantage. The failure modes are different too.
- Early Retention Loss (Lateral Electron Migration)
In 3D CTF, the silicon nitride trap layer is continuously connected across vertically stacked layers. Electrons stored in the nitride migrate laterally through the shared insulator, causing the threshold voltage (Vth) of programmed cells to drift over time. This isn't a P/E cycle problem; it happens even on cells with low write counts. The 870 EVO's 136-layer stack height increases the surface area of shared nitride, increasing the lateral migration path length & the resulting Vth drift rate.
- Tunnel Oxide Trapping
Every erase cycle uses Fowler-Nordheim tunneling to clear the charge trap. During tunneling, electrons pass through the thin tunnel oxide layer. Some get stuck in trap states within the oxide itself instead of reaching or leaving the silicon nitride. Over accumulated P/E cycles, these oxide-trapped electrons shift the cell's baseline Vth upward, narrowing the voltage margins between TLC's 8 programmed states.
- Read Disturb
Reading a single word line requires applying a pass voltage (Vpass) to all unselected word lines in the same block. Vpass is high enough to keep those cells conducting without reading them, but it also nudges electrons in the trap layer. Over thousands of reads, the cumulative Vth shift from Vpass stress pushes cells into adjacent voltage states. On an 870 EVO used as a boot drive with constant OS reads, read disturb accelerates the degradation timeline.
Where This Meets Recovery
All three mechanisms cause the same end result: Vth distributions of the 8 TLC voltage states start overlapping. When overlap exceeds the MKX controller's LDPC correction ceiling, the read fails as an uncorrectable error. With no published technological-mode path on the 870 EVO, the practical recovery path is not vendor read-retry issued from the host; it is extended-timeout normal-mode imaging that lets the controller's own on-chip LDPC decoder spend more time on each sector before giving up.
S.M.A.R.T. Attributes That Matter for Early Detection
These are the S.M.A.R.T. attributes that give the earliest warning of the 870 EVO degradation pattern. Check the raw values, not Samsung's normalized health percentage.
| Attribute | ID | What It Tracks | Warning Threshold |
| Reallocated Sector Count | 5 | NAND blocks remapped to spare pool | Any non-zero raw value on a new drive |
| Uncorrectable Error Count | 187 | Reads that exceeded LDPC correction | Rising count over days (back up immediately) |
| Hardware ECC Recovered | 195 | Reads that required ECC intervention | Spike relative to drive's own baseline |
| Used Reserved Block Count | 179 (0xB3) | Spare-pool blocks consumed to back bad user-area blocks; distinct from attribute 5, which counts LBA-level reallocations rather than spare blocks spent | Rising raw value at any rate, since spare pool exhaustion precipitates FTL collapse |
Samsung 870 EVO Symptom-to-Root-Cause Diagnostic Reference
Different symptoms point to different hardware root causes, and each root cause requires a different recovery approach & falls into a different pricing tier. Use this table to identify the probable hardware failure mode based on diagnostic symptoms.
| Symptom | S.M.A.R.T. Indicator | Root Cause | Recovery Approach | Typical Tier |
| Slow transfers, intermittent freezes | Rising Attr 187 & 195 | V-NAND early retention loss; Vth drift exceeding soft-decode margin | Extended-timeout normal-mode imaging | $600–$1,200 |
| BIOS freezes on boot; drive causes POST hang | S.M.A.R.T. inaccessible (drive in BSY state) | MKX controller FTL panic; firmware exception loop | Hardware stabilization & extended-timeout normal-mode imaging | $600–$1,200 |
| 0 bytes or RAW in Disk Management | S.M.A.R.T. returns all zeros or generic model string | FTL mapping collapse; controller entered protective mode | Generally not recoverable without vendor-level tooling | $600–$1,200 |
| Drive not detected at all (no BIOS, no Disk Management) | N/A (drive doesn't respond to any command) | PMIC failure or shorted component on PCB | FLIR fault localization & Hakko FM-2032 component replacement | $450–$600 |
| Bricked after Samsung Magician firmware update | N/A (drive unresponsive post-update) | ROM or module corruption during interrupted flash | Board-level stabilization; generally not recoverable if ROM itself is damaged | $600–$1,200 |
Free evaluation determines the exact failure mode & tier. No diagnostic fees. Call (512) 212-9111 or submit your case online.
How Do SATA Link Power Management Bugs Affect the 870 EVO?
Separate from NAND degradation, the Linux kernel carries an explicit quirk (ATA_QUIRK_NO_NCQ_TRIM) for the Samsung 860 and 870 families because queued asynchronous TRIM can trigger a firmware panic that the host sees as a port reset cascade. Aggressive host-initiated or device-initiated SATA Link Power Management (HIPM/DIPM) and DevSleep can compound the symptom. To the operating system the drive appears to drop off the bus mid-operation, producing I/O errors or a read-only filesystem remount.
Why Link-Layer Aggression Exposes the 860/870 EVO
When the host issues queued asynchronous TRIM alongside normal I/O, the drive's firmware can throw an exception, the ATA port goes into error-handling, and the kernel issues hard resets. The Linux kernel ships an explicit quirk for this family, ATA_QUIRK_NO_NCQ_TRIM, which forces TRIM to non-queued so the failure never occurs. Aggressive host-initiated or device-initiated power management (HIPM/DIPM) on top of an already-fragile queued path makes the same symptom more likely to appear under light idle workloads.
This is why the same 870 EVO that tested fine in an external USB-to-SATA dock can drop offline when connected internally to a desktop motherboard or laptop AHCI port. USB-to-SATA bridges typically translate host I/O into simpler non-queued SCSI commands and do not implement HIPM/DIPM or pass queued TRIM through, so the firmware path that triggers the kernel resets is never exercised.
Symptoms That Point to LPM, Not NAND
- I/O errors that stop when you disable DIPM or NCQ TRIM
If setting the Windows power plan's SATA link state to "Active" (which disables HIPM/DIPM), or passing
libata.force=noncqtrimon a Linux kernel command line, makes the dropouts disappear, the root cause is link-layer or queued-TRIM handling, not the NAND. The data on the drive is intact; the link is the failure surface.- Kernel log entries showing link resets and hard resets on one SATA port
Linux dmesg output containing "ataN.00: exception Emask" followed by "ataN: hard resetting link" and "failed command: WRITE FPDMA QUEUED" or "SEND FPDMA QUEUED" on a Samsung 860/870 EVO is the signature of the NCQ TRIM firmware exception. The kernel mitigates this with the
ATA_QUIRK_NO_NCQ_TRIMlibata quirk, which forces TRIM to non-queued. After the reset the drive re-enumerates, but the filesystem may have already remounted read-only to protect against further corruption.- Drive enters read-only mode after a short period of idle time
If the drive responds normally for the first few minutes of a session and only starts dropping after the system has been idle long enough for Slumber or DevSleep to engage, the failure is LPM-triggered. A drive that failed during sustained heavy writes is a different failure class (NAND wear or FTL overflow) covered earlier on this page.
Recovery Workflow for an LPM- or NCQ-TRIM-Locked 870 EVO
When an 870 EVO arrives in read-only or repeated-dropout state, the drive is moved off the original host entirely. On the PC-3000 SSD test bench (or an imaging bench with a controller that supports AHCI with LPM disabled), the link-layer aggression that triggered the firmware exception is removed from the equation:
- Power the drive with SATA link power management disabled and with NCQ TRIM suppressed. On Linux this is how the
ATA_QUIRK_NO_NCQ_TRIMquirk is applied in the wild; on a PC-3000 bench, the equivalent configuration is set at the bench controller so queued TRIM is never issued and HIPM/DIPM are not negotiated. - Verify board-level supply rails before any imaging attempt. A drive that drops offline intermittently sometimes does so because a PMIC or capacitor is marginal rather than because of a pure link-layer issue. Rails out of spec are repaired (Hakko FM-2032 on FM-203, Zhuo Mao for BGA work) before the next imaging pass.
- Image the user area in normal mode over SATA with extended per-command timeouts. Timeouts give the MKX's on-chip LDPC decoder time to complete soft-decision decoding on sectors in early retention loss.
- After imaging, the raw image is mounted on a separate workstation for filesystem-level processing. No further reads are issued against the source drive.
A link-layer lockout (LPM-triggered or NCQ-TRIM-triggered) on an 870 EVO with an otherwise healthy NAND array falls into the firmware tier on successful stabilization ($600–$1,200), because the fix is removing host-side aggression and imaging in normal mode rather than rewriting firmware. If the underlying cause turns out to be NAND degradation that was masked by the link-layer symptom, the case moves to the intensive imaging tier ($1,200–$1,500). If the controller itself is dead or the internal FTL cannot reconcile on boot, the case is generally not recoverable today. Free evaluation identifies which bucket applies before any paid work starts. Rush service is available: +$100 rush fee to move to the front of the queue.
Bench-Level Diagnostic Workflow for an 870 EVO in BSY Lockout
When an 870 EVO arrives that hangs the host motherboard during POST or returns a generic identity string, the first job at the bench is determining which of three hardware states the controller is locked in. Same host symptom; three different root causes; three different repair paths.
870 EVO Media-Integrity S.M.A.R.T. Attributes
The 870 EVO is a SATA drive and uses the ATA command set. The failure metrics that map to media-integrity events live in standard ATA S.M.A.R.T. attributes, all readable from the PC-3000 SSD bench's raw S.M.A.R.T. dump:
- Attribute 0x05 (decimal 5): Reallocated Sector Count, the number of NAND blocks remapped to the spare pool.
- Attribute 0xBB (decimal 187): Uncorrectable Error Count, reads that exceeded the MKX's LDPC ceiling.
- Attribute 0xC3 (decimal 195): Hardware ECC Recovered, the count of on-the-fly LDPC corrections.
- Attribute 0xFC (decimal 252): Newly Added Bad Flash Block, the count of total bad blocks since manufacture. CrystalDiskInfo surfaces this raw value.
Is the MKX BSY State the Same as the Seagate F3 BSY Bug?
No. The Seagate F3 BSY bug on Barracuda 7200.11 drives was a S.M.A.R.T. event-log counter overflow that trapped the controller in a diagnostic loop, ignoring the SATA interface entirely. The fix was a serial-port command sequence to clear the log. The Samsung MKX BSY pattern is mechanically different. It is an FTL panic or a protective controller lockout, not a log-counter overflow.
The controller needs free spare blocks to update the FTL with new bad-block reallocations; when both the user area and the spare pool are exhausted, the controller cannot reconcile the logical-to-physical mapping and halts during initialization. On the host side this looks like a permanent BSY assertion: the motherboard's SATA controller waits for BSY to drop, eventually times out, and either declares the port empty or surfaces a generic identity string like "SSD 1TB" instead of "Samsung SSD 870 EVO 1TB."
Three BSY Root Causes the PC-3000 SSD Bench Can Distinguish
- BSY from Power Rail Failure
The PMIC outputs are probed against datasheet expectations (typically 3.3V host rail with internal 1.8V and 1.2V regulation). A FLIR thermal camera is pointed at the powered PCB; a shorted MLCC or PMIC channel shows up either as a localized hotspot or, if the short is severe enough to fold the upstream rail, as a controller die that stays cold because it never received clean supply. The fix is component-level: identify the failing passive or PMIC channel, replace it on the bench with a Hakko FM-2032 on an FM-203 base station, retest rails before applying full power again. This case falls into the $450–$600 board repair tier.
- BSY from NAND Bus Fault
Power rails are within spec. The bench's current-monitoring oscilloscope shows the controller drawing normal boot current, but the drive never asserts DRDY. The controller is booting, attempting to read its main firmware modules from the NAND service area, and failing because one or more NAND packages have lost electrical contact (cracked BGA joints from thermal stress, a fractured ball under the controller package itself, or a NAND die that has died electrically). The repair path is inspection and reflow with a Zhuo Mao precision BGA station, not firmware work.
- BSY from FTL Panic (Firmware Corruption)
Power rails are nominal, NAND is responsive, and the current trace shows the controller drawing dynamic boot current that climbs as the processor initializes, then flatlines at a high idle level when the firmware traps into an exception loop. BSY never clears. The controller has booted into its own firmware, encountered an unresolvable FTL state (post-power-loss FTL inconsistency or accumulated uncorrectable ECC events that pushed the controller into protective lockout), and refused to expose the user area. With no published technological-mode path on the MKX generation, this case is recoverable only if the controller, after a full bench-controlled power cycle with link power management disabled, reconciles its own FTL from redundant copies in the NAND service area and re-enumerates long enough for normal-mode imaging. When it does not, the case is generally not recoverable today.
What PC-3000 SSD Commands Work on the MKX Without Technological Mode?
PC-3000 SSD publishes no Vendor Specific Command (VSC) loader-injection path for the MKX, unlike the older Samsung SATA drives on ACELab's list (the 840 EVO and 850 PRO, MEX silicon). What remains is normal-mode ATA control with precision the OS does not permit. The bench operations we still rely on:
- Extended ATA Identify (opcode 0xEC): the bench captures the full 512-byte response block on every power cycle, even when the drive only briefly enumerates before dropping. Comparing the model string, firmware revision, and native max LBA against the expected values for the customer's drive confirms whether the service-area identity tables loaded correctly.
- Raw S.M.A.R.T. read (opcodes 0xB0/0xD0): dumps the full attribute table including the vendor-specific entries Samsung Magician hides behind its normalized health percentage. Attribute 0xFC and the raw Reallocated Sector Count tell us whether degradation is broad or concentrated before a single read is issued against the user area.
- Link-layer overrides: HIPM and DIPM are forced off, DevSleep is suppressed, and the SATA PHY is held in active state. This removes the power-management failure surface that exposes the documented NCQ TRIM exception in the kernel's
ATA_QUIRK_NO_NCQ_TRIMquirk. - NCQ disable (queue depth = 1): commands are issued one at a time on a non-queued path. A controller already strained by ECC retry on degraded V-NAND cannot survive a host that pipelines 32 outstanding commands; serializing the I/O keeps the controller out of the FPDMA Queued exception path that the Linux kernel logs as
READ FPDMA QUEUEDerrors. - Extended-timeout normal-mode imaging with per-LBA retry budgets:each ATA read is allowed to run far longer than an OS would tolerate, giving the MKX's on-chip LDPC engine time to soft-decision-decode marginal cells. Sectors that still fail are deferred and retried in later passes when surrounding read-disturb pressure has lowered. A soft SATA reset is issued on hangs rather than a hard link reset, so the controller stays in normal mode instead of dropping back to its boot path.
Donor PCB Matching: What the Donor Is Actually For
The MKX applies AES-256 hardware encryption to every block written to NAND. The legacy donor-PCB swap used on unencrypted controllers (transplant the NAND packages onto a donor board with a fresh controller and boot from there) does not work on the 870 EVO. The original controller has to survive and boot for any data to come off the drive.
The donor PCB's role is restricted to component salvage. When an 870 EVO arrives with a shorted PMIC channel, a blown TVS diode from a power surge, a cracked decoupling capacitor, a failed crystal oscillator, or a step-down converter that has folded under thermal stress, a working donor of the same hardware revision provides a known-good source for the failed component. The repair is performed on the customer's original PCB so the original controller (and its key) stays in the loop.
Donor matching constraints we apply when sourcing:
- Same capacity tier. The 250GB/500GB, 1TB, 2TB, and 4TB 870 EVO models use different PCB revisions and DRAM sizes (512MB up to 4GB), which changes the power-rail architecture and PMIC pinout.
- Same PCB silkscreen revision. The silkscreen identifier on the donor must match the customer's drive so component reference designators line up.
- Firmware revision is not a factor for passive component salvage.A donor on a different firmware revision can still supply a PMIC, because the firmware lives in the NAND on the customer's drive, not on the harvested component.
How a Failed Samsung Magician Update Bricks the MKX
When Samsung Magician applies a firmware update, the new microcode is written into the controller's firmware service area in the NAND, and the bootloader pointers are updated so the next power-on loads the new image.
An interrupted firmware write leaves the drive in one of three host-visible states:
- Drive disappears from BIOS/UEFI entirely (the controller's ROM bootloader fired but failed checksum on the partial image and refused to expose the SATA interface).
- Drive enumerates with a generic manufacturing identity string and a near-zero capacity (the ROM bootloader fired, could not load the main firmware module, and presented an emergency identity).
- Drive enumerates correctly, but Disk Management reports a RAW file system and File Explorer hangs on access (the controller booted, but service-area metadata that backs the FTL is corrupted, so logical reads return garbage).
With no published technological-mode path, third-party recovery tools cannot push a clean firmware image back onto a bricked MKX. The recoverable subset of these cases is the third bullet (drive enumerates, FTL is partially intact): the controller, once stabilized at the bench with link power management disabled and NCQ off, sometimes reconciles enough of its FTL from redundant service-area copies to allow normal-mode imaging. The first two bullets, where the drive cannot expose a working SATA interface at all, are generally not recoverable today on this generation. Free evaluation determines which bucket applies before any paid work.
How Much Does Samsung 870 EVO Recovery Cost?
Samsung 870 EVO firmware-tier recovery: $600–$1,200. If extensive multi-pass imaging is required for heavily degraded NAND, the case may reach the $1,200–$1,500 tier (intensive imaging). Free evaluation and firm quote before any paid work. No data recovered means no charge.
The Samsung MKX controller uses hardware AES-256 encryption. Recovery requires the original controller to be functional, which means chip-off is not an option for these drives.
Rush service: +$100 rush fee to move to the front of the queue. Call (512) 212-9111 for a free evaluation.
Do Not Run Recovery Software on a Failing 870 EVO
Consumer recovery software (Disk Drill, EaseUS, Recuva, R-Studio) issues thousands of read commands across the entire drive surface. On a drive with degrading NAND, every read stresses the marginal cells. Each failed read triggers the controller's internal retry logic, adding heat and electrical stress to cells that are already failing.
Software scans also trigger background controller operations. The controller may attempt to relocate data from failing blocks to spare blocks. If the spare pool is exhausted, the controller may enter a protective lockout. Each background operation risks further corruption of the Flash Translation Layer. A drive that was recoverable before the software scan can become unrecoverable after it.
If your Samsung 870 EVO is showing any of the Stage 1 or Stage 2 symptoms described above, power down the drive. Do not run chkdsk. Do not run Samsung Magician diagnostics. Do not attempt to clone the drive with dd or Clonezilla. Send the drive for professional evaluation while the maximum number of NAND cells are still readable.
Can Data Recovery Software Recover a Samsung 870 EVO?
Data recovery software can recover a Samsung 870 EVO only when the drive is physically healthy and the problem is purely logical, such as an accidental deletion with TRIM disabled or a corrupted partition table. It cannot recover a drive that has dropped to 0 bytes, hangs the BIOS, reports a wrong capacity, or has entered a BSY panic. Once the controller stops presenting a coherent drive, there is nothing for host-side software to scan.
The tools that rank for "samsung ssd data recovery software" (Recuva, EaseUS, R-Studio, Samsung Magician, and similar) are logical-recovery tools. They read files back through the drive the way Windows or macOS does. That works on a live drive with an intact file system.
It stops working the moment the failure is physical, because host software runs on top of two layers it has no way to reach below. Our SSD data recovery lab work begins exactly where those tools end.
- The LBA / FTL abstraction boundary
Every host tool reads logical block addresses the MKX presents on top of its Flash Translation Layer. When the FTL collapses or the controller is stuck in BSY, that logical layer is gone, so the software has nothing to enumerate or scan. No host-side application can reconstruct a translation table that lives inside a controller that will not boot.
- The hardware AES-256 boundary
Software on the host cannot reach below the hardware AES-256 boundary; the full explanation of why chip-off does not work on an encrypted SSD is covered earlier on this page.
Why There Is No Loader-Based Fix for the MKX
People reach for software because they assume a professional tool can simply rebuild the firmware. ACELab's PC-3000 SSD support is stratified, not universal. It offers loader-based logical FTL rebuild on a range of third-party controllers, such as the Phison families and the Silicon Motion families, and on older Samsung SATA controllers (the S3C29, S4LJ, and S4LN families used in the 470, 830, and 840 generations).
Modern Samsung in-house controllers are not in that supported set. The 870 EVO's MKX (S4LR059) is a modern Samsung in-house controller, outside the PC-3000 supported-controller list per ACELab's matrix. That is the concrete reason there is no loader-based firmware or FTL-rebuild path for it, and why neither consumer software nor a vendor reflash repairs a panicked MKX.
Recovery here is not a tool-driven FTL rebuild. It is hardware stabilization of the original controller (repairing the power rails, PMIC, or shorted passives so the chip boots on its own) followed by extended-timeout normal-mode imaging over SATA.
The professional path is a free evaluation, no data and no recovery fee, and a firm quote before any paid work. Firmware-tier recovery on a stabilized MKX runs $600–$1,200. Free evaluation in our Austin, TX lab confirms which failure mode applies before anything is charged.
Why does my Samsung 870 EVO show 0 bytes?
The 0 bytes symptom on Samsung 870 EVO drives typically indicates severe NAND degradation or firmware failure triggered by accumulated uncorrectable ECC errors. When the controller encounters more bad blocks than it can remap, it may enter a protective state that reports 0 capacity. The data is still on the NAND cells, but the controller has lost the ability to read it through normal host commands.
How much does Samsung 870 EVO data recovery cost?
Samsung 870 EVO firmware-tier recovery costs $600–$1,200. If the case requires intensive multi-pass imaging to extract data from heavily degraded NAND, it may fall into the $1,200–$1,500 tier. Free evaluation and firm quote before any paid work. No data recovered means no charge.
Should I run data recovery software on my failing 870 EVO?
No. Running recovery software on a drive with degrading NAND forces the controller to repeatedly attempt reads on failing cells. Each failed read stresses the surrounding cells and can trigger garbage collection or reallocation that destroys additional data. Power down the drive and send it for professional evaluation. The fewer read cycles on degrading NAND, the more data survives.
How long does Samsung 870 EVO recovery take?
Firmware-tier cases take 3-6 weeks. Intensive multi-pass imaging of degraded NAND with extended per-command timeouts can extend the timeline depending on how many LBAs require repeated attempts before the controller returns them. Rush service is available: +$100 rush fee to move to the front of the queue.
Can data be recovered after a failed 870 EVO firmware update?
A failed firmware update usually corrupts the ROM or module area, not the user data NAND. The MKX controller's firmware resides in a separate NAND region from user data, so the cells that hold your files are typically unaffected. There is no published PC-3000 technological-mode path for the 870 EVO generation, so the fix is not a routine PC-3000 reflash. Recovery depends on board-level stabilization of the original controller (voltage rail and PMIC work) so the drive re-enumerates long enough for a normal-mode image. If the controller will not revive, the case escalates to board repair or is deemed not economically recoverable; free evaluation determines which applies.
Does the Samsung 870 EVO encrypt data by default?
Yes. The MKX controller applies AES-256 hardware encryption to all data written to NAND, even without BitLocker or Samsung's software encryption enabled. The encryption key is stored in the controller's secure area. Recovery requires the original controller to be functional. Chip-off (desoldering the NAND chips) yields only encrypted, unreadable data without the controller's key.
What is the difference between firmware recovery and NAND swap on an 870 EVO?
Firmware-tier work ($600–$1,200) covers cases where the original MKX controller can be stabilized through voltage-rail and PMIC repair so the drive re-enumerates long enough for a normal-mode image; there is no published PC-3000 technological-mode path for the 870 EVO generation, so this is not a VSC-based firmware rewrite. Board-repair-tier work ($450–$600) covers PCB component-level repair when passive components or rails have failed. When the controller silicon itself is dead, the AES-256 key is lost and the case is generally not recoverable, since chip-off yields ciphertext. Free evaluation determines which path applies. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers.
Why does my 870 EVO hang the BIOS during POST?
The MKX controller is locked in a BSY (busy) state. On the bench we distinguish three root causes: (1) a power-rail failure where a shorted PMIC channel or capacitor folds the supply (board repair tier); (2) a NAND bus fault where the controller boots but cannot read its firmware modules from the NAND service area (board reflow); (3) an FTL panic where the firmware traps into an exception loop because the drive ran out of spare blocks or the FTL is corrupted (firmware tier on successful stabilization, otherwise generally not recoverable today on this generation).
Can data recovery software read a Samsung 870 EVO with degraded NAND?
No. Recuva, EaseUS, and R-Studio run on top of the LBA abstraction the MKX controller has already lost. Once the FTL is corrupted, the controller either refuses to enumerate, hangs in BSY, returns zeroes under Deterministic Zeroes After TRIM, or drops into a throttled PIO-style safe mode at QD=1. Host-level software cannot bypass a controller in firmware panic, so the recovery has to move to board-level stabilization on the bench.
What is the difference between SMART attributes 5 and 179 on a Samsung 870 EVO?
Attribute 5 (Reallocated Sector Count) counts LBAs the controller has remapped after read failures; it grows whenever a user-area block fails ECC. Attribute 179 / 0xB3 (Used Reserved Block Count) counts the spare-pool blocks consumed to back those reallocations. The two attributes move together but measure different things. A drive with many reallocations and a low Used Reserved Block Count still has spare capacity; a drive where 0xB3 is climbing close to its maximum is approaching FTL exhaustion, and a controller that cannot allocate fresh spare blocks during garbage collection drops into a protective lockout (the BSY pattern described above). On the bench, both attributes are read from the raw SMART dump via ATA command 0xB0 with feature register 0xD0 (SMART READ DATA).
Does a low Wear Leveling Count on SMART 0xB1 mean my 870 EVO is safe?
Not by itself. SMART 0xB1 / attribute 177 tracks average P/E cycles across the NAND, and Samsung's normalized scale starts at 100 and decreases as the drive wears. It is a wear counter, so a drive can show a Wear Leveling Count normalized at 99 (effectively no wear) while attributes 5, 187, 195, and 252 are climbing. Cross-check 0xB1 against 0xFC (Newly Added Bad Flash Block) and the Uncorrectable Error Count to get the actual picture.
Related Samsung SSD Recovery Pages
Full SSD recovery service overview
Samsung controller-specific procedures
Controller families across all SSD brands
Diagnosis of 0-byte SSD symptoms
NAND degradation and wear-related failures
Firmware-level controller failures
Full SSD pricing breakdown by failure type
Samsung 870 EVO showing errors or 0 bytes?
Free evaluation. Firmware recovery: $600–$1,200. Intensive NAND extraction: $1,200–$1,500. No data, no fee.
