Transcend SSD Data Recovery
Transcend builds both consumer SSDs and industrial embedded storage for ATMs, POS terminals, medical devices, and digital signage. The consumer SATA lineup uses Silicon Motion SM2258 controllers (SSD230S, SSD220S). The NVMe MTE250H uses a Phison E21T controller. The industrial lineup (SSD460T, MTS570T, MSA370I) uses Silicon Motion controllers with wider temperature ratings and higher NAND endurance. We recover data from all Transcend SSD product lines.
SSD starting at $200 | No Data, No Fee | Free Evaluation | Since 2008
Transcend SSDs We Recover
SSD230S / SSD220S (SATA)
Silicon Motion SM2258 controller. 2.5-inch SATA. 3D TLC NAND. DRAM cache. Most common consumer Transcend SSD.
MTE250H (NVMe Gen4)
Phison E21T controller. M.2 2280. DRAM-less HMB design.
SSD460T / MTS570T / MSA370I (Industrial)
Silicon Motion controllers. Wide-temp rated (-40C to 85C). SLC and 3D TLC NAND. ATMs, POS, medical, kiosks.
SSD250N (M.2 2242 NAS)
Silicon Motion controller. M.2 2242 SATA. Designed for NAS caching. Compact form factor.
Consumer and industrial Transcend SATA SSDs recovered via PC-3000 SSD
8 min read
Transcend SSD Recovery
How Transcend SSD Recovery Works
PC-3000 SSD connects to Silicon Motion controllers through vendor-specific diagnostic commands, bypassing the normal storage interface. From there, we rebuild corrupted firmware modules, repair flash translation tables, and extract raw NAND contents when the controller cannot boot. We evaluate every drive for free, provide a firm quote, and charge nothing if we cannot recover your data.
Industrial SSD Failures in Embedded Systems
Transcend's industrial SSD lineup is designed for environments where consumer drives would fail within months. The SSD460T operates from -40C to 85C. The MTS570T uses SLC NAND rated for 60,000+ P/E (program/erase) cycles, compared to 1,000-3,000 cycles on consumer TLC. The MSA370I uses the mSATA form factor common in legacy embedded hardware. These drives ship with power loss protection circuitry and end-to-end data path protection.
Despite the engineering, industrial SSDs fail. The most common cause is NAND wear-out. An ATM logging thousands of transactions per day writes continuously to the same drive for three to five years. When the SLC NAND exhausts its write endurance, the controller starts relocating data to spare blocks. Once the spare pool is depleted, the controller either locks the drive into read-only mode (if the firmware supports it) or crashes entirely. POS terminals running SQL databases, medical devices recording patient telemetry, and kiosk systems writing access logs follow the same wear pattern.
The second failure mode in industrial applications is thermal cycling stress. A drive rated for -40C to 85C may survive individual temperature extremes, but repeated cycling between the two ends of that range causes solder joint fatigue on the NAND BGA packages and passive components. Outdoor kiosks, vehicle-mounted systems, and industrial control panels expose drives to daily thermal cycles that accelerate this failure mode.
SSD230S: SM2258 Firmware Corruption
The Transcend SSD230S is the most common consumer Transcend SSD we receive for recovery. It uses the Silicon Motion SM2258 controller paired with 3D TLC NAND and a DRAM cache. The SM2258 is also used in the older SSD220S and several other Transcend SATA models, so the SSD data recovery procedure is consistent across the product line.
The primary failure mode is firmware corruption from unclean shutdown. The SM2258 maintains a flash translation layer (FTL) that maps logical block addresses to physical NAND pages. When power is lost during a write operation, the FTL metadata on NAND becomes inconsistent. On the next boot, the controller detects the inconsistency and enters a BSY (busy) state: the drive briefly appears in BIOS with its correct model name, then becomes permanently unresponsive. The system may hang during POST if the drive remains connected.
PC-3000 SSD accesses the SM2258 through Silicon Motion's diagnostic interface. When the drive is in BSY state, the technician uses the SM2258 module to read the firmware region, identify the corrupted modules, and rebuild the FTL from page-level metadata in the NAND spare area. If the standard diagnostic interface fails (the controller does not respond at all), ROM mode entry via pin shorting on the SM2258 chip forces the controller into a low-level programming state where PC-3000 can reprogram the firmware from scratch.
SSD Pricing
Transcend SSD Recovery Pricing
SSD Recovery Calculator
Estimate Your Transcend SSD Recovery Cost
What type of SSD do you have?
Shomari Hohn
Aravind Udayakumar
David Dachenhaus (DDock)
Ludwig Jonsson
LaCie
MTE250H / E21T NVMe
MTE250H: Phison E21T NVMe Recovery
The Transcend MTE250H uses the Phison PS5021-E21T controller, the same silicon found in the Corsair MP600 Mini, Sabrent Rocket 2230, and Kingston NV2. The E21T is a 4-channel, DRAM-less NVMe Gen4 controller that relies on Host Memory Buffer (HMB) for FTL caching, meaning the mapping table lives partially in system RAM during operation.
A system crash or sudden power loss can leave the FTL in an inconsistent state because the HMB cache had not yet been flushed to NAND. The drive disappears from BIOS or shows as an uninitialized device.
The controller's proprietary scrambling and LDPC error correction leave a raw NAND dump unintelligible without the original controller, so chip-off (desoldering NAND) is not viable. The E21T is on ACELab's PC-3000 SSD supported list for firmware-level FTL rebuild; where the controller itself is electrically dead, board-level repair to restore it is the approach. Contact us for an honest assessment of your specific drive and firmware revision.
NAND Technology and Endurance
NAND Endurance: Why Industrial Drives Wear Out
Transcend's industrial SSD lineup uses two NAND types with different endurance characteristics. The MTS570T uses SLC (single-level cell) NAND, which stores one bit per cell and is rated for approximately 60,000 P/E cycles. The SSD460T and MSA370I use 3D TLC (triple-level cell) NAND, rated for 1,000 to 3,000 P/E cycles depending on the NAND generation.
SLC NAND lasts longer per cell, but Transcend's industrial SLC drives ship in lower capacities (64GB to 256GB typical). A 128GB SLC drive in an ATM writing 5GB of transaction logs per day reaches its endurance limit in roughly 4 to 5 years of continuous operation. The controller firmware tracks wear using SMART attributes (Media Wearout Indicator, Available Reserved Space). When spare blocks run out, the firmware has nowhere to relocate data from worn-out cells. The drive either enters read-only mode or the firmware crashes.
TLC industrial drives have lower per-cell endurance but higher capacity. The SSD460T in a POS terminal with a 512GB drive writing 10GB/day may last 3 to 4 years before the TLC cells degrade beyond the error correction threshold. Transcend implements a form of pseudo-SLC mode (sometimes marketed as SuperMLC) on some industrial TLC drives, writing one bit per cell to extend endurance at the cost of reduced usable capacity.
In all wear-out scenarios, the data stored on the NAND does not disappear when the cells degrade. The bits become less reliable to read, requiring more aggressive error correction. PC-3000 SSD reads the NAND at a low level with configurable read retry parameters, applying multiple voltage thresholds to extract data from degraded cells that the drive's own firmware could no longer read.
Controller Architecture Grid
Transcend SSD Controller Map
SSD230S: Silicon Motion SM2258
SATA 6Gbps. 4-channel with DRAM cache. 3D TLC NAND. XOR data scrambling. PC-3000 SSD Silicon Motion module. BSY state firmware repair and ROM mode pin shorting.
Gen4 NVMe x4. 4-channel. DRAM-less (HMB). M.2 2280. AES-256 encryption with controller-bound keys. Chip-off not viable. Board-level repair primary approach. HMB desync FTL corruption.
SSD460T: SM2258 Industrial
SATA 6Gbps. Wide-temp -40C to 85C. 3D TLC with pseudo-SLC mode. Power loss protection. Same PC-3000 recovery module as consumer SM2258 drives.
MTS570T: Silicon Motion
M.2 2242 SATA. SLC NAND. 60,000+ P/E cycles. Wide-temp rated. Industrial endurance for ATM and POS applications. Silicon Motion diagnostic module via PC-3000.
MSA370I: Silicon Motion
mSATA form factor. Industrial grade. Used in legacy embedded hardware, thin clients, and network appliances. Same Silicon Motion recovery procedures.
SSD250N NAS: SM2258
M.2 2242 SATA. Designed for NAS SSD caching in Synology and QNAP units. 3D TLC with DRAM. Standard SM2258 recovery via PC-3000.
XOR Scrambling and Chip-Off Limitations
Data Scrambling and Recovery Limitations
Transcend SATA SSDs using Silicon Motion controllers apply hardware XOR data scrambling to all NAND writes. This is not encryption in the cryptographic sense; it is a reliability feature that distributes bit patterns evenly across NAND cells to prevent charge coupling between adjacent cells.
For recovery purposes, this means desoldering NAND chips and reading them on a standalone programmer (chip-off) produces scrambled data. Reversing XOR scrambling is possible but difficult and time-consuming. PC-3000 SSD is the preferred approach because it accesses data through the controller itself, where descrambling happens automatically. When the controller firmware is corrupted, PC-3000 repairs the firmware first, then reads data through the restored controller interface.
Transcend NVMe SSDs using Phison E21T add a separate layer: AES-256 hardware encryption with keys generated on and bound to the original controller. Even if the XOR scrambling were reversible, the AES encryption remains. Board-level repair to restore the original controller is the only viable approach when Phison firmware-level access fails.
Transcend SSD Recovery FAQ
My Transcend SSD230S stopped showing up after a power outage. Can you recover it?
The SSD230S uses the Silicon Motion SM2258 controller. Power loss during a write operation can corrupt the firmware and flash translation layer, causing the drive to enter a BSY (busy) state where it briefly identifies then locks. PC-3000 SSD accesses the SM2258 through its diagnostic interface to rebuild the firmware and extract data from NAND. Firmware-level recovery on SM2258 drives is listed as $600–$1,200.
Can you recover data from a Transcend industrial SSD used in an ATM or POS terminal?
We recover data from Transcend industrial SSDs including the SSD460T (SATA, wide-temp), MTS570T (M.2, SLC), and MSA370I (mSATA). These drives fail from NAND wear-out after exceeding their rated write endurance under continuous transaction logging workloads. Industrial Transcend SATA SSDs use Silicon Motion controllers, so the recovery process uses the same PC-3000 SSD module as consumer Transcend SATA drives. Recovery is listed in the SATA SSD tiers from $200 to $1,200–$1,500 depending on failure severity.
How much does Transcend SSD data recovery cost?
Transcend SSD recovery pricing follows our published SATA SSD tiers (most Transcend drives are SATA): simple-copy $200, file-system From $250, PCB $450–$600, firmware $600–$1,200, PCB/NAND swap $1,200–$1,500. For NVMe drives such as the MTE250H: simple-copy $200, file-system From $250, PCB $900–$1,200, firmware $900–$1,200, PCB/NAND swap $1,200–$2,500. Free evaluation with no diagnostic fees. No data, no fee guarantee on every recovery.
Is chip-off recovery possible on Transcend SSDs?
Chip-off viability depends on the controller. Transcend SATA SSDs using Silicon Motion SM2258/SM2259 controllers apply hardware XOR data scrambling to all NAND writes. XOR scrambling complicates chip-off reads but does not make them impossible; controller-level recovery via PC-3000 is still preferred because it is faster and more reliable. Transcend NVMe models using Phison E21T implement AES-256 encryption with controller-bound keys, making chip-off not viable on those drives. Board-level repair is the fallback when the controller silicon fails.
My Transcend industrial SSD shows SMART warnings for worn-out NAND. Can you still recover data?
SMART warnings for NAND wear (Media Wearout Indicator below threshold, reallocated sector count rising) mean the flash cells are degrading but the controller is still functional. This is the best time to recover data, before the controller firmware runs out of spare blocks and locks the drive into read-only mode or fails entirely. PC-3000 images the drive at the sector level, working around bad blocks. Wear-related recovery on functional drives is listed in the simple-copy tier $200 or the file-system tier From $250.
What is the difference between recovering consumer and industrial Transcend SSDs?
For SATA models, the recovery tools and procedures are identical. Both consumer and industrial Transcend SATA SSDs use Silicon Motion controllers accessed through the same PC-3000 SSD module. The difference is in the failure patterns: consumer drives fail from firmware corruption after power loss, while industrial drives fail from NAND wear-out after years of continuous write operations in embedded systems. Industrial drives use wider temperature range components, but the NAND flash and controller recovery interface are the same.
Send Us Your Transcend SSD
Free evaluation. Firm quote. No data, no fee. Consumer or industrial, SATA or NVMe. Ship your Transcend SSD to our Austin lab.
