SMR Secondary Translator: Why a Drive Reports 0 Capacity
Why does an SMR drive report 0 bytes after power loss?
An SMR drive keeps a secondary translator that maps host addresses to the shingled bands. If that map is orphaned during a garbage-collection cycle, the drive still spins up & reports full capacity, yet every sector reads back 0x00. The platters keep the data; the index that locates it is gone.
This is a firmware failure, not a mechanical one. The drive is not clicking, the heads are fine, & the model & capacity report correctly to the host. What broke is the address map that only SMR drives carry. The sections below cover what that secondary translator does, why its corruption imitates a dead drive, & what a lab does to read the platters underneath it.
What Is the SMR Secondary Translator?
The secondary translator is an indirection table unique to SMR drives. It sits below the normal translator & tracks where each logical block physically lives right now. A CMR drive has no equivalent layer.
On an SMR drive, two mapping layers work together. Understanding the split is what separates a repairable firmware case from a misdiagnosed dead drive.
- Primary translator
- Resolves a host logical block address to a physical block, the same role the single translator fills on a CMR drive.
- Secondary translator (T2)
- The SMR-only indirection table. It records where each logical block currently sits in the shingled bands, & the firmware updates it every time garbage collection rewrites a band.
Each manufacturer stores this layer differently, which is why one family's recovery workflow does not transfer to another.
| Manufacturer / Family | Secondary Translator Storage |
| Western Digital DM-SMR (Spyglass, Palmer, EFAX Red family) | Module 190, labeled the T2 translator inside PC-3000 |
A CMR drive has one translator: a direct logical-to-physical map modified only by dynamic defect reallocation through the P-list & G-list. There is no second map to orphan, so the power-loss event that zeroes an SMR drive has no equivalent to corrupt on a CMR drive. The mechanical parts are built alike; how CMR and SMR recording differ is a firmware-layer distinction, not a platter one.
Why Does a Corrupted SMR Translator Look Like a Dead Drive Reporting 0 Capacity?
The drive spins up, identifies with its correct model, & reports full capacity, because those values live in a firmware area the corruption never touched. Every User Area sector still returns 0x00, because the logical-to-physical map was orphaned when power dropped mid garbage collection. Standard imaging captures a blank clone.
Power loss during garbage collection is the usual trigger. The firmware is partway through rewriting a shingled band & updating the secondary translator when the rails drop.
On the next boot the drive finds a translator that no longer points at valid physical blocks, so it presents an empty address space rather than wrong data. The model string & capacity come from the ROM & adaptive modules, which is why the host sees a healthy-looking drive with nothing on it.
This is distinct from a mechanically dead drive. A failed head stack clicks or beeps, & a seized spindle will not spin at all; neither will identify a clean capacity to the host. An SMR translator failure passes a basic SMART read & sounds normal, which is exactly why customers & general-purpose labs mistake it for accidental deletion or a bad format. The WD SMR translator failure pattern is the textbook version of the all-zeros case. A lab with Service Area firmware tooling reaches this case; a shop that only runs host-level imaging hands back the same blank clone the customer already made. Firmware-layer capability is the first thing to check when comparing hard drive recovery labs.
Why Does a Write-Blocker Not Protect an SMR Drive?
A SATA write-blocker stops host writes only. It cannot halt the drive's internal background garbage collection, because the drive's own microcontroller runs it with no host command involved. Left idle under power, a drive with a corrupted secondary translator keeps rewriting its shingled bands.
The mistake is treating an SMR drive like any other bad-sector case: attach a write-blocker, start a clone, walk away. The blocker suppresses ATA write commands from the operating system, so it does prevent the host from changing anything. It has no visibility into the firmware. Every second the platters spin, the drive can rewrite shingled bands & the very translator you are trying to save.
The protection that works is a firmware-level lock. On Western Digital drives that means issuing the Service Area command to lock User Area writing before the power-on sequence completes; on other families it means engaging PC-3000 hardware write protection before the spindle stabilizes. That lock freezes the background firmware processes, not just the host bus, so no imaging tool should touch the host LBA space until it is in place. On a suspected SMR case that means leaving the drive powered off and shipping it to the Austin lab rather than re-attempting a clone.
Does TRIM Apply to SMR Hard Drives?
Yes, on Drive-Managed SMR. These drives accept the ATA DATA SET MANAGEMENT command with the TRIM bit set, & the firmware treats it as permission to drop the secondary-translator entry for those addresses. The deleted-until-overwritten assumption that holds on a CMR drive doesn't reliably hold here.
Nothing gets erased. The magnetic domains stay on the platter as written; what changes is that the firmware stops resolving those logical addresses to the band holding them, & the band becomes eligible for reclamation the next time background cleaning runs. The reclaim schedule lives inside the firmware & is not exposed over ATA, so there is no interval you can wait out.
Drives that advertise deterministic read zero after TRIM return 0x00 for the trimmed range, which is why standard software reports an empty region instead of file remnants. That flag is a per-drive capability, so check what the drive reports rather than assuming it. The command semantics are the same ones covered in what a TRIM command does to deleted data; the difference on a mechanical drive is that the platter still carries the magnetization after the map entry is gone.
A CMR drive behaves the way most people expect. Its translator is a direct logical-to-physical map modified by dynamic defect reallocation through the P-list & G-list, not by host delete signals, so a deleted file keeps resolving to the same physical sector until something writes over it. That is the assumption behind file-undelete tools.
If smartctl reports Data Set Management TRIM support on a mechanical drive, treat it as one practical DM-SMR indicator alongside the model-number lookup on the manufacturer spec sheet, which is what the recording-technology comparison works through family by family.
Over USB the outcome depends on the enclosure's bridge, & you can't assume either behavior for a given product without testing it.
| USB Bridge Behavior | What Reaches the Drive |
| UASP bridge that passes SCSI UNMAP through | The delete or quick format reaches drive firmware, & the secondary-translator entry is dropped the same way it would be over a direct SATA connection |
| Bulk-Only Transport bridge with no UNMAP passthrough | The invalidation never reaches the drive, so the secondary translator keeps the old mapping & a straight image can still capture it |
Once the active translator stops resolving those addresses, every host-level tool reads the post-invalidation view, including whatever imager you attach. Reaching the earlier mapping is Service Area & physical-block-addressing work on PC-3000, which is the same reason leaving the drive powered makes the case worse: background cleaning runs on the drive's own schedule no matter what the host bus is doing. The tradeoffs of recovery after a TRIM command apply here, with the shingled bands rather than a flat CMR address space underneath.
How Does the Lab Recover a Corrupted SMR Translator?
Recovery runs at the firmware layer with PC-3000, not host imaging software. The engineer locks the drive's background processes, saves the secondary translator off the platters, then rolls it back or rebuilds it in workstation RAM. If the translator is beyond repair, Physical Block Access reads the shingled bands directly.
- Lock the background processes. Connect the drive to PC-3000 & apply the write lock before the power-on sequence finishes, so garbage collection cannot rewrite bands or update the corrupt translator during the session.
- Save the secondary translator. Read Module 190 out of the Service Area on Western Digital drives using the dedicated T2 module save function.
- Roll back or rebuild the map. Load an earlier translator state into RAM for logical corruption, leaving the platters untouched.
- Fall back to Physical Block Access. When the secondary translator cannot be recovered, switch PC-3000 Data Extractor to read raw shingled bands directly. The output is RAW sector data without file-system structure, but the physical bits are preserved for reassembly.
Imaging happens through PC-3000 once the translator is stable, never through consumer cloning software that would read the same 0x00 the operating system does. Firmware-level SMR recovery at our Austin, TX lab starts at $900. There is no diagnostic fee, & if we can't recover the data you don't pay. Hard drive data recovery pricing covers CMR firmware cases at a lower tier, since a CMR drive carries no secondary translator to rebuild. The full hard drive recovery price tiers break the cost out by failure type.
The platters are not blank; the map is.
An SMR drive reading all zeros almost always still holds its data in the shingled bands. The recoverable path is reconstructing the secondary translator or reading the bands directly, both of which happen at the firmware layer. Repeated power cycles & clone attempts work against that by giving the firmware more chances to rewrite the bands.
