Accidentally Deleted Files?
They're Probably Still There.
When you delete a file, even “permanently,” it isn't actually erased. The space is simply marked as available. Until new data overwrites that space, your files can be recovered. Stop using the drive immediately for best results.
Updated 2026-07-10
Featured Snippet Box
Can Deleted Files Be Recovered?
Yes, in most cases. Here's why:
  • 1
    Deletion only removes the pointer. The file system marks the space as available but does not erase the actual data.
  • 2
    Data remains until overwritten. On Hard Drives, new files must overwrite the old data. On SSDs, the drive may preemptively erase deleted data blocks.
  • 3
    Recovery tools scan for remnants. Professional software can find and reconstruct deleted files.
SSD exception: On solid-state drives, TRIM commands tell the controller which deleted blocks it can discard. Once TRIM runs, you can't get that data back through normal interfaces.
The exception: if the SSD died from a hardware failure (dead controller, shorted PMIC, firmware corruption) before the OS could send TRIM commands, the data still exists on the NAND. Recovery in that scenario depends on rebuilding the translator or emulating the controller, not on scanning for deleted files.
What Customers Say
“Absolutely pleasant and professional experience with them. The first time I worked with them they successfully extracted phone data that a popular chain in my area said could not be extracted. I just finished working with them again with a phone that I accidentally left in my pocket while free diving. The phone was too far gone, but the only cost to me was the shipping to have it returned. I truly appreciate the competence and professionalism of this company.”
Josiah Magnusson
“I had an incredible experience with Rossmann. My computer had shut off without warning and wasn't turning back on. I took it to The Mac Support Store in Gowanus, which was the first well-reviewed place that came up on Google, and they charged $30 for a diagnostic and then gave me an estimate saying my logic board was fried and it would cost $700 to repair.”
Sophia Harvey
Types of Deletion
Types of Deletion We Recover
Recycle Bin Emptied
Files deleted from recycle bin/trash are typically recoverable if the drive wasn't used heavily afterward.
Shift+Delete Bypass
Files deleted without going to recycle bin. Same recovery process as emptied bin. Data still exists.
Deleted Folders/Partitions
Entire folders or partitions accidentally deleted.
Command Line Deletion
Files deleted via rm, del, or other command line tools. No different from GUI deletion for recovery purposes.
App/Program Deletion
Files deleted by software (photo editors, cleanup tools, etc.). Recoverable unless app performed secure delete.
Secure/DoD Wipe
Not recoverable.
HDD vs SSD
HDD vs SSD: Critical Differences
Hard Drives (HDD)
A conventional (CMR) hard drive doesn't erase deleted data on its own. Files remain until the exact sectors are overwritten by new data. This can take months or never happen if the drive has free space.
  • CMR drives don't erase deleted files on their own
  • Recovery possible months/years later
  • Mature recovery tooling for deleted file patterns
  • Even partial files often recoverable
Solid State Drives (SSD)
When the operating system sends TRIM for a deleted file, the controller marks those blocks as invalid.
  • If the drive died from a hardware failure before TRIM could execute, data may still exist on the NAND
SSD Users: If the drive failed immediately after deletion, power it off and contact us for evaluation.
DIY vs Professional
When to DIY vs. When to Call Us
DIY Recovery May Work If:
  • Drive is 100% healthy (no clicks, no slowness)
  • You have another drive to recover files TO
  • Files were recently deleted with minimal drive use since
  • It's an HDD (not SSD with TRIM)
Free tools: Recuva, PhotoRec, TestDisk
Call Us If:
  • Drive makes any unusual sounds
  • Drive is slow, freezing, or disconnecting
  • It's an SSD and time is critical
  • Data is irreplaceable and you need certainty
  • DIY software isn't finding files
Deleted File Recovery Pricing
Drive ConditionWhat This CoversPrice
Healthy DriveDrive reads normally, just need deleted files recoveredFrom $250
Drive with IssuesBad sectors, firmware corruption, needs imaging firstFrom $250 to $600–$900
Mechanical FailureClicking/failing drive + deleted file recovery$1,200–$1,500 to $2,000
No Data, No Charge: If we can't recover your deleted files, you pay nothing.
Can permanently deleted files be recovered?
Yes, in most cases. When you delete a file (even from recycle bin), the data is not erased. Only the pointer to it is removed. The actual file remains on the drive until that space is overwritten by new data.
How long after deletion can files be recovered?
There is no fixed time limit. It depends on drive usage. If you stopped using the drive immediately after deletion, files can be recovered months or years later. Heavy use after deletion reduces chances.
Can deleted photos be recovered?
Yes, photos are often excellent candidates for recovery. Image files have recognizable headers that recovery software can identify even without file system metadata.
Deleted Something Important?
Stop using the drive and contact us. Free evaluation, no data no charge.
