Recovery Software vs. Hardware Recovery
DMDE Alternative for Hardware-Level Drive Failure
DMDE is one of the best logical recovery tools available. Its partition reconstruction engine, hex editor, and virtual RAID builder make it a first-choice tool for IT professionals dealing with corrupted file systems, deleted partitions, and formatted volumes on physically healthy drives. It delivers strong capability for logical recovery without the cost of lab hardware.
If your drive is detected by your operating system with its correct model and capacity, and DMDE can complete a scan, use it. But if DMDE is frozen on LBA 0, your recovered files are zero-filled, or the drive is clicking, not spinning, or dropping off the bus mid-scan, the problem is hardware. No software operating through the OS storage stack can bypass broken read/write heads, a locked-up SSD controller, or corrupted drive firmware.
Updated July 2026
13 min read
When DMDE works
When DMDE Is the Right Tool
DMDE is the correct tool when your storage device is physically healthy, spinning normally, detected by the BIOS with its full capacity, and maintaining a stable connection, but suffers from logical damage such as accidental formatting, deleted partitions, or a corrupted file system. For logical failures on healthy hardware, DMDE is one of the best values in recovery software.
DMDE operates at the sector level, reading raw disk data through the operating system's ATA or NVMe driver. It reconstructs partition tables from backup copies, rebuilds MFT entries, and carves files by signature from unallocated space. This approach works when the drive hardware is functional:
  • The drive spins up normally and is detected in BIOS/UEFI with its correct model number and full capacity
  • The drive appears in Disk Management or lsblk with its expected size, even if no volumes mount
  • You need to recover deleted files, a formatted partition, or a corrupted file system on a drive that responds to reads at normal speed
  • The drive produces no unusual sounds (clicking, beeping, grinding) and does not disconnect during extended reads
In these scenarios, DMDE, R-Studio, PhotoRec, and similar tools are appropriate. DMDE's partition search is particularly strong for cases where the MBR or GPT has been overwritten but the file system structures remain intact deeper on the disk. For a free method that handles the same logical recovery scenarios, our ddrescue guide covers sector-level cloning with open-source tools.
Failure categories
What Type of Failure Is Preventing DMDE from Working?
Drive failures split into three categories: logical damage, firmware corruption, and mechanical failure. DMDE handles the first category on physically healthy hardware. The second and third require direct hardware intervention through tools like PC-3000 that communicate with the drive outside the OS storage stack.
Logical Damage
File system corruption, deleted partitions, accidental formatting, or overwritten MBR/GPT headers. The drive hardware functions normally and responds to read commands at full speed; the problem exists only in the data structures that organize files on disk.
DMDE, R-Studio, and similar tools operate at this level through standard OS read commands. If your drive spins normally and DMDE scans at 50+ MB/s, this is your category. DIY recovery with ddrescue is also an option for logical damage on healthy hardware.
Firmware Corruption
Damage to the drive's internal software: translator tables that map logical addresses to physical sectors, defect lists, SMART modules, or ROM adaptive parameters. The drive may spin up, appear in BIOS with its correct model name, but return wrong data, hang on reads, or report 0 bytes capacity.
DMDE waits for data the corrupted firmware cannot deliver. Recovery requires vendor-specific commands via PC-3000 to access the drive's Service Area and rebuild corrupted modules. Common in Seagate F3 architecture (translator corruption) and Western Digital drives (G-List overflow causing read speed collapse).
Mechanical Failure
Physical component failure: crashed read/write heads, seized spindle motor, stiction, or scored platters. The drive clicks, beeps, does not spin, or drops off the bus entirely. No software can bypass broken hardware. Recovery requires opening the drive inside a 0.02µm ULPA-filtered clean bench and replacing the failed components with matched donor parts before imaging. Standard hard drive head swap recovery at our lab runs $1,200–$1,500. Platter surface damage tops out at $2,000.
Why DMDE freezes
Why DMDE Freezes on LBA 0 and Early Sectors
DMDE freezes on LBA 0 when the hard drive's read/write heads are physically failing or the firmware is trapped in a Busy (BSY) state. The software is not crashing; it is waiting for a hardware response the damaged drive cannot provide. Continued scanning in this state forces degraded heads across the platter surface, causing further damage with every retry.
When DMDE's partition search hangs at "Partition searching... #0 LBA" for hours on a drive that should scan at 100+ MB/s, DMDE is not malfunctioning. The drive hardware is failing to respond to standard read commands. Here is what is happening at the hardware layer:
SATA Command Timeouts and BSY State
When a hard drive's read/write heads encounter unreadable sectors, the drive's firmware retries each read multiple times internally before reporting an error to the host. During those retries, the drive holds the SATA bus in BSY (Busy) state. The OS storage driver waits for the drive to release BSY. DMDE waits for the OS.
This chain means a single bad sector can stall DMDE for 7-30 seconds depending on the drive firmware's retry configuration. On a drive with thousands of weak sectors, those delays compound into hours or days of apparent freeze.
Degraded Read/Write Heads
A head assembly with degraded magnetic transducers can still read some sectors but fails on others. The drive firmware retries failed reads by repositioning the head and re-attempting, which produces the characteristic clicking sound. Each retry cycle forces the damaged head across the platter surface.
DMDE's partition search reads sequentially from the start of the disk, which means it hits the drive's Service Area (where firmware modules and translator tables live) first. If the SA sectors are on a degraded head, DMDE cannot even read the partition table because the drive cannot deliver the first few hundred sectors.
USB Bridge Controller Disconnects
If you're running DMDE through a USB enclosure, the bridge IC has its own timeout. When the drive doesn't respond within the bridge chip's programmed threshold, the bridge resets the USB connection, and DMDE sees the device disappear.
Some bridge chips also force a 4096-byte logical sector size on drives formatted with 512-byte sectors (the "4Kn vs 512e" translation problem), which can cause DMDE to misalign its MBR and partition table parsing. Connect the drive via direct SATA before concluding that DMDE cannot read it.
SMR Translator Corruption
Modern consumer HDDs use Shingled Magnetic Recording (SMR), where data tracks overlap. SMR drives maintain a secondary translator that maps logical block addresses to physical band locations. When this translator corrupts, the drive may report its full capacity to the OS but return garbage or zeros for most LBA ranges.
DMDE will scan the drive and find no recognizable file system structures because the physical-to-logical mapping is broken at the firmware level. Rebuilding an SMR translator requires direct firmware manipulation via PC-3000.
If DMDE has been scanning for more than 30 minutes with less than 1% progress, stop the scan and power down the drive. Continued reads on degraded heads can score the platter surface. The instinct to let the scan finish is understandable, but a drive that takes hours to read megabytes is destroying itself.
Hardware failure states
Hardware Failure States Where All Recovery Software Fails
The following failure states prevent DMDE, R-Studio, and every other recovery application from accessing drive data. Each requires direct firmware or hardware intervention at the lab level because the OS storage stack cannot communicate with the drive's controller.
BSY State (Busy State)
A firmware condition where the drive's microprocessor hangs during initialization or becomes trapped in an internal read-retry loop. The platters continue spinning but the SATA bus remains locked, causing DMDE and the host operating system to wait indefinitely. Common in the Seagate 7200.11 family. PC-3000 can send terminal commands to break BSY without touching the platters.
Damage to the firmware modules that map logical block addresses (LBAs) to physical sector locations on the platters. When the translator corrupts (System File 28 in Seagate F3 drives), DMDE scans successfully but retrieves zero-filled sectors or structural errors because the drive's own address mapping is broken. PC-3000 rebuilds the translator from redundant copies stored in the drive's Service Area.
Stiction (Static Friction)
A physical failure where the read/write heads bond to the platter surface after a crash or prolonged inactivity, preventing the spindle motor from spinning. The drive produces a low buzzing or beeping sound and does not appear to the OS at all. Forcing the drive to spin with software power cycles risks rotational scoring across the entire platter surface. Recovery requires careful physical separation of the heads from the platters inside a 0.02µm ULPA-filtered clean bench.
TRIM / UNMAP Execution
TRIM instructs the flash controller to unmap the associated logical addresses and schedule background garbage collection. The controller then returns zeros for those LBAs and erases the underlying NAND pages during idle time. Once executed, no software, including DMDE, R-Studio, or UFS Explorer, can recover the data. TRIM runs automatically on Windows 7+, macOS 10.10.4+, and Linux kernel 3.8+ with fstrim enabled.
TRIM and zero-filled files
Why DMDE Recovers 0-Byte Files from SSDs
DMDE recovers 0-byte files from SSDs because the operating system's TRIM command has already instructed the controller to unmap those logical addresses and schedule garbage collection. DMDE locates the file names in the directory metadata, but the controller returns zeros for the trimmed LBAs. No software can recover data once the controller has erased the underlying NAND pages during garbage collection.
DMDE users frequently report reconstructing an entire directory tree from an SSD, only to find every recovered file is 0 bytes, opens as a black image, or plays as silent audio. This is not a DMDE limitation. It is TRIM doing what it was designed to do.
DMDE recovers the file system metadata (the MFT entry that says "report.docx existed at clusters 40000-40500") because the MFT is stored separately. But when DMDE follows that pointer to read the actual file data, the NAND blocks contain zeros. The metadata survived; the data did not.
You can verify this yourself: open a recovered file in DMDE's hex editor. If the content area is entirely 00 00 00 00 repeating, TRIM has already run. No software, including DMDE, R-Studio, or any commercial tool, can recover data that has been electrically erased at the NAND cell level.
TRIM is enabled by default on Windows 7 and later, on Apple OEM SSDs in macOS (with manual trimforce support for third-party drives added in macOS 10.10.4), and on Linux kernel 3.8+ with fstrim or continuous TRIM. If you deleted files on an SSD and more than a few seconds passed before you realized, TRIM has likely already run on those blocks.
SSD controller failures
SSD Controller Failures DMDE Cannot Reach
DMDE cannot access SSDs where the controller has stopped enumerating on the bus. Phison S11 firmware lockups, failed NVMe monolithic BGA packages, and Apple T2/M-series encrypted storage all present scenarios where the NAND data may be intact but no software operating through the OS storage driver can reach it. Recovery requires direct hardware intervention via PC-3000 SSD or board-level microsoldering.
Some SSD failures leave the NAND data intact but make the controller stop communicating with the host. DMDE operates through the OS storage driver. If the controller does not enumerate on the bus, DMDE sees no device to scan.
Phison S11: SATAFIRM S11 Lockup
Phison S11-based SSDs can enter a firmware lockup where the host system identifies the drive as "SATAFIRM S11" with 0 bytes capacity. The drive is present on SATA but returning invalid identification data. DMDE will either not see the device or see a 0-byte disk with nothing to scan. PC-3000 SSD loads a volatile microprogram into the drive's RAM to rebuild the FTL mapping.
NVMe Monolithic BGA Packages
Some modern NVMe SSDs, particularly in thin laptops and mobile devices, use monolithic Ball Grid Array (BGA) packages where the controller and NAND are integrated into a single chip. Standard M.2 NVMe drives use discrete components on a PCB, but in both cases, if the controller fails due to a power surge, the drive stops enumerating on PCIe. The OS sees no device.
There's no cable to swap and no enclosure to try. Recovery takes board-level diagnosis: we check power rails with an oscilloscope and replace failed voltage regulators by microsoldering.
Apple T2 and M-series Encryption
On Macs with T2 chips (2018-2020 Intel Macs) and Apple Silicon (M1/M2/M3/M4), SSD storage is encrypted at the hardware level by the Secure Enclave. The encryption keys are bound to the specific security chip on that specific logic board. If the board dies, the NAND cannot be read by DMDE, PC-3000, or any external tool because the decryption keys died with the board. The only recovery path is repairing the original logic board at the component level to restore Secure Enclave functionality.
DMDE vs lab recovery
DMDE vs. Professional Lab Recovery
DMDE is a logical recovery tool that reads sectors through the operating system's ATA or NVMe driver to reconstruct deleted partitions and corrupted file systems on healthy hardware. Professional lab recovery uses a PCIe hardware card (PC-3000) to bypass the OS entirely, repair corrupted firmware modules, and image physically failing drives that no software can access.
CapabilityDMDE SoftwareProfessional Lab (PC-3000)
Sector access methodOS-level ATA/NVMe driver. If the OS cannot enumerate the drive, DMDE cannot access itVendor-specific ATA commands (VSCs) sent directly to the drive firmware via PCIe hardware card, bypassing the OS
Bad sector handlingWaits for the OS timeout on every bad sector. No control over drive-internal retry behaviorControls head positioning, read retries, and timeout thresholds at the millisecond level. Skips bad areas and returns later with adjusted parameters
Firmware repairNo. DMDE reads data but cannot modify drive firmware modules, translator tables, or head mapsReads and edits Service Area modules, rebuilds corrupted translator tables, and restores ROM data
Clicking/beeping driveCannot help. Running DMDE on a clicking drive works a failing mechanism across the plattersHead swap in a 0.02µm ULPA-filtered clean bench, then PC-3000 imaging with head maps and adaptive parameters
SSD controller lockupCannot access. If the controller does not enumerate, no OS-level tool can reach the NANDPC-3000 SSD communicates with the controller through direct hardware commands to push it out of lockup states
RAID reconstructionVirtual RAID builder works on healthy, readable member imagesRecovers each physically failed member drive first, then reconstructs the array from recovered images
PricingLow-cost software license. Free edition limits apply by directoryHDD: $100–$2,000. SSD: $200–$1,500. Free evaluation. No data, no fee
How PC-3000 bypasses software
How PC-3000 Bypasses What DMDE Cannot
PC-3000 communicates with a storage device through vendor-specific ATA commands sent via a dedicated PCIe hardware card, bypassing the operating system entirely. This gives a technician direct control over firmware modules, head positioning, and read timeouts that DMDE and all other software tools cannot access because they operate through the OS storage stack.
The PC-3000 is a PCIe hardware card manufactured by ACE Lab. It sends vendor-specific ATA commands (VSCs), which DMDE has no way to send. That gives a technician direct access to drive internals the operating system can't see:
  • Firmware modules in the Service Area, including the translator table that maps logical block addresses to physical platter locations. When this table corrupts, DMDE scans valid LBAs but gets zeros or garbage because the drive's own address mapping is broken
  • Head maps and defect lists that control which heads are active. PC-3000 can disable a damaged head and image only the platters served by healthy heads, then address the damaged head's platters separately with a donor head swap
  • Read timeout control at the hardware level. Instead of waiting on the OS timeout for every bad sector, PC-3000 sets millisecond-level timeouts, skips problematic sectors instantly, and returns to them later with adjusted head positioning
  • Selective multi-pass imaging that reads accessible areas first, builds a map of problematic regions, and returns in subsequent passes with different read strategies. DMDE scans sequentially from LBA 0; PC-3000 prioritizes areas most likely to contain your data
Imaging an unstable drive
Why Does DMDE's Disk Clone Damage an Unstable Drive?
DMDE's disk clone reads through the operating system's ATA or NVMe driver, so it inherits the drive's own retry behavior and cannot choose which head is active. On a degraded drive, its repeated passes drag the read/write heads over the same weak areas and accelerate mechanical damage.
DMDE ships a disk clone / disk copy feature, and on a healthy drive it images fine. The problem is what it can't do on a drive that reads weakly. Because the clone runs through the OS storage stack, it waits on the drive's internal retries and the OS per-sector timeout for every bad sector and has no way to tell the drive which head to use. There is no head-by-head selection.
On a mechanically weak hard drive, that linear behavior is the danger. Every retry repositions the read/write heads and flies them back over the same damaged media. A degrading head that might survive one targeted pass instead makes seek after seek across the weak zone, which turns a partial head failure into a full head crash. That is why running a linear clone on a clicking drive can end a hard drive recovery before it starts.
Dedicated hardware imagers reach the drive without the OS driver in the loop, and that changes how the read itself behaves. A DeepSpar Disk Imager or PC-3000 sets its own short per-sector timeout, images the accessible areas first, and returns to the bad regions on later passes instead of grinding on them in place.
It can read in reverse and image head by head using the drive's head map, so a degrading head is isolated and read once rather than dragged across the platter on every retry. It can also power-cycle the drive between reads to clear a hung state without a person standing over it.
Imaging behaviorDMDE disk cloneHardware imager (DeepSpar / PC-3000)
Region orderReads in place; retries a bad sector before moving onMaps and pulls the accessible regions first, revisits bad zones on later passes
Head-by-head imagingNone; reads whatever the drive presentsUses the drive head map to isolate and read one head at a time
Power controlNone between readsPower-cycles a hung drive between reads without operator intervention
Diagnostic checklist
How to Tell If DMDE Can Solve Your Problem
DMDE can solve your problem if the drive is detected by the BIOS with its correct model and full capacity, makes no unusual sounds, and scans at 50 MB/s or higher. If the drive clicks, shows 0 bytes, drops off the bus, or scans below 1 MB/s, the failure is physical and no software can address it.
Before sending a drive for lab recovery, check these indicators. DMDE users tend to be technically competent; this checklist respects that by focusing on measurable symptoms rather than vague descriptions:
  1. Measure scan throughput. DMDE shows a progress counter. A healthy SATA HDD reads at 80-180 MB/s. If DMDE is averaging less than 1 MB/s, the drive is struggling to read sectors. This means hardware degradation, not a complex logical problem.
  2. Check SMART attributes. Before running DMDE, pull SMART data with smartctl -a /dev/sdX or CrystalDiskInfo. Reallocated Sector Count (ID 5), Current Pending Sector (ID 197), and Uncorrectable Sector Count (ID 198) above zero indicate media or head degradation. High values (hundreds or thousands) mean the drive is actively failing.
  3. Listen to the drive. Clicking, beeping, or rhythmic sweeping mean the fault is in hardware. Power the drive off. Do not run DMDE.
  4. Verify device enumeration. If the drive shows the wrong model name, 0 bytes capacity, or does not appear in BIOS at all, the firmware or controller has failed. DMDE requires a properly enumerated device.
DMDE Can Handle This
  • Drive detected with correct model and full capacity
  • SMART Reallocated Sector Count is zero or single digits
  • Scan throughput stays above 50 MB/s consistently
  • No unusual sounds from the drive enclosure
DMDE Cannot Help Here
  • Drive clicking, beeping, or not spinning up
  • SMART shows hundreds of reallocated or pending sectors
  • Scan throughput below 1 MB/s or frozen at 0%
  • Drive shows wrong model, 0 bytes, or drops off the bus
HDD pricing
Hard Drive Recovery Pricing
Hard drive hardware recovery costs between $100–$2,000 depending on the severity of the mechanical or firmware failure. Simple imaging of a stable drive starts at $100; head swaps run $1,200–$1,500; platter-level surface damage tops out at $2,000.
We quote based on the fault, not the perceived value of your data. Evaluation is free. No data recovered means no charge.
SSD pricing
SSD Recovery Pricing
SSD recovery costs between $200–$1,500 depending on the required intervention level. Simple copies start at $200; file system repairs on functional controllers start at $250; circuit board repair runs $450–$600; advanced PCB / NAND swaps or board-level microsoldering tops out at $1,200–$1,500.
SSD recovery pricing depends on the type of failure, from file system repair through controller-level and board-level intervention.
Frequently asked
DMDE found my partition but all files are 0 bytes. What happened?
On SSDs, this is a TRIM artifact. DMDE reconstructed the file system metadata (MFT entries, directory tree) from intact sectors, but the actual data blocks behind those pointers were erased by the SSD controller during garbage collection. When you open a recovered file in a hex editor and see only 00 00 00 00, the NAND flash cells holding that data were electrically zeroed by TRIM. This is not a DMDE bug. No software can recover data that has been physically erased at the flash cell level.
DMDE is stuck on 'Partition searching... #0 LBA' for hours. Is it still working?
If DMDE has been scanning LBA 0 or early sectors for more than 30 minutes on a drive that should scan at 100+ MB/s, the drive hardware is failing to respond to read commands. The drive controller is either stuck in a BSY (Busy) state due to firmware corruption or the read/write heads are degraded and timing out on every sector. DMDE is waiting for the OS storage stack to return data that the drive cannot deliver. Stop the scan and power down the drive. Continued reads on degraded heads can score the platter surface.
DMDE is inexpensive. Why would I pay for professional recovery?
DMDE is one of the best values in logical recovery software. If your drive is physically healthy and DMDE can complete a scan, use it. Professional recovery addresses a different category of problem: physical hardware failure where the drive cannot respond to standard read commands. HDD recovery at our lab runs $100–$2,000 depending on severity. SSD recovery runs $200–$1,500. Free evaluation, no charge if we cannot recover data. The software and the lab service solve different problems.
My drive disconnects every time DMDE starts scanning. Why?
USB enclosures use bridge controller ICs (commonly JMicron or ASMedia chips) that translate between USB and SATA protocols. These bridge chips have programmed timeout thresholds. When a drive sector takes longer than the bridge allows, the bridge resets the connection and the OS drops the device. DMDE sees the drive disappear mid-scan. This happens because the drive is struggling to read degraded sectors, not because of a USB cable or enclosure defect. Try connecting via direct SATA if possible. If the drive still hangs on SATA, the problem is hardware-level head or firmware degradation.
Can DMDE reconstruct my RAID array?
DMDE has a virtual RAID constructor that can reassemble logical RAID configurations when all member drives are healthy and readable. It works well for RAID 0/1/5 arrays where the controller failed but the individual drives are intact. If one or more member drives have physical damage (clicking, not spinning, firmware-locked), DMDE cannot image those drives. Each failed drive needs hardware-level recovery first, then the virtual RAID reconstruction can proceed on the recovered images. Attempting a virtual RAID build with a physically failing member drive will cause DMDE to hang on every bad sector of that member.
Can I swap the PCB as an alternative to DMDE for a dead hard drive?
No. Every modern hard drive PCB contains a ROM chip programmed at the factory with adaptive parameters unique to that drive's specific head geometry and platter calibration. Swapping a PCB without desoldering and transferring the original ROM chip to the donor board causes the drive to click, fail initialization, or overwrite firmware modules. If the ROM data is lost, the drive's internal mapping is gone permanently. PC-3000 can read and transfer ROM data between boards when the original PCB has failed components like a burned TVS diode or shorted preamp driver.
Should I run CHKDSK if DMDE is stuck scanning?
Never run CHKDSK, Disk Utility First Aid, or fsck on a drive that causes DMDE to freeze. When DMDE hangs on early sectors, the drive has physical degradation or firmware failure. CHKDSK performs destructive write operations to file system metadata (rewriting $MFT entries, clearing $LogFile, rebuilding $Bitmap). Running those writes through degraded read/write heads forces the weakened heads to perform intensive seek operations across the platter surface. This accelerates head degradation from partial failure to complete mechanical collapse, often producing platter scoring that makes recovery impossible even with donor heads.
Why is DMDE skipping every sector on my Seagate Barracuda drive?
If DMDE scans a Seagate F3 architecture drive (Barracuda, Rosewood, or IronWolf families) and instantly skips every sector or reports 0 MB capacity, the drive's firmware translator is corrupted. The translator maps logical block addresses to physical locations on the platters; when it fails, the drive returns invalid data for every read command DMDE sends. This is a known pattern in Seagate F3 firmware. DMDE has no mechanism to access the Seagate System Area where the translator lives. Recovery requires connecting to the drive's F3 diagnostic interface through PCB test points, clearing corrupted SMART logs, and regenerating the translator table before any data can be read.
Is there a software alternative to DMDE for a clicking Helium hard drive?
No software alternative exists for a clicking hard drive of any type, and Helium-sealed drives add further complexity. Clicking is a hardware fault, and whether it is the heads, the firmware, or the board, no software can address it. Helium drives (common in 8TB+ NAS and enterprise arrays) are hermetically sealed to maintain the low-density gas environment the heads require. Opening a Helium drive in normal atmosphere permanently changes the head fly height, so the donor head swap and imaging must happen in a controlled environment using a 0.02µm ULPA-filtered clean bench. Helium drive recovery follows the canonical helium HDD schedule ($200–$5,000+). Helium cost: $400-$800 additional for head swap and surface damage tiers. This covers the helium refill required after opening the sealed chamber.
Can DMDE recover data from a hardware-encrypted WD My Book?
DMDE can recover data from a WD My Book only if the original USB bridge board (which contains the hardware encryption IC) is fully functional. WD My Book and My Passport drives encrypt all data at the hardware level through the bridge controller. If you remove the bare drive from the enclosure and connect it via SATA, DMDE reads only encrypted ciphertext. If the bridge board itself has failed (common after power surges), DMDE has no way to decrypt the data. PC-3000 can extract the encryption key from the drive's Service Area firmware and apply sector-by-sector decryption to produce a readable image.
Can DMDE image a drive that has bad or unstable sectors?
DMDE can attempt a disk clone, and on a healthy drive with a handful of reallocated sectors it finishes fine. The catch is control. DMDE images through the OS ATA or NVMe driver, so it has no per-head selection. Every linear pass on a physically unstable drive stresses the weak heads. A DeepSpar Disk Imager or PC-3000 does adaptive multi-pass reads, pulling the accessible areas first and returning to bad regions later so a degrading head isn't dragged across the platter on every retry. If the drive clicks or drops off the bus, stop the clone and let the lab image it on hardware. HDD recovery runs $100–$2,000, free evaluation, no data no fee.
Does DMDE support reverse imaging or head-by-head reads?
DMDE's disk copy has a reverse-copy option that images from the end of the disk toward the start, which can get past some read hangs. Head-by-head imaging is the hardware-only step: isolating a single read/write head through the drive head map is not something software driving the OS storage stack can do. A DeepSpar Disk Imager or PC-3000 uses the head map to pull data off the accessible heads first, before a degrading head gives out and takes the rest of the recovery with it. On a clicking or weak-head drive, that ordering is the difference between a partial image and nothing.
What Customers Say
Andrew Hansen
Kyle Hartley (crazybangles)
Christopolis
Patrick Dughi
DMDE found the partition but not the data?
Free evaluation, no data no fee. Ship your drive to our Austin lab and we will diagnose the hardware before you owe anything.
