MacBook Water Damage Repair; Liquid Spills, Corrosion & No-Power
MacBook liquid damage repair cost depends on how far the spill traveled into the logic board and how many separate circuits need rework. We quote each case after evaluation rather than charging a flat board-replacement rate. The first step after any spill is to power the MacBook off immediately; electricity flowing through wet circuits accelerates corrosion and raises repair cost. We perform component-level logic board repair instead of replacing the whole board. Every repair starts with ultrasonic cleaning to remove corrosion from under BGA chips and shielding where a toothbrush cannot reach, followed by diagnosis under a microscope to identify and replace each damaged component. Free evaluation, no fix = no charge on qualifying board repairs. Walk in to our Austin lab or mail your MacBook in from anywhere in the U.S.
We fix spill damage the right way: component-level logic board repair, ultrasonic cleaning, and replacement of liquid-damaged parts. Free estimate, no pressure, no data / no fix = no charge. Visit our Austin lab or use our nationwide mail-in service.
MacBook logic board with liquid damage corrosion under ultrasonic cleaning at Rossmann Repair Group Austin lab
What sets the price on a liquid damage repair
What sets the price on a liquid damage repair?
MacBook water damage repair cost tracks how far the spill traveled into the logic board and how many separate circuits it corroded. We take the board work; a spill that stopped at the top case is a parts job for someone else. Corrosion keeps spreading while current flows, so minutes powered on move the price.
Cost variables on a spill-damaged MacBook
  • Which assembly the liquid reached. On many MacBook models the keyboard & battery are bonded into one top-case assembly, which is a parts job we do not take. What we price is the liquid that ran past it and onto the logic board.
  • How long it stayed powered. Current flowing through a wet board keeps the electrochemical reaction running & keeps eating copper, which makes time-powered-on a cost variable, not only a risk variable. A board shut down in ten seconds is cheaper to repair than the same board somebody spent a week trying to boot.
  • How many separate circuits need rework. One corroded rail is a short session at the bench. Damage spread across the charging circuit, the backlight circuit, & the main power rail is quoted as several repairs on one board, because that is what it is.
  • Whether the damaged part is still sold. Some components we buy in reels. Others were never sold separately & have to come off a donor board, which adds sourcing time & part cost to the quote.
What we quote, and when
The repair itself gets quoted per model once the board is on the bench & we know what the liquid ate. There's no diagnostic fee for that look. If we can't fix it you owe nothing, which is the no fix, no fee policy. We'd rather tell you a board isn't worth saving than sell you a repair that won't hold.
Getting the data off a MacBook that isn't worth repairing
One liquid-damage outcome does carry a published number. If the machine is finished but the files on it are not, that is board-level MacBook data recovery, & it is flat rate by model era: $325-$600. $325 covers 2016-2020 (Select Models), $425 covers 2018-2021 + M1 (Select Models), & $600 covers 2021-2024 Pro/Air (M1 Pro/M2+). Rush available: +$100 to move to front of queue. No data, no recovery fee.
Why the data path is board repair, not chip removal
On T2 & Apple Silicon MacBooks the NAND is soldered to the logic board, while the storage controller & the Secure Enclave that holds the keys sit inside the T2 or the M-series SoC. Desolder that NAND, read it on a dedicated NAND reader, & you get ciphertext; the keys never leave the Secure Enclave. So the recovery is the same work as the logic board repair: clean the corrosion off, replace the components the liquid ate under a microscope with a Hakko FM-2032, & bring the board up far enough that the SoC's inline AES engine, keyed by the Secure Enclave, decrypts in place & the volume mounts. All of it happens at our Austin lab.
Can a water-damaged MacBook be fixed?
Usually yes, & the honest version is that it depends on the same variables that set the price: how long the board sat wet, how long it stayed powered while it was wet, & how many separate circuits the corrosion reached. Those variables set feasibility as well as cost.
What usually settles it is whether the liquid ate the parts or ate the board underneath them: a corroded component comes off & a replacement goes on, while copper the current already ate out from under one has to be rebuilt before anything can go back on top of it. That is where the question turns from how to repair the board into whether the board is worth repairing.
That call gets made with the board out of the case & under a microscope, not from a photo or a phone call. Water damage doesn't show up as one fault; it shows up as whatever the liquid landed on, so the affected rails get traced after the ultrasonic clean rather than guessed at beforehand. A flat-rate board replacement is the answer you can quote without opening anything; a component-level answer needs the board on the bench first.
Asking is free. A water-damaged MacBook gets evaluated at no charge, & under our no-fix-no-fee guarantee a board we can't bring back leaves without a bill, so the feasibility answer never costs you a repair you didn't get. Bring it to the Austin lab, or mail it in from anywhere in the U.S.
Problems we fix on liquid-damaged MacBooks
  • Not turning on
  • Freezing / random shutdowns
  • No light or image on the screen
  • Not charging the battery
  • USB-C or Thunderbolt ports dead
  • Files stranded on a soldered SSD
How we repair spill damage
  • Component-level logic board repair (no unnecessary board swaps)
  • Repair what's broken to save cost and time
  • Ultrasonic cleaning of corroded components (far beyond the "alcohol & toothbrush" myth)
  • 90-day warranty on our work
MacBook liquid damage repair; mail it in or come to our s...
MacBook liquid damage repair; mail it in or come to our store
You poured water, juice, or beer into your laptop. Don't panic; this is what we fix for a living. You'll receive an assessment of exactly what the spill damaged and what needs to be repaired at no charge. If you're local, stop by our Austin store. If you're not, mail your MacBook in for a free estimate.
Spill damage corrodes sensitive components; but it's not unfixable. The common answer is a whole-board replacement. We prefer engineering: repair usable parts you already own and restore functionality at a fair price.
Important: if liquid gets inside, stop using the MacBook immediately. Powering it on lets electricity flow through wet, shorted components and makes corrosion worse. Minimizing damage early increases the chance of a fast, affordable repair.
Severe corrosion from MacBook water damage
Even severe corrosion is repairable; but early shutdown helps.
When you come to Rossmann's, we fix it
Technician performing MacBook liquid damage repair
What sets Rossmann Repair Group apart? Many shops outsource board repair because they don't have the tools or experience. That causes delays, surprises, and a game of telephone between you and a third-party lab.
With us, the buck stops here. We repair your MacBook and its logic board in-house. We've taught thousands of technicians via free YouTube content, guides and personal instruction.
Watch: Microscopic liquid damage in real time
This clip starts exactly where corrosion becomes visible (03:06). You'll see bubbles and "paths" form as electricity flows through moisture on the logic board; and how the reaction stops the moment power is cut. This is why we say: after a spill, power it off.
What the on-screen numbers mean
  • Upper-left: PPBUS_G3H; the main power rail on this MacBook Pro logic board. When water hits, you'll see the reading climb above its steady level and then sag; clear evidence the circuit isn't regulating normally. Overvolting a rail that the rest of the board depends on ends badly.
  • Bubbles / movement: that's an electrochemical reaction actively corroding components. When power is cut, the bubbles stop because the reaction stops.
  • Voltage shouldn't swing like this; moisture creates shorts and backfeed.
  • Re-powering while wet accelerates damage and raises repair cost/time.
  • Powering off immediately limits corrosion and improves repair outcomes.
Microscopic view of a MacBook power circuit reacting to water while powered; voltage overlay shows PPBUS_G3H deviating from its steady reading.
Before & after
Before & after
Before: heavy corrosion on MacBook logic board
Before
After: cleaned and repaired MacBook board
After
At the time of photographing, that board alone cost roughly $750 as a replacement part. We repaired it at a fraction of that cost and it's still alive and kicking.
Typical repair pricing
Pricing depends on model and how far the corrosion spread across the board. Bring or mail in your MacBook for a free evaluation and exact quote. We do not replace keyboards, top cases, trackpads, or batteries, so a spill that damaged only those is a job for a parts shop rather than this bench.
Logic Board Repair
Priced per model and extent of damage
Ultrasonic Cleaning
Included with board repair
Multiple Damaged Circuits
Combined quote after evaluation
Quoted after free evaluation
Frequently asked questions
Can a MacBook with water damage be repaired?
Yes. Most spill-damaged boards can be restored with proper cleaning and component-level repair. The sooner it's powered off and dried (don't keep trying to turn it on), the better your odds.
Does Apple cover water damage?
Liquid damage is not covered under standard Apple warranties, so a spill is an out-of-warranty repair wherever you take it. We work at the component level on the board you already have, and we quote after a free evaluation.
How much does liquid damage repair cost?
It depends on how far the spill traveled across the logic board and how many separate circuits need rework. We quote each case after a free evaluation rather than charging a flat board-replacement rate. We do not replace keyboards, top cases, or trackpads, so those are not part of the quote.
Will my MacBook Air work after spilled water?
Usually, yes, after proper cleaning and repair. Do not keep turning it on; that spreads damage. Bring it in or mail it to our lab for a free estimate.
How long does MacBook water damage repair take?
Typical turnaround is 7 to 14 business days from the time we receive the MacBook. Ultrasonic cleaning takes one day. Component-level diagnosis and repair takes 2 to 5 days depending on how many circuits the liquid reached. If donor parts are needed, sourcing adds additional time. Rush service is available for urgent cases.
Where can I get my water-damaged MacBook repaired in Austin?
Our lab at 2410 San Antonio St in Austin, TX 78705 performs all liquid damage repairs in-house. Walk in during business hours for a free evaluation. We ultrasonic-clean the logic board, diagnose under a microscope, and replace corroded components via micro-soldering. The entire repair happens in our Austin facility; we do not ship your MacBook to a secondary location.
What does it cost to get the data off a water-damaged MacBook?
Data recovery is priced separately from repair, and unlike the repair it carries a published flat rate by model era: $325-$600. $325 covers 2016-2020 (Select Models), $425 covers 2018-2021 + M1 (Select Models), and $600 covers 2021-2024 Pro/Air (M1 Pro/M2+). On T2 and Apple Silicon MacBooks the NAND is soldered to the logic board and the keys stay inside the Secure Enclave, so extraction means repairing the original board rather than removing chips. No data, no recovery fee.
Ready to get your data back?
