Head Crash Recovery
Platter Damage Is Not Always Fatal
Head crashes damage specific areas of the platters, but data outside those zones often survives. We perform clean bench head swaps and use PC-3000 to image around damaged sectors. Even severe crashes can yield partial or full recovery. This failure mode sits inside our broader hard drive data recovery service, which covers mechanical, firmware, and media damage cases in our Austin lab.
Head swap $1,200–$1,500, platter damage $2,000, donor billed separately. No data, no charge. Mail-in from all 50 states.
Can a head-crashed drive be recovered?
Often yes. A head-crashed drive can be recovered when readable areas remain outside the damaged tracks. We open the drive on a ULPA-filtered clean bench, install a matched donor head stack, image the surviving surfaces with PC-3000, and bill no recovery fee if no data comes back.
Grinding noise
Turn the drive off immediately. Every second the damaged heads run, they scrape more of the platter surface, removing the magnetic coating that stores your data.
Grinding noise? That's active platter damage happening now. Power off and contact us for evaluation.
What Is a Head Crash?
Inside a hard drive, the read/write heads float nanometers above the spinning platters, riding on a cushion of air the platters create as they spin.
A head crash happens when the heads touch the platters, typically causing grinding sounds. This can occur from:
  • • Drops or impacts - The most common cause
  • • Wear and age - Bearings degrade over time
  • • Manufacturing defects - Some drives ship marginal
  • • Power surges - Can damage the PCB and interrupt controlled head parking
When heads contact spinning platters, they scrape the magnetic coating. This creates the grinding sound and visible scratches called "rings of death."
Head Crash vs Clicking
Clicking means the drive is searching for servo tracks it cannot read. That is not by itself a crash, and the bench is what tells you whether the heads have touched the surface.
Grinding means active metal-to-metal contact inside the drive right now. This is more severe.
The sooner you stop the drive, the more data survives.
Why Head Crashes Are Often Recoverable
Localized Damage
Head crashes typically damage specific areas where the heads touched down. Data on unaffected platter areas remains intact and readable. Your photos might be fine while your documents are in the damaged zone, or vice versa.
Multi-Head Drives
Modern drives have multiple platters and multiple heads. Often only one head crashes while others remain functional. We can image the good surfaces fully.
Smart Imaging
A surface with a scratched ring is skipped whole.
Recovery process
The Recovery Process
    Evaluation
    We open the drive in our clean bench to assess platter condition. We look for visible scratches, debris, and head damage. This tells us what's recoverable before we proceed.
    Platter Cleaning
    Head crashes leave debris on the platters. We carefully clean this without further damaging the surface. This step is critical for preventing the new heads from immediately crashing.
    We transplant working heads from an exact-match donor drive. Same model, same revision, often same firmware. The new heads let us read the undamaged areas.
    Strategic Imaging
    PC-3000 images good areas first, then carefully attempts damaged zones. We prioritize the data you need most. The goal is maximum recovery before the donor heads wear.
Clean bench inspection
Clean Bench Inspection Before a Head Swap
Before we replace any internal component, the patient drive moves to a ULPA-filtered clean bench for microscopic inspection. What the platters and sliders look like under magnification tells us which heads can be safely powered on, whether the platters need cleaning before a swap, and how aggressive the imaging plan can be without sacrificing surfaces that are still readable.
Stiction (static friction)
The read/write heads have bonded to the platter surface instead of returning to the parking ramp. The spindle motor buzzes without spinning up. The drive moves straight to the clean bench for manual HSA removal before any further power-on attempt.
Donor Head Matching for Head Crash Recovery
How do you match donor heads for head crash recovery?
A head swap only works when the donor head stack is electrically and mechanically compatible with the patient drive. Same model number is not enough. Hard drive manufacturers change preamp vendors, head counts, and HSA revisions across short production windows, so a donor purchased on model number alone usually fails on the first read attempt. We identify the read/write head assembly on four axes before any swap goes near the clean bench. For the underlying firmware and adaptive-parameter theory, see our reference on how donor drives are matched.
Preamp IC part number
The preamplifier amplifies microvolt signals from the TMR read element into a voltage the controller can sample. It is bonded to the HSA flex circuit inside the sealed enclosure, not to the external controller PCB. The donor preamp part number and silicon revision must match the patient.
Platter count and active head count
Manufacturers change platter count and head count across production runs inside one model line. The donor HSA must carry the same number of sliders in the same physical positions as the patient. A 3-head donor cannot replace a 4-head patient because the firmware head map expects to address a specific physical position that the donor does not populate.
HSA revision suffix
The HSA part number printed on the actuator flex carries a revision suffix that pins the assembly to a manufacturing window. Within a single drive model, manufacturers iterate slider design, actuator mass, and preamp silicon.
Firmware revision and head map
The patient drive's adaptive parameters are calibrated against its original head stack. A donor head stack drops into a controller that expects the patient's adaptives, so the firmware revision and head map definition must align. We detail the adaptive-parameter pinning behavior on what a head swap involves.
Imaging plan after the swap
With the donor heads installed, the drive connects to the PC-3000 Portable III. We use the PC-3000 head map function to enumerate the physical head geometry and disable any head that is still unstable after the swap.
The clone also runs on PC-3000, in a strict head-by-head workflow: image every sector reachable on one head, retire that head from the active set, then engage the next. Imaging the stable heads first pulls the maximum data off a drive that can stop functioning at any point in the job.
Why donor cost varies
Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. The donor drive is consumed in the recovery, which is why every head swap quote separates the labor line from the donor line.
For physical-impact context that feeds into the same workflow, see our dropped hard drive recovery page.
How an In-House Head Swap Actually Runs
The patient drive never leaves our Austin, TX lab. Donor sourcing, head stack transfer, and post-swap imaging are all performed on the same bench by the technician who opened the enclosure. We do not ship mechanical work to a partner facility, and we do not stage a swap in one room and image in another. The full chain of custody on a head-crash recovery is one building, one bench, one technician.
Head Stack Transfer on the ULPA-Filtered Clean Bench
Both the patient HSA and the donor HSA are removed under laminar flow on a ULPA-filtered clean bench. The technician installs head combs between the sliders before lifting either assembly off its ramp. The combs hold the heads apart while the assembly is out of the enclosure so the sliders cannot touch each other or land on bare platter media. Each donor head is inspected under low-angle light for glazed air bearing surfaces or embedded particulate before the swap proceeds.
With the donor HSA seated on the patient's actuator pivot, the combs are withdrawn in the same sequence they were inserted. The patient enclosure is closed, breather filter intact, before the drive leaves the bench. This entire procedure is performed in our Austin, TX lab. The drive is not shipped to a partner facility for the mechanical step and brought back for imaging; the same technician who installed the donor head stack runs the imaging plan that follows.
Post-Swap Imaging and PRML Read Channel Re-Tuning
The patient with the donor heads installed first connects to the PC-3000 Portable III for adaptive parameter inspection. The equalizer coefficients, channel gain, and servo loop parameters were tuned for the patient's original heads, not the donor heads now in the enclosure. For the underlying signal-processing theory behind adaptive read-channel calibration for PRML and EPRML architectures, see our technical reference on the topic.
We retrieve the head map and zone tables from the patient's System Area with the PC-3000, reconcile the active head positions against the donor stack, and re-tune the read channel adaptives where needed. Heads that remain unstable after re-tuning are disabled in the active head map and excluded from the clone.
The user-area clone itself runs on PC-3000 in a strict head-by-head order: every reachable sector under one head is imaged, that head is retired from the active set, then the next head engages. The stable heads go first, because a drive in this condition can stop functioning before the job finishes.
Helium drive head crashes
Helium-sealed drives (Toshiba MG08, high-capacity Seagate Exos, and WD Ultrastar HC models) carry the same head crash failure modes as conventional air drives, with one extra constraint: the sealed chamber must be refilled with helium before the drive is closed. Donor sourcing and the refill are both handled in our Austin, TX lab. We do not refer or outsource helium mechanical work.
The clean bench procedure is the same: ULPA-filtered laminar flow, head combs in before either HSA leaves its ramp, donor slider inspection under low-angle light, and PC-3000 Portable III adaptive parameter inspection on the patient controller after the swap. The differences are donor sourcing and the helium refill step before the enclosure is sealed. Platter cleaning, when required, is performed on the same bench by the same technician before the donor HSA is allowed to spin up.
Helium head swap recovery is priced at $3,000–$4,500, and helium platter / surface damage recovery at $4,000–$5,000. Helium cost: $400-$800 additional for head swap and surface damage tiers. This covers the helium refill required after opening the sealed chamber. Helium donor drives must be an exact match. Typical donor cost: $200–$600 depending on model and availability, plus helium refill cost ($400–$800) required after opening the sealed chamber. For the full helium tier breakdown, see our helium drive data recovery page.
What this means for your drive
We evaluate the drive, photograph the platter condition, and tell you what is recoverable before any donor parts are committed. There is no diagnostic fee for this evaluation. If the readable user area does not include the files you need, you decline and pay nothing. The no data, no recovery fee guarantee covers head crash work, donor head matching, and post-swap imaging from the same Austin, TX lab that opened your drive.
Head Crash Recovery Pricing
A head crash lands in one of two tiers: a head swap when the platters are intact, and surface damage when the platters are scored and need cleaning before the donor heads go in. Donor parts are billed on top and consumed in the repair.
See our full pricing guide. All head crash recovery is covered by our no data, no charge guarantee.
Common Questions
Common Questions
Can I see the damage before deciding to proceed?
Yes. After our initial evaluation, we can send you photos of the platter condition along with our assessment of what's likely recoverable. You decide whether to proceed based on real information, not guesses.
My drive has "rings of death." Is there any hope?
Those visible rings are areas where the heads scraped the platters. Data in those rings is likely destroyed. But data outside the rings is often perfectly readable. We image what we can and give you honest odds on what's recoverable.
How long does head crash recovery take?
Typically 4-8 weeks. The time depends on finding an exact-match donor drive and the imaging process. Damaged platters require slow, careful imaging to avoid destroying more data. Rush service is available for critical cases.
What if only some files are recoverable?
We'll provide a file list showing what we recovered. You review it before paying. If the critical files you need are in the damaged zone and unrecoverable, you can decline and pay nothing. Our no data, no charge policy means you only pay for success.
Can a local repair shop handle head crashes?
They need a clean environment, a PC-3000, and donor drive inventory. Most don't have this equipment. Ask before you send your drive - if they say they'll "run a scan first," find someone else.
Get an Honest Assessment
We'll evaluate the damage and tell you what's recoverable. No data, no charge. Mail-in from anywhere.
