PhotoRec is a respected open-source file carving tool maintained by Christophe Grenier at CGSecurity. For logical data loss on a physically healthy drive, it does real work: scanning raw sectors for known file signatures and extracting recoverable data without writing to the source disk. If you accidentally deleted files or formatted a partition on a working drive, PhotoRec and its companion tool TestDisk are legitimate starting points. But if PhotoRec returned thousands of generically named files with no folder structure, produced corrupted outputs, or found nothing at all, the problem is likely below the software layer. File carving cannot fix broken heads or corrupted firmware, and it reads zeros on a TRIMmed SSD.
PhotoRec is the right tool when the drive spins up normally, is detected in BIOS/UEFI with its correct model number and capacity, and the target is a mechanical hard drive where deleted data remains magnetically on the platters. It does not work when the drive clicks, drops off the bus, or reports wrong capacity.
PhotoRec scans a storage device sector by sector, looking for known file signatures (magic numbers like FF D8 FF for JPEG or 50 4B 03 04 for ZIP). This approach works when:
The drive spins up normally and is detected in BIOS/UEFI with its correct model number and capacity
Files were stored contiguously (not fragmented across distant sectors). Small files like photos and documents are more likely to be contiguous than large files like videos or database archives
The target is a mechanical hard drive (HDD), not an SSD. On HDDs, deleted data remains magnetically on the platters until overwritten
The drive does not make clicking, beeping, or grinding sounds when powered on
File Signatures (Magic Numbers)
Binary byte sequences at the start of a file that identify its format. JPEG files begin with FF D8 FF; ZIP files begin with 50 4B 03 04.
File Carving
A recovery method that scans raw disk sectors for known file signatures without reading the filesystem. It cannot reconstruct filenames or folder paths.
In these scenarios, PhotoRec, TestDisk, R-Studio, and similar tools are appropriate first steps. If you want an alternative free method with more control over the imaging process, our ddrescue guide walks through sector-level cloning with GNU ddrescue on SystemRescue Linux before attempting any carving or filesystem repair.
PhotoRec limitations
Why Does PhotoRec Return Corrupted or Unnamed Files?
Carving files by their signatures loses the folder structure and the filenames. It also turns random binary data into false-positive .txt files. Those limits come with signature carving itself. They aren't bugs in PhotoRec.
The most common complaint from PhotoRec users is a recup_dir folder filled with generically named files (f0001234.jpg, f0005678.mp4) with no folder hierarchy. Some of these files open correctly; others are corrupted or truncated.
No Folder Structure or Filenames
Every recovered file gets a sequential numeric name.
If you need folder structure preserved, TestDisk (for partition repair) or R-Studio (for MFT reconstruction) are better starting points on a healthy drive.
Massive False Positives
Some file types lack definitive binary signatures. Plain text files, for example, have no magic number header. Random binary data can be misidentified as text, producing junk .txt files that contain nothing useful.
Damaged drive failures
Why File Carving Fails on Damaged Media
File carving fails on damaged media because PhotoRec communicates through the operating system's storage API and depends on the drive's hardware servicing standard read commands. Degraded heads, firmware corruption, SMR translator failures, and bus-drop events each stop the scan at the OS layer. PC-3000 bypasses the OS and accesses the drive firmware directly.
PhotoRec communicates with the drive through the operating system's storage API. It sends standard read commands, and the OS forwards them to the drive via SATA, NVMe, or USB. If the drive's hardware cannot service those reads, the software is stuck. Here is what happens at each failure point:
Degraded Read/Write Heads
When a head is partially failing, the drive's firmware retries each failed read multiple times before reporting an error to the OS. During those retries, the drive is unresponsive and PhotoRec freezes waiting for a sector response.
If the heads are severely damaged, a scan scores the magnetic coating faster, and that can turn a partial failure into a total loss.
PC-3000 addresses this by retuning the drive's read-channel adaptives to pull readable data off a degraded head.
Firmware Corruption
Hard drives store their operating firmware in a reserved area on the platters called the Service Area (SA). If the SA modules get corrupted, the drive may spin up and still fail to initialize. It could report 0 bytes capacity, or sit in a BSY (busy) state and not respond to any commands.
PhotoRec cannot scan a drive that has not finished its initialization sequence. PC-3000 sends vendor-specific ATA commands (VSCs) directly to the controller to access, read, and repair firmware modules without going through the OS.
Drive Dropping Off the Bus
When a drive encounters persistent read errors, its firmware may reset the SATA or USB interface. The drive disappears from the OS, PhotoRec's scan stops, and you have to reconnect and restart. USB enclosures make this worse: consumer USB-SATA bridge chips have short timeout thresholds and drop the connection when the drive does not respond in time. This is why experienced users clone with ddrescue on a direct SATA connection before attempting any carving.
SMR Drives and the LBA Translator
Some consumer hard drives use Shingled Magnetic Recording (SMR). SMR drives maintain an internal translator that maps logical block addresses (LBAs) to physical locations on overlapping tracks.
Rebuilding an SMR translator takes firmware-level access below the OS. We do that with PC-3000.
If PhotoRec freezes, the drive disconnects mid-scan, or you hear clicking: stop the scan and power down the drive. Each read attempt on failing hardware makes the final outcome worse. A drive that clicks or drops off the bus needs hardware-level recovery, not more software scans.
SSD: why PhotoRec finds nothing
Why PhotoRec Finds Nothing on SSDs
If you ran PhotoRec on an SSD and it returned zero files, the tool is working correctly. Once the controller has processed TRIM for a range of sectors, a carving tool that reads those sectors gets zeros back.
TRIM is enabled by default on Windows, and on macOS for Apple built-in SSDs (third-party SSDs require enabling TRIM manually with trimforce on macOS 10.10.4 and later). After TRIM reaches the controller for a range of sectors, PhotoRec, Disk Drill, EaseUS, and R-Studio read zeros there.
TRIM on SATA SSDs
Once TRIM executes, the controller reports those sectors as unmapped and returns zeros when they are read.
DEALLOCATE on NVMe SSDs
The NVMe equivalent of TRIM.
TRIM does not always reach the controller. If the SSD was in an external USB enclosure that does not pass TRIM commands, or the file deletion happened on a system where TRIM was manually disabled, the data may still exist on the NAND and PhotoRec can find it.
For SSD controller lockups (SATAFIRM S11 mode) where the drive is detected but unresponsive, the data is still on the NAND but requires SSD-specific firmware recovery using PC-3000 SSD to push the controller out of its lockup state.
PhotoRec and PC-3000 solve different problems. PhotoRec is free, open-source software that extracts files by signature from a functioning drive. PC-3000 is dedicated recovery hardware that communicates with a drive's firmware directly, bypassing the OS. One is not a replacement for the other; they operate at different layers of the storage stack.
Feature Comparison
Capability
PhotoRec File Carving
Lab Recovery with PC-3000
Folder structure and filenames
Lost. All output renamed to f0001234.ext in recup_dir folders
We rebuild them from MFT / FAT / NTFS metadata when that metadata survives
Drive with failing read/write heads
Accelerates damage
Targeted sector reads with head maps and reverse imaging
Firmware corruption (wrong capacity, BSY state)
Cannot access drive. Relies on OS device enumeration
Vendor-specific commands to the controller via PC-3000
SSD after TRIM / DEALLOCATE
Returns zeros for the TRIMmed sectors
We run controller diagnostics. Recovery depends on whether garbage collection has erased the blocks
Cost
Free (GPL license)
Standard HDD: $100–$2,000. SSD: $200–$1,500. No data, no fee.
Free vs commercial vs lab
Free Carver, Commercial Software, or a Lab
Most people who land here just watched PhotoRec disappoint them. The next step is not always a lab.
Recovery comes in three tiers, and which one you need depends on whether the drive hardware still works. For a healthy drive, you want filesystem-aware software like R-Studio or UFS Explorer.
Send the drive to us only when the hardware itself has failed, when heads click, firmware reports the wrong capacity, or the controller locks up.
Three-Tier Recovery Decision Matrix
Decision Factor
PhotoRec (free carver)
R-Studio / UFS Explorer (filesystem-aware)
Lab Imaging with PC-3000
Lost. Output renamed to f0001234.ext with no hierarchy
Rebuilt from MFT / FAT metadata when the drive is healthy
Metadata reconstructed after the drive is imaged below the OS
Drive with failing read/write heads (clicking)
Accelerates damage
No help. Sequential reads wear the heads further
Head maps, donor parts, targeted reads on the clean bench
Firmware corruption (wrong capacity, BSY)
Cannot access. Waits on OS device enumeration
No help. The user area is not readable through the OS
Returns zeros for the same TRIMmed sectors
Cost
Free (GPL license)
Paid commercial license
HDD from $100, SSD from $200. No data, no fee.
How Much Does Hardware-Level Recovery Cost?
PhotoRec is free. Our hardware recovery starts at $100 for HDDs and $200 for SSDs. These solve different problems: PhotoRec works when the drive is healthy and data is logically accessible. We handle cases where the hardware itself has failed. If software can solve your problem, it will cost less. If it cannot, no amount of software will change that. Evaluation is free, and if we can't recover your data, there's no recovery fee.
01
02
03
01
02
03
04
05
Shipping
Shipping
Shipping
Mail-in
✓Use the box-in-box method: float a small box inside a larger box with 2 inches of bubble wrap.
✓Wrap the bare drive in an anti-static bag to prevent electrical damage.
✗Do not use packing peanuts. They compress during transit and allow heavy drives to strike the edge of the box.
PhotoRec scans at the sector level, so it can only read what the SSD controller serves back to the operating system.
Is PhotoRec safe to use on a clicking hard drive?
No. A clicking drive has a hardware fault. Scanning it forces read retries that wear out weak heads and can score the platters, and that turns a partial failure into a total loss. If your drive clicks, power it down and don't run any software on it.
What is the difference between PhotoRec and TestDisk?
Both are free, open-source tools by Christophe Grenier (CGSecurity), and they are often bundled together. TestDisk is filesystem-aware: it analyzes and repairs partition tables, boot sectors, and MFT entries to restore access to the original folder structure. TestDisk preserves filenames and directory paths when it works; PhotoRec outputs generically named files (f0001234.jpg) with no folder hierarchy.
What is the best alternative to PhotoRec for data recovery?
It depends on the failure. If the drive is physically healthy and you need better filesystem parsing than PhotoRec provides, R-Studio or UFS Explorer can reconstruct folder structures from MFT/FAT metadata. If you want a free option, GNU ddrescue can clone a degrading drive at the sector level before you attempt carving. If the drive is clicking, not spinning, dropping off the bus, or detected with wrong capacity, no software will help. Hardware-level recovery with PC-3000 is required to access the drive below the OS layer.
Why did PhotoRec only recover random .txt files?
Plain text files have no definitive binary signature (no magic number header). PhotoRec's carving algorithm misidentifies random binary data as text content, producing junk .txt files containing fragments of unrelated disk sectors.
“I was a LaCie user for four years when an accidental drop from my desk resulted in LOSING all access to my drive. So much for the "durable" orange protective casing. All of my client's projects and years of work lost in a second. I was desperate and like many others, immediately googled and youtubed as many solutions as I could find. I tried everything short of breaking the manufacturer seal.”
“This is literally the first review I've ever written, and these guys absolutely deserve it. I had a hard drive fail after it was connected to a bad power supply and fried itself. I basically lost 6+ months of work and was devastated. I sent the drive Rossmann Repair and they managed to recover all of the data I lost, and sent it to me on a new 1tb external drive.”
“Top tier talent and outstanding customer service. Recovered my damaged SSD when others wouldn't even look at it. Walked me through the repair procedure and got everything I needed. Thank you Chris!!”
