Board-Level Microsoldering | Austin, TX Lab | From $500 | No Data, No Fee
Samsung Galaxy Water Damage Data Recovery
Liquid on a Galaxy board is an electrochemical problem. We strip the board, clean it ultrasonically to stop the reaction, replace what the corrosion consumed, and bring the phone back to a lock screen you can unlock yourself.
Does a Water-Damaged Galaxy Still Have Your Data?
Liquid bridging two points held at different voltages turns that patch of board into a galvanic cell, and metal starts leaving one side & plating out on the other. Pads that carried a rail stop carrying it, and shorts appear between things that were never connected.
Storage rarely participates in that. The flash package keeps what it holds without any help from the board around it, so a phone that has been sitting in a drawer since the day it went in the sink still holds the same ciphertext it held that afternoon.
On an encryption-era Galaxy, the phone's own secure hardware wraps the per-file keys. Pull the storage package off the board & read it in a socket, and all you get is ciphertext. The route to your photos is the opposite one: fix the board, let verified boot finish, & let you enter the credential that unwraps credential-encrypted storage on the original hardware.
Generation changes the bench work and not the ending. The Android & Samsung recovery hub lays out which models ship eMMC & which ship UFS, and neither answer moves the credential requirement one inch.
Stop Charging It and Keep It Powered Off
Voltage on a wet board is what drives the metal to dissolve. Every time you try to power the phone on, that reaction runs fast.
- A charger is a current source pointed at an electrolyte. With no power on it, the same board corrodes slowly.
- Quit pressing the power button to check. Every attempt energizes rails that are sitting in solution. The answer does not improve with repetition, & the board gets worse each time.
- Keep it out of Download Mode. Odin writes Samsung-signed firmware to the phone. It has no documented way to read your files out, & picking the wrong CSC can wipe the phone.
- Skip the drying advice. Rice, and every other passive drying ritual, addresses moisture in an air gap. The corrosion is under the BGA packages where the liquid wicked in, and drying the outside of a phone does nothing about a pad that has already dissolved.
- Write down what it went into. Salt water leaves its dissolved minerals on the board as conductive deposits after the water's gone, & sitting in a drawer won't remove them.
- Get it on a bench quickly. Mail-in works from any state, evaluation costs nothing, and there is no diagnostic charge, so finding out what is left does not commit you to a repair.
Charging Circuit and Main PMIC Faults After Liquid
Samsung makes its own power silicon, & on its Exynos-architecture boards two parts split the job.
- S2MU charging IC
- It handles the USB port & charging, the input side of the board.
- S2MPS main PMIC
- It generates the core rails. Those are the supplies the processor, the RAM, & the storage package run on. Corrosion that reaches here is deeper into the board and changes the conversation, though it is still component work.
Triage is a multimeter in diode mode, not software. Nothing enumerates on a board that will not power, so each rail gets read to ground & compared against a known-good board of the same model. A rail at or near 0.000 V is a hard short; a line doing its job answers with a few hundred millivolts.
One rail carries a different meaning from the rest. A short on VDD_CORE points at the processor itself. On a file-based-encryption phone, a destroyed processor takes the encryption keys with it.
The full intake order, from current draw at the port through rail mapping, is written out on Samsung won't turn on data recovery.
Board Symptoms and Their Data Prognosis
What the board does on a bench supply narrows the fault long before anything comes off it, and each behaviour carries its own answer about whether the data survived.
| What the board does | Circuit implicated | What it means for the data |
| Draws near zero from a known-good charger and never appears on a PC | The S2MU charging IC, the USB-C assembly, or the charge control path around them | Best branch on this table. The fault never reached the processor or the storage, so the payload waits behind a component replacement |
| VDD_CORE reads at or near 0.000 V to ground after the board has been cleaned | The processor itself rather than anything feeding it | Worst branch. A destroyed processor takes the encryption keys with it |
| Foldable: no power, shutdowns past a fold angle, or false battery-temperature warnings | The hinge-routed flexible printed circuits carrying power rails and battery interconnects between the main board and the sub-board | Often good. The interconnects mimic a dead motherboard while both boards and the storage stay healthy |
Diode mode reports a voltage drop from a test point to ground, so the reading only means something next to a reference. A value that looks low on one model is normal on another, which is why the comparison is against a working board of the same model rather than against a number someone published.
Bench Sequence for a Corroded Galaxy Board
Order is most of the work. The corrosion gets photographed & mapped under the stereo microscope before anything is cleaned, because the residue distribution is the record of where the liquid travelled, & a cleaned board no longer carries it. Documenting it damages nothing & costs one step.
Cleaning then has to come before any short gets localized. Ionic contamination left on the board keeps the reaction running: metal dissolves off one side of a wetted span & plates back out as dendrites that bridge fresh points between one measurement and the next, so a short map taken through live corrosion is a moving target.
Probing a board before cleaning it measures the residue rather than the circuit, and energizing one before inspecting it can turn a two-component job into a much longer one.
- Disassemble and disconnect the battery. The cell is the one power source still attached to a phone nobody has plugged in, so it comes off before anything else happens.
- Inspect and photograph under the stereo microscope. The corrosion pattern gets mapped & photographed here, before anything is cleaned, because the residue is often the only record of which subcircuits the liquid reached. Dendrites bridging pads, consumed traces, missing or blackened passives, and connector pins that no longer have plating on them. This is where the parts list for the repair comes from.
- Pull the EMI shields. We can't reach liquid that got under a shield while the shield is still on. Leaving them on is how a board fails again weeks later.
- Clean it ultrasonically. With the pattern on record, the ultrasonic cleaner halts the reaction and displaces what is trapped under the BGA packages, where the corrosion concentrates and no wipe reaches.
- Replace what the reaction consumed. Component work runs on a Hakko FM-2032 on an FM-203 or FX-951 base station; packages come off under Atten 862 hot air, & reballs run on a Zhuo Mao station. Severed traces get reconstructed with jumper wire under the scope.
- Power it on a leash. A current-limited DC supply feeds the board with a ceiling on what any remaining short is allowed to pull, and a FLIR thermal camera watches which part turns that current into heat. The part identifies itself instead of being guessed at.
- Boot it, then hand it to you. Once verified boot completes and the phone reaches the lock screen, the rest is yours: your PIN, pattern, or password unwraps credential-encrypted storage on the original hardware, and the files copy off normally.
Nothing in that sequence is a drying step, because drying is not the problem being solved. A board can be bone dry and still be dissolving.
All of it happens at one bench in Austin, so nothing gets handed to a partner lab for the parts of the job that are inconvenient.
Galaxy S22 Ultra Stacked Boards
Boards on the S22 Ultra generation come as two layers joined by an interposer. That stack has a failure of its own that shows up without any liquid.
Thermal stress fractures BGA joints under the processor or inside the interposer, and the phone loops at the boot splash or dies intermittently.
The board-repair community says the tell is temperature. Chilling the phone contracts the stack, & that can briefly re-bridge a fractured joint. That window is a diagnostic clue & a chance to copy files. It's never a repair. The lasting fix is separating the stack & reballing it.
Samsung Galaxy boot loop recovery covers that thermal failure in full.
Hinge Ingress on Galaxy Z Fold and Z Flip Phones
Foldable ingress ratings run behind the slab flagships, and the spec sheet is worth reading before assuming a phone was sealed.
| Generation | Ingress rating | What the rating certifies |
| Fold 1, Fold 2, and the original Z Flip | None | No certified protection against either water or dust |
| Fold 3 and Flip 3 through Fold 5 and Flip 5 | IPX8 | Water resistance tested; the X records zero certified dust protection |
| Fold 6 and Flip 6 | IP48 | The first certified dust rating on a Galaxy foldable, alongside the water rating |
No Galaxy foldable through that generation carries an IP68 rating, which is the number people assume they bought. Dust rides the hinge into the chassis on the earlier models, wears the folding interconnects, and presses into the inner OLED from its unsupported underside.
Liquid uses the same opening & finds a different board layout on the other side. A Fold or Flip splits its electronics across a main board and a sub-board, and every power rail, battery interconnect, display signal, and data line between the halves crosses the hinge on flexible printed circuits. One battery cell sits in each half.
That means two things for us on the bench. Liquid that gets in at the hinge spreads across the main board & the sub-board, so we trace shorts across more than one board.
And a worn or corroded hinge interconnect presents as total power loss, charging failure, shutdowns past a certain fold angle, or a false battery-temperature warning, all of which read like a dead motherboard while both boards are alive.
To get to any of that, we have to take off displays that teardowns treat as destroyable during disassembly. An inner panel that has gone black along the crease is, in the typical documented case, a display fault: the boards are running and the encrypted data is intact behind the dead screen.
What Can Desktop Recovery Software Do for a Wet Galaxy?
The demo scans are honest about what they are once you know what to look for. A tool listing photos off a working phone is listing files that still exist, plus cached thumbnails it never had to decrypt anything to reach.
Three separate barriers sit between that demo and a liquid-damaged handset. Those tools work over MTP & ADB, which expose files and never a block device. The keys for credential-encrypted files only exist in kernel memory after the owner unlocks the phone. USB debugging has to have been switched on before the accident. And an ADB session needs the host's RSA key approved in a dialog on an unlocked screen, which is a screen this phone no longer has.
Deleted files are a separate question with a harder answer. Under file-based encryption each file carries its own key, deletion destroys that key, and the storage layer trims the blocks, so permanently deleted internal-storage data is not coming back from any scan. A factory reset does the same thing to everything at once.
What does work sits off the handset or in an app-level holding area, & it is worth checking before a board ever ships:
- Samsung Gallery Trash holds recently deleted photos for about 30 days, because those items were never actually deleted. It needs a working, unlocked phone.
- The unified My Files trash in One UI 6 and later also holds recently deleted Gallery and Voice Recorder items, with the same requirement of a phone you can get into.
- Google Photos and OneDrive trash live on a server, so a drowned phone has no vote in whether you can reach them.
- Existing Smart Switch backups sit on a PC or another device and predate the accident.
- Older Samsung Cloud backups restore without the handset. Backups made with Enhanced Data Protection turned on are end-to-end encrypted & need the recovery code you got when you turned it on.
If one of those already has your photos, we will say so and charge you nothing for the sentence. Board work is what is left when they do not.
Some Liquid-Damaged Boards Are Past Recovery
A lab earns its credibility by naming the states where the answer is no, and we would rather hand you that answer at intake than three weeks later with an invoice attached.
- Cracked or electrically destroyed processor die
- The hardware-held keys died with it, so moving the storage package to a donor board produces a phone with unreadable ciphertext in it.
- Dead UFS controller on a file-based-encryption phone
- The host cannot query the device descriptor, and the payload behind that controller is hardware encrypted, so there is no fallback of the kind an older eMMC board sometimes allows. That older class has its own treatment on eMMC data recovery.
- A factory reset that already happened
- Key material for every file is destroyed at once, and no scan reverses it.
- A tripped Knox warranty fuse
- The fuse is one-way, and a tripped one withholds the Secure Folder container keys permanently. Everything outside that container is a separate question.
- An end-to-end-encrypted cloud backup nobody can open
- Samsung does not store the recovery code. Once the code and every device that could open the backup are gone, nothing opens it.
Those are cryptography and physics rather than effort levels, so no price and no tool moves any of them.
Between repair and terminal sits the transplant, and it is narrower than the version people are usually quoted. The storage chip never moves alone.
A viable transplant moves the processor with its package-on-package RAM and the storage package together as a paired set, and on Galaxy S21 and newer flagships the discrete secure element goes with them or the repaired phone boots and then rejects the correct PIN.
The storage is bound to the original processor through its Replay Protected Memory Block, which is why a cloned or substituted package is rejected outright rather than merely unreadable. Samsung's heavy underfill turns the removal itself into a long job before any reballing starts.
Your credential is the last boundary, and it is not one we pretend to move. Keys for credential-encrypted storage come from what you know combined with secrets the secure hardware releases, wrong attempts are throttled inside that hardware by Gatekeeper and Weaver, and a lock, Factory Reset Protection, or the Knox fuse is not something this bench removes or works around.
What Does Galaxy Water Damage Recovery Cost?
No data, no fee. Free evaluation. No diagnostic charges. We quote the number firm after a free evaluation, so you never approve work against an estimate.
Every step happens in-house at 2410 San Antonio Street in Austin, Texas, in a shop that has been doing board-level work since 2008. It is one location that has never franchised or outsourced a job. A board that comes back terminal leaves you owing nothing.
Drop it off during business hours, or put it in the mail from any state. A free evaluation comes first, then a firm number, then your decision.
See the particle counter test at the benchQuestions About Liquid-Damaged Galaxy Phones
Does putting a wet Galaxy in rice save it?
My Galaxy got wet and still turns on. Do I need to do anything?
Does a tripped liquid detection indicator affect data recovery?
Is salt water worse than tap water?
Can you get data off a Galaxy that never powered on again?
Do you need my PIN, pattern, or password?
What does liquid-damage data recovery cost on a Galaxy?
Related Samsung Recovery Pages
Generations, encryption reality, and the rest of the fault catalog
Current draw at the port and the per-rail prognosis map
Thermal fracture, interposer cracking, and Odin flash semantics
Controller death and what sits behind it on legacy boards
How to ship a liquid-damaged phone to the Austin lab
What happens when a recovery does not produce data
Phone went in the water?
Take it off the charger and send it before more current runs through the corrosion. Evaluation is free, the quote is firm, and a recovery that produces nothing is not billed.
