Board-Level Microsoldering | Austin, TX Lab | From $500 | No Data, No Fee
Samsung Galaxy Boot Loop Data Recovery
A Galaxy that loops at the Samsung logo, restarts at the lock screen, or dies a minute after it boots is telling you about a board fault, not about erased storage. Your files are almost always still sitting in the UFS or eMMC package. We repair the fault that blocks boot so the phone starts normally and decrypts its own storage when you enter your screen lock.
14 min read
Data survival
Does a Boot-Looping Galaxy Still Have Your Data?
Almost always, yes. The encrypted payload sits intact in the UFS or eMMC package while a board fault blocks boot. The permanent exceptions include a destroyed processor die, a dead UFS controller, and a factory reset. Board-level repair restores the boot path so the phone decrypts its own storage under your screen lock.
In a loop, the phone is drawing current, the processor is running, and the boot chain is getting far enough to put something on the screen. What fails is somewhere between that point and a finished Android boot.
A donor board has to match the original by processor variant, an S24-era board exposes no usable test points, and the A05 and A06 still carry eMMC while the flagships moved to UFS years ago. That whole matrix sits on the Android and Samsung recovery hub. What none of it moves is the credential; the phone still needs yours.
Before it ships
Copy What You Can Before Anyone Flashes the Phone
  1. Use any window you get. If the phone reaches the home screen at all, even for a minute, start copying right then. Run a Smart Switch transfer to a computer. Grab the irreplaceable files first instead of going for a complete backup.
  2. Leave the factory reset alone. Under file-based encryption a reset destroys the key material for every file at once, so it converts a repairable phone into a permanent no. The same applies to wiping the data partition from Android Recovery.
  3. Do not flash standard CSC firmware. That binary tells Odin to wipe userdata. It's a factory reset with extra steps, and on 2025-and-later flagships even the userdata-preserving file is a live wipe risk.
  4. Stop charging a phone that got wet. Applied power is what drives the corrosion, so every charge attempt after liquid exposure eats more copper off the traces.
  5. Send it while the board is still cleanable. Evaluation is free and there is no diagnostic charge, so a phone on the bench costs you nothing until there is a firm number and a decision. Mail-in works from anywhere in the U.S. and all of the work happens at our Austin lab.
Fault classes
Boot-Loop Fault Classes on Galaxy Boards
A boot loop is a symptom, not a diagnosis. What separates the classes is not the splash screen; it is the pattern around the splash screen, meaning temperature correlation, what Download Mode reports, and what the phone was doing when the loop started.
What the loop doesWhat it implicatesWhat it means for the dataWhat must not happen
Boots cold, dies once it warmsFractured BGA joints under the processor, or a crack inside the dual-layer interposer joining the stacked board; documented by the repair community on the S22 UltraPayload intact. The fault is an intermittent electrical break, not a storage failureNo firmware flash. A reflash cannot reach a cracked joint, and it burns the cold-boot window that should have been spent copying files
Loops at any temperature, with a storage read failure in Download ModeThe storage device itself. On the legacy S5, Note 4, and Note Edge class that means eMMC controller deathThe cells behind the controller are usually fine; the controller that addresses them has stopped answeringNo PIT file, no firmware write. Both push writes at a chip that cannot complete a read
Loops after a failed update or an interrupted flashA partition state the bootloader refusesEncrypted payload untouched, and your credential still unwraps it once the phone bootsNo standard CSC binary and no repair firmware. Both wipe userdata by design
Loops after liquid exposureElectrolytic corrosion under the packagesGood odds while the reaction is halted early, falling with every power cycle the phone getsNo charging and no power-on tests. Current through the electrolyte is the mechanism that eats the board
Reaches the lock screen, then restartsOn its own, this symptom won't tell you what brokeThe phone already reaches the state where your credential can be enteredNo repeated retry cycling in the hope it settles. Each heat cycle works the fracture wider
S22 Ultra class
Galaxy S22 Ultra Thermal Fracture and Interposer Cracking
The S22 Ultra board is a stack. Two boards sit face to face, joined by a dual-layer interposer frame that carries the signals between them, and the processor sits under its package-on-package RAM in the middle of that heat. Repeated thermal cycles fatigue solder, and fatigued solder cracks.
What the board-repair community documents on this model, across both the Snapdragon 8 Gen 1 and Exynos 2200 builds, is fracture at the BGA joints under the processor or inside that interposer. The phone loops at the boot splash or dies intermittently. This is community bench consensus rather than a Samsung-published defect notice.
Temperature is the tell. Cooling the assembly contracts it and can press a cracked joint back into contact for a few minutes; warming re-opens the gap. A phone that boots out of a cold room and dies once it is warm in your hand is describing expansion and contraction across a break, not corrupted firmware.
Advice to put the phone in a freezer describes a real phenomenon and then draws the wrong conclusion from it. The crack doesn't care. Chilling buys a window, and the only good use of that window is copying files out of the phone while it is up. Treat it as a backup opportunity and nothing else.
The lasting path is mechanical. The stack gets separated, the fractured packages come off under controlled heat on an Atten 862 hot air station, and the processor & RAM are reballed and set back down on a Zhuo Mao BGA station with the placement checked under a stereo microscope. Reflashing doesn't touch any of that, which is why a flash-first approach on this fault class costs data and buys nothing.
The liquid-damage variant of the same architecture behaves the same way from the outside. Shorts hide inside the interposer layer where nothing is visible with the boards mated, so the stack has to come apart before the board can be cleaned ultrasonically and probed between the layers.
When the original board is past reballing, the remaining route is a paired-set transplant onto a donor board matched to that phone's processor variant and model number. This generation shipped in both Snapdragon 8 Gen 1 and Exynos 2200 builds, so the donor gets chosen off the model number rather than off the marketing name.
Flash semantics
What Does an Odin Flash Do to Your Data?
Odin writes firmware; it cannot read your files out. Which file you flash decides whether userdata survives: standard CSC and repair firmware wipe it, HOME_CSC was the preserving choice, and on 2025-and-later flagships even HOME_CSC carries a real soft-brick risk. Flashing a phone with failing storage can finish the data off.
CSC and HOME_CSC Decide Whether Userdata Survives
A Samsung firmware package carries both binaries. Load the standard CSC and it tells Odin to wipe the userdata partition. That's a factory reset done through a cable, and repair firmware does the same thing. HOME_CSC was built to update the regional configuration and the firmware while leaving user data and settings in place.
That distinction has gotten less reliable. The A/B partition structure on the Galaxy S25 series makes HOME_CSC flashes trigger unrecoverable soft-bricks often enough that any Odin flash on a 2025-or-later flagship carries a real risk of forcing a full wipe. There is no data-safe flash on those boards, only a less-bad one.
Even a hypothetical raw dump pulled through that interface would come back as file-based encryption ciphertext, because the credential-derived keys never exist outside a booted phone. Flashing a non-matching bootloader binary trips the Knox warranty fuse, and a tripped fuse withholds the Secure Folder container keys permanently, even after the phone is repaired and boots normally.
Rollback Protection Blocks Downgrades Below the Recorded Binary Revision
Android Verified Boot records a rollback index, and Samsung exposes it as the binary revision counter shown in Download Mode, the line the bench reads as the BIT or SW REV value. The bootloader refuses to flash or boot any image whose revision sits below the recorded value.
Same-revision flashes stay routine. What is gone is the route backwards: once the index advances, there is no path to an older build, and no amount of hunting for an old firmware file changes that. Plan around the revision the phone already carries.
What Does a Storage Read Failure in Download Mode Mean?
The error string on the screen routes the job, so it is worth reading before anything gets connected.
Only official released binaries are allowed to be flashed
OEM Unlocking is off and the bootloader is refusing unsigned images. That is a configuration state, not a fault, and it leaves a hardware route as the way forward.
MMC read fail
The host could not read the internal storage. That points at the storage device itself rather than at a corrupted partition table, and on legacy Galaxy boards it usually means the eMMC controller has stopped answering. eMMC recovery covers what is still readable behind a dead controller and how the encryption era narrows it.
Tutorials keep implying otherwise. There is no wipe-then-recover sequence under file-based encryption. Deletion destroys the per-file key, F2FS discard and scheduled fstrim clear the physical blocks, and no scan afterwards reverses either step.
Power triage
Power-Fault Triage With a Multimeter in Diode Mode
A phone that loops and then dies is a power question as much as a firmware one, and nothing about the loop itself tells you which rail went marginal. So the bench measures instead of guessing.
On Samsung's Exynos-architecture boards with standard PMIC layouts the power silicon is Samsung's own, split across two jobs. The S2MPS family is the main power management IC. It makes the core rails that feed the processor, the RAM, and the storage. The S2MU family is the sub-PMIC, and it handles the USB interface and charge control.
That split matters because it decides the prognosis before a single component comes off. A fault on the charging and USB path leaves the processor and the storage untouched, which means the encrypted payload is sitting there intact behind a repair. A short on the core rail implicates the processor itself, and on a file-based-encryption phone a destroyed processor means destroyed keys.
Diode mode is the instrument. Each rail gets read to ground against known-good values: a reading at or near 0.000 V is a hard short, while a healthy signal line reads a few hundred millivolts. A current-limited DC supply feeds the board while a FLIR thermal camera finds the part that heats, and the failed component comes off and gets replaced with a Hakko FM-2032 on an FM-203 or FX-951 base under the microscope.
Liquid jobs add a step in front of all of it. The phone comes apart, the shields come off, and the board is cleaned ultrasonically to stop the reaction before anyone starts looking for shorts, because probing a board that is still corroding measures a moving target.
Donor work
Paired-Set Transplant to a Matched Donor Board
Some boards don't come back. When the fracture damage is past reballing or the substrate itself is compromised, the remaining route moves the phone's own silicon to a donor board. The storage chip never travels alone.
The set is the processor with its package-on-package RAM, the UFS or eMMC storage, and, on Galaxy S21 and newer flagships, the discrete Knox Vault secure element that the bench calls the EEPROM or Pin Code IC. A budget model like the A05 doesn't have a Knox Vault, so there's no secure element to move. Leave that secure element behind on a phone that has one and the repaired handset boots, then rejects the correct PIN.
The RAM is in the set for mechanical reasons rather than cryptographic ones. It sits stacked directly on the processor, and splitting the two adds reballing risk with no benefit, so it moves as one assembly.
The binding that does matter runs through the Replay Protected Memory Block inside the UFS package. RPMB stores rollback counters and secure state authenticated with a key the secure environment holds, so a cloned storage chip cannot reproduce that authentication and a donor storage chip is rejected outright. The original chips, moved together and kept in step, still decrypt.
Samsung uses heavy underfill resin, and that turns the removal alone into a long job before any reballing starts. It's quoted from the same $500–$750 range as every other Android phone job.
Honest limits
Which Boot-Loop Outcomes Are Permanent?
Five outcomes are permanent. No amount of money or equipment changes that. One is a cracked or electrically destroyed processor die, and another is a dead UFS controller on an encrypted phone. A completed factory reset is a third. A Knox container whose warranty fuse tripped is a fourth. The fifth is an end-to-end-encrypted Samsung Cloud backup, once the recovery code and every device that could open it are gone. Those are cryptography and physics, not effort levels.
A destroyed processor takes the keys with it, so a paired-set transplant onto another board recovers nothing; there is no longer anything that can unwrap the ciphertext. A dead UFS controller leaves the host unable to read even the device descriptor, and the payload behind it is hardware encrypted, so there is no fallback of the kind an older eMMC phone sometimes allows.
Both of those answers are short, and we would rather say so at intake than at the end.
Your credential is the other hard boundary, and it's a boundary we don't pretend to move. Credential-encrypted storage derives its keys from your PIN, pattern, or password together with secrets released by the phone's secure hardware, and Gatekeeper and Weaver rate-limit wrong attempts inside that hardware.
We repair the board so that you unlock the phone. We do not defeat, remove, or work around a screen lock, Factory Reset Protection, or the Knox warranty fuse, and unlock requests are not work we take.
On Exynos and Qualcomm Galaxy phones, and on any model carrying a discrete secure element, credential-unknown extraction is off the table. Older MediaTek budget parts without a secure element carry a documented BootROM exception class that forensic operators reach on a live board; that is forensic tooling in someone else's field, it never extends to flagships or Knox Vault devices, and it is not something this lab performs, prices, or offers.
What Does Boot Loop Recovery Cost?
Samsung boot loop recovery is $500–$750, one flat range quoted firm after a free evaluation. It's the same range for every model. There is no diagnostic charge either, and if the recovery produces nothing there is no fee.
An S22 Ultra with a fractured interposer and a budget A-series board with a shorted charging path are quoted from the same range.
Every step happens in-house at 2410 San Antonio Street in Austin, Texas. We have one location and no franchises, and nothing gets shipped out to a partner lab. Rossmann Repair Group has done board-level work since it was founded in 2008. If the recovery doesn't produce your data, there is no charge.
Walk it in during business hours or ship it to the lab from anywhere in the country. Start with a free evaluation and you get a firm number before anything is authorized.
Questions We Get About Looping Galaxy Phones
Will flashing my Galaxy in Odin delete my photos?
It depends on which file goes into which slot, and that's a bad bet to take with the only copy of your photos. A Samsung firmware package ships both a CSC and a HOME_CSC binary. The standard CSC tells Odin to wipe userdata. That's a factory reset, just delivered over a cable. HOME_CSC was the file designed to leave user data and settings in place, but the A/B partition structure on the Galaxy S25 series makes HOME_CSC flashes soft-brick phones often enough that any Odin flash on a 2025-or-later flagship carries a real risk of forcing a full wipe. Odin also has no documented way to read your files out, so a flash spends your risk budget without ever producing a copy.
My S22 Ultra boots when it is cold and dies when it warms up. What is that?
That temperature correlation is the signature the board-repair community documents on the S22 Ultra, on both the Snapdragon 8 Gen 1 and Exynos 2200 builds: thermal stress has fractured BGA joints under the processor or inside the dual-layer interposer that joins the stacked board. Chilling the phone contracts the stack and can press a cracked joint back into contact. Use that window to copy files, because warming re-opens the fracture and the crack is still there either way. The lasting fix is mechanical, meaning board separation and a reball, or a paired-set transplant when the board is past that.
Should I factory reset a Galaxy that keeps rebooting?
Not if the data matters. Under file-based encryption every file carries its own key, and a factory reset destroys that key material for everything at once. There is no scan on the other side of a reset that brings it back, and F2FS discard plus scheduled fstrim clear the physical blocks anyway. Wiping the data partition from Android Recovery does the same thing to the same files. If you want the phone usable and you have a current backup elsewhere, a reset is a reasonable repair step; if the phone holds the only copy, it's the end of the job.
Download Mode reports a memory read failure. What does that mean?
It means the host could not read the internal storage, which is a hardware answer rather than a corrupted partition table. On the legacy Galaxy fleet of the S5, Note 4, and Note Edge class it usually means the eMMC controller has stopped answering the processor. Flashing a PIT file or firmware at that point pushes writes at a chip that cannot complete a read, and that can finish off what is left. eMMC recovery goes into what sits behind a dead controller and what the encryption era does to it.
Can you recover data if the phone never reaches the lock screen?
Usually, because the barrier is the boot path rather than the storage. The encrypted payload sits in the UFS or eMMC package while a power fault, a corroded rail, or a fractured joint stops the board from finishing its boot. We repair that fault so the phone boots normally, and then you enter your own screen lock and the phone decrypts its own storage in place. If the processor die itself is cracked or electrically destroyed, the keys went with it and the answer is no.
Do you need my PIN, pattern, or password?
Yes, and there's no version of this job where we work around it. Credential-encrypted storage derives its keys from your credential together with secrets the phone's secure hardware releases, and Gatekeeper and Weaver rate-limit wrong attempts inside that hardware. Our half of the job is the hardware and yours is the credential. Screen locks, Factory Reset Protection, and the Knox warranty fuse are not things we defeat, remove, or work around, and unlock work is not something this bench takes.
How much does Samsung boot loop recovery cost?
Boot loop recovery is quoted from the same flat Android range as every other phone job: $500–$750. There are no model-based tiers, so an S22 Ultra with a fractured interposer and a budget A-series board with a shorted charging path are quoted from the same range. Evaluation is free, there is no diagnostic charge, and if we cannot recover your data you pay nothing.
Galaxy stuck at the Samsung logo?
Send it before anyone flashes it. Free evaluation, firm quote, and no fee if we cannot recover your data.
