How Fusion Drive Recovery Works
A Fusion Drive is two physical drives managed as one logical volume. Recovery requires handling both.
Apple introduced the Fusion Drive in late 2012 as a middle ground between pure SSD speed and HDD capacity. A small SSD blade holds the files you use most, and a spinning hard drive holds the bulk of your data. macOS ties the two together with CoreStorage (through High Sierra) or APFS (Mojave and later). You see them as a single volume.
When a Fusion Drive fails, the recovery path depends on which component broke. If the HDD has a mechanical failure (clicking, head crash, motor seizure), we perform a standard hard drive recovery on the HDD, then merge its image with the SSD data to reconstruct the full volume. If the SSD blade has a firmware lockout or controller failure, we address that through our SSD recovery workflow. If both components are functional but the logical volume is corrupted (the "split" scenario), we image both drives and rebuild the volume metadata offline.
All Fusion Drive recovery work is performed in-house at our Austin, TX lab using PC-3000 and a ULPA-filtered clean bench for any head swap work on the HDD component.
