Mac Data Recovery
iMac, Mac Pro, Mac Mini. Fusion Drive, APFS, FileVault, T2, Apple Silicon. We recover data from every Mac desktop architecture, in-house at our Austin lab.
Updated April 25, 2026
24 min read
No Data = No Charge
T2/M-Series Board Repair
In-House Austin Lab
Nationwide Mail-In
Quick Answer
Mac Data Recovery: What You Need to Know
Mac data recovery covers four storage architectures: spinning hard drives, Fusion Drives, removable SSD modules, and soldered NAND with hardware encryption. T2 and Apple Silicon Macs encrypt all storage through the Secure Enclave using AES-256. Recovery requires repairing the original logic board so the Secure Enclave can initialize and decrypt the APFS volume in place.
Mac Storage Architectures
Overview
Mac data recovery covers four distinct hardware architectures, each with a different recovery path.
Soldered NAND (Apple Silicon & T2)
Storage is hardware-encrypted to the logic board's Secure Enclave using AES-256. Recovery requires component-level micro-soldering to restore power to the SoC, not chip-off extraction.
Proprietary & Fusion Drives (Intel Macs)
Older architectures use removable PCIe blades or hybrid SSD/HDD CoreStorage volumes. Recovery requires PC-3000 with specialized adapters to communicate with failing controllers or reconstruct logical volumes.
Apple's Mac lineup uses four storage architectures: spinning hard drives (older iMacs and Mac Pros), Fusion Drives (iMac 2012-2019), removable proprietary SSD modules (Mac Pro 2013, some iMacs), and soldered NAND with hardware encryption (T2 iMac Pro, all M-series Macs). Each architecture requires a different recovery approach, and we handle all of them in our Austin lab using PC-3000 and a ULPA-filtered clean bench.
For Macs with T2 chips or Apple Silicon (M1/M2/M3/M4), storage encryption is tied to the Secure Enclave on the logic board. Chip-off or NAND removal produces only ciphertext. Recovery requires repairing the board so the Secure Enclave can initialize and decrypt the volume in place.
Looking specifically for MacBook recovery? See our dedicated MacBook data recovery page, which covers every MacBook generation from 2015 through M4.
Why MacBook Logic Board Repair is Required for Data Recovery
On all Apple computers equipped with a T2 security chip or Apple Silicon, standard data recovery techniques cannot bypass a dead logic board. MacBook logic board repair is a mandatory prerequisite for data extraction because of Apple's unified encryption architecture.
Hardware-Bound Encryption
Every byte of data on an M1, M2, M3, or M4 Mac is encrypted by the SoC's Secure Enclave using AES-256. The encryption keys are derived from a UID fused into the silicon during manufacturing. Removing the NAND chips produces mathematically inaccessible ciphertext.
Component-Level vs. Board Swap
Apple's standard repair path replaces the entire logic board, permanently separating your encrypted data from its unique decryption key. We repair the original board at the component level using micro-soldering to preserve the cryptographic pairing between the NAND and the Secure Enclave.
Mac Data Recovery Video
Mac Board Repair for Data Recovery
Watch a real diagnostic and repair session on a MacBook with an undetected soldered SSD.
Mac Data Recovery in Austin
Rossmann Repair Group performs all Mac data recovery at our lab at 2410 San Antonio Street in Austin, TX. Every Mac model from 2006 towers through 2024 M4 hardware is diagnosed and repaired in-house using PC-3000 and micro-soldering equipment. No outsourcing, no middlemen. Walk-in or nationwide mail-in.
Our lab at 2410 San Antonio Street in Austin, TX handles every Mac recovery in-house, from 2006 Mac Pro towers to 2024 M4 Mac Minis. Austin walk-in customers drop off their Mac directly at the lab; out-of-state customers ship via our mail-in service with the same turnaround and pricing.
Local Austin computer repair shops that accept dead MacBooks typically do not perform component-level board work. They package the Mac and ship it to a third-party national lab, adding their own markup to the final price. The customer pays more and waits longer because the Mac travels twice: once to the shop, then to the actual recovery facility.
The distinction matters on T2 and Apple Silicon Macs. A shop that replaces the logic board to "fix" the Mac permanently separates the soldered NAND from its paired Secure Enclave. The encryption keys exist only inside the original SoC.
Once a different board is installed, the data on the old board's NAND is cryptographically inaccessible. Our Austin technicians repair the original board at the component level: replacing a failed CD3217 USB-C controller IC or ISL9240 charging IC via micro-soldering, preserving the Secure Enclave and the encryption keys it holds. The Mac's storage decrypts itself once power is restored to the SoC.
Our West Campus location sits one block from the University of Texas at Austin, serving Travis County and Central Texas. All diagnostic imaging, ultrasonic board cleaning, and clean bench work happens on site. Walk in Monday through Friday for a free microscope evaluation and firm price quote, or use our nationwide mail-in service from anywhere in the country.
In-House Laboratory vs. Mobile Repair
Some Mac repair services in Austin operate as mobile, on-site technicians. Mobile technicians cannot physically transport PC-3000 Express hardware, ULPA-filtered laminar flow benches, or Hakko FM-2032 micro-soldering stations to a home or office. Our dedicated laboratory at 2410 San Antonio Street keeps your Mac in a secure, static-safe facility with the full diagnostic & repair infrastructure required for component-level board work.
Common Symptoms of Mac Storage Failure
What Are Common Symptoms of Mac Storage Failure?
Flashing folder icons, infinite boot loops, and "uninitialized disk" warnings are the three most common Mac storage failure symptoms. Each indicates a different hardware or firmware fault. Running Disk Utility or reinstalling macOS on a physically failing drive overwrites recoverable data.
Flashing folder with a question mark
Indicates the Mac's firmware cannot locate a bootable volume. On T2/M-series Macs, this typically means failed NAND or APFS container corruption.
Infinite boot loops and kernel panics
Often caused by corrupted APFS checkpoint data or degrading NAND cells. On encrypted Macs, a shorted power rail prevents Secure Enclave initialization.
Disk shows as "Uninitialized" in Disk Utility
Means the partition map or APFS container superblock is damaged. Do not accept Disk Utility's offer to erase and reformat.
Mac storage failures produce specific on-screen symptoms that look like software problems but frequently stem from hardware damage. Recognizing these symptoms prevents users from running Disk Utility or reinstalling macOS on a physically failing drive, which overwrites data.
Flashing folder with a question mark: the Mac's EFI firmware cannot locate a bootable volume. On older Macs, this can mean a dead SATA cable or failed hard drive. On T2 and M-series Macs, it typically indicates failed NAND, a corrupted APFS container, or a logic board fault preventing communication between the Secure Enclave and the storage controller.
Infinite boot loops and kernel panics: often caused by corrupted APFS checkpoint data or degrading NAND cells that return read errors during the boot sequence. On encrypted Macs, a shorted PPBUS_G3H power rail or failed PMIC can prevent the Secure Enclave from initializing, which halts boot before the login screen.
Disk shows as "Uninitialized" in Disk Utility: the partition map or APFS container superblock is damaged. Disk Utility will offer to erase and reformat. Accepting this prompt destroys the existing file system metadata. If you see this message, power off the Mac and contact a recovery lab before proceeding. See our page on APFS container corruption for technical detail on superblock reconstruction.
Apple Silicon Recovery Constraints
Apple Silicon (M1/M2/M3/M4) Recovery Constraints
Apple Silicon Macs encrypt all storage through the SoC's Secure Enclave using AES-256 with hardware-fused keys. Desoldering NAND produces only ciphertext. The only viable recovery path is component-level logic board repair to restore Secure Enclave function for in-place decryption.
Apple Silicon Macs (M1, M2, M3, M4) store data on NAND chips soldered directly to the logic board. Every write passes through the SoC's inline AES-256 hardware engine on the storage controller's DMA path, which encrypts using keys the Secure Enclave derives from a UID fused into the silicon during manufacturing. These keys never leave the Secure Enclave. They cannot be extracted, copied, or transferred to another chip.
Some labs advertise "chip-off recovery" for M-series Macs, implying they can desolder the NAND and read it with a programmer. This does not work. Removing the NAND from an M1 or M2 board produces raw ciphertext. Without the Secure Enclave that generated the encryption keys, no tool can decrypt it. The data is mathematically inaccessible.
The only viable recovery path for Apple Silicon is component-level logic board repair. The most common failure point is the PMIC (Power Management IC), which regulates the voltage rails that feed the SoC. When the PMIC fails or a downstream rail shorts, the SoC cannot start and the Mac appears completely dead.
We test each rail with a multimeter, identify the failed component, and replace it under a microscope. Once the SoC powers on, the Secure Enclave initializes, decrypts the APFS volume, and we extract data over Thunderbolt. If a power surge damaged the voltage regulators, the same board-level repair approach applies.
Apple Silicon Board Repair Recovery Process
  1. Disassemble the Mac and remove the logic board for microscope inspection to identify visible corrosion, burned components, or cracked solder joints.
  2. Test each voltage rail with a multimeter, starting at PPBUS_G3H and working through the SoC's core VDD rails, to isolate which power management IC or downstream component has failed.
  3. Use a FLIR thermal camera to identify shorted components that draw excess current and generate localized heat signatures on the board.
  4. Replace the failed PMIC, capacitor, or resistor via micro-soldering using a Hakko FM-2032 iron under microscope magnification.
  5. Power on the board and verify the SoC initializes. Confirm the Secure Enclave authenticates and the APFS volume mounts.
  6. Extract decrypted data over Thunderbolt to a target drive using Apple Configurator 2 or macOS Recovery's Share Disk mode.
Why Donor Logic Boards Cannot Recover Data on T2 or Apple Silicon Macs
On T2 chip Macs (2017-2020 Intel) and Apple Silicon Macs (M1, M2, M3, M4), the SSD NAND is either soldered to the logic board or, on the M4 Mac Mini, lives on a proprietary paired storage module. Either way, the encryption keys live inside the Secure Enclave Processor. The SEP is bonded to the SoC by paired hardware fuses set during manufacturing, and those fuses are unique per chip. A donor logic board carries a different SoC with different SEP fuses, so it cannot read the original NAND.
We perform filmed MacBook board-level repair every week. That means we can address physical board damage that prevents a Mac from powering on: water damage, a shorted PMIC, a burned USB-C controller, a blown core voltage rail. What we cannot do, and what no other lab can do, is reconstruct encryption keys when the SEP itself is destroyed and FileVault was enabled. The constraint is hardware physics, not a procedural limit.
Why a Donor Board Does Not Work
Paired SEP fuses
During SoC manufacturing, Apple sets unique fuse values inside the Secure Enclave that bind the SEP to that specific die. The encryption keys protecting NAND data are derived from those fuses and never leave the chip. A different SoC has different fuses, derives different keys, and cannot decrypt the original NAND.
NAND ciphertext is bound to the original SoC
Every byte written to NAND on a T2 or Apple Silicon Mac is encrypted by the original SEP before it reaches the flash. Reading those NAND chips with a programmer, or transplanting them onto a donor board, yields ciphertext that the donor SEP cannot decrypt.
Apple's standard repair flow swaps the whole board
When Apple Service replaces a logic board, the new board is treated as a new system. The SoC is different, the SEP is different, and any data that was on the old NAND becomes mathematically inaccessible. This is why the standard Apple repair path is a board swap, not a data recovery path.
What We Can Address
  • NAND-side electrical faults when the board still POSTs and the SEP is intact. If the SoC powers on, the SEP initializes, and the system is halted by an electrical failure on the NAND power rail or a NAND-side support IC, we use FLIR thermal imaging to localize the fault and replace the shorted capacitor or power IC under a microscope. Once the rail is clean, the SoC reads its own NAND and the SEP decrypts the volume in place.
  • Physical board repair to bring the system back to power-on. Water damage, a shorted PMIC, a blown 1V or 1.8V rail, a burned USB-C IC, or a failed audio codec: we replace the failed components under a microscope using micro-soldering, leaving the original SoC and its SEP fuse pairing intact.
  • Decryption in place after the board is alive again. Once the system POSTs and the SEP initializes, you enter your FileVault password or recovery key and the Mac decrypts the volume itself. The keys never have to leave the SEP.
What No Lab Can Do
If the SoC die is cracked, the BGA pads under the SoC are torn off, the package is burned, or the SEP is otherwise physically destroyed, and FileVault was enabled, the encryption keys are gone with the chip. We will tell you that on the first evaluation. We will not take a deposit on a case we cannot complete, and we will not promise a result that the hardware cannot deliver. This boundary is the difference between an honest lab and one that quietly drops the drive on the floor after charging a deposit.
T2 Chip Recovery Methodology and DFU Mode
T2 Chip Recovery and DFU Mode
T2-equipped Intel Macs use BridgeOS on the T2 security processor for SSD encryption and system management. When BridgeOS crashes, Apple Configurator 2's Revive command reinstalls firmware without erasing data. If the T2's power management IC has failed, board-level repair must restore power before any software recovery works.
Intel Macs with T2 chips (iMac Pro 2017, MacBook Pro/Air 2018-2020, Mac Mini 2018, Mac Pro 2019) use the T2 as a dedicated security processor. The T2 runs BridgeOS, a separate operating system that manages SSD encryption, the camera, audio, and the Secure Enclave. When BridgeOS crashes or becomes corrupted (often after a failed macOS update), the Mac may show a black screen, a flashing question mark folder, or enter DFU (Device Firmware Update) mode automatically.
DFU mode is accessible by connecting the Mac to a host machine via a specific USB-C port and using Apple Configurator 2. The critical distinction: Apple Configurator 2 offers two options, Revive and Restore. Revive reinstalls BridgeOS firmware without erasing the user data partition. Restore performs a full cryptographic erase, permanently destroying the encryption keys and all user data. On a data recovery case, only Revive is safe.
If the T2's PMIC has failed or a core voltage rail is shorted, the T2 cannot enter DFU mode at all. Apple Configurator 2 will not detect the Mac. In that scenario, board-level repair must restore the T2's power supply before any software-based recovery can proceed.
T2 DFU Revive Process
  1. Connect the T2 Mac to a host Mac running Apple Configurator 2 via a USB-C cable. The cable must plug into the specific DFU-capable port (varies by model; on MacBook Pro, it is the front-left Thunderbolt port).
  2. Force the T2 Mac into DFU mode using the model-specific key combination. For MacBook Pro: press the power button, then within 1 second also press and hold right Shift + left Option + left Control. Continue holding all four keys for approximately 10 seconds. The exact sequence varies by model; Apple publishes the current procedure in support article HT201295.
  3. Verify Apple Configurator 2 detects the Mac. It appears as a "DFU" device in the Configurator window.
  4. Select Revive (not Restore). Revive reinstalls BridgeOS firmware without erasing user data. Restore performs a cryptographic erase and permanently destroys all encryption keys.
  5. Wait for the Revive process to complete. The Mac reboots automatically. If the APFS volume was intact, it mounts normally and data is accessible.
iMac Data Recovery
iMac Data Recovery
iMac data recovery depends on which of three storage architectures your model uses: spinning hard drives (2006-2015), Fusion Drives combining SSD cache with HDD bulk storage (2012-2019), or standalone SSDs with T2 hardware encryption (iMac Pro 2017). We image spinning and Fusion drives at our Austin lab with PC-3000; T2 SSDs hold only ciphertext, so board repair is required to restore Secure Enclave decryption.
Apple shipped iMacs with three different storage configurations across generations, and the recovery path depends on which one your iMac uses.
Fusion Drive
A CoreStorage or APFS logical volume that spans a small SSD cache (24GB or 128GB) and a 1TB-3TB spinning hard drive. macOS writes frequently accessed files to the SSD for speed and stores bulk data on the HDD. If either component fails, the combined volume becomes unmountable.
CoreStorage
Apple's legacy logical volume manager used to bind Fusion Drive components before APFS. CoreStorage places a logical volume header on both the SSD cache and HDD, merging them into a single mount point. Recovery requires imaging both physical drives separately and reconstructing the CoreStorage logical volume group offline using PC-3000.
iMac data recovery by storage configuration
iMac ConfigurationYearsStorageEncrypted?Recovery Path
Fusion Drive iMacs2012–2019 (21.5" and 27")24GB or 128GB SSD cache + 1TB–3TB HDD under a single CoreStorage or APFS logical volumeOnly if FileVault enabled manuallyImage both drives with PC-3000, reconstruct the CoreStorage/APFS container by merging both halves. If SSD cache fails, the HDD still holds bulk user data. Full dual-component imaging workflow.
SSD-Only iMacsiMac 2017+ (BTO), iMac Pro 2017Proprietary NVMe bladeiMac Pro 2017: yes (T2 hardware encryption). Non-T2 BTO models: only if FileVault enabled.Non-T2: remove blade, read via PC-3000 SSD with adapter. T2 iMac Pro: board repair required to restore Secure Enclave decryption.
HDD-Only iMacs2006–2015 (base models)Standard 3.5" SATA hard drive, identical to desktop PC drivesOnly if FileVault enabled manuallyStandard HDD workflow: image with PC-3000, head swap if heads have failed, firmware repair if the drive is not detected. Most straightforward Mac recoveries we handle.
Mac Pro Data Recovery
Mac Pro recovery ranges from removing standard 3.5" SATA drives (2006-2012 towers) to board-level micro-soldering on the 2023 M2 Ultra model, which uses proprietary removable SSD modules encrypted to the SoC's Secure Enclave. The 2013 "Trash Can" uses a proprietary PCIe blade we read via PC-3000 SSD with a Sintech adapter. The 2019 tower has T2-encrypted removable modules requiring Secure Enclave restoration.
Apple sold four distinct Mac Pro generations since the Intel transition, each with a different storage architecture. Recovery complexity varies from straightforward SATA imaging to soldered-NAND board repair.
Mac Pro data recovery by generation
GenerationStorageRecovery Path
Mac Pro 2006-2012 (Tower)Standard 3.5" SATA drives, 4 bays. Optional Apple RAID card for hardware RAID.Remove drives, image with PC-3000. If RAID: image all members and reconstruct the array offline.
Mac Pro 2013 (Trash Can)Proprietary PCIe SSD blade (12+16 pin connector). No encryption binding.Remove blade SSD, read with OWC/Sintech adapter on PC-3000 SSD. No board repair needed.
Mac Pro 2019 (Tower)Proprietary Apple SSD modules (dual removable). Optional Afterburner card. T2 chip handles encryption.T2-encrypted. Board repair to restore Secure Enclave, then extract via Thunderbolt. SSD modules are removable but data is encrypted.
Mac Pro 2023 (M2 Ultra)Proprietary removable SSD modules. Up to 8TB internal. Encryption tied to M2 Ultra Secure Enclave.Board repair mandatory. Removing modules produces ciphertext only. Secure Enclave must be functional.
Extracting Proprietary Apple PCIe Blades
The 2013 Mac Pro and 2013-2015 MacBook Pro/Air models use a proprietary 12+16 pin PCIe SSD blade that does not fit standard M.2 or U.2 connectors. We mount these blades on PC-3000 Portable III using a Sintech or OWC adapter designed for the Apple pinout. When the blade's NVMe or AHCI controller has degraded, the drive triggers kernel panics in macOS because the controller stalls on read attempts to failing NAND blocks.
PC-3000's Data Extractor lets us set extended read timeouts and skip ECC errors, imaging the accessible blocks without locking up the controller. This recovers data from partially degraded blades that macOS cannot mount at all.
Aftermarket SSD Failures in Mac Pro 2013
Many Mac Pro 6,1 owners replaced the stock Apple PCIe blade with aftermarket drives using Sintech adapters. Two specific failure patterns account for the majority of recovery cases we see from these configurations.
OWC Aura Pro X2 (Silicon Motion SM2262EN controller): These drives are susceptible to firmware corruption after power loss during an SLC cache flush. The SM2262EN controller loses access to its flash translation layer mapping tables, and macOS reports the partition as RAW or the drive as unrecognized. Consumer recovery software cannot communicate with a controller in this state. We mount the OWC blade on PC-3000 SSD using the Silicon Motion Active Utility to reconstruct the FTL mapping & extract data from the NAND.
Samsung 970 EVO & other NVMe drives via Sintech adapter: Standard NVMe SSDs connected through Sintech adapters frequently trigger "Loss of MMIO space" or NVMe PM kernel panics during deep sleep. Apple's EFI bootrom on the 6,1 Mac Pro does not correctly handle NVMe power state transitions for non-Apple drives. Repeated forced shutdowns after these kernel panics can corrupt the APFS container superblock. If the volume becomes unmountable, we remove the NVMe drive, connect it directly to PC-3000 Portable III, and image the NAND without the Apple EFI layer in the path.
Mac Mini Data Recovery
Mac Mini models before 2018 used removable 2.5" SATA drives recoverable through standard PC-3000 imaging. The 2018 Mac Mini introduced T2-encrypted soldered storage. The M1 (2020) and M2 (2023) models continue this soldered architecture. The M4 (2024) model uses a removable SSD module, but NAND remains cryptographically bound to the SoC's Secure Enclave. Board repair is the only recovery path for all encrypted Mac Minis.
Mac Mini models before 2018 used removable 2.5" SATA drives (some with Fusion Drive configurations). Recovery on these models is straightforward: remove the drive, image it, and extract data.
The 2018 Mac Mini introduced the T2 chip with soldered SSD storage and hardware encryption. M1 (2020) and M2 (2023) Mac Minis continue this soldered architecture with encryption keys bound to the SoC's Secure Enclave. The M4 (2024) Mac Mini uses a proprietary removable SSD module, but the NAND remains cryptographically paired to the M4 SoC.
For T2 and Apple Silicon Mac Minis, the recovery path is board repair. We isolate the failed component (typically a PMIC or power rail), replace it under a microscope, and restore enough function for the Secure Enclave to decrypt the volume.
Fusion Drive Mac Minis
The 2014 Mac Mini shipped with Fusion Drive as a BTO option. Recovery follows the same CoreStorage/APFS reconstruction workflow as iMac Fusion Drives.
M4 Mac Mini (2024)
The M4 Mac Mini uses a proprietary removable SSD module, but the raw NAND chips remain hardware-encrypted and cryptographically bound to the M4 SoC's Secure Enclave. Board repair is the only viable recovery path.
Why You Cannot Swap the M4 Mac Mini SSD for Data Recovery
The late-2024 M4 Mac Mini puts its NAND on a removable daughterboard, but the SSD controller lives inside the M4 SoC & the NAND is cryptographically bound to that chip's Secure Enclave. Moving the board into a donor Mac yields only ciphertext, so recovery still means repairing the original logic board.
Apple changed the physical layout with the late-2024 M4 Mac Mini. The NAND no longer sits soldered to the main logic board; it rides on a removable proprietary NAND daughterboard. That single change convinced a lot of people they could pull the board, drop it into a working Mac Mini, & read their files. They can't.
The SSD controller is not on the daughterboard. It's integrated into the M4 SoC itself, & the NAND is locked to that SoC's Secure Enclave with AES-256 (XTS) keys fused into the silicon. The chips on the daughterboard are dumb storage holding encrypted data. The key that turns that data back into files exists in exactly one place: the original M4 SoC.
Drop the daughterboard into a donor Mac Mini & the donor's Secure Enclave reads the proprietary BGA NAND packages as ciphertext, because it never held the original hardware-fused key. To make the swapped board usable in the new machine you have to run an Apple Configurator restore, which writes fresh keys & permanently erases whatever was on the NAND. The restore that makes the part work is the same step that destroys your data.
Recovery from a physically damaged M4 Mac Mini follows the same path as the soldered M1 & M2 storage before it: component-level logic-board repair of the original machine to revive the original SoC so its Secure Enclave can decrypt the NAND in place. We isolate the failed power component under a FLIR thermal camera, replace it with a Hakko FM-2032 under the microscope, then image the volume through PC-3000 once the SoC powers on. The removability is misleading; it buys you nothing on a recovery case.
APFS Container Reconstruction
How Does APFS Container Reconstruction Work?
APFS container corruption makes all volumes invisible to macOS, causing Disk Utility to report the disk as uninitialized. We parse the container superblock and checkpoint history at the block level using PC-3000 to reconstruct the volume tree and extract files without reformatting.
Every Mac running macOS 10.13 (High Sierra) or later uses APFS as its default file system. APFS organizes storage into containers, each holding one or more volumes (typically Macintosh HD and Macintosh HD - Data). The container superblock and checkpoint map track the state of every volume inside it.
When the container superblock becomes corrupted, macOS reports the disk as uninitialized or unmountable. Disk Utility offers to erase and reformat. Running First Aid on a corrupted container can make the damage worse if the checkpoint data is inconsistent.
We parse the container structure at the block level using PC-3000, walking the checkpoint history to find the most recent consistent state. If the primary superblock is damaged, we scan for backup superblocks and reconstruct the container tree from those. This process works on both unencrypted APFS and FileVault-encrypted volumes (once the encryption key is available).
APFS Container Reconstruction Steps
  1. Image the full drive using PC-3000 to create a sector-level clone. All reconstruction work runs against the image, never the original media.
  2. Locate the APFS container superblock at the drive's known offset. If the primary superblock is corrupted, scan for backup superblocks at alternative checkpoint locations.
  3. Parse the checkpoint descriptor map to identify the most recent consistent transaction. APFS maintains a rolling checkpoint history; the last valid checkpoint before the corruption event is the recovery target.
  4. Reconstruct the B-tree volume catalog from the validated checkpoint data, mapping file and directory records back to their NAND block addresses.
  5. Extract files from the reconstructed volume tree. Verify directory structure integrity and file header signatures before delivering data to the customer.
Why Software Recovery Fails on Modern Macs
Why Data Recovery Software Fails on Modern Macs
Consumer data recovery software cannot access hardware-encrypted storage on T2 and Apple Silicon Macs. TRIM unmaps deleted file blocks on all Mac SSDs from 2012 onward, and the controller returns zeros when those addresses are read.
Consumer data recovery tools (Disk Drill, EaseUS, Stellar) scan storage at the file system level. They work when the problem is a logical deletion on an accessible, functional drive. They do not work when the storage hardware itself has failed, and on modern Macs, most data loss involves hardware failure or encryption barriers that software cannot address.
TRIM unmaps deleted data on all Mac SSDs from 2012 onward
macOS enables TRIM by default on Apple-supplied SSDs. When a file is emptied from the Trash, macOS issues a TRIM command that tells the SSD controller those blocks are no longer needed. The controller drops them from its mapping table and returns zeros when those addresses are read, so software scanning the volume finds nothing there. The physical NAND erase follows later, when garbage collection recycles the block.
Hardware encryption blocks external reads on T2 & Apple Silicon
On T2 and Apple Silicon Macs, the Secure Enclave encrypts every byte written to storage using AES-256. Recovery software running from an external boot drive or another Mac cannot decrypt this data. Removing the NAND chips and reading them directly produces only ciphertext. The only path to the plaintext is repairing the logic board so the Secure Enclave can decrypt the volume in place.
Kernel extensions cannot fix physical power loss
Some consumer recovery applications claim their macOS kernel extensions (kext) grant low-level access to T2 & M-series chips. A kernel extension provides privileged software access to a functioning file system, but it cannot bypass a physical hardware failure. If a capacitor on the logic board has shorted, the SSD controller receives zero voltage. No software command can read data from an unpowered chip. Recovery requires board-level micro-soldering to restore power to the SoC.
Running software on a failing drive accelerates damage
If a Mac has suffered liquid damage or a power surge, the storage controller may be partially functional. Scanning with recovery software forces sustained read operations across every sector, which can overheat damaged components or trigger cascading controller failures. Power off the Mac and do not attempt software scans if you suspect physical damage.
Firmware Panics on Aftermarket Mac SSDs
Users who upgraded older Macs (pre-2015 SATA models or Mac Pro 6,1 via adapter) with budget SSDs containing Phison controllers encounter a specific firmware failure. The Phison PS3111-S11 controller, found in Kingston A400 and similar drives, is prone to losing access to its on-NAND service area after power loss or NAND cell degradation. When this happens, Disk Utility reports the drive as "SATAFIRM S11" with a capacity of 0 bytes or 2MB.
This is not a file system error. The controller has entered a hardware fallback state (ROM mode) where it can no longer read its own firmware from the NAND flash. No macOS utility, no consumer recovery application, and no Terminal command can address a controller-level firmware panic.
Recovery requires PC-3000 SSD in Technological Mode: we inject a volatile loader program (LDR) directly into the Phison controller's RAM, temporarily replacing the corrupted on-NAND firmware with diagnostic microcode. This wakes the controller long enough to reconstruct the virtual translator & image the user data before the volatile session ends. The same technique applies to SSD recovery on any system where a Phison PS3111-S11 drive enters ROM mode.
MacBook Water Damage Data Recovery
Water damage causes corrosion on MacBook logic board power rails, preventing the SoC from starting and locking hardware-encrypted NAND storage. Recovery requires ultrasonic board cleaning, component-level fault isolation with a multimeter and thermal camera, and micro-soldering replacement of failed ICs to restore Secure Enclave decryption.
When liquid enters a MacBook, corrosion starts forming on the logic board within hours. A common point of failure is the main system power rail (PPBUS_G3H), which regulates between 8.6V and 12.6V depending on the MacBook model.
Liquid bridging between components on this rail shorts voltage regulation and allows the charger's full output voltage to reach downstream capacitors and power management ICs. On T2 and Apple Silicon MacBooks, this prevents the SoC from starting, which means the Secure Enclave cannot initialize and the hardware-encrypted NAND becomes inaccessible.
Recovery from a liquid-damaged MacBook follows a three-step board repair process. We disassemble the MacBook and run the logic board through an ultrasonic cleaner to dissolve corrosive residue from beneath BGA components where manual cleaning cannot reach. We then test each voltage rail with a multimeter and thermal camera to identify which components have shorted or failed.
We replace the damaged ICs, capacitors, or resistors under a microscope using micro-soldering. The goal is not to restore the MacBook as a laptop; we need to restore enough board function for the SoC to power on, authenticate the Secure Enclave, and decrypt the APFS volume for data extraction from the water-damaged SSD.
Pricing for MacBook water damage data recovery follows our SSD recovery tiers: $450–$600 for circuit board repair, $600–$1,200 for firmware-level corruption, and $1,200–$1,500 for advanced board rebuilds requiring multiple component replacements. No data recovered = no charge.
MacBook Water Damage Repair Cost for Data Recovery
MacBook water damage repair costs for data recovery range from $450–$600 for standard circuit board micro-soldering to $1,200–$1,500 for advanced logic board rebuilds. The exact price depends on which power management ICs or voltage rails were shorted by liquid exposure. We don't charge an evaluation fee, and if data is unrecoverable, the recovery attempt costs you nothing.
Circuit Board Repair ($450–$600)
Replacement of isolated shorted capacitors, resistors, or a single failed IC (e.g., CD3217 USB-C controller) via micro-soldering under a microscope.
Firmware-Level Recovery ($600–$1,200)
Required when liquid damage causes secondary logical failure to the SSD flash translation layer, necessitating PC-3000 SSD reconstruction after board repair.
Advanced Board Rebuild ($1,200–$1,500)
Extensive ultrasonic cleaning & reconstruction of multiple corroded power rails, PMIC replacement, and SoC power restoration to bring the Secure Enclave back online.
What to Do Immediately After Spilling Liquid on a MacBook
The first actions after a liquid spill determine whether the encrypted data on your logic board survives. Follow these steps in order.
  1. Disconnect power immediately. Unplug the MagSafe or USB-C charger. Electricity flowing through wet traces accelerates galvanic corrosion on the logic board.
  2. Power down the Mac. Hold the power button until the screen goes black. Do not attempt to turn it back on to check if it works.
  3. Remove peripherals. Disconnect external monitors, drives, and accessories to prevent current from flowing through additional ports.
  4. Do not use rice, hair dryers, or compressed air. Rice does not absorb moisture from inside a sealed laptop chassis. Hair dryers and compressed air push liquid deeper under BGA components and bake mineral deposits onto the logic board.
  5. Bring the Mac to a board-level repair lab. We run the logic board through ultrasonic cleaning to dissolve corrosive residue from beneath BGA chips, then test each voltage rail to identify shorted components for micro-soldering replacement.
How a Power Surge Damages a MacBook & Why Your Data Usually Survives
A power surge almost always burns out the power-delivery front end before it ever reaches the storage. The CD3217 USB-C controller or the main PPBUS_G3H rail takes the hit, & the power management IC shorts to ground to protect the NAND. The flash array stays intact, so the data is still there once we rebuild the power path.
Liquid corrosion & an electrical surge fail a MacBook in different orders. A surge travels in from the charging port & works its way toward the SoC, & the board is designed so the cheap parts die first. That sequence is why a surge-damaged MacBook is often one of the better cases that lands on the bench.
  1. The USB-C power-delivery controller fails first. An overvoltage event hits the CD3217 USB-C controller, the IC that negotiates Power Delivery voltage stepping from the 5V baseline up to 20V. When it dies, the system draws negligible current & stays stranded at 5V, so the Mac looks completely dead.
  2. The surge reaches the main system rail. If the overvoltage propagates past the input stage, it pushes onto PPBUS_G3H, the primary power rail that feeds the rest of the board.
  3. The PMIC sacrifices itself. The Power Management IC acts as a barrier: it shorts to ground to sever the circuit before destructive voltage reaches the NAND flash array. The NAND survives the event, so the data on it stays intact.
  4. We rebuild the power path. We inject a safe current into the board, use a FLIR thermal camera to find the shorted capacitor or PMIC by its heat signature, then replace the failed components with a Hakko FM-2032 under the microscope to restore the power path to the SoC. Once power is back, the Secure Enclave initializes & decrypts the intact NAND in place.
This is board-level work, so it follows our SSD tiers, not a separate price list. Circuit board repair runs $450–$600, firmware-level reconstruction runs $600–$1,200, & an advanced rebuild across multiple rails runs $1,200–$1,500. No data recovered = no charge.
FileVault and Encryption
How Does FileVault Affect Mac Data Recovery?
FileVault has been enabled by default on new Macs during setup since OS X Yosemite (2014). On T2 and Apple Silicon Macs, hardware encryption is always active regardless of FileVault settings. Recovery requires both a functioning Secure Enclave (achieved via board repair) and the user's login password or FileVault recovery key.
FileVault full-disk encryption has been enabled by default on new Macs during setup since OS X Yosemite (2014). Older Macs may have FileVault enabled manually. On T2 and Apple Silicon Macs, hardware encryption is always active regardless of FileVault settings; FileVault adds a second layer that requires the user password at boot.
Recovery from a FileVault-protected Mac requires two things: (1) a functioning Secure Enclave (achieved via board repair if the Mac is dead), and (2) the user's login password or the FileVault recovery key that macOS generated when FileVault was first enabled.
If you have the recovery key, we can unlock the volume after restoring board function. If you do not have the recovery key and the Mac is dead, recovery depends on our ability to repair the board to a state where it can boot and prompt for the password normally.
No Back Door Exists
We do not bypass FileVault. No lab can. Apple does not have a master key. Board repair preserves the Secure Enclave so it can do the decryption itself.
Pre-T2 Macs with FileVault
On Macs before the T2 era (2017 and earlier), FileVault used a software-based encryption wrapper around CoreStorage. Recovery requires the user password or recovery key, but the SSD or HDD can be read independently of the logic board. We image the drive and decrypt offline.
Safe Diagnostics Before Mailing Your Mac
What Diagnostics Are Safe to Run Before Mailing Your Mac?
Before shipping your Mac, check if the storage is accessible using Target Disk Mode (Intel Macs) or Share Disk (Apple Silicon). Do not run Disk Utility First Aid on a clicking hard drive or a drive reporting as "uninitialized." If the drive does not mount on a host Mac, power off both machines to prevent further damage.
Before shipping your Mac, you can safely check whether the storage is accessible using Apple's built-in sharing modes. These modes do not write to the target drive and will not cause further damage.
Mac disk sharing modes by architecture
ModeMac ArchitectureHow to ActivateFileVault Behavior
Target Disk ModeIntel Macs (pre-T2 & T2)Power off. Connect via Thunderbolt or USB-C to a working Mac. Power on while holding the T key.On T2 Macs, prompts for the FileVault password before exposing the volume.
Share Disk ModeApple Silicon (M1/M2/M3/M4)Boot into macOS Recovery by holding the power button. Select Options, click Continue, then choose Utilities > Share Disk. Select the volume, click Start Sharing, connect via Thunderbolt.Target Disk Mode does not exist on Apple Silicon; Share Disk replaces it.
If the volume does not mount, the host Mac prompts to initialize the disk, or the target Mac cannot reach Recovery mode, the failure is at the hardware level. Power off both machines and use our mail-in service to send the Mac for board-level diagnosis.
Mac Data Recovery Pricing
Pricing depends on whether your Mac uses a hard drive, SSD, or requires board-level work. No data = no charge on all tiers.
HDD-Based Macs and External Drives
Applies to: Fusion Drive HDDs, iMac HDD-only models, older Mac Pro tower drives.
SSD-Based Macs
Applies to: iMac SSD-only, Mac Pro 2013 blade, Mac Pro 2019+ NVMe, Mac Mini 2018+, Mac Studio, all T2 and Apple Silicon Macs requiring board-level work.
Mac Model Recovery Matrix
Recovery by Mac Model
Quick reference for storage type, encryption status, and recovery approach by Mac product line.
Mac data recovery methods by model
Mac ModelStorageEncrypted?Recovery Path
iMac (HDD-only, 2006-2015)3.5" SATA HDDOnly if FileVault enabled manuallyRemove drive, PC-3000 imaging
iMac (Fusion Drive, 2012-2019)SSD + HDD hybridOnly if FileVault enabled manuallyImage both drives, reconstruct CoreStorage/APFS volume
iMac Pro (2017)Proprietary NVMe SSDYes (T2 hardware encryption)Board repair for T2 Secure Enclave
Mac Pro (Tower, 2006-2012)3.5" SATA, 4 baysOnly if FileVault enabledRemove drives, PC-3000 imaging. RAID reconstruction if Apple RAID card used.
Mac Pro (Trash Can, 2013)Proprietary PCIe bladeOnly if FileVault enabledRemove blade, read with adapter on PC-3000 SSD
Mac Pro (Tower, 2019)Proprietary Apple SSD (removable)Yes (T2 hardware encryption)Board repair for T2. SSD modules are removable but data is encrypted.
Mac Pro (2023, M2 Ultra)Proprietary removable SSD modulesYes (SoC Secure Enclave)Board repair mandatory
Mac Mini (pre-2018)2.5" SATA HDD or FusionOnly if FileVault enabledRemove drive, standard HDD/SSD recovery
Mac Mini (2018, T2)Soldered SSDYes (T2 hardware encryption)Board repair for T2 Secure Enclave
Mac Mini (M1/M2)Soldered NANDYes (SoC Secure Enclave)Board repair mandatory
Mac Mini (M4, 2024)Proprietary removable SSD moduleYes (SoC Secure Enclave)Board repair mandatory
Why Rossmann
Why Choose Rossmann for Mac Recovery?
One lab. Every Mac generation. Published pricing. No data, no charge.
Board-level repair in-house
T2 and Apple Silicon Macs require repairing the logic board to access encrypted storage. We do this work ourselves, on site.
No data, no charge
If we cannot recover your data, the recovery attempt costs you nothing. That applies to every Mac model we work on.
Published pricing tiers
HDD-based Macs: $100–$2,000. SSD-based Macs: $200–$1,500. No hidden diagnostic fees.
FileVault and encryption handled
We restore Secure Enclave function so the Mac decrypts its own storage. No brute-force, no bypass; the Mac does the decryption itself.
Every Mac generation covered
From 2006 Mac Pro towers with RAID cards to 2024 M4 Mac Mini. One lab, every architecture.
Nationwide mail-in
Not in Austin? Ship your Mac to us from anywhere in the U.S. Free evaluation on arrival.
Mac Recovery Terminology
Mac Data Recovery Terminology
The following terms describe the hardware, software, and procedures specific to Mac data recovery. Each corresponds to an actual tool or component in our Austin lab: PC-3000 for drive imaging, the Secure Enclave for encryption key management, TRIM for SSD block deallocation, and BridgeOS for T2 firmware management.
PC-3000 Portable III and PC-3000 Express
Hardware-software systems from ACE Lab that communicate directly with a drive's microcontroller firmware. They bypass the operating system to image degraded sectors, repair corrupted translator modules, and stabilize failing drives that crash consumer recovery software. We use PC-3000 on every Mac HDD and SSD recovery.
ULPA-Filtered Clean Bench
A laminar-flow workstation with Ultra-Low Penetration Air filtration. It prevents airborne particles from contaminating exposed platters during invasive mechanical work like read/write head swaps on older Mac hard drives. SSD and board-level recovery does not require this environment.
Secure Enclave
A hardware security co-processor embedded in Apple T2 and M-series (M1/M2/M3/M4) chips. It manages AES-256 encryption keys derived from a UID fused into the silicon during manufacturing. Because keys never leave the Secure Enclave, removing NAND chips produces only ciphertext. The original logic board must be repaired for the Secure Enclave to initialize and decrypt storage.
TRIM
An ATA/NVMe command that tells an SSD controller which data blocks are no longer needed. When macOS empties the Trash, it issues TRIM and the controller unmaps those blocks from its translation table, returning zeros when they are read; the physical NAND erase happens later during garbage collection. On Mac SSDs from 2012 onward with APFS, this puts deleted files out of reach of recovery software.
APFS Container
The top-level storage structure in Apple File System, containing one or more volumes (typically "Macintosh HD" and "Macintosh HD - Data"). Container corruption, often from sudden power loss or SSD controller failure, makes all volumes invisible to macOS. Recovery requires parsing the container superblock and checkpoint history to reconstruct the volume tree.
BridgeOS
The dedicated operating system running on the T2 security chip in Intel Macs (2017-2020). BridgeOS manages SSD encryption, the camera, audio routing, and Secure Enclave communication. When BridgeOS crashes after a failed macOS update, the Mac shows a black screen or flashing folder. Apple Configurator 2's Revive command reinstalls BridgeOS without erasing user data.
Can you recover data from an iMac with a Fusion Drive?
Yes. A Fusion Drive is a CoreStorage (or APFS on later models) logical volume that spans a small SSD cache and a 1TB or 2TB hard drive. If the CoreStorage header is intact, we image both drives and reconstruct the volume. If the SSD cache has failed, we extract data from the HDD portion directly using PC-3000.
Do you recover data from Mac Pro RAID arrays?
Yes. Classic Mac Pro towers (2006-2012) supported hardware RAID via the Apple RAID card or software RAID through Disk Utility. We image each member drive using PC-3000, then reconstruct the RAID array offline. The 2019 Mac Pro uses proprietary Apple SSD modules with T2 encryption, so recovery requires board repair.
Can you recover data if FileVault is enabled?
If the Mac boots far enough for the Secure Enclave or T2 chip to initialize, we can decrypt in place using the user's password or recovery key. If the board is dead, we repair it to restore Secure Enclave function. Without the password or recovery key, FileVault-encrypted data is not recoverable by anyone.
Is recovery possible from an M1 or M2 Mac Mini?
Yes. M1 and M2 Mac Minis have soldered NAND, while the M4 Mac Mini uses a proprietary removable SSD module. In all cases, encryption is tied to the SoC's Secure Enclave, so recovery requires board-level repair to restore power and let the Secure Enclave decrypt.
How much does Mac data recovery cost?
It depends on the Mac model and failure type. Hard drive recovery (Fusion Drive HDDs) starts at $100. SSD-based recovery (Mac Mini, iMac 2017+) starts at $200. Board-level work for encrypted Macs (T2/M-series) ranges from $450–$600. No data = no charge.
What is APFS container corruption and can you fix it?
APFS uses a container structure that holds one or more volumes. Container corruption can make all volumes invisible to macOS. We parse the APFS container superblock and checkpoint data using PC-3000 to reconstruct the volume tree and extract files, even when macOS reports the disk as uninitialized.
Can I use software to recover permanently deleted files on my Mac SSD?
On modern Macs with APFS-formatted SSDs, no. When you empty the Trash, macOS issues a TRIM command that tells the SSD controller those NAND blocks are no longer needed. The controller reports those blocks as unmapped and returns zeros when they are read, so recovery software finds nothing there. The physical NAND erase happens later, when the controller's garbage collection recycles the block. TRIM applies to all internal Mac SSDs from 2012 onward. If the drive itself has failed (not a deletion), recovery is a hardware problem, not a software one.
Why is my Mac showing a flashing folder with a question mark?
The flashing folder means the Mac's firmware cannot locate a bootable macOS system. On older Macs with SATA drives, this can indicate a failing hard drive or a bad SATA cable. On T2 and M-series Macs, it typically means the NAND flash has failed, the APFS container is corrupted beyond automatic repair, or the Secure Enclave cannot communicate with the storage controller due to logic board damage. Do not attempt to reinstall macOS if the drive is physically failing; this overwrites existing data.
Why do some data recovery labs claim they can perform chip-off recovery on M1 or M2 Macs?
Those labs are either confusing generic PC SSD recovery with Apple's unified architecture or misrepresenting their capabilities. Chip-off works on unencrypted drives where NAND can be read with a programmer. On M1, M2, M3, and M4 Macs, every byte written to NAND passes through the SoC's inline AES-256 hardware engine on the storage controller's DMA path, keyed by the Secure Enclave. The keys are derived from a UID fused into the Secure Enclave and never leave the chip. Desoldering the NAND produces only ciphertext that no programmer can decrypt. Recovery on Apple Silicon requires micro-soldering to repair the original logic board so the Secure Enclave can initialize and decrypt the data in place.
Why do some labs advertise an ISO Class 5 Cleanroom for MacBook data recovery?
Cleanrooms exist to prevent airborne particles from landing on exposed magnetic platters inside opened hard drives. Modern MacBook recovery (T2 and Apple Silicon) involves soldered NAND on a logic board. There are no exposed platters, no spinning disks, and no read/write heads. The board repair happens at a micro-soldering station. A room-scale ISO Class 5 cleanroom adds zero benefit to this type of work. Our SSD board-level recovery starts at $450–$600 because we price the actual procedure, not the room it happens in.
Why is Mac data recovery pricing at your Austin lab lower than quotes from other local shops?
Most computer repair shops in Austin do not own a PC-3000 or employ micro-soldering technicians. When a customer brings in a dead MacBook, the shop ships it to a third-party national lab and adds a markup to the final invoice. We operate our own recovery lab at 2410 San Antonio Street in Austin with PC-3000 Portable III, PC-3000 Express, and a full micro-soldering station. There is no middleman and no outsourcing markup. SSD board-level recovery starts at $450–$600; firmware-level work runs $600–$1,200.
Can Apple Configurator 2 recover my data if my T2 MacBook shows a black screen?
It depends on the failure. If the T2's BridgeOS firmware has crashed but the board's core voltage rails are intact, the Mac enters DFU mode. A technician connects a host Mac via the correct USB-C port and uses Apple Configurator 2 to issue a "Revive" command, which reinstalls BridgeOS without touching the user data partition. If the failure is hardware (a shorted PMIC preventing the T2 from powering on), software cannot help and board-level repair comes first. Never select "Restore" in Apple Configurator 2 on a data recovery case; Restore performs a cryptographic erase of the SSD, permanently destroying the encryption keys and all user data.
How much does MacBook water damage repair cost for data recovery?
Water damage data recovery pricing follows our SSD recovery tiers because the work is board-level micro-soldering. Circuit board repair (replacing corroded capacitors, resistors, or a single failed IC) ranges from $450–$600. Firmware recovery (required if the SSD controller or flash translation layer has failed secondary to board damage) runs $600–$1,200. Advanced board rebuilds where multiple ICs, traces, and power rails need reconstruction range from $1,200–$1,500. No data recovered = no charge.
Can you recover data from a water damaged MacBook that won't turn on?
Yes. A MacBook that will not power on after liquid exposure is the standard starting point for water damage data recovery. Liquid causes short circuits on the logic board's power rails, triggering protection circuits that prevent the system from starting. On T2 and Apple Silicon MacBooks, the storage is hardware-encrypted to the SoC's Secure Enclave, so the original logic board must be repaired to access data. We run the board through ultrasonic cleaning to remove corrosion, identify the shorted components with a multimeter and thermal camera, and replace them via micro-soldering. Once the SoC powers on and the Secure Enclave authenticates, we extract the decrypted data.
Can I walk in for Mac data recovery at your Austin lab?
Yes. Our lab at 2410 San Antonio Street in Austin, TX accepts walk-ins Monday through Friday. You hand your Mac directly to the technician who will work on it. We run a free microscope evaluation and provide a firm price quote on the spot. No appointment required. For customers outside Austin, we offer the same pricing and turnaround through our nationwide mail-in service.
How long does MacBook water damage repair take for data recovery?
Board-level water damage repair typically takes 3 to 6 weeks. The timeline depends on the severity of corrosion and which components failed. Simple board repair (one or two shorted ICs) runs 3 to 4 weeks. Complex board rebuilds where liquid damaged multiple power rails, the SSD controller, or the PMIC require sourcing specific donor components and additional micro-soldering passes, extending the timeline to 5 to 6 weeks. A +$100 rush fee to move to the front of the queue is available to move to the front of the queue. We provide status updates as the repair progresses.
How much does MacBook logic board repair cost for data recovery?
MacBook logic board repair for data recovery follows our SSD pricing tiers because the work involves micro-soldering on the logic board to restore Secure Enclave function. Circuit board repair (replacing a failed PMIC, shorted capacitor, or corroded USB-C controller IC) runs $450–$600. Firmware-level corruption requiring PC-3000 SSD work to rebuild the flash translation layer costs $600–$1,200. Advanced board rebuilds where multiple ICs and power rails need replacement run $1,200–$1,500. No data recovered = no charge.
What sets Mac data recovery at your Austin lab apart from shipping to a national lab?
Most national labs add a middleman layer: your local repair shop ships the Mac to a remote facility, adds markup, and relays status updates secondhand. At our Austin lab (2410 San Antonio Street), you hand the Mac directly to the technician who will perform the board-level micro-soldering. We own the PC-3000 Portable III, PC-3000 Express, and PC-3000 SSD systems in-house. No outsourcing, no franchise, no markup from an intermediary. Walk-in customers get a free microscope evaluation and firm price quote on the spot.
Is MacBook logic board repair required for data recovery?
On all Apple Silicon (M1/M2/M3/M4) and T2 Macs, yes. Data is hardware-encrypted to the logic board's Secure Enclave using AES-256 keys derived from a UID fused into the silicon. If the board dies, removing the storage chips yields only ciphertext. Swapping the entire logic board (the standard Apple repair path) permanently separates your data from its decryption key. We repair the original board at the component level via micro-soldering, preserving the cryptographic pairing so the Secure Enclave can decrypt your data in place.
Can software kernel extensions recover data from a dead Mac?
No. Data recovery applications that claim macOS kernel extensions (kext) grant low-level access to T2 or M-series chips require a functioning logic board and powered SSD controller to operate. A kernel extension is a privileged software instruction; it cannot bypass physical hardware failures. If a microscopic capacitor on the logic board has shorted, the SSD controller receives zero voltage. No software command, regardless of its kernel privileges, can read data from an unpowered chip.
Why does my upgraded Mac Pro 2013 crash during sleep mode, and is my data safe?
Using a Sintech adapter with third-party NVMe SSDs (Samsung 970 EVO, Crucial P3) on 2013-2017 Intel Macs often causes Apple's EFI bootrom to fail during dark wakes, resulting in 'Loss of MMIO space' or NVMe PM kernel panics. The data on the NAND flash is physically intact, but repeated forced shutdowns can eventually corrupt the APFS container. If the volume becomes unmountable, we remove the NVMe drive and image it directly using PC-3000 Portable III, without the Apple EFI layer in the path.
My Mac SSD shows up as SATAFIRM S11 in Disk Utility. Can software fix this?
No. "SATAFIRM S11" is a hardware-level fallback state specific to Phison PS3111-S11 controllers, found in Kingston A400 and similar budget SSDs used as Mac upgrades. The controller lost access to its flash translation layer and entered ROM mode. Consumer software operates at the file system level and cannot communicate with a crashed controller. Recovery requires PC-3000 SSD in Technological Mode to inject a volatile loader program (LDR) into the controller's RAM, temporarily waking it to reconstruct the mapping tables and extract data. SSD recovery starts at $200.
Why does PC-3000 struggle with the original 2013-2015 MacBook Pro SSD blade?
Apple's 2013-2015 proprietary SSD blades use a Samsung UBX controller running custom AHCI firmware, not NVMe. Standard NVMe protocol commands time out or fail to detect this controller entirely. PC-3000 Portable III requires AHCI-mode initialization via a PCIe-to-proprietary adapter to access the controller's service area & reconstruct the flash translation layer. If you connect the blade using an NVMe adapter, the controller won't respond because it speaks a different protocol. We stock both AHCI and NVMe adapters for the Apple pinout.
Can data be recovered if a MacBook logic board has a short on the NAND power rail?
Yes, but it requires precise fault isolation. A short on the NAND power rail prevents the SSD controller from receiving the voltage it needs to initialize. We inject minimal current through the shorted rail and use a FLIR thermal camera to locate the specific capacitor or component drawing excess current. Once the shorted component is identified, we replace it via micro-soldering without disturbing the NAND array. On T2 and Apple Silicon boards, standard chip-off extraction is impossible because the NAND is cryptographically paired to the Secure Enclave; reading the chips externally yields only ciphertext. The repair must restore power to the SoC so it can decrypt the volume in place. Board-level recovery starts at $450–$600.
Can a donor logic board recover data from a T2 or Apple Silicon Mac?
No. On T2 chip Macs (2017-2020 Intel) and Apple Silicon Macs (M1/M2/M3/M4), the storage encryption keys are generated inside the Secure Enclave Processor and bonded to the SoC by paired hardware fuses set during manufacturing. Those fuses are unique per SoC and cannot be re-paired to a different chip. A donor logic board carries a different SoC with different SEP fuses, so it cannot read the encrypted NAND from the original board. The standard Apple repair path of swapping the entire logic board permanently separates the user data from its decryption key. The only path that keeps data accessible is component-level repair of the original board: replace the failed PMIC, capacitor, USB-C controller, or NAND power IC under a microscope, leaving the original SoC and its SEP fuse pairing intact.
What if the SoC or T2 chip itself is physically destroyed and FileVault was enabled?
When FileVault is on and the SoC or T2 chip is destroyed (cracked die, severe trace damage under the BGA, or burned package), the encryption keys held inside the Secure Enclave are gone with it. No tool, lab, or technique can reconstruct keys from a destroyed Secure Enclave; this is a hardware constraint of Apple's design, not a procedural limitation. We will tell you up front when a case is in this state. What we can address is the case where the SoC is intact but the board around it has failed: water damage, a shorted PMIC, a blown power rail, or a burned USB-C controller. In those cases, component-level board repair brings the system back to a state where it POSTs, the SEP initializes, and you decrypt the volume in place using your password or recovery key.
National Mail-In Logistics
Shipping
Shipping
Mail-in
Ready to get your Mac data back?
Free estimate. No data = no charge. Austin walk-in or mail-in from anywhere in the U.S.
