Corsair SSD Data Recovery
We recover data from failed Corsair SSDs at our own lab in Austin, Texas. Every drive is worked on in-house by our technicians; nothing is shipped to a third-party partner. Mail-in service covers the whole country, the evaluation is free, & there is no diagnostic fee. You get a firm quote before we touch the drive, & if we don't recover your data you don't pay a recovery fee.
Corsair builds its NVMe lineup on Phison controllers, and which one is on the board decides the recovery path. Corsair does not publish the controller per model, and manufacturers change silicon inside a model line, so the part gets read off the package under magnification at intake. Each controller has distinct failure patterns, firmware versions, and recovery pathways.
SSD starting at $200 | No Data, No Fee | Free Evaluation | Since 2008
Corsair SSDs We Recover
Gen5: MP700 and MP700 PRO
Phison E26 controller. M.2 2280. PCIe Gen5 x4. Known thermal throttling failure pattern.
Gen4: MP600, MP600 PRO, and MP600 XT
Phison E18 (PRO/XT) or E16 (original MP600). M.2 2280. Triple Cortex-R5 with AES-256 encryption.
MP600 Mini / Core 2230
Phison E21T. M.2 2230 for Steam Deck, ROG Ally, Surface Pro. DRAM-less HMB design.
Gen3 MP510 and legacy Force Series SATA
Phison E12 (MP510), SandForce SF-2281 (Force 3/GT). Legacy models still in active use.
Current Corsair NVMe SSDs use Phison controllers; legacy Force SATA used SandForce
Updated September 2026
11 min read
Recovery Cost and Intake
What Does Corsair SSD Recovery Cost and How Do You Start?
Corsair SSD recovery starts at $200 for a working drive you only need copied, & runs to $1,200–$2,500 when the board is damaged badly enough to need a NAND transplant. Evaluation is free, the quote is firm before any work begins, & you pay no recovery fee if we don't get the data.
Corsair sells across two interfaces, so quotes come off two tier tables. MP600 & MP700 drives are NVMe; the legacy Force 3 & Force GT are SATA.
Recovery TierNVMe (MP600 & MP700)SATA (Force 3 & Force GT)
Simple copy$200$200
File system recoveryFrom $250From $250
Circuit board repair$900–$1,200$450–$600
Firmware recovery$900–$1,200$600–$1,200
PCB or NAND swap$1,200–$2,500$1,200–$1,500
Which tier you land in comes down to what failed. A drive that won't power on is a board problem, & that is component-level microsoldering work: we find the failed part with a FLIR thermal camera & replace it with a Hakko FM-2032 on an FM-203 base station, which brings the original controller back so the drive can be read normally.
A drive that powers up but never answers the host can be a board fault or a firmware panic, & the free evaluation is what tells the two apart. Worn NAND is a separate failure with a separate price, & it lands in the firmware tier, where the price depends on the extent of bad areas in the NAND.
The $1,200–$2,500 tier carries a 50% deposit & a donor drive cost on top. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers.
Standard turnaround is listed per tier, from 3-5 business days on a simple copy to 4-8 weeks on a swap. If you need it sooner, +$100 rush fee to move to the front of the queue.
How Intake Works
  1. Ship the drive or bring it in. Mail-in recovery works from anywhere in the country; walk-ins go to the Austin lab.
  2. We evaluate the drive for free. No diagnostic fee, whatever the diagnosis turns out to be.
  3. You get a firm quote tied to one of the tiers above, & nothing happens until you approve it.
  4. We do the recovery in-house: board repair, or firmware corruption work on the controller when the drive still powers up but reports wrong.
  5. Your data ships back on a target drive, & the Corsair SSD comes back with it.
Try software first in one specific case: the drive still shows up in your operating system & the problem is logical. Disk Drill, EaseUS, & R-Studio all handle deleted files, lost partitions, & volumes that mount wrong. Deleted files are the weakest of those cases, because once TRIM has run the controller unmaps those blocks, & no lab reverses that. None of those tools help when the BIOS doesn't see the drive, because there is nothing for them to scan.
That is where we start. No data, no recovery fee applies to every Corsair drive we take in, & every one of them is handled by the same technicians doing the rest of our SSD data recovery work at one address in Austin. No franchises, no outsourcing.
How Corsair SSD Recovery Works
The SSD data recovery approach depends on which chip is inside the drive and the specific firmware revision installed at the factory.
PC-3000 SSD connects to the controller through vendor-specific diagnostic commands, bypassing the normal NVMe or SATA interface. From there, we can read firmware modules, repair corrupted flash translation tables, and extract raw NAND contents when the controller firmware is too damaged to boot.
We evaluate every drive for free, provide a firm quote, and charge nothing if we cannot recover your data.
MP700: Gen5 Thermal Failure Pattern
The Corsair MP700 and MP700 PRO use the Phison PS5026-E26 controller, the same Gen5 silicon found in the Crucial T700, Sabrent Rocket 5, and Seagate FireCuda 540. E26 drives ran hot enough under sustained load that they shut down rather than throttling; Corsair shipped MP700 firmware 22.1 so the drive throttles down instead of cutting out when it overheats.
Corsair ships the MP700 with a heatsink on some SKUs, but many motherboard M.2 slots provide inadequate airflow for Gen5 thermal requirements.
The failure pattern: the drive operates normally for months or years under typical mixed workloads. A sustained sequential write (large file copy, game installation, OS migration) pushes the controller past its thermal throttling threshold. The firmware's thermal protection logic reduces clock speeds before the controller reaches its shutdown temperature, so a drive under a heavy sequential write can slow down or drop out mid-transfer.
Drives in this family reach the bench after that, either missing from BIOS entirely or showing as an uninitialized device with 0 bytes capacity. The E26 is not currently supported by PC-3000 SSD, so there is no firmware-level translator rebuild available for this controller. Recovery on an E26 is board-level work: restoring power delivery to the original controller so the drive answers the host again on its own silicon.
MP600 Family: E18 Firmware Panic and E16
MP600 Family: E18 Firmware Panic and E16 Thermal Stress
The Corsair MP600 family spans three Phison controller generations. The original MP600 (2019) uses the PS5016-E16, Phison's first consumer Gen4 controller. The MP600 PRO and MP600 PRO XT (2021-2022) use the PS5018-E18, a more mature Gen4 design with triple ARM Cortex-R5 cores, 4th-generation LDPC error correction, and improved thermal management.
Firmware corruption from thermal events is the primary failure mode: the drive operates normally until a sustained write pushes the controller past its thermal threshold, at which point the firmware panics and the drive drops offline. The E16 may or may not reappear after a cold boot depending on which firmware modules were corrupted.
The E18 is more reliable, but sudden power loss remains its vulnerability.
ACE Lab's PC-3000 SSD list carries the E16 for firmware work and the E18 as repair-only, with no published data-extraction path on the E18. An E18 case is therefore board-level work to revive the original controller.
SSD Pricing
Corsair SSD Recovery Pricing
SSD Recovery Calculator
Estimate Your Corsair SSD Recovery Cost
What type of SSD do you have?
Shomari Hohn
Aravind Udayakumar
David Dachenhaus (DDock)
Ludwig Jonsson
LaCie
MP600 Mini / E21T 2230
MP600 Mini Recovery on the Phison E21T 2230
The Corsair MP600 Mini and MP600 Core (2230 variant) use the Phison PS5021-E21T controller in the compact M.2 2230 form factor. This is the same controller found in the Sabrent Rocket 2230, Crucial P3 Plus, and many aftermarket Steam Deck and ROG Ally upgrade SSDs. The E21T is a 4-channel, DRAM-less NVMe Gen4 controller that relies on Host Memory Buffer (HMB) for FTL caching.
On an E21T failure (firmware corruption after power loss, FTL inconsistency from an HMB desync), the E21T is on ACE Lab's PC-3000 SSD supported list for firmware-level FTL reconstruction. We evaluate each drive on the bench first: if the current tooling does not cover the specific firmware revision on the drive in front of us, we say so rather than accept a job we cannot do.
MP510 / E12 Gen3
MP510: Phison E12 Gen3 and Legacy Force Series
The Corsair Force MP510 uses the Phison PS5012-E12, the most commercially successful NVMe Gen3 controller. The same silicon powers the Sabrent Rocket, PNY CS3030, and Seagate BarraCuda 510. The E12 is an 8-channel controller with DRAM cache and AES-256 hardware encryption. It has mature PC-3000 support through the Phison NVMe module in SSD Extended.
E12 failure modes are well-documented: firmware corruption from unclean shutdown is the primary cause. The drive disappears from BIOS or drops offline under load. Some units show as an unallocated RAW volume after a system crash.
PC-3000 accesses the E12 through Phison's diagnostic mode, reads the firmware state, repairs or replaces corrupted FTL modules, and images the NAND contents to a target drive. E12 recovery is among the more straightforward NVMe procedures because the controller has been in production since 2018, though ACE Lab scopes its E12 coverage to drives built with Toshiba/Kioxia NAND, so the NAND on your specific board decides what is available.
The older Corsair Force 3 and Force GT (SATA) used the SandForce SF-2281 controller. SandForce drives implement always-on AES encryption and proprietary DuraWrite compression that makes both chip-off and standard tooling recovery difficult. The SF-2281 requires specialized proprietary techniques outside standard PC-3000 utilities. These drives are now 10+ years old, and we still receive them when users pull data from old systems or backup drives.
Controller Architecture Grid
Corsair SSD Controller Map
MP700: Phison E26
Gen5 NVMe x4. M.2 2280. Up to 10,000 MB/s sequential read. AES-256 encryption with controller-bound keys. Known thermal shutdown failure pattern. Not currently supported by PC-3000 SSD; no firmware-level translator rebuild exists for this controller. Chip-off not viable due to encryption. Board-level repair is the recovery path.
MP600 PRO and XT: Phison E18
Gen4 NVMe x4. Triple ARM Cortex-R5. 12nm process. 8-channel with DRAM. 4th-gen LDPC error correction. AES-256 + TCG Opal 2.0. PC-3000 support is more limited than older Phison generations; some firmware revisions restrict to repair/reset rather than full extraction.
Original MP600: Phison E16
First consumer Gen4 controller. Essentially an E12 with Gen4 PHY. Higher failure rates than E18 successor. Prone to firmware corruption from thermal events. AES-256 encryption. PC-3000 SSD Phison module. Chip-off not viable.
MP600 Mini: Phison E21T
Gen4 NVMe x4. 4-channel. DRAM-less (HMB). M.2 2230 form factor. On ACE Lab's PC-3000 SSD supported list for firmware-level FTL reconstruction. Common in Steam Deck, ROG Ally, Surface Pro upgrades.
MP510: Phison E12
Gen3 NVMe x4. 8-channel with DRAM. AES-256 encryption. Most commercially successful Phison NVMe controller. PC-3000 SSD support via Phison Utility, scoped by ACE Lab to Toshiba/Kioxia NAND builds. Firmware corruption from power loss is the primary failure mode.
Force 3 and GT: SandForce SF-2281
Legacy SATA 6Gbps. Always-on AES encryption, DuraWrite compression, and RAISE parity. Chip-off not viable due to encryption. Requires specialized proprietary techniques outside standard PC-3000 utilities. These drives are 10+ years old but still arrive for recovery from old systems and backup drives.
NAND Supplier Variance
Corsair does not manufacture NAND flash. They purchase NAND from Micron, Kioxia (formerly Toshiba), and SK Hynix.
This matters for recovery because NAND supplier differences affect data scrambling patterns, page sizes, spare area layouts, and error correction parameters. PC-3000 SSD detects the NAND configuration automatically when connected through the Phison diagnostic interface, but the technician needs to verify that the detected NAND parameters match the physical NAND packages on the PCB.
A mismatch between the firmware's expected NAND configuration and the actual NAND installed (which can happen if a previous repair attempt installed the wrong firmware) will cause read errors during recovery.
AES-256 and Chip-Off Limitations
Encryption and Why Chip-Off Does Not Work on Corsair SSDs
Hardware AES is not present on every consumer NVMe SSD, but where a Phison controller does encrypt at rest, the key is generated on the drive and wrapped by a key tied to that controller's hardware-unique root, so it does not travel with the NAND packages.
Desoldering NAND flash packages from the PCB does not produce readable files either way. On an encrypting drive the dump is ciphertext; on one without encryption, the controller's XOR scrambling and LDPC error correction still stand between the raw pages and the data. That is why chip-off is marked "not viable" for the Phison NVMe controllers in our recovery database.
When the controller firmware is too corrupted for PC-3000 to access through the diagnostic interface, and the controller silicon itself has not failed, board-level repair is the next step.
Replacing failed passive components (capacitors, resistors, voltage regulators) around the controller can restore it to a state where PC-3000 can establish a diagnostic connection. If the controller die itself is damaged (rare but possible from electrical surges or severe thermal events), recovery options are limited to finding a donor controller from the same production revision and transplanting it, though this is not guaranteed to preserve the encryption keys.
Corsair SSD Recovery FAQ
My Corsair MP600 PRO disappeared from BIOS after a power outage. Can you recover it?
The MP600 PRO is built on a Phison PS5018-E18 controller. ACE Lab's PC-3000 SSD list carries the PS5018 as repair-only, with no published data-extraction path, so recovery on these drives is board-level work to revive the original controller, listed at the circuit board repair tier $900–$1,200.
My Corsair MP700 overheated and stopped working. Is the data gone?
The MP700 uses the Phison E26 Gen5 controller. Early units shut down rather than throttling under sustained write load, which Corsair addressed with MP700 firmware 22.1. Drives in this family reach us after a thermal event, invisible to BIOS. The E26 is not currently supported by PC-3000 SSD, so there is no firmware-level translator rebuild for this controller. Recovery on an E26 is board-level work to revive the original controller, listed at the circuit board repair tier $900–$1,200 or the PCB/NAND-swap tier $1,200–$2,500 depending on the extent of the board damage.
Can you recover data from a Corsair MP600 Mini 2230 SSD?
The MP600 Mini uses the Phison PS5021-E21T controller in a compact M.2 2230 form factor. This DRAM-less controller uses Host Memory Buffer (HMB) for FTL caching, which means the mapping table lives partially in system RAM. A system crash or power loss can leave the FTL in an inconsistent state. The E21T is on ACE Lab's PC-3000 SSD supported list for firmware-level FTL reconstruction, so a firmware-corruption case has a path; contact us for an honest assessment of your specific situation.
How much does Corsair SSD data recovery cost?
Corsair SSD recovery pricing follows our published SSD tiers. SATA simple-copy starts at $200; SATA file-system recovery starts at $250; SATA PCB repair is listed at $450–$600; SATA firmware recovery is listed at $600–$1,200; SATA PCB/NAND swap is listed at $1,200–$1,500. For NVMe drives (MP600/MP700 family) the corresponding tiers are $200, From $250, $900–$1,200, $900–$1,200, and $1,200–$2,500. Free evaluation with no diagnostic fees. No data, no fee guarantee on every recovery.
Why does Corsair use different controllers in different SSDs?
Corsair does not manufacture SSD controllers or NAND flash. They source controllers from Phison (E12, E16, E18, E21T, E26) and pair them with NAND from various suppliers (Micron, Kioxia, SK Hynix). This matters for recovery because the controller determines which toolchain and firmware version we need, and whether a firmware-level path exists at all.
Is chip-off recovery possible on Corsair NVMe SSDs?
Chip-off is not viable on any current Corsair NVMe SSD. Phison's proprietary XOR scrambling and LDPC error correction leave a raw NAND dump unintelligible without the original controller, and on a drive whose AES engine is active the dump is ciphertext on top of that. Board-level repair to revive the original controller is the only path when firmware-level PC-3000 access fails.
Send Us Your Corsair SSD
Free evaluation. Firm quote. No data, no fee. Ship your Corsair SSD to our Austin lab.
