Kingston SSD Data Recovery
Kingston is one of the largest SSD manufacturers by volume. Their consumer lineup spans five controller families from Phison, Silicon Motion, Marvell, and SandForce. The A400 is the single most common SSD we see with the SATAFIRM S11 firmware lockout. The KC3000, NV2, and A2000 each use different controllers requiring different PC-3000 modules. We recover all Kingston models; the tools and approach depend on the controller inside.
SSD from $200 | No Data, No Fee | Free Evaluation | Since 2008
Kingston SSDs We Recover
SATA SSDs
A400 (Phison PS3111-S11, SATAFIRM S11 failure), UV500 (Marvell 88SS1074), UV400 (Marvell 88SS1074), HyperX/V300 (SandForce SF-2281)
NVMe Gen3 SSDs
A2000 (SM2263EN, TLC+DRAM), KC2000 (SM2262EN), KC2500 (SM2262EN, TLC+DRAM), NV1 (Realtek RTS5763DL or Phison)
NVMe Gen4 SSDs
KC3000 (Phison E18, TLC+DRAM), NV2 (SM2267XT or E21T or SM2269XT, DRAMless), FURY Renegade (Phison E18)
PC-3000 SSD with Phison, Silicon Motion, and Marvell modules
10 min read
Kingston SSD Recovery
How Kingston SSD Recovery Works
Kingston does not manufacture its own SSD controllers. Each Kingston model uses a third-party controller from Phison, Silicon Motion, Marvell, Realtek, or (in legacy drives) SandForce. Recovery requires identifying which controller is inside the drive and loading the correct PC-3000 SSD module. The A400 uses a Phison PS3111-S11. The KC3000 uses a Phison E18. The NV2 ships with at least four different controllers depending on the production batch. We evaluate your drive for free, provide a firm quote, and charge nothing if we cannot recover your data. Pinning down the controller before any imaging is the core of our SSD recovery workflow, since loading a mismatched firmware profile can deepen the corruption it was meant to repair.
A400 satafirm s11
Kingston A400: The SATAFIRM S11 Problem
The Kingston A400 is one of the best-selling budget SSDs in the world. It uses the Phison PS3111-S11 controller paired with 2D or 3D TLC NAND and no DRAM cache. The A400 is also the single largest source of SATAFIRM S11 failures in our lab.
When the TLC NAND cells storing the flash translation layer (FTL) degrade beyond the ECC correction threshold, the PS3111 controller enters a protective lockout. The drive reports its model name as "SATAFIRM S11" in BIOS. It shows the correct capacity but is completely inaccessible to the operating system. Disk Management shows the drive as uninitialized.
Recovery requires PC-3000 SSD's Phison utility. The diagnostic interface accesses the controller below the firmware layer, rebuilds the corrupted FTL mapping tables, and images the NAND contents. The A400's Phison PS3111 does not use full AES encryption; it applies XOR data scrambling, which must be reversed during extraction but does not prevent data access the way AES-256 encryption does.
NVMe Drives: KC3000, NV2, A2000, KC2500
Kingston NVMe SSD Recovery: KC3000, NV2, A2000
Kingston's NVMe lineup spans three controller families across four price tiers. The KC3000 and FURY Renegade use the Phison PS5018-E18, a Gen4 controller with triple ARM Cortex-R5 cores, onboard DRAM, and AES-256 hardware encryption. The KC2500 and KC2000 use the Silicon Motion SM2262EN (Gen3, 8-channel). The A2000 uses the Silicon Motion SM2263EN (Gen3, 4-channel). All four have onboard DRAM for FTL caching.
The NV2 is Kingston's budget NVMe option and the most unpredictable to recover. Kingston ships the NV2 with at least four different controllers across production batches: SM2267XT, Phison E21T, Phison E19T, and SM2269XT. All are DRAMless and rely on Host Memory Buffer (HMB) for FTL metadata. A single power loss event can corrupt the FTL because the mapping data lives in NAND rather than dedicated DRAM.
SSD Pricing
Kingston SSD Recovery Pricing
SSD Recovery Calculator
Estimate Your Kingston SSD Recovery Cost
What type of SSD do you have?
Shomari Hohn
Aravind Udayakumar
David Dachenhaus (DDock)
Ludwig Jonsson
LaCie
Controller Architecture Grid
Kingston SSD Controllers and Recovery Methods
Phison PS3111-S11 (A400)
2-channel DRAMless SATA controller. The A400 pairs this with 2D or 3D TLC NAND. The PS3111 stores its FTL mapping in NAND cells that degrade at the same rate as user data. When those cells hit the ECC correction limit, the controller enters SATAFIRM S11 lockout mode. PC-3000's Phison utility covers the PS3105 through PS3111 family. Recovery involves accessing the diagnostic interface, reading the NAND contents with scrambling reversal, and rebuilding the flash translation layer. Data scrambling (not AES encryption) makes chip-off feasible as a last resort.
SATAFIRM S11 recovery details
Phison PS5018-E18 (KC3000)
Triple ARM Cortex-R5 cores, 12nm process, 8-channel NVMe Gen4 with onboard DRAM. The KC3000 pairs this with 3D TLC NAND for sequential reads up to 7,000 MB/s. Severe NAND degradation or sudden power loss can trigger firmware panics that drop the drive completely offline. ACE Lab lists the PS5018-E18 under its repair-only designation, so PC-3000 SSD does not rebuild the translator on this controller. Board-level repair (replacing failed PMICs or voltage regulators) preserves the encryption key and restores controller access.
Phison E18 recovery details
SM2262EN (KC2500 / KC2000)
Dual ARM Cortex-R5 cores, 8-channel NVMe Gen3 with onboard DRAM. The KC2500 pairs this with 96-layer 3D TLC NAND. The KC2000 uses the same controller with slightly different firmware tuning. Unclean shutdowns can corrupt the controller firmware, with power loss during SLC cache flush being the most damaging scenario. PC-3000 SSD covers the SM2262EN through its Silicon Motion module family. Recovery involves pin shorting to access ROM mode, then rebuilding the firmware tables and FTL mapping.
SM2262EN recovery details
SM2263EN (A2000)
4-channel NVMe Gen3 controller with onboard DRAM. The A2000 pairs this with 96-layer 3D TLC NAND and an XTS-AES 256-bit hardware encryption engine. The SM2263EN is the lower-channel sibling of the SM2262EN, sharing the same PC-3000 Silicon Motion module family. Improper shutdown corrupts controller firmware, with power loss during SLC cache flush being particularly damaging for the 4-channel design. Recovery involves pin shorting to access ROM mode, then rebuilding the firmware tables and FTL mapping.
Multi-Controller NV2
Kingston ships the NV2 with multiple controllers across production runs: Silicon Motion SM2267XT, Phison E21T, Phison E19T, and Silicon Motion SM2269XT. All are DRAMless Gen4 controllers using HMB for FTL metadata. The controller choice is not listed on retail packaging; we identify it from PCB markings during intake.
Marvell 88SS1074 (UV400 / UV500)
4-channel SATA controller with onboard DRAM. The UV400 and UV500 are mid-range SATA SSDs Kingston sold before consolidating around the A400 for budget and the MX-equivalent for performance. BSY state and firmware boot failures are the primary failure modes.
Rossmann does not currently offer in-lab recovery for the Kingston UV400 or UV500. ACE Lab staff have stated on the company forum that the Kingston part on this controller is not supported.
Marvell 88SS1074 controller reference
Kingston Multi-Controller Challenge
Why Kingston SSDs Require Controller Identification First
Kingston uses multiple suppliers for the same product line. The NV2, for example, has shipped with at least four different controllers from two different manufacturers. The A400 has had both 2D planar NAND and 3D TLC variants. Kingston's SSDNow V300 was the subject of controversy when Kingston silently switched from synchronous to asynchronous NAND mid-production.
This multi-sourcing means two Kingston NV2 drives bought from the same retailer on the same day can have entirely different controllers inside. The PC-3000 module for a Phison E21T is different from the module for a Silicon Motion SM2267XT. Loading the wrong module against the wrong controller produces no result or, in some cases, can corrupt the diagnostic interface.
We identify the controller before beginning any recovery work. On SATA drives, the controller chip is visible on the PCB. On M.2 NVMe drives, the controller may be under a label or thermal pad. Part numbers stamped on the controller die (e.g., SM2267XT for certain NV2 batches) determine which PC-3000 module to load and which pin-shorting procedure to follow.
5+
Different controller families used across the Kingston SSD lineup
4
Controllers found inside the NV2 alone (SM2267XT, E21T, E19T, SM2269XT)
PC-3000
Phison, Silicon Motion, and Marvell modules for Kingston coverage
Chip-off and Encryption
Chip-Off Recovery and Kingston Encryption
Chip-off viability varies across the Kingston lineup based on the controller's encryption implementation. The A400 with Phison PS3111-S11 uses XOR data scrambling rather than cryptographic AES encryption. Chip-off is difficult (the scrambling pattern must be reversed after reading), but the data is not encrypted in the mathematical sense. Controller-level recovery via PC-3000 is preferred, but chip-off remains a last resort if the controller is physically destroyed.
All NVMe Kingston SSDs (A2000, KC2000, KC2500, KC3000, NV1, NV2, FURY Renegade) use controllers with hardware AES-256 encryption. The encryption key is generated by and bound to the original controller silicon. Desoldering the NAND chips from a dead KC3000, for example, yields only ciphertext that cannot be decrypted without the original Phison E18 controller.
Board-level repair is the primary recovery path for encrypted Kingston NVMe SSDs. Replacing failed voltage regulators, PMICs, or capacitors on the original M.2 PCB preserves access to the AES key. Our microsoldering workstations handle BGA rework on M.2 2280 and 2230 form factors.
Legacy Kingston Drives
Legacy Kingston SSDs: SSDNow V300 and HyperX
Kingston's older SSDNow V300 and HyperX SATA drives used the SandForce SF-2281 controller. The SF-2281 applies always-on AES encryption (marketed as AES-256, though Intel discovered in 2012 that only AES-128 functions correctly at the silicon level), DuraWrite compression, and RAISE NAND parity simultaneously. This combination makes the SF-2281 one of the most challenging controllers for data recovery. Most labs historically declared SF-2281 BSY failures unrecoverable.
The SSDNow V300 was also the subject of a 2014 controversy when Kingston silently switched from faster synchronous NAND to slower asynchronous NAND mid-production, reducing performance without updating the product specs. This NAND variability means two V300 drives of the same capacity can have different NAND types, which affects the imaging parameters during recovery.
Kingston SSD Data Recovery FAQ
My Kingston A400 shows as SATAFIRM S11 in BIOS. Can you recover it?
Yes. The A400 uses a Phison PS3111-S11 controller. When the TLC NAND storing the flash translation layer degrades beyond ECC capacity, the controller enters a protective lockout and reports its identity as 'SATAFIRM S11' instead of the Kingston model name. PC-3000 SSD's Phison utility accesses the controller diagnostic interface, rebuilds the firmware tables, and extracts the data. This is one of the most common SSD failures we handle. Firmware recovery is $900–$1,200.
My Kingston NV2 is not detected in BIOS. Which controller does it have?
Kingston ships the NV2 with at least four different controllers depending on production batch: Silicon Motion SM2267XT, Phison E21T, Phison E19T, and Silicon Motion SM2269XT. The controller determines the recovery approach. We identify the controller from the drive label or PCB markings. The NV2's DRAMless HMB design makes it more vulnerable to FTL corruption from power loss than DRAM-equipped drives.
Is the Kingston KC3000 recoverable after firmware failure?
The KC3000 uses the Phison PS5018-E18, a Gen4 NVMe controller with triple ARM Cortex-R5 cores and AES-256 encryption. ACE Lab lists the PS5018-E18 under its repair-only designation, so PC-3000 SSD does not rebuild the translator on this controller. Board-level repair to fix failed voltage regulators or PMICs preserves the encryption key.
Can you recover data from Kingston enterprise SSDs like the DC600M?
Kingston enterprise SSDs (DC600M, DC1500M) use controllers with enhanced encryption and custom enterprise firmware. We evaluate each enterprise drive individually. Contact us with the specific model number for an honest assessment.
How much does Kingston SSD recovery cost?
Kingston SSD recovery is priced $200–$2,500. Simple data copies are $200. File system recovery is from $250. Circuit board repair runs $900–$1,200. Firmware corruption including SATAFIRM S11 is $900–$1,200. Advanced component repair requiring microsoldering is $1,200–$2,500. Free evaluation with no diagnostic fees.
Is chip-off recovery possible on Kingston SSDs?
The A400 with Phison PS3111-S11 uses data scrambling rather than full AES encryption, making chip-off technically feasible as a last resort.
Send Us Your Kingston SSD
Free evaluation. Firm quote. No data, no fee. Ship your Kingston SSD to our Austin lab.
