Drobo Symptom Recovery
Drobo Blinking Red Light Data Recovery
Your Drobo is blinking red, the Dashboard won't load, and the volume won't mount. A single bay blinking red usually means that one drive needs replacing. Alternating yellow and green across the bays means a rebuild or data-protection layout is in progress, and you shouldn't pull drives while it runs. If the chassis is dead or the Drobo no longer recognizes the pack, BeyondRAID recovery has to happen outside the Drobo. Drobo Inc. and its parent StorCentric were liquidated in 2023, and there's no manufacturer support. We image every disk through a write-blocker and reconstruct the BeyondRAID virtual LUN offline in our Austin, TX lab.
Updated June 2026
10 min read
Reading the Bay
What does a blinking red light on a Drobo mean?
A single bay blinking red means that one disk has failed and needs replacing. Alternating yellow and green across the bays means BeyondRAID is rebuilding or relayouting data, so leave the disks where they are. The red light of death is a reboot loop. The chassis can't assemble the BeyondRAID volume from the pack. That's a recovery case, not a drive-swap case.
LED PatternMeaningAction
Single bay blinking redThat drive has failed.Drobo's guide says to replace it, and that starts a rebuild. If the data is irreplaceable and you have no verified backup, image every disk through a write-blocker before any rebuild. Don't pull any other bay.
Alternating yellow and green across baysData protection or rebuild in progress.Do not remove drives. Wait for the pattern to resolve.
These LED meanings come from Drobo's official user guides.
The “red light of death” is a reboot loop. The chassis powers on, tries to assemble the BeyondRAID volume from the disk pack, fails, and cycles again. The controller can't bring the virtual LUN online, so the volume never reaches your host.
Beyondraid Layer
What is BeyondRAID and why is it different from a normal NAS?
BeyondRAID is Drobo's proprietary block-level virtualization layer. Instead of building a single RAID 5 or RAID 6 set across the disks, BeyondRAID lays down zone-based parity over a thin-provisioned virtual LUN. The virtual volume the operating system sees is sized regardless of how much disk capacity is installed. The controller tracks which blocks actually contain data with a bitmap, instead of relying on uniform stripes the way a standard RAID would.
On Drobo's 5N and 5N2 NAS units, the virtual BeyondRAID volume is then formatted with ext3 or ext4 on top. On a direct-attached Drobo, your computer's operating system formats the virtual LUN as if it were one big external disk. Either way, the filesystem is sitting on a virtual block device whose underlying layout only exists in the Drobo's metadata.
The Drobo controller keeps that metadata in a Data Allocation Table. The table maps where each block of the virtual volume lives across the member drives. None of that is standard RAID metadata, and no Linux kernel knows how to assemble it. The BeyondRAID metadata has to be parsed before any filesystem can be mounted. Reconstructing that table from raw drive images is a procedure in its own right, laid out step by step in how BeyondRAID reconstruction works.
One disk has failed and should be replaced.
BeyondRAID is rebuilding or relayouting data. Do not remove disks.
Red-light reboot loop
Disk pack
The set of member disks that together hold one BeyondRAID array.
Relayout
BeyondRAID redistributing data and parity as disks are added or replaced.
Thin provisioning
The virtual volume's size doesn't depend on how much disk capacity is installed. A bitmap tracks which blocks actually contain data.
The virtual block device the operating system formats and mounts; its underlying layout exists only in the Drobo metadata.
The metadata the Drobo controller keeps to map where each block of the virtual volume lives across the member drives. It has to be parsed before any filesystem can be mounted.
Why It Is Harder
Why is Drobo recovery harder than recovering from a normal NAS?
BeyondRAID has no open specification, and standard mdadm, LVM, and hardware RAID controllers can't interpret it. Getting the data back takes specialized software that parses the Data Allocation Table. BeyondRAID lays down variable stripe widths, so that table has to be parsed zone by zone. StorCentric and Drobo Inc. liquidated in 2023, and there's no support path left.
Standard RAID tools can't read BeyondRAID
mdadm, LVM, ZFS, and Btrfs are all open formats. A working Linux box can read a Synology SHR or generic mdadm array. BeyondRAID isn't open, and standard mdadm and LVM tools can't interpret it. QNAP is different on this point: QTS is built on mdadm, LVM, and ext4, and QuTS hero is built on ZFS. If a QNAP red status light error shows up, what it means depends on the unit, and that's a separate diagnosis.
Dynamic stripe widths
BeyondRAID can lay down different stripe widths for different zones, especially after disks have been added or upgraded over time. That means reconstructing the array by hand requires walking the Data Allocation Table zone by zone instead of assuming a single layout.
Thin-provisioned virtual LUN
The bitmap that tracks allocated blocks has to be parsed before the filesystem can be mounted.
Vendor is gone
On a Drobo, there's no vendor. StorCentric and Drobo Inc. liquidated in 2023. There's nobody to escalate a support case to.
Vendor Liquidation
What happened to Drobo Inc.? Why can't I get support?
Drobo, Inc. filed its own Chapter 11 petition on June 20, 2022, the same day its parent company StorCentric filed. In April 2023, the cases moved from Chapter 11 restructuring to Chapter 7. Chapter 7 is a liquidation: the company's property gets sold, and nothing gets reorganized.
There's no manufacturer warranty and there are no authorized replacement parts.
A dead Drobo is now a hardware-recovery problem with no vendor path. If the chassis or controller has failed, we pull the disks and reconstruct the BeyondRAID layout offline from images of those disks. It's one of the harder cases in RAID data recovery, because BeyondRAID writes variable stripe widths that the standard mdadm tooling used on conventional arrays can't parse.
Chassis Swap
Can I just move the disks to a different Drobo chassis?
Before you try it, image every disk through a write-blocker.
Process
How does Rossmann Group recover a Drobo?
All work happens in-house at our Austin, TX lab. Single location, no franchises, no outsourcing, no shipping your disks to a third-party partner. Our workflow is image-first.
  1. Ship us the whole Drobo and every drive.
  2. Write-blocked imaging of every disk. We image each member disk with PC-3000 Portable III, PC-3000 Express, or PC-3000 SSD, depending on the disk type. If a disk has failed heads, we swap in donor heads on the clean bench before we try to image it.
  3. Parse BeyondRAID metadata offline. We parse the Data Allocation Table from the imaged copies with specialized software. Then we reconstruct the virtual LUN zone by zone, accounting for the dynamic stripe widths that BeyondRAID lays down as disks are added or replaced.
  4. Mount the filesystem and extract. On 5N and 5N2 units, we mount the reconstructed virtual LUN as ext3 or ext4 and walk the share tree. On direct-attached Drobos, we mount the LUN with whatever filesystem your computer formatted it with. We check the files against your priority list and copy them to target media.
No diagnostic fee. No data, no recovery fee. Free evaluation before any work begins.
How much does Drobo recovery cost?
We bill Drobo recovery per drive, using the published hard drive tiers. Each member disk is scoped by its own failure type: From $250 for file-system work, $600–$900 for firmware repair, and $1,200–$1,500 for head swaps. Reconstructing the BeyondRAID array is one more fee of $400-$800.
Drobo Blinking Red Light Recovery FAQ
Is my data gone if my Drobo is blinking red?
Not necessarily. A single bay blinking red means that one drive has failed and needs replacing. Alternating yellow and green across the bays means BeyondRAID is rebuilding or relayouting data. Pulling drives while it's doing that can cause data loss. The red light of death is a reboot loop. The chassis can't assemble the BeyondRAID volume from the disk pack. At that point, data recovery happens outside the Drobo.
Can I put my Drobo disks into a different Drobo to recover my data?
Before you try that, image every disk through a write-blocker.
Does Drobo still offer support?
No. Drobo, Inc. filed its own Chapter 11 petition on June 20, 2022, the same day its parent company StorCentric filed. In April 2023, those bankruptcy cases were converted to Chapter 7 liquidation. There is no manufacturer warranty and no authorized replacement parts.
We price a Drobo off our published hard drive tiers, one drive at a time. We bill each member disk by its own failure type: From $250 for file-system work, $600–$900 for firmware repair, and $1,200–$1,500 for head swaps. Target media and tax come on top of that, plus donor cost when donor parts are needed. Reconstructing the BeyondRAID array is one more fee of $400-$800. If we recover nothing, you don't pay.
Drobo blinking red and the Dashboard won't load?
Ship us the whole unit. The evaluation is free. No data, no fee.
