mdadm Recovery
mdadm recovery separates sector imaging from array math. The single most destructive thing you can do is run mdadm --create --assume-clean on the original disks to "fix" an inactive array. That writes fresh superblocks; if the order, metadata version, or chunk size is off, the data_offset shifts and the filesystem turns to garbage. We clone every member, attach the images read-only with losetup -r, then use mdadm --examine and mdadm --assemble --readonly against the clones.
Updated 2026-06-21
Send your drives to our lab and we recover the data in-house. All mdadm work is performed at 2410 San Antonio Street, Austin, TX 78705. There is no diagnostic fee, and under no data, no recovery fee, you pay nothing if we cannot reassemble your array and extract the filesystem. The Rossmann Group has been recovering data since 2008, and software RAID cases never leave the building or get outsourced.
What is mdadm, and why does corruption look like drive failure?
mdadm is the Linux Multiple Device administrator, the software RAID layer underneath almost every modern NAS and most Linux servers. It binds several block devices into one virtual array using a small binary superblock written to each member. The array geometry, chunk size, parity rotation, disk order, and data_offset all live in that superblock, not in any controller card.
That is the weak point. When mdadm cannot read a coherent set of superblocks, the array goes inactive and the kernel reports something like mdadm: no recogniseable superblock or refuses to assemble at all. Most people assume the platters died. They usually have not. A single bad sector in the metadata region, a dropped member, or a desynchronized events counter produces the same symptom as a dead array while the heads, motor, and user data area stay healthy.
Misreading that state is how data gets destroyed. People accept a firmware prompt to rebuild, move the disks into a new chassis that auto-initializes them, or follow a forum recipe to recreate the array. Each of those overwrites the only surviving map of where the data lives.
What happens if you run mdadm --create?
Running mdadm --create on an existing array is the leading cause of permanent software RAID data loss. Forums, StackOverflow threads, and even vendor support scripts routinely tell people to run mdadm --create ... --assume-clean with the original disks to force an inactive array back to life. The QNAP-style recipe looks like mdadm -CfR /dev/md1 --assume-clean -l 5 -n 5 -c 512 -e 1.0 followed by the member partitions.
--create writes a fresh superblock to every member. The original superblocks, with the true disk order, metadata version, chunk size, and parity rotation, are gone. If any of those parameters is even slightly off, the new superblock places data_offset at the wrong sector. The array assembles and mounts, but every read lands at the wrong byte offset, so the filesystem payload comes back as perfectly interlaced garbage.
It gets worse with two common layers. If LVM was on top, the new mdadm superblock overwrites the LVM PV header, severing the link to the volume group.
If the user then runs fsck against the garbled volume, the repair tool decides the inodes are corrupt and zeroes them out, which shreds the payload for good. "It worked for someone on a forum" only means that person guessed every parameter correctly. It is a coin flip you do not need to take.
The safe path never touches the originals. We read superblocks with mdadm --examine and assemble read-only with mdadm --assemble --readonly against clones. When on-disk metadata is too damaged for mdadm to parse at all, we reconstruct the array geometry virtually in software using Data Extractor Express RAID Edition, the genuine ACE Lab array tool that runs on our PC-3000 Express, working from the image files rather than the live members.
How is the mdadm superblock laid out on disk?
Recovery is only possible because the superblock has a fixed structure and the metadata version dictates exactly where it sits and where the data payload begins. Misdetecting the version shifts the payload, so the version is the first thing an engineer pins down.
VersionMetadata locationPayload startNotes
0.90End of deviceByte 0Legacy. 2TB member limit, 28-device limit. Found on older Synology and Debian systems.
1.08–12KB from endByte 0Payload at offset 0, so a member can auto-mount as a standalone volume and desynchronize. Dangerous.
1.1Start of deviceAfter superblockRare in modern production.
1.24KB from startdata_offsetModern default. Payload starts after a calculated data_offset, typically 1MB-aligned.
Whatever the version, a valid superblock carries the array UUID, the chunk size and parity layout (left-symmetric is the RAID 5 default), the data_offset, the member role or device index, and the update time and events counter. Those last two are the synchronization metric. The events counter is what tells us which members are current and which dropped early.
Read the version wrong and you place the data payload in the wrong spot, which is exactly the trap mdadm --create falls into. A wiped or unreadable superblock is its own recovery path, detailed in our mdadm missing superblock recovery writeup.
What does mdadm --examine output actually show?
mdadm --examine is read-only. It prints the array UUID, RAID level, layout, chunk size, data_offset, update time, events counter, and the device role for one member. Those fields are what an engineer reads before deciding which member is stale or how to carve geometry.
A representative mdadm --examine on one member of a four-disk RAID 5 with 1.2 metadata looks like this:
/dev/loop3:
          Magic : a92b4efc
        Version : 1.2
    Array UUID : 7d3a9c11:4f6b8e02:91ad55cf:0e2b73d4
  Creation Time : Fri Mar 14 09:21:07 2025
     Raid Level : raid5
   Raid Devices : 4
 Used Dev Size : 31255627776 (14903.84 GiB)
    Array Size : 93766883328 (44711.53 GiB)
    Data Offset : 264192 sectors
   Super Offset : 8 sectors
          State : clean
    Device UUID : b1c40af9:2e7d6610:8a55c3be:14f902dd
    Update Time : Mon Jun 15 03:42:18 2026
       Checksum : 5a1e9b3c - correct
         Events : 41763
         Layout : left-symmetric
     Chunk Size : 512K
   Device Role : Active device 3
   Array State : AAA. ('A' == active, '.' == missing)
Each field maps to a concrete recovery decision. These are the parameters an engineer pins down before assembling anything.
Array UUID
Binds the physical members to one logical array. Members that share a UUID belong together; a member with a different UUID was carved from a different array and does not belong in the set.
Raid Level and Layout
raid5 with left-symmetric is the parity rotation algorithm. Layout plus level fix how parity walks the stripes, which is half of the destriping math. Read either one wrong and the reconstruction reads from the wrong member.
Chunk Size
512K is the byte size of each stripe unit. Chunk size, disk order, layout, and data_offset together define the destriping map. A wrong chunk size interlaces every stripe.
Data Offset
264192 sectors (129 MiB) is where the payload begins on this member, after the 1.2 superblock and reserved area. The payload does not start at sector zero, so the offset must be exact.
Super Offset
8 sectors is where the 1.2 superblock sits, 4KB from the start of the device. That is the metadata structure carrying every field in this list.
Update Time
The last time the kernel wrote metadata to this member. Read with the events counter, it shows when a member dropped out relative to the survivors.
Events counter
41763 increments on every metadata update. When a member drops, its counter freezes while the survivors keep counting. The member with the lowest events count is the stale one and holds old data. Events drives stale-member identification.
Array State
AAA. is one letter per slot: A for a slot mdadm believes is active, . for a slot it believes is missing. This member sees three active members and one absent, so the array was already degraded when this superblock was last written.
Device Role
Active device 3 is this member's slot in the stripe order. Device role, data_offset, chunk size, and layout are exactly the four parameters that mdadm --create would overwrite and that hex-carving has to recover when the superblocks are gone.
What if mdadm --examine shows an Intel IMSM container instead of a version?
That member belongs to an Intel IMSM (Matrix Storage / RST / RSTe) array, the on-board FakeRAID. mdadm reads it natively with --metadata=imsm. You do not need the original Intel board: the metadata is on the disks, so assemble the container by scan and the volume inside comes up.
IMSM is Intel Matrix Storage Manager, also branded Intel RST and RSTe and commonly called FakeRAID. The array is defined in the motherboard or HBA option ROM, but the RAID work runs in software, in the OS driver on Linux. That means a dead Intel board is not a wall. mdadm reads IMSM arrays natively, the same on-disk-metadata principle that lets a Dell PERC or LSI DDF array be reconstructed without its original controller.
The tell is the signature. The native member shown earlier on this page reports the mdadm magic a92b4efc and a Version : 1.2 line. An IMSM member instead reports the Intel container signature Intel Raid ISM Cfg Sig. and no native Version: line. Read that signature on each member with a read-only mdadm --examine before you touch anything, because it decides whether you assemble as native md or as an imsm container.
IMSM writes its metadata to the trailing sectors at the end of each member, not byte zero. The partition table and the filesystem at the start of the disk can look perfectly normal while the array itself is broken, so a clean-looking front of disk is no evidence the array is healthy. IMSM also uses a two-level model: an outer container holds the metadata, and one or more RAID volumes live inside that container. mdadm --examine --scan, optionally with --export, surfaces the container UUID and the member volumes so you can see the structure before assembly.
This is why an explicit native-style assemble fails on IMSM. A command like the following looks for native md superblocks, finds none on the IMSM members, and brings nothing up:
mdadm --assemble /dev/md0 /dev/sda /dev/sdb
The correct path is container-first: let mdadm discover and assemble the imsm container by scan, then the RAID volume inside it activates. The forensic discipline is identical to native mdadm. Image every member over a write-blocked connection, run mdadm --examine read-only on each surviving member, and never run mdadm --create, which is the same overwrite trap covered in our mdadm missing superblock recovery writeup.
Does a missing superblock on one drive mean that drive is dead?
No. The mdadm superblock is a single 4KB metadata structure. On the modern 1.2 format it sits 4KB from the start of the member, and on the 1.0 and 0.90 formats it sits near the end. The striped user data lives in the multi-terabyte payload area after data_offset, physically separate from that metadata sector.
A lone bad sector or a stray write inside the superblock region makes mdadm reject the member with no recogniseable superblock, but the data stripe on that drive is intact and fully readable. The drive is not dead. Only its metadata sector is corrupt.
The destructive reflex is to treat that member as failed and re-add it. Assemble the array writable, run mdadm --add on the rejected drive, or let the NAS firmware re-add it on its own, and the kernel treats it as a fresh spare. It immediately starts a recovery that recomputes the member's contents from the surviving drives and writes the result back over the intact stripe.
If the survivors are stale or the geometry is even slightly wrong, that resync overwrites good data with a bad reconstruction, and the original stripe is gone. This is why imaging is not optional and has to come before any assembly attempt. Every member, including the one with the missing superblock, is cloned first, then the superblock is rebuilt or the geometry carved against the clones with mdadm --assemble --readonly, never re-added on the originals.
How do you carve array geometry from the ext4 0xEF53 magic?
When the superblocks are missing or untrustworthy, the geometry can be rebuilt from the filesystem itself. An ext4 filesystem keeps its primary superblock at byte offset 1024 (0x400) from the start of the filesystem, and the magic number 0xEF53 (stored on disk as little-endian bytes 53 EF) sits at offset 0x38 inside that superblock. So the magic always lands 0x438 bytes into the logical ext4 payload.
That fixed relationship turns a hex search into a geometry proof. Finding that 0xEF53 magic at 0x100438 on a member, which is 1MB plus 0x438, proves that member is disk 0 and that the mdadm data_offset was exactly 1MB. Locating fragments of the ext4 block-group descriptor tables across the other members then validates the chunk size and the disk order.
We confirm all of that against the clones before any assembly is attempted, so the array math is verified, not guessed.
What does an events counter mismatch mean, and is --force safe?
When a drive disconnects, the kernel drops it and keeps writing to the survivors. The dropped drive's events counter freezes while the active members keep counting up. After a reboot, mdadm sees the gap and refuses to assemble, because it cannot tell which members are coherent.
mdadm --assemble --force permits assembly of slightly desynchronized superblocks, and it has a place in recovery, but it is a sharp tool. Run against the wrong member, it feeds stale blocks into the parity math and corrupts the reconstruction.
We use it only read-only, only against clones, and only after the events counters across all members have been compared with mdadm --examine to identify and exclude the stale, lowest-event drive. On the original disks, in writable mode, with the stale member included, it is how a recoverable array becomes an unrecoverable one.
How do you assemble an mdadm array read-only, step by step?
Read-only assembly runs only against forensic clones attached with losetup -r. The sequence is examine, then mdadm --assemble --readonly, then mount -o ro. Never run mdadm --create, and never assemble the original drives writable.
The whole sequence targets loop devices backed by write-blocked images, never the originals. Each member image is mapped read-only, the events counters are compared, then the array is assembled and the filesystem mounted read-only:
# 1. Map each write-blocked image to a read-only loop device
losetup -r /dev/loop0 disk0.img
losetup -r /dev/loop1 disk1.img
losetup -r /dev/loop2 disk2.img
losetup -r /dev/loop3 disk3.img
# 2. Examine every loop device and compare the Events counters
mdadm --examine /dev/loop0
mdadm --examine /dev/loop1
mdadm --examine /dev/loop2
mdadm --examine /dev/loop3
# 3. Assemble strictly read-only against the clones
mdadm --assemble --readonly /dev/md0 \
      /dev/loop0 /dev/loop1 /dev/loop2 /dev/loop3
# 3b. --force is read-only-only here, used ONLY after excluding
#     the lowest-Events (stale) member from the set
mdadm --assemble --readonly --force /dev/md0 \
      /dev/loop0 /dev/loop1 /dev/loop3
# 4. Mount the ext4 filesystem read-only, journal replay suppressed
mount -o ro,noload /dev/md0 /mnt/recover
Every command targets loopN clones. The originals stay write-blocked images that nothing in this sequence can touch. The --force variant stays read-only and is used only after mdadm --examine has identified and excluded the lowest-events member, and mount -o ro,noload suppresses ext4 journal replay so no write reaches the array. If assembly fails because the superblocks are gone rather than desynchronized, the path is hex-carving the geometry and reconstructing the array with Data Extractor Express RAID Edition on our PC-3000 Express, not mdadm --create.
Why is RAID 5 rebuild not routine on a degraded array?
A RAID 5 rebuild has to read every sector of every surviving member to recompute the missing parity. Consumer SATA drives carry an Unrecoverable Read Error rate near 1 in 10^14 bits, which is roughly one URE per 12.5TB read. A degraded four-bay array of 16TB drives forces about 48TB of sequential reads during resync, so encountering a URE is statistically near-certain.
Enterprise hardware controllers puncture the unreadable stripe and keep the volume online. Linux mdadm records the address in its bad block list and finishes the resync. In both cases the data that lived in the unreadable region is permanently lost, which is a different outcome from losing the whole array but not a recoverable one.
That is why we never frame a degraded RAID 5 rebuild as a routine operation. RAID is availability, not a backup. Before any rebuild is even discussed, every member is imaged so the resync runs against clones where a URE costs nothing.
The hardware-controller side of this same problem, with PERC, Smart Array, and MegaRAID parity rotation, runs through our RAID data recovery workflow, since the on-disk geometry, not the card, is what we reconstruct.
Why do SMR drives get ejected mid-rebuild?
Drive-Managed Shingled Magnetic Recording drives stall during the sustained sequential writes a rebuild demands. A resync floods the disk, and the drive pauses host communication while it reshingles.
The default Linux block-layer timeout at /sys/block/sdX/device/timeout is usually 30 seconds. When an SMR member stalls past that, the kernel decides the drive is dead, issues a bus reset, and drops it from the array mid-rebuild. Stack a second SMR member into the same resync and the array cascades into total collapse. Cloning the slow members first takes that failure mode off the table.
Why does a corrupted or missing write-intent bitmap force a full resync?
A write-intent bitmap records which regions of the array had writes in flight, so after an unclean shutdown mdadm resyncs only those dirty regions instead of rereading the entire array. It comes in two forms.
An internal bitmap is stored alongside the array metadata on the members themselves (--bitmap=internal). An external bitmap lives in a separate file (--bitmap=/path/to/file), which the mdadm manual only treats as known-safe on ext2 or ext3. The value is internal, none, or a real path; there is no bare file keyword.
When the bitmap is missing or unreadable, mdadm has no record of which regions were dirty at the crash. The only safe assumption is that any region could be inconsistent, so recovery falls back to a full-array resync rather than a targeted one. That is a consequence of what the bitmap is for, not a shortcut: without it there is nothing to scope the resync to.
The bitmap does not make a degraded array safe to resync. A bitmap-directed partial resync still reads every surviving member across the dirty regions, and on a degraded array an Unrecoverable Read Error inside those regions cannot be rebuilt from parity, so that data is lost even though fewer sectors are read.
Consumer SATA drives sit near one URE per 10^14 bits, about one per 12.5TB, so a multi-terabyte degraded resync is statistically likely to hit one. mdadm logs the bad block and carries on, and the stripe it belonged to is gone. This is why every member is cloned with ddrescue before any resync, and why md deliberately refuses to auto-start an array that is both dirty and degraded rather than risk feeding inconsistent stripes into the parity math.
Why is an interrupted mdadm --grow reshape a forensic recovery, not a restart?
mdadm --grow changes the geometry of a live array: adding a member to a RAID 5, changing the chunk size, or converting the level. mdadm relocates every stripe into the new layout and tracks how far it has gotten in reshape_position. While that runs, the array straddles two geometries at once. Everything before reshape_position is already in the new layout; everything after it is still in the old one.
A reshape that overwrites data in place, such as adding a drive or shrinking the data area, has to preserve the region it is about to overwrite. mdadm copies that critical section to the location given by --backup-file.
The size of that backup region depends on the geometry change, so it is not a fixed byte count. If a member fails mid-reshape, the array is now degraded and mid-transition simultaneously, and you cannot simply rerun the grow.
mdadm needs the correct reshape_position and, for an in-place reshape, the backup file. Without the backup file its default is a loud abort with Failed to restore critical section for reshape, not a silent finish that writes wrong data. That abort is protecting the array.
Recovery starts by reading reshape_position from mdadm --examine, then treating the two zones separately: the reshaped region is decoded under the new geometry and the un-reshaped region under the old one, and the two are reconciled offline against clones. The ext4 superblock magic 0xEF53 anchors the filesystem so the data offset can be located independently of which geometry a given stripe was written in.
Array-level reconstruction of a straddled reshape runs on Data Extractor Express RAID Edition, never on mdadm --create against a degraded or mid-reshape array, which would write fresh superblocks over the very state that records where the reshape stopped. The same superblock-first logic drives our missing mdadm superblock recovery workflow.
Why is most NAS storage really a nested mdadm stack?
Most mdadm recovery cases do not come from bare-metal servers. They come from NAS appliances, where mdadm is layer one of a stack. The vendors do not use a proprietary format.
They use mainline Linux mdadm, open-source LVM2, and standard filesystems. The complexity is the nesting, not secrecy.
Vendor / OSLayer oneVolume layerFilesystem
Synology SHRmdadm (RAID 1/5/6)LVM2 volume groupBtrfs or ext4
QNAP QTSmdadm (RAID 1/5/6)LVM2 thick and thin (dm-thin)ext4
Asustor / TerraMastermdadm (RAID 1/5/6)LVM2 volume groupext4 or Btrfs
Synology SHR slices mixed-capacity drives into uniform partitions, builds multiple mdadm arrays across those slices, pools every md device into one LVM volume group, and formats the resulting logical volume with Btrfs or ext4. SHR is not proprietary. It is mdadm plus LVM plus Btrfs/ext4, and it reassembles on a vanilla Linux workstation with no Synology hardware present. QNAP QTS follows the same pattern with standard mdadm under LVM2 thick or dm-thin pools.
The consequence for recovery is strict ordering. The mdadm layer must be reassembled read-only first, because the LVM PV and the filesystem do not exist until the md device is presented. Trying to repair LVM or mount Btrfs while the underlying software RAID is still inactive is futile, because the block device it lives on has not been built yet.
That same mdadm-then-LVM ordering drives our Synology SHR recovery and our QNAP QTS recovery, and it is the reason these are NAS recoveries first and filesystem recoveries second. Once the array is up, the LVM step runs through our Linux LVM recovery process and the on-disk Btrfs through our Btrfs recovery process.
How do professional engineers recover an mdadm array?
Our workflow is strictly offline and read-only. Every command runs against forensic clones, never the original drives. Imaging and reconstruction are two separate stages.
  1. Write-blocked imaging: Every member is cloned sector-by-sector with ddrescue or the PC-3000 Portable III behind a write blocker. On drives with bad sectors or SMR stalls, the imager's adaptive read parameters and long timeouts pull the metadata regions and the data area without killing the drive.
  2. Map to read-only loop devices: Each image is attached with losetup -r so every later operation is physically read-only against the clone.
  3. Read-only superblock inspection: We run mdadm --examine on each loop device to read the UUID, chunk size, parity layout, data_offset, device role, and events counter, and to identify any stale member.
  4. Geometry validation when metadata is gone: When superblocks are missing, we carve the ext4 0xEF53 magic and block-group descriptors across the images to prove disk order, chunk size, and data_offset before assembling anything.
  5. Software reconstruction: The geometry is reassembled virtually against the image files, with mdadm --assemble --readonly where the on-disk metadata is usable, or with Data Extractor Express RAID Edition on our PC-3000 Express when the metadata is too corrupt for mdadm to parse. The hardware images the drives; the software rebuilds the array. Neither ever writes to a member.
  6. LVM, filesystem, mount, export: For NAS stacks we recover the LVM layer next, then mount the ext4 or Btrfs filesystem read-only and copy the data to a separate drive you provide.
All work is performed in-house in Austin, TX. We use named equipment: PC-3000 Portable III, PC-3000 Express, Data Extractor Express RAID Edition, and a ULPA-filtered clean bench. Single location, no franchises, no outsourcing. Founded in 2008.
What should you avoid before sending the drives?
Most permanent mdadm data loss comes from advice that treats a logical array problem as a hardware problem. The following patterns are the ones we routinely undo, or fail to undo when it is already too late.
Running mdadm --create to "rebuild" the array
mdadm --create --assume-clean writes fresh superblocks. One wrong parameter shifts data_offset and turns the payload to garbage, and a later fsck finishes the job. Never run it on original media.
Scanning the NAS live over SSH or its IP address
Tools that promise to recover a NAS without unplugging the drives force the kernel to serve heavy reads through a degraded abstraction and retry weak sectors without limit. That converts recoverable surfaces into head crashes. Power down and image first.
Letting the appliance or a new chassis auto-rebuild
Booting the drives in a replacement NAS or accepting a firmware repair prompt can auto-initialize or resync from corrupt state, overwriting the user data area. Image first, migrate never.
Forcing assembly with the stale member included
mdadm --assemble --force with the lowest-event drive still in the set feeds outdated blocks into parity. Identify and exclude the stale member first, read-only, against clones.
How much does mdadm recovery cost?
mdadm recovery is priced per drive: each member is imaged and analyzed individually, and the virtual array reassembly is performed in-house at no separate line item. Standard consumer NAS and server drives use our HDD pricing tiers:
  • Array reassembly and filesystem recovery: From $250
  • Firmware repair (drive unrecognized or wrong size): $600–$900
  • Head swap (clicking or not spinning): $1,200–$1,500
Helium-filled enterprise drives (10TB and larger Toshiba MG, WD Ultrastar, Seagate Exos), common in modern arrays, use helium-specific pricing: From $200 through $3,000–$4,500. A multi-bay NAS or server array is priced as the sum of the applicable per-drive tiers.
Rush service adds 100. +$100 rush fee to move to the front of the queue Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
No diagnostic fees. No data, no recovery fee. If we cannot reassemble your array and extract the filesystem, you pay nothing for the recovery attempt.
How long does mdadm recovery take?
Imaging takes roughly 6 to 10 hours per 4TB member. A clean array with intact superblocks is usually reassembled in 1 to 2 business days. A NAS stack that needs mdadm reassembly, LVM metadata recovery, and hex carving of a lost geometry typically takes 2 to 4 business days. Drives with bad sectors, SMR stalls, or mechanical damage need slower bitwise imaging with PC-3000, which adds time.
Frequently asked questions
Can I run mdadm --create --assume-clean to recover my array?
No. mdadm --create writes fresh superblocks to the member drives. If the disk order, metadata version (1.2 versus 1.0), chunk size, or parity rotation is wrong, the data_offset shifts and the filesystem payload becomes interlaced garbage. If LVM sat on top, the new superblock overwrites the PV header, and a later fsck zeroes the inodes it thinks are corrupt. Use mdadm --examine and mdadm --assemble --readonly against clones instead.
Why did my RAID 5 rebuild fail and crash the volume?
A rebuild reads every sector of every surviving drive to recompute parity. Consumer drives carry a URE rate near 1 in 10^14 bits, about one per 12.5TB. A degraded four-bay array of 16TB drives forces about 48TB of reads, so hitting a URE is near-certain. Linux mdadm records the address in its bad block list and finishes the resync, and the data in that region is permanently lost. RAID is availability, not a backup.
How do I safely reassemble a degraded mdadm array?
Never work on the originals. Clone each member with ddrescue or PC-3000 Portable III, attach the images read-only with losetup -r, read the superblocks with mdadm --examine, then assemble with mdadm --assemble --readonly and mount read-only to verify before copying anything off.
Can I recover NAS data without the original enclosure?
Yes. Synology, QNAP, Asustor, and TerraMaster run standard Linux mdadm with LVM on top, not a proprietary format. The drives parse on a vanilla Linux workstation using read-only loop devices and standard mdadm and LVM tools. The chassis is not required.
What does an mdadm events counter mismatch mean?
The members dropped out of the array at different times. The drive with the lowest events count is stale and holds old data. Forcing assembly without excluding that stale member feeds outdated blocks into the parity math and corrupts the reconstruction. We identify it with mdadm --examine before doing anything else.
Is Synology SHR a proprietary RAID format?
No. SHR is mdadm aggregating mixed-size partitions into RAID 1, 5, or 6 sets, LVM pooling those md devices into a volume group, and Btrfs or ext4 on top. It reassembles on any Linux workstation without Synology hardware. The work is Linux storage expertise, not a closed-format secret. The same is true of QNAP, Asustor, and TerraMaster.
Does an mdadm write-intent bitmap protect a degraded array?
No. The bitmap only scopes a resync to the regions that were dirty at an unclean shutdown, which speeds recovery on a healthy array. On a degraded array those regions still have to be read from every surviving member, any unrecoverable read error there costs the data in that region, and a missing or unreadable bitmap forces a full resync because nothing records which regions were in flight. Clone the members with ddrescue first. Valid bitmap values are internal, none, or a file path, not a bare file keyword.
Can I restart an mdadm --grow reshape that was interrupted by a drive failure?
Not safely. An interrupted reshape leaves the array straddling two geometries at reshape_position: new layout before it, old layout after it. Continuing needs the correct position and, for an in-place reshape, the --backup-file; without it mdadm aborts with Failed to restore critical section for reshape rather than finishing on wrong data. Recovery reads reshape_position from mdadm --examine and decodes the two geometry zones separately against clones.
Ship us your drives. We'll reassemble the array.
Linux mdadm software RAID recovery with offline read-only tools. No data, no recovery fee. Free diagnosis. Austin, TX lab.
