G-Technology Data Recovery
Since 2008 | No Data, No Fee | $100–$2,000 | Nationwide Mail-In
G-Technology drives (now sold as SanDisk Professional) contain HGST or Western Digital enterprise-class hard drives inside aluminum enclosures. Recovery targets the internal HGST Ultrastar or WD drive, not the Thunderbolt/USB bridge board. We extract the bare drive and image it through PC-3000 using the WD Marvell or HGST firmware module. No data recovered = no charge.
PC-3000 HGST/WD Module
Enterprise firmware access
No Data, No Charge
Free evaluation always
G-Technology = HGST/WD Inside
G-Technology was founded as a premium storage brand for creative professionals. HGST acquired G-Technology, and Western Digital acquired HGST (formerly Hitachi GST) in 2012, bringing G-Technology under the WD umbrella. Every G-Technology enclosure contains a standard HGST or WD mechanism. In 2021, the brand was renamed SanDisk Professional.
G-DRIVE
Single Ultrastar enterprise drive (Thunderbolt 3 or USB-C)
G-RAID
Two HGST/WD drives in hardware RAID 0 (default) or RAID 1
G-SPEED Shuttle
4 or 8-bay Thunderbolt RAID with a built-in hardware RAID controller
ArmorATD
Rugged portable with WD/HGST 2.5" mobile drive (USB 3.0/USB-C)
G-DRIVE SSD
NVMe rugged SSD; recovery follows SSD pricing
Updated September 2026
12 min read
G-Technology Recovery Cost
How Much Does G-Technology Recovery Cost?
G-Technology data recovery pricing is determined by the failure type of the HGST or WD drive inside, not the enclosure model. Air-filled internals use standard HDD pricing from $100–$2,000. Helium-sealed G-DRIVE, G-RAID, and G-SPEED mechanical cases use helium HDD pricing from $200–$5,000+. Thunderbolt bridge board failures where the internal drive is healthy are treated as simple copies. Free evaluation and a firm quote for every drive.
Critical Warning
If Your G-DRIVE or G-RAID Is Clicking
Power it off. Do not run Disk Utility, DiskWarrior, or any recovery software. G-Technology enclosures contain enterprise HGST/WD drives with high-density platters. Running software on a drive with failing heads forces repeated read attempts that carve through the magnetic coating. Once the coating is gone, the data is permanently destroyed. Send it for free evaluation instead.
What G-Technology Recovery Customers Say
Andrew Hansen
Kyle Hartley (crazybangles)
Christopolis
Patrick Dughi
G-Technology Recovery Pricing
Air-filled HGST/WD internals use standard HDD tiers. Helium-sealed Ultrastar internals in high-capacity G-DRIVE, G-RAID, and G-SPEED units use helium HDD tiers for mechanical work. Bridge board failures where the drive itself is healthy fall into the simple copy tier.
Air-filled G-Technology internal drive pricing
Helium-sealed G-Technology internal drive pricing
    From $600
    $3,000–$4,500
    $4,000–$5,000
Helium cost
Product Line Breakdown
Recovery by G-Technology Product Line
Each G-Technology product pairs a different HGST or WD drive family with a specific enclosure design. The failure pattern and recovery approach depend on the internal drive, not the aluminum housing or Thunderbolt interface.
G-DRIVE Desktop
Enterprise internals
Contains a single Ultrastar enterprise 3.5-inch drive built for sustained throughput in video editing workflows. Enterprise-class heads are more resilient than consumer drives, but they still fail from desk vibration and power surges. The most common G-DRIVE failure is a Thunderbolt bridge board fault; the internal drive is often intact. Recovery uses PC-3000 with the HGST module for firmware access. Newer models ship with WD Ultrastar DC HC series drives.
Interfaces: Thunderbolt 3, USB-C, USB 3.0 | Capacities: 4TB, 6TB, 10TB, 12TB, 14TB, 18TB
G-RAID
RAID 0 default
Two-bay Thunderbolt 3 enclosure containing dual HGST or WD enterprise drives. Ships configured as RAID 0 (striped) by default for maximum throughput. RAID 0 provides zero fault tolerance: one drive failure destroys the entire volume. Many video editors mistake RAID 0 for a backup; it is the opposite. Recovery requires imaging both member drives individually, then reconstructing the RAID stripe with the correct parameters. G-RAID hardware controllers use specific stripe sizes that differ from generic NAS defaults.
Interfaces: Thunderbolt 3, USB-C | Capacities: 8TB, 12TB, 24TB, 36TB
G-SPEED Shuttle
Complex recovery
4-bay or 8-bay Thunderbolt 3 RAID enclosure designed for multi-stream 4K/8K video editing. Uses a built-in hardware RAID controller with support for RAID 0, 1, 5, 6, and 10. The controller stores RAID metadata on the controller board and on each member disk. If the controller fails, the drives still hold data, but reconstruction requires matching the array parameters: stripe size, parity rotation direction, disk ordering, and reserved partition layout. We image all member drives via PC-3000 and reconstruct the array offline.
Controller: built-in hardware RAID | Capacities: 16TB, 24TB, 32TB, 48TB, 64TB, 72TB
ArmorATD / G-DRIVE Mobile
Rugged portable enclosure containing a 2.5-inch WD or HGST mechanism. The triple-layer shock-resistant housing (aluminum, rubber, internal bumper) protects against minor drops, but internal head failures still occur from vibration in transit or during use. Recovery workflow mirrors standard WD portable drive recovery: extract the bare drive, connect to SATA, and image via PC-3000 with the WD Marvell module. Head swaps require matching donor drives by model, head count, and firmware revision.
Interfaces: USB 3.0, USB-C | Capacities: 1TB, 2TB, 4TB, 5TB
Thunderbolt Bridge Board vs. Internal Drive
Thunderbolt Bridge Board vs. Drive Failure
Every G-Technology external drive has two components: the Thunderbolt/USB bridge board (converts SATA to Thunderbolt 3 or USB protocol) and the internal HGST or WD hard drive. The first diagnostic step is determining which component failed.
If the bridge board is dead but the internal drive is functional, we extract the HGST/WD drive, connect it directly to a SATA port, and perform a standard data copy. This is a simple copy tier recovery ($100). No clean bench work, no head swaps, no firmware repair.
If the internal drive has failed (clicking, beeping, not spinning, firmware corruption), the bridge board is irrelevant. We bypass it and connect the bare drive to PC-3000 via SATA for firmware-level diagnostics using the WD Marvell or HGST module.
G-DRIVE Thunderbolt models use Intel or Texas Instruments Thunderbolt controller chips on the bridge board. These controllers handle protocol translation and sometimes power delivery. The bridge board is separate from the drive and does not contain user data. A failed bridge does not mean the data is gone.
G-Technology Diagnostic Sequence
    Listen once, then stop. A drive that clicks, beeps, or grinds has a hardware fault and belongs on a bench; the sound does not name the part, and repeated listening costs data surface. A drive that spins normally and still will not mount points at firmware or the file system.
    Extract. Remove the HGST/WD drive from the G-Technology enclosure. Connect directly to SATA to bypass the Thunderbolt bridge.
    Test bare drive. If it works on SATA, the bridge was the problem. Simple copy. If it fails, proceed to PC-3000 diagnostics.
    PC-3000 module. Connect to PC-3000 with the appropriate module (HGST for older models, WD Marvell for newer). Read firmware state and determine recovery tier.
HGST Helium Drive Considerations
HGST Helium Drives in G-Technology Enclosures
Larger G-DRIVE models ship with helium-sealed HGST Ultrastar mechanisms. Helium-sealed drives use a lower-density gas instead of air to reduce aerodynamic drag on the platters, which allows thinner platters, closer head spacing, and higher capacity per drive.
Helium drives present specific recovery challenges. The hermetic seal must remain intact during recovery. If the seal is breached (through improper opening), air enters the drive housing, turbulence increases, and the heads crash into the platters within seconds. Head swaps on helium drives must be performed with the seal intact or in a controlled environment with minimal exposure time. Not all recovery labs stock helium-sealed HGST donor drives; we maintain helium drive donor inventory for Ultrastar He series models.
Helium seal failure can also cause data loss without any drop or impact. If the factory seal degrades over time, the helium leaks out and air enters. The drive may develop increasing read errors, slow performance, or complete failure. PC-3000 can detect helium pressure-related performance degradation through SMART attribute monitoring.
In-House Head Swap Procedure
In-house head swaps on G-Drive and G-RAID enclosures
A G-Technology head swap is mechanical work on the bare HGST or WD drive after extraction from the enclosure. Disassembly, donor matching, and reseal happen at the Austin lab on a 0.02 micron ULPA-filtered laminar-flow clean bench. We do not outsource head stack work. The same workflow applies to 2.5-inch G-DRIVE Mobile and ArmorATD internals and to 3.5-inch G-DRIVE desktop and G-RAID internals, with helium-specific steps added when the mechanism inside is helium-sealed.
Donor matching for WD-family heads
Heads inside G-Technology enclosures come from the HGST Ultrastar and WD Ultrastar product families. A donor that looks the same is not enough. Before any disassembly, we screen donor candidates against the attributes below so the donor head stack will read the patient platters, and which of them are decisive depends on the exact drive:
  1. Model family. Exact match on the HGST or WD model family (HUH721212ALN, HUH728080ALE, WUH721818ALE, and similar) including the platter generation suffix.
  2. Firmware revision. Donor firmware band must be compatible with the patient firmware band so SA tracks line up. Off-band firmware causes translator mismatch.
  3. Head map. Same head count and same physical head map. A patient drive with a disabled head must match a donor with the same active-head topology.
  4. Preamp ID. Preamp chip identifier and revision recorded in the SA. A swapped head stack with the wrong preamp will not negotiate read channel parameters.
  5. ROM adaptive zone count. Donor ROM adaptive zone count must match. WD-family drives store per-head adaptive parameters; mismatched zone counts make the translator reject the swapped stack.
  6. Manufacture date window. Donor manufacture date should fall inside a narrow window around the patient. Platter coatings and head fly height tolerances drift across production runs.
Donor inventory is indexed by those attributes. When a G-DRIVE arrives, the patient PCB is read with PC-3000 to extract the model, firmware, preamp ID, and ROM adaptive zone count before any donor candidate is opened. The procedure is documented further on our donor drive matching reference page.
Atmospheric purge and helium refill on helium-sealed G-Drive mechanisms
Breaking the seal on a helium-sealed Ultrastar mechanism inside a G-DRIVE or G-RAID enclosure vents the helium, so the gas has to go back before the platters turn again. The disassembly itself happens under our 0.02 micron ULPA-filtered clean bench in filtered ambient air, with the drive unpowered and nothing spinning, because the risk at that stage is particulate contamination rather than aerodynamics.
After the new head stack is installed, the lid gasket is replaced with a fresh seal and the chassis is closed. The chamber is then purged and refilled with high-purity helium through a calibrated manifold, and the drive is leak-checked at the seam before any spin-up. Helium refill on these units adds material and bench time to the recovery; that cost is published in our helium hard drive recovery pricing.
PC-3000 Portable III initialization and translator validation
A swapped head stack is not the end of the recovery. The drive comes out of the clean bench and onto PC-3000 Portable III for firmware initialization. We power the drive in safe mode, read the SA module to confirm donor preamp parameters were accepted, then walk the translator: rebuild or verify the LBA-to-CHS map, recheck adaptive zone tables against the ROM, and validate that each head in the new stack reads its assigned surface. Only after the translator is clean does imaging begin through the DeepSpar Disk Imager with retry counts tuned for the remaining weak heads.
This procedure is the same workflow we apply across all hard drive data recovery cases with mechanical damage. The G-Technology enclosure simply adds the bridge-board extraction step before the bare drive enters the head swap pipeline.
G-SPEED Shuttle RAID Deep Dive
G-SPEED Shuttle RAID Recovery
The G-SPEED Shuttle is G-Technology's flagship product for video production houses. A single Shuttle can contain 48TB-72TB of active project footage in RAID 5 or RAID 6. When the hardware RAID controller fails, the entire volume goes offline.
The controller stores RAID metadata on its own flash and on a reserved area of each member disk. If the controller board fails but the drives are intact, we reconstruct the array from the on-disk metadata. If that metadata is damaged in both places, we derive the parameters from the member images themselves: stripe size, parity rotation, and member disk ordering.
Recovery process: extract all 4 or 8 member drives from the Shuttle enclosure, image each drive individually through PC-3000, verify the health and integrity of each member image, then reconstruct the RAID array offline. If one or two member drives have also failed (common in aging Shuttle arrays where all drives are the same age and batch), those drives go through individual recovery first before the array is assembled.
Do not attempt a RAID rebuild on a degraded G-SPEED Shuttle. If the enclosure reports a degraded array, do not insert a replacement drive and rebuild. A rebuild forces a full read of all surviving drives. If a second drive fails during the rebuild (likely when all drives are from the same batch and age), the entire array is destroyed. Power off the Shuttle and send it for professional RAID recovery.
SanDisk Professional Rebrand
G-Technology to SanDisk Professional
In 2021, Western Digital rebranded G-Technology as SanDisk Professional. Products previously sold as G-DRIVE, G-RAID, and G-SPEED Shuttle are now marketed under the SanDisk Professional name with the same product line designations.
Recovery procedures do not change based on whether the label says "G-Technology" or "SanDisk Professional." The internal drives remain HGST or WD Ultrastar enterprise mechanisms. PC-3000 firmware access uses the same modules regardless of the external branding. If you have a SanDisk Professional G-DRIVE, G-RAID, or G-SPEED Shuttle, the recovery workflow described on this page applies to your drive.
Encryption Handling
Encryption on G-Technology Drives
Tell us at intake whether the volume was ever locked with a password. With the password in hand, the recovered volume unlocks after imaging. Without it, the contents stay encrypted no matter which lab holds the drive. No lab can bypass that, and one that says otherwise is describing something else.
Data Security
Data Security During G-Technology Recovery
Your G-Technology drive stays in our Austin lab from intake through return. Every drive is logged, serialized, and tracked. Recovery work happens on isolated, air-gapped systems; your data is never exposed to a network. We deliver recovered files on encrypted external media and securely purge all working copies using secure multi-pass cryptographic erasure.
G-Technology drives are popular with video production houses, post-production facilities, and photographers working on commercial projects. We handle sensitive creative work regularly. NDAs are available on request.
Shipping
Shipping
Shipping
Mail-in
G-Technology Recovery Questions
How much does G-Technology data recovery cost?
G-Technology data recovery pricing depends on the failure type of the internal drive, not the enclosure model. Bridge board or Thunderbolt controller failures where the internal HGST/WD drive is healthy cost $100 after extraction. Air-filled firmware and head work use standard HDD pricing from $100–$2,000. Helium-sealed G-DRIVE and G-RAID mechanical cases use helium HDD pricing from $200–$5,000+. Free evaluation for all drives; no data recovered, no charge.
Are G-Technology drives the same as HGST or WD drives?
Yes. G-Technology enclosures contain standard HGST or Western Digital hard drives. G-DRIVE desktop models contain an Ultrastar enterprise-class 3.5-inch mechanism. G-DRIVE Mobile models contain a 2.5-inch WD or HGST mechanism. G-RAID units contain dual HGST drives in RAID configuration. After the WD-HGST merger, newer production runs ship with WD Ultrastar drives under the same model numbering. We extract the bare drive and image it via PC-3000 using the WD Marvell or HGST module.
Can you recover a G-RAID that shows as offline?
Yes. G-RAID enclosures run two HGST or WD drives in RAID 0 (default) or RAID 1. RAID 0 arrays lose all data when one drive fails because data is striped without redundancy. We extract both drives, image each individually through PC-3000, then reconstruct the RAID stripe offline. G-RAID hardware controllers use specific stripe sizes and parity layouts that must be identified before reconstruction. Recovery for a two-drive RAID 0 with one failed drive typically falls into the $1,200–$1,500 tier if the failed drive needs head work.
My G-SPEED Shuttle stopped responding. Is the data recoverable?
When a G-SPEED Shuttle stops presenting its volume, the drives themselves are often intact and the enclosure's hardware RAID controller is the failure point. The Shuttle contains 4 or 8 enterprise HGST/WD drives in RAID 5 or RAID 6. If the controller fails, the drives still hold valid data. We extract all member drives, image each via PC-3000, and reconstruct the array from the parameters recovered off the members: stripe size, parity rotation, disk order. If individual drives have also failed, we recover those drives first before array reconstruction.
Does G-Technology still exist?
G-Technology was rebranded to SanDisk Professional in 2021 under the Western Digital umbrella. The product lines continued under the new name. Products formerly sold as G-DRIVE, G-RAID, and G-SPEED Shuttle are now marketed as SanDisk Professional G-DRIVE, G-RAID, and G-SPEED Shuttle. Recovery procedures are the same regardless of which label is on the enclosure.
My G-DRIVE is clicking after it fell off the desk. What should I do?
The HGST Ultrastar drive inside the G-DRIVE enclosure has been dropped and the read/write heads are damaged. Each time you power it on, the heads scrape against the platter surface and destroy more data. Do not attempt to run any recovery software. Ship the complete enclosure to our lab for evaluation. We open the drive in a 0.02 micron ULPA-filtered clean bench, replace the heads with a matched HGST donor, and image the platters using PC-3000.
Do you recover helium-filled G-Drives?
Yes. When the mechanism inside a G-DRIVE or G-RAID enclosure is a helium-sealed drive, we open it under our 0.02 micron ULPA-filtered clean bench, replace the head stack with a donor matched on parameters including preamp ID and ROM adaptive zone count, then reseal the chassis and purge and refill it with high-purity helium through a calibrated manifold before the platters are ever spun. Helium refill pricing is published on our helium hard drive recovery page; tiers run from $200–$5,000+.
How long does a G-RAID head swap take?
A single G-RAID head swap typically runs three to seven business days from intake to recovered data. The clean bench head transplant itself takes a few hours, but most of the time is spent before and after the mechanical step: donor inventory screening against the six matching criteria, PC-3000 Portable III initialization and translator validation, and DeepSpar Disk Imager imaging tuned for the weak head pattern. G-RAID adds time because both member drives are evaluated and the array is reconstructed offline after imaging.
Do you need the donor enclosure or just the bare drive?
Bare donor drive only. The Thunderbolt or USB bridge board on the donor G-Technology enclosure has no role in the head transplant; the donor head stack and PCB are what we use. We screen donors out of HGST and WD Ultrastar inventory by model family, firmware revision, head map, preamp ID, ROM adaptive zone count, and manufacture date window. Customers do not need to source a matching donor; that inventory is maintained at the Austin lab.
Can you recover encrypted G-Technology drives?
If the volume was locked with a password you still have, tell us at intake and we work the case with it. Without the password the contents stay encrypted after imaging, and no lab bypasses that. Say at intake whether encryption or a password was ever enabled, so the case is scoped before the drive is opened.
Need G-Technology Data Recovery?
Free evaluation for all G-Technology and SanDisk Professional models. We identify the internal HGST/WD drive and failure pattern before quoting. No data, no charge.
