iPhone NAND Recovery
iPhone Stuck in DFU: NAND & Storage Recovery
DFU mode means the CPU is alive but cannot find an operating system to load. In most of these phones the NAND storage chip still holds your photos, messages, and apps. The phone just can't talk to that chip anymore. We fix the communication path at the board level so the phone boots and your data becomes accessible again.
What DFU Mode Means for Your Data
DFU stands for Device Firmware Upgrade. When an iPhone enters DFU mode, the CPU powers on, but it can't find a valid operating system on the NAND storage chip. The phone drops into DFU automatically as a fallback state. iTunes or Finder detects the device, but the screen stays black.
On most DFU phones, the NAND chip itself is fine. All photos, messages, contacts, and app data remain on the chip. The phone simply cannot read the data because something broke the communication path between the CPU and the storage.
DFU mode isn't the same thing as a dead phone that will not turn on, or a boot loop, where the phone finds the OS but crashes during startup. Each presentation points to a different failure and a different repair path.
PP3V0_NAND Power Rail Diagnostics
PP3V0_NAND is a NAND power rail on the iPhone 6 and iPhone 8. Without this rail, the NAND has no power and the CPU cannot read or write to storage.
On iPhone 8, a shorted PP3V0_NAND causes the PMIC (power management IC) to heat up. The phone draws too much current and won't boot at all.
Additional NAND Power Rails
On the iPhone 11, the NAND rails include PP2V63_NAND, PP1V8_NAND, and PP0V9_NAND. We test each one separately in diode mode.
Update vs. Restore: The Critical Distinction
Never restore a DFU phone that has important data. A restore erases all user data: photos, messages, contacts, app data, everything. This action is irreversible. If someone at a repair shop tells you to restore, and your data matters, stop and get a second opinion.
When the phone is in Recovery mode, iTunes and Finder give you two options: Update and Restore. In DFU mode, the only thing iTunes or Finder can do is restore it. Those two options aren't the same thing, and the difference is whether you keep your data.
- Update reinstalls the iOS operating system while preserving all user data. Photos, messages, contacts, and apps remain on the device.
- Restore wipes the device completely, then installs a fresh copy of iOS.
If the phone is in Recovery mode and you care about the data, try Update first. If it's in DFU mode, 3uTools has a flashing mode it calls "Retain User's Data While Flashing". 3u's own documentation says that mode starts from DFU mode and updates iOS without losing user data.
If the update fails, the error code returned by iTunes is diagnostic information. Write down the error code before doing anything else.
If the update succeeds, the phone boots with all data present. If it fails, we diagnose from there. Either way, the data remains on the NAND because an update never erases it.
iTunes Error Codes During an Update or Restore
Error 9 / Error 35
These errors indicate the device disconnected during the restore or update process.
See our Error 4013 page if that's the code you got.
Other restore-error families have their own root causes; see Error 1110 and Error 14 for those specific failures.
NAND Programming and Compatibility
If the original NAND chip is dead, the replacement NAND has to be programmed with the phone's serial number, WiFi MAC address, and Bluetooth MAC address, or the phone won't activate. Without this programming step, iOS refuses to complete setup.
Tooling
NAND programming requires a compatible programmer for the specific iPhone model.
Donor Compatibility
Donor NAND compatibility depends on the NAND type and generation. Some iPhone models share the same BGA NAND package and can serve as donors for each other after reprogramming with the correct serial number and MAC addresses. Compatibility must be verified for each specific model pairing before attempting a swap.
We Don't Do CPU Swaps
The encryption pairing lives in the silicon, not in the fiberglass. The NAND is cryptographically married to the CPU that carries the Secure Enclave and to the board's secure-storage chip, a logic EEPROM on older models and a Secure Storage Component on newer ones. The board underneath is a carrier for those chips. That's why a NAND moved by itself onto another board can't be decrypted there.
When the original board can't be repaired, the trade's answer is a CPU Swap: the CPU, the NAND, and that secure-storage chip move together onto a donor board of the same model. We don't do CPU swaps, so a board that would need one isn't a job we take. What we do is reball the original NAND back onto the repaired original board.
NAND replacement does not recover existing data. The NAND is encrypted with keys held by the Secure Enclave on the original CPU. A new NAND chip starts empty. NAND replacement restores phone function for cases where the user has an iCloud backup. To get data off the original NAND, we repair the original board.
Why Chip-Off Recovery Does Not Work on iPhones
“Chip-off” recovery means pulling the NAND flash chip off the board and reading it with a standalone programmer. This technique works on older Android phones and USB flash drives where the storage is not encrypted or uses a known encryption key. It does not work on any iPhone with an A7 processor or newer (iPhone 5s and all later models).
Every iPhone since the 5s has a Secure Enclave coprocessor built into the main CPU die. The Secure Enclave generates and stores the hardware encryption keys that protect the NAND. These keys are unique to each individual CPU and are not extractable. The NAND data is encrypted in hardware with AES in XTS mode, AES-128-XTS on the A9 through A13 generations and AES-256-XTS on A14 and later, and the decryption key never leaves the Secure Enclave boundary.
If you desolder the NAND chip and read it on a programmer, you get encrypted data. Without the matching Secure Enclave (which lives on the original CPU), that data cannot be decrypted. There is no known method to extract Secure Enclave keys. Moving the NAND to a different logic board produces the same result: the new board has a different Secure Enclave with different keys, so the encrypted data is unreadable.
The same Secure Enclave constraint governs iPad and Apple Silicon Mac storage, which is why iPad data recovery and Apple Silicon Mac recovery follow the same rule: the original SoC must run the decryption, and there is no chip-off shortcut.
On an A7 or later iPhone, the path to the data is repairing the original logic board. The original CPU must be alive and able to boot far enough to process the Secure Enclave decryption. That's why you can't do iPhone data recovery without board-level microsoldering.
Our Diagnostic Process
- Identify the presentation. DFU mode, Recovery mode, specific iTunes error code, or no power at all. Each starting point narrows the possible failures. A phone that will not turn on at all has different root causes than one sitting in DFU.
- Check NAND power rails. Diode mode readings on PP3V0_NAND, PP0V9_NAND, and PP1V8_NAND (model-dependent). A shorted rail gets traced and repaired before proceeding.
- Attempt an update, never a restore. If power rails are good, we connect to iTunes or 3uTools and attempt an iOS update. The result tells us whether NAND communication is restored or what remains broken.
Contact us or ship your device for a free evaluation.
Watch: iPhone Data Recovery from Dead Logic Board
Louis Rossmann walks through board-level diagnosis and repair of a dead iPhone, including DC power supply analysis and component-level fault isolation for data recovery.
More board-level walkthroughs: the full dead logic board recovery walkthrough and an iPhone 6s diode-mode diagnostics teardown.
Can you recover data from a phone stuck in DFU?
iTunes says 'Update' but I'm afraid it will erase my data
What does Error 4014 mean?
Someone already tried to restore my phone. Is the data gone?
How much does NAND recovery cost?
Can you just move my NAND to another phone?
My iPhone board snapped in half. Is the data gone?
Related iPhone Recovery Services
Hub page for all iPhone recovery services
Dead phone that will not turn on
Phone powers on but restarts repeatedly
Error 4013 during an update or restore
Corrosion cleanup and board repair
Recover recordings from a failed iPhone
View complete service catalog
iPhone stuck in DFU mode?
The storage chip usually still has your data. Free evaluation, no data no fee.
