Dead iPhone Recovery
iPhone Won't Turn On: Data Recovery
A dead iPhone almost never means dead data. The NAND storage chip that holds your photos, messages, and contacts is one of the most durable components on the board. What fails is the power delivery circuit: a single shorted capacitor, a worn-out charging IC, or a cracked coil. We diagnose the failure with a DC power supply, fix the broken component with microsoldering, boot the phone, and copy your data.
A phone that shut off on its own, and one that keeps turning on and off, usually point to the same place: the board lost the ability to hold its power rails, not the ability to hold your files.
This is board-level microsoldering on your original logic board, done under a stereo microscope. In data recovery, a cleanroom does one job: keeping dust off the bare platters inside an opened hard drive. A phone logic board has no platters and no exposed magnetic media. What the work needs instead is a current-limited DC power supply, diode-mode measurements, and a soldering iron fine enough to replace one capacitor on a power rail.
15 min read
Why Most Dead iPhones Still Have Your Data
Why Most “Dead” iPhones Still Have Your Data
How Do You Force Restart an iPhone That Will Not Turn On?
Run a force restart before you assume the board is at fault. Apple gives it as the step for an iPhone that isn't responding and can't be turned off then on. The buttons depend on the model:
  • iPhone with Face ID. Press and quickly release volume up, press and quickly release volume down, then press and hold the side button until the Apple logo appears. Apple says that can take longer than 10 seconds.
  • iPhone 7 or iPhone 7 Plus. Hold the side button and the volume down button together until the Apple logo appears.
  • iPhone 6s and earlier. Hold the Home button and the side or top button together until you see the Apple logo.
On a Face ID model the two volume buttons are pressed and released one at a time, in that order. A force restart erases nothing. It cuts power and boots iOS again.
Have your passcode ready. After any restart iOS wants the passcode typed in by the owner before Face ID or Touch ID will unlock the phone again.
A phone that comes back with the Apple logo had a software hang or a display that stopped drawing. If it keeps running normally afterward, it needs no lab work. A screen that stays black through the whole sequence is the hardware fault the rest of this page covers. A phone that shows the logo and then dies again belongs on the boot loop page instead.
Every iPhone stores data on a NAND flash chip soldered to the logic board. This chip is a passive storage device. It does not need power to retain data, and it does not participate in the power delivery circuits that fail when a phone dies. The NAND sits on its own power rail and communicates with the CPU over a separate data bus. When a capacitor shorts on VDD_MAIN, the NAND is electrically uninvolved.
The components that fail are the ones that handle power: decoupling capacitors on the main voltage rail, the Tristar and Tigris charging ICs, boost converter circuits, and occasionally the coils that deliver power from the PMIC to the CPU. A single capacitor worth fractions of a cent can make an iPhone appear completely dead. Remove that one capacitor with a soldering iron and the phone boots normally.
This is why board-level repair exists for data recovery. We do not replace the motherboard (which would erase your data, since the NAND and CPU are cryptographically paired). We find the specific failed component, remove or replace it, and restore the power path so the original board boots with your original data intact.
Why board-level repair needs no cleanroom
The NAND that holds your photos is soldered to the board through a BGA pad array. There is no drive to remove and no recording surface to expose to the air, which is why this job has no cleanroom step. Hard drive work is the opposite case: the housing comes open, bare platters sit exposed, and that is what a filtered clean bench protects.
That NAND is also cryptographically paired to the Secure Enclave inside your original SoC, so lifting it onto some other board returns ciphertext rather than files. It decrypts next to the processor it shipped with, and only once you have entered your passcode.
So the repair stays on the board you sent us. We locate the failed power-delivery component or the failed Tristar or Hydra and replace it with a Hakko FM-2032 under a stereo microscope. Where a part has to come off, we use Atten 862 hot air. Then we bring the board back to a boot. You enter your own passcode, the phone decrypts its own data in place, and the files copy off over USB.
Why It Shut Off or Keeps Cycling
Why Did My iPhone Suddenly Turn Off, or Keep Turning On and Off?
A phone that dies mid-use and will not come back, and a phone that keeps cycling on and off, usually fail in the same place: the power path. Four causes account for most of them. An aging battery that sags under load, a shorted capacitor on a main rail, a worn charging IC, or a broken power feed between the PMIC and the CPU. Of those four, only the battery is not a board fault.
The battery hit its limit (not a board fault)
Lithium-ion cells gain internal impedance as they chemically age, and more of it at low charge or in cold weather. When the CPU and the radios draw peak power, that impedance makes the cell voltage sag, and the power management system shuts the phone down deliberately rather than let the rails brown out mid-write. This is protection working, not damage. It is why a phone can switch off with charge still showing on the gauge, and why the shutdowns come closer together as the cell ages. A known good battery on the bench is the first check here, and nothing on the board gets touched.
A decoupling capacitor shorted on VDD_MAIN
Decoupling capacitors sit across the main rails filtering noise. When one fails short-circuit it ties the rail straight to ground, and the phone goes dark mid-use with no drop and no liquid involved. This is one common cause behind a phone that flickers or restarts for a few days and then stops responding entirely. The rail comes back when the shorted capacitor comes off the board.
A worn IC on the port: Tigris, or Tristar/Hydra
Tristar, replaced by Hydra on iPhone 8 and newer, handles USB negotiation and data switching on the port. Tigris regulates charge current. They degrade over years of daily charge cycles, faster with cheap third-party cables. The pattern is a phone that charges to a number that never moves, runs itself flat, and then never comes back, even though the port is clean and the battery is good. Replacing the IC restores the charge path.
A broken power feed between the PMIC and the CPU
The CPU gets its power through small inductors locked down with underfill. The phone dies, or it powers on and back off depending on how the board is flexed at that moment. Intermittent behavior tied to squeezing or setting the phone down points here rather than at the battery.
None of these four faults involve your storage. The NAND sits on its own rail and takes no part in a short on VDD_MAIN, so the photos and messages written before the phone quit are still on the chip. Recovery is repairing the original board until it boots again, then letting the phone decrypt its own data in place once you enter your passcode.
Will Your Data Survive: Outcome by Failure Mode
Will Your Data Survive? Outcome by Failure Mode
Data on a dead iPhone is almost always intact, because the failure sits in the power path, not in storage. Recovery means repairing the original logic board back to a bootable state so it decrypts its own data in place once you enter your passcode. Software tools cannot read a single file from a board that will not boot; no app reaches a phone that has no power.
The repair question and the data question are separate. A shop can tell you the board is hard to fix; that is not the same as your photos being gone. The table below maps each failure we see to its data outcome, independent of how involved the board repair is.
Failure ModeData Outcome
Battery or charging-path faultData fully intact. The fault is in power delivery; the NAND is never touched.
Board-level rail short, including corrosionData intact once the short is cleared and the original board boots.
NAND solder-joint separationData intact. The factory-paired NAND is reballed onto its original board.
NAND die cracked or delaminatedData lost. The storage silicon that holds the ciphertext is destroyed.
Secure Enclave or SoC destroyed by board damageData lost permanently. The keys are fused into that processor and die with it.
Why pulling the memory chip does not work
A common assumption is that a dead phone just needs its memory chip desoldered and read on a programmer. On every iPhone from the 5s forward (A7 and later), that returns nothing usable. The NAND holds only ciphertext: hardware AES Data Protection is tied to the Secure Enclave and to a hardware UID fused into the SoC, so a raw dump off a programmer has no filesystem structure and cannot be decrypted without the original paired SoC.
There is no blank or foreign chip swap, no logical donor read, and no shortcut that reads your storage on some other device. The lone exception is pre-A7 iPhones, which predate the Secure Enclave; on those older models this encryption barrier does not apply.
The same Secure Enclave constraint governs iPad data recovery and Apple Silicon Mac recovery: the original SoC must run the decryption, and there is no chip-off shortcut.
Liquid corrosion is a repair, not a verdict
When the rail short comes from liquid corrosion, microsoldering clears the short so the original board powers up and decrypts in place. Do not power on or charge a liquid-damaged phone; corrosion spreads by the hour, and current pushed through a wet board can turn a survivable short into severed traces.
Decryption happens only when the three originals come together: the paired NAND, the original SoC that carries the Secure Enclave, and your passcode entered on the repaired phone. We never work around the passcode or the Secure Enclave; we repair the hardware so you unlock your own device.
A phone that shows the Apple logo and then goes dark is not fully dead. That is a boot loop, a different diagnostic path from a board that draws no current at all.
When the data is gone for good
Two outcomes forfeit the data permanently: a cracked or delaminated NAND die, and a Secure Enclave or SoC destroyed by the same impact or short that killed the board. Once the processor that holds the keys is gone, no repair and no software brings the data back.
The Five Patterns of a Dead iPhone
When we connect a dead iPhone's logic board to a DC power supply (DCPS) at battery voltage and prompt it to boot, the current draw pattern tells us which circuit has failed. Most dead iPhones fall into one of five categories.
DCPS ReadingPatternLikely Cause
2A+ before boot promptImmediate current limitVDD_MAIN short (shorted capacitor)
0.15-0.25A first boot numberLow first boot, no progressTristar/Tigris charging IC failure
0 → 320mA → 0 → 1.4A cyclingOscillating, PMIC restart loopNAND power rail short
20-40mA steadyLow draw, no boot activityCPU communication failure (broken coils/solder balls)
2mA with brief 30mA peakNear-zero drawUSB prompt needed, possible Tristar or PMIC issue
The 2A+ reading before any boot prompt is the single most common pattern. It means a capacitor on VDD_MAIN has failed short-circuit, creating a direct path from the power rail to ground. The DCPS hits its current limit the instant you connect battery voltage. No amount of charging, battery replacement, or screen replacement will fix this. The short must be located and removed from the board.
The oscillating pattern (0 → 320mA → 0 → 1.4A) is distinctive. The PMIC detects the short on the NAND power rail, shuts down to protect itself, then retries. The current spikes each time the PMIC attempts to bring up the NAND rail, then drops to zero when it shuts down again. The PMIC heats up during this cycle, but the PMIC itself is not the problem. The short is on a capacitor downstream of the PMIC on the NAND rail.
VDD_MAIN Shorts: The Most Common Fix
VDD_MAIN is the primary power rail on the iPhone logic board. It feeds every major subsystem. Dozens of decoupling capacitors sit on this rail, each one filtering noise for a different circuit. When one of these capacitors fails short-circuit, it creates a dead short between VDD_MAIN and ground. The entire rail collapses. The phone draws 2A+ on the DCPS without being prompted to boot, and will not respond to any button combination.
Once the short is confirmed, we inject current-limited voltage directly into the shorted rail using bench power clips and apply freeze spray across the board.
The shorted capacitor heats up because all the injected current flows through it to ground. Freeze spray evaporates on contact with the hot component, making it visible. A thermal camera accomplishes the same thing without the spray.
The fix is removal. The phone functions normally without the capacitor. These are decoupling caps; they filter high-frequency noise, but the circuit runs fine without any single one of them. Reinstalling a replacement cap adds unnecessary heat exposure to the board for no functional benefit.
Common Short Locations by Model
iPhone 7
Under BBPMU_RF: C5625_RF, C5622_RF. Back top arm: C2611, C2612. Backlight circuit: C3725, C3705. Near WiFi module: C7610_RF. Front top above CPU: C3327, C3328.
iPhone 8
Under BBPMU: C303_E. Back top arm: C4190, C4191. Near WiFi: C7608_W, C7609_W. Front top above CPU: C3790. Also check TP0526 for a loose screw shorting the pad to ground; this is a common misdiagnosis that looks like a board-level short but is mechanical.
iPhone XR
Caps on the VDD_MAIN_YANGTZE sub-rail, or speaker amp U5002 and caps on PP_SPKAMP_TOP_VBOOST, can short VDD_MAIN. A failed Yangtze IC (U3300) usually presents as no power or no charging without a short to ground on VDD_MAIN, so rule out a shorted capacitor before removing the IC.
iPhone 11 and newer
U_NFC chip cracks internally from drop impact, shorting VDD_MAIN. Rigel (U4400) can fail but is less common. On sandwich-board models (11 and up), the short may be on either the top or bottom layer. Split the sandwich and test each layer on the DCPS separately to isolate which board carries the short.
Tristar and Tigris: Charging IC Failure
Tristar and Tigris are the two ICs that manage how power enters the iPhone from the Lightning or USB-C port. Tristar handles USB negotiation and data switching. Tigris manages charge current regulation. When either fails, the phone cannot charge, cannot communicate over USB, and in many cases will not boot at all. These ICs degrade from years of daily charge cycles and fail faster with cheap third-party cables that send incorrect USB signals.
On the DCPS, a Tristar/Tigris failure shows a first boot number of 0.150-0.250A, which is lower than the normal 0.4-0.8A range for a healthy boot sequence. The phone draws some current but cannot progress through the boot. With a charger connected, the battery connector shows 0.300-0.600V instead of the normal 3.7V, confirming that the charging circuit is not delivering power to the battery.
Tristar testers exist, but they are unreliable. We have seen phones where the Tristar tester passed at every stage of diagnosis, yet replacing Tristar fixed the phone. The tester checks a limited set of functions and misses partial failures. We diagnose based on DCPS behavior and charger-connected voltage measurements instead.
Model-specific repair order matters. On iPhone 7: replace Tigris first, then Tristar if symptoms persist. On iPhone 8 Plus: the Hydra IC can damage a newly installed Tigris. Both Hydra and Tigris must be replaced together, or the new Tigris will fail within hours. Skipping this step wastes a $15-$30 IC and the labor to install it.
Symptoms that point to Tristar/Tigris: the phone shows 0 amps on the DCPS when a charger is connected (no current entering the phone at all). The phone displays a charging icon but the battery percentage never increases (fake charging). The phone died overnight while connected to a charger. These symptoms overlap with water damage because water corrodes the charging ICs first when a wet phone is plugged in.
CPU Communication Failure
The “brain dead phone” draws 20-40mA on the DCPS after a boot prompt and then does nothing. No screen activity, no Apple logo, no vibration. The power rails are not shorted. The PMIC is delivering voltage. But the CPU cannot execute its boot sequence because it has lost physical connectivity to the rest of the board.
One cause is a broken coil above the CPU. These coils deliver power from the PMIC to the CPU through tiny inductor packages surrounded by underfill (a rigid epoxy that Apple uses to reinforce solder joints).
The CPU loses its power input and sits at a low idle draw. Finding these broken coils requires clearing the underfill with heat and solvent to expose the solder joints underneath.
Another is the CPU itself. A dropped or flexed board can fracture the BGA solder spheres under the CPU package, and the CPU then loses connectivity to the board it is sitting on even though every rail around it is healthy.
Reballing the CPU is a difficult, high-risk repair. The Secure Enclave lives inside the CPU die, so a successful reball preserves it, but any damage to the die during rework destroys the encryption keys and makes the data permanently inaccessible.
A note on PMIC diagnosis: On iPhone 8, the PMIC heats up during a brain-dead boot attempt because it is in the current path. This leads many shops to replace the PMIC. But the PMIC is delivering power correctly; the CPU is failing to use it. Replacing the PMIC wastes time and risks damaging the board without fixing the underlying problem.
Physically Broken and Crushed Logic Boards
Impact damage is its own category. A corner drop onto concrete, a car tire, a hard sit on a back pocket: none of those fail one component the way an aging capacitor does. They break the board itself.
What we find under the microscope is cracked or severed copper traces, BGA pads torn off the laminate, delaminated inner layers where the fiberglass plies have separated, and on sandwich-board models, an interconnect between the two stacked PCBs that has split or lost connections.
This changes the shape of the repair. A shorted rail has one guilty component: diode mode narrows it to a rail, a FLIR thermal camera points at the part, hot air lifts it off, and the board comes back.
Physical damage offers nothing to lift off. We rebuild the broken connections one at a time under a stereo microscope.
We Don't Do CPU Swaps
Your storage is not paired to the fiberglass. It is paired to specific chips on it. A CPU swap lifts the factory-paired set off a broken board and reballs it onto a donor logic board of the same model. The set is the SoC that carries the Secure Enclave, the NAND that SoC was paired with at the factory, and the secure-storage chip that completes the key chain. We don't do that work, so a phone that would need it isn't a job we take.
There is no version of this where the memory chip moves alone. A NAND landed on someone else's board sits next to a processor it was never paired to, and the ciphertext on it stays ciphertext. The same pairing rule is why NAND-side faults get solved by reballing the original chip back onto its own board rather than by substituting a healthy one.
Damage to the SoC die is the end of the road. The keys are fused into that silicon, and they are not stored anywhere else.
If the impact cracked the die, or if the die cracks during rework, the data is gone permanently and no repair and no software recovers it.
We do not crack, defeat, or work around the Secure Enclave, your passcode, or Activation Lock, and those last two are separate things. The passcode is the encryption gate.
Activation Lock is an iCloud ownership lock that has nothing to do with whether your files can be decrypted. Our job ends at hardware: we put the board back into a state where you can unlock your own device.
A replacement board is the opposite of recovery
A shop looking at a snapped board can order a working logic board for that model and hand back a functioning phone quickly. That phone boots to the setup screen. No photos, no messages, no notes, because everything that identified those files as yours stayed behind on the broken board.
What impact damage does to the data outcome
The failure-mode table earlier on this page maps electrical faults to data outcomes. Physical damage sorts a little differently, because the question is which layer of the board took the hit.
Severed traces and cracked solder joints
Repairable, and the data is untouched. Copper is rebuilt with jumper wire under the microscope, fractured joints are reflowed or reballed, and the original board goes back to booting. Nothing leaves the board, so nothing about the key chain changes.
Torn pads underneath the SoC or NAND
We don't rebuild a ripped pad. We find the via it connected to, solder a microscopic jumper wire to that via, and hold the jumper in place with green conformal coat.
A split sandwich board
Recoverable in principle. The two boards are separated deliberately, each layer is tested on its own against a current-limited DC supply, and the interconnect is rebuilt. It is slow work, and the data outcome depends on whether the dies came through it, not on how ugly the interconnect looks.
A cracked die on the SoC or the NAND
Not recoverable. A cracked NAND die takes the ciphertext with it. A cracked SoC die takes the keys. Either one ends the job.
Impact and liquid arrive together more often than people expect, because a cracked housing lets water reach the board weeks later. If your phone was both dropped and wet, read the corrosion repair page as well, and get the phone moving sooner rather than later.
Every one of these repairs happens at our Austin, TX lab. Nothing gets shipped to a third party, evaluation is free, and our iPhone recovery terms are the same for a crushed phone as for a dead one: No data, no fee. Free evaluation. No diagnostic charges.
Model-Specific Differences
Each iPhone generation has different board layouts, different failure-prone components, and different repair approaches. A technician who knows only one model's failure patterns will misdiagnose another. Here are the most common non-power causes of death by model.
ModelSignature FailureRepair Approach
iPhone 7Broken power coils above the CPUClear underfill, reflow or replace coils
iPhone 8 / 8 PlusCPU solder ball fractureDifficult and high-risk. We reball the CPU, preserving the Secure Enclave in the die
iPhone XRYangtze IC (U3300) internal crack; speaker amp U5002 shortRemove or replace Yangtze; remove speaker amp if on VBOOST rail
iPhone 11+Sandwich board separation; U_NFC internal crackSplit sandwich, test layers independently on DCPS
iPhone 11 Pro, 12, and newer models use a sandwich board design. Drops and pocket flexion can separate the layers, breaking connections between the top board (where the CPU lives) and the bottom board (where NAND and other components sit). Diagnosing a sandwich board failure requires splitting the two layers apart and testing each one independently on the DCPS. This adds time to the repair but is necessary to isolate which layer carries the fault.
Our Diagnostic Process
Every dead iPhone follows the same diagnostic sequence. The order matters: each step eliminates categories of failure before we commit to a repair path.
  1. Visual inspection under microscope: Before applying any power, we remove the shields and inspect both sides of the board at 10-40x magnification. We look for cracked ICs, corroded pads, burn marks, displaced components, and signs of previous repair attempts. On sandwich board models, we check the interposer area for separation. The visual inspection alone identifies the cause in a meaningful number of cases.
  2. Known good parts test: We connect a known good battery, screen, and charge port to rule out accessory failures. A dead battery, a broken screen, or a damaged Lightning flex can all make a phone appear dead when the board is fine.
  3. DCPS current draw analysis: We connect the board to the DC power supply at battery voltage (3.8-4.0V) and prompt it to boot. The current draw pattern identifies which of the five failure categories applies. This is the most informative diagnostic step.
  4. Diode mode testing on power rails: Using a multimeter in diode mode, we probe the major rails: VDD_MAIN, the NAND supply, backlight, and the charging circuit lines. A shorted rail reads far lower than a healthy one. Diode mode identifies shorts without applying power, which protects the board from further damage.
  5. Voltage injection and thermal imaging: For confirmed shorts, we inject a current-limited voltage into the shorted rail and locate the heating component using freeze spray or a thermal camera. The shorted component absorbs all the current and heats up while surrounding components stay cold.
  6. Microsoldering repair: We remove the failed component, clean the pads, and verify the short is cleared by rechecking diode mode. For charging IC failures, we reball and install a replacement Tristar, Tigris, or both. For broken coils, we clear underfill and resolder the coils onto freshly tinned pads.
  7. Data extraction: Once the power circuit is restored, we boot the phone with a known good battery and screen, enter the passcode, and copy all data to external storage. The phone only needs to stay alive long enough to complete the transfer. We do not repair cameras, speakers, or cosmetic damage for data recovery jobs; we fix only the circuits needed to boot and access the file system.
Pre-X iPhones (original iPhone through 8 Plus)$500
FaceID models (X and newer)$750
EvaluationFree
No data recoveredNo charge
What to Do Before Sending Your Phone
What you do (and do not do) before sending the phone affects recovery outcome. Follow these guidelines to avoid making the problem worse.
Stop pressing the power button repeatedly
If the phone has a VDD_MAIN short, each boot attempt sends a 2A+ surge through the shorted rail. Repeated attempts stress adjacent components and can turn a single-cap failure into a multi-component failure. Press the power button once. If nothing happens, stop.
Do not attempt a restore through iTunes or Finder
A DFU restore erases all user data and reinstalls iOS. If the phone enters DFU mode (some dead phones can), a restore wipes the NAND. Your photos, messages, and contacts are gone permanently. Never attempt a restore on a phone where data recovery is the goal.
Do not open the phone or disconnect the battery
Opening an iPhone without proper ESD protection risks static discharge to the logic board. Disconnecting the battery connector with a metal tool can short components on the board. Leave the phone sealed and send it as-is. We handle disassembly in a controlled environment.
4
Write down your passcode
We need your passcode to access your data after repair. iPhone storage is encrypted, and the passcode is required to unlock the file system. Without it, the data is on the phone but inaccessible. Include the passcode in your shipping paperwork or provide it during intake.
5
Note what happened before the phone died
Did it die while charging? After a drop? Did it show the Apple logo then go black? Did the screen flicker first? Was it exposed to heat or cold? These details point us toward specific failure modes and speed up diagnosis. A phone that died on the charger suggests Tristar/Tigris. A phone that died after flickering suggests a progressive VDD_MAIN short. Every detail helps.
Ready to send your phone? See our mail-in process for shipping instructions, or contact us to start a free evaluation.
What We Can and Cannot Recover
Not every dead iPhone is recoverable. Here is an honest breakdown of what we see and what the outcomes look like.
Recovery is straightforward
  • VDD_MAIN short from a single failed capacitor
  • Tristar or Tigris charging IC failure
  • NAND power rail cap short
  • Broken power coils above the CPU
  • Display circuit failures (black screen, not actually dead)
Recovery is difficult but possible
  • CPU solder ball fracture
  • Sandwich board separation on iPhone 11+
  • Multiple concurrent failures from a previous repair attempt
Recovery is not possible
  • CPU damage (Secure Enclave destroyed; data encryption keys lost)
  • NAND chip physically cracked or delaminated
  • Previous repair caused overvoltage to the CPU
DCPS Quick Reference: What the Current Tells You
Before opening the phone, a DC power supply reading at battery voltage (3.8-4.0V) instantly categorizes the failure. This 30-second test determines the entire diagnostic path.
0.000A
No Current Draw
The PMIC is not responding. Either the PMIC itself is dead, the power button circuit is broken, or the board has a dead short so severe that the protection circuit cuts power before the PMIC can initialize. Check for shorts on VDD_MAIN first. If VDD_MAIN is clean, check the power button line and PMIC input rails.
0.01-0.15A
Low Current, No Boot
The PMIC starts but the CPU never begins its boot sequence. A partial short on a secondary rail (backlight, display, or baseband) holds the system in a pre-boot state. Also seen with Tristar/Tigris failures where the charging IC cannot negotiate power delivery correctly.
0.4-0.8A
Normal Boot Current, Black Screen
The board is booting normally but nothing shows on the screen. The phone may actually be on; try connecting to iTunes or triggering Siri. If iTunes detects the phone, the display circuit or backlight is the problem, not the logic board. Data extraction is straightforward once display output is confirmed via USB.
Watch: Dead iPhone Logic Board Recovery
Louis Rossmann walks through diagnosing and repairing a dead iPhone logic board, showing the DC power supply readings, component-level fault isolation, and microsoldering repair process from start to data extraction.
More board-level walkthroughs: the full dead logic board recovery walkthrough and an iPhone 6s diode-mode diagnostics teardown.
Is my data gone if my iPhone won't turn on?
Almost always no. The NAND storage chip that holds your photos, messages, and contacts is physically separate from the power delivery circuits that fail. A dead iPhone has a broken power path, not destroyed storage. We repair the power circuit with microsoldering, boot the phone, enter the passcode, and copy your data. The phone does not need to work permanently; it only needs to run long enough to transfer your files.
My phone died overnight on the charger. What happened?
Two common causes. First: a capacitor on a main power rail failed short-circuit while the phone was charging, creating a dead short that the PMIC cannot overcome. Second: the Tristar or Tigris charging IC degraded from prolonged charger connection, especially with a cheap third-party cable. Both are repairable with microsoldering. The NAND is unaffected in either case.
A repair shop said I need a new motherboard. Is that true?
For data recovery, a new motherboard means your data is gone. The NAND storage chip and the CPU are cryptographically paired to your original board. Replacing the motherboard gives you a working phone with none of your data. Most failures that shops call a dead motherboard are actually a single shorted capacitor, a failed charging IC, or a cracked coil. These are component-level repairs that keep your original board and your data intact.
Why did my iPhone die with no drop and no water damage?
Capacitors fail from age and thermal cycling. Charging ICs degrade from years of daily charge cycles, especially with third-party cables. Power-delivery inductors near the CPU crack from repeated flexion in a pocket, and CPU solder balls develop micro-fractures from thermal expansion. None of these require a drop or liquid exposure. They are wear failures that happen over time.
How much does dead iPhone data recovery cost?
Dead iPhone data recovery at Rossmann Group costs $500–$750. Pre-X iPhones (original iPhone through 8 Plus) are $500. Face ID models (X and newer) are $750. Evaluation is free.
Can you recover data if the screen is black but the phone vibrates?
A phone that vibrates, rings, or makes sounds has a working board. The display circuit has failed, not the phone itself. This is a different repair path from a dead phone. On the DC power supply, these phones show a normal boot current draw. The fix targets the backlight circuit or display connector rather than the main power rail. Data recovery from a black-screen phone with a working board is straightforward once the display output is restored.
My iPhone shows the Apple logo then goes black. Is it dead?
That is a boot loop, not a dead phone. The board has power and the CPU is running, but something is failing during the boot sequence. Common causes include NAND communication errors or a corrupted file system. Boot loops have a different diagnostic path and are often easier to resolve than a phone with no power at all. See our boot loop recovery page for details.
Why does my iPhone keep turning on and off?
Repeated shutdowns usually split two ways. An aging lithium-ion cell gains internal impedance, and more of it in the cold, so the voltage sags when the CPU and radios pull peak current. The power management system then shuts the phone down on purpose to protect the electronics, which is why a phone can die with charge still showing on the gauge. That points at the battery rather than the board, and a known good battery on the bench is the first check. The other path is a board fault the PMIC keeps retrying: a partial short on a power rail, or a degraded Tigris charging IC or Tristar or Hydra that cannot hold a stable input. We tell them apart by running the board on a DC power supply with no battery attached and watching the current pattern. Neither of those power-path faults touches the NAND, so your data is still on the phone.
My iPhone was crushed or run over. Is the data gone?
Not automatically. Crushing destroys the housing, screen, and battery long before it destroys silicon, so the question is narrower than it looks: did the two chips that hold and unlock your data survive the hit? If the board cracked, traces were severed, or pads tore loose but the NAND die and the SoC die are intact, the data is still there. When the broken connections can be rebuilt on the original board, we rebuild them there. If either die is cracked, the data is gone and no lab and no software changes that. Evaluation is free.
What is a CPU swap, and does it get my data back?
We don't do CPU swaps, so a phone that needs one isn't a job we take. A CPU swap moves the factory-paired chips off a broken logic board onto a working donor board of the same model: the SoC that carries the Secure Enclave, the NAND it was paired with, and the secure-storage chip that completes the key chain. All three move together. The memory chip on its own will not decrypt next to a processor it was never paired to, so there is no shortcut version of this repair. Once the transplanted board boots, you enter your passcode and the phone decrypts its own data as it always did. The swap preserves the encryption arrangement rather than stepping around it, so the passcode is still required. The risk is die damage during rework, which would destroy the keys permanently.
Does dead iPhone data recovery need a cleanroom?
No. A cleanroom keeps dust off the bare platters of an opened hard drive, where a single particle on a recording surface does damage. Your iPhone stores data on a NAND chip soldered to the logic board, and that chip stays soldered where it is. What the job needs is a current-limited DC power supply, diode-mode measurements, and microsoldering under a stereo microscope. We repair the power path or the Tristar or Hydra chip on your original board, boot it, and let you unlock it with your own passcode.
Most dead iPhones still have recoverable data. Free evaluation, no data no fee.
