RAID 5 Two Drives Failed
A RAID 5 array with two failed drives is not automatically unrecoverable. The second failure is often an SMR timeout ejection or a controller firmware mismatch. We recover double-degraded RAID 5 arrays by imaging every member offline and assembling the volume virtually on Data Extractor Express RAID Edition. The original chassis is never written to. Free evaluation. No data recovered means no charge.
What Happens When Two Drives Fail in a RAID 5 Array?
The controller stops servicing reads and writes because it cannot satisfy either operation. For a read, it needs all data blocks or parity plus all but one data block to XOR the missing piece; with two missing blocks, the math has two unknowns and one equation. For a write, it cannot update parity without reading the old data and old parity, which is now impossible because two members are unreadable.
The critical distinction is that the array is inaccessible, not destroyed. Every block that was readable before the second failure is still on the platters. The problem is geometric: the controller no longer knows which blocks form complete stripes, and even if it did, it lacks the parity data to fill the gaps. Recovery means extracting those blocks and reconstructing the stripe layout without the controller.
Not all dual failures are equal. If the two drives failed at different times, the older failure may contain data that was current when it dropped out. The overlap window between the first failure and the second failure determines how much data is fully reconstructible versus how much spans stripes with two permanently missing blocks.
Double-Degraded RAID 5 Terminology
- Double Degraded
- An array state where two members are offline or out of sync at the same time, exceeding the single-fault tolerance of RAID 5. One missing member leaves every stripe solvable from parity; the second missing member leaves every stripe short two of its N blocks and takes the volume offline.
- XOR Reconstruction Limit
- The algebraic constraint of single-parity RAID. XOR parity can solve exactly one unknown block per stripe. A stripe missing one block is reconstructible; a stripe missing two blocks is one equation with two unknowns and cannot be solved from parity alone.
- Write-Blocked Imaging
- Member-by-member cloning of each drive through a hardware write-blocker on PC-3000 Express before any rebuild or repair is attempted. The originals are never written to.
- Virtual Assembly
- Offline reconstruction of the array from the cloned member images in software rather than on the original hardware. Data Extractor Express RAID Edition assembles the stripe geometry in RAM from detected or captured metadata, so the original drives and chassis are never touched by the rebuild.
What Decides Whether a Double-Degraded Array Comes Back?
What happens physically to the member drives before any rebuild arithmetic runs decides it. A controller-initiated rebuild on a degraded parity array drives sustained read load across every surviving member, and those members share the same power-on hours, duty cycle, and operating environment as the drive that failed. Imaging each member first on PC-3000 Express reads the drive through a write blocker and moves the risk off the source drives and onto image files. Data Extractor Express RAID Edition then interprets the metadata and assembles the stripe geometry against those images, so a wrong assembly guess costs the original drives nothing and can be tried again.
That ordering is not specific to a dual failure. It is the same intake we use across hardware and software RAID array recovery at any level, and when the data is irreplaceable and no verified backup exists, it is what a still single-degraded single-parity RAID 5 volume needs before a second member drops.
Does Two Drives Failed Mean the Same Thing on RAID 6, RAID 10, and RAID 50/60?
The phrase "two drives failed" describes a symptom, not a verdict. Whether it means data loss depends on the array geometry. The double-degraded RAID 5 case is the worst one, because RAID 5 carries a single parity block per stripe and cannot reconstruct two missing blocks at once. The same count of failures on a different level often leaves the data fully present and recoverable. The table below maps what the symptom means at each level.
| RAID Level | What "Two Drives Failed" Means | Recoverable? |
| RAID 5 | Two missing blocks per stripe; single parity cannot solve two unknowns | Partial; depends on whether the two failures were time-separated |
| RAID 6 | Both losses are inside dual-parity (P + Q) tolerance | Yes; data is mathematically present, image before any rebuild |
| RAID 10 | Depends on whether both drives were in the same mirror pair | Yes if different pairs; lost if the same pair |
| RAID 50 | Depends on whether both losses hit one RAID 5 sub-array | Yes if spread one-per-sub-array; lost span if both in one |
| RAID 60 | Each RAID 6 sub-array absorbs two failures on its own | Yes; a single sub-array sustains two losses within tolerance |
RAID 6: two failures are inside tolerance
A RAID 6 array that loses exactly two members is still inside its fault tolerance, so the data is mathematically present. RAID 6 carries two independent syndromes per stripe: P, the XOR parity used by RAID 5, and Q, a Reed-Solomon syndrome computed over the Galois field GF(2^8). With two members gone the remaining blocks plus both syndromes give two equations for two unknowns, so every stripe is solvable.
The catch is that a double-degraded RAID 6 now has zero remaining redundancy, the same exposure a singly-degraded RAID 5 has. Any unrecoverable read error during a controller-driven rebuild then compromises the stripe it lands on, so every surviving member is imaged member-by-member before any rebuild is attempted, exactly as the URE math below demands. Our RAID 6 dual-parity recovery work follows the same image-first discipline.
A double-degraded RAID 6 behaves differently from a double-degraded RAID 5 at the operational level, not just the mathematical one. Because both P and Q are still resolvable, a RAID 6 array that loses two members usually stays online and keeps serving reads in a degraded-critical state; the volume is still mounted and the filesystem is still visible. A RAID 5 that loses its second member has no way to resolve the two missing blocks per stripe, so the controller drops the volume offline and the filesystem disappears. The RAID 6 "still readable" state is a trap: it is running with no redundancy, so a single unrecoverable read error or a third member dropping converts it from readable to unrecoverable with no warning. That is why the surviving members are imaged immediately rather than left running.
RAID 10: it depends on which pair failed
A RAID 10 array survives two failed drives only when the two drives sat in different mirror pairs. RAID 10 is a stripe of mirrors: each pair holds two identical copies of its half of the data. Lose one drive in a pair and its mirror still carries a full copy, so two failures spread across two different pairs leave every pair with a surviving member and the whole array reconstructs. Lose both drives in the same pair and that span has no surviving copy, so that portion of the stripe set is gone.
When a RAID 10 is recoverable, the rebuild reads only the surviving mirror of each pair, not every other member, so read amplification and the URE exposure window are far lower than a parity rebuild. RAID 10 mirror-set recovery turns on identifying which physical slots map to which pair.
RAID 50 and RAID 60: it depends on the sub-array distribution
A RAID 50 array tolerates two failed drives only when they fall in different RAID 5 sub-arrays. RAID 50 stripes data across multiple RAID 5 sets, and each set independently tolerates a single failure. Two failures spread one-per-sub-array leave each set singly degraded and recoverable; two failures inside one RAID 5 set push that set past its single parity and lose that span.
RAID 60 stripes across RAID 6 sets instead, so each sub-array inherits dual-parity tolerance and a single sub-array can absorb two simultaneous failures without catastrophic loss. For nested arrays the recovery turns on mapping each member to its sub-array before anything else, since the same two-failure count can be benign or fatal depending only on distribution.
The discipline is identical at every level. Whatever the layout, we image each member offline first and assemble the array virtually in Data Extractor Express RAID Edition from those images. For RAID 6 and RAID 50 the data can be mathematically present yet still lost if a controller hits a URE during a live rebuild and drops the array, which is why no live rebuild is ever attempted on a zero-redundancy span. The metadata that defines stripe order, chunk size, and sub-array membership lives on the member drives, so the original controller is not required to reassemble the array.
Which Member Do We Image First?
The member that dropped second is imaged first. Imaging order gets settled at intake, before anyone works out how probable the second failure was, because the drop order already decided which sectors carry the last coherent state of the volume. Every member leaves the chassis and goes onto a hardware write-blocker; nothing is forced online and no foreign configuration is imported before the clones exist. That intake posture applies to every array that comes through our RAID data recovery service, single-parity or nested.
In an N-member RAID 5 where one member dropped at T1 and a second dropped at T2, the N-2 members still in the chassis carry every write the controller committed to them up to T2. What they do not carry is whatever sat in an unflushed write-back cache, or a stripe that was mid-update when the array dropped. Add a clone of the second-failed member and each stripe the clone reads has N-1 of its blocks present, which is what single-parity reconstruction needs. The first-failed member is a fallback source; every stripe written between T1 and T2 is stale on it, so it gets consulted only for stripes the second-failed member cannot deliver.
Unreadable sectors get retried and mapped by the imager instead of aborting the job, because no live rebuild is run on the original members. PC-3000 Express reads sectors off each SATA or PATA member in that drop-order priority. The geometry work happens afterward in software, where Data Extractor Express RAID Edition detects stripe size, member order, and parity rotation against the image files.
Why the Second Failure Was Statistically Likely
Hard drives are sold with a URE specification, also called the bit error rate. Consumer SATA drives such as the WD Blue, Seagate Barracuda, and Toshiba P300 spec one URE per 10^14 bits read, which works out to about one unreadable sector per 12.5 TB of sequential reads. Enterprise drives such as the WD Ultrastar and Seagate Exos spec one URE per 10^15 bits, ten times better, or roughly one unreadable sector per 125 TB.
A four-member RAID 5 with 8 TB drives, after losing one member, has three surviving members of 8 TB each. The controller must read 24 TB sequentially under sustained load.
Against the worst-case 12.5 TB-per-URE warranty floor that read volume puts the probability of hitting at least one unreadable sector firmly above even odds on consumer media, and roughly ten times lower on enterprise media. Field studies show most drives read far past 12.5 TB clean, so treat that figure as a worst-case upper bound that scales with capacity and drive age, not a schedule.
When the controller hits a sector it cannot read, it cannot compute the missing XOR for that stripe, and the outcome is controller-specific. Legacy and low-end controllers abort the rebuild and drop the volume offline. Modern Dell PERC and LSI/Broadcom MegaRAID puncture the stripe: they write a bad-block placeholder, finish the rebuild, and keep the volume online, with only that one stripe permanently lost.
Linux mdadm records the bad LBA in its Bad Block Log and continues. The data inside the affected stripe is gone in every case, but a single URE does not always take the whole array offline.
This is why we do not attempt live rebuilds on degraded arrays. We image each member offline through PC-3000 Express with adaptive retry settings. If a sector fails on the first pass, the imager retries with adjusted read parameters. Sectors that remain unreadable after exhaustive retries are flagged, and the missing data for those stripes is reconstructed from parity during offline assembly rather than during a live rebuild under controller timeout pressure.
When the "Second Failure" Is Actually an SMR Timeout
Drive-managed Shingled Magnetic Recording (SMR) drives use a small persistent conventional-recording (CMR) cache zone for incoming writes, then reorganize that data onto overlapping shingled tracks during idle periods. A RAID rebuild is the opposite of idle. It forces continuous sequential writes to the replacement drive while the surviving members are read at sustained sequential rates. Once the CMR cache fills, the SMR drive must pause to flush its accumulated writes into the shingled zones.
No drive-managed SMR drive belongs inside a parity RAID array. If a drive-managed SMR drive was placed as the replacement during a rebuild, the rebuild does not just slow down; it actively converts the array from single-fault degraded to double-fault failed.
The SMR drive is not mechanically failed. When removed from the controller and connected to a direct SATA port or to PC-3000 Express, it reads normally. The array is recoverable by imaging the SMR member at its own pace, repairing the mechanically failed first member if needed, and assembling the array virtually.
When the Second Failure Is an NVMe Cache Dropout
Synology DSM runs its arrays on standard Linux mdadm, with SHR adding LVM beneath a Btrfs or ext4 filesystem. Prosumer models such as the DS920+, DS1520+, and DS1621+ accept M.2 NVMe drives configured as read/write caches in front of that array. In read/write mode the cache is dirty: writes are acknowledged to the filesystem once they land on the NVMe device, before they are destaged to the mechanical members. The newest filesystem state lives on the cache, not on the platters.
Under heavy sustained write load, consumer-grade NVMe controller firmware can panic and the cache device drops off the PCIe bus. Every dirty write it was holding, acknowledged to the filesystem but never flushed to the HDD members, is permanently lost. The underlying array is left holding an incomplete, corrupted Btrfs filesystem, and DSM immediately reports the volume as crashed.
Like the SMR timeout ejection above, this is a second failure that is not a mechanical failure. The spindle members spin up, pass SMART, and read normally; no head crashed and no motor seized. What died is the consistency of the filesystem above them. On an array that was already degraded when the cache dropped, the situation compounds: one member is missing, the filesystem is corrupted, and there is no redundancy left to absorb a single further read error.
Btrfs makes the wrong response here unusually expensive. Because Btrfs is copy-on-write, older generations of the metadata trees survive on disk, and those historical tree roots are exactly what professional recovery reads to reconstruct the filesystem. Running btrfs check --repair or force-mounting with recovery flags writes updated B-tree structures in place and overwrites those older generations. The DSM Repair button belongs on the same banned list as the controller commands below.
The recovery target is the consistent state on the mechanical members, not the cache device. The uncommitted writes trapped in the crashed NVMe drive are gone; what remains recoverable is everything Btrfs had already committed to the platters. Each member is imaged through a hardware write-blocker on PC-3000 Express, the volume is assembled virtually with Data Extractor Express RAID Edition, and the filesystem is extracted with read-only Btrfs forensic tools such as btrfs-find-root and btrfs restore, working from historical transaction generations rather than repairing anything in place.
Distinguishing a True Dual Failure from a Timeout Ejection
| Symptom | Timeout Ejection | True Mechanical Failure |
| Spins up on power | Yes, normal speed | No, or spins then stops (stuck spindle) |
| SMART self-test | Passes | Fails or timeouts |
| Direct SATA read | Reads normally | Extensive bad sectors or no response |
| Controller status | Unconfigured-Bad or Offline | Failed or Missing |
| Next power cycle | Often returns to Unconfigured-Good | Same failure, no change |
| Recovery path | Logical imaging, no mechanical repair | Head swap, platter work, or donor transplant |
Hex-Level Disk Ordering Reconstruction
RAID metadata lives in controller-specific structures: LSI MegaRAID and Dell PERC store SNIA Disk Data Format (DDF) metadata at the end of each member: the 512-byte DDF Anchor Header sits at the absolute last LBA, and MegaRAID reserves 512 MB at the end of each member for that metadata.
HP Smart Array writes its proprietary RAID Information Sectors (RIS) at the beginning of each member. Linux mdadm v1.2 superblocks sit at the 4 KiB offset. When these structures are intact, we read stripe size, parity rotation, and member order directly.
When metadata has been overwritten by prior recovery attempts or controller auto-initialization, we fall back to hex analysis. The filesystem that sat on the array left signatures at known offsets. The EXT4 superblock sits at offset 0x400 (1024 bytes) and carries the magic signature 0xEF53 at offset 0x438 (1080 bytes) from the start of the volume. XFS allocation group headers begin with 0x58465342 (XFSB). NTFS boot sectors start with NTFS at LBA 0 of the volume.
In a correctly ordered array, these signatures appear at the same logical offset across member boundaries because the stripe size places each filesystem block on the member where it belongs. In a misordered array, the signatures are scattered or absent because each member contains the wrong subset of stripes. By rotating the member order virtually and testing which permutation produces coherent filesystem headers at the expected offsets, we determine the correct assembly without relying on surviving superblocks.
Missing Parity Block Recovery via Virtual Assembly
RAID 5 distributes parity across all members in a rotating pattern. For any stripe, XORing all data blocks and the parity block produces zero. When one member is missing, XORing the remaining blocks reproduces the missing one. When two members are missing, the equation has two unknowns and cannot be solved algebraically.
However, if the two failures occurred at different times, the member that failed first may still contain parity blocks that were current at the moment it dropped out. The second failure happened later, after the array had continued writing with one member missing. The parity on the first-failed drive matches the data state from before the second failure for stripes that were not written after the first drive dropped.
Data Extractor Express RAID Edition loads the cloned images and assembles the virtual array using detected or captured metadata. For each stripe, it checks how many blocks are readable. Stripes with zero or one missing block are fully reconstructible. Stripes with two missing blocks are flagged. We then use filesystem-level analysis to determine which files span only reconstructible stripes versus which files touch permanently lost stripes. Priority data (databases, virtual machines, shared folders) is verified first.
This approach only works because we assemble the array virtually from cloned images. The original drives are never written to. The reconstruction happens in RAM, stripe by stripe, with no controller timeouts and no stress on marginal media.
Why Competitors Claim Two-Drive-Failure RAID 5 Is Unrecoverable
DiskInternals recommends connecting failing disks to a local workstation and using software to rebuild the array. This ignores URE physics, controller timeout drops, and the difference between a logical disk drop and a mechanical head crash. Running software reconstruction against a double-degraded array without imaging first risks further stress on marginal drives and produces incomplete or corrupted output.
Secure Data Recovery states that RAID 5 distributes data across multiple drives along with parity information. Parity information removes the need for a dedicated drive. This is technically true at the RAID level but provides no guidance for a sysadmin facing two simultaneous failures. It does not explain parity rotation, stripe size detection, or virtual assembly.
Ontrack claims that RAID 5 data recovery is possible in most cases... provided the failed drive is replaced quickly. This framing conflates single-fault recovery with dual-fault recovery and implies that speed of replacement is the deciding factor. The deciding factor is whether the two failures occurred at different times and whether at least one of the failed members is still mechanically readable.
The reality is that double-degraded RAID 5 recovery is a forensic exercise, not a software wizard. It requires imaging every member, parsing RAID metadata or reconstructing it from hex signatures, and performing stripe-by-stripe parity analysis on cloned images. Data Extractor Express RAID Edition and UFS Explorer Professional are the tools that perform this work, not generic RAID recovery software running against live drives.
Commands That Destroy Double-Degraded Arrays
If your RAID 5 has two failed drives: the commands below are the ones most often recommended on forums for recovering a double-degraded array. Every one of them writes to the member drives and forecloses on a clean forensic recovery.
megacli -PDMakeGood -PhysDrv [E:S] -aALLWhat it does: changes the DDF state of an Unconfigured-Bad drive to Unconfigured-Good and frequently triggers an immediate background initialization. Why it destroys data: the initialization overwrites the existing metadata that records which stripes belong to which array.MegaCli -CfgForeign -Clear -aALLWhat it does: tells the LSI controller to discard the Foreign Configuration metadata it found on the drives. Why it destroys data: the array geometry is in that metadata. Clearing it leaves the drives with valid user data but no record of how to assemble it.mdadm --create --assume-clean --level=5 --raid-devices=N ...What it does: creates a new mdadm superblock on every member and assumes parity is already consistent. Why it destroys data: the v1.2 superblock at offset 4 KiB is rewritten with new UUIDs and a new event count; the array geometry from the original create call is lost unless it happens to be identical, and silent corruption follows on the next write.- Synology DSM Storage Manager Repair button on a crashed volumeWhat it does: runs a Synology-authored script that calls mdadm and lvm with parameters intended to bring the array back online. Why it destroys data: the script can overwrite md superblocks and LVM metadata on partition 3 of the surviving members. Read-only inspection on a separate Linux workstation is the safe alternative.
- Force Online or Make Optimal in LSI or PERC BIOS menusWhat it does: overrides the controller's decision that the array is offline. Why it destroys data: writes pending in the cache flush to the drives even though parity and data are inconsistent.
Most two-drive failures we see happen inside a consumer or prosumer NAS enclosure rather than a server. Synology, QNAP under QTS, Buffalo, Asustor, and TerraMaster units run standard Linux mdadm RAID 5 or RAID 6 under the hood, and Synology SHR is just mdadm plus LVM plus btrfs or ext4, not a proprietary format.
The same double-degraded mdadm recovery path applies, and the chassis is never required because the array metadata lives on the member drives. If you hit this on a NAS box, route the case through Synology and QNAP NAS data recovery.
Our Image-First, No Live Rebuild Process
- Do not retry the rebuild, do not click Repair, and do not run any controller commands. Every additional power-on cycle increases the risk of head crash on marginal drives.
- Free evaluation and documentation. Record the controller model, RAID level, member count, filesystem (ext4, XFS, Btrfs, ZFS, NTFS, VMFS), and every prior rebuild or repair attempt and the commands run. This step is free.
- Label every drive bay. Each drive is marked with its physical slot number before removal and bagged individually. Slot order is required to validate stripe layout during virtual assembly.
- Capture RAID metadata from each member. Metadata location varies by controller family: LSI MegaRAID and Dell PERC store DDF in the trailing sectors; HPE SmartArray writes RIS at the beginning of the drive; Linux mdadm v1.2 superblock sits at offset 4 KiB. Metadata capture runs against cloned images, not the originals.
- Write-blocked forensic imaging. Each member is connected through a hardware write-blocker to PC-3000 Express. Adaptive retry and head-map analysis pull marginal sectors that the controller had given up on. Mechanical members receive donor head transplants on the ULPA-filtered laminar-flow clean bench before imaging.
- Offline virtual assembly. Data Extractor Express RAID Edition loads the cloned images and assembles the array virtually using the captured metadata. The stripe size, parity rotation, and member order are read from the on-disk metadata or determined by hex analysis if metadata is damaged.
- Parity recalculation and filesystem extraction. Stripes with missing data are reconstructed from parity. The assembled volume is mounted read-only. R-Studio and UFS Explorer handle filesystem-level recovery if the filesystem itself sustained damage.
- Delivery and secure purge. Recovered data is copied to your target media. After you confirm receipt, working copies are securely purged on request.
How Member Interface Changes the Imaging Toolchain
The write-blocked imaging in step 5 uses different hardware depending on the physical interface of each member drive. SATA HDDs and SATA SSDs are imaged on PC-3000 Express, a SATA and PATA imager. NVMe members are imaged on the PC-3000 SSD with the PC-3000 SSD Extended add-on, which provides NVMe support; they are not imaged on PC-3000 Express, which is optimized for spinning HDDs. An NVMe member needing an image is a different situation from a read/write NVMe cache device dropping off the array covered above; the point here is the imaging toolchain, not the cache-dropout failure mode.
A failed SAS member is a separate intake discussion. The lab does not own a PC-3000 SAS, so SAS member imaging is scoped case by case rather than treated as an in-house step.
| Member Interface | Imaging Toolchain |
| SATA HDD or SATA SSD | PC-3000 Express |
| NVMe | PC-3000 SSD with the PC-3000 SSD Extended add-on |
| SAS | Scoped case by case at intake; not imaged in-house |
Regardless of member interface, the assembled images are loaded into Data Extractor Express RAID Edition for offline virtual assembly.
How Much Does RAID 5 Two-Drive-Failure Recovery Cost?
Per-Member Imaging
- Logical or firmware-level issues: $250 to $900 per drive. Covers filesystem corruption on the array, firmware module damage that prevents normal reads, and SMART threshold failures.
- Mechanical failures (head swap, motor seizure): $1,200 to $1,500 per drive with a 50% deposit. Donor parts are consumed during the transplant. Head swaps are performed on a validated laminar-flow clean bench before write-blocked cloning.
- Timeout-ejected SMR or desktop drives: $250 per drive. The drive is mechanically healthy and images cleanly once removed from the controller.
Array Reconstruction
- $400 to $800 depending on member count, filesystem type, and whether RAID parameters must be detected from raw data versus captured from surviving DDF or mdadm superblocks.
- Data Extractor Express RAID Edition performs parameter detection and virtual assembly from cloned member images. R-Studio and UFS Explorer handle filesystem-level extraction after reconstruction.
No Data = No Charge: if we recover nothing from your array, you owe $0. Free evaluation, no obligation.
Example: a four-member array with one mechanically failed member and one timeout-ejected member costs approximately $1,200 (head swap) + $250 (logical imaging) + $400-$800 (reconstruction) = $1,850 to $2,250.
+$100 rush fee to move to the front of the queue. Full HDD pricing is published at our HDD recovery service page.
RAID 5 Two Drives Failed Recovery Questions
Is a RAID 5 with two failed drives unrecoverable?
Why did the second drive fail during the RAID 5 rebuild?
Can an SMR drive look like a failed drive when it is actually healthy?
How do you tell the difference between a timeout ejection and a real drive failure?
What is virtual assembly in RAID 5 recovery?
What is hex-level disk ordering reconstruction?
How do you recover missing parity blocks?
Which failed drive do you image first in a double-degraded RAID 5?
Should I force the failed drives online in the controller BIOS?
How much does RAID 5 two-drive-failure recovery cost?
How long does RAID 5 two-drive-failure recovery take?
Two drives failed.
