Enterprise Server Data Recovery
Dell PERC H740P Data RecoveryDell PowerEdge R740 / Dell PowerEdge R740xd / Dell PowerEdge R640
Dell PERC H740P data recovery at Rossmann Group in Austin, Texas. This Dell hardware raid controller supports RAID levels 0, 1, 5, 6, 10, 50, 60 across up to 64 drives via SAS/SATA. Commonly found in Dell PowerEdge R740, Dell PowerEdge R740xd, Dell PowerEdge R640. Per-drive imaging costs $600 to $1,500 depending on drive condition, plus an array reconstruction fee. The most common failure we handle is patrol read detected uncorrectable error. All work is backed by our no-data-no-fee guarantee; you pay nothing if we cannot recover your files.
Dell PERC H740P Specifications
The Dell PERC H740P is a Broadcom SAS3516-based controller found in 14th-generation PowerEdge servers. It supports 12Gb/s SAS and 6Gb/s SATA drives, with 8GB flash-backed DDR4 cache. RAID metadata is stored in DDF format. The H740P introduced persistent cache: if the server loses power mid-write, pending data is preserved in flash and automatically committed on reboot. If the controller itself fails, cache recovery requires a matching replacement H740P (same firmware revision) to read the flash-backed cache module.
- Manufacturer
- Dell
- Controller Type
- Hardware RAID
- Interface
- SAS/SATA
- RAID Levels
- 0, 1, 5, 6, 10, 50, 60
- Max Drives
- 64
- Cache
- 8GB DDR4
- Battery-Backed Cache
- Yes
Recovery Tool Support
Broadcom SAS3516 ROC with 12Gb/s SAS. Same DDF metadata family as H730 but with larger reserved sectors. Data Extractor Express RAID Edition parses the DDF metadata to reconstruct arrays. Flash-backed cache recovery requires a matching replacement H740P with the same firmware revision.
Compatible Server Lines
The Dell PERC H740P is found in the following server platforms. If your server uses this controller and the array has failed, we can reconstruct the RAID offline from individual drive images.
Failure Modes
RAID controller failures differ from individual drive failures. The controller metadata, stripe maps, and parity calculations must all be intact for the array to function. Below are the failure modes specific to the Dell PERC H740P.
Patrol Read Detected Uncorrectable Error
Background patrol read finds sectors the drive cannot correct internally. If enough accumulate, PERC preemptively flags the drive as 'Predictive Failure' and may drop it from the array. Rebuild starts automatically on the remaining members but fails if media errors exist on those drives too.
Symptoms you may notice
- iDRAC lifecycle log shows patrol read errors with specific LBA ranges
- Single drive drops from RAID 5/6 array
- Rebuild starts but stalls at a percentage when it hits bad sectors on remaining drives
Related search terms
Cache Data Preserved / Pinned Cache
Flash-backed write cache preserves unflushed writes after power loss. If the controller fails and is replaced, the new controller cannot read the pinned cache from the old controller's flash module. The array will not import until the cache is either flushed by the original controller or discarded (losing the cached writes).
- Replacement controller shows 'Preserved Cache' or 'Pinned Cache' warning at POST
- Array will not import until cache is discarded or original controller restored
- iDRAC logs show cache policy conflict
How We Recover Dell PERC H740P Arrays
Step 1: Individual Drive Imaging
Every drive from the array is imaged independently using the PC-3000 and DeepSpar Disk Imager. Drives with head failures or firmware corruption are repaired first. Each drive is imaged sector-by-sector to a clean target before any reconstruction begins.
For SAS/SATA drives, we use the appropriate interface hardware. SAS drives require dedicated SAS HBAs; SATA drives connect directly. This preserves every readable sector without relying on the original Dell PERC H740P controller.
Step 2: Array Reconstruction
We use Data Extractor Express RAID Edition to reverse-engineer the Dell PERC H740P's metadata structure: stripe size, drive order, parity rotation, and offset values. The array is reconstructed from the drive images without needing the original controller hardware.
Once the virtual array is assembled, we extract the file system (NTFS, ext4, XFS, VMFS, ZFS, or other) and verify file integrity before delivering the recovered data.
The Dell PERC H740P includes a battery-backed or flash-backed write cache (8GB DDR4). If the server lost power during a write operation, pending writes are preserved in the cache. On restart with a healthy controller, the firmware automatically flushes this cached data to disk; no manual intervention is needed. If the controller itself has failed, recovering cached data requires an identical replacement controller (same model, firmware revision) to which the cache module can be transferred.
Recovery pricing for Dell PERC H740P arrays has two components: per-drive imaging and array reconstruction. Drive imaging costs $600–$900 to $1,500 per drive depending on condition (firmware repair vs. head swap). Array reconstruction adds a separate fee depending on the number of drives and RAID level complexity.
See our full pricing breakdown for details. Our No Data, No Fee guarantee means you pay nothing if we cannot recover your files.
My PERC H740P shows 'Preserved Cache' after a controller replacement. Is that data recoverable?
What is the difference between PERC H730 and H740P for recovery purposes?
Can you recover an H740P array where patrol read dropped a drive?
How much does PERC H740P RAID recovery cost?
Other Dell RAID Controllers
We also recover arrays built on these Dell controllers.
Need help with a different setup? We also recover NAS arrays, standalone RAID, and enterprise SSDs.
Server Recovery Overview →Since 2008
Other Recovery Services
Nationwide Coverage
Popular Service Areas
Dell PERC H740P array down?
Ship the drives to our Austin lab for a free evaluation. No data, no charge.
