Enterprise Server Data Recovery
Dell PERC H730 Data RecoveryDell PowerEdge R730 / Dell PowerEdge R730xd / Dell PowerEdge R630
Dell PERC H730 data recovery at Rossmann Group in Austin, Texas. This Dell hardware raid controller supports RAID levels 0, 1, 5, 6, 10, 50, 60 across up to 32 drives via SAS/SATA. Commonly found in Dell PowerEdge R730, Dell PowerEdge R730xd, Dell PowerEdge R630. Per-drive imaging costs $600 to $1,500 depending on drive condition, plus an array reconstruction fee. The most common failure we handle is foreign configuration detected. All work is backed by our no-data-no-fee guarantee; you pay nothing if we cannot recover your files.
Updated February 2026
5 min read
Specifications
Dell PERC H730 Specifications
The Dell PERC H730 uses a rebranded LSI SAS3108 ROC with 2GB DDR3 cache. It stores RAID metadata in DDF (Disk Data Format) on reserved sectors at the end of each member drive, plus a copy in controller NVRAM. Default strip size is 64KB; the parity rotation is read from the on-disk metadata rather than assumed from a vendor default. Data Extractor Express RAID Edition reads the DDF superblock directly from the drive images to reconstruct the array without needing the original controller.
Manufacturer
Dell
Controller Type
Hardware RAID
Interface
SAS/SATA
RAID Levels
Max Drives
32
Cache
2GB DDR3
Battery-Backed Cache
Yes
Recovery Tool Support
Data Extractor Express RAID Edition: Supported
Manual Reconstruction: Supported
Data Extractor Express RAID Edition reads the DDF superblock directly from the drive images to reconstruct the array without needing the original controller. Default strip size is 64KB; the parity rotation is read from the on-disk metadata rather than assumed from a vendor default.
Compatible Server Lines
The Dell PERC H730 is found in the following server platforms. If your server uses this controller and the array has failed, we can reconstruct the RAID offline from individual drive images.
Dell PowerEdge R730Dell PowerEdge R730xdDell PowerEdge R630Dell PowerEdge T630Dell PowerEdge R530Dell PowerEdge T430
Failure Modes
Failure Modes
RAID controller failures differ from individual drive failures. The controller metadata, stripe maps, and parity calculations must all be intact for the array to function. Below are the failure modes specific to the Dell PERC H730.
Foreign Configuration Detected
Occurs when drives are moved between PERC controllers or the controller is replaced. PERC writes its own DDF metadata; swapping controllers causes the new PERC to flag drives as foreign because the controller serial number in the metadata does not match.
Symptoms you may notice
  • BIOS/UEFI shows 'Foreign Configuration Detected' during POST
  • Server will not boot to OS
  • Amber blinking on drive activity LEDs
Related search terms
Dell PERC H730 foreign configurationPERC H730 foreign config detectedDell PERC foreign drivesPERC H730 data recovery
Virtual Disk Degraded / Failed
One or more drives dropped from the array. PERC marks the virtual disk as degraded (single drive loss in RAID 5/6) or failed (beyond redundancy). Automatic rebuild attempts fail if the remaining drives have bad sectors that the controller cannot remap.
  • OMSA or iDRAC alerts showing virtual disk degraded or failed
  • OS reports I/O errors on the logical volume
  • Server performance drops as PERC retries reads on failing sectors
PERC H730 virtual disk failedDell PERC H730 degraded arrayPERC H730 rebuild failedDell PowerEdge RAID recovery
Recovery Process
How We Recover Dell PERC H730 Arrays
Step 1: Individual Drive Imaging
Every drive from the array is imaged independently using the PC-3000 and DeepSpar Disk Imager. Drives with head failures or firmware corruption are repaired first. Each drive is imaged sector-by-sector to a clean target before any reconstruction begins.
For SAS/SATA drives, we use the appropriate interface hardware. SAS drives require dedicated SAS HBAs; SATA drives connect directly. This preserves every readable sector without relying on the original Dell PERC H730 controller.
Step 2: Array Reconstruction
We use Data Extractor Express RAID Edition to reverse-engineer the Dell PERC H730's metadata structure: stripe size, drive order, parity rotation, and offset values. The array is reconstructed from the drive images without needing the original controller hardware.
Once the virtual array is assembled, we extract the file system (NTFS, ext4, XFS, VMFS, ZFS, or other) and verify file integrity before delivering the recovered data.
The Dell PERC H730 includes a battery-backed or flash-backed write cache (2GB DDR3). If the server lost power during a write operation, pending writes are preserved in the cache. On restart with a healthy controller, the firmware automatically flushes this cached data to disk; no manual intervention is needed. If the controller itself has failed, recovering cached data requires an identical replacement controller (same model, firmware revision) to which the cache module can be transferred.
Recovery pricing for Dell PERC H730 arrays has two components: per-drive imaging and array reconstruction. Drive imaging costs $600–$900 to $1,500 per drive depending on condition (firmware repair vs. head swap). Array reconstruction adds a separate fee depending on the number of drives and RAID level complexity.
See our full pricing breakdown for details. Our No Data, No Fee guarantee means you pay nothing if we cannot recover your files.
My PERC H730 shows 'Foreign Configuration Detected' after a controller swap. Can you recover the data?
Yes. The PERC H730 stores DDF metadata on reserved sectors at the end of each member drive. When a controller is replaced, the new PERC flags the drives as foreign because its serial number does not match the metadata. We image the drives and read the DDF superblock directly using Data Extractor Express RAID Edition to reconstruct the array without needing the original controller.
What stripe size does the PERC H730 use by default?
The H730 defaults to a 64KB strip size. Dell publishes no factory-default parity rotation, so during recovery Data Extractor Express RAID Edition reads the strip size and the layout from the DDF metadata rather than guessing the configuration.
Can you recover a PERC H730 RAID 5 array where rebuild failed partway through?
Yes. A failed rebuild leaves the array in a partially consistent state: some stripes have been rebuilt with new parity, others still reference the failed drive. We image all member drives including the replacement, read the rebuild checkpoint from DDF metadata, and reconstruct both the pre-rebuild and post-rebuild stripe regions to produce a complete image.
How much does PERC H730 RAID recovery cost?
Each drive is imaged individually; pricing depends on the drive condition (firmware repair, head swap, etc.). Array reconstruction with DDF metadata parsing is $400-$800 per array. No data recovered means no charge.
Other RAID Controllers
Other Dell RAID Controllers
We also recover arrays built on these Dell controllers.
Overview
Need help with a different setup? We also recover NAS arrays, standalone RAID, and enterprise SSDs.
Server Recovery Overview →
Nationwide Coverage
View All Locations
Dell PERC H730 array down?
Ship the drives to our Austin lab for a free evaluation. No data, no charge.
