PC-3000 SSD Recovery Workflows
DRAM-less SSD Data Recovery
Budget SSDs like the Kingston A400, ADATA SU650, Crucial BX500, Patriot P300, Kingston NV1, & WD_BLACK SN750 SE omit the dedicated DRAM cache that holds the Flash Translation Layer. SATA DRAM-less drives keep the FTL in NAND with a small SRAM working set on the controller; DRAM-less NVMe drives use the Host Memory Buffer (HMB) protocol to borrow 16 MB to 64 MB of system RAM as a volatile scratchpad. When that scratchpad evaporates, the drive can't find its own data.
This is one of the most common patterns we see in SSD data recovery service: a power cut, a USB enclosure pop-out, a BSOD, or a PCIe link drop, and the drive enumerates with the wrong size, 0GB, or refuses to detect entirely. SATA firmware recovery starts at $600–$1,200. NVMe firmware recovery starts at $900–$1,200. No diagnostic fee.
Updated May 2026
What should you do when a DRAM-less SSD shows 0GB or fails to detect?
DRAM-less SSDs cache the FTL either in NAND (SATA) or in host RAM through Host Memory Buffer (NVMe). When the PCIe link drops or the controller panics, the working FTL state is lost & the drive enumerates with the wrong size, 0GB, or refuses detection. Recovery is performed in PC-3000 SSD Technological Mode by rebuilding the translator from NAND-resident metadata.
What Makes a DRAM-less SSD Different?
A DRAM-cached SSD pairs the controller with a dedicated DDR3 or DDR4 chip (typically 256 MB to 1 GB per terabyte of NAND) that holds the entire active Flash Translation Layer. The controller maintains the L2P map in that DRAM, commits checkpoints to NAND on a schedule, and recovers cleanly from most power events because the on-NAND checkpoint is recent. The DRAM acts as a buffer between the host and the relatively slow NAND.
DRAM-less drives remove that chip to cut bill-of-materials cost. The FTL still has to live somewhere, & the controller still needs a working set of L2P entries to service incoming reads.
The two architectures handle the missing DRAM differently. SATA DRAM-less controllers store the FTL in NAND & cache a small portion in on-die SRAM. NVMe DRAM-less controllers use the NVMe Host Memory Buffer feature to carve out a region of system RAM & treat it as if it were the missing DRAM. Both approaches work in the steady state. Both fall apart under an unclean shutdown.
SATA DRAM-less: FTL in NAND, working set in SRAM
The PS3111-S11, SM2259XT, & Maxio MAS0902A all share the same pattern. The active L2P map lives in dedicated NAND service blocks. At boot, the controller reads the service area, validates the most recent checkpoint & journal, & pulls a hot subset of L2P entries into on-die SRAM.
User reads against addresses in the SRAM cache resolve quickly; reads against cold addresses cause an SRAM miss & trigger an NAND lookup of the L2P map itself.
The vulnerability lives in the journal. The PS3111-S11 is a 2-channel controller with limited write parallelism, so the in-flight L2P delta during a sequential write can span several NAND pages. A power cut mid-write produces split-brain metadata where half a 16 KiB page committed & the other half failed ECC.
The controller cannot resolve which copy is authoritative on the next boot & panics into BootROM, emitting the SATAFIRM S11 identity string. The user data is still on the NAND; only the FTL pointer to it is gone.
NVMe DRAM-less: FTL in Host Memory Buffer
The NVMe specification added Host Memory Buffer in version 1.2 to make DRAM-less NVMe drives commercially viable. The host OS driver allocates a region of system RAM (commonly 16 MB on entry drives, up to 64 MB on Gen4 parts) & hands the physical addresses to the SSD controller during NVMe initialization. The controller then uses that region as its primary L2P cache, treating it as if it were soldered to the drive's PCB.
Steady-state performance is acceptable: HMB latency over PCIe Gen3 x4 is on the order of a few microseconds, fast enough that an L2P lookup against host RAM beats a roundtrip to NAND. The trade-off is that the HMB region is fundamentally volatile. The controller does not own that memory. The host can revoke it; a USB-NVMe enclosure can lose the PCIe link; the host OS can crash & tear down the PCIe topology entirely.
When any of those events happens before the in-flight L2P delta has committed to NAND, the delta is gone. The on-NAND FTL ends up describing a different state of the drive than the writes actually produced, & the controller fails its consistency check on next boot.
Which Controllers Are DRAM-less?
The most common DRAM-less controllers shipping in retail & OEM drives as of 2026, the drives that use them, & where the FTL working set actually lives.
ControllerInterfaceFTL Working SetCommon Drives
Phison PS3111-S11SATANAND + SRAM working setKingston A400, Patriot Burst, Silicon Power S55, many OEM rebrands
Silicon Motion SM2259XTSATANAND + SRAM working setCrucial BX500 (later revisions), ADATA SU650 (some revisions), WD Green SATA
Maxio MAS0902ASATANAND + SRAM working setVarious OEM and budget rebrand SSDs
Silicon Motion SM2263XTNVMe Gen3 x4Host Memory Buffer (16-64 MB) + SRAMHP EX900, ADATA XPG SX6000 Lite, OEM rebrands
Phison PS5013-E13TNVMe Gen3 x4Host Memory Buffer + SRAMPatriot P300, Kingston NV1 (subject to silent controller swaps)
Phison PS5019-E19NVMe Gen4 x4Host Memory Buffer + SRAMWD_BLACK SN750 SE
Phison PS5021-E21TNVMe Gen4 x4Host Memory Buffer + SRAMCrucial P3, Kingston NV2 (also subject to silent controller swaps), Corsair MP600 Mini 2230
Silicon Motion SM2269XTNVMe Gen4 x4Host Memory Buffer + SRAMBudget NVMe rebrands, OEM modules, latest DRAM-less SMI Gen4 designs
Realtek RTS5763DLNVMe Gen3 x4Host Memory Buffer + SRAMADATA Swordfish (1TB/2TB), XPG SX6000 Pro, XPG SX6000 Lite, Gammix S5, Gammix S20G, some Kingston NV1 batches
Drives like the Kingston A400, Kingston NV1, Kingston NV2, & Crucial P3 are known for silent component-level revisions: the controller, NAND vendor, & firmware can change inside the same model number & SKU between production runs. The specific controller in a returned drive can vary even when the label is identical, which matters when matching the correct PC-3000 SSD loader & NAND chip ID profile during recovery.
Realtek RTS5763DL exception: The Realtek RTS5763DL is the one DRAM-less NVMe controller in the table above that is not currently covered by PC-3000 SSD's loader library. Rossmann does not currently offer in-lab recovery for Realtek RTS5763DL. Confirm the controller silicon visually on the PCB before shipping; the same SKU (notably Kingston NV1) ships with Phison, Silicon Motion, or Realtek silicon across production runs, & the label on the drive does not disambiguate.
How Do DRAM-less SSDs Actually Fail?
DRAM-less drives fail through the volatility of their FTL working set. The on-NAND FTL drifts out of sync with the writes that were buffered in HMB or SRAM, & the controller refuses to mount a drive whose metadata it cannot trust. The symptom is the same across vendors: wrong capacity, 0GB, refused detection, or garbage on reads.
HMB tear-down on NVMe drives
The failure chain on an NVMe DRAM-less drive during a power cut runs like this. The controller is buffering the working L2P delta in the HMB region that the host allocated inside system RAM. User writes generate new L2P entries that sit in HMB waiting for the next idle window to commit to NAND.
A power cut tears down the PCIe link before that commit finishes; the in-flight delta in host RAM is lost instantly & the drive never receives a clean shutdown notification.
On the next boot, the controller reads its last on-NAND checkpoint & finds it inconsistent with the block sequence numbers in the physical data region.
Depending on how far the write was from completing, the controller either journal-replays through its on-NAND log (if the log survived) or panics into BootROM & emits a firmware-panic identity string. The drive enumerates with the wrong capacity, 0GB, or fails to enumerate on the PCIe bus at all.
Common HMB tear-down triggers
  • Sudden power loss to the host during write activity
  • Host OS crash or BSOD that tears down the PCIe topology before drive flush
  • USB-to-NVMe enclosure disconnect during a write
  • PCIe link training error after a thermal event or marginal slot contact
  • Driver re-initialization that revokes the HMB allocation mid-operation
  • Firmware panic from an unrelated path that invalidates the HMB-resident state
SATA DRAM-less: same outcome, no HMB
The PS3111-S11, SM2259XT, & MAS0902A don't use HMB; they don't have access to the host RAM in the first place because SATA doesn't expose anything equivalent. Instead, the FTL lives in NAND service blocks & the controller pulls a hot working set into on-die SRAM at boot.
An unclean shutdown produces the same class of inconsistency: a partial L2P journal write, a failed wear-leveling block, or a corrupted firmware module in the service area. The controller hits the broken metadata, fails its consistency check, & drops back to BootROM with a SATAFIRM S11 (Phison) or equivalent factory identity string (Silicon Motion, Maxio).
The visible symptom: wrong capacity (0GB, 2MB, 20MB), the controller's factory alias instead of the drive's model name in Device Manager, or a drive that spins up but refuses every standard ATA read.
Controller-Specific Failure Signatures
A panicked DRAM-less controller reports its factory ROM identity instead of the drive's model name, & the capacity it advertises is a small placeholder, not the real user volume. The exact alias string & the placeholder size differ by controller, which is the first thing the diagnostic step keys on.
The two DRAM-less NVMe controllers below show this pattern in distinct ways. A third part, the DRAM-cached InnoGrit IG5236, is listed only to disambiguate it from the DRAM-less population: it carries its own onboard DRAM, does not use Host Memory Buffer, & is out of scope for the DRAM-less / HMB mechanism described here.
Silicon Motion SM2267XT (Gen4 DRAM-less, Kingston NV2)
In ROM / safe mode the controller enumerates under its factory alias rather than the drive label, & reports a placeholder capacity instead of the real namespace size. A firmware-panicked SMI part commonly draws current but never completes NVMe enumeration until it is forced into ROM by shorting the documented test pad while cycling power. Steady-state, the part runs on a roughly 64 MB HMB allocation. The SM2267XT is supported by PC-3000 SSD, so the path is the standard NVMe DRAM-less loader injection: enter safe mode, upload the controller-matched loader, & rebuild the translator from NAND spare-area metadata.
Phison PS5013-E13T (Gen3 DRAM-less, Patriot P300)
The E13T enters firmware panic the same way the rest of the DRAM-less NVMe population does: it drops off the PCIe bus, or half-enumerates with a wrong capacity, after the HMB-resident L2P delta is lost mid-write. The PS5013-E13T is supported by PC-3000 SSD & follows the NVMe DRAM-less loader workflow already documented on this page; there is no separate procedure for it.
InnoGrit IG5236 (Rainier, Gen4 x4): DRAM-cached, out of scope
The IG5236 is a DRAM-cached Gen4 controller, not a DRAM-less part: it pairs with a dedicated onboard DRAM chip & does not use Host Memory Buffer, so the DRAM-less / HMB tear-down mechanism described on this page does not apply to it. It is included here only to keep it from being mistaken for the DRAM-less population. Confirm the controller silicon visually on the PCB before shipping.
The reason the loader has to rebuild the map from scratch on the SM2267XT & the PS5013-E13T is that neither part keeps a usable FTL copy of its own once it panics. There is no onboard DRAM holding the live L2P table, & the HMB region that was standing in for it lived in host RAM that is already gone.
PC-3000 SSD has nothing to read back from the controller, so it walks the NAND spare-area metadata directly (block sequence numbers, wear counters, page-header LBA tags) & reconstructs the translator in RAM. The map is built from what physically committed to flash, not from any cache the controller used to hold.
Why Recovery Software Fails on DRAM-less SSDs
Why Does Recovery Software Fail on DRAM-less SSDs?
Consumer recovery software fails on DRAM-less drives in firmware panic because it requires the drive to enumerate normally & present a valid logical address space before it can scan. A controller stuck in BootROM doesn't present a logical address space; it presents its factory identity string & rejects standard read commands. There is nothing for Disk Drill, EaseUS, PhotoRec, or R-Studio to address.
Disk Drill & EaseUS are fine tools for logical failures on a physically healthy drive. If you accidentally formatted a working Samsung 870 EVO, run Disk Drill first. The Recuva ladder is the right answer for recoverable user error.
They cannot help when the controller is dead, when the firmware has panicked into BootROM, or when the FTL working set has been lost to an HMB tear-down. Those are hardware & firmware failures that live below the layer software operates on.
The three layers software cannot reach
The controller layer
Software speaks ATA or NVMe to the controller. If the controller is in BootROM & refuses standard commands, software has no path to the NAND. Entering Technological / Safe Mode requires shorting hardware test points on the PCB while cycling power. There is no software-only equivalent.
The FTL layer
Even when a drive half-enumerates with 2MB or 20MB capacity, the user LBA range it exposes is the BootROM stub, not the real user volume. Software scanning that range finds nothing useful & cannot reconstruct the real L2P map.
The garbage collection layer
Worse, if the controller does partially recover & software starts scanning, the controller's background garbage collection runs against a partial FTL & can physically erase NAND blocks that still held recoverable data. Repeated power cycling of a panicked SSD compounds the problem.
The only non-destructive recovery path is to enter the controller's diagnostic mode through hardware test points, inject a volatile loader into controller RAM that bypasses the corrupted firmware, & rebuild the FTL in RAM from NAND metadata. The drive is never written to. That workflow is PC-3000 SSD; there is no consumer-grade equivalent.
PC-3000 SSD Workflow for DRAM-less Recovery
How Does PC-3000 SSD Recover a DRAM-less Drive?
PC-3000 SSD recovers DRAM-less drives by injecting a volatile microcode loader into the controller's RAM, scanning the NAND for surviving FTL metadata, & rebuilding a virtual translator entirely in RAM. The original drive's NAND is never written to during the procedure. The reconstructed LBA-mapped namespace is then imaged sector-by-sector to a target drive.
The workflow splits along the SATA / NVMe boundary because the connection hardware & the diagnostic entry mechanics differ.
SATA DRAM-less workflow (PS3111-S11, SM2259XT, MAS0902A)
  1. Identify the controller. Visual inspection of the PCB plus a PC-3000 SSD database lookup against the controller markings & NAND chip IDs. On Kingston A400 & similar drives, the controller silkscreen can vary between production runs, so the chip ID is the authoritative identifier.
  2. Connect via PC-3000 Express or Portable III. On Express with a PS3111-S11, route through PATA0 or PATA1 via a short (40cm max) IDE cable paired with an ACE Lab PATA-to-SATA adapter.
  3. Force technological mode. For the PS3111-S11, short the R/B* (Ready/Busy) pin near the R29 pad to ground using precision tweezers while cycling the power supply. Silicon Motion & Maxio controllers expose different test pads documented in the PC-3000 SSD utility. Grounding the test point halts the normal firmware load from NAND & forces BootROM execution.
  4. Confirm ROM mode. The drive should report its ROM-mode identity string (SATAFIRM S11 on Phison, vendor-specific aliases on SM & Maxio) in the ATA Identify response, typically with 0GB or 2MB capacity.
  5. Inject the loader. Launch the controller-specific PC-3000 utility & match the loader (LDR) to the controller silicon, NAND chip ID, & firmware version. PC-3000 uploads the loader into the controller's volatile RAM, replacing the corrupted on-NAND firmware path.
  6. Reverse XOR scrambling. The loader reads raw NAND pages & reverses the deterministic XOR scrambling applied at the page level.
  7. Build the virtual translator. PC-3000 scans surviving NAND metadata (block sequence numbers, wear-level counters, page header LBA tags, ECC checksums) & reconstructs the LBA-to-PBA mapping table entirely in RAM. The translator is never written back to the SSD.
  8. Extract via Data Extractor. With the virtual translator active, PC-3000 presents the file system (NTFS, exFAT, ext4) & extracts user data to a target drive. "Ignore ECC errors" handles degraded NAND blocks that fall below the controller's correction threshold.
NVMe DRAM-less workflow (PS5013-E13T, PS5019-E19, PS5021-E21T, SM2263XT)
  1. Connect via PC-3000 Portable III's M.2 adapter. The Portable III is required; UDMA-E & Express boards lack PCIe interfaces & cannot communicate with NVMe controllers at all. Active cooling is mandatory on Gen4 parts (PS5019-E19, PS5021-E21T) because sustained reads push the controller package past its thermal throttle threshold within minutes.
  2. Verify PCIe link training. A firmware-panicked drive often completes link training but fails NVMe initialization. If the drive does not appear on the PCIe bus, proceed to safe-mode entry.
  3. Force safe mode. Short the controller's safe-mode test pads on the PCB while powering on. Pad locations are controller-specific; the PS5013-E13T, PS5019-E19, PS5021-E21T, & SM2263XT each have distinct layouts documented in the PC-3000 SSD utility.
  4. Launch the controller-specific NVMe utility. Match the loader to the controller & NAND chip ID (Kioxia BiCS, Micron 3D TLC, SK hynix, Intel QLC). Kingston NV1 & Kingston NV2 require checking the actual silicon on the board, not the label, because the same SKU can ship with Phison or SMI controllers across production runs.
  5. Inject the loader. PC-3000 uploads the loader directly into the controller's volatile RAM. The loader disables background TRIM & garbage collection so the NAND state is frozen for the duration of the extraction.
  6. Bypass the lost HMB region. Because the original HMB-resident L2P cache no longer exists, PC-3000 ignores HMB entirely. The injected loader scans physical NAND spare areas for surviving block sequence numbers, wear-level counters, & page-header LBA tags, then rebuilds the L2P map into RAM from metadata that actually committed to flash.
  7. Manage thermals during extraction. On Gen4 controllers, sustained reads can drive die temperatures past 80 °C. If the controller throttles, extraction pauses & the read state may need to be re-established. Active cooling on the M.2 adapter is mandatory.
  8. Image the LBA-mapped namespace. PC-3000 Data Extractor walks the reconstructed namespace sector-by-sector & writes the recovered image to a target drive. On degraded NAND blocks, multi-pass reading with voltage threshold shifts maximizes yield from cells whose ECC headroom is exhausted.
Board-level repair when the controller itself is dead
When the failure is a shorted PMIC, a blown voltage regulator, or a dead controller IC rather than a firmware panic, the recovery path is board-level repair, not loader injection. The encryption reality applies here: modern NVMe controllers (including the PS5019-E19 with TCG Opal) bind AES-256 encryption keys to the controller's hardware fuses. A dead controller means the keys are inaccessible.
Chip-off yields ciphertext on encrypted parts & LDPC-bound raw NAND output on the rest. Recovery requires reviving the original controller, not transplanting the NAND.
We locate the failed component using a FLIR thermal camera, replace the shorted PMIC or voltage regulator with a Hakko FM-2032 microsoldering iron on an FM-203 base station, & bring the original controller back to life. Once the controller boots with functioning power rails, the encryption keys are intact & standard NVMe imaging through the loader workflow above extracts the data. SATA board repair: $450–$600. NVMe board repair: $900–$1,200.
How HMB Allocation Size Varies By Operating System
The NVMe Host Memory Buffer is not a single fixed size. The host OS driver negotiates the allocation with the drive at NVMe initialization, & each OS picks its own ceiling. The exact number matters because the controller's firmware was qualified against a specific HMB size during validation. An OS that grants more than the firmware expects can crash the drive on the spot.
Operating SystemHMB AllocationNotes
Windows 10 / Windows 11 pre-24H264 MB defaultMatches the firmware expectation on most DRAM-less Gen3 & early Gen4 drives
Windows 11 24H2Up to 200-256 MBIncreased ceiling causes BSODs & data-loss reports on WD SN770 / SN580 firmware that only handles 64 MB
Linux NVMe driver32-128 MBBounded by max_host_mem_size_mb = 128 in drivers/nvme/host/pci.c
macOSNo HMB supportDRAM-less NVMe drives in Thunderbolt enclosures run on SRAM + SLC cache only
Windows 11 24H2 HMB overallocation: the WD SN770 / SN580 case
Windows 11 24H2 raised the HMB allocation cap from the legacy 64 MB to as much as 256 MB. The WD SN770 & SN580 firmware shipping on 2TB variants was qualified against the 64 MB ceiling & cannot service a buffer larger than that.
When 24H2 grants the drive a 200 MB or 256 MB region, the firmware indexes past the end of the structures it knows how to address, corrupts its own internal state, & the drive drops off the PCIe bus or returns garbage on subsequent reads.
The fix is a firmware update, not a data recovery case. WD's 731130WD firmware revision (SN770 2TB & SanDisk Extreme M.2 2TB) and the 281050WD firmware revision (SN580 2TB) clamp the accepted HMB allocation regardless of what the OS offers; an alternative workaround is a registry DWORD under the StorNVMe driver key (HmbAllocationPolicy) that forces Windows back to the pre-24H2 64 MB ceiling.
Do not ship a SN770 or SN580 to us for this specific problem. Flash the firmware or set the registry value first; the data on NAND is intact, & the drive will mount once the OS stops overallocating the buffer.
The DRAM-less drives that do still need lab recovery after a 24H2 incident are the ones where the controller was caught mid-write when the overallocation crashed the firmware & the on-NAND FTL is now inconsistent with the writes that were in flight. That subset of cases follows the standard NVMe DRAM-less workflow earlier on this page.
macOS Thunderbolt DRAM-less NVMe behavior
macOS does not implement HMB at all. A DRAM-less NVMe drive in a Thunderbolt enclosure on a Mac runs entirely on the controller's on-die SRAM plus its SLC pseudo-cache region in NAND. Steady-state throughput drops because the controller no longer has 32-128 MB of host RAM to lean on, but the drive functions, & the macOS pattern does not produce the HMB tear-down failure mode at all because there is no HMB to tear down.
The catch is at the SRAM layer. If a DRAM-less drive is pulled mid-write from a Mac Thunderbolt enclosure, the L2P delta sitting in controller SRAM & the SLC-cached page data that has not yet folded into TLC blocks are both volatile.
The failure mode is the same SATAFIRM-class firmware panic seen on any DRAM-less drive: wrong capacity reporting on reconnect, refusal to mount, or a controller alias in System Information instead of the drive's real model name. The recovery path is identical to the Windows / Linux NVMe DRAM-less workflow: Technological Mode entry, loader injection, & virtual translator rebuild from NAND metadata.
Why DRAM-less Failures Need Board-Level Recovery
Why DRAM-less SSD Failures Need Board-Level Recovery
Can DRAM-less SSDs be recovered by software or chip-off?
No. DRAM-less SSDs cache their Flash Translation Layer in volatile host memory through HMB or in SRAM on the controller. When the drive dies, software has nothing to address. Revival of the original PCB through board-level microsoldering is the only physical path to the data.
FTL Persistence: DRAM-cached vs HMB and SRAM-only
The two designs hold the active L2P map in different places. Power loss & host disconnect treat those places very differently.
ArchitectureActive FTL LocationPower Loss BehaviorHost Disconnect Behavior
DRAM-cached SSDOnboard DDR3/DDR4 chip; full L2P map resident on the driveController mirrors L2P checkpoints to NAND on a schedule; enterprise variants ride out the cut on PLP capacitorsL2P stays resident; the drive does not depend on the host for mapping state
DRAM-less NVMe (HMB)Host RAM region (16-64 MB) shared over PCIe DMA, plus a small SRAM working set on the controllerHMB region evaporates instantly; uncommitted L2P delta is lost & on-NAND checkpoint diverges from physical write statePCIe link drop or HMB revocation tears down the active map; the controller fails consistency check on next boot
DRAM-less SATA (SRAM only)NAND service blocks; hot working set in on-die SRAMPartial L2P journal commit leaves split-brain metadata in the service area; controller drops to BootROM with SATAFIRM S11 or vendor aliasNo HMB exposure; SRAM working set is rebuilt from NAND on next power-on if the journal is intact
Why a 16-64 MB HMB Cannot Stand In for a 1 GB L2P Map
Page-level mapping at the industry-standard 4 KiB page size with a 4-byte entry produces an L2P table that is roughly 0.1% of the user capacity. A 1 TB drive needs about 1 GB of RAM to hold its complete L2P. HMB allocations granted by Windows, Linux, & macOS drivers run from 16 MB on entry Gen3 controllers to 64 MB on Gen4 parts.
The arithmetic is unkind. A 64 MB HMB region holds roughly 6.25% of a 1 TB drive's L2P map at any moment; a 16 MB region holds about 1.56%. The controller is constantly paging mapping segments between NAND service blocks & host RAM through PCIe. A power cut, BSOD, or USB-NVMe enclosure pop-out lands inside that active 1.5%-6.25% working set with high probability, & the in-flight delta is destroyed before it commits to NAND.
A DRAM-cached drive does not have this problem because the entire L2P map is local. A DRAM-less drive cannot make HMB non-volatile & cannot replay enough of the working set from a partial NAND checkpoint to reconstruct the missing delta. The mapping has to be rebuilt from the NAND's own Out-of-Band metadata in an external lab, which is what PC-3000 SSD's virtual translator does.
See the Phison architecture & Silicon Motion architecture pages for controller-family detail on how each family handles the journal under power loss.
AES Binding, the Failed Donor Swap, & the Microsoldering Path
The Media Encryption Key is generated on-die by a hardware TRNG at factory provisioning & is wrapped by a Hardware Unique Key that is physically fused into the controller's OTP eFuses. A donor controller, even an identical part number with identical firmware, has a different HUK fused into its OTP & cannot unwrap the original MEK.
Chip-off transplants of the NAND onto a donor PCB produce decryption failures, not data. The same logic rules out swapping the controller IC onto the original PCB: the keys live with the silicon, not the package.
The only path that preserves the AES key chain is to bring the original controller back to life on the original board. At the Austin lab, the workflow runs through one room of dedicated SSD board equipment:
  • FLIR thermal camera to localize the shorted PMIC, voltage regulator, or controller power rail before any sustained power is applied
  • Hakko FM-2032 on an FM-203 or FX-951 base station for precision component-level rework of capacitors, resistors, & QFN regulators
  • Atten 862 hot air rework station for safe removal of shorted PMICs & reflow of small surface-mount packages near the NAND
  • Zhuo Mao precision BGA rework station for controller reballing & full-array work when the package itself, not the power network around it, has failed
  • PC-3000 SSD on Portable III to enter Technological Mode once power is restored, inject the controller-specific loader, & reconstruct the virtual translator in RAM from NAND OOB metadata
The flagship SSD data recovery page covers the same board-repair path across the full SATA & NVMe controller matrix. DRAM-less drives are the population that needs it most, because they have no second copy of the FTL to fall back on when the controller goes down.
Related DRAM-less Reference Pages
Which Controller & Drive Pages Go Deeper?
The DRAM-less topic intersects two controller families & several drive lines. These pages cover each axis in more depth: controller-specific workflows on Phison & Silicon Motion, & drive-specific failure profiles on the Kingston A400 & ADATA budget lineup.
DRAM-less SSD Recovery Pricing
How Much Does DRAM-less SSD Recovery Cost?
DRAM-less recovery is priced by failure type & interface, not by the absence of DRAM. A SATA firmware panic on a Kingston A400 (PS3111-S11) falls in the same tier as firmware corruption on a DRAM-equipped Crucial MX500. An NVMe firmware panic on a Patriot P300 (PS5013-E13T) is priced as NVMe firmware recovery.
The two pricing axes are interface (SATA vs NVMe) & failure layer (firmware vs board vs NAND swap). No diagnostic fee, no data no recovery fee, & +$100 rush fee to move to the front of the queue.
SATA DRAM-less Recovery (Kingston A400, Crucial BX500, ADATA SU650, WD Green)
NVMe DRAM-less Recovery (Patriot P300, Kingston NV1, WD_BLACK SN750 SE, HP EX900)
DRAM-less SSD Recovery FAQ
What is HMB (Host Memory Buffer) and why does it complicate data recovery?
Host Memory Buffer is an NVMe protocol feature that lets a DRAM-less SSD controller borrow a small region of the host computer's system RAM (typically 16 MB to 64 MB) as a scratchpad for the Flash Translation Layer. The controller stores live L2P mapping deltas, write cache pointers, and lookup tables in that host RAM region instead of in dedicated DRAM on the drive. The catch: HMB is volatile. A host crash, sudden power loss, PCIe link drop, or USB enclosure disconnect tears down the HMB region instantly. Any L2P updates that were buffered but not yet committed to NAND are lost, and the on-NAND FTL ends up out of sync with the writes that were in flight. The drive then enumerates with the wrong capacity, 0GB, 2MB, or refuses to enumerate at all.
Why do recovery tools fail on Kingston A400 and similar DRAM-less SSDs?
Disk Drill, EaseUS, R-Studio, and PhotoRec require the drive to enumerate normally and present a valid logical address space before they can scan for files. A Kingston A400 in firmware panic (PS3111-S11 SATAFIRM S11 state) does not enumerate normally; the controller is stuck in BootROM and rejects standard ATA read commands. The recovery software never sees the drive's user data at all. Even on the cases where the controller half-enumerates with a 2MB or 20MB capacity, internal garbage collection running on a partially recovered FTL can destroy pending writes while software is still scanning. The recovery requires controller-level access through PC-3000 SSD Technological Mode, not file-system-level scanning.
Can software recover data from a DRAM-less SSD that shows 0GB?
No. A 0GB or 2MB capacity report means the controller failed to mount its Flash Translation Layer and is presenting its BootROM identity instead of the real user capacity. Software runs above the controller; if the controller refuses to expose the user LBA range, no software (consumer or professional) can address it. Recovery requires entering the controller's diagnostic mode through hardware test points, injecting a volatile microcode loader into controller RAM, and rebuilding the FTL externally in RAM. That is PC-3000 SSD's workflow; consumer tools have no equivalent.
How does PC-3000 SSD recover a DRAM-less NVMe drive?
The engineer connects the drive to PC-3000 Portable III's M.2 NVMe adapter with active cooling, then forces the controller into Safe Mode by shorting controller-specific test pads while cycling power. PC-3000 uploads a volatile microcode loader into the controller's RAM; the loader bypasses the corrupted on-NAND firmware and disables TRIM and garbage collection so the NAND state is frozen. PC-3000 then scans physical NAND blocks for surviving metadata (block sequence numbers, wear counters, ECC checksums, page header LBA tags) and reconstructs a virtual translator entirely in RAM. The drive is never written to. The reconstructed LBA-mapped namespace is then imaged sector-by-sector to a target drive.
Is recovery cheaper or more expensive on a DRAM-less SSD compared to a DRAM-cached one?
Pricing tracks the failure type, not the DRAM topology. A SATA DRAM-less firmware panic (Kingston A400, Crucial BX500) on the PS3111-S11 or SM2259XT falls in the SATA firmware recovery tier at $600–$1,200. An NVMe DRAM-less firmware panic (Patriot P300, Kingston NV1, WD_BLACK SN750 SE) falls in the NVMe firmware tier at $900–$1,200. Board-level repair for a dead PMIC or shorted voltage rail is $450–$600 on SATA, $900–$1,200 on NVMe. No diagnostic fee. No data, no recovery fee. +$100 rush fee to move to the front of the queue.
Can a DRAM-less SSD be recovered?
Yes for most cases, with one important exception. The dominant DRAM-less failure mode is a firmware panic after a power cut, BSOD, or HMB tear-down on a controller PC-3000 SSD supports: Phison PS3111-S11, PS5013-E13T, PS5019-E19, Silicon Motion SM2259XT, SM2263XT, SM2269XT, & Maxio MAS0902 / MAS0902A (excluding specific SanDisk, some Toshiba, & some YMTC NAND configurations that ACELab marks as unsupported) recover through Technological Mode loader injection & virtual translator rebuild at the NVMe firmware tier of $900–$1,200 or SATA firmware tier of $600–$1,200. The exception: drives built on the Realtek RTS5763DL (ADATA Swordfish, XPG SX6000 family, some Kingston NV1 batches) are outside PC-3000 SSD's loader library; Rossmann does not currently offer in-lab recovery for Realtek RTS5763DL.
Phison E13T data recovery: what is the workflow?
The Phison PS5013-E13T is a DRAM-less Gen3 NVMe controller used in the Patriot P300, some Kingston NV1 production runs, & assorted OEM 2280 modules. The PS5013-E13T is supported by PC-3000 SSD, so the recovery path is the standard NVMe DRAM-less workflow: connect through PC-3000 Portable III's M.2 adapter with active cooling, force safe mode by shorting the controller-specific test pads while powering on, inject the volatile loader matched to the controller revision & NAND chip ID, ignore the lost HMB region, & rebuild the L2P map in RAM from NAND spare-area metadata (block sequence numbers, wear counters, page-header LBA tags). The reconstructed namespace is then imaged sector-by-sector. Pricing falls in the NVMe firmware tier at $900–$1,200; board-level PMIC repair, if needed, is $900–$1,200.
Why does my NVMe SSD show up as 1GB or 2GB in safe mode?
A DRAM-less NVMe controller that has panicked drops back to its factory ROM identity & advertises a small placeholder capacity instead of the real namespace. The controller is reporting its ROM stub, not the user volume, because it could not mount the Flash Translation Layer after losing the HMB-resident L2P state. The capacity number is a symptom, not a measure of surviving data. Note that not every wrong-capacity NVMe drive is DRAM-less: the InnoGrit IG5236 is typically deployed as a DRAM-cached Gen4 controller, and a DRAM-equipped IG5236 does not rely on Host Memory Buffer, so that configuration is out of scope for this DRAM-less mechanism.
What is HMB SSD failure & why does Windows 11 24H2 crash some DRAM-less drives?
HMB SSD failure is the class of failure where a DRAM-less NVMe drive loses the Host Memory Buffer region it was relying on as its primary L2P cache, & the on-NAND FTL ends up out of sync with writes that were in flight. Windows 11 24H2 added a specific variant of this problem: it raised the HMB allocation ceiling from the legacy 64 MB up to 200-256 MB. The WD SN770 & SN580 firmware shipping on 2TB variants was qualified at the 64 MB ceiling & cannot service a larger buffer; when 24H2 hands the drive a 200 MB region, the controller corrupts its own internal state & the drive drops off the PCIe bus. This specific case is a firmware-update fix, not a data recovery case. WD's 731130WD firmware (for the SN770 2TB and SanDisk Extreme M.2 2TB) and 281050WD firmware (for the SN580 2TB) clamp the accepted HMB size; a registry DWORD (HmbAllocationPolicy under the StorNVMe driver key) forces Windows back to the pre-24H2 ceiling. The NAND content is intact in this scenario; flash the firmware or set the registry, & the drive mounts.
Why Trust Rossmann for DRAM-less SSD Recovery?
DRAM-less SSD recovery combines firmware diagnostics, FTL reconstruction in RAM, & board-level repair when the failure is a dead PMIC or shorted voltage rail. Our single Austin, TX lab handles these recoveries in-house with PC-3000 SSD, FLIR thermal cameras, Hakko FM-2032 microsoldering irons, Atten 862 hot air, & Zhuo Mao BGA rework equipment.
Single Austin Lab
All DRAM-less SSD work is performed at 2410 San Antonio Street in Austin, TX. Nationwide jobs arrive by mail-in service; no franchises, no satellite benches, no outsourced SSD board repairs.
No Diagnostic Fee
Founded in 2008. We diagnose the SSD before quoting the SATA or NVMe tier. If there is no recovered data, there is no recovery fee. That matters when a DRAM-less drive has a PMIC fault, a controller swap silently changed the recovery profile, or HMB tear-down corrupted the journal.
Published SSD Pricing
SATA recovery uses 5 published tiers, $200–$1,500. NVMe recovery uses 5 published tiers, $200–$2,500.
Controller-Aware Workflow
Kingston NV1, Kingston NV2, Crucial P3, & many OEM rebrands silently swap controllers between production runs. Our diagnostic step identifies the actual silicon & matches the correct PC-3000 SSD loader profile before any recovery attempt.
DRAM-less SSD not detected, showing 0GB, or stuck in firmware panic?
Free evaluation. SATA firmware recovery from $600–$1,200. NVMe recovery from $900–$1,200. No data, no fee.
