What Is the SATAFIRM S11 Error?
SATAFIRM S11 is the factory firmware identity string of the Phison PS3111-S11 controller. When the controller's Flash Translation Layer corrupts beyond its self-repair threshold, the controller falls back to ROM MODE and reports this factory identity instead of "Kingston A400" or whatever brand was programmed into the firmware.
The Phison PS3111-S11 is a budget, DRAM-less SATA controller. It stores its entire Flash Translation Layer on the same TLC NAND that holds user data. When the NAND pages storing the FTL degrade (from wear, power loss during writes, or bad block table overflow), the controller cannot boot its firmware normally. It enters ROM MODE: a minimal state where it responds to basic vendor commands but cannot access user data.
In BIOS or Disk Management, the drive appears as "SATAFIRM S11" with 0 bytes capacity (or a small placeholder like 2MB). The OS cannot interact with it. Recovery software cannot scan it. The data remains physically stored on the NAND cells, but the mapping table that tells the controller where each file is located has been lost or corrupted. At this point the drive needs professional SSD data recovery, not a software scanner.
Why DIY Firmware Flashing Destroys Your Data
Forum guides on Elektroda.pl, Reddit, and YouTube recommend using PhisonToolBox, UPTOOL, or MPTools to reflash the controller firmware. These tools are manufacturing utilities designed for blank drives. Running them on a drive with data permanently overwrites the Flash Translation Layer, bad block tables, and wear-leveling metadata stored on the NAND.
Manufacturing tools write a fresh firmware image to the NAND service area. This fresh image includes a blank FTL with no entries, a reset bad block table, and default configuration parameters. The old FTL, which contained the logical-to-physical mapping for every file on the drive, is overwritten. Without that mapping, the raw NAND data becomes an unsorted pile of pages with no directory structure, no file boundaries, and no sequence information.
ROM-pin-shorting (connecting specific controller pins to force ROM MODE entry for flashing) is a prerequisite step in many of these guides. The pin-shorting itself does not destroy data, but the firmware flash that follows does. Some guides also recommend "initializing" the drive after flashing, which performs a full NAND erase.
For a detailed technical breakdown of the SATAFIRM S11 failure mechanism and why these tools are destructive, see our SATAFIRM S11 Phison firmware guide.
How We Recover Data from Kingston A400 Drives
The PC-3000 SSD system with the Phison utility communicates with the PS3111-S11 controller in ROM MODE. Instead of flashing firmware to NAND, it injects a temporary loader into the controller's RAM. This loader boots the controller enough to access NAND without touching the service area.
- 01
Identify controller revision and NAND configuration
The Kingston A400 ships with multiple NAND vendors (Toshiba/Kioxia, Micron, SKHynix) depending on manufacturing batch. The PC-3000 SSD Phison Utility reads the NAND ID to determine the exact flash type, page size, block size, and ECC configuration. This determines which loader profile to use.
- 02
Inject firmware loader into controller RAM
PC-3000 sends vendor-specific commands to load a minimal firmware image into the controller's volatile RAM. This image is NOT written to NAND. It runs entirely in RAM and is lost when the drive is powered off. The loader gives the controller enough functionality to read NAND pages and respond to diagnostic commands.
- 03
Reconstruct the Flash Translation Layer
PC-3000 reads the NAND pages that contained the FTL and related metadata (page headers, block sequence numbers, wear-level counters). From these fragments, it reconstructs a virtual FTL in software. This virtual map restores the logical-to-physical mapping without writing anything to the NAND.
- 04
Image the drive and verify files
With the virtual FTL active, the drive presents its original capacity and file system. We image every sector to a known-good destination drive. Files are verified against the reconstructed directory structure and delivered on your return media via mail-in service.
Which Other SSDs Use the Phison PS3111-S11?
The Phison PS3111-S11 is one of the most widely used budget SATA controllers. Dozens of brands ship it as identical silicon under different firmware branding.
- Kingston A400
- 120GB and 240GB models predominantly use PS3111-S11. Higher capacities (480GB, 960GB) may use Silicon Motion SM2258XT instead. Reports as SATAFIRM S11 on failure when PS3111-S11 is present.
- PNY CS900
- Budget SATA SSD with the same PS3111-S11 controller. Same SATAFIRM S11 failure mode and same recovery procedure.
- Patriot Burst
- Another PS3111-S11 drive sold at the budget tier. Patriot firmware branding is replaced by SATAFIRM S11 on failure.
Other drives using the PS3111-S11 include the Goodram CX400 and various OEM SSDs sold under dozens of smaller brand labels. The recovery procedure is identical across all of them because the controller architecture is the same. See our SSD controller directory for the full list.
How Much Does Kingston A400 Recovery Cost?
Kingston A400 firmware recovery (SATAFIRM S11): $600–$1,200. If the controller also has electrical damage requiring board repair: $450–$600. Free evaluation, firm quote before any paid work, no data = no charge.
The PS3111-S11 is a DRAM-less controller, which simplifies the FTL reconstruction process compared to DRAM-cached controllers. Most Kingston A400 cases fall into the firmware recovery tier. Board-level repair is needed only when the controller has additional electrical damage from power surges or physical trauma.
Board repair ($450–$600) sometimes requires a donor Kingston A400 for replacement components. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers. We quote the donor cost separately so you know what you're paying for before any work starts.
Rush service: +$100 rush fee to move to the front of the queue. Call (512) 212-9111 for a free evaluation.
When Recovery Software Works on a Kingston A400
Recovery software works when the Kingston A400 is physically healthy and recognized by the operating system. Tools like Disk Drill, EaseUS, PhotoRec, & R-Studio can scan for deleted files, corrupted partitions, or formatted volumes on a functioning drive. Once the controller is dead or stuck in ROM MODE, software can't communicate with the NAND at all.
Logical failures on a working Kingston A400 are genuine software territory. Accidental deletion, partition table corruption, or a quick format that left the file data intact can be recovered without opening the drive or touching the controller. The catch is TRIM. On Windows 7+, TRIM is enabled by default; macOS enables it only for Apple-shipped SSDs unless trimforce is run. When you delete a file, the OS tells the PS3111-S11 controller those blocks are free. The controller immediately unmaps these logical addresses, returning zeroes to any software read request through Deterministic Read Zero after TRIM, and schedules the blocks for physical erasure during background garbage collection.
SATAFIRM S11 is not a logical failure. The controller itself has crashed. No USB adapter, no SATA dock, & no software tool can read a drive in ROM MODE. At that point, the recovery requires a PC-3000 SSD with the Phison Utility to inject firmware into RAM & rebuild the FTL without touching NAND. This is a lab procedure, not a software procedure.
PS3111-S11 Controller Internals & Recovery Workflow
The Phison PS3111-S11 is a DRAM-less SATA 6 Gbps controller that stores its Flash Translation Layer on the same NAND chips as user data. This architecture trades durability for cost, making the A400 one of the cheapest SSDs on the market but also one of the most failure-prone in the budget SATA segment.
SRAM Architecture & FTL Boot Process
Controllers like the Samsung 860 EVO's MJX use external LPDDR4 DRAM to cache the full FTL in volatile memory, with periodic flushes to NAND. The PS3111-S11 has no external DRAM. It uses a small pool of internal SRAM to hold the active portion of the FTL. On every power-up, the controller reads FTL data from the NAND Service Area into SRAM before it can translate logical block addresses to physical NAND pages.
A power loss during SRAM-to-NAND flush corrupts the Service Area copy of the FTL. The controller detects the corruption on next boot, can't build a coherent address map, & falls into ROM MODE. DRAM-cached controllers handle this better because the full FTL exists in volatile RAM during operation; NAND flushes are less frequent & use journaling structures that survive partial writes. The PS3111-S11 has no such safety net.
NAND Configuration Detection & CE Line Mapping
The PS3111-S11 addresses multiple NAND dies across parallel channels. Before any data extraction, the PC-3000 SSD Phison Utility must detect which CE lines are active, how many dies are present, & the geometry of each die: page size (4KB, 8KB, or 16KB depending on the NAND generation), block size, & pages per block.
Kingston doesn't guarantee a specific NAND vendor. One batch of A400 240GB drives ships with Toshiba/Kioxia BiCS3 TLC; the next uses Micron 64-layer 3D TLC; another uses SKHynix TLC. The PC-3000 reads the NAND ID bytes (manufacturer code, die configuration, cell type) from each CE line & loads the matching configuration profile. A wrong profile means incorrect page addressing, scrambled reads, & failed FTL reconstruction. Correct NAND identification is the first step, & there is no shortcut.
LDPC Error Correction & Why Chip-Off Fails
The PS3111-S11 uses LDPC (Low-Density Parity-Check) error correction, not the older BCH codes found in earlier-generation controllers. LDPC is a probabilistic, soft-decision decoding scheme. When NAND cells degrade from program/erase cycles, the controller doesn't just read a 1 or 0; it reads a voltage probability distribution across each cell's threshold window & uses iterative LDPC decoding to determine the most likely bit value.
This matters for recovery because chip-off NAND extraction on PS3111-S11 drives produces unusable results in most cases. Desoldering the NAND & reading it on a standalone reader yields raw pages with uncorrectable bit errors. The standalone reader can't replicate the controller's specific LDPC decode parameters, voltage threshold shifting, or read-retry sequences. LDPC decoding on degraded TLC NAND requires the original controller's firmware to calibrate the voltage windows. Without it, the bit error rate exceeds the correction threshold.
On top of the ECC barrier, the PS3111-S11 uses hardware data scrambling. NAND pages are XOR-scrambled with a controller-specific polynomial to reduce cell-to-cell charge coupling effects. Chip-off reads without the correct descrambling polynomial produce data that looks like random noise even before ECC correction enters the picture.
FTL Virtual Reconstruction in PC-3000
After the loader boots the controller, the PC-3000 SSD Phison Utility scans the NAND pages that stored the FTL & related metadata. It reads block sequence numbers, page headers, & wear-level counters from surviving metadata pages. From these fragments, PC-3000 builds a virtual LBA-to-PBA (logical block address to physical block address) mapping table entirely in RAM on the drive itself.
This virtual FTL is not written back to NAND. It exists only in the PC-3000's host RAM during the session. If the FTL metadata is partially degraded (common on Kingston A400 drives with high write amplification from years of use), reconstruction is partial. PC-3000 flags unmappable regions, & the resulting image requires file-by-file verification to determine which files are intact & which have corrupted sectors.
The Phison PS3111-S11 controller page covers additional FTL recovery scenarios including bad block table overflow, where the controller runs out of spare blocks & can't relocate failing pages. That overflow condition causes a different FTL corruption pattern than power-loss corruption, & the PC-3000 reconstruction procedure differs for each.
NAND Read Stability on Degraded Cells
TLC NAND stores 3 bits per cell across 8 voltage states. As cells accumulate program/erase cycles, the voltage windows narrow & charge leakage between states increases. Sustained write loads (security cameras, swap partitions, database journals) consume that budget fastest. Read disturb errors accumulate & the controller's LDPC engine struggles to correct pages on the first pass.
During extraction, the PC-3000 SSD Phison Utility performs multiple read retries with shifted voltage thresholds to improve the read accuracy on degraded cells. This process adds time but can recover pages that would otherwise return uncorrectable errors.
Electrical Failure Diagnosis & Board-Level Repair
Not every dead Kingston A400 is a firmware problem. When the drive isn't detected in BIOS at all, the failure is often electrical: a shorted PMIC, a failed voltage regulator, or a blown capacitor on the 3.3V rail. The PS3111-S11 controller draws power from an on-board power management IC, & a surge from a cheap power supply or a USB adapter with unstable voltage can kill the PMIC while leaving the NAND & controller silicon intact.
Diagnosis starts with FLIR thermal imaging. We power the board briefly & scan for hot spots that indicate a shorted component drawing excess current. Once the fault is localized, component-level replacement uses a Hakko FM-2032 iron on an FM-203 base station for precision soldering of 0402-size passives & QFN-packaged PMICs. If the PMIC package is damaged beyond rework, we source a replacement from a donor Kingston A400 PCB.
The PS3111-S11 uses hardware data scrambling (XOR) to break up the repetitive bit patterns that cause electrical interference and uneven wear across adjacent NAND pages. Chip-off recovery remains impractical: reading desoldered NAND yields scrambled data that requires the correct XOR descrambling polynomial and advanced LDPC error correction to reconstruct. Reviving the original controller through PMIC or voltage regulator replacement allows the controller's native LDPC engine and descrambling logic to read the degraded NAND directly. Board repair is not an alternative to data recovery on modern solid-state media; repairing the original power delivery circuit to revive the controller is often the only reliable path to access the data.
SATAFIRM Panic Triggers Beyond Power Loss
Power loss during an FTL flush is the most common cause, but not the only one. The PS3111-S11 firmware maintains journal indices, erase counters, and bad block counters across NAND service-area pages. When the controller's integrity check on the next boot cannot validate that metadata, it falls into ROM MODE rather than risk writing further damage to the FTL. The drive enumerates as SATAFIRM S11 with no logical capacity even though the user data pages are physically intact. This firmware-bug failure mode is a textbook case for controller-level SSD recovery, where the PC-3000 loader bypasses the corrupted firmware to read the intact NAND directly.
Bad block table overflow produces the same surface presentation. The PS3111-S11 reserves a fixed pool of spare blocks for retiring worn pages. When the spare pool exhausts (typical on Kingston A400 drives used as system swap, video surveillance storage, or database journal targets), the next bad page has nowhere to relocate and the firmware halts. From the host side this is indistinguishable from power-loss corruption: SATAFIRM S11, zero capacity, no read response.
PC-3000 Technological Mode and the Original Firmware Bundle
PC-3000 calls its full-diagnostic state Technological Mode (TECH MODE in the PC-3000 menus). It is distinct from ROM MODE: ROM MODE is the controller's fallback after FTL corruption and exposes only a minimal vendor command set, while TECH MODE is a full-diagnostic state entered by injecting a Phison Loader (LDR) microprogram matching the controller revision and NAND configuration into the PS3111-S11's RAM. The loader runs entirely in volatile memory and is discarded at power-off; nothing is written to the NAND service area, so the corrupted FTL stays intact for forensic reconstruction.
Once TECH MODE is active, PC-3000 issues vendor commands to read NAND pages by physical block and page address rather than logical block address. The original FTL metadata pages, journal entries, and translator backup copies are pulled from the service area into the host PC. The translator is then assembled in RAM on the drive itself, mapped onto the LBA range, and the user data is imaged to the destination drive. The difference between this workflow and the PhisonToolBox or MPTools manufacturing path is that the manufacturing tools write a fresh blank FTL to the same service area pages PC-3000 reads from; once those pages are overwritten, the translator cannot be reconstructed by any tool.
RZAT Interaction with FTL Reconstruction: What Comes Back, What Stays Zero
Customers occasionally assume that once PC-3000 rebuilds the FTL, every byte ever written to the drive becomes accessible. This is incorrect. Deterministic Read Zero after TRIM operates at the LBA mapping layer, not the NAND physical layer. When the host OS issues a TRIM command, the PS3111-S11 marks the affected LBA range as unmapped in the FTL itself. The physical NAND pages may still hold user data for some time before garbage collection erases them, but the FTL contains an explicit unmapped flag for those LBAs.
A logical read of an LBA the FTL marks as unmapped returns zeros. Whether the stale physical page behind it is still reachable before garbage collection erases it is a separate question, and not one anyone should promise either way. See TRIM and RZAT physics for the controller-level mechanics.
The practical implications: files that existed on the drive at the moment the controller fell into ROM MODE, and were not deleted before the failure, are recoverable through PC-3000 FTL reconstruction. Files deleted before the failure on a TRIM-enabled OS (Windows 7 or later, macOS with an Apple-shipped SSD or trimforce, modern Linux with fstrim or discard mount option) are not. The deletion-then-failure ordering is what determines recoverability, not the failure event itself. This also explains why a Kingston A400 used as a snapshot or scratch volume often returns less data than the customer expects; the volume has been TRIMming continuously throughout its operational life. The Phison controller architecture page covers the full TRIM-to-FTL command path for the PS3111-S11 and adjacent Phison SATA controllers.
Kingston A400 Controller Variants: Not Every A400 Uses the Same Chip
Kingston swaps controllers between production batches depending on NAND flash pricing and supply chain availability. A Kingston A400 purchased in 2019 may contain entirely different silicon than one purchased in 2024. The 120GB and 240GB models predominantly use the Phison PS3111-S11. The 480GB and 960GB models frequently use the Silicon Motion SM2258XT or SM2259XT instead.
This matters for data recovery because the Phison and Silicon Motion controllers use different firmware architectures, different FTL structures, and different diagnostic modes. The PC-3000 SSD uses separate utility modules for each controller family. Running the Phison utility on a Silicon Motion drive produces no result; running the Silicon Motion utility on a Phison drive does the same. Identifying the controller is the first step before any recovery work begins.
- 120GB / 240GB Models
- Predominantly Phison PS3111-S11 paired with Toshiba/Kioxia 15nm planar TLC or early Micron 3D TLC. These are the drives most likely to show the SATAFIRM S11 error on failure. Recovery uses the PC-3000 Phison utility.
- 480GB / 960GB Models
- Highly variable. These capacities frequently use the Silicon Motion SM2258XT or SM2259XT paired with 64-layer or 128-layer NAND from Micron, Kioxia, or YMTC. Both are DRAM-less parts from a different controller family, and both are recovered on the Silicon Motion utility rather than the Phison one.
How to Identify Which Controller Your Kingston A400 Uses
Two methods identify the controller before any recovery work starts: visual inspection of the PCB and SMART attribute analysis. Visual inspection requires opening the plastic enclosure. SMART analysis works through software when the drive is at least partially detected.
Visual PCB Identification
The Phison PS3111-S11 appears as a small, square chip bearing the Phison logo with a PS3111-S11 marking, or the Kingston-rebranded code "CP33238B." A Silicon Motion part carries the SMI logo instead.
SMART Attribute Identification
If the drive is partially functional or detectable in diagnostic software (CrystalDiskInfo, Hard Disk Sentinel), firmware strings and SMART data distinguish the controller without opening the enclosure.
| Diagnostic Marker | Phison PS3111-S11 | Silicon Motion SM2258XT |
| Firmware String | SBFK prefix (e.g., SBFKB1D1) | Not established |
| Failure Identity | Drive name changes to "SATAFIRM S11" with 0 bytes (or 2MB/20MB placeholder) | Drive disappears from BIOS entirely or hangs the bus |
| Capacity on Failure | 0 bytes, 2MB, or 20MB placeholder | 0 bytes, a BSY hang, or not detected |
The existing PS3111-S11 technical section covers Phison-specific recovery in detail. The sections below cover the SM2258XT workflow.
SM2258XT Failure Modes: BSY State, Wrong Capacity, and Read-Only Lockup
The Silicon Motion SM2258XT does not produce the "SATAFIRM S11" error string. Its firmware corruption manifests through three distinct failure presentations, each requiring the PC-3000 SSD Silicon Motion Utility for diagnosis and recovery.
Keep BSY (Busy) State
The SM2258XT briefly identifies to the SATA port, then the ATA status register locks into a permanent BSY (Busy) state. The internal firmware is trapped in an infinite loop attempting to read corrupted bad block tables or heavily degraded NAND sectors. The operating system hangs on boot or fails to recognize the drive entirely.
Wrong Capacity Reporting
In cases of partial firmware corruption, the SM2258XT boots into a diagnostic mode but misreports its geometry. The drive responds to basic ATA commands, while corrupted firmware metadata in the NAND service area feeds incorrect geometry parameters to the host. Attempting to initialize or format the drive in this state overwrites the remaining valid metadata.
Read-Only Lockup with SATA Bus Dropout
The SM2258XT remains functional but drops off the SATA bus when hitting sectors backed by degraded NAND cells. The drive appears healthy until the OS reads a bad region; the controller locks up and requires a hard power cycle to respond again. Writes may appear to succeed in the OS buffer but fail to persist in the NAND after a reboot. Running CHKDSK accelerates the failure by forcing additional writes to a controller that cannot reliably program cells.
All three failure modes require the PC-3000 SSD with the Silicon Motion Utility. SSD data recovery software cannot communicate with a drive in BSY state, cannot repair corrupted firmware metadata, and cannot image a drive that drops off the bus mid-read.
PC-3000 SSD Silicon Motion Utility: SM2258XT Recovery Workflow
Recovering a Kingston A400 with an SM2258XT controller requires the PC-3000 Silicon Motion Utility, not the Phison Utility. The utility differs and the loader library differs, and the loader still has to match the controller variant and the NAND configuration read off the bare silicon.
- 01
Force the controller into safe mode
The controller is forced into its diagnostic safe mode by shorting documented pads while power is applied. The pads differ per controller and per board, so the step is done against ACE Lab's published safe-mode contact-point documentation rather than by guessing.
- 02
NAND ID read and loader matching
The Silicon Motion utility reads the raw Flash ID from each NAND die. The technician selects a loader that matches both the controller variant (SM2258XT vs SM2259XT) and the NAND configuration. Uploading the wrong loader produces ECC reading errors because each NAND type requires different page geometry, timing parameters, and voltage threshold settings.
- 03
Read the service-area firmware metadata
The PC-3000 reads the drive's firmware metadata out of the NAND service area: identity, geometry, and the pointers into the FTL structures. Corruption in that metadata is what produces the wrong-capacity presentation described above.
- 04
Virtual translator build
The PC-3000 builds the virtual FTL translator in RAM on the drive itself. On SM2258XT drives with degraded TLC or QLC NAND, this process involves extensive read-retry operations with shifted voltage thresholds across every NAND die. The resulting image requires file-by-file verification to identify sectors with uncorrectable errors.
Firmware recovery for both Phison and Silicon Motion variants of the Kingston A400 costs $600–$1,200. The pricing is identical because the labor intensity is comparable, despite the different tooling. +$100 rush fee to move to the front of the queue. For cases that escalate past firmware reconstruction into PMIC replacement or NAND-level workflows, see the full board repair and chip-off NAND recovery scope on the flagship page.
Does Chip-Off Recover a Kingston A400 with a Dead Controller?
The Kingston A400 SM2258XT uses XOR data scrambling, not AES-256 encryption. That does not make chip-off a practical recovery path. On this LDPC-era TLC family, a standalone NAND reader cannot do the soft-decision decoding the original controller does, which is the same barrier described in the Phison section above.
XOR scrambling exists to break up patterned data (long strings of zeroes) that would otherwise cause electrical interference and uneven wear across adjacent NAND pages. The SM2258XT applies an XOR polynomial to pseudo-randomize data before writing it to NAND. Because XOR is a predictable mathematical operation, not cryptographic encryption, it is reversible when the controller's polynomial is known.
Reversing the scrambling is not the hard part. Chip-off recovery on degraded TLC runs into LDPC error correction: the raw pages come back with bit error rates that only the original controller's read-retry and voltage-threshold logic can pull back inside the correction margin.
Board-level repair to revive the original controller ($450–$600) is the path on both controller variants, because the controller's own LDPC engine and descrambling logic read the degraded NAND directly. Where the original PCB is too damaged to bring back, NAND swap pricing ($1,200–$1,500) applies. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers.
Phison vs Silicon Motion: Which Controller Is in Your A400
Kingston ships the A400 as a single SKU but the silicon inside changes between production batches. Identifying the controller branch before any recovery work is the difference between a clean FTL reconstruction and a wasted loader injection. Three signals identify the controller without opening the enclosure, and the PCB confirms it.
The Phison PS3111-S11 is a DRAM-less SATA 6 Gbps controller, most often paired with Toshiba/Kioxia 15nm planar TLC or early Micron 3D TLC. The Silicon Motion SM2258XT is a DRAM-less controller from a different family, typically paired with 64-layer or 128-layer NAND from Micron, Kioxia, or YMTC. Which family is fitted decides which PC-3000 SSD utility module the recovery runs on.
Capacity heuristic (first-pass guess)
120GB and 240GB A400 drives are predominantly Phison PS3111-S11. 480GB and 960GB drives split roughly across both controller families with Silicon Motion appearing more frequently. Capacity is a first-pass guess, never a final identification, because Kingston has shipped both families at 240GB and 480GB during overlapping production windows.
Firmware revision string (most reliable)
The firmware revision printed on the drive sticker or reported by CrystalDiskInfo and smartctl is the most reliable non-invasive identifier. Phison-based A400s are seen with SBFK-prefix firmware revisions, SBFKB1D1 among them.
Failure identity string (post-mortem)
Once the drive has failed, the identity string itself names the controller. SATAFIRM S11 is the hardcoded ROM-mode identity baked into Phison PS3111-S11 silicon; if the drive enumerates with that string, the controller is Phison. A Silicon Motion variant in a comparable failure state instead hangs the SATA bus in BSY, disappears from BIOS entirely, or reports a generic passport with placeholder capacity.
PCB markings confirm the controller
With the case open, the controller die is laser-etched. The Phison part carries a PS3111-S11 marking, sometimes Kingston-rebranded as CP33238B. A Silicon Motion part carries the SMI logo instead. NAND vendor and generation vary by production batch and are confirmed by reading the Flash ID on the bench, not by reading the label.
| Identification Signal | Phison PS3111-S11 | Silicon Motion SM2258XT / SM2259XT |
| Architecture | DRAM-less | DRAM-less |
| Predominant capacities | 120GB, 240GB | 480GB, 960GB |
| Firmware string prefix | SBFK prefix (e.g., SBFKB1D1) | Not established |
| PCB die marking | PS3111-S11 or CP33238B (Kingston rebrand) | SMI logo |
| Failure identity | SATAFIRM S11, 0/2MB/20MB capacity | ATA BSY hang, BIOS disappearance, generic SM passport ID |
| PC-3000 utility module | PC-3000 SSD Phison Utility | PC-3000 SSD Silicon Motion Utility |
DRAM-less SATA Architecture and FTL Wear Characteristics
The Kingston A400 has no DRAM chip and cannot use Host Memory Buffer because HMB is an NVMe-only protocol feature. The Phison PS3111-S11 holds only the active portion of its Flash Translation Layer in internal controller memory, constantly streaming FTL fragments back and forth to the NAND service area. That streaming is the root cause of elevated write amplification and accelerated service-area wear on this drive family.
HMB does not apply to SATA
Host Memory Buffer is an NVMe feature defined in the NVMe 1.2 specification. It relies on the PCIe interface to let a DRAM-less NVMe controller carve out a small block of host system RAM and use it as an external FTL cache. The SATA protocol has no equivalent. SATA is a storage transport layered on top of AHCI, not a memory bus, and the host cannot expose RAM to a SATA device. The Kingston A400 is a SATA drive, so HMB is not available regardless of which controller is fitted. Articles and forum posts that suggest enabling HMB to stabilize an A400 are conflating SATA and NVMe architectures.
Internal controller memory cannot hold the whole FTL
The PS3111-S11 has no external DRAM. Its internal memory carries in-flight data and the active FTL fragments, nothing close to the whole table. The controller therefore loads small FTL segments from the service area on demand, services the host request, then flushes dirty segments back to the service area when cache pressure forces an eviction. It is a workaround for the missing external DRAM, not an architectural equivalent.
Write amplification consequences
Every host write that crosses an FTL segment boundary forces the controller to read the affected segment from NAND, modify it in the SDRAM cache, and write the updated segment back to a fresh service-area page. A single 4KB user write can produce several NAND page writes worth of FTL metadata churn on top of the user data write itself. Compared with a DRAM-cached drive that journals FTL updates and flushes the cache periodically in large batches, the A400 writes far more bytes to NAND per byte of host data. That ratio of NAND writes to host writes is the write amplification factor.
Why the service area dies first
The pages that get written most often on a DRAM-less SATA controller are the service-area pages that hold the FTL segments themselves. Every one of those flushes hits the same pool of reserved blocks. Those blocks accumulate program/erase cycles faster than user-data blocks, which means the service area exhausts its endurance budget while the user-data NAND still has cycles left. When LDPC error correction can no longer recover a service-area page, the controller cannot read the FTL on its next boot, and it falls into SATAFIRM S11 ROM mode on the Phison variant or hangs the ATA bus in BSY on the Silicon Motion variant. The user data is still readable; the map to find it is gone. That asymmetry is why the A400 fails with FTL-level symptoms far more often than with end-of-life NAND wear-out.
Why power loss is so destructive
On a DRAM-cached drive the FTL lives in volatile DRAM during operation and only flushes to NAND on a schedule, protected by a journaling structure that survives partial writes. On the A400 the FTL is being read out of and written back to NAND constantly. A power loss during the few microseconds the controller is mid-write to a service-area page leaves that page partially programmed. The integrity check on the next boot rejects the page, and there is no full secondary copy in a dedicated DRAM cache to fall back to. The drive enumerates as SATAFIRM S11 even though the previous power-off cycle wrote no user data at all.
A400 SMART Attributes That Predict Failure
The subset of A400 SMART data that matters for recovery prediction is narrow: a handful of NAND-health counters and a remaining-life normalized value. Read these from a partially detectable drive in CrystalDiskInfo or smartctl before sending it for recovery; once the controller drops into ROM MODE or BSY, SMART is no longer reachable.
| Hex ID | Decimal | Attribute Name | Phison / SMI Semantics | Recovery Relevance |
| 0x05 | 5 | Reallocated Sector Count | Count of page or block reallocations caused by program or read failures. | High values suggest the bad block table is approaching overflow; precursor to SATAFIRM S11 on Phison and BSY hang on Silicon Motion. |
| 0x09 | 9 | Power On Hours | Cumulative power-on hours including idle. | Establishes drive age; cross-reference with 0xF1 and 0xE7 to estimate remaining endurance. |
| 0x0C | 12 | Power Cycle Count | Cumulative power-on or power-off events, including unsafe shutdowns. | Establishes how often the drive has been through a power transition. Power loss during an FTL flush is what corrupts the service-area metadata. |
| 0xAB | 171 | Program Fail Count | Number of NAND program (write) failures over the life of the drive. | A rising count signals TLC or QLC cells rejecting new charge states; predicts BSY hangs on SM2258XT. |
| 0xAC | 172 | Erase Fail Count | Number of NAND erase failures during garbage collection. | When blocks cannot be erased, the Silicon Motion controller frequently locks in BSY; the Phison controller forces a service-area rewrite that accelerates FTL corruption. |
| 0xB5 | 181 | Program Fail Count (alt ID) | Alternate attribute ID used by some A400 firmware revisions to record NAND program failures. | Read alongside 0xAB; some firmware reports both, some reports only one. Either climbing is a NAND-wear signal. |
| 0xBB | 187 | Reported Uncorrectable Errors | ECC errors the LDPC engine could not mathematically correct. | The single most predictive attribute. Any non-zero value means uncorrectable reads have already happened; if they land in the service area, ROM MODE follows on the next boot. |
| 0xC2 | 194 | Temperature | Internal drive temperature in Celsius. | Sustained operation above the controller's rated thermal envelope accelerates charge leakage in TLC cells and raises uncorrectable error counts. |
| 0xC7 | 199 | UDMA CRC Error Count | CRC errors on the SATA interface layer. | Points to cable, connector, or PHY problems rather than NAND death. Rule this out before diagnosing the controller. |
| 0xE7 | 231 | SSD Life Left | Normalized remaining-life value derived from average erase count against the NAND rated P/E cycle budget. | A falling value means the drive is working through its rated endurance. Image it before the failure rather than after. |
| 0xF1 | 241 | Host Writes (GB) | Total host-side writes in gigabytes. | Establishes the cumulative host write load the drive has served. |
Rising error counters on a drive whose SSD Life Left is falling are the signal to stop using it, pull power, and image it through a known SATA controller (not through a cheap USB-to-SATA adapter that may issue TRIM or extra writes during enumeration). SMART by itself does not stop a failure; it tells you the failure window has opened.
How the Phison Utility Recovers a SATAFIRM S11 Drive on PC-3000 SSD
SATAFIRM S11 is a controller-level firmware panic, not a media failure. The user data is still resident on the NAND dies. What is missing is the Flash Translation Layer the controller needs to translate logical block addresses into physical NAND pages. The PC-3000 SSD Phison Utility documents a non-destructive recovery path: force the controller into ROM mode, inject a volatile microcode loader into its on-chip RAM, rebuild a Virtual Translator from surviving service-area fragments, and image the user area without writing a single byte back to the drive. This is the same class of workflow described on our broader SSD firmware panics and ROM-mode recovery page, applied to the specific Phison S11 controller family.
SATAFIRM S11 identification in BIOS and SATA Identify
On power-on, the system BIOS enumerates the drive and issues an ATA IDENTIFY DEVICE command. A healthy Kingston A400 returns the model string "KINGSTON SA400S37" with the rated capacity. A panicked drive returns the hardcoded ROM identity "SATAFIRM S11" and a diagnostic capacity of 0 bytes, 2MB, or 20MB depending on firmware revision. The drive will refuse standard ATA READ, WRITE, FORMAT, and INITIALIZE commands. Disk Management, GParted, and Disk Utility either gray out their action buttons or throw I/O errors. That response pattern is the diagnostic signature for FTL failure rather than media failure.
PCB ROM-mode entry via documented test-pad shorting
If the controller is not already trapped in ROM mode (some failures leave it stuck in a BSY loop or in a reboot cycle trying to load corrupt firmware), the technician forces ROM entry at the hardware level. There are documented ROM-mode test pads on the controller side of the PCB. Shorting the correct pad to ground during the bench power-on instant prevents the controller from reading the operating firmware out of the NAND service area. Instead, the controller halts inside its internal mask ROM and waits for diagnostic commands. The sequence is power down, short the documented contact points, restore power; the short is released once the PC-3000 utility reports the drive in Technological Mode. Nothing is written, no fuses are blown, and no firmware is altered.
The exact pad geometry varies across PS3111-S11 PCB revisions, which is why this step is done under a stereo microscope with the PCB referenced against ACE Lab's published safe-mode contact-point documentation. Guessing pads is how DIY attempts kill controllers. The same technique is used across the older Phison and SandForce SATA controllers documented on our SandForce and Marvell legacy SSD recovery page, with different pad assignments per controller family.
Attach the drive to the PC-3000 SSD in ROM-mode state
The drive attaches to the PC-3000 SSD complex over a PATA0 or PATA1 connection through a PATA-to-SATA adapter. That is the path ACE Lab documents for reaching Technological Mode on the PS3111; a plain SATA connection does not get there. USB-to-SATA bridges are not an option at any point either. The bridge silicon masks the Vendor-Specific Commands the workflow depends on and routinely issues spurious writes or TRIM commands during enumeration.
Match the Phison S11 factory loader (.LDR) to the drive's firmware family
With the controller stable in ROM mode, the PC-3000 utility queries the bare silicon to read the NAND Flash ID. The ID exposes the NAND vendor (Toshiba/Kioxia, Micron), the process node, and the die geometry. The technician selects a .LDR microcode bundle from the PC-3000 SSD Phison Utility that matches both the controller stepping and the NAND configuration. The selection also has to align with the firmware family the drive shipped with. A wrong loader profile will load but will produce massive LDPC ECC failure rates the moment NAND reads start. There is no way to compensate for that downstream; the loader has to match.
The selected .LDR is uploaded over Vendor-Specific Commands directly into the controller's volatile RAM workspace. The microcode executes from RAM only. Garbage collection, TRIM processing, and wear-leveling background tasks are disabled by the loader. Nothing is written back to the NAND. Power-cycle the drive and the loader is gone; the controller returns to its SATAFIRM S11 panic state. The entire diagnostic environment is volatile by design.
Rebuild the Virtual Translator from surviving service-area fragments
With the loader running, the PC-3000 utility scans the NAND service area. Most SATAFIRM S11 panics happen because an FTL write was interrupted, leaving the service-area metadata logically inconsistent while the remaining fragments stay intact. The utility reads the surviving fragments, parses the Out-of-Band metadata attached to every physical NAND page (block sequence numbers, page headers, LBA markers, wear-level counters), reverses the deterministic XOR scrambling polynomial, and compiles a fresh LBA-to-PBA mapping table from the consistent fragments. That mapping table is the Virtual Translator, and it is uploaded into RAM on the drive itself, where it stays volatile. It is not a repair of the drive's on-board FTL; it is a parallel, read-only translation surface for this one extraction session.
Dump user-area logical pages once the VT is built
Sector 0 is read first. The 55 AA signature at the end of the sector confirms the MBR is legible and that the Virtual Translator is mapping correctly. From there the utility images the user area sector by sector through that volatile Virtual Translator. The LDPC engine in the controller handles bit-flip correction on the raw NAND reads, with the utility issuing retries on pages that come back with high error rates. Throughput is far lower than a healthy SATA SSD because every read goes through the volatile loader and the rebuilt translator. The output is a forensically clean image file on a destination drive. The Kingston A400 receives no writes during this entire process.
File-system verification outside the drive
Once the user area is imaged, verification happens on the image file, not on the drive. The image is mounted read-only and the file system layer is checked: NTFS, exFAT, APFS, or ext4 depending on what the host was running. Files are spot-checked against expected hashes where the client has hash references. Any partition-level repair (rebuilding a corrupted MFT, repairing a damaged APFS container, replaying an ext4 journal) is done against the image file with the original drive powered off and stored. Pricing for this workflow follows the firmware-recovery tier ($600–$1,200) when the controller is electrically healthy and the panic is purely FTL-side, or the board-repair tier ($450–$600) when PMIC or voltage-regulator damage has to be addressed before the controller can be brought into ROM mode at all.
Why does my Kingston A400 show as SATAFIRM S11?
The Kingston A400 uses the Phison PS3111-S11 SATA controller. When the controller's Flash Translation Layer corrupts beyond self-repair (usually from power loss during a write, NAND degradation, or bad block table overflow), the controller enters a protective ROM MODE. In this state, it reports its factory firmware identity 'SATAFIRM S11' instead of the Kingston brand name. The drive typically shows 0 bytes capacity (some units report 2MB or 20MB instead). Your data is still on the NAND; the controller has lost the map to find it.
Can I fix SATAFIRM S11 myself with firmware tools?
No. Forum guides suggest using PhisonToolBox or MPTools to flash new firmware onto the controller. Flashing firmware overwrites the existing service area on the NAND, which contains the Flash Translation Layer, bad block tables, and wear-leveling metadata. This permanently destroys the mapping between logical addresses and physical NAND locations. Your data is still on the flash, but no tool can reconstruct which pages belong to which files after the FTL is overwritten. ROM-pin-shorting to force the controller into a reflashable state carries the same risk.
How much does Kingston A400 data recovery cost?
Kingston A400 firmware recovery (SATAFIRM S11) costs $600–$1,200. If the controller has additional electrical damage requiring board repair, the cost is $450–$600. Free evaluation and firm quote before any paid work. No data recovered means no charge.
Is SATAFIRM S11 only a Kingston A400 problem?
No. Any SSD using the Phison PS3111-S11 controller can display the SATAFIRM S11 error. This includes the PNY CS900, Patriot Burst, Goodram CX400, and dozens of other budget SATA SSDs.
How long does Kingston A400 recovery take?
Firmware recovery typically takes 3 to 6 weeks for standard service. Rush service is available for +$100 rush fee to move to the front of the queue. The timeline depends on the severity of NAND degradation and whether the FTL can be fully reconstructed or requires partial reconstruction with file-by-file verification.
Does every Kingston A400 use the same controller?
No. Kingston swaps controllers between production batches depending on component availability. The 120GB and 240GB models predominantly use the Phison PS3111-S11. The 480GB and 960GB models frequently use the Silicon Motion SM2258XT or SM2259XT instead. Different controllers require different PC-3000 utility modules and different recovery procedures.
My Kingston A400 is stuck at BSY and does not show SATAFIRM S11. Can it be recovered?
Yes. A BSY hang on its own does not tell you which controller is fitted, so identifying the controller is the first step before any recovery work begins. Recovery then runs on the PC-3000 SSD utility module that matches the controller actually on the board. Firmware recovery cost: $600–$1,200. Free evaluation, no data = no charge.
Should I run CHKDSK on a failing Kingston A400?
No. CHKDSK writes file system corrections to the drive. A Kingston A400 with degraded NAND is already struggling to manage its spare block reserves. CHKDSK forces additional writes to a controller that cannot reliably program NAND cells, accelerating FTL corruption and pushing the drive into a permanent BSY or SATAFIRM lockup. Power off the drive and send it for professional evaluation.
How do I tell if my Kingston A400 has a Phison or Silicon Motion controller without opening it?
Read the firmware revision string in CrystalDiskInfo or smartctl. Phison PS3111-S11 firmware on the A400 carries an SBFK prefix, SBFKB1D1 among them. Capacity is a secondary heuristic: 120GB and 240GB drives are most often Phison, while 480GB and 960GB drives more frequently use Silicon Motion. Capacity alone is not reliable because Kingston has shipped both controller families across multiple production batches at the same capacity.
Does the Kingston A400 use HMB (Host Memory Buffer)?
No. The Kingston A400 is a SATA SSD, and HMB is an NVMe-only feature defined in NVMe 1.2 and later. HMB lets a DRAM-less NVMe controller borrow a small block of host system RAM over the PCIe bus to cache FTL fragments. The SATA protocol has no equivalent mechanism. The A400 is DRAM-less and SATA, so it has to manage its entire Flash Translation Layer on-board. The controller holds only the active FTL segment in its internal memory and constantly streams FTL fragments in and out of the NAND service area. That continuous streaming is what drives the elevated write amplification and accelerated service-area wear that produces SATAFIRM S11 failures.
Which SMART attribute tells me my Kingston A400 is about to fail?
There is no single attribute. Watch a small cluster together. Attribute 0xBB (Reported Uncorrectable Errors) rising above zero means the LDPC engine is throwing ECC errors it cannot mathematically correct; if those errors land in the service area, the next boot drops the controller into SATAFIRM S11 ROM mode. Program Fail Count and Erase Fail Count climbing together indicate NAND cells rejecting new charge states, which is the precursor to BSY hangs on Silicon Motion variants. Attribute 0xE7 (SSD Life Left) falling means the drive is working through its rated endurance and any of the above can trigger. Power the drive off and image it before running diagnostics that write to the media.
What does the firmware string SBFK mean on my Kingston A400?
SBFK is a firmware revision prefix seen on Kingston A400 drives built around the Phison PS3111-S11, SBFKB1D1 among the revisions observed in the wild. Reading that revision string in CrystalDiskInfo or smartctl is the most reliable way to identify the controller family without opening the drive, and the controller family is what determines which PC-3000 SSD utility module and which loader profile the recovery runs on.
What is the .LDR loader file and why can't I just download it and use it myself?
The .LDR file is a Phison factory microcode bundle that the PC-3000 SSD complex uploads into the controller's volatile RAM over Vendor-Specific Commands. It does not get written to the NAND service area. It runs only in the controller's volatile RAM workspace, and it vanishes when bench power is removed. Its job is narrow: expose the raw NAND through a documented diagnostic interface, disable garbage collection and TRIM, and let the host workstation parse Out-of-Band metadata to rebuild a Virtual Translator in RAM on the drive itself. The .LDR bundles are licensed and distributed by ACE Lab to PC-3000 SSD owners and are matched to specific controller die revisions and NAND geometries. They are not consumer firmware. A wrong loader produces ECC failure storms and unreadable configuration pages. Even if a matching loader were obtained outside the PC-3000 environment, the host side of the workflow (XOR descrambling, OOB metadata parsing, Virtual Translator compilation) lives inside the PC-3000 SSD utility itself. The loader is one piece of a larger toolchain; it is not a standalone unbricker.
Why must the loader version match the firmware family on the drive?
The PS3111-S11 ships in several controller die revisions, and the NAND it is paired with varies across production batches: Toshiba/Kioxia 15nm planar TLC on early Kingston A400 units, Micron 3D TLC on later runs, and a handful of other configurations in OEM-rebadged drives. Each loader profile in the PC-3000 SSD Phison utility is tuned for a specific controller stepping plus a specific NAND geometry, ECC strength, and page layout. The firmware family string (read from the drive before failure, or inferred from the controller markings and NAND ID after failure) tells the technician which loader profile to select. A loader matched to the wrong family will load and execute, but the descrambler will apply the wrong XOR polynomial, the page-layout offsets will be off, and the OOB metadata parser will read garbage where it expects LBA markers and block sequence numbers. The Virtual Translator either fails to compile or compiles wrong, returning corrupted data. Matching the loader is the first checkpoint of the procedure; everything downstream depends on it.
Why does my Kingston A400 lose 2MB of capacity in BIOS?
When the Phison PS3111-S11 controller cannot read a coherent Flash Translation Layer from the NAND service area, it falls back to a minimal bootstrap state called ROM MODE. In ROM MODE the controller cannot translate any logical block address to a physical NAND page, so it cannot report its real user capacity. Instead it returns a hardcoded placeholder geometry stored in silicon. That placeholder is typically 0 bytes; some firmware revisions report 2MB or 20MB instead. The drive simultaneously changes its identity string from Kingston A400 to SATAFIRM S11. The 2MB number is not a partial recovery or a corrupted partition table; it is the ROM-mode placeholder, and it confirms that the FTL is the failure point, not the NAND cells. The user data is still physically present on the NAND and is recoverable through PC-3000 FTL reconstruction provided no firmware-flashing tool has been run against the drive in the meantime.
Related Kingston A400 Recovery Pages
Deep technical breakdown of Phison S11 failures
All Kingston SSD models
Full SSD recovery service overview
SM2258XT, SM2259XT controller recovery
PS3111-S11, E12, E18 controller recovery
Every controller family across the SSD market
General firmware failure recovery
Full SSD pricing breakdown by failure type
Kingston A400 showing SATAFIRM S11?
Do not flash firmware. Free evaluation. Recovery: $600–$1,200. No data, no fee.
