SSD Recovery Workflow Reference
Silicon Motion Controller Recovery Workflows
A bench-level reference for how Silicon Motion SSDs (SM2258, SM2258XT, SM2259, & their NVMe siblings) are actually recovered. This page is the controller-specific companion to our SSD data recovery: ROM Safe Mode entry, PC-3000 SSD loader injection, Host Memory Buffer failure analysis, & Vendor Specific Command sequences for translator reconstruction. SATA recovery starts at $200; NVMe starts at $200. No diagnostic fee. No data, no recovery fee.
Looking for the architectural overview instead? Read the Silicon Motion Architecture hub. This page is the workflow companion.
What does Silicon Motion controller recovery actually involve?
Silicon Motion SSD recovery is a five-stage bench workflow. The controller is forced into ROM Safe Mode through a pin short, a controller-matched loader is pushed into its RAM by PC-3000 SSD, the Flash Translation Layer is rebuilt from NAND spare area metadata using Vendor Specific Commands, & the resulting logical view is imaged to a target drive. All work is performed in-house at our Austin, TX lab. Founded 2008. No data, no recovery fee.
Five-Stage Recovery Workflow
Every firmware-level Silicon Motion recovery moves through these five stages in order. The customer sees one outcome (data on a target drive); the engineer moves through five distinct bench states.
- 1
Visual Triage & Power Profile
PCB inspection under microscope for shorted PMIC, cracked passives, or burnt traces near the controller. We log current draw on a bench supply. A drive that pulls 0 mA has lost a power rail. One that pulls full current with no enumeration is in firmware panic.
- 2
Safe Mode Entry
If we confirm firmware panic, we force the controller into ROM bootloader by shorting a specific ROM pin pair on the drive during power-up. This bypasses the corrupted NAND-resident firmware so PC-3000 SSD can communicate with the silicon directly.
- 3
Loader Injection
PC-3000 SSD pushes a controller-matched loader image into the chip's internal RAM. On the SM2258XT and SM2259XT the loader has to match the drive's internal firmware version and NAND chip configuration, because ACE Lab publishes a list of loaders for those two rather than one universal build. For the SM2260G, SM2262ENG and SM2263XT ACE Lab's loaders are universal.
- 4
FTL Reconstruction
With the loader running, Vendor Specific Commands unlock the NAND spare area. The engineer reads the logical block address tags written into each physical page and rebuilds the Flash Translation Layer in software, independent of whatever damaged the on-NAND copy.
- 5
Image Extraction
Once the rebuilt FTL is loaded, the drive presents a logical sector view. PC-3000 SSD images sector by sector to a target drive, with bad-block retry passes on any cells the controller flags as marginal. The original SSD is never written to during this stage.
Why SMI Controller Failures Need XOR Descrambling, Not Cleanroom
A dead Silicon Motion SSD recovers because the engineer reverses scrambling math and rebuilds striped translation tables, not because the bench is inside an ISO-class room. Chip-off is the slow path, and a donor PCB doesn't produce a readable image.
XOR Data Scrambling on SM2246EN and SM2258XT
Silicon Motion controllers apply XOR scrambling to user data before any byte reaches the NAND. The purpose is electrical, not cryptographic. Writing a long run of identical values into modern TLC or QLC cells produces a uniform charge pattern across adjacent floating gates, and the cross-coupling between neighbours pushes the read-back voltage outside the window the controller's LDPC engine can correct. The scrambler breaks that uniformity by XOR-ing every page with a firmware-derived polynomial keyed to the physical block and page offset.
A page the host originally filled with zeroes reveals the scrambler output for that page, because zero XOR-ed with anything yields the other operand. The catch is that the engineer needs a clean physical image first. Pulling the NAND off-board and reading it on a stand-alone programmer returns the scrambled stream plus whatever LDPC parity the controller wrote alongside it; the bytes look like noise until both the descrambler and the ECC engine are applied in the right order.
The shortest path to plaintext is to keep the original controller alive. We short the pins and run the loader injection that forces the SM2258XT into Techno Mode. The silicon then runs the LDPC and descrambler hardware paths against its own NAND and streams already-readable data to the PC-3000 SSD workstation. The math the controller was designed to do is the same math that recovers the drive.
Per-Die Wear-Leveling FTL Reconstruction
Descrambled NAND pages still aren't a file system. A Silicon Motion controller hits its rated sequential throughput by striping writes across every available NAND die, channel, and logical plane in parallel; the Flash Translation Layer that maps logical block addresses to physical pages is correspondingly striped, not a single linear table. We have to de-interleave that geometry exactly.
The SM2258XT is DRAM-less, so there is no external cache holding the live L2P map; the persistent FTL state lives in reserved system blocks on the NAND itself. When power is cut during an FTL flush, the on-NAND copy is partial and the controller halts at boot with a permanent ATA busy state. At that point we read the out-of-band spare area of every physical page and collect the logical block tags and write-sequence numbers stored there. PC-3000 SSD compiles a virtual translator from them and uploads it into the drive's own volatile RAM. The translator de-interleaves the stripe and presents the drive as a logical sector device for the Data Extractor task.
Nothing in this pass is written back to the customer NAND. The reconstructed translator exists only in volatile RAM on the drive itself. For deeper coverage of how stripe corruption is detected and the per-die spare-area scan is sequenced, the Silicon Motion Architecture hub documents the firmware-corruption mechanics in further depth.
Why Donor SMI Boards Rarely Work
The donor PCB instinct comes from mechanical hard drives, where the board carries drive-unique calibration data. Silicon Motion SSDs don't work that way. There is no external NVRAM holding drive-unique calibration; the FTL, the bad-block table, the wear-level counters, and the adaptive read-retry thresholds all live in the NAND service area on the original drive. A donor board ships with its own NAND-resident state from the donor drive's prior life. Power the donor PCB on the original NAND and the controller refuses to bind: the metadata it expects to load doesn't match what is on the chips, and the drive halts.
Where the OEM enabled hardware AES, the binding is harder still. The media encryption key is generated at random inside the original controller and kept wrapped by a key fused into that die. A donor controller cannot unwrap it, so its AES engine returns ciphertext. On a drive with no AES in the path the metadata mismatch alone is enough to keep the controller at the busy state through every boot attempt.
The path that does work is repairing the original PCB in place. A FLIR thermal camera localises the failing rail within a few seconds of power-on by showing the component that is sinking the short. A Hakko FM-2032 on an FM-203 base lifts the failed PMIC, oscillator, or decoupling capacitor under microscope, and an Atten 862 hot air station reflows the replacement; Zhuo Mao BGA rework stations handle the controller or NAND package if the failure is deeper than discrete-component level. Once the original board passes its power profile, the controller is the same silicon the NAND was paired with, the service area binds on the next boot, and the rest of the recovery proceeds through the Safe Mode and loader-injection workflow already documented below.
Silicon Motion Controller Family Comparison
Five controller families differ in host interface, NAND channel count, FTL caching strategy, the failure signature the lab sees, and the PC-3000 SSD recovery path that applies. The Silicon Motion Architecture hub covers the per-family failure mechanics in more depth. For broader context on the underlying FTL panic state, see the SSD firmware corruption page.
| Controller | Host Interface | NAND Channels | DRAM vs HMB | Common Failure Signature | PC-3000 SSD Recovery Path |
| SM2258 | SATA 6 Gb/s | 4 | External DDR3/DDR3L | ATA BSY hang at normal operating current after power loss during FTL flush. The product brief lists real-time full-drive AES and the TCG Opal protocol. | ROM Safe Mode entry, loader injection matched to NAND chip ID & firmware revision, VSC spare-area FTL rebuild. |
| SM2259 / SM2259XT | SATA 6 Gb/s | 4 | SM2259: External DDR3/DDR4, LPDDR3. SM2259XT: DRAM-less, on-NAND FTL backup only. | Drive enumerates but reports raw silicon string (e.g., SM2259XT) with a 0-byte or otherwise wrong capacity. The product brief lists full-drive AES and the TCG Opal protocol. | Same SATA workflow as SM2258 with an SM2259-specific loader. Encrypted parts require reviving the original controller, because the media encryption key is wrapped by a key fused into that controller die. |
| SM2263XT | PCIe Gen3 x4 (NVMe 1.3) | 4 | DRAM-less; active FTL working set held in host RAM via Host Memory Buffer. | HMB working set vanishes when PCIe link drops; on-NAND backup left mid-update. Drive reports SM2263XT descriptor with 0-byte namespace. | M.2 adapter on PC-3000 Portable III Port 0, test-pin Safe Mode, Loader upload, spare-area scan across every page (longer pass on HMB parts). |
| SM2262EN | PCIe Gen3 x4 (NVMe 1.3) | 8 | External DDR3/DDR4, LPDDR3 | Enumeration failure or partial PCIe handshake. The product brief lists full-drive AES, whose key is wrapped by a key fused into the original controller. | Loader upload on the original silicon. Chip-off yields ciphertext because the key is bound to that die. A donor PCB swap isn't viable. |
| SM2264 | PCIe Gen4 x4 (NVMe 1.4) | 8 | External LPDDR4/LPDDR4X or DDR4 | Quad-core ARM Cortex R8 CPU. The product brief lists real-time AES 128/256 full-drive encryption and the TCG Opal 2.0 protocol. | Not in the ACE Lab PC-3000 SSD supported-controller list. A matched loader is not currently available. The viable path is component-level board repair on the original controller, since the AES-128/256 MEK is bound to that controller die and chip-off yields ciphertext. |
Two notes about the table. First, the host-interface column tracks the NVMe spec revision the controller ships with, not the link speed an individual drive may negotiate; an SM2264 drive in a Gen3 slot is still an NVMe 1.4 part. Second, the DRAM column distinguishes externally-cached FTL from DRAM-less HMB-cached FTL because the two have substantially different power-loss failure profiles even on identically-rated drives.
What Does Silicon Motion Recovery Cost?
Pricing depends on failure severity, not on the controller model. A simple copy off a healthy SM2258XT costs the same as a simple copy off a healthy SM2269XT. A firmware recovery on either platform costs the same. +$100 rush fee to move to the front of the queue. Full SSD recovery cost breakdown.
SATA Pricing (SM2258, SM2258XT, SM2259, SM2259XT)
NVMe Pricing (SM2262EN, SM2263XT, SM2269XT)
Technical Methodologies
The procedures referenced here are bench operations performed under microscope on dedicated PC-3000 SSD hardware. They are documented for reference, not as DIY instructions; performing any of these steps on a live drive without the right equipment will brick the controller.
ROM Pin Shorting & Safe Mode Entry
The SM2258, SM2258XT, & SM2259 boot in two stages. A small primary bootloader lives in mask ROM inside the controller silicon; the larger secondary firmware image lives in a reserved area of the NAND. When the secondary image becomes corrupted (the typical outcome of a power loss during an FTL flush), the primary bootloader has nothing valid to hand off to, & the controller halts before SATA enumeration. The drive sits at full current draw with no link.
Forcing the controller back into a usable diagnostic state requires bypassing the broken NAND-resident image. Shorting a specific ROM pin pair during power-up signals the silicon to skip the secondary load & remain in the primary bootloader. This is the state PC-3000 SSD documentation calls Safe Mode. The controller still does not enumerate as a normal storage device, but it does respond to PC-3000's diagnostic command set.
Pin selection differs between the SM2258XT (144-ball TFBGA) & the SM2259 (336-ball TFBGA). The procedure is performed under microscope with a fine probe; the same short executed on the wrong pad damages a power rail or the NAND interface permanently. Don't try this yourself.
PC-3000 SSD Loader Injection
Once the controller is in Safe Mode, PC-3000 SSD's Silicon Motion utility pushes a temporary firmware image (the loader) into the controller's RAM. The loader is a stripped-down firmware build that exposes raw NAND access without any of the consumer firmware's wear-leveling, garbage collection, or write logic. It lives only in volatile RAM & vanishes the moment power is cut.
Loader selection is not the same job on every part. ACE Lab publishes universal loaders for the SM2260G, SM2262ENG and SM2263XT, optimized to be used with any type of internal firmware and NAND memory chip ID. For the SM2258XT and SM2259XT there's no universal build. The utility carries a list of loaders instead, and the engineer matches the drive's internal firmware version and NAND chip configuration before loading one. A loader built for another NAND part, such as SanDisk 64-layer BiCS3, does not read a drive whose flash is a different part.
Once the loader is running, the RAM-only firmware bypasses the consumer firmware's TRIM pipeline entirely. The standard read path that returns deterministic zero after TRIM never executes; the loader reads raw physical pages directly, exposing the pre-erase charge state that DZAT was masking from the host.
DRAM-less HMB Architecture & Power-Loss Failure Modes
Silicon Motion ships its DRAM-less SATA controllers (SM2258XT, SM2259XT) without any external DRAM cache. The Flash Translation Layer is held in a mix of on-die SRAM (a small working set) & reserved NAND blocks (the persistent backup). A power cut during a write can land the drive in a state where the SRAM working set is gone & the NAND backup was mid-update; the controller boots, finds the backup in an inconsistent state, & enters firmware panic.
The NVMe DRAM-less parts (SM2263XT, SM2269XT) extend this architecture by borrowing a slice of host PC RAM through the Host Memory Buffer (HMB) feature defined in NVMe 1.2+. The active FTL working set lives in HMB. A power cut on an HMB drive severs the PCIe link in microseconds, far faster than the controller can flush its in-flight HMB state to NAND. On the next boot the on-NAND backup is stale and the controller panics.
Recovery for both architectures looks the same from the engineer's side: enter Safe Mode, inject the matched loader, & rebuild the FTL from NAND spare-area metadata using Vendor Specific Commands. The user data inside the NAND cells survives both failure modes intact; only the address map is destroyed. Because the NAND content is undamaged, recovery yields a complete image rather than a partial one, which is the key difference between FTL-loss recovery & cell-degradation recovery.
Vendor Specific Command Sequences & Translator Reconstruction
Vendor Specific Commands are non-standard ATA or NVMe opcodes that controller manufacturers reserve for factory diagnostics. They are not exposed to any operating system & are not documented publicly. Once we've put the drive in Safe Mode and injected the loader, PC-3000 SSD's Silicon Motion utility reaches the controller's technological command set. That's what gives it read access to the NAND spare area on every physical page.
The spare area on each NAND page carries the logical block address tag that was originally written alongside the user data, plus the page's ECC parity. Reading this tag across the entire flash device gives the engineer enough information to rebuild the logical-to-physical map from scratch. We upload the reconstructed map (the translator) into the drive's volatile RAM. We never write it back to the failed drive's NAND. Once it is loaded, PC-3000 presents a logical sector view of the drive over its own bus, & standard imaging tools can pull the data off sector by sector.
This is the recovery path that works when no copy of the original FTL survives. It is slower than loader-only recovery because every NAND page must be read for its tag, but it is the difference between a complete image & a permanent loss for severe firmware-panic cases on SM2258XT & SM2269XT drives.
Encryption Boundary & Why Chip-Off Is Not the Default
Silicon Motion's product briefs list real-time full-drive AES on the SM2262EN and AES 128/256 on the SM2269XT. The media encryption key is generated inside the controller and kept wrapped by a key fused into that die. The NAND content is ciphertext at rest. Removing the NAND chips & reading them on a stand-alone NAND reader yields encrypted bytes that cannot be decrypted without the original controller. This is why chip-off is not the default approach for these drives; the only path to plaintext is to revive the original controller through Safe Mode entry, loader injection, & FTL reconstruction.
The SM2258XT product brief lists no AES engine. On a drive with no AES in the path, chip-off can work in principle. XOR scrambling is a reliability measure, and you can reverse it once you know the controller's polynomial. It is still slower and less reliable than controller-level recovery, and pulling the NAND off the board risks damaging solder pads on the PCB. Controller-level recovery preserves the original drive intact for downstream analysis & remains the first-line approach across the entire Silicon Motion family.
NVMe Silicon Motion Variants: SM2260, SM2262EN, SM2263XT
Everything above this section applies primarily to the SATA Silicon Motion family (SM2258, SM2258XT, SM2259, SM2259XT). The NVMe parts add three more wrinkles. The SM2263XT uses DRAM-less Host Memory Buffer architecture. The SM2262EN carries hardware AES with controller-bound keys. The PC-3000 SSD workflow also changes: the utility uploads the Loader over the NVMe interface rather than the SATA path.
SM2260 Drives and Their Panic Signature
The SM2260 is on ACE Lab's published PC-3000 SSD supported-controller list. It shipped on the Intel SSD 600p, the ADATA XPG SX8000 with 3D MLC NAND, the ADATA XPG SX7000, and HP's OEM-marked 910595-01 module, which is the HP version of the 600p.
One documented SM2260 failure is a drive reporting a tiny, wrong capacity: one HP-branded 600p reported 1.07 GB instead of 256 GB and identified itself as SM2260 to the host. The drive enumerates, but the capacity it reports is not its own. The address map is what broke. Recovery is firmware tier on the NVMe pricing schedule.
SM2262EN: 8-Channel With DRAM and Hardware AES
The SM2262EN is a PCIe Gen3 x4 NVMe 1.3 controller with eight NAND channels and external DRAM (DDR3, DDR3L, LPDDR3 or DDR4), and its product brief lists real-time full-drive AES with the TCG Opal protocol. Engineers inspect the PCB silkscreen and controller laser-mark under microscope before selecting a loader profile. The part-number on the box isn't authoritative.
The typical SM2262EN failure presents as enumeration failure (the drive draws current but never appears on the PCIe bus) or a partial PCIe handshake that hangs the host during POST. Because the media encryption key is wrapped by a key fused into the original controller die, chip-off isn't a recovery path. Reading the NAND on a stand-alone reader yields ciphertext. The only way to get plaintext back is to revive the original controller with a Loader upload & rebuild the FTL while the silicon is still alive enough to hold its key.
SM2263XT: 4-Channel DRAM-less With Host Memory Buffer
The SM2263XT is a 4-channel DRAM-less NVMe 1.3 controller. There is no on-board DRAM cache; the FTL working set borrows a slice of host RAM through the Host Memory Buffer (HMB) feature. ACE Lab's published supported list carries it under the HP EX900, through HP's own H8068 and H8098 markings. Manufacturers change silicon inside a model over its production life, so we read the part off the package, not off the box.
Signature failure on the SM2263XT is the drive reporting its raw silicon descriptor (the string SM2263XT itself) in BIOS, or 0 bytes capacity. This happens after a power loss during a write: the HMB working set vanishes when the PCIe link drops, the on-NAND backup is mid-update, & the controller boots into firmware panic with no valid FTL on either side of the cache. Recovery is the same firmware tier as the SM2260. FTL reconstruction takes longer, because the spare-area read pass has to cover every page on the device.
Telling the SM2263 Apart From the SM2263XT
The Intel SSD 660p runs the SM2263, not the SM2263XT, and the two aren't interchangeable at the bench. Silicon Motion's brief pairs the DRAM-equipped SM2263EN with the DRAM-less SM2263XT: both are PCIe Gen3 x4 NVMe 1.3 four-channel parts, but only the XT runs without external DRAM and borrows host RAM through HMB. We read the die off the package before we pick a loader.
PC-3000 SSD's Loader Upload for NVMe Silicon Motion Controllers
ACE Lab says the NVMe-side workflow is to switch the drive to Safe Mode and upload the Loader. It runs on the PC-3000 Portable III through ACE Lab's M.2 PCIe NVMe adapter on Port 0. There are four bench stages.
- Step 1: Test-pin shorting at PCB diagnostic points. The utility shows which pins to short on the drive in front of you, and the engineer bridges them under microscope while the board is powered through the M.2 adapter. That is what switches the drive into Safe Mode so the Loader can be uploaded.
- Step 2: Loader selection & upload. ACE Lab calls its SM2260G, SM2262ENG and SM2263XT loaders universal, optimized to be used with any type of internal firmware and NAND memory chip ID. We push the selected loader into the controller's on-die RAM. While the loader runs, it switches off TRIM and the internal component-checking background processes, & forces read access to slower single-channel mode for stability. The loader also unlocks the Techno Mode functions that PC-3000 needs for spare-area access.
- Step 3: Virtual translator reconstruction. With the loader active, PC-3000 reads the spare-area metadata from every physical NAND page across the device. PC-3000 reconstructs the FTL from the logical block address tags written into each spare area, then uploads it into the drive's volatile RAM. We never write anything back to your NAND, at any point. On HMB drives such as the SM2263XT this stage is the longest bench phase because every page on the device must be read for its tag, & the page count on a 1 TB drive runs into the millions.
- Step 4: Data extraction. With the virtual translator loaded, the PC-3000 Data Extractor task issues LBA reads against the reconstructed map. The translator looks up the corresponding physical block, instructs the loader to read that block from NAND through the live controller, & returns the assembled file system over the workstation bus to the target drive. The customer's original SSD is read-only throughout; nothing is committed back to its NAND.
Pricing Tier for NVMe Silicon Motion Firmware Recovery
NVMe Silicon Motion firmware recovery (SM2260 diagnostic-capacity descriptor, SM2262EN enumeration failure, SM2263XT raw-silicon-name BIOS report) falls under the firmware tier of the NVMe SSD pricing schedule at $900–$1,200. The exact figure within that range depends on how many NAND blocks are marked as bad & how long the spare-area read pass takes on the specific drive capacity. +$100 rush fee to move to the front of the queue when a job needs to skip the queue.
Cases that escalate to NAND transplant onto a donor PCB move to the NAND swap tier; A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers. All work is performed in-house at our Austin, TX lab on PC-3000 SSD. There is no diagnostic fee & no recovery fee if the data does not come back; see the no-fix-no-fee guarantee for the full terms.
Why Recovery Software Cannot Help With a Panicked Controller
Recovery software (Disk Drill, EaseUS, R-Studio, PhotoRec) requires the SSD to enumerate as a normal storage device on the host operating system. It then reads logical sectors through the standard ATA or NVMe interface, scans for file system signatures, & reconstructs deleted or formatted data from intact filesystem metadata. This works on Silicon Motion drives whose controller is healthy & whose FTL is intact; logical recovery from a healthy SM2258XT is a routine job.
It does not work when the controller is in firmware panic. A drive reporting its raw silicon descriptor (SM2258XT, SM2269XT) in BIOS does not enumerate, does not present logical sectors, & does not respond to standard ATA/NVMe reads. The recovery software has nothing to talk to. At that point the only path forward is the bench workflow described above: ROM short, loader injection, FTL rebuild, image extraction.
Equipment Used at the Bench
- PC-3000 SSD with the Silicon Motion utility loader database, used for Safe Mode communication, loader injection, VSC sequencing, & imaging.
- Hakko FM-2032 microsoldering iron on an FM-203 base station, used for ROM pin tack-shorts, donor PCB component transfer, & PMIC replacement on the SATA & NVMe board-repair tier.
- FLIR thermal cameras for live fault localization on PCBs that pull abnormal current; a shorted PMIC reveals itself within seconds of power-on under thermal imaging.
- Atten 862 hot air rework station for BGA & QFN reflow during NAND transplant or controller donor work.
- Zhuo Mao precision BGA rework stations for controlled-profile reballing on NAND-swap jobs that require lifting the original NAND off the failed PCB & reseating it on a donor.
SM2267XT & SM2269XT: Gen4 DRAM-less HMB Recovery
The SM2263XT covered above is the Gen3 face of Silicon Motion's DRAM-less HMB design. The SM2267XT & SM2269XT are its Gen4 DRAM-less parts. Both fail in a way that is specific to host-RAM-backed translation.
Gen4 x4 4-Channel DRAM-less HMB Architecture
The SM2267XT & SM2269XT are PCIe Gen4 x4, 4-channel controllers with no external DRAM. They follow the same memory hierarchy as the SM2263XT: the active Flash Translation Layer working set is borrowed from host PC RAM through the Host Memory Buffer feature, & the persistent backup lives in reserved NAND blocks. Silicon Motion's own figures give the SM2269XT four NAND channels at up to 1,600 MT/s and the SM2267XT four channels at up to 1,200 MT/s, both up to 4TB.
The architectural split that decides recovery is the same one described in the DRAM-less vs DRAM-buffered section: there is no external cache to dump, so every byte needed to rebuild the logical view sits in the NAND spare area on the customer's own flash.
The engineer reads the controller laser-mark under microscope before selecting a loader, because the part number on the box is not authoritative.
Power-Loss FTL Panic on the Gen4 XT Parts
Both parts fail through a power-loss FTL panic. The HMB working set lives in host RAM, & when the PCIe link drops the host RAM contents are gone in microseconds, well before the controller can flush its in-flight FTL update to the NAND backup.
On the next boot the controller reads the on-NAND backup, finds it stale or partially written, & lands in one of three states: an L2P-corruption panic, an NVMe BSY-state lockout, or a fail-to-detect where the drive reports a raw silicon descriptor or 0 bytes in BIOS. The user data inside the NAND cells is intact; the address map is what broke.
This is a firmware-state problem, not a NAND-wear problem. The cells still hold what was written to them, and the controller couldn't load the map that says where it lives.
PC-3000 SSD Recovery Path for the XT Parts
The supported path is the same Loader upload workflow we run on the SM2263XT. The drive mounts on a PC-3000 SSD's M.2 adapter, and we bring the controller into ROM/Safe Mode through its diagnostic test points. We upload a controller-matched loader into RAM, & a spare-area Vendor Specific Command scan rebuilds the HMB-dependent L2P translator in the drive's volatile RAM.
On HMB parts that spare-area pass is the longest bench phase, because the NAND backup is updated less frequently than on a DRAM-buffered drive & every physical page has to be read for its logical block tag. It's the same four-stage sequence as the Loader upload workflow. The SM2267XT & SM2269XT run that same workflow with their own loader builds.
Which Drives Ship These Controllers
ACE Lab's published PC-3000 SSD supported list pairs the Kingston NV2 with the SM2267XT, and the ADATA Legend 800 and Legend 850 Lite with the SM2269XT. Silicon inside a model can change over its production life, so the engineer confirms which die is present from the controller laser-mark before selecting a loader.
| Controller | Drive Models | Notes |
| SM2267XT | Kingston NV2 | Gen4 x4, 4-channel, DRAM-less HMB, up to 1,200 MT/s. |
| SM2269XT | ADATA Legend 800, ADATA Legend 850 Lite | Gen4 x4, 4-channel, DRAM-less HMB, up to 1,600 MT/s. |
How This Differs From the SM2258 & SM2258XT SATA Profile
The HMB power-loss failure on these Gen4 NVMe parts is a different animal from the SATA SM2258 firmware panic, & the difference comes down to where the translator working set lives. The DRAM-equipped SM2258 keeps its live L2P map in an external DDR chip next to the controller; the DRAM-less SM2258XT holds its working set in a small on-die SRAM cache; the SM2267XT & SM2269XT borrow theirs from host PC RAM through HMB.
Three different memory tiers, three different things that vanish at power loss.
The signature on the bench tracks that split. A panicked SATA SM2258 or SM2258XT typically hangs at the ATA BSY flag at normal operating current, or enumerates & reports a raw controller string with a placeholder capacity. The SM2258XT holds its working set in on-die SRAM, which is gone the instant the drive loses power.
The NVMe XT parts fail through a PCIe link-drop that takes the HMB region in host RAM with it, then panic on a stale NAND backup.
The full SATA SM2258 failure profile, including the exact BIOS strings & the BSY-versus-raw-descriptor split, is documented on the SM2258 failure reference.
Silicon Motion Controller Architecture: Die Identification, Die-Level Parity, & Microcode Binding
The workflow above treats each Silicon Motion family as a unit. The bench reality is finer-grained: die markings differ between revisions of the same controller, DRAM-less parts route their FTL through different memory hierarchies than their DRAM-equipped siblings, the controller-level die-parity scheme rewrites the chip-off math, and the hardware AES engine binds the original PCB to its NAND in a way that no donor swap can undo. The subsections below cover the architectural facts that decide which SSD recovery path applies once a Silicon Motion drive lands on the bench.
Die Identification: Package Markings, BGA Footprints, & ROM-Mode Entry Points
The first bench question on any Silicon Motion drive is which die is actually on the board. SMI marks the controller package with a laser-etched part number on the top side of the BGA; the engineer reads it under microscope before selecting any loader profile. The SM2258 & SM2259 carry their family name on the package in plain text, such asSM2259H. The DRAM-less SM2258XT & SM2259XT differ from their DRAM-equipped siblings primarily in package footprint. The XT parts ship in smaller BGA bodies, typically 144-ball TFBGA, against the 336-ball TFBGA of the DRAM-paired SM2259. The NVMe SM2262 & SM2263 families follow the same convention: SM2262ENfor the high-clocked 8-channel part, SM2263XTfor the DRAM-less 4-channel HMB part, & so on.
PC-3000 SSD's Silicon Motion utility documents pin-level ROM-mode entry for each controller. It shows which points to short on the board in front of you, and the short keeps the controller from running the corrupted NAND-resident image. The controller then answers with a generic silicon descriptor and a placeholder capacity. This is the descriptor PC-3000 waits for before uploading the loader. The same mask-ROM identity has nothing to do with Phison's SATAFIRM S11identifier, which appears only on PS3111-class silicon; the two are sometimes confused on forum threads & should never be treated as interchangeable diagnostic signals.
On NVMe SMI parts (SM2262EN, SM2263XT) the same job is done through test points on the M.2 PCB. ACE Lab's utility shows which pins to short for the drive on the bench rather than fixing one pad coordinate, and the engineer locates them under microscope before applying M.2 rail power. The intent is the same as the SATA path: keep the controller from executing the corrupted Stage-2 image so the loader can be injected into RAM cleanly.
DRAM-less vs DRAM-Buffered Translator Architecture
The single biggest architectural split inside the Silicon Motion catalog is whether the controller has an external DRAM cache. DRAM-equipped parts (SM2258, SM2259, SM2262EN) keep the active L2P translator in DDR3 or DDR4 next to the controller. The persistent backup lives in reserved NAND blocks and is updated on a schedule the firmware controls. DRAM-less parts (SM2258XT, SM2259XT, SM2263XT, SM2269XT) have no external cache at all. On SATA-side DRAM-less silicon the working set lives in on-die SRAM. On NVMe-side DRAM-less silicon it is borrowed from host PC RAM through the Host Memory Buffer feature defined in NVMe 1.2.
The recovery consequence is that PC-3000 SSD's FTL reconstruction has nothing external to read on a DRAM-less drive. There is no DDR3 chip to dump & no LPDDR3 module that retains state across reset. Every byte the engineer needs to rebuild the logical view sits inside the NAND spare area on the customer's own flash chips. The Vendor Specific Command pass already documented above is therefore the entire game on a DRAM-less part: spare-area scan across the device, collect the logical block tags page by page, & assemble the translator inside RAM on the drive itself. On a DRAM-equipped part the same spare-area pass still runs, but the firmware is more likely to have left a partial in-DRAM image written out to NAND on the last graceful flush, which gives the loader a head start on bootstrapping a usable translator.
On HMB NVMe parts (SM2263XT, SM2269XT) the failure mode that produces the longest bench session is a power loss that catches the controller mid-write: the HMB region in host RAM vanishes when the PCIe link drops in microseconds, & the NAND backup is left stale by however many flushes the firmware was batching. Reconstructing the FTL under those conditions means scanning every physical page on the device for its spare-area tag, which on a 1 TB drive runs into the millions of page reads. The workflow does not change, but the bench time does.
Controller-Level Die Parity & Why It Complicates Chip-Off
Silicon Motion's product briefs list a RAID engine as part of NANDXtend on the SM2259 and SM2259XT, the SM2262EN, the SM2263EN and SM2263XT, the SM2264, and the SM2269XT. The SM2269XT brief describes an embedded programmable RAID that works alongside the LDPC engine to extend NAND life, which means the live firmware computes parity across the flash and stores it with the user pages. The customer never sees any of it, because the controller reverses the parity on the read path.
The consequence for chip-off recovery is that a raw NAND dump no longer has a clean one-to-one mapping from physical pages to logical user data. Some of the pages the NAND programmer pulls off are parity stripes, not user pages, & the stripe geometry (which dies hold parity for which user dies, & how the stripe rotates across blocks) is decided by the live firmware at write time. Before we can reassemble any LBA-tagged user data, we have to tell the parity pages apart from the user pages. That's one more reason we keep the original silicon alive and let the firmware reverse the parity itself. Controller-level recovery is the first-line workflow, not the last resort.
The same reasoning applies to the SM2264 NVMe controller, which extends this die-parity scheme onto PCIe Gen4 silicon. Rossmann does not currently offer in-lab recovery for SM2264. The SM2264 silicon isn't in the ACELab PC-3000 SSD supported-controller list, & the matched loader we'd need to revive one in Safe Mode isn't in the active utility. SM2264 cases that do arrive at the lab are evaluated for component-level board repair on the original controller only; full firmware recovery requires loader support that ACELab has not yet shipped.
Hardware AES, Key Binding, & Why Donor PCB Swaps Fail
The product briefs for the SM2259 and SM2259XT, the SM2262EN and the SM2263EN and SM2263XT all list real-time full-drive AES with the TCG Opal protocol. Tom's Hardware reports 256-bit AES under TCG Opal on the SM2263XT. On a self-encrypting drive the media encryption key is generated at random inside the controller and stored wrapped by a hardware-unique key fused into that die. The fused key isn't written to NAND, and isn't reproducible on another physical part even if every NAND chip is transferred intact.
The bench consequence is that the textbook PCB-swap procedure that works on mechanical hard drives does not work on encrypted SMI SSDs. A donor PCB ships with its own controller die holding its own fused key, so it cannot unwrap the media encryption key the original controller wrote the data under. Everything the donor reads off the NAND is LDPC-corrected by the ECC engine, descrambled by the XOR engine, and then run through an AES decrypt with the wrong key. The output is ciphertext, not user data. Injecting a loader on the donor doesn't close the gap, because the loader runs on top of the key-unwrapping hardware.
On a part with no AES in the path, such as the SM2258XT, whose product brief lists no AES engine, the donor PCB still fails for a different reason. The FTL, bad-block table, wear-level counters, and adaptive read-retry thresholds all live in the NAND service area of the original drive, and a donor PCB ships with its own NAND-resident metadata from the donor drive's prior life. The controller refuses to bind because the metadata it expects to load doesn't match what is on the customer's chips. The first-line path on both encrypted & non-encrypted SMI silicon is therefore the same: repair the original PCB in place using FLIR thermal imaging to localize the failed component & a Hakko FM-2032 on the FM-203 base to lift & replace it under microscope, then run the standard Safe Mode & loader-injection workflow on the revived original controller.
SLC Cache Exhaustion & Read-Disturb on Silicon Motion Silicon
Silicon Motion controllers reserve a portion of the TLC or QLC NAND to be programmed in SLC mode as a fast incoming-write cache. On static-cache parts the SLC region is a fixed allocation of dedicated blocks; on dynamic-cache parts the SLC region grows & shrinks with free space on the drive. While writes stay inside the cache, latency is low & the firmware can absorb bursts cleanly. Once sustained writes exceed the SLC region, the controller falls back to direct TLC or QLC programming and write latency rises. On DRAM-less parts the FTL update load can collide with cache flushing. That collision is one path into the panic state. The controller is mid-flush of an FTL delta when a power event lands, the cache flush completes partially, & the on-NAND backup is left mid-update.
Read-disturb is the other slow-burn failure path. Reading a NAND page requires the controller to drive a high pass-through voltage (Vpass) onto every unselected wordline in the same block so the string current can reach the sense amplifier. That Vpass is below the program voltage but high enough to induce weak Fowler-Nordheim tunneling into the floating gates of unread cells on the other wordlines of the same block; the cumulative effect over many reads pushes those cells closer to the LDPC engine's correction limit. Silicon Motion's SATA briefs list a StaticDataRefresh function and an early weak-block retirement option, both aimed at keeping charge inside what the ECC engine can still correct. A controller that cannot load its own metadata cannot run that housekeeping, and read-disturb then accumulates until ECC errors begin returning on previously stable pages.
The bench distinction matters because read-disturb failure looks superficially like cell-wear failure on the symptom side (uncorrectable read errors on what used to be healthy pages) but it has a separate root cause & a different recovery profile. Cell wear means the NAND is genuinely past its program-erase budget & the data on the affected blocks is degraded; read-disturb means the cells still hold the original charge pattern within ECC tolerance, but the controller's tracking has lost the ability to trigger refresh. PC-3000 SSD's spare-area scan recovers data from read-disturb cases at the same firmware tier as ordinary FTL panic recovery, because the NAND content itself is intact; cell-wear cases escalate to the NAND-transplant tier where chip-off becomes the path of last resort. For a deeper treatment of how cell degradation differs from FTL-loss failure, see the NAND degradation reference.
Why This Workflow Lives Here
Rossmann Repair Group has run a single Austin, TX lab since 2008. Every recovery described on this page is performed in-house by the same engineers who repair MacBook logic boards & iPhone PCBs. There are no satellite offices, no franchise partners, & no outsourcing. The customer talks to the technician doing the work.
Pricing is published in five tiers per platform; nothing is hidden behind a quote wall. There are no diagnostic fees. If the data does not come back, there is no recovery fee. +$100 rush fee to move to the front of the queue when a job needs to move to the front of the queue.
For the architectural overview of Silicon Motion controller families & their failure signatures, see the Silicon Motion Architecture hub. For broader SSD firmware corruption coverage, see the SSD firmware corruption page. For the chip-off workflow on drives where controller revival fails, see the chip-off NAND recovery page.
What does ROM pin shorting do on a Silicon Motion controller?
Why does PC-3000 SSD require an exact loader match for SM2258XT and SM2259XT?
What happens to a DRAM-less NVMe SSD during a power loss?
What are Vendor Specific Commands and how do they help recover a Silicon Motion SSD?
How much does Silicon Motion SSD recovery cost?
How is this page different from the Silicon Motion Architecture page?
Can data be recovered from a failed Silicon Motion SSD?
Is donor PCB swap viable on Silicon Motion controllers?
How does Silicon Motion die-level parity affect chip-off recovery?
Why does a donor PCB swap fail on an encrypted Silicon Motion SSD?
What does an SM2258 firmware bug look like?
Can data be recovered from a dead Kingston NV2?
How does an SM2269XT NVMe failure differ from an SM2258 SATA failure?
Free Evaluation on Your Silicon Motion SSD
Ship your drive to our Austin, TX lab. No diagnostic fee. No data, no recovery fee. Talk to the engineer doing the work.
