Stellar Data Recovery Alternative for Hardware Failure
Stellar Data Recovery is a legitimate tool for logical failures: accidental deletion, formatted volumes, corrupted partitions on physically healthy drives. If the drive is detected by your operating system with its correct model number and capacity, Stellar is a reasonable starting point. But if the drive is clicking, not spinning, showing up as "SATAFIRM S11" with 0 bytes, or Stellar is frozen mid-scan with no progress, the problem is hardware. No software can bypass broken read/write heads, a locked SSD controller, or Apple Silicon hardware encryption. That is a limitation of every application that communicates through the operating system's standard storage interface.
Stellar Data Recovery works on physically healthy drives. When the drive spins up normally, is detected with its correct model number and capacity, and the loss is logical (accidental deletion, formatted volumes, corrupted partitions), Stellar is an appropriate tool. Software cannot help when the hardware has failed.
Stellar Data Recovery scans file system metadata, partition tables, and unallocated disk space for recognizable file signatures. It can rebuild corrupted directory entries, locate lost partitions, and carve files from raw sectors. This works when:
The drive spins up normally and is detected in BIOS/UEFI with its correct model number and capacity
The drive appears in Disk Management (Windows) or Disk Utility (macOS), even if the volume is not mountable
You accidentally deleted files, formatted the wrong partition, or the file system corrupted after an improper shutdown or power loss
The drive does not make unusual sounds (clicking, beeping, grinding) when powered on
In these scenarios, Stellar, R-Studio, DMDE, PhotoRec, and similar tools are appropriate. Professional recovery would be unnecessary overhead. If you want a free method that handles the same work without a license fee, our ddrescue guide covers sector-level cloning with open-source tools.
Hardware boundary
Where Stellar Data Recovery Stops Working
Stellar stops working when the hardware between the NAND flash and the operating system is broken. No scan settings or license tier bypass a failed controller, corrupted firmware, or damaged read/write heads. The drive's data may still be intact, but software cannot reach it.
Failing Read/Write Heads (HDD)
A hard drive reads data by flying a magnetic head nanometers above a spinning platter. When a head is degraded, it can still read some sectors but fails on others. The drive's firmware retries each failed read multiple times before reporting an error to the OS. During those retries, the drive is unresponsive. Stellar freezes because it is waiting on a hardware response that takes seconds instead of milliseconds.
SMR Complications
Some consumer HDDs use Shingled Magnetic Recording (SMR), where data tracks overlap like shingles on a roof. When Stellar gets stuck reading bad sectors on an SMR drive, the drive's background garbage collection process may continue running, rewriting adjacent tracks to consolidate data. This background process can overwrite recoverable data while the software is hung waiting for a read response. The longer a failing SMR drive stays powered on, the more data the controller may silently destroy through internal maintenance operations.
WD Palmer and Spyglass: SMR Translator Failures
Western Digital 2.5-inch drives from the Palmer and Spyglass families use SMR. When one of these drives starts reading unreliably, Stellar stalls or freezes. The problem sits in the Service Area (SA). The SMR translator in SA Module 190 maps addresses between the media cache and the shingled zones.
Standard SA access commands used by generic firmware repair utilities can corrupt this translator and render the data permanently unrecoverable. PC-3000 addresses WD SMR translator failures by reconstructing the damaged Module 190 translator and locking User Area writes to prevent background garbage collection from erasing data during imaging. This is a hardware-level firmware manipulation that no consumer software can replicate.
Drive Dropping Off the Bus
When a drive encounters persistent read errors, its firmware may reset the SATA or USB interface. Stellar's scan stops because the device just disappeared from the system. USB enclosures are prone to this because many consumer USB-SATA bridge chips have short timeout thresholds and drop the connection when the drive does not respond in time.
If Stellar is frozen or scanning at near-zero speed, stop the scan and power down the drive. Leaving a physically failing drive running for hours while software retries reads can score the platter surface and permanently destroy data that was otherwise recoverable.
TRIM and SSDs
Why Stellar Recovers Empty Files from SSDs
If Stellar finds deleted files on your SSD but they come out empty or unreadable, TRIM did that, the way it was designed to. It isn't a bug in Stellar.
When you delete a file, the operating system sends the SSD a TRIM command. It tells the controller to unmap those blocks. After the controller processes TRIM, it returns zeros whenever software reads those blocks. The data itself stays on the NAND until garbage collection erases it. On a mechanical hard drive, deleting a file marks the space as available in the file system but leaves the magnetic data intact until something overwrites it.
What Stellar recovers in this scenario is the file system pointer: the Master File Table (MFT) entry that says a file existed at specific clusters. The pointer survives because the MFT is stored separately from the data. But when Stellar follows that pointer to read the actual file content, the controller returns zeros. The result is a file with the correct name and file size but no actual data inside.
TRIM is on by default on Windows 7 and later. On macOS, it's on by default only for Apple-supplied SSDs. On a third-party SSD you have to turn it on yourself with the trimforce command, which arrived in OS X 10.10.4.
SSD Controller Failures: When the Drive Is Invisible to Software
Some SSD failures do not erase data; they make the controller stop communicating. The NAND flash chips still hold the data intact, but the controller is the only path to the operating system. When the controller locks up, Stellar and every other OS-level tool see nothing. PC-3000 SSD bypasses the lockup through vendor-specific commands the OS driver cannot send.
Phison S11: SATAFIRM S11
When a Phison PS3111-S11-based SSD encounters firmware corruption, the controller enters a lockup mode. The host system identifies the drive as "SATAFIRM S11" with a reported capacity of 0 bytes. The drive is present on the SATA bus but returning invalid identification data. Stellar will either not see the drive at all or see a 0-byte device with no scannable sectors. PC-3000 SSD communicates directly with the controller through vendor-specific commands to push it out of the lockup state and access the NAND contents.
Apple Silicon encryption
Apple T2 and M-Series Macs: Why Software Cannot Help
On T2 Macs (2018-2020 Intel) and all Apple Silicon Macs (M1/M2/M3/M4), the SSD is encrypted at the hardware level by the Secure Enclave. The encryption keys are bound to the security chip on that logic board. If the board fails, no software tool can decrypt the NAND; Stellar and every other application cannot begin a scan.
Mac users looking for Stellar alternatives face an additional constraint. On Macs with T2 security chips (2018-2020 Intel Macs) and all Apple Silicon Macs (M1/M2/M3/M4), the SSD storage is encrypted at the hardware level by the Secure Enclave. The encryption keys are bound to the specific security chip on that specific logic board.
If the logic board dies, the NAND chips cannot be read by any external tool because the decryption keys died with the board. Stellar, Disk Drill, and every other software tool are not just ineffective here; they cannot even begin a scan because the data is AES-encrypted at the hardware level. The NAND blocks contain ciphertext that is meaningless without the Secure Enclave key.
The only path to data is repairing the original logic board at the component level to restore Secure Enclave functionality. This means diagnosing which power rail or component failed, sourcing donor parts, and resoldering ball grid array chips under a microscope. Chip-off NAND extraction is not viable for these devices.
Stellar handles logical failures on physically healthy drives; professional lab recovery handles physical failures, firmware corruption, and controller lockups where the drive hardware itself has failed. The scenarios do not overlap. If the drive is clicking, frozen, or showing 0 bytes, no software license changes the outcome.
Scenario
Stellar Data Recovery (Software)
Professional Lab Recovery
Accidental deletion (no TRIM)
Recovers files by scanning file system metadata and carving raw sectors
Can do the same work, but software is faster and cheaper for this case
SSD after TRIM
Finds file pointers only. Recovered files read back as zeros because the controller has unmapped those blocks
We run controller diagnostics. Recovery depends on whether garbage collection has erased the blocks
Head swap in a 0.02µm ULPA-filtered clean bench, then PC-3000 imaging with head maps and adaptive read parameters
SATAFIRM S11 / controller lockup
Drive shows 0 bytes or wrong name. Software sees nothing scannable
PC-3000 sends vendor-specific commands to push the controller out of lockup and access NAND contents directly
Apple T2/M-series Mac
Cannot decrypt. NAND is hardware-encrypted by the Secure Enclave. Software cannot access the decryption key
Board-level repair restores Secure Enclave functionality so the Mac can decrypt its own storage
Free, Standard, Professional, and Premium editions
Standard HDD: $100–$2,000. SSD: $200–$1,500. Free evaluation. No data, no fee
How hardware recovery works
How Hardware-Level Recovery Works
The PC-3000 sends vendor-specific ATA commands that a standard SATA controller can't issue. That lets us get into the firmware modules, head maps, and defect lists, which Stellar can't reach.
The PC-3000 is hardware paired with proprietary software that sends vendor-specific ATA commands to the drive's firmware. These are commands that a standard motherboard SATA controller cannot issue and that Stellar has no mechanism to send. This gives a technician direct access to:
Firmware modules stored in the drive's Service Area, including translator tables that map logical block addresses (LBAs) to physical platter locations
Head maps and defect lists that control which heads are active and which sectors are excluded from normal operation
Selective imaging where the tool reads accessible areas first, skips damaged regions, and returns to them in later passes with adjusted parameters
Diagnostic steps
How to Tell If Your Problem Is Hardware
Three things tell you whether it's a logical failure, where software can help, or a hardware failure, where it can't. Watch for disk activity when a Stellar scan freezes, listen for sounds from the drive, and check how the drive shows up in Disk Management. Check these before purchasing a software license or sending the drive to a lab.
Before deciding between software and professional recovery, check these indicators:
Check Task Manager or Activity Monitor. If Stellar shows 0% CPU and 0% disk usage while the scan progress bar is stuck, the drive's controller has locked up the I/O bus. The software is waiting for a response the hardware cannot provide.
Listen to the physical drive.Clicking, beeping, or rhythmic sweeping sounds mean the fault is in hardware.
Check Disk Management or Disk Utility. If the drive shows as "Not Initialized," reports 0 bytes, displays the wrong model name, or drops out entirely during a Stellar scan, the firmware or controller hardware has failed.
Likely Logical (Software Can Help)
Drive detected with correct model and capacity
No unusual sounds from the drive
Files were accidentally deleted or partition was formatted
Stellar scan completes and finds files
Likely Physical (Software Will Not Help)
Drive clicking, beeping, or grinding
Not detected in BIOS or shows 0 GB / wrong name
Stellar frozen with no progress for hours
Drive disappears mid-scan or after power cycling
HDD pricing
Hard Drive Recovery Pricing
Hard drive recovery is quoted based on the fault type, not the perceived value of your data. Evaluation is free. If we can't recover your data, there's no recovery fee. Pricing runs from simple file copies through mechanical head swaps requiring clean bench work and donor drives.
01
02
03
SSD pricing
SSD Recovery Pricing
SSD recovery pricing depends on the type of failure and the hardware intervention required. Cases range from logical file system repair to controller-level recovery where PC-3000 SSD accesses NAND directly through vendor-specific commands. Evaluation is free. If we don't recover any data, there's no recovery fee.
SSD recovery pricing is based on the type of failure and the level of intervention required, from file system repair through controller-level recovery.
01
02
03
04
05
Frequently asked
The questions below address the most common failures where Stellar stops working: TRIM-erased SSD files, controller lockups, SATAFIRM S11 errors, clicking hard drives, and Apple Silicon encryption. Hardware failures require hardware-level tools. No software license, including Stellar Professional, bypasses a failed controller or broken read/write heads.
Why does Stellar Data Recovery show my files but recover them as corrupted?
On SSDs, this is caused by the TRIM command. When you delete a file, the operating system sends a TRIM command telling the SSD controller those blocks are no longer in use. The file system metadata (the directory entry showing the file name and size) may still exist, which is why Stellar finds the file during a scan. But once the controller has processed TRIM, it returns zeros when the software reads those blocks. The result is a file with the correct name but no usable content inside. On HDDs, corrupted recoveries usually indicate the sectors holding the file data were overwritten or the read/write heads were too degraded to read them cleanly.
Is Stellar Data Recovery legitimate?
Stellar is a real company that has operated for over two decades. Their software handles logical data loss scenarios on healthy drives: accidental deletion, formatted partitions, corrupted file systems. User frustration typically comes from cases where the free version scans a drive and displays file names, prompting a license purchase, but the recovered files turn out corrupted because the underlying failure was hardware-based, not logical. Stellar software did what it was designed to do; the problem is that the drive needed hardware-level intervention, not a software scan.
What should I do if Stellar Data Recovery is stuck or frozen during a scan?
Power off the drive. A scan that hangs for hours or estimates hundreds of hours to complete is reading from a drive with failing hardware. On HDDs, this means degraded read/write heads are causing the drive firmware to enter internal retry loops on bad sectors. Forcing a failing drive to keep running while software retries reads accelerates the damage. The data may still be recoverable with hardware-level tools, but only if the drive is powered down before the heads score the platter surface or the controller locks out entirely.
Can Stellar Data Recovery fix the SATAFIRM S11 error?
No. When an SSD shows up as "SATAFIRM S11" with 0 bytes capacity, the Phison PS3111-S11 controller has entered a firmware lockup state. The drive is present on the SATA bus but returning invalid identification data. PC-3000 SSD sends vendor-specific commands directly to the controller, pushing it out of the lockup state and accessing the NAND contents through the controller's diagnostic interface.
How does Stellar pricing compare to professional lab recovery?
Stellar sells Free, Standard, Professional, and Premium editions of its Windows software. Recovery at our lab starts at $100 for a hard drive and $200 for an SSD. Evaluation is free, and if we can't recover your data, there's no recovery fee. The two handle different failures. Stellar handles logical failures on healthy drives. We handle physical failures, firmware corruption, and controller lockups, where the drive hardware itself has failed. If Stellar can solve your problem, it costs less. If the drive has a hardware fault, no software license will change that.
Can I try Disk Drill or Recuva if Stellar is stuck scanning?
No. If Stellar freezes or takes days to complete a scan, the drive has a hardware problem: degraded read/write heads on an HDD, or a stalling controller on an SSD. Running alternative software forces the failing hardware to keep retrying reads, which scores platter surfaces on HDDs and can permanently kill a degraded SSD controller. Professional hard drive recovery or SSD recovery can still extract data through hardware-level tools like PC-3000, but only if the drive is shut down before the damage compounds.
Can Stellar Repair for Exchange Server or SQL Server fix my corrupted database?
Stellar sells dedicated database repair tools for Exchange Server (.edb), SQL Server (.mdf), and SharePoint that parse and reconstruct corrupted database files at the logical level. These tools require a healthy underlying storage medium to read the file structure. If the server's RAID array has physically degraded disks or the SAN controller has failed, the database corruption is a symptom of hardware failure, not standalone logical corruption. The repair tool reads from storage that is returning bad sectors or incomplete data, producing output that cannot be reconstructed. The storage layer must be recovered first through hardware-level RAID imaging and reconstruction before any database repair utility can function.
Is the paid version of Stellar Data Recovery worth buying after the free scan finds my files?
Only if the drive is physically healthy. The paid license is worth it when the drive is detected with correct capacity, makes no unusual noises, and the loss is logical (deletion, format, partition damage). The license is wasted when the drive is clicking, frozen mid-scan, showing 0 bytes, or appearing as SATAFIRM S11.
Will Stellar Data Recovery work on a clicking hard drive?
No. A clicking drive has a hardware fault, and the click won't tell you which part failed. Every retry Stellar makes runs the mechanism across the platters again. If we find physically damaged heads, we open the drive on a 0.02 micron ULPA-filtered clean bench and replace them before any imaging tool, PC-3000 included, can pull data off it.
Does Stellar Toolkit for Data Recovery replace professional lab recovery for hardware failures?
No. Stellar Toolkit handles logical failures on functioning drives. It doesn't change the hardware boundary: none of the toolkit's applications can communicate below the OS storage interface. If the drive has a physical fault (clicking heads, controller lockup, firmware corruption), Stellar Toolkit hits the same wall as the Standard edition. The toolkit has value for users with multiple logical recovery needs across file types.
Why does Stellar Data Recovery ask for a BitLocker key when my drive has a hardware fault?
Stellar prompts for a BitLocker recovery key because the volume is encrypted and the software can't read the file system without decrypting it first. That key request is correct behavior, but the key doesn't fix a hardware fault. If the drive is clicking, the controller is stalling, or the firmware is corrupted, the hardware can't return data regardless of the decryption key. The decryption layer sits above the hardware layer; if the hardware won't deliver sectors, the key is irrelevant. Hardware recovery labs image raw sectors first, then apply decryption during file reconstruction. If you have the 48-digit BitLocker recovery key or .bek file, keep it available for the lab.
Why can't Stellar Data Recovery for Mac recover files from a T2 or M-series Mac with a failed logic board?
Stellar Data Recovery for Mac can't recover data from T2 (2018-2020 Intel Macs) or Apple Silicon Macs (M1 through M4) when the logic board has failed. On these Macs, the Secure Enclave processor holds the hardware encryption keys for the internal SSD. Those keys never leave the chip. If the logic board fails, the NAND chips can be physically removed, but the data reads as ciphertext without the Secure Enclave key to decrypt it. Stellar, Disk Drill, and any other software tool require a functioning OS to read storage; none can bypass hardware encryption bound to a dead chip. Recovery requires board-level microsoldering to restore Secure Enclave function so the Mac can decrypt its own storage. See our Mac data recovery page for Apple Silicon board repair details.
“I consulted Rossmann Repair Group for data recovery services. A new IT client was recently referred to me, because his main computer crashed and his business database went offline as a result. It turned out that the computer crashed because its main storage, a 500 GB Solid State Hybrid Drive, failed. That part was easy - replace it with a new 1 TB SSD and reinstall Windows along with the software he uses. However, the data on the SSHD was critical and would have meant serious problems for his business if he didn't get that back.
That's where Rossmann Repair Group came in.”
