A Hard Drive Data Recovery That Was No Fun
This 5TB Western Digital Spyglass 2 external drive showed evidence of a prior repair attempt. Its USB bridge stood between the technician and PC-3000. 41 minutes of troubleshooting that ends in partial recovery.
Video
Summary
SATA Conversion
Before any recovery work can happen, the USB bridge must be isolated so the drive can talk directly to PC-3000 over SATA. The video walks through removing the small coupling capacitors that tie the bridge to the SATA lines and soldering leads to test points E71, E72, E73, and E75, prepping the pins for direct connection.
The customer had already tried data recovery software on it. That didn't work.
Summary
Head Stack Damage
Once mounted in PC-3000, the real problems became visible. The head stack assembly had damage at multiple points.
Finding a compatible donor for a Spyglass 2 isn't straightforward. Even drives from the same production batch can have different preamp versions and calibration parameters.
The technician limited power cycles to protect the data still on the drive.
Summary
Partial Recovery
This one's only a partial recovery. That's not everything, but it's not nothing either.
Every extra problem stacked on a drive lowers the odds.
Get help
Got a Drive That Looks Like "No Fun"?
Even drives with prior repair attempts and multiple hardware failures can yield partial recoveries. Send it in before adding another layer of damage to the stack.
