We repair MacBook logic boards at component level, and at this point we do it for data recovery. On a T2 or Apple Silicon machine the SSD is soldered to the board, so your files are on the board, and replacing it means losing them. We fix the board you already have. Typically 3 to 7 business days. No fix = no fee.
MacBook logic board repair is priced per model after evaluation, with tiers covering pre-2015 unibody models, 2016 to 2018 MacBooks, and 2019+ models with Touch Bar or T2 chips. We repair the existing board at component level under a microscope, replacing only the failed chips, capacitors, or power management ICs. That is what keeps your data. On a T2 or Apple Silicon machine the SSD is soldered to the board, so replacing the board means losing what is on it. Board work here is done in service of data recovery at this point; the machine booting again is what that looks like when it goes well. Turnaround is 3 to 7 business days after evaluation. Every repair includes a 1-year warranty. If we cannot fix the board, you pay nothing. Free evaluation for walk-in customers at our Austin lab or via nationwide mail-in. We do not service models older than 2013 or the 2011 GPU failure.
Signs of a Bad Logic Board
Logic board problems can cause all sorts of MacBook issues. If your MacBook is experiencing any of the following symptoms, there's a good chance the logic board is at fault, and is fixable by our team:
MacBook does not turn on at all (no power).
Random shutdowns or won't stay on.
Not charging the battery / not detected by charger.
Works on charger power but not on battery power.
No backlight (dark screen but faint image visible).
Fans revving, random freezes, or input devices not responding.
Standard Repair
Unibody/older models up to 2015.
Priced per model after evaluation
Macbooks 2016-2018
Macbook Models from 2016-2018
Premium Repair
2019+ Models (Touch Bar, T2) - Touch Bar Pros, late 2018-2019 Air with T2 chip, etc.
Ranges cover worst-case scenarios. If simpler, we charge less. Typically turn around time is 3-7 business days, which does not include time spent in transit/shipping. We do not offer repairs on devices older than 2013. No fix, no fee.
Our Logic Board Repair Process
We take a thorough, professional approach to component-level board repair. Your MacBook isn't working; here's how we bring it back to life:
Free Diagnostic: First, we diagnose your MacBook to confirm the logic board is the culprit and identify exactly what's wrong. We'll also check other components (battery, etc.) to ensure there are no surprises. After diagnosis, we provide a firm quote (within the pricing range above) and get your approval to proceed.
Board Repair & Component Replacement: Our technicians then get to work on the logic board itself. Using advanced tools (microscopes, soldering stations, schematics), we pinpoint failed components or damaged circuitry. We replace bad chips, blown fuses, corroded connectors; whatever the board needs, with high-quality parts. For liquid damage, we always perform a deep ultrasonic cleaning bath to remove corrosion before and after repairs.
Testing in a Complete MacBook: Once the board repair is done, we reassemble your MacBook (we have to have the whole machine for this). We then test every function: does it turn on reliably? Charge properly? Run on battery? Wi-Fi, keyboard, trackpad, sound, etc. We verify that your MacBook is fully functional and the original issue is resolved.
Quality Control & Warranty: We double-check the repair under both light and heavy usage to ensure it's stable. Finally, we return your MacBook to you with a 1 Year warranty on the logic board repair. In the unlikely event of an issue resurfacing, you're covered; and even beyond 1 Year, we'll support you as much as we can.
Typical turnaround: Most logic board repairs are completed within 3-7 business days. This does not include time spent in transit/shipping. We keep most replacement chips in stock for fast service. If you need your Mac back sooner, ask us about rush options; we can often accommodate urgent repairs.
Real MacBook Board Repairs on Camera
Many shops won't show you what they actually do. We have been sharing MacBook logic board repairs on YouTube for years, so you can see how we fix these boards. Check out the video below to watch us repair actual customer boards:
Why show our work?
Anyone can claim they do great work. We prefer to prove it. Louis Rossmann (our founder) started the trend of uploading real repair sessions so customers can see the skill and effort that goes into component-level logic board repair. It's educational and assures you that when we say we fixed something, we actually did the work.
You'll see us diagnose issues, replace chips, and bring dead MacBooks back to life. No camera tricks; just honest repair.
Why Choose Rossmann for Logic Board Repair?
We built our reputation on component-level logic board repair, and that work is now mostly done for data recovery, because the board is the only route to a soldered SSD. A few reasons people from around the world send us their boards:
Permanent Solutions, Not Band-Aids
We fix the root cause of your board's failure. That's why we offer a 1 Year warranty. We aim for a lasting repair, not a temporary workaround.
No Parts Swapping or Upsells
We stock all necessary chips and parts, so we have no need to scavenge from your machine. You get back exactly what you sent us, except now it works.
Mail-In or Walk-In, Nationwide
Locals can visit our Austin store. Not local? Our mail-in process handles devices shipped from all over the world.
Chips and Parts In-Stock
Many chips on a Mac logic board (power controllers, drivers, etc.) are made by third-party manufacturers, not Apple, and are readily available. We source genuine parts equivalent to or better than the originals.
Guaranteed Workmanship
We stand behind our repairs with a 1 Year warranty. If the same issue comes back within 3 months, we fix it again free of charge.
Trusted Repair Experts
We have been doing component-level MacBook repairs for over a decade. Louis Rossmann's repair videos have millions of views. Other repair shops look to us for guidance.
Fine print
The Fine Print
No board-only repairs; send the whole MacBook.
For us to warranty and fully test your repair, we need the entire laptop, not just the bare logic board. When people send only the board, inevitably something else ends up being an issue (cables, components, etc.) once it's back in their machine. By sending the complete MacBook, we can assemble and verify everything works before returning it to you. We do not offer warranty on board-only jobs.
No screens, batteries, keyboards, or trackpads.
Board-level work and data recovery are the scope here. We do not replace MacBook displays, batteries, keyboards, top cases, or trackpads, on this page or any other. Those are parts jobs, and a shop that does them daily will do them faster and for less. In Austin, CompuPLUS on North Lamar handles that work, and we will say so rather than take the job. If a failed circuit on the logic board is what is actually causing the symptom, that part is still ours.
No 2011 GPU repairs, no models older than 2008.
The infamous 2011 MacBook Pro GPU failure cannot be permanently fixed; replacement graphics chips are either unavailable or just as failure-prone. We do not service this particular issue. Additionally, very old Mac models (original 2008 MacBook Air, 2006-2008 plastic MacBooks, etc.) are often not economical to repair due to part scarcity. If you're unsure about your model, feel free to contact us and we'll let you know if we can help.
Can you repair a liquid-damaged MacBook logic board?
Yes - we specialize in fixing liquid damage. We ultrasonically clean the board to remove corrosion, replace any damaged components, and restore functionality. Liquid-damaged MacBook boards from spills are often repairable unless the corrosion has burnt through multiple PCB layers or destroyed critical BGA pads beyond reconstruction.
Do I need to send the entire laptop for logic board repair?
Yes. We require the complete MacBook (not just the bare board) for repair. This allows us to test the machine fully after we fix the board. If you send only the board, we can't verify everything in your MacBook works, and we wouldn't be able to warranty the repair. Sending the whole laptop ensures you get it back ready to go with no surprise issues.
How much does MacBook logic board repair cost?
Most logic board repairs fall between $325-$600 total, following the same published model-era tiers as our data recovery work: $325 for older soldered-SSD models, $425 for T2 and early M1 models, and $600 for current-generation machines. The flat rate covers board-level parts and labor. You only pay this fee if we can fix your board - if it's not repairable, you pay nothing.
Will I lose my data if my logic board is repaired?
No, you won't lose your data. On a soldered-SSD model the storage is part of the logic board, so replacing the board means losing what is on it. We repair the original board instead, and all your files and software stay exactly as they were. Preserving the data is the main reason to repair a board rather than replace it.
How long does a logic board repair take?
Typically our turn around time is 3-7 business days and most repairs are done within about 5 business days.
What if the logic board is not repairable?
If we can't fix your logic board, you owe us $0. No fix = no fee. We can return your MacBook to you (you'd just cover return shipping if applicable), or we can discuss alternative solutions like board replacement. But we won't charge you a diagnostic or labor fee if the board ends up beyond repair. We only charge for successful repairs.
Do you replace MacBook screens, batteries, keyboards, or trackpads?
No. Board-level repair and data recovery are the scope of this lab. We do not replace MacBook displays, batteries, keyboards, top cases, or trackpads. Those are parts jobs, and a shop that does them every day will do them faster and for less; in Austin, CompuPLUS on North Lamar handles that work. If a failed circuit on the logic board is what is actually causing the symptom, that part is still ours.
Do you repair the 2011 MacBook Pro GPU issue?
Unfortunately, no. The 2011 MacBook Pro discrete GPU problem cannot be permanently solved due to lack of reliable replacement graphics chips. Any 'fix' tends to be temporary. We do not offer repairs for this specific issue. For those models, replacing the logic board or using integrated graphics only are the common approaches, but a permanent board-level repair isn't feasible.
Data recovery from a dead MacBook?
When data is the goal rather than full repair, we approach the job differently: board-level work to access your soldered, encrypted SSD without swapping the board.
“My story isn't much different than anyone else on here leaving a Rossmann review, but I feel compelled to write all this anyway.
After importing 14GB of RAW photos from my brand new camera to my 13" MBP (A2338), I started to excitedly sift through my gorgeous sunset photos in Lightroom. After 5 minutes of editing, my MacBook died. Wouldn't turn on, wouldn't charge, wouldn't make any sound. It's always been well taken care of and I was dumbfounded as to why this happened. Absolutely clueless as to what to do next, I took it to the "Genius Bar".”
“I used their mail-in service and followed their simple instructions on how to send it it. First fill out a form, then you get a ticket number and write it down and put it in the box you ship the device in. Few days later from delivery I got an email indicating diagnosis was beginning.”
“I had a MacBook Air which was dead because of logic board failure, I took it to apple store only to realize that it would take minimum 500$ to repair excluding tax and labor. I was horrified and found Rossman by god's grace on youtube. I sent my laptop and got it repaired with a fair price.”
“My MacBook Pro (A1990) bricked and would not turn back on. I had years of family photos and important documents that were not backup up. Panicking, I first tried bringing my laptop to the local UBreakIFix.”
