Ransomware Data Recovery
Hardware-Level Recovery & Offline Extraction
We do not negotiate with criminals. We help you recover data without paying the ransom. Attackers often fail to encrypt everything, or they damage backups which we can then recover. We can image your drives offline, ensuring no malware spreads, and hunt for unencrypted shadow copies (HDDs), deleted fragments, and backup archives.
Ransomware Recovery in One Paragraph
We image affected drives offline through hardware write-blockers, extract Volume Shadow Copies and unencrypted remnants, and repair backup hardware the attackers damaged. No decryption key is required for the data we recover. Every step is documented with SHA-256 hashes and timestamped logs so your cyber insurance carrier receives forensic-grade evidence. Pricing starts at $100 (HDD) and $200 (SSD). No data, no fee.
What Can Data Recovery Services Recover After a Ransomware Attack?
Ransomware attackers often fail to encrypt everything. We recover deleted shadow copies, unencrypted fragments, formatted backup drives, and damaged RAID arrays without a decryption key.
AES-256 encryption cannot be reversed without a key; the data we target exists outside the encrypted portion of your storage.
We CAN Recover:
- Deleted shadow copies (VSS)
- Formatted backup drives
- Damaged RAID arrays (sabotaged by attackers)
- Files from "interrupted" encryption
- Unencrypted fragments in free space
We CANNOT:
- Break AES-256 encryption math
- Decrypt files without a key (unless a decryptor exists)
- Negotiate payment for you
How Does Ransomware Cause SSD Firmware Failures?
Sustained encryption write loads exhaust an SSD's spare block pool and trigger controller-level firmware panics. The drive locks into safe mode or drops off the bus entirely, requiring hardware intervention via PC-3000 SSD before any data extraction can begin.
- Phison PS3111-S11 Safe-Mode Lock
- Drives using the Phison PS3111 controller (common in Kingston A400, Patriot Burst, and Inland Professional SSDs) enter a read-only safe mode when the controller detects excessive NAND wear or write amplification. The drive reports its model string as "SATAfirm S11" instead of the original product name. A technician manually shorts the controller's ROM test pads to force it into factory ROM mode, then uses PC-3000 SSD to upload the loader (LDR) microcode and rebuild the flash translator in RAM to access the underlying NAND pages.
- Silicon Motion SM2258XT Zero-Capacity Failure
SSDs with Silicon Motion SM2258XT controllers (used in early revisions of Crucial BX500, ADATA SU650, and WD Green drives) report 0 bytes capacity instead of their rated size. The controller halts its boot sequence when it cannot read its mapping table.
PC-3000 SSD issues vendor-specific diagnostic commands to force the controller past the stalled boot sequence, then reconstructs the logical-to-physical address map using the native silicon for hardware descrambling. This recovers data that was never encrypted because the controller failed before the ransomware finished writing.
Both failure modes require physical board-level access before any decryption or file carving can proceed. Standard SSD data recovery techniques apply to these ransomware-triggered hardware failures.
How Does Ransomware Lock NVMe SSD Controllers?
High-IOPS random write workloads generated by ransomware encryption can exhaust an NVMe drive's spare block pool and corrupt its Flash Translation Layer. The drive enters a BSY state or drops off the PCIe bus, requiring physical board-level recovery before any file extraction.
- Samsung Elpis Controller Read-Only Lockup
Samsung 980 PRO drives use the Elpis controller. A 980 PRO that has locked into read-only mode remains visible to the host but refuses writes.
Because Samsung NVMe controllers use hardware-bound AES-256 encryption, data must be read through the original controller; NAND chip removal yields only ciphertext. We image the drive through the locked controller using managed read timeouts to secure a forensic-grade copy of whatever the ransomware had not yet overwritten.
How Long Does Enterprise Ransomware Recovery Take?
Recovery timelines depend on the physical condition of the storage hardware and the number of drives in the array.
Enterprise RAID arrays with 12 member disks and 8 TB each require 1 to 3 weeks of sequential imaging through write-blockers before reconstruction begins.
- Single-Drive Cases: 1 to 5 Days
- A single hard drive or SSD connected to a hardware write-blocker images at the media's native read speed. Drives with bad sectors or firmware instability require PC-3000's managed read retry logic, which extends imaging to 2 to 5 days depending on damage density.
- Multi-Drive RAID & SAN: 1 to 3 Weeks
- Enterprise RAID arrays require each member disk to be imaged individually before virtual reconstruction begins. A 12-drive RAID 6 with 8 TB members means imaging 96 TB of raw capacity sequentially through write-blockers. After imaging, Data Extractor Express RAID Edition reconstructs the virtual array from the cloned images, parsing stripe sizes & parity rotation from the controller superblocks.
- Rush Imaging Available
- A +$100 rush fee to move to the front of the queue moves your drives to the front of the imaging queue. For multi-drive enterprise cases, contact us for a custom rush timeline based on your array size & hardware condition.
What Is Our Ransomware Recovery Process?
We isolate infected drives from the network, create forensic-grade clones using hardware write-blockers, then scan raw sectors for recoverable data that the ransomware missed or failed to encrypt. Every step is documented with SHA-256 hashes and timestamped logs for cyber insurance chain-of-custody requirements.
- Offline imaging via hardware write-blockers. We clone your infected drives using PC-3000 connected through hardware write-blockers. This prevents the ransomware from spreading or continuing to encrypt, while preserving the evidence state for insurance documentation.
- Raw sector scanning for unencrypted remnants. We scan the raw physical sectors for deleted versions of files, temporary files, and Volume Shadow Copies that the ransomware attempted (but failed) to wipe. On mechanical drives, deleted data persists on the magnetic platters until physically overwritten.
- Backup drive hardware repair. Older backup drives often fail mechanically when you try to restore from them in a panic. We perform hard drive recovery on these critical backup drives, including NAS and RAID arrays, to get your pre-attack data back.
What Should Your IT Team Do in the First 60 Minutes After a Ransomware Attack?
Physically disconnect network cables from all affected machines, leave servers powered on to preserve volatile RAM evidence, and contact a recovery lab that uses hardware write-blockers for imaging. Incorrect triage in the first hour destroys forensic evidence.
- Disconnect network cables from all affected servers and workstations. Do not rely on disabling Wi-Fi or software-level network isolation. Pull the Ethernet cables and disable iSCSI initiators to prevent lateral movement across the domain. If the attack entered through RDP or a compromised VPN appliance, disable those access points at the firewall.
- Do not power down affected machines. Active encryption keys and threat actor artifacts reside in volatile RAM. A hard shutdown erases this forensic evidence permanently. If you need to stop encryption from progressing, disconnect the storage (pull SAS/SATA cables) rather than cutting power to the entire server.
- Contact a lab that uses hardware write-blockers for imaging. Software-based forensic copies risk executing the ransomware payload on the imaging workstation. We connect affected drives to hardware write-blockers and create sector-level clones using PC-3000 without ever mounting the file system. For multi-drive server and RAID environments, each member disk is imaged individually before any reconstruction begins.
What Happens After the First 60 Minutes of a Ransomware Attack?
Hardware containment stops the immediate threat. The full ransomware recovery lifecycle runs six phases: attack validation, response team assembly, hardware isolation, forensic imaging through write-blockers, raw sector carving for unencrypted remnants, and delivery of SHA-256 timestamped documentation for cyber insurance chain-of-custody requirements.
- Validate the attack. Confirm you're dealing with actual encryption, not adware or a lock-screen scam. Check for ransom notes in affected directories & cross-reference the file extensions against ID Ransomware to identify the variant. If a public decryptor exists, the recovery process changes.
- Assemble the response team. Your IR team includes IT staff, legal counsel, your cyber insurance carrier's breach hotline, & the data recovery lab. Insurance carriers often require notification within 24 to 72 hours of discovery. Delayed notification voids coverage on some policies.
- Contain via hardware isolation. This is the first-60-minutes triage: pull network cables, leave machines powered on, disable RDP & VPN endpoints at the firewall. Every server & workstation that touched the infected network segment gets isolated.
- Image all affected drives using hardware write-blockers. We connect each drive to a write-blocker & create bit-for-bit forensic clones using PC-3000. The write-blocker prevents the ransomware payload from executing during imaging. Original drives stay offline & untouched from this point forward.
- Extract recoverable data from forensic images. We scan cloned images for deleted files, Volume Shadow Copies, unencrypted free-space fragments, & backup archives the attacker missed. On mechanical drives, deleted VSS data persists on the magnetic platters until overwritten. On SSDs, TRIM limits what can be recovered.
- Deliver forensic documentation for insurance & law enforcement. We generate SHA-256 hashes, timestamped recovery logs, ransomware variant identification, & an independent audit report. Your insurer receives the full chain-of-custody documentation proving evidence integrity from seizure through recovery.
What Is Backup Poisoning and How Does It Affect Recovery Point Objectives?
Backup poisoning is the deliberate corruption of backup repositories during the attacker dwell period before encryption fires.
Your nominal RPO of 24 hours becomes an effective RPO of weeks or months once you discover that every recent backup is unrecoverable.
- Veeam VBK Header Tampering
- Attackers with domain admin credentials can modify Veeam backup metadata so the backup service reports successful jobs while the underlying VBK chain references encrypted or null blocks. We image the underlying repository drives offline through hardware write-blockers, then validate each backup chain against its catalog by checking block hashes against the metadata before any restoration is attempted.
- Datto and BDR Appliance Tampering
- Datto SIRIS, ALTO, and similar BDR appliances run on ZFS or hardware RAID. Attackers with appliance credentials can delete snapshots or corrupt the ZFS metadata to break the snapshot tree. We extract the underlying disks from the appliance chassis, image each member through write-blockers, and reconstruct the ZFS pool offline to walk the snapshot history for pre-dwell-period recovery points.
- Identifying Pre-Dwell-Period RPOs
Once we have offline images of every backup repository, we compare backup catalog dates against the suspected initial-access date in the threat actor timeline. Any backup created before the dwell period began is presumed clean.
Any backup created during the dwell period requires file-level integrity validation before restoration, because attackers commonly plant persistence mechanisms that survive a backup restore and re-trigger encryption days later. We perform this validation against backup data extracted from Veeam and Datto backup repositories before delivery.
How Do You Identify the Ransomware Family Hitting Your Network?
Cross-reference the file extension, the ransom note filename, and the encryption pattern against ID Ransomware and the No More Ransom Project.
Family identification matters because some strains have public decryptors, and some encrypt selectively in ways that affect which carving strategy works.
- File Extension and Ransom Note Triage
Some strains append a family-name extension to encrypted files (e.g., .ryuk, .akira, .conti). LockBit 3.0 and BlackCat generate a randomized extension per victim, so the extension alone does not identify the family. The ransom note filename and contents are the reliable signal.
Photograph the ransom note before any reboot. Do not edit, rename, or delete it; the original timestamps are evidence for your insurance carrier and law enforcement filing.
- Family-Specific Recovery Notes
- Different families behave differently against hardware-level recovery. We document variant-specific procedures on dedicated subpages where the recovery path materially differs from the general workflow: LockBit 3.0 recovery covers offline forensic imaging for LockBit-encrypted RAID arrays, and Ryuk recovery covers the legacy Ryuk variant that targeted Windows file servers and Active Directory hosts.
- When the Family Cannot Be Identified
- Newly emerged or heavily customized variants may not match any public signature. The hardware-level workflow does not depend on family identification; we still image through write-blockers, carve the raw images for unencrypted remnants and shadow copies, and recover whatever survived outside the encrypted byte ranges. Family identification only changes the answer to "is there a public decryptor we can apply to the imaged data."
What Documentation Does Cyber Insurance Require After a Ransomware Attack?
Cyber liability policies require forensic documentation proving evidence integrity. Attempting internal recovery without establishing a forensic baseline gives adjusters grounds to deny business interruption and ransom reimbursement claims.
- Pre-Imaging SHA-256 Hashing
- Before we connect any write-blocker, we generate SHA-256 cryptographic hashes of every affected drive at the raw block device level. These hashes establish a verifiable baseline proving no data was altered between seizure and imaging. The hash values, timestamps, and drive serial numbers go into the forensic log.
- Forensic Audit Trail
- Every recovery action is timestamped and logged: which engineer handled the drive, what tools were used, which sectors were read, and what files were extracted. This chronological documentation satisfies the chain-of-custody requirements that insurance adjusters and legal counsel review before approving payouts.
- Independent Reporting
We deliver a forensic incident report alongside the recovered data. The report includes hash verification results, a timeline of all recovery procedures, and the ransomware variant identification.
Your IT team can submit this directly to your insurer or attach it to a law enforcement filing. Read more about our physical and digital security protocols.
How Do You Recover Data from Ransomware-Encrypted Virtual Machines?
Ransomware targeting VMware ESXi or Hyper-V environments encrypts the virtual disk files (VMDK, VHD, VHDX) rather than individual guest files.
Recovery requires bypassing the hypervisor layer: we image the affected datastore LUNs offline through hardware write-blockers, then mount the virtual disk images at the sector level to read the guest file system directly.
- VMDK/VHDX Sector-Level Mounting
- We image the affected datastore LUNs offline using hardware write-blockers. PC-3000 Data Extractor mounts the virtual disk images at the sector level, bypassing the hypervisor and reading the guest file system directly from the flat file. If the ransomware only encrypted the VMDK descriptor or the first few extents, the remaining guest data is readable.
- Incomplete Encryption Carving
- Most ransomware encrypts in chunks; if the process was interrupted (power loss, detection, reboot), large portions of the virtual disk remain unencrypted. We parse the flat file extent by extent in a hex editor, identify the encrypted vs. unencrypted blocks, and carve recoverable files from the clean regions.
- Backup Repository Repair
- Attackers commonly target Veeam repositories and NAS-based backup shares before encrypting production VMs. We perform standard NAS recovery on these backup devices. Recovering a pre-attack Veeam backup set restores the entire VM state from before the encryption event.
How Do You Extract VMFS Data After ESXi Ransomware?
Ransomware variants like Akira and LockBit target VMware ESXi hypervisors through SSH tunneling or Active Directory integration exploits.
We disconnect the SAN or DAS storage from the compromised ESXi host, connect each drive to a hardware write-blocker, and extract data directly from the underlying RAID hardware without the hypervisor layer.
- Offline VMFS Datastore Parsing
ESXi ransomware encrypts .vmdk descriptor files and .vmx configuration files on the VMFS datastore. We disconnect the SAN or DAS storage from the compromised ESXi host, connect each drive to a hardware write-blocker, and reconstruct the underlying RAID array using Data Extractor Express RAID Edition.
Data Extractor then parses the raw VMFS file system directly, without the hypervisor layer. If the ransomware only encrypted the VMDK descriptor or the first few extents, the remaining guest OS data is readable from the unencrypted flat file regions.
- Targeting Backup Repository Drives
- Attackers commonly delete or encrypt Veeam backup repositories and NAS-based backup shares before encrypting production VMs. When the backup storage uses a separate physical array, we perform standard server data recovery on those backup drives. Recovering a pre-attack Veeam VBK backup set restores the entire VM state from before the encryption event without needing to decrypt anything.
How Do You Recover SQL Server Databases Hit by Ransomware?
Attackers brute-force exposed MSSQL ports and abuse the xp_cmdshell stored procedure to drop payloads that encrypt or destroy .mdf and .ldf database files.
We image the underlying host drives offline through hardware write-blockers and scan raw sectors for deleted SQL data pages that persist on mechanical platters until physically overwritten.
- xp_cmdshell Payload Deployment
- Campaigns like DB#JAMMER gain access through weak SA passwords on internet-facing SQL Server instances, enable xp_cmdshell, and use it to stage Cobalt Strike beacons and the FreeWorld (Mimic variant) ransomware binary on the host. The FreeWorld payload then encrypts the database files (.mdf data and .ldf transaction logs) and drops a ransom note.
- Raw MDF Page Carving from Offline Images
We image the underlying host drives offline using hardware write-blockers and scan the raw sectors for deleted SQL data pages and transaction log fragments. On mechanical drives, the deleted .mdf pages persist on the magnetic platters until physically overwritten.
We reassemble the recovered 8 KB SQL data pages into a consistent database structure. If the server used encrypted storage, the raw sector scan operates on the decrypted block device layer after we unlock the volume with the customer's BitLocker or LUKS key.
Does Our No Fix, No Fee Guarantee Apply to Ransomware Cases?
Our No Fix, No Fee guarantee applies to every ransomware case, with no non-refundable evaluation fees. We provide a file listing before delivery so you can verify the recovered data meets your needs before paying.
- Hardware-level imaging: We connect your drives to write-blocked forensic stations and create bit-for-bit clones using PC-3000, keeping originals untouched and offline. This prevents the ransomware payload from executing or encrypting additional sectors during the recovery attempt.
- Decryption and file carving: We cross-reference the ransomware variant against known decryptor databases, including the No More Ransom Project and ID Ransomware. If a public decryption key exists for your strain, we apply it to the cloned image. If no decryptor is available, we carve the raw image for unencrypted file remnants, Volume Shadow Copies, and deleted backup fragments that the attacker missed.
You only pay when we return usable files. See our pricing for current recovery rates.
How Much Does Ransomware Data Recovery Cost?
Price tracks the physical condition of the storage hardware & the number of drives we have to image. Not the ransomware variant, & not what the files are worth to you. A single drive that only needs offline imaging & carving lands in the same published tiers as any other job in this lab. Mechanical or controller damage moves it up.
Hard Drive Pricing: Backup Disks, NAS Members, RAID Members
Ransomware cases seldom arrive as one clean drive. The backup disk that was already dying, the NAS member the attacker sabotaged, & every RAID member pulled out of a poisoned repository price one drive at a time against these 5 tiers.
- Low complexity
- Low complexity
- Medium complexity
- High complexity
- High complexity
SATA SSD Pricing
An encryption write-load that pushed a SATA SSD into a controller safe-mode lock is billed as the firmware tier, not as a ransomware surcharge. What decides the tier is whether the controller still answers & the flash translator can be rebuilt in RAM, or whether the board needs component-level work first.
Multi-drive enterprise cases don't get a table. RAID arrays & NAS units are quoted individually against the member-disk count & the engineering time the reconstruction takes, because each member is imaged separately before any virtual assembly begins. There is no evaluation fee, every drive is handled in-house at the Austin lab, & no data, no fee covers the whole case. Rush handling is available: +$100 rush fee to move to the front of the queue.
See the particle counter test at the benchFrequently Asked Questions About Ransomware Recovery
Can you recover my files without paying the ransom?
What are Volume Shadow Copies and can ransomware delete them?
My backup drive failed during the attack. Can that data be recovered?
How do you image an infected drive without spreading the ransomware?
Does your No Data No Fee policy apply to ransomware cases?
Why can deleted shadow copies be recovered from HDDs but not from modern SSDs?
How do you reconstruct a RAID array that ransomware damaged?
Will cyber insurance cover data recovery if my IT team attempts repairs without chain-of-custody documentation?
How much does enterprise ransomware data recovery cost?
How long does enterprise ransomware data recovery take?
Should our company pay the ransom to get data back faster?
How does hardware-level recovery impact our RTO and RPO?
How do I identify which ransomware family hit my network?
Related Recovery Services
Offline forensic imaging for LockBit-encrypted arrays
Recover failed backup drives
Synology, QNAP, Buffalo devices
Multi-drive array reconstruction
Recover wiped or deleted data
Evidence-grade imaging
Don't Pay The Ransom Yet
Let us check your hardware for other options first. Secure, confidential, and isolated.
