Forensic Data Recovery
Chain of Custody, Write-Blocked Imaging, Published Pricing
We recover data from physically damaged storage devices while preserving evidence integrity. Every forensic recovery uses hardware write-blocking through our PC-3000 to prevent any modification to the source media. Chain of custody is documented from the moment your device arrives to the moment it ships back.
Evidence Integrity Preserved
Confidentiality
We sign strict NDAs upon request to guarantee client confidentiality. We are not HIPAA certified and do not sign BAAs. If your case requires HIPAA-compliant handling, we will tell you upfront rather than make claims we cannot back. For corporate investigations, litigation support, and HR matters, our NDA process covers the confidentiality requirements most firms need.
Standard vs. Forensic Recovery
| Approach | Goal | Method | Result for Evidence |
| Standard Recovery | Get the user's files back. | May alter the drive, clearing SMART data or repairing the file system to make it mountable. | Changes the metadata hash, breaking evidence integrity & risking exclusion. |
| Forensic Recovery | Get data while changing nothing on the source media. | Hardware write-blockers via PC-3000, imaged to E01 if requested. | Every step timestamped; the image stays admissible. |
Chain of Custody
Every forensic case follows the same four-step process. Each transition is logged and timestamped.
Intake
Diagnosis
Recovery
Return
Hardware Imaging with PC-3000
A forensic image is made by placing the source drive in a write-blocked state, then reading it bit-for-bit through the PC-3000. Where firmware stabilization is needed, it is performed in volatile RAM and every service-area interaction is documented. The output is a hashed, verifiable copy.
The PC-3000 from ACE Laboratory is the tool used by law enforcement labs and professional data recovery firms worldwide. It communicates directly with the drive's firmware through vendor-specific ATA and SCSI commands, bypassing the operating system entirely.
For forensic cases, the PC-3000 operates in write-blocked mode. The source drive operates in a write-blocked state regarding user data. Necessary firmware stabilization is performed in volatile memory (RAM) where possible, with all service-area interactions documented. The resulting image is a bit-for-bit copy that can be hashed (MD5, SHA-256) and verified against the original media.
Hardware-level write protection prevents any modification to the source drive during the imaging process.
E01 Forensic Format
Expert Witness Format (E01) includes built-in hash verification and case metadata. Available on request alongside raw DD images.
Hash Verification
MD5 and SHA-256 hashes generated at imaging time. Reproducible verification confirms nothing changed between acquisition and analysis.
Raw DD Image vs. E01
A raw DD image is a flat, byte-for-byte dump with nothing wrapped around it. An E01, the Expert Witness Format, carries that same sector data alongside case metadata & the MD5 hash computed the moment the image was acquired. Because that hash lives inside the file, anyone can recompute it later & prove the image hasn't changed since acquisition.
We produce either format. Examiners who plan to present findings in court usually ask for E01, since the embedded hashes carry the integrity proof with the evidence instead of in a separate log.
What We Recover
Damaged Evidence
Recovering data from phones, hard drives, or SSDs that have been smashed, water-damaged, or burned in an attempt to destroy evidence.
Corporate Investigations
HR cases, IP theft, departing employee devices. We image the drive and return it with a documented chain of custody. You provide the drive to your forensic examiner with the evidence integrity intact.
JTAG / Chip-Off
Direct memory extraction for unencrypted flash media and non-Apple mobile devices that cannot be accessed via standard USB/SATA interfaces. Not viable on Apple hardware with Secure Enclave encryption.
Chip-Off vs. Board Repair on Encrypted Devices
Chip-off recovery reads a desoldered NAND chip directly, & it works on unencrypted flash & older non-Apple devices. It fails on modern Apple T2 & M-series machines & hardware-encrypted NVMe drives, where the chip holds only ciphertext. The encryption key stays on the logic board, so the board itself has to be repaired.
Reading a desoldered die isn't as simple as dumping the flash. Even with no AES in play, the controller's proprietary data scrambling & LDPC error correction sit between the raw NAND & readable files. A dedicated NAND reader can pull the physical pages, but without the original controller's translation the output is unintelligible. On simple flash media a NAND chip-off is a real option; on a drive that leans on a live controller it isn't.
On an Apple machine with a T2 or M-series chip, the storage controller & the Secure Enclave that holds the encryption key both sit in the SoC on the logic board. Desolder the NAND & you get ciphertext the key never leaves to decrypt. The forensically sound path is component-level repair of the original board so its native controller & Secure Enclave authorize decryption the way they were designed to.
We don't crack, defeat, or work around the encryption; we bring the original hardware back to a working state. The tradeoffs behind a logic board swap versus board-level recovery decide which Apple cases are recoverable at all.
Board-level repair happens at the soldering station, not a clean bench. We localize a shorted rail under FLIR thermal cameras, reflow or replace controller-side components with a Hakko FM-2032 & Atten 862 hot air, & reball BGA packages on a Zhuo Mao station. The same procedures that revive a laptop logic board bring a hardware-encrypted solid-state drive controller back so it can talk to its own NAND again.
Forensic recovery uses the same pricing tiers as standard recovery. The price is based on the physical fault, not the legal context. There is no "forensic surcharge." Write-blocked imaging and chain of custody documentation are included.
HDD recovery ranges from $100–$2,000 across 5 tiers. SSD recovery ranges from $200–$1,500 across 5 tiers. Call (512) 212-9111 for a free estimate.
Hard Drive Recovery
- Low complexity
- Low complexity
- Medium complexity
- High complexity
- High complexity
SSD Recovery
Related Recovery Services
Standard and forensic HDD imaging
Flash storage forensic recovery
Mobile device chip-off extraction
Chain of custody and security protocols
Step-by-step recovery workflow
Attack response and offline imaging
Secure Evidence Recovery
Contact us to discuss your case requirements. NDAs available upon request.
