Recovery Software vs. Hardware Recovery
Wondershare Recoverit Alternative for Physical Drive Failures
Wondershare Recoverit is a logical recovery tool. It scans file system metadata, carves deleted files by signature, and rebuilds corrupted partitions. On a physically healthy drive, it does what it advertises. The problem starts when users run Recoverit on a drive that is clicking, not spinning, dropping off USB mid-scan, or reporting 0 GB capacity. In those cases, the drive has a hardware fault that no software can fix. Running a deep scan on failing hardware makes the outcome worse, not better.
When Recoverit Is the Right Tool
Recoverit scans the drive at the file system level: reading partition tables, directory entries, and unallocated space to locate deleted or damaged files. This works when the drive hardware is functional:
- The drive spins up normally and appears in BIOS/UEFI with the correct model number and capacity
- The drive is visible in Disk Management (Windows) or Disk Utility (macOS), even if the volume will not mount
- Files were accidentally deleted, the partition was formatted, or the file system corrupted after improper shutdown
- The drive is silent; no clicking, grinding, or beeping when powered on
In these scenarios, Recoverit, Disk Drill, R-Studio, PhotoRec, and similar tools all work. Professional lab recovery would be unnecessary overhead. For a free open-source imaging tool, see our ddrescue guide.
Recoverit vs. Professional Lab Recovery
The distinction is not about software quality. Recoverit is competent at what it does. The distinction is about what kind of failure your drive has.
| Capability | Wondershare Recoverit | Professional Lab (Rossmann) |
| Dead or Degraded Read/Write Heads | Cannot access the drive. Software hangs, freezes, or drive clicks. | Head replacement in ULPA clean bench. PC-3000 selective imaging with per-head maps. |
| Firmware Corruption (Service Area) | Drive not detected or shows wrong capacity. Software cannot see the volume. | PC-3000 terminal access to vendor-specific ATA commands. Rebuild translator tables, reload modules. |
| Apple T2 / M-Series Mac (Dead Board) | No software can reach the encrypted storage on a dead board. | Board-level microsoldering to restore logic board function. Data accessed through the original hardware encryption path. |
| SSD After TRIM Executes | On drives that return zeros after TRIM, it reads zeros from the TRIMmed blocks. Software reads what the controller hands it. | Recoverable only on a controller we can hold in diagnostic mode, and only before garbage collection erases the block. Honest about physical limits. |
| SSD Controller Lockup (SATAFIRM S11, 0 GB) | Cannot communicate with a locked controller. Drive invisible to OS. | PC-3000 SSD sends vendor-specific commands to reset the controller. |
| Pricing | Wondershare sells monthly, annual and perpetual licenses (source: recoverit.wondershare.com/buy/store.html). | HDD: $100–$2,000. SSD: $200–$1,500. No recovery fee if we don't recover data. |
If your drive clicks, does not spin, or shows 0 GB capacity, the right column applies. Stop running software and contact a lab.
Why Recoverit Freezes or Crashes Mid-Scan
When Recoverit hangs at a percentage, causes your system to lock up, or the drive disconnects during scanning, the software is not the problem. The drive is failing at the hardware level. Here is what is happening underneath:
A hard drive reads data by flying a magnetic head nanometers above a spinning platter. When a head is degraded, it reads some sectors but fails on others. The drive firmware retries each failed read internally before reporting an error to the OS. Those retries take seconds instead of milliseconds. Recoverit freezes because it is waiting for a reply that never comes quickly enough. With severely damaged heads, the drive clicks repeatedly as it attempts to recalibrate heads that can no longer position correctly.
Drive Dropping Off USB
When persistent read errors occur, the drive firmware may reset the SATA or USB interface. Consumer USB-SATA bridge chips (common in external enclosures) have short timeout thresholds and drop the connection when the drive stops responding. The scan stops; the drive disappears from your system. Some drives re-enumerate after a few seconds, others require a full power cycle. This is why external enclosures are unreliable for recovery scans on failing hardware.
Firmware Corruption
Hard drives store operating firmware partly on the platters in a reserved area called the Service Area (SA). If SA modules become corrupted, the drive may spin up but report a wrong model name, wrong capacity, or fail to complete its initialization sequence. Recoverit cannot interact with a drive that has not finished initializing because the drive itself does not know how to present its data to the host. Resolving this requires PC-3000 terminal access to read and repair the corrupted modules directly.
If Recoverit is stuck at the same percentage, stop the scan and power down the drive. Continued scanning with damaged heads scores the platter surface and can turn a recoverable case into a total loss.
Why Recoverit Fails on T2 and M-Series MacBooks
On 2018 and later MacBooks (any model with a T2 chip or Apple Silicon M1 through M4), the SSD NAND flash is hardware-encrypted. The encryption keys are managed by the Secure Enclave Processor (SEP), located on the T2 coprocessor in Intel Macs and integrated into the SoC on M-series Macs. This means:
- Desoldering the NAND chips and reading them on an external programmer returns encrypted data that is useless without the original SEP key. Chip-off recovery does not work on these machines
- Creating a bootable USB with Recoverit does not help if the logic board itself is the failure point. The SEP must be functional for any data access
The only path to data on a dead T2 or M-series Mac is board-level microsoldering to restore the logic board to a state where the SEP can decrypt the NAND. This is component-level rework under a microscope, not a software problem.
Why Software Recovery Fails on SSDs After Deletion
When you delete a file on an SSD, the operating system sends a TRIM command telling the controller those NAND flash blocks are no longer needed. The controller unmaps the logical addresses and schedules background garbage collection to electrically erase the physical cells. Unlike a hard drive, where deletion marks space as available but leaves magnetic data on the platters, this process destroys data at the physical layer.
TRIM is on by default on Windows 7 and later. On macOS it is on by default only for Apple-supplied SSDs; third-party SSDs need it enabled manually with the trimforce command, introduced in OS X 10.10.4. Most Linux distributions run periodic fstrim rather than discarding on delete. Where the OS does issue TRIM on deletion, it has normally already gone out by the time you realize the file mattered. If the drive returns zeros after TRIM, Recoverit will scan it and get zeros back from the TRIMmed blocks.
Recoverit can recover files from an SSD with file system corruption if TRIM has not run on the target blocks. It cannot recover files the controller has already TRIMmed. No software can. This is a physics constraint, not a software limitation.
SSD Controller Lockup: When the Drive Is Invisible
Some SSD failures leave the NAND data intact but make the controller stop communicating. The drive appears in your system with incorrect information or does not appear at all. One example:
Phison S11: SATAFIRM S11 Lockup
Phison S11-based SSDs can enter a firmware corruption state where the drive identifies as "SATAFIRM S11" with 0 bytes capacity. The NAND still holds all data. The controller locked up before it could translate physical NAND addresses into logical blocks. Recoverit cannot see a 0-byte drive. Our SATAFIRM S11 recovery process uses PC-3000 SSD to push the controller out of the lockup state.
In this case, the NAND flash contains the data. The failure point is the controller chip, which sits between the NAND and the host interface. Consumer software operates above the controller; it sends read requests through the OS and waits for the controller to respond. When the controller is the broken component, software requests never reach the data.
Recovered Video Files That Will Not Play
Recovered .mp4 and .mov files can show the right file size and still not open in any player. This happens because of how video container formats store their metadata.
MP4 and MOV files use a structure called the moov atom as a playback index. Many recording devices write the moov atom to the end of the file after the recording completes. When the file is fragmented across non-contiguous disk sectors, raw signature carving recovers the video data but cannot reconstruct the moov atom. The result: a file that looks correct in size but is unplayable because no player can locate the frame index.
When Running Recovery Software Causes Additional Damage
Recovery software cannot write to the original drive (if used correctly). The damage comes from forcing a failing drive to perform reads it is not capable of completing safely:
- Head Degradation Acceleration
- Recoverit's "Deep Scan" reads every accessible sector sequentially. On a drive with a weak head, this forces the degrading head to sweep across every platter surface. A professional imaging approach reads accessible areas first, skips bad regions, and returns to them in later passes using adjusted read parameters on PC-3000.
- MFT Overwrite from Software Installation
- Installing Recoverit to the same drive you are trying to recover from overwrites sectors. The Windows installer writes to the C: drive by default. If the deleted files were on C:, the Recoverit installer itself may overwrite the MFT entries or data blocks you need. This is documented in our software overwrite corruption guide.
- SMR Translator Corruption
- Many modern consumer HDDs use Shingled Magnetic Recording (SMR), where data tracks overlap. These drives maintain a persistent cache and translator table. Running a full scan on a failing SMR drive can force cache flushes that corrupt the translator, making the data inaccessible even to professional tools until the translator is rebuilt.
What Hardware Recovery Involves
Hardware-level recovery uses tools that interact with the drive below the operating system layer. Our primary tool is the PC-3000 (Portable III for HDDs, PC-3000 SSD for solid state drives), manufactured by ACE Lab. It sends vendor-specific ATA and NVMe commands.
For HDDs
- Head replacement in ULPA-filtered clean bench using matched donor parts
- Firmware module repair: translator table rebuilding, adaptive parameter correction, ROM extraction
- Selective imaging with per-head maps: accessible sectors first, bad regions in later passes
For SSDs
- Controller reset via PC-3000 SSD vendor commands for locked/bricked controllers
- PCB-level repair: failed voltage regulators, dead PMICs, shorted capacitors
- NAND swap to donor PCB with precision BGA rework when the original board is beyond repair
All work is performed in-house at our Austin, TX lab. Single location, no franchises, no outsourcing.
HDD Recovery Pricing
We quote based on the fault, not the perceived value of your data. Evaluation is always free. If we cannot recover data, there is no charge.
- Low complexity
- Low complexity
- Medium complexity
- High complexity
- High complexity
SSD Recovery Pricing
SSD recovery pricing reflects the complexity of controller-level and board-level work. NAND swap cases involve precision microsoldering.
Does Wondershare Recoverit work for logical data recovery?
Can Recoverit recover data from a clicking hard drive?
Why does Recoverit say it cannot scan my MacBook?
Can Recoverit recover deleted files from an SSD?
How does Recoverit's pricing compare to lab recovery?
Why are my recovered video files unplayable after Recoverit scanning?
How do I send my drive to you?
Related Recovery Services
Full HDD recovery service overview
SSD firmware and controller recovery
When Disk Drill freezes on failing hardware
When to use each approach
When EaseUS hits hardware limits
Transparent cost breakdown
Recoverit not working on your drive?
Free evaluation, no data no fee. Ship your drive to our Austin lab and we will tell you what is wrong before you owe anything.
