Split-Board Foldables | Mail-In to Austin, TX | From $500 | No Data, No Recovery Fee
Galaxy Z Fold and Z Flip Data Recovery
Mail your Fold or Flip to our Austin, TX lab from anywhere in the country. All the work happens there, in-house. One that went dark has almost always kept its files: a worn hinge interconnect can pass for board death while the encrypted storage sits intact, a dead inner display leaves the boards behind it alive, and repairing that fault is how the files come back.
Is the Data Still There When a Fold or Flip Goes Dark?
Both lines split their electronics across a main board & a sub-board joined through the hinge, carry one battery cell per half, & let liquid & dust in at the hinge. Where they differ is what you can do about a dead screen.
On a Fold or Flip with no power, we rule out the hinge interconnects before we call the main board dead. That's because a worn flex across the hinge can take the whole phone down while both boards are healthy.
Encryption doesn't change with the form factor. Your files decrypt on the original hardware once the phone boots & you type your own screen lock. Getting it to boot is our job; the unlock stays yours.
How Does a Worn Hinge Flex Mimic a Dead Main Board?
Each Fold & Flip has a main logic board & a separate sub-board. The power rails, battery interconnects, display signals & data lines between the two halves all cross the hinge on flexible printed circuits that bend with every fold.
Mechanical wear becomes an electrical fault. Teardown & board-repair community documentation ties worn hinge FPCs to four presentations: total power loss, shutdowns past a certain fold angle, charging failure, & false battery-temperature warnings.
Either a board repair gets spent on a flex fault, or a healthy battery gets replaced over a temperature warning the interconnect produced.
Dual Battery Cells Linked Through the Hinge
Each half carries its own cell, & the two cells link through those same hinge interconnects. A failed interconnect can look to the power management IC like a voltage imbalance or a thermal fault, & the phone then boot-loops or won't power on.
Triage stays power-first: a multimeter in diode mode reads each rail to ground, where a reading at or near 0.000 V is a hard short, & on a foldable the hinge interconnects sit on the suspect list beside every chip on both boards.
Which Ingress Rating Does Each Fold and Flip Generation Carry?
Foldable ingress ratings trail Samsung's slab flagships.
| Generation | Ingress rating |
| Galaxy Z Fold 2 and the original Z Flip | No ingress rating |
| Z Fold 3 and Z Flip 3 through Z Fold 5 and Z Flip 5 | IPX8; the X records zero certified dust protection |
| Z Fold 6 and Z Flip 6 | IP48 |
No Galaxy foldable through the IP48 Fold 6 & Flip 6 generation carries an IP68 rating. On the unrated & IPX8 models, community documentation follows particulate riding the hinge into the chassis, where it distorts speakers, punctures the hinge-routed interconnects, & attacks the inner OLED from underneath.
Liquid Entering at the Hinge Reaches Both Boards
Liquid that gets in at the hinge reaches the main board, the sub-board & the display driver at once. On a wet foldable, that means we trace shorts across several boards.
It's corrosion, not dampness. On a powered board the liquid bridges points at different voltages & becomes an electrolyte, dissolving metal off traces in one spot & plating it out as dendrites in another, & that runs fast while power is applied. Take a wet foldable off the charger & leave it switched off. Rice does nothing for corrosion forming under the chips.
Each board's corrosion gets photographed & mapped under the stereo microscope before any cleaning, since the residue pattern records the path the liquid took across both halves. Shields come off, every board is cleaned ultrasonically, & shorts get localized afterward, because hunting a short through active corrosion means chasing a target that keeps moving. The Samsung water damage recovery page covers that chemistry for the whole Galaxy line.
Does a Black Inner Screen Along the Crease Mean Lost Data?
The display gives out along the crease while the split boards, the storage, & the battery interconnects behind it go untouched. The phone can keep running blind under a dead panel. That makes it an access problem.
Opening a Foldable Carries Display Liability
Reaching either board or either battery means removing displays that community teardowns document as fragile enough to be destroyed during disassembly. Slab phones don't carry that risk. That risk applies even to a power-only diagnosis, so we tell you about it up front, before we open the phone.
Which Foldables Allow Blind PIN Entry Over USB-C?
It splits by line. DisplayPort Alt Mode carries video on the USB-C connector's SuperSpeed lane pairs, so the first question is whether your phone's port has those pairs.
| Models | Wired video-out | Samsung DeX | Route to your lock screen |
| Galaxy Z Fold 2 through Z Fold 6 | DisplayPort Alt Mode | Full DeX | USB-C hub with HDMI, a monitor, and a USB keyboard; you type the PIN |
| Original Galaxy Z Flip, Z Flip 3, and Z Flip 4 | None; the USB 2.0-only port has no SuperSpeed lane pairs | No DeX, wired or wireless | A temporary working display, or the intact board moved into a donor chassis |
| Galaxy Z Flip 5 | Basic DisplayPort Alt Mode mirroring over a USB 3.2 port | Disabled by Samsung in software | Mirrored screen on a monitor plus a USB keyboard; you type the PIN |
A Fold owner has something to try before shipping anything. With a hub carrying HDMI out, a monitor, & a USB keyboard, you enter your PIN, the phone unlocks, & DeX, Smart Switch, or MTP copies the files off. Screen repair is one route for a Fold, never the only one.
The original Z Flip, the Z Flip 3, & the Z Flip 4 have no such path. Their USB 2.0-only ports wire the D+ & D- pair alone, which leaves nothing for DisplayPort Alt Mode to reassign; the missing video-out is a missing set of conductors that no hub, cable, or adapter adds. What gets one of those three to its lock screen is a temporary working display, or a board move into a donor chassis, so you unlock it the ordinary way.
The Flip 5 moved to a USB 3.2 port whose lane pairs carry basic mirroring, which is enough for a blind unlock with a keyboard, but Samsung leaves DeX disabled on it, so the monitor shows the phone's own screen rather than a desktop. Samsung's own DeX page says the Z Flip series isn't compatible with DeX over a DeX or HDMI cable.
Auto Blocker and Maintenance Mode Can Close the Cable Path
Each of those routes enters your credential; none of them goes around it. Auto Blocker, when it's switched on, refuses commands arriving over the cable, & the Block USB connections while locked setting shuts USB access in a similar way. How that plays out depends on settings, the software build, & how long the phone has sat locked.
Maintenance Mode works differently. If you turned it on before the damage, the phone starts in an empty profile & your real data stays sealed, though not wiped, until you exit the mode with your credential on a working display. USB debugging won't help here either, since it had to be enabled before the screen died & the connecting computer's key needs approval on an unlocked screen.
When the cable route is closed on any model, a temporarily fitted working screen or board repair lets you unlock the phone normally.
Which Fold and Flip Models Carry Knox Vault?
Predating Knox Vault doesn't make those three unencrypted. They run file-based encryption with keys held in TrustZone, so your credential is still required & a removed storage chip still reads out as ciphertext.
No lab tool pulls the keys out of Knox Vault or TrustZone on a Qualcomm or Exynos Galaxy, ours included. A processor die or secure element that's been physically destroyed takes the keys & the files with it.
Your screen lock is part of the math too. Credential Encrypted storage opens only when your PIN, pattern, or password & the phone's secure hardware work together, while Gatekeeper & Weaver throttle wrong guesses inside that hardware. We fix the phone & you unlock it. Without your credential, a repaired Fold or Flip keeps its user data encrypted.
Knox Vault Changes What a Transplant Carries
A board past repair has one fallback: the processor, its stacked package-on-package RAM, & the storage package move to a donor board together as a paired set. On Fold 3, Flip 3, & later boards, the discrete Knox Vault secure element, the chip bench technicians call the EEPROM or Pin Code IC, has to travel with that set, or the phone boots on the donor & then refuses a PIN you know is right.
Boards from the Fold 1, the Fold 2, & the original Z Flip keep key custody inside the processor, so no separate Vault chip moves. On every generation the storage chip stays with its processor, because the keys that unlock it live in that processor's secure hardware. The stacked RAM carries no cryptographic pairing. It travels with the processor because splitting the stack adds reballing risk.
Heavy Samsung underfill makes that transplant a long job of underfill removal & reballing.
The packaging where a controller-death read is even physically possible is the legacy & budget eMMC case, & eMMC data recovery covers what that involves. It is a different situation from these foldables, where the storage package leaves with its processor as a paired set.
Fingerprint and Face Unlock Never Replace Your PIN
Biometrics gate your credential without standing in for it. Until the first unlock after power-on, the phone takes only the PIN, pattern, or password, so a dead fingerprint reader or failed face-unlock hardware changes nothing about the data. On Knox Vault foldables the templates stay inside Knox Vault, & on no model does a template work as a substitute key.
Bench Order for a Dead or Wet Foldable
- Intake questions. A prior flash raises the question of whether the one-way Knox warranty fuse already tripped, & the display liability of opening a foldable gets stated here.
- A wet board gets no power. We map the corrosion on both boards under the stereo microscope first, then we take the shields off & put each board through the ultrasonic cleaner.
- Diode mode across both boards. We read every rail to ground with a multimeter, & we treat the hinge interconnects as electrical suspects before we condemn either board.
- Current at the port. Draw from a known-good charger is read next, as a pointer toward the fault rather than a verdict on it.
- Component replacement. The failed part comes off & the replacement goes on with a Hakko FM-2032 on an FM-203 or FX-951 base, an Atten 862 hot air station & a Zhuo Mao BGA rework station.
- Your unlock. The phone boots, you enter your own credential, & it decrypts its own storage so the files can come off.
The no-power presentation across the rest of the Galaxy line is mapped on the Samsung won't turn on recovery page, & restart cycles get their own treatment on Samsung boot loop recovery.
What Can Software Reach on a Fold or Flip That Won't Boot?
Odin & Download Mode only write signed firmware & can't read your data out. The wrong CSC choice wipes the phone. If the real fault is failing storage, reflashing the phone can finish the data off.
Deleted files hit a separate wall. On a modern Galaxy, permanently deleting a file destroys its key & the blocks behind it get trimmed. That's why no scan brings deleted internal-storage files back. On a modern Galaxy, a factory reset destroys the keys for every file at once. Check Samsung Gallery Trash, which holds deleted photos for about 30 days on a working, unlocked phone. Also check the My Files trash, the Google Photos or OneDrive trash, & any Smart Switch backup you made to a computer. An end-to-end encrypted Samsung Cloud backup needs your recovery code when none of your other devices can still open it.
Secure Folder is its own Knox container with its own keys & credential. PC backups through Smart Switch skip it & Samsung ended its cloud backup, so it comes back from a booting phone, your Secure Folder credential, & a direct transfer while it's open. If anyone flashed unofficial firmware trying to revive the phone, a tripped Knox fuse withholds that container for good.
Factory Reset Protection recovers nothing for anyone. It appears after a reset has already destroyed the keys, & we never take that work on.
When Is Fold or Flip Data Gone for Good?
Seven conditions end a foldable job, & we name them at the free evaluation. Physics & cryptography set them. No tool changes that, & neither does paying more.
- A cracked or electrically destroyed processor die. Its keys die with the silicon, so moving the storage chip to a donor board won't recover anything.
- A physically destroyed Knox Vault secure element on a Fold 3, Flip 3, or later board. The keys go with the destroyed secure hardware.
- A dead controller inside the storage chip. On an encrypted phone nothing behind a dead storage controller can be read in plaintext.
- Factory reset already run. It destroyed the keys for every file at once.
- No one knows the screen lock. The credential is part of the key derivation, so the repaired phone stays sealed.
- Secure Folder behind a tripped warranty fuse. The fuse is one-way, & the container's keys stay withheld after it trips.
- An end-to-end encrypted Samsung Cloud backup that nothing can open. Samsung does not store the recovery code. Once the code and every device that could open the backup are gone, nothing opens it.
Anything else comes down to which fault sits between you & your files. We find that fault at the evaluation, which is free.
What Does Fold or Flip Data Recovery Cost?
No data, no fee. Free evaluation. No diagnostic charges.
The work happens in-house at our Austin, TX lab at 2410 San Antonio Street. Rossmann Repair Group was founded in 2008. We have one location, no franchises, & we don't outsource. No data, no recovery fee.
Service is mail-in: ship it to Austin from any state. For the full generation matrix across the Galaxy line, start at Android & Samsung data recovery, or book the free evaluation & get a firm quote.
See the particle counter test at the benchQuestions About Foldable Hinges and Screens
Why does my Flip shut off when I open it past a certain angle?
Will a USB-C hub and monitor work on my Z Flip 4?
Does an IPX8 Fold or Flip keep dust out of the hinge?
My Fold's inner screen went black along the crease. Is my data gone?
Can you recover a Fold or Flip if I forgot the PIN?
What does Galaxy Z Fold or Z Flip data recovery cost?
Related Samsung Recovery Pages
The generation matrix, the encryption reality, and the fault catalog
Port current, diode-mode readings, and per-rail prognosis
Why power drives corrosion and how liquid boards get cleaned
Restart cycles, failed updates, and why flashing comes last
Is your Fold or Flip dead, wet, or stuck behind a black screen?
Take it off the charger and leave Odin closed until a meter has been on the board. Evaluation is free & the quote is firm. No data, no recovery fee.
