When a server drive fails, database repair software cannot help because it cannot read the files. We recover the drive first using PC-3000 and clean bench techniques, then repair the database structure from the recovered image. SQL Server, Exchange, MySQL, Oracle, QuickBooks, PostgreSQL, and MongoDB. No data, no fee.
Enterprise database recovery is a two-layer process. Layer one images the failed physical storage (SAS/SATA/NVMe drive, SAN LUN, RAID member, or ZFS vdev) in write-blocked mode.
Layer two parses the recovered sector-level clone to extract database files (MDF/LDF, EDB, ibdata1, datafiles, WAL segments) and repair page-level, block-level, or tablespace-level corruption. Software-only repair tools fail on failing storage because the file system cannot mount the volume.
Why Does Database Repair Software
Why Does Database Repair Software Fail on Crashed Drives?
Database repair software fails because it requires a functional file system to read page headers. When the underlying drive has failed heads, corrupted firmware, or damaged platters, the operating system cannot mount the volume and every repair tool reports the same result: file not found.
Operate on files that already exist on a readable filesystem. They parse database page headers, rebuild indexes, & patch torn pages. None of them can read a drive with failed heads, corrupted firmware, or damaged platters.
Server crash failure sequence
A drive develops bad sectors or a mechanical fault, the OS retries reads aggressively, the database engine detects I/O errors & marks the database as suspect or dismounts the store, and the administrator discovers that the underlying drive is no longer accessible.
Two-layer approach
We handle both layers. The physical recovery produces a clean sector-level image of the drive using PC-3000. The database repair phase operates on that image, never on the original media.
What Hardware Failures Cause Database
What Hardware Failures Cause Database Corruption?
Database engines don't corrupt themselves in isolation. SQL Server Error 824 (torn page detected), Exchange Dirty Shutdown, & PostgreSQL PANIC entries in pg_log all trace back to the same root cause: the underlying storage returned bad data or went offline mid-write. The database engine is the messenger; the drive is the problem.
SQL Server Error 824 from SAS/SATA Drive Degradation
Error 824 means SQL Server requested a data page & the storage layer returned a page with a mismatched checksum. On enterprise hard drives, the drive returns that sector without reporting a read error: the mismatch was written to the media with valid sector-level ECC, after an interrupted write or corruption introduced before the data reached the platter.
Running DBCC CHECKDB WITH REPAIR_ALLOW_DATA_LOSS on a drive with active bad sectors destroys the recoverable pages it can't validate. We image the drive first using PC-3000 Express with adaptive read parameters that retry failing sectors at different head offsets, capturing pages that a single-pass read would miss. The MDF repair runs on the cloned image, not the failing media.
Exchange Dirty Shutdown from RAID Controller Failure
When a Dell PERC or HP Smart Array controller drops a drive mid-write, the Exchange Information Store service terminates without flushing its transaction logs. The EDB database enters Dirty Shutdown state. Error -541 (JET_errLogFileSizeMismatch) appears when the log files on the failed drive are truncated or unreadable.
After we image each RAID member drive & reconstruct the virtual array, we extract the EDB & transaction logs from the recovered volume. If log files are missing sectors from unreadable regions on the original media, we replay the surviving log chain against the cloned copy, without touching the original drives. Replay reaches as far as the log chain survives and no further.
PostgreSQL PANIC on ZFS Pool Import Failure
PostgreSQL running on ZFS-based NAS appliances (TrueNAS, FreeNAS) writes its WAL (Write-Ahead Log) segments sequentially. When a drive in the ZFS pool develops unreadable sectors in the middle of a WAL segment, the pool goes into a DEGRADED or FAULTED state. PostgreSQL logs PANIC: could not locate a valid checkpoint record because the WAL file it needs for crash recovery is physically damaged.
Forcing a ZFS pool import with zpool import -f on a degraded pool writes to the original disks: any read-write import replays the intent log and commits new transaction groups, which can overwrite the state a later rewind would need. We clone each pool member individually, reconstruct the ZFS vdev layout from the cloned images, & extract the PostgreSQL data directory with the WAL segments intact for proper crash recovery.
SQL Server MDF and LDF Corruption at the Page Level
SQL Server stores data in 8 KB pages grouped into 64 KB extents. When the storage layer returns corrupted bytes, the page checksum in the header fails and SQL Server raises Error 824 (logical consistency) or Error 823 (operating system returned an I/O error).
The damaged page is logged to msdb.dbo.suspect_pages with its file_id, page_id, & event_type. Every page-level recovery starts with that row.
Torn Writes and the Double-Write Buffer
A torn write occurs when SQL Server issues an 8 KB page write but the underlying storage only commits a partial 512-byte or 4 KB sector before a power loss or controller fault. The page header CRC or torn-page detection bits no longer match the page body. Unlike InnoDB, SQL Server does not use a double-write buffer; it relies on PAGE_VERIFY CHECKSUM & the transaction log to detect and replay partial writes.
The LDF file holds the log records that preceded the torn write. If the drive is still readable, we image the MDF & LDF as a matched pair (same LSN snapshot), then walk the log forward from the MinLSN of the last full checkpoint.
Transactions that committed before the torn write can be reapplied from the log. Transactions that were mid-flight at the moment of failure are rolled back using the undo records written to the LDF.
Page Splits and Index B-Tree Corruption
When a clustered index page fills & SQL Server performs a page split, it allocates a new page, moves half the rows across, & updates the sibling pointers in the B-tree. If the storage layer fails mid-split (one sibling updated, the other not), the index becomes logically inconsistent. Queries walking the B-tree hit orphaned records or infinite loops.
We detect the broken sibling pointer by comparing m_prevPage & m_nextPage fields in every page of the index, then rebuild the chain from the recovered image so the database can be attached cleanly via CREATE DATABASE ... FOR ATTACH_REBUILD_LOG or a full dump-and-reload.
Log Chain Breaks and LDF Truncation
The LDF is a circular file composed of VLFs (Virtual Log Files).
A log chain break occurs when a VLF is physically unreadable or when a tail-log backup was not taken before an accidental restore. SQL Server reports The log scan number passed to log scan in database errors & refuses to bring the database online.
Running ALTER DATABASE ... SET EMERGENCY followed by DBCC CHECKDB ... REPAIR_ALLOW_DATA_LOSS is destructive: it deallocates pages the repair cannot validate. We image the LDF first and parse the surviving VLFs to identify the last consistent LSN. Every decision after that is executed against the cloned image, never the original database.
PostgreSQL WAL Replay and Base Backup Reconstruction
PostgreSQL durability depends on the Write-Ahead Log. Every data modification is written to pg_wal/ (formerly pg_xlog/) as a 16 MB segment before the corresponding page in a table or index is flushed. When the server crashes, the recovery process replays committed WAL records from the last checkpoint LSN forward to bring the cluster to a consistent state.
When the storage fails mid-write, that replay is where the damage surfaces.
pg_control and the Checkpoint LSN
The global/pg_control file is 8 KB. It carries the database system identifier, the catalog version, the checkpoint location, the timeline ID, & the minimum recovery point LSN. If pg_control is zeroed or the checkpoint LSN points into a missing WAL segment, the postmaster refuses to start & logs PANIC: could not locate a valid checkpoint record.
We rebuild pg_control from the most recent base backup combined with WAL segment headers that survived on the failing drive. pg_resetwal is avoided on the original cluster because it advances the LSN past unrecoverable records; instead, we run it on a copy of the recovered image once all surviving segments have been replayed.
Walking WAL Records with pg_waldump
Each WAL segment contains XLOG records identified by a resource manager (Heap, Btree, Hash, GIN, SPGist, Transaction, XLOG). We feed the recovered pg_wal directory into pg_waldump to walk forward record by record.
The last valid XLOG_CHECKPOINT_SHUTDOWN or XLOG_CHECKPOINT_ONLINE record identifies the LSN that becomes the PITR target for the recovered cluster.
TOAST and Relfilenode Extraction
PostgreSQL stores large values (over 2 KB) in the TOAST table associated with the parent relation. If a TOAST relfilenode is damaged, rows in the parent table return missing chunk number errors.
We extract surviving TOAST chunks by their chunk_id & chunk_seq, reassemble the detoasted value, & reinsert it against the parent row's OID. When pg_class is damaged, we map relfilenodes back to relation names by matching the on-disk relfilenode to the recovered catalog or to the base/<dboid>/ directory listing on the imaged drive.
MySQL InnoDB Tablespace Extraction
InnoDB organizes data into tablespaces composed of 16 KB pages. The shared system tablespace ibdata1 holds the data dictionary, the rollback segments, the doublewrite buffer, & the change buffer.
With innodb_file_per_table=ON, each table also has its own .ibd file. Recovery strategy depends on which file survived.
Per-table .ibd surviving, ibdata1 damaged
The .ibd file carries the tablespace header, the index root page (FIL_PAGE_INDEX), & the data pages. We parse each .ibd directly using undrop-for-innodb, rebuild the schema from the serialized dictionary records InnoDB stores inside each .ibd tablespace, read with ibd2sdi (MySQL 8.0), & emit each table as a CSV or SQL dump. The damaged ibdata1 is not required for this path.
ibdata1 required (shared tablespace, MySQL 5.5 or file-per-table disabled)
Every table lives inside ibdata1. If the file is partially readable, we scan the image for pages whose FIL header contains the FIL_PAGE_INDEX type (0x45BF), extract the space_id & index_id from each page, & group pages into their parent B-trees. The data dictionary is reconstructed by locating the SYS_TABLES & SYS_INDEXES cluster pages inside space_id 0.
Redo log (ib_logfile0/1) corruption
InnoDB refuses to start when ib_logfile0 or ib_logfile1 is truncated or corrupted. Setting innodb_force_recovery=6 lets the server start but blocks writes & can mark pages inconsistent. We extract data from the recovered image with force_recovery set to 1 or 2, dump every table, & rebuild the database in a new initialized instance rather than attempting a destructive in-place redo replay.
MyISAM legacy tables (.MYD and .MYI)
Older MySQL installs still carry MyISAM tables. The .MYD file stores row data, & the .MYI file stores the index. A corrupt .MYI is rebuilt with myisamchk -r against the recovered .MYD on the cloned image, never the original.
Oracle ASM Disk Group Reconstruction
Oracle ASM (Automatic Storage Management) presents raw LUNs as ASM disks grouped into disk groups. Each disk carries a header block containing the disk group name, the disk number, & the allocation unit size.
Datafiles, redo logs, control files, & the SPFILE live inside these allocation units & are referenced by ASM file numbers.
Disk Header Scan and Disk Membership
When the disk group fails to mount because headers are damaged, we image every LUN member individually and rebuild the disk group roster from the disk number, disk group name, & allocation unit size recorded in each header. Failure-group membership has to come back with it; without it, ASM mirroring (NORMAL or HIGH redundancy) cannot be unwound correctly.
File Directory and Extent Mapping
The ASM file directory maps ASM file numbers to the list of allocation units that store the file.
Once the file directory is recovered, datafiles are located by filename pattern (+DATA/ORCL/DATAFILE/SYSTEM.256.123456789) & their AUs are pulled & concatenated into a flat .dbf file outside ASM.
Control File and SPFILE Recovery
Oracle will not open a database without a control file. The control file carries the database SCN, the datafile list, the redo log thread members, & the RMAN backup metadata.
If the control file AUs are damaged, we extract them from the ASM image, parse the datafile and control-file block headers, & rebuild a consistent control file via CREATE CONTROLFILE ... RESETLOGS against the extracted datafiles. The SPFILE (ASM file number in the parameter file directory) is recovered the same way & converted to a PFILE for bootstrap.
Storage Layer Context: SAN, RAID, and NAS Under the DBMS
A database engine error is a messenger. The file format (MDF, EDB, .ibd, .dbf, pg_wal) sits on top of a stack: filesystem, volume manager, block device, physical drive. Every database recovery starts with the lowest layer that actually lives on spinning platters or NAND cells, not the DBMS itself.
SAN LUN on Fibre Channel or iSCSI
SQL Server & Oracle instances frequently mount LUNs from a Dell EMC Unity, NetApp FAS, HPE 3PAR / Primera, or Pure Storage FlashArray over FC or iSCSI. The LUN is a virtual block device; the physical data lives on the member drives inside the shelf. We image those member drives write-blocked, reconstruct the LUN offline using the array's stripe geometry, then hand the virtual block device to the filesystem parser.
Hardware RAID (Dell PERC, HP Smart Array, LSI MegaRAID)
Mid-range database servers run on PERC H730, H740, or HP P440ar controllers presenting RAID 5, 6, or 10 logical drives. When the controller fails or multiple members drop, forcing a rebuild on the original drives overwrites parity & destroys recoverable data.
We image each member, detect stripe size & parity rotation from the cloned images (left symmetric, right asymmetric, Q-shift for RAID 6), & reconstruct the array in software. Original drives remain untouched throughout. See our RAID data recovery process for the full workflow.
ZFS zvol and NAS Volumes (TrueNAS, Synology, QNAP)
PostgreSQL & MySQL on TrueNAS zvols or Synology Btrfs volumes depend on the pool's health. A DEGRADED raidz2 vdev still serves I/O. Once redundancy is exhausted & a block fails its checksum, ZFS fails that read & returns an I/O error to the database engine rather than handing it corrupted data.
We clone each pool member, import the pool read-only on a lab bench using zpool import -o readonly=on -R /mnt/recovery against the clones, & extract the DBMS data directory before any scrub or resilver touches the original drives. See our NAS data recovery workflow for the matching NAS procedure.
Ceph RBD and Distributed Block Storage
Kubernetes-hosted databases (PostgreSQL operators, Percona XtraDB clusters) frequently consume Ceph RBD images backed by BlueStore OSDs spread across many drives. When enough OSDs fail to breach the CRUSH failure domain, the RBD image becomes unreadable. We image every failed OSD drive, extract the BlueStore object metadata, & reassemble the RBD image object by object (4 MB default object size) until the database files inside the ext4 or XFS filesystem on the image are accessible.
VMFS Datastores and Virtual Disk Chains
Production VMs running SQL Server or Oracle often live on VMFS datastores with snapshot chains (a base VMDK plus delta disks). A damaged snapshot breaks the chain & the running VM hangs. We image the underlying VMFS extents, parse the VMFS metadata, walk the snapshot chain from base to current, & flatten it into a single consistent VMDK before mounting the guest filesystem to extract the database files.
Two-Layer Recovery Workflow
Database recovery at Rossmann runs in two layers. Layer 1 is physical drive repair: PC-3000 imaging, head swaps in a ULPA-filtered clean bench, & firmware correction.
Layer 2 is logical database structure repair on the recovered sector-level clone. Both layers run in-house at our Austin, TX lab. One lab handles both.
Layer 1: Physical Drive Recovery
Write-blocked forensic imaging using PC-3000 with conservative retry settings
Head swap in ULPA-filtered clean bench if heads have failed
Firmware repair for drives reporting wrong capacity, wrong model ID, or refusing to spin
Bad sector management with adaptive read parameters to maximize data yield from degraded platters
Full sector-level clone to a healthy target drive before any database work begins
Layer 2: Database Structure Repair
Mount recovered MDF/EDB/InnoDB files from the cloned image in an isolated environment
Page-level integrity scan to identify torn pages, checksum failures, and orphaned records
Hex-level repair of damaged page headers and allocation metadata
Transaction log reconstruction when LDF/E00 log files are missing or corrupt
Final export: restored database files, mailbox PSTs, or raw table dumps depending on engine
How We Extract Databases from Failed Server Arrays
Production databases rarely sit on single drives. SQL Server, Exchange, & Oracle instances typically run on RAID 5, 6, or 10 arrays behind a Dell PowerEdge PERC or HP Smart Array controller. When the controller fails or multiple drives drop simultaneously, forcing a rebuild destroys parity & overwrites the data you need.
Clone each member drive individually. Every RAID member is imaged. SATA members are imaged write-blocked on a PC-3000 Express or Portable III, and SAS members are imaged on a PC-3000 SAS card. We image each drive to a healthy target, handling bad sectors with adaptive read parameters. No data is written to the original media.
Reconstruct the virtual array offline. Using the cloned images, we detect the stripe size, parity rotation, & drive order. For RAID 5 & RAID 6 arrays, we virtually reassemble the array without writing to any original disk, then parse the LVM or NTFS volume from the reconstructed block device.
Extract & repair database files. Once the virtual array is mounted, we locate the MDF, EDB, InnoDB tablespace, or other database files & run engine-specific repair on the recovered copies. The original drives remain untouched throughout.
Consumer SSD Failures in Database Servers: Phison and SMI Controller Panics
Small business database servers are sometimes built using budget consumer SATA SSDs as primary storage. When an unexpected power loss occurs while the controller is flushing its internal SLC cache to TLC/QLC NAND, the Flash Translation Layer (FTL) mapping table corrupts. The drive drops to 0 bytes or becomes unresponsive.
Phison PS3111-S11 firmware corruption
Stops reporting its capacity after power loss during cache flush. We connect the drive to PC-3000 SSD, enter Technological Mode via ATA Vendor Specific Commands, & rebuild the FTL translator from surviving NAND service area copies. Database files cached on the SSD at the time of failure are recoverable if the blocks holding them were not already deallocated by TRIM.
Silicon Motion SM2259XT (BSY state)
Enters a locked BSY (Busy) state showing 0 bytes or incorrect capacity after FTL corruption. PC-3000 SSD loads a volatile microcode loader into the controller RAM and rebuilds the translator. This is not something standard recovery software can do, because it needs the controller to be functional first.
TRIM/UNMAP note: on modern SSDs with TRIM enabled, deleted blocks are unmapped from the translation layer and their contents stop being readable. If the database engine deleted records before the crash, those records are unrecoverable once the blocks holding them have been erased.
Marvell 88SS1074 Database Drive Failures
Budget SATA SSDs running the Marvell 88SS1074 controller are common in small business database servers where cost drives the hardware decision. When the firmware boot sequence corrupts after a power loss or NAND degradation event, the drive enters a permanent BSY (Busy) state. The SATA bus reports the drive but returns no data; the operating system hangs on mount attempts, and the SQL Server or PostgreSQL instance cannot start.
Recovery requires PC-3000 SSD with the Marvell utility ACE Lab designates the Venus family for this controller. The utility rebuilds the Flash Translation Layer from surviving NAND metadata. Once the FTL is reconstructed, the drive responds normally and we image the full capacity to extract the database files.
NVMe Database Cache Failures: Phison E12 and E16 ROM Mode
High-performance NVMe SSDs with Phison E12 (PCIe 3.0) and E16 (PCIe 4.0) controllers are frequently deployed as L2ARC read caches or ZFS SLOG write caches in database arrays. During unexpected power loss while the controller is flushing its FTL mapping table to NAND, the drive locks into a protective ROM state. The server BIOS still detects an NVMe device, but not with the identity or the capacity the drive is supposed to report.
Standard NVMe management tools (nvme-cli, Samsung Magician, Intel SSD Toolbox) cannot communicate with a drive in ROM mode because the controller's main firmware never loads. We connect the drive to PC-3000 SSD, enter Technological Mode via the PCIe interface, and upload a custom microcode loader directly into the controller's RAM. The loader replaces the corrupted firmware in volatile memory, allowing us to reconstruct the FTL from surviving NAND service area copies and extract the cached database segments.
Lenovo Server NVMe: Marvell 88SS1093 Timeout Errors
Enterprise database servers from Lenovo (ThinkSystem SR series) and OEM partners using Ramaxel-branded NVMe drives frequently run the Marvell 88SS1093 controller. When NAND cells degrade past the controller's internal ECC threshold, or a firmware translation fault corrupts the logical-to-physical block map, the drive generates persistent timeout errors during database I/O. SQL Server logs Error 823 (I/O error) and PostgreSQL reports "could not read block" failures that trace back to the NVMe timeout.
We connect the drive to PC-3000 SSD and work from the controller side rather than the normal host I/O path, then image the drive and extract the database files.
Recovering Databases from Encrypted Server Drives
Many Windows Server deployments use BitLocker, and Linux production servers frequently use LUKS full-disk encryption. When the underlying drive fails, the physical failure prevents access to the encrypted volume.
After imaging, the encryption prevents reading the database files without the original key. We handle this in two separate phases.
Phase 1: Physical recovery of the encrypted volume
The failing drive is connected to PC-3000 Express or Portable III in write-blocked mode. We create a sector-level clone of the entire encrypted partition to a healthy target drive, including the BitLocker metadata header and LUKS key slots. Bad sectors are handled with adaptive read parameters; the clone captures every readable sector without writing to the original media.
Phase 2: Decryption & database extraction
Once the physical clone is complete, you provide the BitLocker recovery key or LUKS passphrase. We mount the encrypted volume on the cloned image and extract the database files (MDF, EDB, InnoDB tablespace, or PostgreSQL data directory). If the database uses SQL Server Transparent Data Encryption (TDE), the database master key and certificate must also be available; without it, the MDF file contents remain encrypted even after the volume is unlocked.
We don't break or bypass encryption. Recovery requires the original recovery key, passphrase, or TDE certificate. Without credentials, the encrypted data is mathematically unrecoverable regardless of the physical condition of the drive.
Database Recovery from Virtual Machine
Database Recovery from Virtual Machine Hosts
Production databases frequently run inside VMware ESXi, Hyper-V, or Proxmox VE virtual machines. When the host server fails, the database files are locked inside VMDK, VHDX, or raw disk images on a VMFS, ReFS, or ZFS datastore. Software tools can't reach the database because the virtualization layer is broken.
Image the physical host drives. Each drive from the host (or SAN shelf) is cloned via PC-3000 in write-blocked mode, exactly as with a bare-metal RAID array recovery.
Reconstruct the datastore. The VMFS, ReFS, or ZFS volume is reassembled from the cloned images. We locate the target VM's virtual disk files (VMDK, VHDX, or QCOW2) and verify their integrity.
Mount the virtual disk & extract database files. The virtual disk is mounted as a loopback device. We navigate the guest OS file system to locate the MDF, EDB, InnoDB tablespace, or PostgreSQL data directory, then run the appropriate database repair on the extracted files.
Accidental VM deletion, snapshot corruption, & SAN LUN failures are all recoverable if the underlying physical storage still contains the VMDK/VHDX data blocks. TRIM on thin-provisioned datastores is the exception; if VMFS UNMAP has already zeroed the blocks, those sections are permanently gone.
Supported Database Engines
We recover SQL Server (MDF/NDF/LDF), Exchange Server (EDB), MySQL & MariaDB (InnoDB tablespace files), Oracle (datafiles, ASM diskgroups), QuickBooks (QBW company files), PostgreSQL data directories, MongoDB (WiredTiger collection files), & SharePoint content databases. The physical drive recovery process is the same regardless of database engine.
DBCC REPAIR_ALLOW_DATA_LOSS and eseutil /p are destructive operations. They delete data they cannot validate.
If the corruption originates from a physical drive problem, these commands destroy data that a proper drive recovery would have preserved. Power down the server and contact us before running repair utilities.
How Much Does Database Recovery
How Much Does Database Recovery Cost?
Database recovery pricing is based on the physical condition of the drive, not the database engine. The database repair phase is included at no additional cost.
Why Recover Databases With Rossmann
Why Recover Databases With Rossmann Repair Group
Physical drive repair & logical database structure repair run in one lab with no outsourcing. Five published pricing tiers based on drive condition. Database repair is included at no additional cost.
Free evaluation before any paid work begins. No data, no fee. Direct access to the engineer doing the work.
Two-layer recovery
Physical drive repair (PC-3000, head swaps, firmware correction) followed by logical database structure repair. One lab handles both.
Multi-engine support
SQL Server MDF/NDF, Exchange EDB, MySQL InnoDB, PostgreSQL. The drive recovery is universal; the database repair adapts to each engine's on-disk format.
Transparent pricing
Five published tiers based on drive condition. Database repair is included.
Direct engineer access
Talk to the person doing the work. No sales scripts, no call center.
No evaluation fee
Free assessment of drive condition and recovery feasibility before any paid work begins.
Image-first workflow
Every drive is forensically imaged before any repair attempts. Original media is never modified. All database repair runs against the cloned image.
High-availability database deployments (Always On Availability Groups, Exchange DAG, MySQL Galera, Oracle RAC, PostgreSQL streaming replication) replicate transactions across nodes to survive single-node failure. They do not survive shared-storage failure, correlated firmware bugs, or logical corruption that propagates through the replication channel before detection. When the failure crosses the replication boundary, every replica needs to be treated as an independent recovery target.
Shared-Storage Failure on RAC and DAG
Oracle RAC and stretched Exchange DAG configurations share a SAN-backed storage layer between nodes. A dual-disk failure during a RAID 5 or RAID 6 rebuild, a controller cache battery failure on a Dell PERC, or a SAN firmware panic takes down every clustered instance simultaneously.
We image the underlying SAN drives, reconstruct the RAID geometry offline, then rebuild the ASM disk group or VMFS datastore from the cloned LUNs. Datafile and EDB extraction runs against the recovered virtual storage, never the original disks.
Replicated Logical Corruption
When an Always On primary writes a torn page or an Exchange DAG active copy commits a corrupt log record, synchronous replicas accept the bad page before any health check fires. We compare LSN watermarks across every cloned replica and identify the highest clean checkpoint that predates the corruption event. The same approach applies to PostgreSQL hot-standby clusters and MySQL Group Replication: the GTID or LSN history determines which clone is the recovery base.
Database Servers on Virtualized Hosts
Most production database servers now run inside VMware, Hyper-V, or KVM guests on shared infrastructure. When the underlying host loses its datastore (failed RAID, VMFS metadata corruption, accidental LUN deletion), the database guest goes offline with the rest of the host.
We recover the physical host drives, rebuild the datastore, and extract VMDK or VHDX virtual disks for database file recovery. See virtual machine data recovery for the full host-level workflow.
NAS-Backed Database Storage
Smaller deployments (development, QA, mid-market accounting) often run database files on a Synology, QNAP, or TrueNAS share over NFS or iSCSI. When the NAS array degrades or its btrfs volume reports unrecoverable read errors, the database engine sees I/O timeouts and either shuts down or marks pages suspect. We image the NAS drives, reassemble the btrfs or ZFS pool offline, and extract the database files from the recovered share for repair.
Encrypted Database Volumes
SQL Server TDE, Oracle TDE, and full-disk encryption (BitLocker, LUKS, VeraCrypt) on database volumes remain a recovery requirement, not a blocker. We image the failing drive first, then mount the cloned volume with the customer-supplied recovery key. See encrypted data recovery for the key-handling workflow.
Server-Class Drive Failures
Enterprise SAS drives in 24/7 production fail differently than the desktop SATA drives most recovery advice is written for, and they are imaged on different hardware. See server data recovery for SAS-specific imaging procedures and hard drive data recovery for the underlying drive-level repair workflow.
How Do You Secure Database Drives in Transit and During Recovery?
Enterprise database drives travel under a documented chain of custody. The drive is logged on intake, imaged in write-blocked mode on the PC-3000 Express or the Portable III, with SAS drives imaged on the PC-3000 SAS card, and processed on air-gapped workstations that have no internet route.
NDAs can be executed before shipment. Recovered MDF, EDB, ibdata1, and pg_wal files are returned on customer-supplied or new media; original drives are returned untouched.
B2B database recoveries carry a different security posture than consumer drives. The MDF, EDB, ibdata1, or pg_wal contents on a single SAS drive can include payroll, PHI, intellectual property, and customer PII covered by contractual obligations the customer owes their downstream clients.
Our handling protocol documents the drive every step from intake to return shipping, and the technical processing happens on isolated infrastructure. See our broader data security posture for the lab-wide policy that applies to every recovery.
Intake logging and write-blocked imaging
Each drive is photographed on receipt, its serial number and slot label recorded against the case ID, and connected to PC-3000 Express or Portable III in write-blocked mode, with SAS members imaged on the PC-3000 SAS card. The original drive is never modified; imaging flows through native hardware or software write-blocking to a separate, customer-isolated target drive. Multi-member RAID and SAN intakes preserve slot order so the array geometry can be reconstructed without guessing.
Air-gapped processing for hex-level database repair
After imaging, MDF, LDF, EDB, ibdata1, .ibd, .dbf, and pg_wal files are mounted on diagnostic workstations that have no outbound network path. Page-level repair, B-tree reconstruction, ASM file directory parsing, and WAL replay run inside this isolated environment. Our hex-level repair process for damaged database pages never touches a cloud-connected machine; see our full recovery process for the workflow that wraps every case.
NDA execution before drive shipment
For enterprise customers with contractual confidentiality obligations to their own clients, we execute a mutual NDA before the drives ship. Customer templates are accepted; a baseline NDA is also available on request via help@rossmanngroup.com. Engagement scope, retention period for the recovered image, and key-handling procedures for TDE, BitLocker, or LUKS keys are written into the engagement record at intake.
Multi-member array handling and post-recovery media disposition
For failed RAID arrays and SAN intakes, every member drive is logged independently; cloned images stay segregated by case ID on encrypted internal storage. Retention of the recovered image after delivery is agreed with the customer at intake.
Original drives ship back via the same carrier path the customer used, tracked end-to-end. Customers who require shred-on-return for physically failed media receive a destruction certificate.
Production database recoveries run differently from consumer drive jobs. The customer is usually a DBA or a CTO who needs a defensible recovery point objective, a defensible recovery time objective, and a written forensic trail their downstream auditors will accept. This section documents what we commit to and how the engagement is structured before a drive ever ships to the Austin, TX lab.
RTO and RPO targets by database engine
Storage-layer RTO is bounded by drive condition. Read-only imaging of a healthy-but-degraded SAS or NVMe member completes in 3 to 5 business days per drive. Drives requiring donor head swaps or PCB transplants on helium HDDs add 4 to 8 weeks depending on parts availability.
RPO is bounded by transaction log integrity on the recovered image. The targets below describe what the engine permits once imaging is complete and the cloned volume is mounted on an air-gapped workstation.
Engine
RPO floor (storage permitting)
PITR mechanism
Notes
SQL Server (MDF/LDF)
Last hardened LSN on a clean LDF stripe
Tail-log backup + RESTORE LOG WITH STOPAT
Locally-committed-not-replicated transactions are recoverable when the primary's LDF survives intact on the recovered image; in-flight uncommitted transactions are rolled back during recovery and cannot be salvaged.
MySQL InnoDB (ibdata + .ibd)
Last redo log LSN flushed to ib_logfile
Replay of ib_logfile0/1 against recovered ibdata1
The RPO ceiling depends on how InnoDB was configured to flush its redo log at commit time.
Exchange EDB
Last clean checkpoint (Enn.chk) plus replayable Enn.log range
Log replay against the cloned EDB and log directory
Dirty Shutdown is recoverable when the required log generation range survives; missing generations break the chain and cap the RPO at the last clean log.
PostgreSQL (pg_wal)
Last XLOG_CHECKPOINT_ONLINE LSN with surviving WAL segments
Replay to a recovery target LSN
pg_control reconstruction from base backup + WAL headers is performed when the original pg_control is zeroed; the recovered cluster starts as a PITR target.
Oracle (datafiles + redo)
Last applied redo SCN on a clean group
RECOVER DATABASE UNTIL CHANGE n
ASM diskgroup reconstruction precedes any datafile-level repair; the ASM file directory and disk header blocks are parsed from cloned LUNs before opening the database.
We do not publish a single "recovery time SLA" that ignores drive condition, because storage-layer RTO is set by physics and parts availability, not by ticket queue policy. The achievable RPO is communicated in writing after imaging is complete and the log chain on the cloned volume has been parsed.
Direct engineer access during the engagement
A production database recovery is a forensic engagement. The customer's DBA needs to confirm LSN ranges, validate page IDs, and decide which recovery point is acceptable for their commit semantics.
That conversation does not survive a tiered support queue. Every B2B engagement is routed to the engineer doing the imaging and the database-layer repair.
Imaging-phase technical contact
Once intake completes, the imaging engineer's direct line and email are provided to the named DBA or incident commander. Drive condition, head-stack status, donor-part requirements, and image completeness percentages come from that engineer, not a case manager reading a script. Multi-member RAID jobs route to the same engineer for the duration of the imaging phase so that slot order, geometry hypotheses, and parity reconstruction decisions are owned by one person.
Repair-phase database engineer
After imaging, the engineer handling MDF, EDB, ibdata1, or pg_wal repair is introduced. Page-level decisions (which clone becomes the recovery base, which LSN to set as the recovery target) are discussed with the customer DBA before they execute on the cloned image. When the DBA requests a specific recovery_target_lsn, that instruction goes to the engineer doing the work, in writing, with a timestamp.
Out-of-hours availability for active incidents
Standard lab hours are 10 AM - 6 PM. For active production incidents where the recovered image needs to be applied during a customer maintenance window outside those hours, the assigned engineer is reachable by the direct contact established at intake to walk through restore-target selection and validation queries against the recovered database. Reach the lab during business hours at (512) 212-9111.
Pricing structure for enterprise engagements
Pricing follows the published RAID and server drive pricing per member drive plus the database-layer repair quote after imaging. There are no diagnostic fees, no rush-tier upcharges billed separately from the recovery quote, and no recovery fee if the database cannot be made consistent on the cloned image.
Forensic image hashing and evidence integrity
Chain-of-custody documentation is only as defensible as the integrity of the underlying image. For engagements that will feed an internal audit, an insurance claim, or external forensic review, the cloned image is hashed and the hash is logged against the case ID. The forensic image becomes the working artifact; the original drive is sealed and not re-mounted unless an additional imaging pass is required because of read-error retries during the initial clone.
SHA-256 hash of the forensic image
After imaging completes on the PC-3000 Express, the Portable III, or the PC-3000 SAS card, the resulting raw image (.dd or PC-3000 task file equivalent) is hashed with SHA-256 on the imaging workstation. The hash is recorded against the case ID and the drive serial number; the same hash can be re-computed by the customer against the returned image to confirm bit-for-bit integrity. RAID and SAN intakes get one hash per member drive, with the slot label preserved.
Bad-sector and read-retry log
Imaging tools produce a per-LBA log of every sector that required retry and every sector that returned a final read failure after exhausting retries. That log is attached to the engagement record.
When a downstream auditor asks why a specific database page was unrecoverable, the answer references the LBA range in the imaging log, not a generic "bad sectors" explanation. See the full recovery process documentation for how imaging, repair, and verification are sequenced.
Image retention after delivery
After delivery is confirmed by the customer, the cloned image and any intermediate repair artifacts stay on encrypted internal storage for the hold window agreed at intake, then are erased.
Customers requiring physical destruction of returned media that cannot be reused receive a destruction certificate covering the original drives.
Read-only working copies for downstream analysis
When the customer's internal forensic team needs to inspect the same image we worked from (typical when the recovery is part of a broader incident response), a read-only copy of the hashed image is provided alongside the recovered database files. The customer's analysts can mount and parse it without modifying the copy retained for the hold window, and the SHA-256 hash lets both teams confirm they are looking at the same bytes.
Trust signals
Database Recovery FAQ
What types of databases do you recover?
SQL Server (MDF/NDF/LDF), Exchange Server (EDB), MySQL/MariaDB (InnoDB tablespace files), Oracle (datafiles, ASM diskgroups), QuickBooks (QBW company files), PostgreSQL data directories, and MongoDB (WiredTiger collection files). The physical drive recovery process is the same regardless of database engine. The logical repair phase differs by format.
Can you recover a database from a physically failed drive?
Yes. Software-only database repair tools require the drive to be readable. When the underlying drive has failed (clicking, firmware corruption, bad sectors), we recover the raw data using PC-3000 and clean bench techniques first, then repair the database structure from the recovered image.
How is database recovery priced?
Pricing follows our standard drive recovery tiers based on the physical condition of the drive: From $250 for file system issues, $600–$900 for firmware repair, $1,200–$1,500 for head swaps. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. Database structure repair is included at no additional charge. No data, no fee.
Do you need our entire server?
Usually just the drives containing the database files. For hardware RAID configurations, send all member drives and label each drive's slot position before removal.
How long does database recovery take?
Single-drive recoveries with healthy reads: 3-5 business days. Firmware repair: 3-6 weeks. Head swaps: 4-8 weeks. RAID arrays with multiple failed members add additional time for per-member imaging. +$100 rush fee to move to the front of the queue.
Why does SQL Server mark a database suspect or Exchange report Dirty Shutdown?
Both conditions occur when the database engine detects I/O anomalies from the underlying storage. SQL Server marks a database as suspect (Error 824, torn page detected) when it can't read a data page consistently. Exchange reports dirty shutdown when the EDB transaction logs are incomplete or the drive returned corrupted sectors during a write. In both cases, the drive itself is usually developing bad sectors or has a degraded RAID stripe. Running DBCC CHECKDB with REPAIR_ALLOW_DATA_LOSS or eseutil /p on physically failing storage will permanently destroy database pages that a proper drive recovery would have preserved.
What is the difference between logical database corruption and physical drive failure?
Logical corruption means the drive hardware is healthy but the database file structure is damaged (torn pages, orphaned records, mismatched checksums). Software repair tools can fix this. Physical failure means the drive itself has failed heads, corrupted firmware, or bad sectors. The database files are inaccessible because the storage layer is broken. We handle both: PC-3000 imaging recovers the physical layer, then database-specific repair tools address logical corruption on the recovered image.
Can you recover a database from a BitLocker or LUKS encrypted server drive?
We don't break encryption. We recover the physical drive first using PC-3000, creating a sector-level clone of the failing media. Once the clone is on a healthy drive, you provide the BitLocker recovery key or LUKS passphrase, and we mount the encrypted volume to extract the database files. SQL Server Transparent Data Encryption (TDE) adds a second layer; the database master key must also be available for the MDF files to be readable after extraction.
Can you recover a database running inside a VMware or Hyper-V virtual machine?
Yes. We image the physical host drives, reconstruct the VMFS or ReFS datastore, locate the VMDK or VHDX virtual disk files, then mount the virtual disk to access the database files inside. The database repair phase runs on the extracted MDF, EDB, or InnoDB files from the virtual disk image. Physical host failure, SAN LUN corruption, & accidental VM deletion are all recoverable if the underlying storage is intact.
Is rush service available for database recovery?
Yes. +$100 rush fee to move to the front of the queue. Rush moves your case to the front of the imaging queue, which is the bottleneck for most server recoveries. The database repair phase after imaging is typically fast (hours, not days) since it operates on an already-recovered image.
Can you recover SharePoint content databases from a failed SAN or RAID array?
Yes. SharePoint stores all sites, documents, & lists inside SQL Server .mdf content databases. When a SAN or Dell PERC RAID array drops multiple drives, the SharePoint front-end can't connect. We image the failed SAS & SATA drives individually with write-blocked sector-level imaging, reconstruct the virtual array's block size & parity rotation in software, then extract the raw SharePoint .mdf files. Database repair runs on the recovered image; the original drives remain untouched.
Can you recover a database encrypted by ransomware?
If ransomware encrypted MDF, EDB, or InnoDB files while the drive was still physically healthy, recovery depends on whether the original unencrypted data was overwritten or just marked deleted. On HDDs without TRIM, we can often recover pre-encryption file versions from unallocated sectors using PC-3000 imaging. On SSDs with TRIM enabled, the original blocks are permanently erased. See our ransomware data recovery page for the full process.
Can you recover ERP or accounting databases like SAP HANA, NetSuite, or Sage?
Yes. ERP systems store financial data in standard database engines: SAP HANA uses its own column-store format on XFS or ext4 volumes, SAP Business One runs on SQL Server or HANA, Sage runs on SQL Server or Pervasive PSQL, and NetSuite is Oracle-based. The drive recovery process is identical regardless of the ERP layer. After we image the failed drive with PC-3000, we extract the database files & run engine-specific repair. The ERP application reads the repaired database once it's restored to a functional server.
Can you recover legacy database formats like FileMaker, Lotus Notes, and IBM Db2?
Yes. We recover proprietary & legacy database engines including FileMaker (.fmp12), Lotus Notes (.nsf), IBM Db2, Paradox (.db), and Sybase ASA. The physical drive recovery process using PC-3000 is identical regardless of the database software. Once we clone the failing drive at our Austin lab, the raw legacy database files are extracted from the recovered volume for restoration on a healthy server.
Why does our database NVMe cache drive report the wrong capacity in BIOS?
A capacity that does not match the drive means the controller never finished loading its normal firmware and is answering the BIOS from a fallback state. When the Flash Translation Layer (FTL) mapping table corrupts during a power loss, the controller locks into a protective ROM state. Software recovery tools can't reach the drive in this state. We use PC-3000 SSD Technological Mode to upload a microcode loader into the controller RAM, reconstruct the FTL, & extract the cached database files.
How do you recover a database from a failed SAN or iSCSI LUN?
SAN LUN failures typically involve multiple drives in a RAID group behind a Dell EMC, NetApp, or HP MSA controller. We image each physical drive individually via SAS or SATA write-blocked channels. After cloning, we reconstruct the LUN's block layout (stripe size, parity type, drive order) from the cloned images in software. Once the virtual LUN is reassembled, we mount the VMFS, NTFS, or ext4 volume and extract the database files for repair. The original SAN drives are never written to.
What if our server runs multiple databases on the same drive array?
We recover all databases from the same imaging pass. After the physical recovery produces a clean sector-level clone, every database file on the recovered volume is accessible: SQL Server MDF files, Exchange EDB stores, MySQL data directories, and application files. There's no per-database charge for the physical recovery. The drive condition determines the price, not the number of databases stored on it.
How do you recover an SQL Server MDF after a torn page (Error 824) on a SAN LUN?
We stop all writes to the LUN immediately. The failed page is recorded in msdb.dbo.suspect_pages with its file_id, page_id, & event_type. We image the underlying SAN member drives write-blocked with adaptive read parameters, reassemble the LUN offline, & extract the MDF and LDF together. Every repair decision after that runs against the cloned image. DBCC CHECKDB with REPAIR_ALLOW_DATA_LOSS is never used; it discards the very page we are trying to recover.
Can you recover a PostgreSQL cluster when pg_control is zeroed and WAL segments are missing?
Yes. pg_control holds the checkpoint LSN, timeline ID, & database system identifier. If pg_control is zeroed, the postmaster refuses to start. We image the failed drive, reconstruct pg_control from the most recent base backup plus surviving WAL segment headers, then feed the recovered pg_wal directory into pg_waldump to walk forward record-by-record and identify the last valid XLOG_CHECKPOINT_SHUTDOWN or XLOG_CHECKPOINT_ONLINE record. Missing segments are flagged; we deliver the data directory as a PITR (point-in-time-recovery) target at the last consistent LSN.
What does MySQL InnoDB tablespace extraction look like when ibdata1 is corrupted?
ibdata1 holds the system tablespace: the data dictionary, rollback segments, & double-write buffer. If ibdata1 is damaged but per-table .ibd files survive (innodb_file_per_table=ON), we parse the .ibd pages directly using undrop-for-innodb or equivalent tooling, extract the schema from the .frm or .sdi files, & rebuild each table as a CSV or SQL dump. If ibdata1 is required (shared tablespace, MySQL 5.5 without file-per-table), we image the drive, identify surviving FIL_PAGE_INDEX pages by signature, & reconstruct the dictionary from the space_id & index_id fields recorded in each page header.
How do you reconstruct an Oracle ASM disk group when disk headers are damaged?
ASM disks carry a header block that identifies the disk group name, disk number, & allocation unit size. When headers are damaged, we image every member LUN and rebuild the disk group membership from the metadata that survives on each member. Control files, datafiles, & redo logs are located by their ASM file numbers & extracted to a flat filesystem for Oracle RMAN-based restore.
Do you diagnose the storage stack below the DBMS (iSCSI, FC LUN, ZFS zvol, Ceph RBD)?
Yes. A DBMS error is a messenger for a storage problem one, two, or three layers down. A PostgreSQL "could not read block" can trace to an ext4 bad sector, which traces to a ZFS zvol checksum failure, which traces to a degraded raidz2 vdev, which traces to a failed SAS drive behind a Dell PERC H730. We document the full stack on intake (database engine, filesystem, volume manager, block device, physical array) and image the layer where the data actually lives: the physical drives, not the virtual mount. The DBMS file format only matters after the storage stack underneath is reconstructed.
Can you recover an SQL Server Always On Availability Group when both replicas are corrupt?
Yes. Always On replicates transaction log records between primary and secondary replicas, so a logical corruption written on the primary often propagates to every synchronous secondary before anyone notices. We treat each replica as an independent recovery target: image the underlying drives or LUNs behind every replica, extract the MDF and LDF files from each, then compare LSN watermarks across copies. The replica with the highest clean LSN before the corruption event becomes the recovery base. If the corruption is hardware-driven on one node (bad RAID member, failed SAS cable retransmits), the intact secondary is the copy we work from. We never run DBCC CHECKDB REPAIR_ALLOW_DATA_LOSS on either replica during this process; it would discard the page versions we are reconstructing from.
How do you recover an Exchange Database Availability Group when multiple DAG members fail?
An Exchange DAG can hold up to 16 copies of each mailbox database across its members. When two or more members fail simultaneously (typically a shared storage incident on a converged SAN, or a controller firmware bug taking down both nodes in a stretched DAG), the active copy can mark itself FailedAndSuspended and refuse to mount. We image each surviving DAG member's EDB and transaction log volumes, identify the copy with the most recent clean checkpoint via eseutil /mh on the cloned image, and replay outstanding log files (Enn.log through Ennnnn.log) against that copy offline. Mailbox extraction runs against the recovered EDB without touching the production environment; PST or live-mailbox import happens after Microsoft Exchange Information Store accepts the repaired database in a lab Exchange instance.
Can you recover a MySQL Galera or Group Replication cluster after a split-brain or quorum loss?
Yes. Galera writesets and Group Replication GTIDs synchronize transactions across nodes, but a network partition combined with a storage failure can leave every node refusing to bootstrap (each thinks it might not be the most current). We image the InnoDB data directory on every node, parse the gtid_executed table or grastate.dat file from each clone, and identify the node with the highest sequence number that also has a consistent ibdata1 system tablespace. The recovered data directory is restored to a single-node MySQL instance for verification before the customer rebuilds the cluster from a known-good base.
How do you recover Oracle RAC when the shared ASM storage on the SAN fails?
Oracle RAC nodes share a single set of datafiles, control files, and online redo logs on ASM disk groups exported from a SAN. When the SAN loses multiple LUNs (failed RAID rebuild, controller cache battery failure, dual-disk failure on RAID 5), every RAC instance crashes simultaneously because the shared storage is gone. We image each physical SAN drive behind the affected LUNs, reconstruct the RAID geometry offline, then rebuild the ASM disk group by parsing the ASM disk headers on each cloned LUN. Control files identify datafile locations by ASM file number; we extract each datafile to a flat filesystem and hand them off for RMAN restore on a single-instance Oracle on a fresh server. The original SAN drives remain write-blocked throughout.
How does storage-layer RPO/RTO impact database recovery after a catastrophic RAID failure?
RPO (Recovery Point Objective) is bounded by transaction log integrity. When a Dell PERC or HP Smart Array controller drops two members of a RAID 5 mid-write, the LDF, Enn.log, or pg_wal segments on the failed stripe are physically truncated. The RPO ceiling becomes the last LSN that exists on a clean stripe across every member drive after we image each one (each member imaged write-blocked; SATA members on the PC-3000 Express). RTO depends on whether heads are intact (3-5 days for read-only imaging) or require donor head swaps (4-8 weeks). The DBMS-level RPO target the customer wrote into their DR runbook is meaningless until the storage layer is reconstructed; we publish the achievable RPO after imaging completes, not before.
Can you execute Point-in-Time Recovery (PITR) across a physically damaged PostgreSQL WAL segment?
Standard PITR requires a continuous WAL chain from the base backup forward. If a 16 MB segment in pg_wal/ is physically damaged (unreadable sectors on the failing drive), recovery stops at that boundary. We image the failing drive to pull back as much of that segment as the media still returns, then deliver the data directory as a PITR target at the last consistent LSN. Full PITR past a destroyed segment is impossible.
What happens if our Always On Availability Group primary replica suffers a hard drive crash mid-transaction?
If the primary replica's NVMe or SAN drive fails before a synchronous-commit acknowledgement reaches the secondary, the secondary's last hardened LSN trails what the primary already committed locally. The tail of the log on the dead primary contains those locally committed records the secondary never received. We image the primary's drive (NVMe via PC-3000 Portable III, SATA via PC-3000 Express, all in write-blocked mode) and deliver the recovered MDF and LDF pair to the DBA. Whether those locally committed records can be carried forward depends on the log file surviving intact on the recovered image; where the log is damaged, Microsoft's own guidance applies and the transactions committed after the last log backup are lost. ACID semantics: in-flight uncommitted transactions are rolled back during recovery and cannot be salvaged; only locally-committed-not-replicated transactions are recoverable.
Can you recover SQL databases trapped inside a corrupted Veeam or Commvault backup repository?
Yes. Veeam .vbk & .vib files & Commvault chunk libraries are themselves databases stored on a ReFS, NTFS, ZFS, or XFS volume behind a RAID array. When the underlying array fails, the backup files become structurally truncated & Veeam Explorer or Commvault CommCell refuses to mount them. We image every member of the failed repository array using PC-3000, reconstruct the volume offline, & return the .vbk, .vib, or Commvault chunk files intact so the backup software that wrote them can mount them again.
How to Ship Server Drives
How to Ship Server Drives for Database Recovery
We serve all 50 states through mail-in data recovery. Server drives require more careful packing than consumer drives because enterprise SAS drives & RAID members must arrive with their slot positions documented.
Label each drive with its slot number before removal. Double-box enterprise SAS drives. Include the database engine name & file names if known.
Label each drive before removal. Use masking tape & a marker. Write the slot number (0, 1, 2...) and the server model. For RAID arrays, the slot order determines stripe reconstruction.
Wrap each drive individually. Use anti-static bags if available. Wrap in bubble wrap. Never let bare drives touch each other in transit.
Ship in a sturdy box with 2+ inches of padding. Double-box for enterprise SAS drives. FedEx & UPS both work. Carrier declared-value coverage applies to the physical hardware only, not the data stored on it.
Include a note. Database engine (SQL Server, Exchange, PostgreSQL), file names if known (e.g., the .mdf filename), & your contact info. The more context we have, the faster the diagnosis.
Ship to: 2410 San Antonio Street, Austin, TX 78705. Local Austin drop-offs accepted during Mon-Fri 10am-6pm CT. Call (512) 212-9111 before shipping if you have questions about packing a specific server configuration.
“HIGHLIGHT & CONCLUSION
******Overall I'm having a good experience with this store because they have great customer services, best third party replacement parts, justify price for those replacement parts, short estimate waiting time to fix the device, 1 year warranty, and good prediction of pricing and the device life conditions whether it can fix it or not.”
