Micron Enterprise SSD Data Recovery
Micron manufactures its own NAND flash and builds enterprise SSDs using enterprise-grade controllers for data center deployments. The 5400 series (SATA), 7450 series (NVMe U.3/E1.S, Micron proprietary controller), 9400 series (NVMe U.3, Microchip NVMe 3016 controller), and 6500 ION (232-layer TLC NVMe priced at QLC tiers) pair high-density NAND with enterprise-grade firmware, power loss protection, and AES-256 encryption. For consumer Crucial/Micron SSDs (MX500, P3, P5 Plus, OEM 2400/3500), see our Crucial data recovery page.
SSD from $200 | No Data, No Fee | Free Evaluation | Since 2008
Micron Enterprise SSDs We Recover
5400 Series (SATA)
5400 PRO (TLC, 1 DWPD), 5400 MAX (TLC, 5 DWPD). 2.5-inch SATA, 240GB to 7.68TB. Proven enterprise SATA controller architecture.
7450 Series (NVMe U.3/E1.S/M.2)
7450 PRO (TLC, 1 DWPD), 7450 MAX (TLC, 3 DWPD). NVMe Gen4, 480GB to 15.36TB. PLP capacitors.
9400 Series (NVMe U.3)
9400 PRO (176-layer TLC, 1 DWPD). Microchip NVMe 3016 controller, 16-channel Gen4. Up to 30.72TB. Data center high-performance workloads.
6500 ION (TLC NVMe)
232-layer TLC NVMe in U.3/E1.L form factors. Up to 30.72TB. Marketed at QLC price points with TLC write endurance and 4K indirection.
PC-3000 SSD with vendor-specific Micron enterprise access
10 min read
Micron Enterprise SSD Recovery
How Micron Enterprise SSD Recovery Works
Micron enterprise SSDs pair Micron-manufactured NAND with enterprise-grade controller silicon tailored for data center reliability. Unlike consumer Crucial SSDs (which use Silicon Motion, Phison, or the Micron DM02A1), the 5400, 7450, 9400, and 6500 ION use controllers specific to the enterprise product line (notably the Microchip NVMe 3016 in the 9400 series and proprietary Micron NVMe silicon in the 7450). SSD data recovery on Micron enterprise drives requires vendor-specific access through PC-3000 SSD to bypass firmware lockouts, read NAND contents below the FTL layer, and rebuild corrupted flash translation tables. We evaluate every enterprise drive for free, provide a firm quote, and charge nothing if we cannot recover your data.
Micron 5400: SATA Enterprise Failures
The Micron 5400 is the current-generation SATA enterprise SSD, replacing the older 5300 series. It ships in two endurance tiers: the 5400 PRO (1 DWPD, read-mixed) and 5400 MAX (5 DWPD, write-intensive). Both use Micron 176-layer 3D TLC NAND with a proprietary SATA controller. Capacities range from 240GB to 7.68TB in the standard 2.5-inch 7mm form factor.
The 5400 includes power loss protection capacitors, but the primary failure mode for this drive is endurance exhaustion on write-heavy workloads. When TLC NAND cells degrade past their retention threshold, the controller increments SMART attribute 202 (Percent Lifetime Used). At 100%, the firmware transitions the drive to write-protect mode. On some firmware revisions, the drive instead becomes completely inaccessible, failing to respond to standard SATA IDENTIFY commands.
Micron 7450: NVMe U.3 Power Loss and FTL
Micron 7450: NVMe U.3 Power Loss and FTL Corruption
The Micron 7450 is the mainstream NVMe enterprise SSD for mixed-use data center workloads. It ships in three form factors: 2.5-inch U.3, E1.S, and M.2 22110. The 7450 PRO (1 DWPD) targets read-heavy workloads; the 7450 MAX (3 DWPD) handles write-intensive applications. Both use Micron 176-layer 3D TLC NAND with a Micron proprietary NVMe controller and onboard DRAM for FTL caching.
The 7450 includes tantalum PLP capacitors on the PCB rated to flush the DRAM write cache to NAND during power loss. Capacitor degradation is the hidden risk. Tantalum capacitors lose effective capacitance under sustained high-temperature operation (typical in dense server chassis with inadequate airflow). After 3-5 years at elevated temperatures, the PLP capacitors may no longer hold sufficient charge for a complete flush. A power event at this point corrupts the FTL because the write cache cannot be safely committed.
The 7450's Micron controller stores FTL metadata in dedicated NAND blocks with redundancy. When PLP-related corruption damages the primary FTL copy, PC-3000 SSD can attempt to reconstruct the mapping from the secondary FTL metadata and NAND page headers. The success of this reconstruction depends on how many NAND blocks received partial writes during the unprotected power loss event.
SSD Pricing
Micron Enterprise SSD Recovery Pricing
SSD Recovery Calculator
Estimate Your Micron SSD Recovery Cost
What type of SSD do you have?
Shomari Hohn
Aravind Udayakumar
David Dachenhaus (DDock)
Ludwig Jonsson
LaCie
9400 Series
Micron 9400 PRO: 16-Channel NVMe Architecture and Recovery
The Micron 9400 PRO is a U.3 NVMe Gen4 enterprise SSD with capacities up to 30.72TB. It pairs Micron 176-layer 3D TLC NAND with a Microchip NVMe 3016 (PM8628C1-F3EI MorrisTown) 16-channel controller. The high channel count distributes I/O across a wide array of NAND dies to deliver the IOPS required for demanding data center workloads.
The dense channel architecture complicates recovery. The controller manages a large array of NAND dies with complex FTL mapping. No commercial recovery tool exposes a diagnostic mode for these enterprise controllers. That limits recovery to what the controller itself will still serve: imaging the namespace while the drive responds, and board-level work to bring a failed controller back far enough to respond at all.
AES-256 hardware encryption on the 9400 prevents chip-off as a fallback. The encryption keys are generated per-namespace and bound to the controller silicon. If the controller fails at the silicon level (not just firmware), recovery options depend on whether board-level repair can restore controller operation. We evaluate each 9400 individually and provide an honest assessment of recovery feasibility before any work begins.
6500 ion
6500 ION: 232-Layer TLC at QLC Price Points
The Micron 6500 ION is frequently misread as a QLC drive because of its positioning. It targets read-intensive data center workloads and competes directly with QLC drives like the Solidigm D5-P5316, but the 6500 ION actually uses Micron's 232-layer 3D TLC (triple-level cell) NAND. By leveraging high-density TLC, Micron reached QLC-class cost-per-gigabyte while keeping TLC endurance and performance characteristics.
Because it uses TLC, the 6500 ION natively supports standard 4K indirection units instead of the 64K indirection used by competing QLC enterprise drives. That avoids the alignment and write-amplification penalties typical of 64K-only QLC stacks and gives the drive substantially higher random write endurance than the QLC parts it replaces. Sustained writes still pressure the SLC write cache and the underlying TLC, but the drive is rated for far heavier write workloads than a QLC equivalent of similar capacity.
When a 6500 ION fails, the typical scenarios are FTL corruption following an unexpected power event, PLP capacitor degradation in long-deployment data center use, or NAND wear in environments that consistently exceed the drive's rated DWPD. PC-3000's read retry mechanism shifts voltage reference thresholds to resolve worn cells; on a 30TB drive, this can be a multi-day operation. Board-level component repair is often required when the drive arrived after an electrical surge.
Controller Architecture and Encryption
Micron Enterprise Controller Architecture
5400 SATA Controller
Proven enterprise SATA 6Gbps controller architecture. 176-layer 3D TLC NAND. PLP capacitors for write cache flush. SMART attribute 202 (Percent Lifetime Used) triggers firmware-level write protect or lockout at end of life. Both the 5400 and the consumer Crucial MX500 use Micron-manufactured TLC NAND, but different generations and different controllers.
7450 NVMe Controller
Micron proprietary NVMe Gen4 controller with onboard DRAM. AES-256 hardware encryption with per-namespace keys. Tantalum PLP capacitors for power loss flush. Available in U.3, E1.S, and M.2 22110 form factors. FTL stored in dedicated NAND blocks with primary/secondary redundancy. PC-3000 SSD accesses through vendor-specific NVMe commands for FTL reconstruction.
9400 NVMe 3016 Architecture
Microchip NVMe 3016 (PM8628C1-F3EI MorrisTown) 16-channel Gen4 controller paired with Micron 176-layer 3D TLC NAND. U.3 form factor up to 30.72TB. AES-256 encryption with controller-bound keys. Board-level repair is the only path when the controller silicon fails.
6500 ION TLC Architecture
High-capacity NVMe drive built on Micron's 232-layer 3D TLC NAND, marketed at QLC price points. U.3 and E1.L form factors for high-density rack deployments. Native 4K indirection units (versus 64K on competing QLC drives) deliver substantially higher random write endurance. Read retry uses standard 8-level TLC voltage calibration. Recovery completeness depends on controller silicon health and NAND wear state at the time of failure.
Encryption and Chip-Off Limitations
All current Micron enterprise SSDs implement AES-256 hardware encryption with keys bound to the controller silicon. The 7450 and 9400 generate per-namespace encryption keys during provisioning. Desoldering NAND packages yields only ciphertext. Board-level repair to restore the original controller is required when firmware-level access fails. Microsoldering workstations handle BGA component rework on U.3 and E1.S PCBs.
Enterprise Form Factors
Micron enterprise SSDs ship in five form factors. The 5400 uses a standard 2.5-inch SATA connector (7mm height). The 7450 and 9400 use the 2.5-inch U.3 (SFF-8639) tri-mode connector for NVMe. E1.S (EDSFF short) is available for the 7450 in dense storage configurations. M.2 22110 is available for the 7450 in space-constrained servers. E1.L (EDSFF long) is exclusive to the 6500 ION for maximum capacity per slot. Each form factor requires specific PCB handling during board-level repair.
PLP Capacitor Degradation
Power Loss Protection Capacitor Degradation
Enterprise SSDs include PLP capacitors (typically tantalum or ceramic) to store enough energy to flush the DRAM write cache to NAND when power is lost. The Micron 5400, 7450, and 9400 all include PLP capacitors as standard. The capacitors are rated for the drive's operational life under normal thermal conditions (0-70C for data center environments).
Tantalum capacitors degrade faster at elevated temperatures. In a 40C ambient server chassis, the capacitor's effective operating temperature is higher due to heat from the controller and NAND dies. After 3-5 years of continuous operation, the capacitance drops. Micron's firmware periodically tests PLP capacitor health (visible through vendor-specific SMART telemetry logs). When capacitance drops below the flush threshold, the drive should be replaced proactively, but many deployments do not monitor this telemetry.
A power event on a drive with degraded PLP capacitors produces a partial flush. Some NAND blocks receive complete writes while others receive partial page programs. The FTL metadata may be inconsistent because the mapping update was interrupted. This is the most common enterprise SSD failure scenario we receive: the drive worked for years in a server, a UPS failure or facility power event occurred, and the drive is now unresponsive or shows corrupted data on reboot.
SMART Monitoring for IT Admins
SMART Attributes That Predict Micron SSD Failures
Micron enterprise SSDs expose vendor-specific SMART attributes through the NVMe health log (Log Page 02h) and SATA SMART framework. Key attributes for predicting impending failure:
  • Attribute 202 (Percent Lifetime Used): Tracks NAND wear. At 100%, the 5400 series may enter write-protect or lockout mode. Monitor this weekly on write-heavy workloads.
  • Attribute 170 (Available Reserved Space): Tracks spare NAND block count. As blocks fail and are retired, this value decreases. When it reaches zero, the drive has no spare blocks for wear leveling. PLP capacitor health is reported separately through Micron vendor-specific telemetry (SMART log page).
  • Attribute 171 (Program Fail Count): Non-zero values indicate NAND blocks that failed during programming. An increasing trend signals NAND wear approaching end of life.
  • Attribute 172 (Erase Fail Count): Non-zero values indicate blocks that could not be erased. Combined with high program fail counts, this predicts imminent drive failure.
  • NVMe Critical Warning (Byte 0 of Health Log): Bit flags for spare capacity exhaustion, temperature threshold, reliability degradation, read-only mode, and volatile memory backup failure. Any bit set warrants immediate backup.
If you are reading this after a drive has already failed: stop power-cycling the drive. Each boot attempt on a drive with corrupted FTL can overwrite NAND metadata blocks that recovery tools need. Ship the drive to us powered off.
Micron Enterprise SSD Recovery FAQ
My Micron 5400 PRO shows SMART warning for media wearout. Can you recover it?
The Micron 5400 PRO uses 176-layer 3D TLC NAND with a proven enterprise SATA controller. When SMART attribute 202 (Percent Lifetime Used) reaches the manufacturer threshold, the drive may transition to read-only mode or become inaccessible depending on the firmware revision. Recovery cost depends on NAND health and falls under our standard SSD firmware recovery tier.
Can you recover a Micron 7450 that failed after a data center power event?
The Micron 7450 PRO and MAX include onboard power loss protection (PLP) capacitors rated for a controlled flush of the DRAM write cache on power loss. If the PLP capacitors have degraded (common after years of high-temperature operation), a power event can corrupt the flash translation layer. PC-3000 SSD accesses the Micron controller through vendor-specific NVMe commands to rebuild the FTL mapping. The 7450 uses a Micron proprietary NVMe controller; recovery depends on the current PC-3000 module support for this specific firmware revision.
Is the Micron 9400 PRO recoverable?
The 9400 PRO is a U.3 NVMe enterprise SSD using Micron's 176-layer 3D TLC NAND paired with a Microchip NVMe 3016 (PM8628C1) 16-channel controller. Controller silicon failure is more complex because the 9400 uses AES-256 hardware encryption with keys bound to the controller. Board-level repair to revive the original controller is the only path when encryption prevents chip-off. Contact us with the specific model number and failure symptoms for an honest evaluation.
What is the difference between this page and the Crucial recovery page?
Crucial is Micron's consumer SSD brand. The Crucial page covers MX500, BX500, P2, P3, P5 Plus (which uses the Micron DM02A1), and Micron OEM laptop SSDs (2400, 2450, 3500). This page covers Micron enterprise data center SSDs: the 5400 series (SATA), 7450 series (NVMe U.3/E1.S), 9400 series (NVMe U.3), and 6500 ION (TLC NVMe targeting QLC price points). Enterprise Micron SSDs use enterprise-grade controllers with different firmware, power loss protection hardware, and encryption implementations than the consumer Crucial line.
How much does Micron enterprise SSD recovery cost?
Micron enterprise SSD recovery scales with interface and complexity. SATA drives fall under our standard SSD tiers ($200–$1,500); NVMe drives fall under our NVMe SSD tiers ($200–$2,500). Simple data copies sit at the low end, while board-level microsoldering and firmware reconstruction sit at the higher tiers. Free evaluation with no diagnostic fees.
Can you recover a Micron 6500 ION SSD?
The 6500 ION is a high-capacity 232-layer TLC NVMe drive (up to 30.72TB) priced to compete with QLC alternatives like the Solidigm D5-P5316. Because it uses TLC, it natively supports 4K indirection units and offers substantially higher write endurance than the QLC drives it targets at retail. When a 6500 ION fails (typically from PLP capacitor degradation, firmware corruption after a power event, or NAND wear in write-intensive workloads beyond its rated DWPD), PC-3000 SSD vendor-specific access can extract data if the controller and NAND are still readable. Recovery cost depends on NAND health, capacity, and whether the failure required board-level repair.
Send Us Your Micron Enterprise SSD
Free evaluation. Firm quote. No data, no fee. Ship your Micron enterprise SSD to our Austin lab.
