Intel & Solidigm SSD Data Recovery
Intel's consumer SSDs include the SATA-era 545s with Silicon Motion SM2259 and the QLC NVMe 660p and 670p.
SSD from $200 | No Data, No Fee | Free Evaluation | Since 2008
Intel SSDs We Recover
SATA SSDs
Intel 545s (SM2259, 64-layer TLC), Intel 535 (SF-2281), Intel Pro 5450s, Intel DC S3520 (enterprise SATA)
NVMe Consumer SSDs
Intel 660p (SM2263, QLC), Intel 665p (SM2263, 96L QLC), Intel 670p (SM2265, 144L QLC), Intel 760p (SM2262, TLC)
Solidigm (Post-Intel)
Solidigm P41 Plus (SM2269XT, QLC), Solidigm P44 Pro (SK hynix in-house controller, TLC)
PC-3000 SSD with NVMe and SATA modules in-house
10 min read
Intel SSD Recovery
How Intel SSD Recovery Works
The 545s uses the SM2259 (SATA). The 660p and 665p use the SM2263 (NVMe Gen3). The 670p uses the SM2265 (NVMe Gen3). The 760p uses the SM2262 (NVMe Gen3 with DRAM). Solidigm's Silicon Motion-based drives use the same platform. We evaluate your drive for free and provide a firm quote. No data, no recovery fee. Silicon Motion-based Intel and Solidigm consumer drives move through the same solid-state drive recovery sequence.
The Intel-to-Solidigm Timeline
From Intel to Solidigm: What Changed for Data Recovery
In December 2021, SK hynix completed the first phase of its $9 billion acquisition of Intel's NAND and SSD business, forming a subsidiary called Solidigm.
The Solidigm P41 Plus uses a Silicon Motion SM2269XT controller, the Gen4 successor in Silicon Motion's entry-level NVMe line (the 660p used the Gen3 SM2263). The P44 Pro uses an SK hynix in-house controller, a different architecture entirely.
QLC NVMe Drives: 660p, 665p, 670p
Intel 660p, 665p, and 670p Recovery
The Intel 660p was the first consumer QLC NVMe SSD when it launched in 2018. It uses the Silicon Motion SM2263 controller with Intel 64-layer QLC NAND. The 665p updated the NAND to 96-layer QLC while keeping the same SM2263 controller. The 670p moved to the SM2265 controller with 144-layer QLC NAND and improved endurance.
All three drives share a fundamental design limitation: QLC NAND stores 4 bits per cell across 16 voltage states. This gives Intel more capacity per chip but lower endurance than TLC. The 660p's 1TB model is rated for only 200 TBW. As the QLC cells wear, the error rate climbs until the controller can no longer correct reads.
These drives write incoming data to QLC cells in faster SLC mode (1 bit per cell), creating a speed cache. If the system loses power during the cache flush from SLC to QLC mode, the flash translation layer can corrupt, causing the drive to report 0GB capacity or vanish from BIOS.
Intel 545s and 760p
Intel 545s and 760p Recovery
The Intel 545s is Intel's last mainstream SATA SSD. It uses the Silicon Motion SM2259 controller paired with Intel 64-layer 3D TLC NAND and a DRAM cache. The SM2259 is from the same controller family used in the Crucial MX500. That means we use a similar PC-3000 workflow on it: we short pins to enter ROM mode and do the FTL reconstruction.
The Intel 760p uses the SM2262 controller, an 8-channel NVMe Gen3 design with onboard DRAM. The SM2262 is from the same controller family used in the HP EX920. Intel ran custom firmware on the 760p.
SSD Pricing
Intel SSD Recovery Pricing
SSD Recovery Calculator
Estimate Your Intel SSD Recovery Cost
What type of SSD do you have?
Shomari Hohn
Aravind Udayakumar
David Dachenhaus (DDock)
Ludwig Jonsson
LaCie
Controller Architecture Grid
Intel SSD Controllers and Recovery Methods
SM2263: Intel 660p and 665p
4-channel NVMe Gen3 controller with onboard DRAM. Intel pairs it with 64-layer (660p) or 96-layer (665p) QLC NAND. The SM2263 stores its FTL in DRAM and periodically flushes to NAND. Power loss during the flush corrupts the translator. Once the QLC cells reach their endurance limit, uncorrectable bit error rates climb and eventually lock the drive into a firmware protection state.
Intel 660p recovery details
SM2265: Intel 670p
4-channel NVMe Gen3 controller with improved LDPC error correction. Paired with Intel 144-layer QLC NAND that offers better endurance than the 660p's 64-layer cells. The 670p's 1TB model is rated for 370 TBW, nearly double the 660p's 200 TBW. The improved error correction extends the practical lifespan of the QLC cells.
SM2259: Intel 545s
4-channel SATA controller with onboard DRAM, from the same Silicon Motion family used in the Crucial MX500. Intel pairs it with 64-layer 3D TLC NAND. The dedicated DRAM cache stores the FTL mapping. The SM2259 uses hardware AES-256 encryption tied to the controller die, making chip-off not viable. We use PC-3000 SSD's Silicon Motion (SM) Utility on SM2259 drives. Shorting pins puts the drive into ROM mode, and we run the FTL reconstruction.
SM2258/SM2259 family recovery details
SM2262: Intel 760p
8-channel NVMe Gen3 controller with onboard DRAM, the performance variant of Silicon Motion's NVMe lineup. Paired with Intel 3D TLC NAND.
SM2262 recovery details
SM2269XT: Solidigm P41 Plus
DRAMless NVMe Gen4 controller, Silicon Motion's Gen4 entry-level NVMe design. Paired with 144-layer QLC NAND. The DRAMless design uses Host Memory Buffer (HMB) for FTL caching, similar to the Crucial P2. Without onboard DRAM, the FTL is more vulnerable to corruption during power loss. The P41 Plus is Solidigm's budget NVMe offering and the direct continuation of the Intel QLC consumer line.
Enterprise: DC S3520 and D7-P5510
Intel and Solidigm enterprise SSDs use proprietary controllers distinct from the Silicon Motion consumer designs. The Intel DC S3520 (SATA) uses an Intel proprietary controller. The Solidigm D7-P5510 and D7-P5810 (U.2 NVMe) use custom controllers with enhanced encryption and enterprise-specific firmware. We provide an honest assessment of recoverability before any work begins.
QLC SLC Cache Exhaustion
QLC and SLC Cache Exhaustion on Intel NVMe SSDs
Intel's 660p, 665p, and 670p all use a dynamic SLC cache strategy. The controller writes incoming data to QLC cells in SLC mode (1 bit per cell instead of 4), which is faster and places less stress on the cell. This creates a speed buffer that masks the inherent slowness of QLC writes.
The cache size is dynamic: on a nearly empty 1TB 660p, up to 140GB of NAND can operate in SLC mode. As the drive fills, the SLC cache shrinks. On a 75% full drive, the cache drops to around 12GB. Sustained writes that exceed the cache cause the controller to flush SLC data to QLC in the background. If the system loses power during this flush, both the SLC cache mapping and the QLC destination pages can end up in an inconsistent state. The flash translation layer, which maps logical block addresses to physical NAND locations, loses coherence.
The result: the drive either reports 0GB capacity, shows as an uninitialized disk, or disappears from BIOS. QLC cells that have already worn past their rated endurance produce higher bit error rates during imaging, requiring more Read-Retry iterations.
200 TBW
Intel 660p 1TB rated endurance.
~12GB
SLC cache remaining when the 660p is 75% full. Fills during sustained writes.
Common Intel SSD Failure Signatures
ReadOnly Mode from QLC Exhaustion
Intel 660p and 670p drives use a firmware protection mechanism that locks the drive to read-only mode when the QLC NAND degrades past its error correction threshold. This is the controller preventing further writes that would destroy remaining data.
Translation Layer Corruption: 0GB or Generic Device ID
When the flash translation layer corrupts on SM2263 or SM2265 controllers, the drive reports a capacity of 0GB. Some Intel drives display a generic device identifier or "Intel Bootloader" instead of their normal model string.
Thermal Throttling and Controller Shorts on 660p and 670p
The Intel 660p and 670p are M.2 2280 NVMe drives that run hot under sustained load, particularly in laptops without heatsinks or airflow over the M.2 slot. Prolonged thermal throttling degrades QLC NAND cells faster. In some cases, thermal stress causes component-level shorts on the 3.3V power rail, making the drive appear completely dead. Board-level diagnostics with a thermal camera identify the shorted component. Microsoldering replaces the failed part and restores power to the controller, preserving the encryption key needed to access the NAND.
Chip-off and Encryption
Chip-Off Limitations on Intel SSDs
Most Intel consumer SSDs from the 600p through the 670p use hardware AES-256 encryption implemented at the controller level. The encryption key is wrapped by a hardware key fused into the controller die. This means the NAND flash contents are always encrypted, even if the user never enabled a BIOS password or OS-level encryption like BitLocker.
If the controller fails and cannot be revived through board-level repair, desoldering the NAND chips yields only ciphertext. Unlike some DRAMless SATA controllers (e.g., SM2258XT in the Crucial BX500) that use XOR scrambling instead of full AES, Intel's SM2263 and SM2262 controllers use cryptographic encryption that cannot be reversed without the key material on the original die.
Board-level repair to revive the original controller is the required path. Our microsoldering workstations handle BGA component replacement on M.2 2280 PCBs: replacing failed voltage regulators, PMICs, or capacitors to restore power to the original controller and preserve access to the encryption key.
Intel SSD Data Recovery FAQ
Why did Intel sell its SSD business to Solidigm?
Intel sold its NAND and SSD business to SK hynix in two phases. The first closed in December 2021 and created a subsidiary called Solidigm. Solidigm manufactures SSDs using Intel's original designs and NAND technology. Consumer drives like the 670p continued under the Intel brand during the transition. The Solidigm P41 Plus is the direct successor to the Intel 670p.
My Intel 660p shows 0GB in BIOS. Is my data gone?
A 0GB capacity report on the 660p typically indicates firmware corruption, not permanent data loss. The SM2263 controller's flash translation layer has become inconsistent, causing the controller to report zero logical blocks. The QLC NAND data remains physically intact. SSD firmware recovery is $900–$1,200.
Does the Intel 660p QLC endurance issue affect recovery?
The 660p's 1TB model is rated for only 200 TBW (terabytes written). When QLC cells reach their endurance limit, the error rate climbs until the ECC engine cannot correct reads. Heavily worn QLC NAND requires more read-retry iterations.
Can you recover data from Solidigm enterprise SSDs?
We recover consumer and prosumer Solidigm drives (P41 Plus, P44 Pro). Enterprise Solidigm drives (D7-P5510, D7-P5810) use proprietary controllers with strengthened encryption and custom firmware. Contact us with the specific model number for an honest assessment before shipping.
How much does Intel SSD data recovery cost?
Intel NVMe SSD recovery is priced $200–$2,500. Simple data copies are $200. File system recovery is from $250. Circuit board repair runs $900–$1,200. Firmware corruption is $900–$1,200. Advanced component repair requiring microsoldering is $1,200–$2,500. Free evaluation with no diagnostic fees.
Is chip-off recovery possible on Intel SSDs?
Most Intel consumer SSDs from the 600p onward use controllers with hardware AES-256 encryption. The encryption key is bound to the original controller die. If that controller fails beyond repair, desoldering the NAND yields only ciphertext. The Intel 545s with SM2259 also uses hardware encryption. Board-level repair to revive the original controller is the only viable path for encrypted Intel drives.
Send Us Your Intel SSD
Free evaluation. Firm quote. No data, no fee. Ship your Intel or Solidigm SSD to our Austin lab.
