Crucial & Micron SSD Data Recovery
Crucial is Micron's consumer SSD brand. The SATA lineup, the MX500 and BX500, uses Silicon Motion controllers. We work on those with the Silicon Motion utility in PC-3000 SSD. The P3 uses the Phison E21T. The tools and the approach depend on the controller family.
SSD from $200 | No Data, No Fee | Free Evaluation | Since 2008
Crucial SSDs We Recover
SATA SSDs
MX500 (SM2258H or SM2259H), BX500 (SM2258XT, DRAMless)
NVMe SSDs
P3 (Phison E21T)
PC-3000 SSD with Silicon Motion and Phison modules in-house
11 min read
Crucial SSD Recovery
How Crucial SSD Recovery Works
Crucial SSDs use controllers from Silicon Motion and Phison. Recovery requires matching the correct tools to the controller inside the drive, not the Crucial brand label on the outside. We work on the MX500 and BX500 with the Silicon Motion Utility in PC-3000 SSD. The P3 uses the Phison E21T. We evaluate your drive for free, provide a firm quote, and charge nothing if we cannot recover your data.
SATA Drives: MX500 and BX500
Crucial SATA SSD Recovery: MX500 & BX500
The MX500 is a Crucial SATA SSD. It uses the Silicon Motion SM2258H or SM2259H controller.
The BX500 is the budget alternative. BX500 drives on the SM2258XT controller have no DRAM cache.
We work on the MX500 and the BX500 with the Silicon Motion (SM) Utility in PC-3000 SSD. We force the controller into Safe Mode. Then we use the utility to upload a loader into the drive's RAM and emulate the translator so we can read the data. Both drives are SATA, so we don't need an NVMe adapter.
Rossmann does not currently offer in-lab recovery for the Crucial MX300.
NVMe Drives: P-series
Crucial NVMe SSD Recovery: P3
The Crucial P3 is an M.2 2280 NVMe SSD. It uses the Phison E21T controller.
SSD Pricing
Crucial SSD Recovery Pricing
SSD Recovery Calculator
Estimate Your Crucial SSD Recovery Cost
What type of SSD do you have?
Shomari Hohn
Aravind Udayakumar
David Dachenhaus (DDock)
Ludwig Jonsson
LaCie
Controller Architecture Grid
Crucial SSD Controllers and Recovery Methods
SM2258H / SM2259H (MX500)
Silicon Motion 4-channel SATA controllers. We force the controller into Safe Mode, then use PC-3000 SSD to upload a loader into the drive's RAM and emulate the translator.
SM2258XT (BX500)
DRAMless 4-channel SATA controller. A BX500 with corrupted firmware stays in a BSY state. We force the controller into Safe Mode, then use PC-3000 SSD to upload a loader into the drive's RAM and emulate the translator. The SM2258XT uses XOR data scrambling rather than full AES encryption. That makes chip-off technically feasible as a last resort. We'd rather go through the controller with PC-3000.
SM2258XT recovery details
Phison E21T (P3)
The Crucial P3 uses the Phison E21T and has no DRAM.
Phison E21T recovery details
Micron OEM (2400, 2450, 3500)
The Micron 2400 uses 176-layer QLC NAND with an NVMe Gen4 interface. The Micron 3500 uses Micron's 232-layer NAND.
QLC NAND Complications
QLC NAND and Crucial Recovery Challenges
QLC (Quad-Level Cell) NAND stores 4 bits per cell across 16 voltage states, compared to 8 states for TLC and 4 for MLC. The tighter voltage margins mean QLC cells degrade faster, tolerate fewer program/erase cycles, and produce higher bit error rates as the drive ages.
For data recovery, QLC complicates the imaging process. PC-3000's Read-Retry function cycles through voltage threshold variations to coax correct data from degraded cells. QLC requires more read-retry iterations than TLC because the voltage windows between valid states are narrower.
PC-3000
Silicon Motion + Phison modules for SATA and NVMe recovery
QLC
4 bits per cell. 16 voltage states. Tighter margins require more read-retry passes
Chip-off and Encryption
Chip-Off Recovery and Crucial Encryption
Chip-off recovery, which involves desoldering NAND chips and reading them on a standalone programmer, has limited viability across the Crucial lineup. The BX500 with SM2258XT uses XOR data scrambling rather than full AES encryption. This makes chip-off difficult but technically possible: the scrambling pattern must be reversed after reading, but the data is not encrypted in the cryptographic sense.
The MX500's SM2258H controller encrypts the data, and the key is bound to the original controller. Chip-off on an MX500 gets you encrypted data that can't be decrypted without that controller.
That's why we go to board-level repair first on the MX500. Replacing failed voltage regulators, PMICs, or capacitors on the original PCB keeps access to the encryption key. We do BGA rework at our microsoldering workstations.
SM2258H Controller PCB Diagnostics
SM2258H Controller PCB Diagnostics: Identifying Dead Shorts
An MX500 with corrupted firmware still powers on and stays in a BSY state. When an MX500 arrives dead, with no detection on the SATA bus, we check the PCB for shorts.
Multimeter and FLIR Thermal Diagnostics
The diagnostic sequence for a dead MX500 follows a fixed protocol:
  1. Visual inspection under magnification for carbonized components or cracked capacitors.
  2. Multimeter resistance testing across major capacitor banks against ground.
  3. Current-limited voltage injection into the shorted rail. The shorted component dissipates power as heat. We find it with a FLIR thermal camera, which shows the failed component as a localized hot spot.
  4. Hot-air removal of the failed component, re-test to confirm the short has cleared, then donor component installation via microsoldering.
Recoverable vs Unrecoverable SM2258H Failures
Whether data can be recovered from a failed MX500 depends on which component died and whether the SM2258H controller die itself survived.
  • Shorted capacitor: Recoverable when the controller and NAND are intact. Component replacement restores power delivery. PCB repair falls under our standard SSD circuit board repair tier.
  • Firmware corruption (BSY state): Recoverable. We force the controller into Safe Mode, then use PC-3000 SSD to upload a loader into the drive's RAM and emulate the translator. This case falls under our standard SSD firmware recovery tier.
  • Dead controller die: Unrecoverable. The SM2258H encrypts the data, and the key is bound to the original controller. If the controller itself is dead, and not only the power circuit around it, what's on the NAND is ciphertext. No data, no fee applies.
  • NAND degradation: QLC and heavily worn TLC cells produce read errors that PC-3000's read-retry cycles can compensate for, but recovery completeness depends on how many cells have drifted past correctable thresholds.
Crucial SSD Data Recovery FAQ
Can Crucial Storage Executive recover my data?
No. Crucial Storage Executive monitors drive health and updates firmware. It cannot recover data from a failed drive.
My Crucial MX500 is not detected in BIOS. Can you recover it?
The MX500 uses a Silicon Motion SM2258H or SM2259H controller. When the firmware is corrupted, we force the controller into Safe Mode. Then we use the Silicon Motion (SM) Utility in PC-3000 SSD to upload a loader into the drive's RAM and emulate the translator. This case falls under our standard SSD firmware recovery tier.
My Crucial P3 Plus lost all data. What happened?
We can't tell you what failed until we've looked at the drive. The evaluation is free.
Is chip-off recovery possible on Crucial SSDs?
It depends on the controller. The BX500 with SM2258XT uses XOR data scrambling rather than full AES encryption, making chip-off difficult but not impossible. The MX500's SM2258H controller encrypts the data. Read its NAND chips directly and all you get is encrypted data. When an MX500's board fails, we repair that board to bring the original controller back up.
How much does Crucial SSD recovery cost?
Crucial SSD recovery pricing scales across our standard SSD tiers ($200–$1,500). Simple data copies start at the low end; file system recovery, PCB repair, firmware reconstruction, and board-level microsoldering fall into higher tiers. See the pricing table on this page for the exact tier breakdown. Free evaluation with no diagnostic fees.
Do you recover Micron OEM SSDs from Dell and HP laptops?
We evaluate Micron OEM drives for free. The Micron 2400 uses 176-layer QLC NAND with an NVMe Gen4 interface.
Can I fix my Crucial MX500 by swapping the circuit board?
No. The SM2258H controller in the MX500 encrypts the data, and the key is bound to the original controller. Put a replacement board on the drive and you get encrypted data you can't read. We repair the original board instead.
Send Us Your Crucial SSD
Free evaluation. Firm quote. No data, no fee. Ship your Crucial or Micron SSD to our Austin lab.
