OWC SSD Data Recovery
OWC (Other World Computing) is a major aftermarket SSD brand for Mac users. Their Aura Pro line uses proprietary Apple-style connectors that do not fit standard M.2 slots, creating a physical barrier to recovery that most labs cannot solve without the correct adapter hardware. We recover Aura Pro X2 (SM2262EN), Aura Pro NT, Envoy Pro FX, Mercury Electra, and Accelsior drives using PC-3000 SSD with OWC-to-M.2 adapters for proprietary connector models.
SSD starting at $200 | No Data, No Fee | Free Evaluation | Since 2008
OWC SSDs We Recover
Aura Pro X2 NVMe SSD
Silicon Motion SM2262EN. Proprietary 12+16 pin Apple connector. For MacBook Pro/Air 2013-2017, Mac Pro 2013.
Aura Pro NT / Aura N2
Newer Silicon Motion controllers. Apple connector and M.2 2280 variants. NVMe Gen3 x4.
Envoy Pro FX / Envoy Pro Elektron
Thunderbolt 3/USB-C portable SSDs. Internal NVMe drive behind Thunderbolt bridge chip.
Mercury Electra / Mercury Extreme Pro
SandForce SF-2281 SATA controller. Legacy 2.5" SATA SSDs. Known BSY state firmware lockout bug.
Proprietary connectors require adapter hardware for PC-3000 access
10 min read
OWC SSD Recovery
How OWC SSD Recovery Works
OWC SSDs present a unique recovery challenge because many of their drives use proprietary Apple-style connectors instead of standard M.2. The Aura Pro X2 and Aura Pro NT use a 12+16 pin blade connector that physically matches Apple's original SSD slot in MacBook Pro (2013-2015), MacBook Air (2013-2017), and Mac Pro (2013) systems. This connector is electrically NVMe over PCIe, but the form factor is incompatible with any standard M.2 socket. We use passive OWC-to-M.2 adapters to convert the proprietary connector to standard M.2 2280, then connect the drive to PC-3000 SSD for diagnostics and recovery. The adapter passes through all PCIe lanes without modification; the drive behaves identically to any other NVMe SSD once physically connected. We evaluate every drive for free, provide a firm quote, and charge nothing if we cannot recover your data.
Aura Pro X2: SM2262EN and the Proprietary
Aura Pro X2: SM2262EN and the Proprietary Connector Problem
The OWC Aura Pro X2 is the most common OWC drive we receive for recovery. It uses the Silicon Motion SM2262EN controller, the same 8-channel NVMe Gen3 chip found in the ADATA SX8200 Pro, HP EX950, and Kingston KC2000. The SM2262EN features dual ARM Cortex-R5 cores, DRAM cache, and AES-256 hardware encryption. OWC packages this controller with a proprietary 12+16 pin blade connector that fits Apple's internal SSD slot from the 2013-2017 Mac era.
The primary failure mode is firmware corruption triggered by macOS updates or unclean shutdowns. When macOS pushes a major update (Ventura to Sonoma, Sonoma to Sequoia), the updated NVMe driver can interact differently with the SM2262EN's firmware than the previous version did. Apple validates their own SSDs against new NVMe driver builds; OWC drives do not receive this validation. A firmware state left inconsistent after an update-triggered reboot can leave the SM2262EN in a state where it fails to initialize on the next boot. The Mac shows a flashing question mark folder or refuses to detect any startup disk.
Recovery involves removing the Aura Pro X2 blade SSD from the Mac, mounting it on an OWC-to-M.2 adapter, and connecting it to PC-3000 SSD. The SM2262EN diagnostic interface allows firmware module reading, FTL repair, and NAND-level data extraction. If the firmware corruption is limited to the flash translation layer, PC-3000 can rebuild the logical-to-physical mapping and image the full drive contents. If the corruption extends deeper into the controller's boot ROM, board-level repair may be required to restore the controller to a bootable state before data extraction.
Envoy Pro FX: Thunderbolt Bridge Failures
The OWC Envoy Pro FX is a portable SSD with a Thunderbolt 3/USB-C interface that works cross-platform between Mac and PC. Internally, the Envoy Pro FX contains a standard NVMe SSD connected to a Thunderbolt-to-NVMe bridge controller (Intel JHL7440 or similar). The bridge chip translates between the Thunderbolt protocol and NVMe commands. This two-controller architecture means failures can occur at two independent points.
Bridge chip failures are the more common scenario on the Envoy Pro FX. A power surge through the USB-C port, a damaged cable, or a static discharge event can damage the Thunderbolt bridge without affecting the internal NVMe SSD at all. When the bridge fails, the drive is invisible to every computer regardless of operating system or cable. The user sees nothing in Disk Utility, Device Manager, or BIOS. This looks catastrophic but is often recoverable by disassembling the enclosure and reading the internal NVMe SSD directly on PC-3000.
NVMe controller failures on the internal SSD are less common but more complex. Firmware corruption from a system crash during a large file transfer can leave the NVMe controller in a non-bootable state. In this case, the bridge chip reports a device but the NVMe SSD behind it does not respond to standard commands. PC-3000 SSD accesses the NVMe controller through vendor-specific diagnostic commands after the SSD is removed from the enclosure.
SSD Pricing
OWC SSD Recovery Pricing
Shomari Hohn
Aravind Udayakumar
David Dachenhaus (DDock)
Ludwig Jonsson
LaCie
Mercury Electra / Legacy SATA
Mercury Electra: SandForce SF-2281 SATA Recovery
The OWC Mercury Electra and Mercury Extreme Pro are 2.5" SATA SSDs built around the SandForce SF-2281 controller. OWC sold these drives primarily as upgrades for older MacBook Pro, Mac Mini, and iMac systems that used standard 2.5" SATA drive bays. The SF-2281 was one of the most widely deployed SSD controllers in the 2011-2014 era, also used by Intel (520/330 series), Corsair (Force 3/Force GT), and Kingston (HyperX).
The SF-2281 implements a hardware compression engine that writes data to NAND in compressed form. This compression reduces write amplification but adds complexity to recovery because raw NAND reads must be decompressed using the SandForce-specific algorithm. The controller is also vulnerable to the BSY (busy) state bug: after a power loss during a garbage collection cycle, the controller enters a locked state where it reports 0MB capacity to the host. The drive appears in BIOS but shows as an empty, uninitialized device.
SF-2281 recovery requires specialized proprietary techniques. PC-3000 SSD does not yet have a dedicated SandForce module; recovery relies on vendor-specific SATA commands and manual firmware repair procedures. The SF-2281 also implements always-on AES-128 encryption (marketed as AES-256, but Intel discovered in 2012 that the AES-256 implementation was broken at the silicon level). Combined with DuraWrite compression and RAISE parity, the always-on encryption makes chip-off recovery not viable on SF-2281 drives. Board-level repair to revive the original controller is the only recovery path when the controller silicon has failed.
Accelsior PCIe Cards
Accelsior: PCIe Internal SSD Recovery
The OWC Accelsior line includes PCIe expansion card SSDs designed for Mac Pro (2010-2012 tower, 2013 cylinder, 2019 tower) and PC workstation use. The Accelsior 4M2 holds up to four M.2 NVMe SSDs on a single PCIe x8 card with a built-in SoftRAID controller. The older Accelsior S and Accelsior E2 used pairs of SATA or PCIe SSDs on a carrier card.
Recovery on Accelsior multi-drive cards depends on how the drives were configured. If the user ran the drives as individual volumes (JBOD), each M.2 SSD can be removed from the carrier card and recovered independently on PC-3000. If the user configured a SoftRAID stripe (RAID 0) or mirror (RAID 1) across the drives, the RAID configuration must be reconstructed. We image each M.2 SSD individually, then rebuild the RAID array using the SoftRAID metadata stored on each drive. Stripe size, drive order, and parity layout are all encoded in the SoftRAID partition table.
The Mac Pro 2013 (cylinder) is the most common Accelsior recovery scenario because its PCIe slots were the only expansion option for users who needed more storage than Apple's internal blade SSD provided. Thermal throttling in the Mac Pro 2013's confined enclosure can accelerate NAND wear on Accelsior cards running sustained workloads.
Proprietary Connector Technical Deep Dive
Apple Proprietary Connector: Why Standard Tools Fail
Apple used proprietary SSD connectors in MacBook Air (2012-2017), MacBook Pro Retina (2012-2015), Mac Pro (2013), and iMac (2012-2017). OWC designed the Aura Pro line to be drop-in replacements for these Apple SSDs, adopting the same proprietary connector. This means OWC Aura Pro drives share the same physical recovery challenge as original Apple SSDs from the same era: they cannot be plugged into any standard M.2 slot.
Multiple connector pinouts exist across Apple generations. The 2013-2015 MacBook Pro uses a 12+16 pin connector. The 2016-2017 MacBook Pro switched to a different pinout before soldering NAND directly to the logic board in 2018+ models. OWC's Aura Pro X2 targets the 2013-2017 connector variant. The Aura N2 targets the M.2 2280 form factor for standard PCs. Identifying which connector variant your OWC drive uses is the first step in recovery; using the wrong adapter will result in no electrical connection.
Our lab stocks adapters for every Apple proprietary SSD connector generation from 2012 through 2017. For drives that arrive without documentation of which Mac they came from, we visually identify the connector by pin count and keying notch position, then match the correct adapter. This step adds no cost to the recovery; it is part of our standard evaluation process.
OWC Controller Architecture Grid
OWC SSD Controller Reference
Aura Pro X2: Silicon Motion SM2262EN
NVMe Gen3 x4. Dual ARM Cortex-R5. 8-channel with DRAM. AES-256 encryption. Proprietary 12+16 pin Apple connector. SLC cache collapse and FTL corruption from macOS updates are the primary failure modes. Adapter required for PC-3000.
Aura Pro NT and Aura N2: Silicon Motion
NVMe Gen3/Gen4. Updated Silicon Motion controller (varies by production revision). Apple connector and M.2 2280 variants available. AES-256 encryption. Firmware-level recovery through PC-3000 SSD Silicon Motion module.
Envoy Pro FX: Thunderbolt Bridge and NVMe
Thunderbolt 3/USB-C external. Intel JHL7440 or similar bridge chip. Internal NVMe SSD behind bridge controller. Bridge failures are common; disassembly and direct NVMe access bypasses the bridge entirely.
SATA 6Gbps. Standard 2.5" form factor. DuraWrite compression engine. Known BSY state firmware lockout. Always-on AES-128 encryption (marketed as AES-256 but broken at silicon level). Chip-off not viable. Specialized proprietary recovery techniques required.
Wear-Leveling Exhaustion on Older OWC Drives
Wear-Leveling Exhaustion on 2013-Era OWC Drives
OWC Aura Pro drives purchased between 2013 and 2016 are now over a decade old. Users who kept these drives in daily-driver MacBooks through years of macOS updates, Time Machine backups, and swap file writes have pushed the TLC NAND cells through a significant portion of their rated write endurance. As NAND cells wear, the bit error rate increases. The controller's ECC engine (LDPC on the SM2262EN, BCH on older models) corrects these errors transparently until the error rate exceeds the correction threshold.
When the error rate crosses that threshold, the controller can no longer reliably read its own flash translation layer. The drive may slow down noticeably, start throwing read errors, or enter a firmware lockout state. SMART data (if accessible through a Mac or adapter) shows the "Percentage Used" attribute approaching or exceeding 100%.
Recovery from wear-related failures requires reading NAND contents at the raw page level through PC-3000, then reconstructing the logical data using the FTL metadata and ECC parity data stored in the NAND spare areas. Pages with uncorrectable bit errors may result in individual file corruption, but the majority of data on the drive remains recoverable because wear does not affect all NAND blocks uniformly; blocks with lower write counts retain full readability.
OWC SSD Recovery FAQ
My OWC Aura Pro X2 is not detected after a macOS update. Can you recover it?
The Aura Pro X2 uses the Silicon Motion SM2262EN controller with AES-256 hardware encryption. macOS updates can trigger firmware state changes on third-party NVMe SSDs that were not validated against Apple's updated NVMe driver. The drive may drop from the system entirely or mount read-only. PC-3000 SSD accesses the SM2262EN through Silicon Motion's diagnostic interface to repair corrupted firmware modules and extract data from NAND. The Aura Pro X2 uses a proprietary Apple-style connector, so we use an OWC-to-M.2 adapter to interface it with PC-3000. Firmware-level recovery is listed as $900–$1,200.
Does the OWC Aura Pro X2 use a standard M.2 connector?
No. The Aura Pro X2 uses a proprietary 12+16 pin connector designed to fit Apple MacBook Pro (2013-2015), MacBook Air (2013-2017), and Mac Pro (2013) SSD slots. This connector is physically incompatible with standard M.2 slots. For recovery, we use a passive adapter that converts the OWC proprietary connector to standard M.2 2280, allowing connection to PC-3000 SSD. The adapter does not alter the electrical interface; it only changes the physical form factor.
Can you recover data from an OWC Mercury Electra that stopped working?
The Mercury Electra uses the SandForce SF-2281 SATA controller with hardware compression (DuraWrite) and always-on AES-128 encryption. SF-2281 drives are vulnerable to the BSY bug, where the controller enters a locked state and reports 0MB capacity after a power loss or firmware corruption event. SF-2281 recovery requires specialized proprietary techniques because the controller's always-on encryption, DuraWrite compression, and RAISE parity all operate simultaneously. Chip-off is not viable on SF-2281 drives due to the always-on AES encryption.
How much does OWC SSD data recovery cost?
OWC SSD recovery pricing follows our published SSD tiers. For SATA drives (Mercury Electra, Mercury Pro): simple-copy $200, file-system From $250, PCB $450–$600, firmware $600–$1,200, PCB/NAND swap $1,200–$1,500. For NVMe drives (Aura Pro X2, Envoy Pro FX, Accelsior): simple-copy $200, file-system From $250, PCB $900–$1,200, firmware $900–$1,200, PCB/NAND swap $1,200–$2,500. Free evaluation with no diagnostic fees. No data, no fee guarantee on every recovery.
Is chip-off recovery possible on OWC NVMe SSDs?
Chip-off is not viable on any current OWC SSD. The SM2262EN controller in the Aura Pro X2 and similar Silicon Motion controllers in newer OWC drives implement AES-256 hardware encryption with keys bound to the controller silicon. Desoldering NAND packages yields only encrypted data. The legacy Mercury Electra (SF-2281 SATA) also has always-on AES-128 encryption that blocks chip-off. Board-level repair to revive the original controller is the only recovery path when firmware-level access fails on any OWC drive.
Can you recover an OWC Envoy Pro FX that is not recognized by any computer?
The Envoy Pro FX is a Thunderbolt 3/USB-C portable SSD. When the drive is not recognized, the failure can be in the Thunderbolt bridge chip, the NVMe controller, or the NAND firmware. We disassemble the enclosure and connect the internal NVMe SSD directly to PC-3000, bypassing the Thunderbolt bridge entirely. If the internal NVMe drive is functional, it is an enclosure-only failure, and we can image the data directly. If the NVMe controller firmware is corrupted, we proceed with firmware-level recovery.
Send Us Your OWC SSD
Free evaluation. Firm quote. No data, no fee. Ship your OWC SSD to our Austin lab.
