PNY SSD Data Recovery
SSD starting at $200 | No Data, No Fee | Free Evaluation | Since 2008
PNY SSDs We Recover
Gen4: CS3040 and XLR8 CS3140
Phison E18 (CS3140) and E16 (CS3040). M.2 2280. AES-256 encryption.
CS2230 M.2 2230 SSD
DRAMless Phison controller. M.2 2230 for Steam Deck, PS5, ROG Ally, Surface Pro. HMB-dependent FTL.
Gen3: CS3030 and CS1030
Phison E12 (CS3030, 8-channel DRAM) and E13T (CS1030, 4-channel DRAMless). NVMe Gen3 x4.
SATA: CS900 and CS1311
Phison S10 (CS1311). Budget SATA.
PC-3000 SSD support varies by controller and firmware revision.
10 min read
PNY SSD Recovery
How PNY SSD Recovery Works
The SSD data recovery approach depends on which chip is inside the drive, the specific firmware revision, and the failure mechanism. PC-3000 SSD connects to Phison controllers through vendor-specific diagnostic commands, bypassing the normal NVMe or SATA interface. From there, we read firmware modules, repair corrupted flash translation tables, and extract raw NAND contents when the controller firmware is too damaged to boot. Budget PNY models like the CS1030 use DRAMless controllers that are more vulnerable to FTL corruption from power loss because their mapping tables rely on NAND or host memory rather than dedicated DRAM cache. We evaluate every drive for free, provide a firm quote, and charge nothing if we cannot recover your data.
CS3040 and XLR8 CS3140: Phison Gen4 Firmware
CS3040 and XLR8 CS3140: Phison Gen4 Firmware Failure
The XLR8 CS3140 uses the Phison PS5018-E18 controller, the same Gen4 silicon found in the Corsair MP600 PRO, Seagate FireCuda 530, and Kingston KC3000. The E18 is an 8-channel controller with triple ARM Cortex-R5 cores, 4th-generation LDPC error correction, and AES-256 hardware encryption, and its sequential read speeds reach 7,500 MB/s. The earlier CS3040 uses the first-generation Gen4 Phison PS5016-E16 and is rated at 5,600 MB/s; both carry AES-256 hardware encryption.
The primary failure mode on both drives is firmware corruption from sudden power loss. The controller maintains complex internal state during write operations, and a power cut mid-write leaves the FTL metadata in a state the boot firmware cannot resolve. The drive either disappears from BIOS, shows as an uninitialized device with 0 bytes capacity, or causes the system to hang during POST. Thermal stress under sustained sequential writes is a secondary failure trigger; the CS3140 ships with a heatsink on some SKUs, but many motherboard M.2 slots do not provide adequate airflow for Gen4 thermal requirements.
PC-3000 SSD handles the CS3040's PS5016-E16 through the Phison Utility. ACE Lab lists the CS3140's PS5018-E18 under its repair-only designation, so PC-3000 SSD does not rebuild the translator on that controller; recovery there depends on reviving the original silicon through board-level repair. When repair mode restores a drive to a bootable state, we image the full contents before returning it.
CS1030: DRAMless Gen3 and FTL Vulnerability
The PNY CS1030 uses the Phison PS5013-E13T, a 4-channel DRAMless NVMe Gen3 controller. PNY positions the CS1030 as an entry-level NVMe upgrade over SATA SSDs, and it is sold at price points where buyers do not expect (or think about) the reliability implications of DRAMless architecture. The E13T relies on Host Memory Buffer (HMB) for FTL caching, meaning the flash translation layer mapping table lives partially in host system RAM during operation.
DRAMless controllers are more vulnerable to FTL corruption from power loss than their DRAM-equipped counterparts. When a system crash or power failure occurs, the portion of the FTL cached in host RAM is lost. The controller must reconstruct its mapping table from metadata stored in NAND on the next boot. If the NAND metadata was also being updated when power was lost, the reconstruction fails, and the drive either disappears from BIOS or shows as an uninitialized device.
The E13T shares architectural DNA with the E12, but its reduced channel count (4 vs 8) and lack of DRAM make it a distinct recovery target. PC-3000 SSD's Phison module supports the E13T through the same diagnostic interface used for other Phison NVMe controllers. Recovery involves reading the NAND contents below the failed FTL layer and reconstructing the logical-to-physical mapping from page headers.
SSD Pricing
PNY SSD Recovery Pricing
SSD Recovery Calculator
Estimate Your PNY SSD Recovery Cost
What type of SSD do you have?
Shomari Hohn
Aravind Udayakumar
David Dachenhaus (DDock)
Ludwig Jonsson
LaCie
CS2230 / 2230 Form Factor: Steam Deck, PS5, ROG Ally
CS2230: M.2 2230 Failures in Steam Deck and PS5
The PNY CS2230 is an M.2 2230 NVMe SSD sold as an aftermarket upgrade for the Steam Deck, PlayStation 5, ASUS ROG Ally, and Microsoft Surface Pro. The compact 2230 form factor (22mm x 30mm vs the standard 2280's 22mm x 80mm) limits the PCB area available for components, which is why 2230 drives exclusively use DRAMless controllers with HMB-dependent FTL caching.
Steam Deck failures are the most common CS2230 recovery scenario we see. The Steam Deck's suspend/resume cycle creates repeated partial power transitions that stress the FTL metadata. A system crash during resume from sleep can leave the FTL in an inconsistent state because the controller expected to find its cached mapping table in host RAM, but the RAM contents were lost during the crash. The drive may boot successfully on the next attempt if only the cached portion was affected, or it may fail to initialize if the NAND-resident metadata was also being updated.
PS5 installations face a different risk profile. The PS5's M.2 slot runs at Gen4 speeds with limited cooling in a confined compartment. Thermal throttling during large game installations can trigger the same firmware corruption pattern seen in desktop Gen4 drives: the controller's thermal protection logic executes an emergency shutdown mid-write, corrupting FTL metadata in NAND.
PC-3000 SSD support for DRAMless Phison 2230 controllers is under active development. We evaluate each CS2230 honestly: if the current tooling does not support the specific firmware revision on your drive, we will tell you rather than accept a drive we cannot work on.
CS3030 / E12 Gen3
CS3030: Phison E12 Gen3 Recovery
The PNY CS3030 uses the Phison PS5012-E12, the most commercially successful NVMe Gen3 controller. The same silicon powers the Corsair MP510, Sabrent Rocket, and Seagate BarraCuda 510. The E12 is an 8-channel controller with DRAM cache and AES-256 hardware encryption. It has mature PC-3000 support through the Phison NVMe module in SSD Extended.
E12 failure modes are well-documented: firmware corruption from unclean shutdown is the primary cause. The drive disappears from BIOS or drops offline under load. Some units show as an unallocated RAW volume after a system crash. PC-3000 accesses the E12 through Phison's diagnostic mode, reads the firmware state, repairs or replaces corrupted FTL modules, and images the NAND contents to a target drive. E12 recovery is among the more straightforward NVMe procedures because the controller has been in production since 2018 and has mature PC-3000 Phison module coverage.
Controller Architecture Grid
PNY SSD Controller Map
XLR8 CS3140 (E18) and CS3040 (E16)
Gen4 NVMe x4, 8-channel with DRAM, AES-256 + TCG Opal 2.0. The CS3140's E18 is a triple ARM Cortex-R5 design with 4th-gen LDPC; the CS3040 uses the earlier first-generation Gen4 E16. Firmware panic from power loss is the primary failure mode.
CS3030: Phison E12
Gen3 NVMe x4. 8-channel with DRAM. AES-256 encryption. Most commercially successful Phison NVMe controller. Full PC-3000 support. Firmware corruption from power loss is the primary failure mode. Mature recovery toolchain.
CS1030: Phison E13T
Gen3 NVMe x4. 4-channel. DRAMless (HMB). M.2 2280. Entry-level NVMe. FTL corruption from power loss is the primary vulnerability due to HMB-dependent mapping table. AES-256 encryption makes chip-off not viable.
CS2230: DRAMless Phison
NVMe Gen3 x4. M.2 2230 form factor. DRAMless (HMB). Common in Steam Deck, PS5, ROG Ally, and Surface Pro upgrades. PC-3000 support for newer DRAMless Phison 2230 controllers is under active development. Suspend/resume FTL corruption is the primary failure pattern.
CS1311 and CS2211: Phison S10
SATA 6Gbps. 8-channel with DRAM. Legacy models using BCH error correction (weaker than LDPC). Vulnerable to uncorrectable bit errors as 3D TLC NAND wears. PC-3000 SATA Phison utility. Chip-off viable but data scrambling must be reversed.
NAND Supplier Variance
PNY does not manufacture NAND flash. They purchase NAND from Micron, Kioxia (formerly Toshiba), and SK Hynix.
This matters for recovery because NAND supplier differences affect data scrambling patterns, page sizes, spare area layouts, and error correction parameters. PC-3000 SSD detects the NAND configuration automatically when connected through the Phison diagnostic interface, but the technician needs to verify that the detected NAND parameters match the physical NAND packages on the PCB. A mismatch between the firmware's expected NAND configuration and the actual NAND installed (which can happen if a previous repair attempt installed the wrong firmware) will cause read errors during recovery.
AES-256 and Chip-Off
Encryption and Why Chip-Off Does Not Work on PNY NVMe SSDs
Every Phison NVMe controller used in PNY SSDs (E12, E13T, E16, E18) implements AES-256 hardware encryption. Data written to the NAND is encrypted with keys generated by the controller during manufacturing and stored in a protected area of the controller's internal ROM. This is why chip-off recovery is marked as "not viable" for every Phison NVMe controller in our recovery database.
PNY SSD Recovery FAQ
My PNY CS3040 disappeared from BIOS after a power outage. Can you recover it?
The CS3040 uses the first-generation Gen4 Phison PS5016-E16 controller with AES-256 hardware encryption. Power loss during a write operation can corrupt the controller firmware and flash translation layer, and the controller cannot boot past corrupted firmware modules, so the drive drops from BIOS detection entirely. PC-3000 SSD accesses the E16 through its vendor-specific diagnostic interface to rebuild the FTL and extract data from NAND. Firmware-level recovery is listed as $900–$1,200.
Can you recover data from a PNY CS2230 that failed in my Steam Deck?
The PNY CS2230 is an M.2 2230 NVMe SSD sold as an upgrade for Steam Deck, PS5, ROG Ally, and Surface Pro devices. It uses a DRAMless Phison controller that relies on Host Memory Buffer (HMB) for FTL caching. When the host system crashes or loses power, the FTL mapping table can become inconsistent because part of it lived in system RAM. PC-3000 SSD support for newer DRAMless Phison 2230 controllers is under active development. We evaluate each drive honestly and provide an upfront assessment of whether current tooling supports your specific firmware revision.
How much does PNY SSD data recovery cost?
PNY SSD recovery pricing follows our published SSD tiers. SATA (CS900, CS1311): simple-copy $200, file-system From $250, PCB $450–$600, firmware $600–$1,200, PCB/NAND swap $1,200–$1,500. NVMe (CS3040, XLR8 CS3140, CS3030, CS1030, CS2230): simple-copy $200, file-system From $250, PCB $900–$1,200, firmware $900–$1,200, PCB/NAND swap $1,200–$2,500. Free evaluation with no diagnostic fees. No data, no fee guarantee on every recovery.
Is chip-off recovery possible on PNY NVMe SSDs?
Chip-off is not viable on any PNY NVMe SSD. Every Phison NVMe controller (E12, E13T, E16, E18, E21T) implements AES-256 hardware encryption with keys bound to the controller silicon. Board-level repair to revive the original controller is the only path when firmware-level PC-3000 access fails.
Why does PNY use different controllers across their SSD lineup?
PNY does not manufacture SSD controllers or NAND flash. They source controllers from Phison across all product tiers: E13T for entry NVMe Gen3 (CS1030), E12 for midrange Gen3 (CS3030), E16 for Gen4 (CS3040), E18 for Gen4 (XLR8 CS3140). NAND comes from Micron, Kioxia, or SK Hynix. The controller determines which PC-3000 module and firmware version we need.
Send Us Your PNY SSD
Free evaluation. Firm quote. No data, no fee. Ship your PNY SSD to our Austin lab.
