Samsung Data Recovery
We recover data from Galaxy phones that will not power on, have a dead or broken screen, or got wet, and from Samsung SSDs and SpinPoint hard drives. Every one of them is worked at our Austin, TX lab, and service is mail-in from anywhere in the country. Samsung makes SSDs. It made SpinPoint hard drives until it sold its hard drive business to Seagate in 2011. ACE Lab's PC-3000 SSD supports the older Samsung SATA controller families; the in-house controllers in the 860 through 990 drives are not on that list, so those cases run as imaging and board-level repair of the original drive.
Phones From $500 | HDD From $100 | SSD From $200 | No Data, No Fee | Since 2008
Samsung Devices We Recover
Galaxy Phones
Phones that will not power on, boot loop, have a dead screen, or got wet
SSD Product Lines
860 EVO/PRO, 870 EVO, 980, 980 PRO, 990 PRO, 970 EVO/EVO Plus, T7 Portable
HDD Product Lines
SpinPoint F3, F4, and M8
Drive work runs in-house on PC-3000 Express and PC-3000 Portable III
Galaxy Phones
Galaxy Phone Data Recovery
A Galaxy that will not power on almost always has a board fault, not erased data: the encrypted files sit intact in the storage chip while a power, charging, or corrosion fault blocks the boot. We repair the board so the phone runs again and decrypts its own data when you enter your own PIN, pattern, or password, and a broken screen changes how you reach the files, not whether they are there. A forgotten screen lock, Factory Reset Protection and the Knox fuse are not something a repair gets past, and on an encryption-era Galaxy pulling the storage chip off the board returns only ciphertext.
If the phone got wet, stop charging it and stop turning it on. Permanently deleted files on a modern Galaxy's internal storage are gone, and no scan and no desktop recovery program brings them back. On a working, unlocked phone, check the Samsung Gallery trash, which holds items about 30 days, along with the My Files trash and your cloud accounts first, because a trashed item was never actually deleted.
While the phone still works, Samsung gives the backup and restore steps in Samsung's support article on backing up and restoring a Galaxy phone. Galaxy phone recovery is $500–$750, one range quoted firm after the evaluation. No data, no fee. Free evaluation. No diagnostic charges. Start on the Android and Samsung phone recovery page, or go straight to the page for the fault or the model you have.
Updated September 2026
8 min read
Samsung Drive Recovery Process
How Samsung Drive Recovery Works
Samsung data recovery requires different tools depending on whether the failed drive is an SSD or a hard drive. ACE Lab's PC-3000 SSD has no firmware-level loader or FTL-rebuild path for the in-house controllers in the 860 through 990 drives, so those cases run as imaging and board-level repair of the original drive. SpinPoint hard drives are worked in the same Austin lab, on PC-3000 Portable III and PC-3000 Express hardware. We evaluate your drive for free and charge nothing if we cannot recover your data.
Samsung SSD Recovery Overview
Samsung SSDs use Samsung's own controllers. Each controller handles firmware, wear leveling, and error correction differently, which means the SSD recovery approach changes with each generation. Our Samsung SSD data recovery page covers the product lines and the controller in each one.
ACE Lab's PC-3000 SSD supports the older Samsung SATA drives (470, 830, 840, 840 PRO, 840 EVO, 850 PRO). The in-house controllers in the 860, 870, 970, 980, and 990 series are not on that list, so there is no firmware-level or FTL-rebuild path for them; those drives are imaged while they still respond and otherwise go to board-level repair of the original drive.
Samsung's support article Avoid data loss on your Samsung Solid State Drive (SSD) names three warning signs that an SSD is failing: “Fails to save, move, or read files”, “Computer crashes on boot up”, and “Has S.M.A.R.T. errors”.
Those controllers are not on ACE Lab's PC-3000 SSD supported-controller list. The lab takes these drives case by case: one that still enumerates may need only a logical recovery, and on the 970, 980, and 990 families PC-3000 can sometimes read a drive a normal computer will not see.
SSD Pricing
Samsung SSD Recovery Pricing
SSD Recovery Calculator
Estimate Your Samsung SSD Recovery Cost
What type of SSD do you have?
Samsung HDD Recovery Overview
Samsung SpinPoint Hard Drive Recovery
Samsung sold its hard disk drive business to Seagate in December 2011; the sale included the M8 line of 2.5-inch laptop drives.
SpinPoint drives are worked on the PC-3000 in our Austin lab; ACE Lab publishes Samsung-specific PC-3000 for HDD procedures for them.
For drives with mechanical damage, we perform head swaps on our 0.02 micron ULPA-filtered clean bench.
HDD Pricing
Samsung HDD Recovery Pricing
Video
Samsung Magician Said This Samsung 970 EVO Was OK, and It Was Wrong
A Samsung 970 EVO passed Samsung Magician diagnostics but had bad sectors. PC-3000 found what the OEM tool missed. This is why we use professional-grade firmware tools instead of relying on manufacturer utilities.
What Customers Say About Our Lab
Shomari Hohn
Aravind Udayakumar
David Dachenhaus (DDock)
Ludwig Jonsson
LaCie
Samsung SSD Controller Architecture
Samsung SSD Controller Architecture and Recovery Methods
MKX Controller
Powers the 870 EVO. The 860 EVO and 860 PRO used the earlier MJX controller. Neither is on ACE Lab's PC-3000 SSD supported list, so there is no utility-driven FTL rebuild; recovery is board-level repair of the original drive.
MKX recovery details
970 Series Controller
Powers the 970 EVO. Hardware encryption makes chip-off not viable, so the route to the data is board-level repair that brings the original controller back.
970 series controller reference
Elpis Controller
Powers the 980 PRO. Hardware-bound encryption makes chip-off not viable. Recovery means repairing the board until the original controller boots again.
Elpis recovery details
990 PRO Controller
Powers the 990 PRO. Recovery is board-level repair of the original drive.
Pablo Controller
Powers the Samsung 980. Not on ACE Lab's PC-3000 SSD supported list; recovery is board-level repair to keep the original controller, which holds the AES key, alive.
Pablo recovery details
870 EVO
The 870 EVO uses the MKX controller.
870 EVO recovery details
Software Recovery Limits
When Software Recovery Works on Samsung SSDs
Recovery software like Disk Drill, EaseUS, PhotoRec, & R-Studio works when a Samsung SSD is physically healthy but has a logical problem: an accidentally deleted partition, a corrupted file system, or a formatted volume where TRIM hasn't yet executed on the target blocks.
Software can't help when the controller is dead, the firmware is corrupted, or the PMIC has shorted. A drive that won't enumerate in BIOS is invisible to every software tool on the market. At that point the recovery is board-level repair of the original drive.
TRIM is a logical unmap: the OS tells the controller which blocks hold deleted data, and on drives that report zeros for unmapped blocks, recovery software reads only zeros from that point on. The NAND keeps the old data until garbage collection erases the block, and logical recovery software cannot reach it.
Chip-off and Encryption
Chip-Off Recovery and Samsung Encryption
Chip-off recovery (desoldering NAND chips and reading them on a standalone programmer) is a last resort on unencrypted drives whose controller's scrambling and error correction can be reproduced.
Samsung's in-house NVMe controllers enforce always-on AES-256 hardware encryption with the key generated on the controller die, and the Pablo controller likewise holds the AES key on the controller. If that controller is dead and cannot be revived through board-level repair, the data is encrypted at rest and chip-off yields only ciphertext.
This is why we prioritize board-level repair: reviving the original controller preserves access to the hardware encryption key. Our microsoldering workstations handle BGA rework, PMIC replacement, and voltage rail repair on Samsung SSD PCBs.
Samsung Data Recovery FAQ
Can Samsung Magician recover my data?
No. Samsung Magician is a drive health monitoring and firmware update tool. It cannot recover files from a failed drive.
My Samsung SSD firmware update bricked my drive. Can you fix it?
PC-3000 SSD has no firmware-level loader or FTL-rebuild path for the Elpis controller, so the honest workflow is imaging the drive while it still responds, then board-level work if it does not. NVMe firmware recovery runs $900–$1,200.
Do you recover Samsung SpinPoint hard drives?
Yes. Samsung sold its hard disk drive business to Seagate in December 2011, and we still take in SpinPoint F3, F4, and M8 drives. HDD recovery starts at $100 for simple copies, with firmware repair at $600–$900.
How much does Samsung SSD recovery cost?
Samsung SSD recovery ranges from $200 for a simple data copy to $1,500 for advanced work on SATA drives and $2,500 on NVMe drives. Circuit board repair runs $450–$600 on SATA drives and $900–$1,200 on NVMe drives. Firmware corruption costs $600–$1,200 on SATA drives and $900–$1,200 on NVMe drives. Advanced PCB and NAND swap work is $1,200–$1,500 on SATA drives and $1,200–$2,500 on NVMe drives. Free evaluation with no diagnostic fees.
Is chip-off possible on Samsung SSDs?
Chip-off is a last resort on unencrypted drives whose controller's scrambling and error correction can be reproduced. Samsung's in-house NVMe controllers such as Elpis enforce always-on AES-256 hardware encryption with the key generated on the controller die, and the Pablo controller likewise holds the AES key on the controller. If that controller is dead and cannot be revived through board-level repair, chip-off yields only ciphertext. The Samsung MJX, MKX, Elpis and Pablo controllers are not on ACE Lab's PC-3000 SSD supported-controller list, and those drives are taken case by case: one that still enumerates may need only a logical recovery.
Can data be recovered from a dead Samsung SSD?
Yes. Board-level repair revives the original controller so it can decrypt & read the NAND contents. Circuit board repair on SATA Samsung SSDs runs $450–$600; NVMe models run $900–$1,200. Free evaluation, no diagnostic fee.
Send Us Your Samsung Device
Free evaluation. No data, no fee. Ship your Galaxy phone, Samsung SSD, or SpinPoint HDD to our Austin lab.
