Lab Operational Since: 17 Years, 6 Months, 3 DaysFacility Status: Fully Operational & Accepting New Cases
Native USB SSD Controller Data Recovery
Native USB SSD controllers integrate the USB 3.2 PHY directly into the SSD controller silicon. There is no SATA or NVMe interface to bypass & no internal drive to remove. Recovery runs through PC-3000 Portable III over the USB protocol. Examples: Silicon Motion SM2320G in the Kingston DataTraveler Max, & Phison PS2251-U17 in several portable SSD designs.
Author01/12
Updated 2026-05-03
What Is A Native USB SSD Controller02/12
What Is a Native USB SSD Controller?
A Native USB SSD controller is a single chip that runs the SSD firmware & speaks USB 3.2 directly. The USB 3.2 PHY, the FTL engine, the LDPC error-correction logic, & the NAND command interface all live on the same silicon die. There is no separate USB bridge chip & no internal SATA or NVMe interface anywhere in the drive.
Most portable SSDs from 2017 onward took a different approach: they paired a real NVMe SSD with a USB bridge IC like the ASMedia ASM2362 or JMicron JMS583. The internal NVMe controller did the FTL work. The bridge translated NVMe commands into USB Mass Storage with UASP. Two silicon dies, two failure points, two recovery paths.
Native USB designs collapse that into one. Silicon Motion shipped the SM2320G in 2021 with USB 3.2 Gen2x2 (20 Gbps) right on the controller; Kingston used it in the DataTraveler Max. Phison shipped the PS2251-U17 with similar integration for its U- series portable SSD & high-capacity USB drive customers.
The integration improves cost, board area, & thermal density. It also rewrites the recovery rulebook: there is no internal drive to pull out, no PCIe link to attach, & no second controller to fall back on. The Native USB controller is the entire data path.
Native USB Vs USB Bridge03/12
How Does Native USB Differ From a USB Bridge Architecture?
Bridge-based portable SSDs use two chips: a real SSD (SATA or NVMe) & a separate USB bridge IC. Native USB SSDs use one chip that does both. This single-die vs two-die distinction determines whether the internal drive can be removed for direct imaging or whether recovery has to go through the USB protocol.
Knowing which architecture is inside the enclosure is the first diagnostic step at the bench.
AspectUSB Bridge ArchitectureNative USB Architecture
Silicon diesTwo: SSD controller + bridge ICOne: integrated USB SSD controller
Internal protocolSATA or NVMe between the SSD & the bridgeNone; NAND is wired directly to the controller
Bridge bypass possibleYes on non-encrypted models; pull the M.2 drive & use a PCIe adapterNo; there is no internal drive to bypass to
Recovery interfaceBridge bypass to PCIe (non-encrypted) or bridge repair (encrypted)PC-3000 Portable III over the USB protocol
Hardware encryptionOptional; lives in the internal NVMe controller (WD My Passport, SanDisk Extreme)Common; AES-256 with the cryptographic key locked inside the Native USB controller silicon
Common bridge chipsASMedia ASM2362, ASM2364, ASM235CM, JMicron JMS578, JMS583, Realtek RTL9210Silicon Motion SM2320G, Phison PS2251-U17, PS2251-U18
Example drivesSamsung T7, T7 Shield, T9, SanDisk Extreme Portable V2, Crucial X8, WD My Passport SSD, Seagate One Touch SSDKingston DataTraveler Max, certain Phison-based portable SSDs & high-capacity USB drives
For a deeper look at the bridge side of the table, see our external SSD recovery guide. Bridged drives are not the focus of this page.
Which Drives Use Native USB Controllers04/12
Which Portable Drives Use Native USB Controllers?
Most portable SSDs sold under the consumer brands use a bridge architecture. Native USB controllers show up most consistently in the Kingston DataTraveler Max family & in OEM portable SSDs built on Phison U-series reference designs.
The list below is the conservative one. If a vendor revises a SKU mid-life & switches between Native USB & bridge silicon, the controller has to be confirmed at the bench during the free evaluation.
Drive FamilyArchitectureController / BridgeRecovery Approach
Kingston DataTraveler MaxNative USBSilicon Motion SM2320GPC-3000 Portable III over USB
Phison U-series portable SSDs & high-capacity USB drivesNative USBPhison PS2251-U17 / U18PC-3000 Portable III over USB
Samsung T7 / T7 ShieldBridgedSamsung NVMe controller + ASMedia ASM2362Bridge bypass not viable on Samsung due to integrated PCB; bridge repair on original board
Samsung T9BridgedSamsung NVMe controller + ASMedia ASM2364Bridge repair on original board
SanDisk Extreme Portable V2BridgedWestern Digital NVMe controller + ASMedia ASM2362Bridge repair required; AES-256 binds NVMe controller to original bridge
WD My Passport SSDBridgedWD SN550E NVMe controller + ASMedia ASM2362Bridge repair required; encryption blocks bypass & chip-off
Crucial X8Mixed by capacity1 TB & 2 TB: Crucial P1 NVMe + ASMedia ASM2362; 4 TB: Native USB Phison PS2251-U171-2 TB: bridge bypass to PCIe imaging; 4 TB: PC-3000 Portable III over USB
Crucial X6Mixed by SKUEarly 500 GB / 1 TB / 2 TB: Silicon Motion SM2259XT SATA + ASMedia ASM235CM bridge; later revisions (incl. 4 TB): Native USB Phison PS2251-U17Confirmed at bench during free evaluation
ADATA SE800 / SE760BridgedM.2 NVMe drive + ASMedia ASM2362Bridge bypass to PCIe imaging
Bridge-architecture drives in the table are listed for contrast; their detailed recovery workflow lives on the external SSD recovery page. The rest of this page focuses on Native USB silicon.
Why Won't a SATA-to-USB or M.2-to-PCIe Adapter Work?
Adapters expose an existing interface to the host. A Native USB SSD controller does not have an exposed SATA or NVMe interface anywhere on the PCB; the USB pins on the connector are the only host interface. Plugging the NAND chips into a SATA port is not a thing the silicon supports, & there is no PCIe link to feed an NVMe adapter.
On a bridged design, the recovery shortcut is well known: open the enclosure, pull the M.2 NVMe drive, plug it into a PCIe-to-USB or motherboard M.2 slot, & image it. The bridge becomes irrelevant once it is out of the data path. That works because the M.2 module is a complete NVMe SSD on its own.
On a Native USB design, the controller is soldered to the same PCB as the NAND. There is no module to pull. The controller drives the NAND over its own internal channel interface (Toggle DDR or ONFI), which is not exposed on any external pin. The only way to talk to the firmware is through USB.
That is why this page exists. PC-3000 Portable III ships with USB-protocol diagnostic modules for both the Silicon Motion & the Phison Native USB controller families, & that is the tool that does the work.
Pricing05/12
How Much Does Native USB SSD Recovery Cost?
Native USB SSD recoveries map to our NVMe SSD pricing tiers because the controller runs the same workloads as a discrete NVMe SSD: FTL maintenance, LDPC error correction, hardware AES-256, & SLC cache folding on TLC or QLC NAND. Pricing runs $200–$2,500 across five tiers.
Most cases land in the firmware tier at $900–$1,200 or the circuit board repair tier at $600–$900. A drive with a functional controller & logical-only damage stays in the simple-copy or file-system tier. From $200.
A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers. +$100 rush fee to move to the front of the queue. Free evaluation, firm quote before any work begins, & no recovery fee if we cannot extract the data.
NVMe SSD Pricing (Native USB Controllers)
The destination drive we copy recovered data onto. You can supply your own or we provide one at cost plus a small markup. All prices are plus applicable tax.
SATA SSD Pricing (Older Bridged Drives For Reference)
Native USB Controller Failure Modes06/12
What Goes Wrong on a Native USB SSD Controller?
Failure modes on a Native USB SSD controller cluster into four groups: physical connector damage, voltage damage, firmware module corruption, & NAND degradation. Each one needs a different tool path. Diagnosing which group a drive falls into is the first job at the bench.
USB Enumeration Failure
The controller will not advertise itself on the USB bus. Device Manager shows nothing, or it shows an unknown USB device with a vendor ID of 0x0000. The drive may draw current & warm up, but it never enumerates.
Two root causes: a dead controller or dead power delivery. FLIR thermal imaging separates the two within a minute. A shorted PMIC or a blown LDO shows up as a hot spot under bus power; a silent thermal map points back at the controller silicon itself or at the USB-C signal lines.
USB Mass Storage with 0 Bytes Capacity
The drive enumerates as a USB Mass Storage device but reports zero addressable capacity. Disk Management shows it, Device Manager sees it, & the operating system never assigns a usable drive letter. This is a controller firmware panic.
The mask ROM ran & got far enough to negotiate USB enumeration. The firmware modules in NAND failed integrity checks, so the FTL never loaded. PC-3000 Portable III enters Safe Mode through vendor-specific commands & rebuilds the FTL from raw NAND metadata. This is the same recovery class as the "wrong capacity" firmware panics seen on internal NVMe drives.
Wrong Capacity / Wrong ID
The drive shows up at 2 MB, 8 MB, or its raw silicon model name (for example "SM2320" or "PS2251") instead of the retail product string. This indicates the controller booted from mask ROM but cannot read its firmware overlays from NAND.
On a Phison PS2251-U17, the analogous fallback string is the raw controller ID; on a Silicon Motion SM2320G, the controller exposes a generic factory descriptor. PC-3000 Portable III responds the same way it does on the internal NVMe equivalents: vendor-specific commands push the controller into a diagnostic mode & a volatile loader reads NAND past the bricked firmware.
Firmware Module Corruption After Surge or Disconnect
A surge event or a sudden disconnect mid-write can sever the firmware journal in NAND. Native USB controllers run the same SLC-cache-to-TLC fold cycle as their NVMe cousins, so an interrupted fold leaves the FTL inconsistent.
Recovery requires reading the surviving SLC journal pages, reconciling them against the TLC main map, & rebuilding the translator in host RAM. PC-3000 Portable III does this with controller-specific utilities; the operation runs for hours per terabyte on a healthy NAND, longer when read errors force retry-with-shifted-voltage cycles.
NAND Read-Disturb in Compact Portable Enclosures
Native USB drives are physically small. A Kingston DataTraveler Max is barely larger than a thumb drive, & the SM2320G runs hot under sustained writes. Heat accelerates charge migration in TLC & QLC cells, raising the read-error rate the longer a drive sits in a hot environment.
Symptoms: slow reads, files that hash differently across passes, & rising LDPC correction counts. Recovery is still possible, but the imaging strategy shifts. We read the healthy regions first & come back to the marginal blocks with adjusted voltage thresholds before the cells degrade further from repeated read-disturb.
PC-3000 Portable III USB Workflow07/12
How Does PC-3000 Portable III Recover Data Over the USB Protocol?
PC-3000 Portable III ships with utility modules that talk to specific controller families: a Silicon Motion utility for the SM2320G, a Phison utility for the U-series. The workflow looks similar to the NVMe firmware recovery work we do on internal drives, with two key differences: the host interface is USB, & the diagnostic entry sequence uses USB vendor-specific commands instead of NVMe Admin commands.
  1. Identify the controller via USB descriptors. PC-3000 reads the USB vendor & product ID strings, the device class descriptor, & any vendor-specific descriptors the controller exposes in mask ROM mode. This confirms which utility module to load: Silicon Motion or Phison.
  2. Enter Safe Mode / Technological Mode. For controllers that boot normally but fail past mask ROM, PC-3000 issues vendor-specific USB commands to halt the firmware boot sequence. For controllers that will not boot at all, physical test-pad shorting on the PCB forces the controller into diagnostic mode during power application. The shorted pads are then released so PC-3000 can upload its volatile loader.
  3. Inject a volatile loader into controller SRAM. The loader is a small operating system that runs in SRAM only; nothing is written to NAND. The loader disables background operations like garbage collection & TRIM & exposes raw NAND access through the USB interface.
  4. Map NAND health. PC-3000 scans every block for read errors, ECC failures, & bad-block markers. The map drives the imaging strategy: healthy regions image first; marginal regions get retry-with-adjusted-voltage passes.
  5. Build a virtual translator in host RAM. The loader walks the NAND spare areas to extract LBA tags, sequence numbers, & block-pair metadata. The PC-3000 host workstation reconstructs the FTL in its own RAM & uses it to translate physical pages back into logical sectors. SLC-cache journals get reconciled against TLC main-map blocks where the firmware fold was interrupted.
  6. Image the logical view. With the virtual translator built, PC-3000 streams logical sectors out to a forensic image. We verify file system integrity, copy the data to a target drive, & ship it back.
Why Hardware Encryption Forces Original-Controller Recovery
Modern Native USB SSD controllers run AES-256 media encryption with the cryptographic key locked inside the controller silicon. Every NAND page is encrypted before it lands in flash. Removing the NAND chips with chip-off equipment yields raw ciphertext & the key never leaves the dead controller.
The recovery path is reviving the original controller so it decrypts during normal reads. This is legal board repair, not security circumvention. We restore the hardware so the controller does what it was designed to do; the encryption layer is transparent in the data path. See our hardware encryption recovery page for the broader explanation.
Why TRIM Still Limits What We Can Recover
Native USB SSD controllers honor TRIM on most host operating systems through UASP. If files were deleted on a healthy drive & the host issued TRIM, the controller unmapped & eventually erased those LBAs. No lab can reverse a TRIM-then-erase sequence; the cells are physically zero. See our TRIM & garbage collection page for the engineering detail.
USB-C Connector And TVS Diode Repair08/12
Why Are USB-C Connector & TVS Diode Failures the #1 Cause of Dead Portable SSDs?
Portable SSD PCBs are dense, & the USB-C connector is the most stressed component on the board. Every plug cycle stresses the surface-mount pads. Drops shear the connector off. Bus-power spikes blow the TVS diodes that are supposed to protect the controller from VBUS overvoltage events. We see all three of these patterns more often than every other Native USB failure combined.
USB-C Connector Pad Tear-Out
A drop on the USB-C end of a Kingston DataTraveler Max can shear the connector housing & lift its surface-mount pads off the PCB. Sometimes the copper traces tear off with them. The drive is electrically dead even though the controller silicon & the NAND are intact.
Repair is microsoldering work. Hakko FM-2032 on an FM-203 base station handles the precision soldering for individual pad jumpers; Atten 862 hot air handles the connector desolder & the new connector installation. We run jumper wires from surviving trace stubs to the replacement connector pads when the original copper has torn off the board.
TVS Diode Failures Under VBUS Surge
The reference design for a Native USB SSD board includes TVS (transient voltage suppressor) diodes across the VBUS line & across the USB 3.x differential pairs. Their job is to clamp surges before they hit the controller. When a host port delivers a glitchy 5V rail or a hot-plug event spikes VBUS, the TVS diode either clamps the spike & survives or fails short to ground.
A shorted VBUS TVS diode pulls the 5V rail down. The host port refuses to power the drive, sometimes resetting itself. FLIR thermal imaging finds the shorted diode in seconds. We desolder the failed diode & replace it with the correct part. Bridge board repair tier on a Native USB drive falls under $600–$900.
Power Rail Damage From Unstable Hosts
A failing laptop battery, a cheap unpowered USB hub, or a damaged cable can deliver erratic VBUS to a portable SSD. The board's onboard LDOs derive 3.3V & 1.2V for the controller core; a glitchy 5V rail can fry an LDO. The drive draws no power after that & never enumerates.
FLIR thermal imaging locates the burned regulator. Hakko FM-2032 swaps it with the correct part. The NAND & the controller silicon are usually unaffected because the LDOs absorb the damage before it reaches them. Bridge-tier pricing applies.
Diagnostic Symptom Matrix09/12
What Does Your Native USB SSD Symptom Mean?
The symptom the host reports points directly at the failure layer. A drive that does not enumerate at all is a power or controller fault. A drive that enumerates but reports zero or wrong capacity is a firmware or FTL fault. The matrix below maps each symptom to its likely cause, the recovery approach, & the typical cost tier.
SymptomLikely CauseRecovery ApproachTypical Cost Tier
Drive does not enumerate; nothing in Device ManagerDead controller, shorted PMIC, blown LDO, or torn USB-C padsFLIR thermal diagnosis, Hakko FM-2032 component-level repair, USB-C replacement$600–$900
Enumerates as USB Mass Storage with 0 bytes / No MediaController firmware panic; mask ROM ran but FTL did not loadPC-3000 Portable III Safe Mode entry; volatile loader injection; FTL rebuild$900–$1,200
Reports raw controller ID (e.g. "SM2320" or "PS2251") instead of brand nameService Area read failure; firmware overlays unreadablePC-3000 Portable III utility module; vendor-specific Safe Mode; SA module reconstruction$900–$1,200
Reports 2 MB or 8 MB capacity instead of advertised sizeInterrupted SLC-to-TLC fold; FTL journal severedVirtual translator construction in host RAM; SLC journal reconciliation$900–$1,200
Drive disconnects mid-transfer under sustained writeThermal throttling on dense controller; stressed solder jointsFLIR thermal profiling; Zhuo Mao BGA reflow if joints fractured$600–$900
Drive draws power, gets warm, never enumeratesShorted VBUS TVS diode or shorted onboard regulatorFLIR thermal localization; component swap with Hakko FM-2032 & Atten 862$600–$900
We confirm the symptom-to-cause mapping during free evaluation at our Austin, TX lab before any work begins. No diagnostic fee. If we cannot recover the data, you do not pay.
Board Level Microsoldering10/12
Why Does Board-Level Microsoldering Matter for Native USB SSD Recovery?
Most data recovery labs are equipped for firmware-level work with PC-3000 but not for component-level soldering. When a Native USB SSD fails on the connector, the TVS diode, or a power rail, those labs either outsource the board repair or declare the drive unrecoverable. We do the soldering in-house in Austin, TX.
Board-level repair is the foundation of this shop, dating back to MacBook logic board repair since 2008.
For Native USB drives with hardware AES-256, board repair IS data recovery. The encryption key lives inside the controller silicon & never leaves it. If we cannot get the original controller back online, the data stays encrypted. PC-3000 has no path to ciphertext on a dead controller.
FLIR thermal cameras locate shorted or failed components in seconds. Hakko FM-2032 microsoldering irons on FM-203 or FX-951 base stations handle the precision work: 0201 capacitors, 0402 voltage regulators, USB-C pad jumpers. Atten 862 hot air handles connector desolder & QFN package replacement. Zhuo Mao precision BGA rework stations handle controller reballing when thermal cycling has fractured the solder joints under the SM2320G or PS2251-U17 package.
Single location in Austin. No outsourcing. The technician who diagnoses your drive is the technician who solders the repair & runs the PC-3000 imaging session. See our SSD electrical failure page for the broader board-repair methodology, & the firmware corruption page for what happens once the board is back online.
Controller Family Reference11/12
Controller Family Detail Pages
The PC-3000 utility modules used on Native USB controllers share their codebase with the modules used on internal SATA & NVMe drives from the same silicon vendor. The deeper architectural detail lives on the per-vendor pages.
Faq12/12
What is a Native USB SSD controller?
A Native USB SSD controller integrates the USB 3.2 PHY directly into the SSD controller silicon. The chip presents NAND flash to the host as a USB Mass Storage device with no underlying SATA or NVMe interface. Examples include the Silicon Motion SM2320G in the Kingston DataTraveler Max & the Phison PS2251-U17 in several portable SSD designs. Bridge-based portable SSDs are different: they pair a SATA or NVMe SSD with a separate USB bridge IC.
Why won't a SATA-to-USB or M.2-to-PCIe adapter work on these drives?
Because there is no SATA or NVMe interface inside the controller. A Native USB SSD controller speaks USB protocol natively at the silicon level. There is no internal SATA bus to attach a SATA cable to & no PCIe lanes to plug into an NVMe adapter. Recovery has to talk to the controller over USB, which is what PC-3000 Portable III is designed to do for these chip families.
Is a Kingston DataTraveler Max the same as a Samsung T7 or SanDisk Extreme?
No. The Kingston DataTraveler Max uses the Silicon Motion SM2320G, a Native USB controller with no internal SATA or NVMe interface. The Samsung T7 & T7 Shield pair an internal NVMe controller with an ASMedia ASM2362 USB bridge; the SanDisk Extreme Portable V2 uses a Western Digital NVMe controller with an ASMedia bridge. Bridged designs sometimes allow internal-drive removal & direct PCIe imaging. Native USB designs do not.
How much does Native USB SSD controller recovery cost?
Native USB SSD recoveries fall under our NVMe SSD pricing tiers since the controllers handle the same firmware-level workloads as NVMe drives. Pricing runs $200–$2,500 across five tiers. Most cases land in the firmware tier at $900–$1,200 or the circuit board repair tier at $600–$900. Free evaluation. +$100 rush fee to move to the front of the queue.
What are the most common failure modes on portable SSDs with Native USB controllers?
Three patterns dominate: USB-C connector damage from drop or cable stress, voltage damage from a failing host port or cheap hub, & firmware module corruption after a sudden disconnect mid-write. The first two are board-level repair problems we fix with Hakko FM-2032 microsoldering. The third is a PC-3000 Portable III firmware repair using the Silicon Motion or Phison utility module that matches the controller.
Can chip-off recover data from a Kingston DataTraveler Max or Phison U17 drive?
Usually no. Modern Native USB SSD controllers apply hardware AES-256 encryption inside the controller silicon with the cryptographic key locked inside the controller itself. Desoldering the NAND yields ciphertext with no recoverable key. The recovery path is reviving the original controller so it can decrypt during normal reads. Chip-off only succeeds on older drives with no controller-side encryption.
How long does a Native USB SSD recovery take?
Standard turnaround is 2-6 weeks depending on the failure tier. USB-C connector repair is usually under 2 weeks. Firmware corruption with FTL reconstruction takes 3-6 weeks since virtual translator builds run for hours per terabyte on the PC-3000 host. +$100 rush fee to move to the front of the queue.
My drive shows up as USB Mass Storage with 0 bytes. What does that mean?
The controller booted from its mask ROM but couldn't load the firmware modules from NAND, so it presents a generic USB Mass Storage interface with no addressable capacity. On a Silicon Motion SM2320G or Phison PS2251-U17, this is a controller firmware panic. PC-3000 Portable III enters Safe Mode through vendor-specific commands & rebuilds the FTL from raw NAND metadata. Logical recovery software cannot help; the drive has nothing for the operating system to read.
Native USB portable SSD failed?
Silicon Motion SM2320G, Phison PS2251-U17, Kingston DataTraveler Max & related controllers. PC-3000 Portable III over USB. From From $200; firmware tier $900–$1,200; board repair $600–$900. Free evaluation, no data = no fee.
4.9★ · 1,837+ reviews
